822BR03-213R001
822BR03-213R001
    NORCOMP
    822BR03-213R001
822BR03-213R001 数据手册
DESCRIPTION: QUIK-LOQ - FEMALE - RIGHT ANGLE - PANEL MOUNT 0.787 20.00 0.256 6.50 (MAX. PANEL THICKNESS) 0.768 19.50 0.138 3.50 0.787 20.00 MECHANICAL DURABILITY: 5000 CYCLES OPERATING TEMP. RANGE: -40 C ~ +200 C PROCESS TEMPERATURE : 260 C FOR 5 SECONDS MAX. TORQUE VALUE : 6.0 Nm [53 IN/lbs] SHIELDING: 75dB @ 10MHz 40dB @ 1GHz 0.787 20.00 M15*1.0 0.530 13.46 UNITS = MM [INCHES] CHARACTERISSTICS MATERIALS SHELL : BRASS SHELL PLATING : NICKEL NUT : BRASS NUT PLATING : NICKEL LATCH SLEEVE : BRASS LATCH SLEEVE PLATING : NICKEL CONTACTS : COPPER ALLOY CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN. INSULATOR : PPS (HIGH TEMPERATURE) 2.00 [0.079] IP RATING: 50 822B R YY - 2 1 3 R 00 1 1 = GOLD FLASH SERIES 15.00 [0.591] CHART A 1 **VIEW FROM TERMINATION END** = KEY LOCATION 1 1 # OF POSITIONS (Ex. 002) **SEE CHART A** 1 1 RoHS COMPLIANT R = RIGHT ANGLE NICKEL/CHROME PLATED SHELL BOARD MOUNT (PANEL MOUNT) 2 = FEMALE CONTACT RESISTANCE = 3 mΩ TEST VOLTAGE = 2100V WORKING VOLTAGE = 700V 3 POSITION 12 AMP MAX. PIN = 1.60 [0.063] CONTACT RESISTANCE = 4 mΩ TEST VOLTAGE = 2400V WORKING VOLTAGE = 800V 4 POSITION 12 AMP MAX. PIN = 1.30 [0.051] CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1850V WORKING VOLTAGE = 610V 1 1 1 6 POSITION 12 AMP MAX. PIN = 1.30 [0.051] 8 POSITION 6 AMP MAX. PIN = 0.90 [0.035] CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1350V WORKING VOLTAGE = 450V CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1500V WORKING VOLTAGE = 500V .1 15 1 1 1 4] 59 [0. 0.535 13.60 2 POSITION 12 AMP MAX. PIN = 2.00 [0.079] PANEL CUTOUT 10 POSITION 6 AMP MAX. = 0.90 [0.035] PIN 12 POSITION 6 AMP MAX. PIN = 0.70 [0.028] 14 POSITION 6 AMP MAX. PIN = 0.70 [0.028] 16 POSITION 6 AMP MAX. PIN = 0.70 [0.028] 19 POSITION 5 AMP MAX. PIN = 0.70 [0.028] 26 POSITION 2 AMP MAX. PIN = 0.50 [0.020] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1450V WORKING VOLTAGE = 500V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 1250V WORKING VOLTAGE = 480V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 1150V WORKING VOLTAGE = 380V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 950V WORKING VOLTAGE = 315V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 950V WORKING VOLTAGE = 315V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 950V WORKING VOLTAGE = 315V RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. NorComp DRAWN: M. SIGMON DATE: 02-15-16 TOLERANCE = +0.10, -0.0 [+0.004, -0.00] **NOTE** SEE PAGE 2 FOR BOARD LAYOUTS SCALE: N.T.S. SHEET 1 DWG NO. OF 2 822BRYY-213R001 REV: 3 DESCRIPTION: QUIK-LOQ - FEMALE - RIGHT ANGLE - PANEL MOUNT UNITS = MM [INCHES] BOARD LAYOUTS (TOP VIEW) = KEY LOCATION / PCB EDGE 0.100 2.54 TYP. 3 0.200 5.08 4 8 7 3 6 1 2 0.100 2.54 2 4 POS 6 POS 8 POS 10 POS HOLE SIZE = 0.90 [0.035] HOLE SIZE = 0.90 [0.035] HOLE SIZE = 0.70 [0.028] HOLE SIZE = 0.70 [0.028] 15 13 14 18 12 6 14 2 5 4 12 POS HOLE SIZE = 0.70 [0.028] RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 14 POS HOLE SIZE = 0.70 [0.028] 3 HOLE SIZE = 0.70 [0.028] NorComp M. SIGMON 23 1 15 4 24 6 02-10-16 19 16 0.100 2.54 8 7 25 18 2 17 3 6 5 4 26 POS HOLE SIZE = 0.70 [0.028] DATE: 20 26 19 POS 16 POS DRAWN: 14 5 0.050 1.27 TYP. 0.100 2.54 TYP. 3 15 0.050 1.27 TYP. 3 2 22 16 19 13 1 9 21 7 0.100 2.54 TYP. 4 17 10 13 0.050 1.27 TYP. 16 12 8 11 5 0.100 2.54 3 7 11 9 12 1 12 2 2 11 13 4 10 8 10 6 11 0.050 1.27 TYP. 0.050 1.27 TYP. 7 0.100 2.54 TYP. 0.100 2.54 TYP. 0.100 2.54 TYP. 0.050 1.27 TYP. 9 14 10 0.100 2.54 TYP. 0.050 1.27 TYP. 9 1 10 0.100 2.54 TYP. 0.100 2.54 3 POS 5 9 3 HOLE SIZE = 0.90 [0.035] 0.100 2.54 TYP. 1 4 2 2 POS 8 11 4 3 10 1 HOLE SIZE = 0.90 [0.035] 0.079 2.00 TYP. 12 5 9 0.100 2.54 8 6 5 1 1 2 0.100 2.54 6 6 8 2 7 7 3 0.100 2.54 TYP. 1 4 5 0.138 3.50 2 1 0.050 1.27 TYP. 0.100 2.54 0.100 2.54 0.100 2.54 0.100 2.54 TYP. SCALE: HOLE SIZE = 0.70 [0.028] N.T.S. SHEET 2 DWG NO. OF 2 822BRYY-213R001 REV: 3
822BR03-213R001 价格&库存
很抱歉,暂时无法提供与“822BR03-213R001”相匹配的价格&库存,您可以联系我们找货
