DATA SHEET
HIGH VOLTAGE CHIP RESISTORS
RV series
0.5%, 1%, 5%
sizes 0603/0805/1206/2010/2512
RoHS compliant
IEC 62368-1 Safety Certificate issued by UL Demko:
Product specification – November 13, 2018 V.8
Chip Resistor Surface Mount
RV
0603/0805/1206/2010/2512 (RoHS Compliant)
SERIES
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC
This specification describes
RV0603/0805/1206/2010/2512
high voltage chip resistors with
lead-free terminations made by
thick film process.
Both part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
YAGEO BRAND ordering code
GLOBAL PART NUMBER (PREFERRED )
APPLICATIONS
Converter
Printer equipment
Battery charger
Computer
Power supply
Car electronics
FEATURES
AEC-Q200 qualified for 47ohm
≤ R< 5Mohm
RoHS compliant
Reducing environmentally
hazardous wastes
High component and equipment
reliability
Non-forbidden materials used in
products/production
Halogen Free Epoxy
Moisture sensitivity level: MSL 1
IEC 62368-1:2014 safety
certificate (G.10.2) issued by UL
Demko for the following sizes
and resistance ranges:
2
9
RV XXXX X X X XX XXXX L
(1)
(2) (3) (4) (5)
(6)
(7)
(1) SIZE
(2) TOLERANCE
D = ± 0.5%
F = ± 1%
J = ± 5%
(3) PACKAGING TYPE
R = Paper/PE taping reel
K = Embossed taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
– = Base on spec
(5) TAPING REEL
07 = 7 inch dia. Reel
(6) RESISTANCE VALUE
There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point, no need
to mention the last zero after R/K/M, e.g.1K2, not 1K20.
Detailed resistance rules show in table of “Resistance rule of global part number”.
(7) DEFAULT CODE
Letter L is system default code for ordering only (Note)
- 0603: 100KΩ to 10MΩ
- 0805: 100KΩ to 22MΩ
- 1206: 100KΩ to 27MΩ
*Please refer to UL certification
number
Resistance code rule
Example
XXKX
(10 to 97.6 KΩ)
10K = 10,000 Ω
97K6 = 97,600 Ω
XXXK
(100 to 976 KΩ)
100K = 100,000Ω
976K = 976,000Ω
XMXX
(1 to 9.76 MΩ)
1M = 1,000,000 Ω
9M76 = 9,760,000 Ω
XXMX
(10 to 16 MΩ)
10M = 10,000,000 Ω
27M = 27,000,000 Ω
O RDERING EXAMPLE
The ordering code of a RV1206
chip resistor, value 1 MΩ with
± 5% tolerance, supplied in 7-inch
tape reel is: RV1206JR-071ML.
NOTE
1. All our R-Chip products meet RoHS
compliant. "LFP" of the internal 2D reel
label mentions "Lead Free Process"
2. On customized label, "LFP" or specific
symbol printed and the optional "L" at
the end of GLOBAL PART NUMBER /
12NC can be added (both are on
customer request)
www.yageo.com
Nov. 13, 2018 V.8
RV
SERIES
3
9
PHYCOMP BRAND ordering codes
Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp
brand products.
For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2.
12NC CODE
2322
XXX XXXXX L
(1)
SIZE TYPE
(2)
(3)
Last digit of 12NC
Resistance decade (3)
(4)
START TOL. RESISTANCE
IN (1) (%) RANGE
Last digit
EMBOSSED (2) PAPER/PE (2)
TAPE ON REEL TAPE ON REEL (units)
0.01 to 0.0976 Ω
0.1 to 0.976 Ω
4,000
7
5,000
1 to 9.76 Ω
0805 VRC11
± 5% 47 to 10M Ω
8
2322
792 61xxx
VRC12
± 1% 47 to 10M Ω
10 to 97.6 Ω
9
2322
793 6xxxx
1206 VRC01
2322
± 5% 47 to 27M Ω
790 61xxx
100 to 976 Ω
1
VRC02
2322
± 1% 47 to 10M Ω
791 6xxxx
1 to 9.76 KΩ
2
2512 VPRC221 2322
± 5% 47 to 16M Ω
762 98xxx
10 to 97.6 KΩ
3
100 to 976 KΩ
4
1 to 9.76 MΩ
5
10 to 97.6 MΩ
6
(1) The resistors have a 12-digit ordering code starting with 2322.
(2) The subsequent 4 or 5 digits indicate the resistor tolerance and
packaging.
(3) The remaining 4 or 3 digits represent the resistance value with the
last digit indicating the multiplier as shown in the table of
“Last digit of 12NC”.
(4) "L" is optional symbol (Note) .
O RDERING EXAMPLE
The ordering code of a VRC01 resistor, value 1 MΩ with ± 5% tolerance,
supplied in tape of 5,000 units per reel is: 232279061105L or
RV1206JR-071ML.
