SR1206JR-0747RL
SR1206JR-0747RL
    YAGEO(国巨)
    贴片电阻 1206 47Ω ±5% 1/4W ±100ppm/℃
SR1206JR-0747RL 数据手册
DATA SHEET AUTOMOTIVE GRADE SURGE CHIP RESISTORS SR series 20%, 10%, 5% sizes 0402/0603/0805/1206/1210/1218/2010/2512 Product specification – August 04, 2021 V.9 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount SR 0402/0603/0805/1206/1210/1218/2010/2512 SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes SR0402 to SR2512 chip resistors with lead-free terminations made by thick film process. Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. 2 8 GLOBAL PART NUMBER SR XXXX X X X XX XXXX L APPLICATIONS  Telecommunications  Power supplies  Car electronics FEATURES  AEC-Q200 qualified  Superior to RC series in pulse withstanding voltage and surge withstanding voltage.  MSL class: MSL 1  Halogen free epoxy  RoHS compliant - - Products with lead-free terminations meet RoHS requirements Pb-glass contained in electrodes, resistor element and glass are exempted by RoHS  Reduce environmentally hazardous waste  High component and equipment reliability (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0402 / 0603 / 0805 / 1206 / 1210 / 1218 / 2010 / 2512 (2) TOLERANCE J = ± 5% K = ± 10% M = ± 20% (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Based on spec. (5) TAPING REEL & POWER 07 = 7 inch dia. Reel 7W = 7 inch dia. Reel & 2 x standard power 13 = 13 inch dia. Reel 7T = 7 inch dia. Reel & 3 x standard power 47 = 7 inch dia. Reel & 4xstandard power (6) RESISTANCE VALUE 1 Ω ≤ R ≤ 1M Ω There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed coding rules of resistance are shown in the table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is the system default code for ordering only. (Note) Resistance rule of global part number Resistance coding Example rule XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XXKX (10 to 97.6 KΩ) 10K = 10,000 Ω 97K6= 976,000 Ω XXXK (100 KΩ) 100K = 100,000 Ω ORDERING EXAMPLE The ordering code for an SR0805 chip resistor, value 10 KΩ with ± 5% tolerance, supplied in 7-inch tape reel is: SR0805JR-0710KL. www.yageo.com Aug. 04, 2021 V.9 Product specification Chip Resistor Surface Mount SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 3 8 MARKING SR0402 No Marking ynsc007 Fig. 1 SR1218 E-24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros YNSC099-1 Fig. 2 Value=10 KΩ SR0603 / SR0805 / SR1206 / SR1210 / SR2010 / SR2512 03 Fig. 3 E-24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros YNSC001 Value=10 KΩ NOTE For further marking information, please refer to data sheet “Chip resistors marking”. TAPING REEL & POWER Table 1 POWER, W (P70) TYPE CODING 07 7W 7T 47 0402 1/16 1/8 1/5 - 0603 0805 1206 1/10 1/5 1/4 - 1/8 1/4 1/3 1/2 1/4 1/2 3/4 1 1210 1218 2010 2512 1/2 1 - - 1 1.5 - - 3/4 1.25 - - 1 2 - - CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added at each end and connected by a resistive glaze. The resistive glaze is covered by a lead-free glass. The composition of the glaze is adjusted to give the approximately required resistance value. The whole element is covered by a protective overcoat. The top of overcoat is marked with the resistance value. Finally, the two external terminations (Ni/matte tin) are added, as shown in Fig.4. OUTLINES marking layer overcoat protective glass resistive layer inner electrode termination (Ni/matte tin) inner electrode YNSC095 ceramic substrate Fig. 4 Chip resistor outlines www.yageo.com Aug. 04, 2021 V.9 Product specification Chip Resistor Surface Mount SR SERIES 4 8 0402/0603/0805/1206/1210/1218/2010/2512 DIMENSIONS Table 2 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) SR0402 1.00± 0.05 0.50± 0.05 0.35± 0.05 0.20± 0.10 0.25± 0.10 SR0603 1.60± 0.10 0.80± 0.10 0.45± 