DESCRIPTION: QUIK-LOQ - FEMALE - RIGHT ANGLE - PANEL MOUNT
UNITS = MM [INCHES]
CHARACTERISSTICS
MATERIALS
SHELL : BRASS
SHELL PLATING : NICKEL
NUT : BRASS
NUT PLATING : NICKEL
LATCH SLEEVE : BRASS
LATCH SLEEVE PLATING : NICKEL
CONTACTS : COPPER ALLOY
CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN.
INSULATOR : PPS (HIGH TEMPERATURE)
820B R YY - 2 1 3 R 00 1
1 = GOLD FLASH
SERIES
9.50 [0.374]
RoHS COMPLIANT
R = RIGHT ANGLE
NICKEL/CHROME PLATED SHELL
# OF POSITIONS
(Ex. 02)
**SEE CHART A**
VERTICAL (PANEL MOUNT)
0.394
10.00
(ACROSS FLATS)
2 = FEMALE
0.984
25.00
IP RATING: 50
8]
35
[0.
0.524
13.30
0.500
12.70
M9*0.5
0.472
12.00
MECHANICAL
DURABILITY: 5000 CYCLES
OPERATING TEMP. RANGE: -40 C ~ +200 C
PROCESS TEMPERATURE : 260 C FOR 5 SECONDS
MAX. TORQUE VALUE : 2.5 Nm [22.1 IN/lbs]
SHIELDING: 75dB @ 10MHz
40dB @ 1GHz
0.025
0.64
CHART A
0.461
11.70
0.022
0.56
= KEY LOCATION
1
1
1
2 POSITION
6 AMP MAX.
PIN
= 0.90 [0.035]
CONTACT
RESISTANCE = 6 mΩ
TEST VOLTAGE = 1000V
WORKING VOLTAGE = 330V
3 POSITION
6 AMP MAX.
PIN
= 0.90 [0.035]
CONTACT
RESISTANCE = 6 mΩ
TEST VOLTAGE = 1200V
WORKING VOLTAGE = 400V
4 POSITION
6 AMP MAX.
PIN
= 0.70 [0.028]
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 850V
WORKING VOLTAGE = 280V
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF NorComp AND
SHALL NOT BE REPRODUCED, COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
PANEL CUTOUT
0.118
3.00
0.138
3.50
(MAX. PANEL THICKNESS)
TOLERANCE = +0.10, -0.0
[+0.004, -0.00]
**VIEW FROM MATING FACE**
1
1
1
5 POSITION
6 AMP MAX.
PIN
= 0.70 [0.028]
6 POSITION
2.5 AMP MAX.
PIN
= 0.50 [0.020]
7 POSITION
2.5 AMP MAX.
PIN
= 0.50 [0.020]
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 850V
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 850V
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 800V
WORKING VOLTAGE = 260V
NorComp
DRAWN:
M. SIGMON
DATE:
02-12-16
**NOTE**
SEE PAGE 2 FOR
BOARD LAYOUTS
SCALE:
N.T.S.
SHEET
1
DWG NO.
OF
2
820BRYY-213R001
REV:
3
DESCRIPTION: QUIK-LOQ - FEMALE - VERTICAL - PANEL MOUNT
UNITS = MM [INCHES]
BOARD LAYOUTS
VIEW SHOWN FOR
CONNECTOR ORIENTATION
= KEY LOCATION
ALL HOLE SIZES: 0.80 [0.031]
0.100
2.54
TYP.
0.100
2.54
0.300
7.62
0.100
2.54
TYP.
0.100
2.54
4 POS
3 POS
0.300
7.62
5
1
0.100
2.54
5 POS
RoHS COMPLIANT
0.100
2.54
TYP.
3
4
2
5
1
6
3
0.300
7.62
2
0.100
2.54
TYP.
4
0.100
2.54
TYP.
3
0.300
7.62
0.050
1.27
0.300
7.62
0.300
7.62
0.100
2.54
TYP.
0.300
7.62
2 POS
N
C
4
0.100
2.54
0.300
7.62
0.100
2.54
3
1
1
0.100
2.54
2
2
5
6
0.100
2.54
0.100
2.54
TYP.
7 POS
6 POS
NorComp
7
1
0.100
2.54
TYP.
0.100
2.54
TYP.
4
0.100
2.54
TYP.
2
3
2
0.300
7.62
1
0.300
7.62
0.100
2.54
0.100
2.54
0.300
7.62
0.300
7.62
DRAWN:
M. SIGMON
DATE:
02-12-16
SCALE:
N.T.S.
SHEET
2
DWG NO.
OF
2
820BRYY-213R001
REV:
3
很抱歉,暂时无法提供与“820BR06-213R001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+457.928241+59.24001