Example:
0.02 Ω
0200 or 200
0.3 Ω
3007 or 307
1Ω
1008 or 108
33 KΩ
3303 or 333
10 MΩ
1006 or 106
NOTE
1. All our R-Chip products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process"
2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART
NUMBER / 12NC can be added (both are on customer request)
www.yageo.com
Nov. 13, 2018 V.8
RV
SERIES
4
9
MARKING
03
Fig. 1
Value=10 KΩ
E-24 series: 3 digits, ±5%
First two digits for significant figure and 3rd digit for number of zeros
RV0603
Fig. 2 Value=24Ω
E-24 series: 3 digits, ±0.5% & ±1%
Exception values 10/11/13/15/20/75 of E24 series
One short bar under marking letter
E-96 series: 3 digits, ±0.5% & ±1%
Fig. 3 Value=12.4 KΩ
Including values 10/11/13/15/20/75 of E24 series
First two digits for E-96 marking rule and 3rd letter for number of zeros
RV0805/1206/2010/2512
00
Fig. 4 Value=10 KΩ
Both E-24 and E-96 series: 4 digits, ±0.5% & ±1%
First three digits for significant figure and 4th digit for number of zeros
For further marking information, please refer to data sheet “Chip resistors marking”.
CONSTRUCTION
The resistor is constructed on top of a high-grade
ceramic body. Internal metal electrodes are added on
each end to make the contacts to the thick film resistive
element. The composition of the resistive element is a
noble metal imbedded into a glass and covered by a
second glass to prevent environment influences. The
resistor is laser trimmed to the rated resistance value.
The resistor is covered with a protective epoxy coat,
finally the two external terminations (matte tin on Nibarrier) are added. See fig.5
OUTLINES
For dimension see Table 1
DIMENSIONS
Table 1 For outlines see fig. 5
TYPE
L (mm) W (mm)
H (mm)
I1 (mm)
I2 (mm)
RV0603 1.60 ± 0.10 0.80 ± 0.10 0.45 ± 0.10 0.25 ± 0.15 0.25 ± 0.15
RV0805 2.00 ± 0.10 1.25 ± 0.10 0.50 ± 0.10 0.35 ± 0.20 0.35 ± 0.20
RV1206 3.10 ± 0.10 1.60 ± 0.10 0.55 ± 0.10 0.40 ± 0.20 0.45 ± 0.20
RV2010 5.00± 0.10 2.50± 0.15 0.55± 0.10 0.45± 0.15 0.50± 0.20
RV2512 6.35 ± 0.10 3.10 ± 0.15 0.55 ± 0.10 0.60 ± 0.20 0.50 ± 0.20
Fig. 5 Chip resistor outlines
www.yageo.com
Nov. 13, 2018 V.8
RV
SERIES
5
9
ELECTRICAL CHARACTERISTICS
Table 2
RESISTANCE
RANGE
TYPE
Rated
Power
Operating
Temperature
Range
CHARACTERISTICS
Max.
Max.
Working
Overload
Voltage
Voltage
Dielectric
Withstanding
Voltage
Temperature
Coefficient
of Resistance
5% (E-24) 47Ω to 10MΩ
RV0603
1% (E-24/E-96) 47Ω to 10MΩ
0.5% (E-24/E-96) 47Ω to 10MΩ
1/10W
350V
500V
500V
400 V
800 V
800 V
500 V
1,000 V
1,000 V
3/4W
500 V
1,000 V
1,000 V
1W
500 V
1,000 V
1,000 V
RV0805
5% (E-24) 47Ω to 22MΩ
1% (E-24/E-96) 47Ω to 22MΩ
1/8 W
RV1206
5% (E-24) 47Ω to 27MΩ
1% (E-24/E-96) 47Ω to 27MΩ
0.5% (E-24/E-96) 47Ω to 15MΩ
1/4 W
–55 °C to
+155 °C
± 200 ppm/°C
RV2010
RV2512
5% (E-24) 47Ω to 16MΩ
1% (E-24/E-96) 47Ω to 16MΩ
FOOTPRINT AND SOLDERING PROFILES
For recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”.
PACKING STYLE AND PACKAGING QUANTITY
Table 3 Packing style and packaging quantity
PACKING STYLE
REEL
DIMENSION
RV0603
RV0805
RV1206
RV2010
RV2512
Paper/PE taping reel (R)
7" (178 mm)
5,000
5,000
5,000
Embossed taping reel (K)
7" (178 mm)
4,000
4,000
NOTE
1. For Paper/PE/Embossed tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”.
www.yageo.com
Nov. 13, 2018 V.8
RV
SERIES
6
9
FUNCTIONAL DESCRIPTION
O PERATING TEMPERATURE RANGE
Range: –55 °C to +155 °C
P OWER RATING
Each type rated power at 70 °C:
RV0603=1/10W; RV0805=1/8W; RV1206=1/4W;
RV2010=3/4W; RV2512=1W
R ATED VOLTAGE
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
V=
or max. working voltage whichever is less
Fig. 6 Maximum dissipation (P max ) in percentage of rated power
as a function of the operating ambient temperature (T amb)
Where
V = Continuous rated DC or AC (rms) working voltage (V)
P = Rated power (W)
R = Resistance value (Ω)
Maximum working voltage can be applicable to resistors only if the resistance value is equal to or higher than
the critical resistance value.