0.10 0.25± 0.15 0.25± 0.15 SR0805 2.00± 0.10 1.25± 0.10 0.50± 0.10 0.35± 0.20 0.35± 0.20 SR1206 3.10± 0.10 1.60± 0.10 0.55± 0.10 0.45± 0.20 0.40± 0.20 SR1210 3.10± 0.10 2.60± 0.15 0.55± 0.10 0.45± 0.15 0.50± 0.20 SR1218 3.10± 0.10 4.60± 0.10 0.55± 0.10 0.45± 0.20 0.40± 0.20 SR2010 5.00± 0.10 2.50± 0.15 0.55± 0.10 0.55± 0.15 0.50± 0.20 SR2512 6.35± 0.10 3.10± 0.15 0.55± 0.10 0.60± 0.20 0.50± 0.20 For dimension, please refer to Table 1 SR0402 SR0603/0805/1206/ 1210/2010/2512 I1 SR1218 Side view for all type I1 I1 W W Fig. 5 Chip resistor dimensions H W I2 L L L YNSC096_1 ELECTRICAL CHARACTERISTICS Table 3 TYPE SR0402 POWER CHARACTERISTICS Operating Temperature Max. Max. Dielectric RESISTANCE Range Working Overload Withstanding RANGE Voltage Voltage Voltage 1/16W 1/8W 50 V 100 V 100 V 75V 150V 150V 150V 300V 300V Temperature Coefficient of Resistance 1/5W 1/10W SR0603 1/5W 1/4W 1/8 W SR0805 1/4W 1/3W 10Ω < R ≤ 1MΩ ± 100 ppm/°C 1/2W 1/4 W SR1206 1/2W 3/4W E24 5%, 10%, 20% 1 Ω ≤ R ≤ 1M Ω –55 °C to +155 °C 200 V 400 V 500 V 200 V 400 V 500 V 1W SR1210 1/2W 1W SR1218 1W 1.5W 200 V 400 V 500 V SR2010 3/4W 1.25W 200 V 400 V 500 V 200 V 400 V 500 V SR2512 1W 2W 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C www.yageo.com Aug. 04, 2021 V.9 Product specification Chip Resistor Surface Mount SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 5 8 FOOTPRINT AND SOLDERING PROFILES Recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 4 Packing style and packaging quantity PACKING STYLE Paper taping reel (R) Embossed taping reel (K) REEL DIMENSION SR0402 SR0603/0805/1206 SR1210 SR1218/2010/2512 7" (178 mm) 10,000 5,000 5,000 --- 13" (330 mm) 50,000 20,000 20,000 --- 7" (178 mm) --- --- --- 4,000 NOTE 1. For paper/embossed tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”. TEMPERATURE COEFFICIENT OF RESISTANCE RESISTANCE FUNCTIONAL DESCRIPTION RANGE OPERATING TEMPERATURE RANGE MRA632 Pmax PT040–55 °C to +155 °C 100 mΩ to 910 mΩ Range: (%Prated) 2 ± 200 ppm/°C POWER RATING 100 PT060 Each type rated power at 70 °C: ± 200 ppm/°C 3 SR0402: 1/16W, 1/8W, 1/5W SR0603: PT080 1/10W, 1/5W, 1/4W 50 ± 200 ppm/°C SR0805: 1/8W, 1/4W, 1/3W, 1/2W 5 SR1206: 1/4W, 1/2W, 3/4W, 100 MΩ TO 910 MΩ 1W PT120 1/2W, 1W SR1210: 100 mΩ 0 > 100 mΩ 6 SR1218: 1W, 1.5W 55 0 50 70 100 155 SR2010: 3/4W, 1.25W Tamb ( C) PT201 SR2512: 1W, 2W ± 100 ppm/°C ± 75 ppm/°C 0 Fig. 6 Maximum dissipation (P max ) in percentage of rated power RATED VOLTAGE as a function of the operating ambient temperature (T amb ) PT251 ± 100 working ppm/°C voltage ± 75 ppm/°C The DC or AC (rms) continuous 2 corresponding to the rated power is determined by the following formula: V= (P X R) Where V = Continuous rated DC or AC (rms) working voltage (V) P = Rated power (W) R = Resistance value (Ω) www.yageo.com Aug. 04, 2021 V.9 Product specification Chip Resistor Surface Mount SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 6 8 PULSE LOAD BEHAVIOR YNSC093 104 One-Pulse limiting electric power (W) 103 102 101 2512 2010 1218 1 1210 1206 0805 0603 0402 10-1 10-2 10-1 1 101 102 103 Pulse duration (ms) Fig. 7 Pulse-Load behavior TESTS AND REQUIREMENTS Table 5 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS High Temperature Exposure AEC-Q200 Test 3 1,000 hours at TA = 155 °C, unpowered ± (3.0%+0.05Ω) Moisture Resistance AEC-Q200 Test 6 Each temperature / humidity cycle is defined at 8 hours (method 106F), 3 cycles / 24 hours for 10d. with 25 °C / 65 °C 95% R.H, without steps 7a & 7b, unpowered ± (2.0%+0.05Ω) 1,000 hours; 85 °C / 85% RH 10% of operating power ± (3.0%+0.05Ω) MIL-STD-202 Method 108 MIL-STD-202 Method 106 Biased Humidity AEC-Q200 Test 7 MIL-STD-202 Method 103 Measurement at 24± 4 hours after test conclusion. Operational