HR22-12TJD-20S(73)
HR22-12TJD-20S(73)
    HRS(广濑)
    20 Position Circular Connector Jack, Female Sockets Solder Cup Silver
HR22-12TJD-20S(73) 数据手册
High Performance, Miniature Circular Connectors HR22 Series Features ·Both waterproof and non-waterproof types are available. (Waterproof and nonwaterproof connectors can be mated with each other if needed, but will no longer result in a waterproof connection) ·Waterproof performance The HR22 waterproof type is IP67 and IP68 rated when mated. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. IP67 : Left at a water depth of 1 m for 30 minutes IP68 : Left at a water depth of 2 m for 14 days ·Both crimp and solder type termination are available. Termination style can be chosen as required by your specific application. ·The receptacle features a jam nut configuration at the front, which allows for easy panel mounting. ·The jack connector can also be used as a panel jack. Product specifications Ratings Rated current 2A  Operating temperature range -25ç to +85℃ Rated voltage 100V AC, 140V DC Storage temperature range -10ç to +60℃ Item Specifications Conditions 1. Contact resistance 20mø max. Measured at DC 1A 2. Insulation resistance 1,000Mø min. Measured at DC 100V 3. Withstanding voltage No flashover or dielectric breakdown. Measured at AC 300V for 1 minute 4. Vibration resistance There shall be no electrical No electrical 10 to 500Hz/cycle, amplitude : 0.75mm, acceleration- 98m/s2 discontinuity for 10µs or greater. 3 axis directions, 2 hours each 5. Shock resistance No electrical discontinuity for 10µs or greater. Acceleration : 490m/s2,duration : 11ms, 3 axis directions, 3 times each 6. Mating cycles Contact resistance : 20mø max. 100 times 7. Resistance to water pressure Mated connectors left in Water at a depth of 1.8m for 48 No water penetration into the connector. hours. Materials / Finish Items Plated shell Insulator Male contact Female contact Hood and bushing Material Brass Zinc alloy PBT resin Finish Nickel plating Black Beryllium copper (Soldering) Silver plating UL94V-0 ―――― ―――― ―――― Phosphor bronze (Crimping) Acrylonitrile-butadiene rubber ―――― ―――― Brass (Soldering) Phosphor bronze (Crimping) Remarks Black In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2021.6④ 1 HR22 Series●High Performance, Miniature Circular Connectors Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. HR22 - 12 W T P A - 20 SC (**) 1 2 3 4 5 6 7 8 9 1 Model name : HR22 2 Shell size : The shell size is the outer diameter of the mating end of the plug. 3 W : Waterproof Blank : Non-waterproof 4 Locking mechanism T : Threaded coupling type Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5 Shell type P : Plug J : Jack R : Receptacle 6 Shell variation : Variation of the same connector configuration is shown by A, B, C, D.... 7 Number of contacts 8 Contact form P : Male pin S : Female pin PC : Crimp type male pin SC : Crimp type female pin 9 Other specifications : A two-digit character is added to indicate other specifications as needed. 