ALUMINUM ELECTROLYTIC CAPACITOR ▪ DV SERIES
DV SERIES ▪ LOW IMPEDANCE, AUTOMOTIVE 105°C TYPE
KEY FEATURES
ALUMINUM ELECTROLYTIC CAPACITOR ▪ SMD type
Endurance: 105°C ▪ 2 000 hours up to 5 000 hours
Low impedance type
Vibration-proof (VP) version (up to 30g) available upon request
AEC-Q200 version available
SPECIFICATIONS
Items
Operating Temperature Range
Rated Voltage Range
VR
Surge Voltage
VS
Capacitance Range
CR
Cap. Tolerance
ΔC
Leakage Current
ILEAK
(20°C ▪ VR applied)
Dissipation Factor %
tanδ
(20°C ▪ 120Hz)
Low Temperature
Characteristics at
120Hz
Performance Characteristics
-55 ~ +105°C
6.3 ~ 100V DC
VS = 1.15∙VR
1 ~ 6800µF
±20% (120Hz ▪ 20°C)
≤ 0.01∙CR∙VR or 3µA, whichever is greater ▪ After 2 minutes
[ ILEAK (µA) ; CR (µF) ; VR (V) ]
VR (V DC)
tanδ
VR (V DC)
Z ratio
max.
Z-25°C/Z+20°C
Z-40°C/Z+20°C
Z-55°C/Z+20°C
6.3
24
10
19
16
16
25
14
35
14
50
12
63
10
80
9
100
8
6.3
2
8
12
10
2
6
10
16
2
4
6
25
2
4
6
35
2
3
4
50
2
3
4
63
2
3
4
80
2
3
4
100
2
3
4
Lifetime Test
Endurance
105°C
(VR applied)
Shelf Life
105°C
(VR = 0)
Resistance to Soldering Heat
CapXon_Ver. 004 – 01/07/2022
≥ Ø 12.5mm
5 000 hours
< Ø 12.5mm
2 000 hours
△C/CR ≤ ±30% of initial measured value
tanδ ≤ 300% of initial specified value
ILeak ≤ the initial specified value
Test 1 000 hours
Before measurement: Restore capacitor to 20°C, apply VR for 30 min
according JIS-C-5101-4
The capacitors shall be kept on a hot plate maintained at 250°C for 30 seconds. After removing from the hot plate and restored at room temperature,
they meet the characteristic requirements listed below
△C/CR Within ±10% of initial value
tanδ Less than specified value
ILeak Less than specified value
Test
1
For further information please contact sales@capxon.org
Document Number: DV series
6.3
10
Standard
VR
(V)
Vibration-proof
STANDARD RATINGS
Part number shows blister tape on paper reel
CR
(µF)
øD
(mm)
L
(mm)
Z ▪ Max.
Impedance
+20°C ▪ 100kHz
(mΩ)
IR ▪ Max.
Ripple Current
+105°C ▪ 100kHz
(mA rms)
CapXon Part Number
22
27
33
33
47
47
56
68
68
100
100
150
150
220
220
330
330
470
680
1000
1000
1200
1500
1800
3300
6800
22
27
33
33
47
47
56
68
100
100
150
150
220
220
330
470
680
4
4
4
5
4
5
5
5
6.3
5
6.3
6.3
8
6.3
6.3
6.3
8
8
8
8
10
10
10
10
12.5
16
4
5
4
5
5
6.3
6.3
6.3
5
6.3
6.3
8
6.3
8
8
8
10
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
6.5
7.7
5.5
7.7
6.5
10.5
10.5
10.5
10.5
10.5
10.5
10.5
14
17
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
6.5
7.7
6.5
10.5
10.5
10.5
2200
1980
1900
1300
1880
1100
1100
900
550
800
530
510
480
450
480
360
340
280
250
200
170
160
130
80
80
52
2200
1900
1850
1200
1100
590
570
550
800
530
490
470
440
400
250
250
200
75
79
82
130
86
150
150
160
220
170
230
235
250
260
240
275
290
450
500
530
570
600
650
860
1100
1250
80
125
90
150
165
180
210
220
210
240
250
260
270
285
500
550
680
DV220M6R3B055ETR ꙱꙱
DV270M6R3B055ETR ꙱꙱
DV330M6R3B055ETR ꙱꙱
DV330M6R3C055ETR ꙱꙱
DV470M6R3B055ETR ꙱꙱
DV470M6R3C055ETR ꙱꙱
DV560M6R3C055ETR ꙱꙱
DV680M6R3C055ETR ꙱꙱
DV680M6R3E055ETR ꙱꙱
DV101M6R3C055ETR ꙱꙱
DV101M6R3E055ETR ꙱꙱
DV151M6R3E055ETR ꙱꙱
DV151M6R3F065ETR ꙱꙱
DV221M6R3E077ETR ꙱꙱
DV221M6R3E055ETR ꙱꙱
DV331M6R3E077ETR ꙱꙱
DV331M6R3F065ETR ꙱꙱
DV471M6R3F105ETR ꙱꙱
DV681M6R3F105ETR ꙱꙱
DV102M6R3F105ETR ꙱꙱
DV102M6R3G105ETR ꙱꙱
DV122M6R3G105ETR ꙱꙱
DV152M6R3G105ETR ꙱꙱
DV182M6R3G105ETR ꙱꙱
DV332M6R3Z140ETR ꙱꙱
DV682M6R3J170ETR ꙱꙱
DV220M010B055ETR ꙱꙱
DV270M010C055ETR ꙱꙱
DV330M010B055ETR ꙱꙱
DV330M010C055ETR ꙱꙱
DV470M010C055ETR ꙱꙱
DV470M010E055ETR ꙱꙱
DV560M010E055ETR ꙱꙱
DV680M010E055ETR ꙱꙱
DV101M010C055ETR ꙱꙱
DV101M010E055ETR ꙱꙱
DV151M010E055ETR ꙱꙱
DV151M010F065ETR ꙱꙱
DV221M010E077ETR ꙱꙱
DV221M010F065ETR ꙱꙱
DV331M010F105ETR ꙱꙱
DV471M010F105ETR ꙱꙱
DV681M010G105ETR ꙱꙱
꙱꙱ see description at end of standard ratings
2
10
16
25
Standard
VR
(V)
Vibration-proof
STANDARD RATINGS
CR
(µF)
øD
(mm)
L
(mm)
Z ▪ Max.