www.yageo.com
Nov. 13, 2018 V.8
RV
SERIES
7
9
TESTS AND REQUIREMENTS
Table 4 Test condition, procedure and requirements (AEC-Q200 report available for 47ohm ≤ R < 5Mohm)
TEST
TEST METHOD
PROCEDURE
Life/
Operational Life/
Endurance
MIL-STD-202G-method 108A
1,000 hours at 70± 5 °C applied RCWV
1.5 hours on, 0.5 hour off, still air required
High
Temperature
Exposure/
Endurance at
upper category
temperature
Moisture
Resistance
MIL-STD-202G-method 106F
IEC 60115-1 4.24.2
IEC 60115-1 4.25.1
REQUIREMENTS
± (2%+0.05 Ω)
JIS C 5202-7.10
IEC 60115-1 4.25.3
1,000 hours at maximum operating temperature
depending on specification, unpowered
JIS C 5202-7.11
No direct impingement of forced air to the parts
± (1%+0.05 Ω)
Tolerances: 155± 3 °C
Each temperature / humidity cycle is defined at 8
hours (method 106F), 3 cycles / 24 hours for 10d
with 25 °C / 65 °C 95% R.H, without steps 7a &
7b, unpowered
± (2%+0.05 Ω)
Parts mounted on test-boards, without
condensation on parts
Measurement at 24± 2 hours after
test conclusion
Thermal Shock
MIL-STD-202G-method 107G
-55/+125 °C
Note: Number of cycles required is 300.
Maximum transfer time is 20 seconds. Dwell time
is 15 minutes. Air – Air
Short time
overload
MIL-R-55342D-para 4.7.5
Board Flex/
Bending
IEC60115-1 4.33
IEC60115-1 4.13
± (0.5%+0.05 Ω) for 10 KΩ to
10 MΩ
± (1%+0.05 Ω) for others
2.5 times RCWV or maximum overload voltage
whichever is less for 5 sec at room temperature
± (2%+0.05 Ω)
Device mounted on PCB test board as described,
only 1 board bending required
Bending for 0603 & 0805: 3mm
1206 & above: 2mm
Holding time: minimum 60 seconds
± (1%+0.05 Ω)
No visible damage
No visible damage
Ohmic value checked during bending
Humidity
IEC 60115-1 4.24.8
Steady state for 1,000 hours at 40°C / 95% R.H.
RCWV applied for 1.5 hours on and 0.5 hour off
± (3.0%+0.05 Ω)
AEC-Q200 Test 7
for 47ohm ≤ R< 5Mohm, 1,000 hours; 85°C /
85% RH 10% of operating power
Measurement at 24 ± 4 hours after test conclusion
± (5.0%+0.05 Ω)
MIL-STD-202 Method 103
www.yageo.com
Nov. 13, 2018 V.8
RV
SERIES
8
9
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Solderability
- Wetting
IPC/JEDECJ-STD-002B test B
Electrical Test not required
Well tinned (≥95% covered)
IEC 60068-2-58
Magnification 50X
No visible damage
SMD conditions:
1st step: method B, aging 4 hours at 155 °C
dry heat
2nd step: leadfree solder bath at 245± 3 °C
Dipping time: 3± 0.5 seconds
- Leaching
- Resistance to
Soldering Heat
IPC/JEDECJ-STD-002B test D
No visible damage
IEC 60068-2-58
Leadfree solder, 260 °C, 30 seconds
immersion time
MIL-STD-202G-method 210F
Condition B, no pre-heat of samples
± (1%+0.05 Ω)
IEC 60068-2-58
Leadfree solder, 260 °C, 10 seconds
immersion time
No visible damage
Procedure 2 for SMD: devices fluxed and
cleaned with isopropanol
www.yageo.com
Nov. 13, 2018 V.8
RV
SERIES
9
9
REVISION HISTORY
REVISION
DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 8
Nov .09, 2018
- Add AEC-Q200 for 47ohm ≤ R < 5Mohm
Version 7
Jul. 06, 2017
- Add IEC62368-1 safety certificate declaration for sizes 0603/0805/1206
Version 6
Dec. 01, 2016
- Extend resistor value of RV1206 0.5%
Version 5
Aug. 27, 2015
- Extend resistor range and add 0.5%
Version 4
Jan. 27, 2014
- RV0603 resistance range extend to 10MΩ
- Add RV2010
Version 3
Aug. 26, 2013
- Add RV0603
Version 2
Sep 29, 2011
- Type error correction
Version 1
Nov 19, 2008
- Change to dual brand datasheet that describes RV0805/1206/2512 with
RoHS compliant
- Description of "Halogen Free Epoxy" added
- Define global part number
Version 0
Feb 14, 2006
- New datasheet for high voltage chip resistors sizes of 0805/1206/2512,
5%, 1% tolerance with lead-free terminations
- Replace the 0805/1206/2512 parts of pdf files:
VRC01_02_11_12_51_3.pdf, VPRC221_5_3.pdf, and combine into a
document.
- Test method and procedure updated
- PE tape added (paper tape will be replaced by PE tape)
“ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itself are unchanged. Any
product change will be announced by PCN.”
www.yageo.com
Nov. 13, 2018 V.8
