822B008-273L501
822B008-273L501
    NORCOMP
    822B008-273L501
822B008-273L501 数据手册
DESCRIPTION: QUIK-LOQ - FEMALE - CABLE MOUNT UNITS = MM [INCHES] CHARACTERISSTICS MATERIALS HOUSING : BRASS HOUSING PLATING : 196µ" NICKEL MIN. SHELL & COLLET NUT: BRASS, 196µ" CHROME PLATED MIN. CONTACTS : COPPER ALLOY CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN. INSULATOR : PPS (HIGH TEMPERATURE) STRAIN RELIEF(BOOT) : THERMOPLASTIC POLYURETHANE 1.890 48.00 0.571 14.50 MECHANICAL DURABILITY: 5000 CYCLES OPERATING TEMP. RANGE: -40 C ~ +200 C PROCESS TEMPERATURE : 260 C FOR 5 SECONDS MAX. TOURQUE VALUE : 2.5 Nm [22.1 IN/LBS] SHIELDING: 75dB @ 10MHz 40dB @ 1GHz 0.512 13.00 IP RATING: 50 13.00 [0.512] (ACROSS FLATS) 822B YYY - 2 7 3 L YY 1 1 = GOLD FLASH SERIES 15.00 [0.591] CHART A 1 = KEY LOCATION 1 1 **VIEW FROM TERMINATION END** 1 1 COLLET SIZE **SEE CHART B** # OF POSITIONS (Ex. 002) **SEE CHART A** 2 = FEMALE RoHS COMPLIANT CABLE MOUNT NICKEL/CHROME PLATED SHELL CHART B 2 POSITION 16 AWG MAX. 25 AMP MAX. PIN = 2.00 [0.079] CONTACT RESISTANCE = 3 mΩ TEST VOLTAGE = 2100V WORKING VOLTAGE = 700V 3 POSITION 18 AWG MAX. 17 AMP MAX. PIN = 1.60 [0.063] CONTACT RESISTANCE = 4 mΩ TEST VOLTAGE = 2400V WORKING VOLTAGE = 800V 4 POSITION 20 AWG MAX. 15 AMP MAX. PIN = 1.30 [0.051] CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1850V WORKING VOLTAGE = 615V 1 1 1 6 POSITION 20 AWG MAX. 12 AMP MAX. PIN = 1.30 [0.051] 8 POSITION 22 AWG MAX. 10 AMP MAX. PIN = 0.90 [0.035] CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1350V WORKING VOLTAGE = 450V CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1500V WORKING VOLTAGE = 500V COLLET SIZE 1 1 1 10 POSITION 22 AWG MAX. 8 AMP MAX. = 0.90 [0.035] PIN 12 POSITION 24 AWG MAX. 7 AMP MAX. PIN = 0.70 [0.028] 14 POSITION 24 AWG MAX. 6.5 AMP MAX. PIN = 0.70 [0.028] 16 POSITION 24 AWG MAX. 6 AMP MAX. PIN = 0.70 [0.028] 19 POSITION 24 AWG MAX. 5 AMP MAX. PIN = 0.70 [0.028] 26 POSITION 28 AWG MAX. 2 AMP MAX. PIN = 0.50 [0.020] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1450V WORKING VOLTAGE = 500V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 1250V WORKING VOLTAGE = 480V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 1150V WORKING VOLTAGE = 380V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 950V WORKING VOLTAGE = 315V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 950V WORKING VOLTAGE = 315V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 950V WORKING VOLTAGE = 315V RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. NorComp DRAWN: M. SIGMON DATE: 02-03-16 WIRE DIAMETER 50 4.30 [0.169] ~ 5.20 [0.205] 60 5.30 [0.209] ~ 6.20 [0.244] 70 6.30 [0.248] ~ 7.20 [0.283] 80 7.30 [0.287] ~ 8.20 [0.323] 90 8.30 [0.327] ~ 9.20 [0.362] 00 9.30 [0.366] ~ 10.20 [0.402] SCALE: N.T.S. SHEET 1 DWG NO. OF 1 822BYYY-273LYY1 REV: 7
822B008-273L501 价格&库存
很抱歉,暂时无法提供与“822B008-273L501”相匹配的价格&库存,您可以联系我们找货
822B008-273L501
  • 18+431.2539618+55.78929
