DESCRIPTION: QUIK-LOQ - FEMALE - CABLE MOUNT
UNITS = MM [INCHES]
CHARACTERISSTICS
MATERIALS
HOUSING : BRASS
HOUSING PLATING : 196µ" NICKEL MIN.
SHELL & COLLET NUT: BRASS, 196µ" CHROME PLATED MIN.
CONTACTS : COPPER ALLOY
CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN.
INSULATOR : PPS (HIGH TEMPERATURE)
STRAIN RELIEF(BOOT) : THERMOPLASTIC POLYURETHANE
1.890
48.00
0.571
14.50
MECHANICAL
DURABILITY: 5000 CYCLES
OPERATING TEMP. RANGE: -40 C ~ +200 C
PROCESS TEMPERATURE : 260 C FOR 5 SECONDS
MAX. TOURQUE VALUE : 2.5 Nm [22.1 IN/LBS]
SHIELDING: 75dB @ 10MHz
40dB @ 1GHz
0.512
13.00
IP RATING: 50
13.00 [0.512]
(ACROSS FLATS)
822B YYY - 2 7 3 L YY 1
1 = GOLD FLASH
SERIES
15.00 [0.591]
CHART A
1
= KEY LOCATION
1
1
**VIEW FROM TERMINATION END**
1
1
COLLET SIZE
**SEE CHART B**
# OF POSITIONS
(Ex. 002)
**SEE CHART A**
2 = FEMALE
RoHS COMPLIANT
CABLE MOUNT
NICKEL/CHROME PLATED SHELL
CHART B
2 POSITION
16 AWG MAX.
25 AMP MAX.
PIN
= 2.00 [0.079]
CONTACT
RESISTANCE = 3 mΩ
TEST VOLTAGE = 2100V
WORKING VOLTAGE = 700V
3 POSITION
18 AWG MAX.
17 AMP MAX.
PIN
= 1.60 [0.063]
CONTACT
RESISTANCE = 4 mΩ
TEST VOLTAGE = 2400V
WORKING VOLTAGE = 800V
4 POSITION
20 AWG MAX.
15 AMP MAX.
PIN
= 1.30 [0.051]
CONTACT
RESISTANCE = 5 mΩ
TEST VOLTAGE = 1850V
WORKING VOLTAGE = 615V
1
1
1
6 POSITION
20 AWG MAX.
12 AMP MAX.
PIN
= 1.30 [0.051]
8 POSITION
22 AWG MAX.
10 AMP MAX.
PIN
= 0.90 [0.035]
CONTACT
RESISTANCE = 5 mΩ
TEST VOLTAGE = 1350V
WORKING VOLTAGE = 450V
CONTACT
RESISTANCE = 6 mΩ
TEST VOLTAGE = 1500V
WORKING VOLTAGE = 500V
COLLET
SIZE
1
1
1
10 POSITION
22 AWG MAX.
8 AMP MAX.
= 0.90 [0.035]
PIN
12 POSITION
24 AWG MAX.
7 AMP MAX.
PIN
= 0.70 [0.028]
14 POSITION
24 AWG MAX.
6.5 AMP MAX.
PIN
= 0.70 [0.028]
16 POSITION
24 AWG MAX.
6 AMP MAX.
PIN
= 0.70 [0.028]
19 POSITION
24 AWG MAX.
5 AMP MAX.
PIN
= 0.70 [0.028]
26 POSITION
28 AWG MAX.
2 AMP MAX.
PIN
= 0.50 [0.020]
CONTACT
RESISTANCE = 6 mΩ
TEST VOLTAGE = 1450V
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 1250V
WORKING VOLTAGE = 480V
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 1150V
WORKING VOLTAGE = 380V
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 950V
WORKING VOLTAGE = 315V
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 950V
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 950V
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF NorComp AND
SHALL NOT BE REPRODUCED, COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
NorComp
DRAWN:
M. SIGMON
DATE:
02-03-16
WIRE DIAMETER
50
4.30 [0.169] ~ 5.20 [0.205]
60
5.30 [0.209] ~ 6.20 [0.244]
70
6.30 [0.248] ~ 7.20 [0.283]
80
7.30 [0.287] ~ 8.20 [0.323]
90
8.30 [0.327] ~ 9.20 [0.362]
00
9.30 [0.366] ~ 10.20 [0.402]
SCALE:
N.T.S.
SHEET
1
DWG NO.
OF
1
822BYYY-273LYY1
REV:
7
很抱歉,暂时无法提供与“822B012-273L501”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 18+475.7046218+61.62039