Life Resistance to Soldering Heat AEC-Q200 Test 8 ± (3.0%+0.05Ω) MIL-STD-202 Method 108 1,000 hours at 125 °C, derated voltage applied for 1.5 hours on, 0.5 hour off, still-air required AEC-Q200 Test 15 Condition B, no pre-heat of samples ± (1.0%+0.05Ω) MIL-STD-202 Method 210 Lead-free solder, 260± 5 °C, 10± 1 seconds immersion time No visible damage Procedure 2 for SMD: devices fluxed and cleaned with isopropanol www.yageo.com Aug. 04, 2021 V.9 Product specification Chip Resistor Surface Mount TEST Thermal Shock SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 TEST METHOD PROCEDURE REQUIREMENTS AEC-Q200 Test 16 -55/+125 °C ± (1.0%+0.05Ω) MIL-STD-202 Method 107 Number of cycles is 300. Devices mounted 7 8 Maximum transfer time is 20 seconds. Dwell time is 15 minutes. Air – Air ESD AEC-Q200 Test 17 Human Body Model, AEC-Q200-002 1 pos. + 1 neg. discharges ± (3.0%+0.05Ω) 0201: 500V 0402/0603: 1KV 0805 and above: 2KV Solderability - Wetting AEC-Q200 Test 18 Electrical Test not required Magnification 50X J-STD-002 SMD conditions: (a) Method B, aging 4 hours at 155 °C dry heat, dipping at 235± 3 °C for 5± 0.5 seconds. Well tinned (≥95% covered) No visible damage (b) Method B, steam aging 8 hours, dipping at 215± 3 °C for 5± 0.5 seconds. (c) Method D, steam aging 8 hours, dipping at 260± 3 °C for 30± 0.5 seconds. Board Flex AEC-Q200 Test 21 AEC-Q200-005 Chips mounted on a 90mm glass epoxy resin PCB (FR4) ± (1.0%+0.05Ω) Bending for 0201/0402: 5 mm 0603/0805: 3 mm 1206 and above: 2 mm Holding time: minimum 60 seconds Temperature Coefficient of Resistance (T.C.R.) MIL-STD-202 Method 304 At +25/–55 °C and +25/+125 °C Refer to table 2 Formula: R2–R1 T.C.R= ------------------------- × 106 (ppm/°C) R1(t2–t1) Where t1=+25 °C or specified room temperature t2=–55 °C or +125 °C test temperature R1=resistance at reference temperature in ohms R2=resistance at test temperature in ohms Short Time Overload IEC60115-1 4.13 2.5 times of rated voltage or maximum overload voltage whichever is less for 5 sec at room temperature ± (2.0%+0.05Ω) www.yageo.com Aug. 04, 2021 V.9 Product specification Chip Resistor Surface Mount SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 8 8 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 9 Aug. 04, 2021 - - Upgrade to Automotive Grade Version 8 Jul. 22, 2019 - - Update power rating - Extend resistance range of 0402 ~ 2512 to 1Mohm, Version 7 Sep. 27, 2018 - - Tighten TCR of all sizes for 10Ω < R ≤ 1MΩ from ± 200 ppm/°C to ± 100 ppm/°C - Add SR1210, SR1218, SR2010 7W (double power) Version 6 Oct. 02, 2017 - - Add SR0402 7T (triple power), SR0805 47 (quadruple power), SR2512 7W (double power) Version 5 Nov.11, 2016 - - Update 7T power for 1206 Version 4 Sep. 01, 2015 - Version 3 Jul. 31, 2015 - Version 2 Jan. 06, 2014 - Version 1 Mar 18, 2011 - - Update SR0603 Dielectric Withstanding Voltage to 150V - Update 7T power for 0603/0805 & 7W for 1210 - Comply with AEC-Q200 standard - Add SR0402/0603/1210 - Update electrical characteristic - Change to dual brand datasheet that describes SR0805 to SR2512 with RoHS compliant - Define global part number Version 0 Oct 19, 2004 - - “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products are unchanged. Any product change will be announced by PCN.” "The reimbursement is limited to the value of the products." www.yageo.com Aug. 04, 2021 V.9
SR1206JR-0747RL 价格&库存
很抱歉,暂时无法提供与“SR1206JR-0747RL”相匹配的价格&库存,您可以联系我们找货
SR1206JR-0747RL
  • 5000+0.500975000+0.06043
  • 10000+0.4582910000+0.05528
  • 25000+0.4099025000+0.04945
  • 35000+0.4013535000+0.04842
  • 50000+0.3814350000+0.04601
  • 125000+0.35581125000+0.04292
库存:9330
SR1206JR-0747RL
  • 1+0.40740
  • 100+0.26280
  • 1000+0.18720
  • 2500+0.13890
  • 5000+0.10350
库存:54015
