DESCRIPTION: QUIK-LOQ - FEMALE - SOLDER CUP - PANEL MOUNT
UNITS = MM [INCHES]
CHARACTERISSTICS
MATERIALS
SHELL : BRASS
SHELL PLATING : NICKEL
NUT : BRASS
NUT PLATING : NICKEL
LATCH SLEEVE : BRASS
LATCH SLEEVE PLATING : NICKEL
CONTACTS : COPPER ALLOY
CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN.
INSULATOR : PPS (HIGH TEMPERATURE)
0.906 ±0.012
23.00 ±0.30
0.780
19.80
MECHANICAL
DURABILITY: 5000 CYCLES
OPERATING TEMP. RANGE: -40 C ~ +200 C
PROCESS TEMPERATURE : 260 C FOR 5 SECONDS
MAX. TORQUE VALUE : 6.0 Nm [53 IN/lbs]
SHIELDING: 75dB @ 10MHz
40dB @ 1GHz
0.787
20.00
0.531
13.50
(ACROSS FLATS)
M15*1.0
0.669
17.00
0.138
3.50
IP RATING: 50
0.177
4.50
(MAX. PANEL THICKNESS)
CHART A
1
822B YYY - 2 0 3 R 00 1
**VIEW FROM TERMINATION END**
= KEY LOCATION
1
1
# OF POSITIONS
(Ex. 002)
**SEE CHART A**
2 = FEMALE
1
1
1 = GOLD FLASH
SERIES
15.00 [0.591]
RoHS COMPLIANT
SOLDER CUP (PANEL MOUNT)
CONTACT
RESISTANCE = 3 mΩ
TEST VOLTAGE = 2100V
WORKING VOLTAGE = 700V
3 POSITION
18 AWG MAX.
17 AMP MAX.
PIN
= 1.60 [0.063]
CONTACT
RESISTANCE = 4 mΩ
TEST VOLTAGE = 2400V
WORKING VOLTAGE = 800V
4 POSITION
20 AWG MAX.
15 AMP MAX.
PIN
= 1.30 [0.051]
CONTACT
RESISTANCE = 5 mΩ
TEST VOLTAGE = 1850V
WORKING VOLTAGE = 615V
1
1
1
6 POSITION
20 AWG MAX.
12 AMP MAX.
PIN
= 1.30 [0.051]
8 POSITION
22 AWG MAX.
10 AMP MAX.
PIN
= 0.90 [0.035]
CONTACT
RESISTANCE = 5 mΩ
TEST VOLTAGE = 1350V
WORKING VOLTAGE = 450V
CONTACT
RESISTANCE = 6 mΩ
TEST VOLTAGE = 1500V
WORKING VOLTAGE = 500V
.1
15
1
1
1
10 POSITION
22 AWG MAX.
8 AMP MAX.
= 0.90 [0.035]
PIN
12 POSITION
24 AWG MAX.
7 AMP MAX.
PIN
= 0.70 [0.028]
14 POSITION
24 AWG MAX.
6.5 AMP MAX.
PIN
= 0.70 [0.028]
16 POSITION
24 AWG MAX.
6 AMP MAX.
PIN
= 0.70 [0.028]
19 POSITION
24 AWG MAX.
5 AMP MAX.
PIN
= 0.70 [0.028]
26 POSITION
28 AWG MAX.
2 AMP MAX.
PIN
= 0.50 [0.020]
CONTACT
RESISTANCE = 6 mΩ
TEST VOLTAGE = 1450V
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 1250V
WORKING VOLTAGE = 480V
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 1150V
WORKING VOLTAGE = 380V
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 950V
WORKING VOLTAGE = 315V
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 950V
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 950V
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF NorComp AND
SHALL NOT BE REPRODUCED, COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
NorComp
DRAWN:
M. SIGMON
4]
59
[0.
0.535
13.60
2 POSITION
16 AWG MAX.
25 AMP MAX.
PIN
= 2.00 [0.079]
NICKEL/CHROME PLATED SHELL
DATE:
02-05-16
PANEL CUTOUT
TOLERANCE = +0.10, -0.0
[+0.004, -0.00]
SCALE:
N.T.S.
SHEET
1
DWG NO.
OF
1
822BYYY-203R001
REV:
4
很抱歉,暂时无法提供与“822B004-203R001”相匹配的价格&库存,您可以联系我们找货