2 HR22 Series●High Performance, Miniature Circular Connectors Plug Ø10 Ø11.9 1 4 5 10 1117 2016 Ø21 62 (Applicable cable dia.) Waterproof type M15×0.75 (Representative example) Crimp type Solder type Part No. HRS No. RoHS HR22-12WTPA-20SC(73) 122-0004-7 73 Yes Part No. HRS No. RoHS HR22-12WTPA-20S(73) 122-0015-3 73 HR22-12WTPA-20P(73) 122-0027-2 73 Yes Cable clamping force, rotation force, waterproof performance, and other types of performance may differ depending on the cable type used. Please make sure to verify the suitability of the cable assembly before use or production. Ø8.5 Ø11.9 Ø21 53.5 M15×0.75 (Applicable cable dia.) Non-waterproof type 1 4 5 10 1117 2016 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HR22-12WTPA-20SC(73) (Representative example) HR22-12TPD-20SC(73) Crimp type Solder type Part No. HRS No. HR22-12TPD-20SC(73) 122-0010-0 73 HR22-12TPD-20PC(73) 122-0018-1 73 Part No. HRS No. HR22-12TPD-20S(73) 122-0011-2 73 HR22-12TPD-20P(73) 122-0012-5 73 RoHS Yes RoHS Yes Cable clamping force, rotation force, waterproof performance, and other types of performance may differ depending on the cable type used. Please make sure to verify the suitability of the cable assembly before use or production. 3 HR22 Series●High Performance, Miniature Circular Connectors Right angle plug Waterproof type 1 Ø21 4 10 5 16 11 20 17 Ø11.9 17.95 M16×0.75 M15×0.75 41.7 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HR22-12WTLP-20P(31) (Representative example) Crimp type Part No. HR22-12WTLP-20PC(31) HRS No. 122-0064-9 31 RoHS Yes Solder type Part No. HR22-12WTLP-20P(31) HRS No. 122-0054-5 31 RoHS Yes Cord clamp for use on right-angled plugs φ20 φA M16×0.75 17 JR13WCC-10(72) Part No. JR13WCC-4(72) JR13WCC-5(72) JR13WCC-6(72) HRS No. 114-2045-0 72 114-2046-3 72 114-2047-6 72 (Representative example) A 4 5 6 RoHS Part No. JR13WCC-7(72) JR13WCC-8(72) JR13WCC-9(72) JR13WCC-10(72) Yes HRS No. 114-2048-9 72 114-2049-1 72 114-2050-0 72 114-2051-3 72 A 7 8 9 10 RoHS Yes Cable clamping force, rotation force, waterproof performance, and other types of performance may differ depending on the cable type used. Please make sure to verify the suitability of the cable assembly before use or production. Receptacle Waterproof / Non-waterproof combined use type A 21.5 13.5 4 20 φ20.6 10 16 1 17 5 11 M15×0.75 HR22-12WTRA-20P(73) Crimp type Solder type 4 15.8 20(HEX) M17×0.75 (Representative example) Part No. HR22-12WTRA-20SC(73) HR22-12WTRA-20PC(73) HRS No. 122-0021-6 73 122-0005-0 73 Part No. HR22-12WTRA-20S(73) HR22-12WTRA-20P(73) HRS No. 122-0014-0 73 122-0013-8 73 RoHS Yes A 24 25.5 RoHS Yes HR22 Series●High Performance, Miniature Circular Connectors Jack Waterproof type 20 4 17 1 5 11 Ø10 10 16 15.8 20(HEX) (Applicable cable dia.) 64 M17×0.75 M15×0.75 Crimp type (Representative example) Part No. HRS No. RoHS HR22-12WTJA-20PC(73) 122-0006-2 73 Yes Cable clamping force, rotation force, waterproof performance, and other types of performance may differ depending on the cable type used. Please make sure to verify the suitability of the cable assembly before use or production. 55.5 15.8 20(HEX) (Applicable cable dia.) Non-waterproof type Ø8.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HR22-12WTJA-20PC(73) M17×0.75 M15×0.75 HR22-12TJD-20P(73) Solder type (Representative example) Part No. HRS No. HR22-12TJD-20S(73) 122-0023-1 73 HR22-12TJD-20P(73) 122-0022-9 73 RoHS Yes Cable clamping force, rotation force, waterproof performance, and other types of performance may differ depending on the cable type used. Please make sure to verify the suitability of the cable assembly before use or production. 