821B008-203R001
821B008-203R001
    NORCOMP
    821B008-203R001
821B008-203R001 数据手册
DESCRIPTION: QUIK-LOQ - FEMALE - SOLDER CUP - PANEL MOUNT UNITS = MM [INCHES] CHARACTERISSTICS MATERIALS SHELL : BRASS SHELL PLATING : NICKEL NUT : BRASS NUT PLATING : NICKEL LATCH SLEEVE : BRASS LATCH SLEEVE PLATING : NICKEL CONTACTS : COPPER ALLOY CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN. INSULATOR : PPS (HIGH TEMPERATURE) 821B YYY - 2 0 3 R 00 1 1 = GOLD FLASH SERIES 12.00 [0.475] # OF POSITIONS (Ex. 002) **SEE CHART A** 2 = FEMALE RoHS COMPLIANT SOLDER CUP (PANEL MOUNT) MECHANICAL DURABILITY: 5000 CYCLES OPERATING TEMP. RANGE: -40 C ~ +200 C PROCESS TEMPERATURE : 260 C FOR 5 SECONDS MAX. TORQUE VALUE : 4.5 Nm [39 IN/lbs] SHIELDING: 75dB @ 10MHz 40dB @ 1GHz NICKEL/CHROME PLATED SHELL 0.913 23.20 0.736 18.70 IP RATING: 50 .1 6] 47 [0. 0.417 10.60 0.630 16.00 0.413 10.50 (ACROSS FLATS) 0.551 14.00 M12*1.0 12 PANEL CUTOUT 0.126 3.20 TOLERANCE = +0.10, -0.0 [+0.004, -0.00] 0.236 6.00 (MAX. PANEL THICKNESS) CHART A 1 1 1 2 POSITION 20 AWG MAX. 15 AMP MAX. PIN = 1.30 [0.051] CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1500V WORKING VOLTAGE = 500V 3 POSITION 20 AWG MAX. 12 AMP MAX. PIN = 1.30 [0.051] CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1300V WORKING VOLTAGE = 430V 4 POSITION 22 AWG MAX. 10 AMP MAX. PIN = 0.90 [0.035] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1300V WORKING VOLTAGE = 430V RoHS COMPLIANT N C **VIEW FROM TERMINATION END** = KEY LOCATION THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 1 1 1 1 1 1 5 POSITION 22 AWG MAX. 9 AMP MAX. PIN = 0.90 [0.035] 6 POSITION 24 AWG MAX. 7 AMP MAX. PIN = 0.70 [0.028] 7 POSITION 24 AWG MAX. 7 AMP MAX. PIN = 0.70 [0.028] 8 POSITION 24 AWG MAX. 5 AMP MAX. PIN = 0.70 [0.028] 10 POSITION 28 AWG MAX. 2.5 AMP MAX. PIN = 0.50 [0.020] 14 POSITION 28 AWG MAX. 2 AMP MAX. PIN = 0.50 [0.020] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1250V WORKING VOLTAGE = 415V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 1050V WORKING VOLTAGE = 350V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 950V WORKING VOLTAGE = 315V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 950V WORKING VOLTAGE = 315V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 900V WORKING VOLTAGE = 300V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 800V WORKING VOLTAGE = 260V NorComp DRAWN: M. SIGMON DATE: 02-05-16 SCALE: N.T.S. SHEET 1 DWG NO. OF 1 821BYYY-203R001 REV: 3
821B008-203R001 价格&库存
很抱歉,暂时无法提供与“821B008-203R001”相匹配的价格&库存,您可以联系我们找货