5 HR22 Series●High Performance, Miniature Circular Connectors Contact Male contact Female contact 1.35 1.2 1.18 1.35 1.18 A 1.2 A A 13 A 14.8 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Male contact Item Part No. HRS No. Applicable cable Packaging RoHS Loose contact HR22-PC-122 122-0017-9 100 pcs/pack Reel contact HR22-PC-222 122-0009-0 24 to 28 AWG Insulation diameter Ø1.15MAX 10,000 pcs/reel Item Part No. HRS No. Applicable cable Packaging Loose contact HR22-SC-122 122-0016-6 100 pcs/pack Reel contact HR22-SC-222 122-0008-8 24 to 28 AWG Insulation diameter Ø1.15MAX Yes Female contact RoHS Yes 10,000 pcs/reel Applicable tools Item Part No. HRS No. Applicable terminal Applicable wire Manual crimping tool HR22-TA2428HC 150-0200-4 HR22-PC-122 HR22-SC-122 24 to 28 AWG Insulation diameter Ø1.15MAX CM-105C 901-0001-0 ―――― ―――― AP105-HR22-2 901-2023-7 HR22-PC-222 HR22-SC-222 24 to 28 AWG Insulation diameter Ø1.15MAX HR10A-TC-04 150-0058-5 ―――― Ø8.5 RP6-SC-TP 150-0039-0 ―――― ―――― HR22-12P-T01 150-0075-4 ―――― Plug connector use Machine body Automatic crimping tool Applicator Cable crimping tool Extractor Cable termination tool Extractor Manual crimping tool Cable crimping tool HR22-12P-T01 Automatic crimping machine CM-105C 6 HR22 Series●High Performance, Miniature Circular Connectors Panel mounting dimensions 15.85 +0.05  0 4 3 2 1 10 9 8 7 6 5 Pin allocation 16 15 14 13 12 11 +   0.0 0 5 20 19 18 17 Ø0.8 Ø1 7. 05 Solder pot inner dia. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Panel thickness t: 1 to 3mm Notes: The above figure shows the pin allocation viewed from the engagement side. Precautions 1. Switch off the power of the circuit before disconnecting or plugging-in the connectors. 2. Use connectors with socket contacts at the power side of the circuit. 3. Make sure that the coupling is in completely cocked position. 4. The cable pull and twisting strength and other characteristics may differ, depending on the cable structure. Please confirm before the use. 5. This product uses silver plated contacts. Please be aware that silver easily reacts to sulfur gases, causing discoloration or degradation when exposed to certain environmental conditions as shown below. These conditions include areas with: • Dusty site • Area or location with a high density of sulfur dioxide gas, hydrogen sulfide gas, nitrogen dioxide gas, or other gas (Emission gases from vehicles and factories, etc.) • Highly fluctuating temperatures, such as close to a heating apparatus. In addition, it is recommended to store the products in their original packaging or similar state in order to prevent discoloration. • Temperature : -10 to +60ç, relative humidity : 80% or lower (An environment where temperature and relative humidity are constant and there is little temperature variation.) Please use the products within six months after delivery. (lf the storage period has expired, please examine the connectors and solder cups for corrosion and/or tarnish.) 7 HR22 Series●High Performance, Miniature Circular Connectors Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO: 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN https://www.hirose.com/ 8 The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 06/2021. Contents are subject to change without notice for the purpose of improvements.
HR22-12TJD-20S(73)
物料型号:HR22系列,包括不同型号的插头(Plug)、插座(Receptacle)和面板安装型插头(Jack),具有不同的防水性能和端接方式。
器件简介:HR22系列是高性能、小型化的圆形连接器,提供防水和非防水类型,具有IP67和IP68的防水等级。它们适用于需要高可靠性的应用,如汽车领域。
引脚分配:文档中提供了不同型号的引脚分配图,展示了从2到多个引脚的分配情况。
参数特性:包括额定电流、工作温度范围、存储温度范围、接触电阻、绝缘电阻、耐电压、振动抵抗、冲击抵抗、插拔寿命和耐水压性能。
功能详解:文档详细描述了连接器的防水性能、端接方式(压接和焊接)、面板安装的便利性、以及作为面板插头使用的可能。
应用信息:适用于需要高可靠性的应用,如汽车领域。建议在这些应用中联系公司代表以获取更多信息。
封装信息:提供了材料和表面处理的详细信息,包括镀层壳体、锌合金、绝缘体、公接触件、母接触件、罩和衬套的材料和颜色。
HR22-12TJD-20S(73) 价格&库存
很抱歉,暂时无法提供与“HR22-12TJD-20S(73)”相匹配的价格&库存,您可以联系我们找货