Impedance
+20°C ▪ 100kHz
(mΩ)
IR ▪ Max.
Ripple Current
+105°C ▪ 100kHz
(mA rms)
CapXon Part Number
1000
2200
4700
10
15
22
22
27
33
47
47
56
68
68
100
150
150
220
220
330
470
680
1500
3300
6.8
10
15
22
22
27
33
33
47
47
56
68
68
100
100
150
220
330
470
10
12.5
16
4
4
4
5
5
6.3
5
6.3
6.3
6.3
8
6.3
6.3
8
6.3
8
8
8
10
12.5
16
4
4
5
5
6.3
6.3
5
6.3
6.3
6.3
6.3
6.3
8
6.3
8
8
8
8
10
10.5
14
17
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
6.5
5.5
7.7
6.5
7.7
6.5
10.5
10.5
10.5
14
17
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
7.7
5.5
5.5
5.5
6.5
7.7
6.5
10.5
10.5
10.5
10.5
150
80
52
2200
2000
1980
1600
740
600
1050
580
560
540
500
520
450
440
430
410
250
220
160
80
52
2800
2100
1900
1200
1150
620
1050
580
540
560
540
480
450
380
360
250
220
200
150
740
1100
1250
80
85
90
140
170
185
195
210
220
230
240
255
265
270
275
285
550
590
720
1100
1250
70
85
125
145
160
200
160
220
230
220
230
240
260
290
300
480
530
570
650
DV102M010G105ETR ꙱꙱
DV222M010Z140ETR ꙱꙱
DV472M010J170ETR ꙱꙱
DV100M016B055ETR ꙱꙱
DV150M016B055ETR ꙱꙱
DV220M016B055ETR ꙱꙱
DV220M016C055ETR ꙱꙱
DV270M016C055ETR ꙱꙱
DV330M016E055ETR ꙱꙱
DV470M016C055ETR ꙱꙱
DV470M016E055ETR ꙱꙱
DV560M016E055ETR ꙱꙱
DV680M016E055ETR ꙱꙱
DV680M016F065ETR ꙱꙱
DV101M016E055ETR ꙱꙱
DV151M016E077ETR ꙱꙱
DV151M016F065ETR ꙱꙱
DV221M016E077ETR ꙱꙱
DV221M016F065ETR ꙱꙱
DV331M016F105ETR ꙱꙱
DV471M016F105ETR ꙱꙱
DV681M016G105ETR ꙱꙱
DV152M016Z140ETR ꙱꙱
DV332M016J170ETR ꙱꙱
DV6R8M025B055ETR ꙱꙱
DV100M025B055ETR ꙱꙱
DV150M025C055ETR ꙱꙱
DV220M025C055ETR ꙱꙱
DV220M025E055ETR ꙱꙱
DV270M025E055ETR ꙱꙱
DV330M025C055ETR ꙱꙱
DV330M025E055ETR ꙱꙱
DV470M025E077ETR ꙱꙱
DV470M025E055ETR ꙱꙱
DV560M025E055ETR ꙱꙱
DV680M025E055ETR ꙱꙱
DV680M025F065ETR ꙱꙱
DV101M025E077ETR ꙱꙱
DV101M025F065ETR ꙱꙱
DV151M025F105ETR ꙱꙱
DV221M025F105ETR ꙱꙱
DV331M025F105ETR ꙱꙱
DV471M025G105ETR ꙱꙱
3
25
35
50
Standard
VR
(V)
Vibration-proof
STANDARD RATINGS
CR
(µF)
øD
(mm)
L
(mm)
Z ▪ Max.
Impedance
+20°C ▪ 100kHz
(mΩ)
IR ▪ Max.
Ripple Current
+105°C ▪ 100kHz
(mA rms)
CapXon Part Number
1000
2200
3.3
4.7
6.8
10
10
15
22
22
27
33
33
47
47
56
68
100
100
150
220
330
470
680
1500
1
2.2
3.3
4.7
6.8
10
10
15
22
27
33
33
47
47
56
68
100
150
12.5
16
4
4
4
4
5
5
5
6.3
6.3
6.3
8
6.3
8
6.3
6.3
6.3
8
8
8
10
12.5
12.5
16
4
4
4
4
5
5
6.3
6.3
6.3
6.3
6.3
8
6.3
8
8
8
8
10
14
17
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
6.5
5.5
6.5
7.7
7.7
7.7
10.5
10.5
10.5
10.5
14
14
17
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
5.5
7.7
7.7
6.5
7.7
6.5
10.5
10.5
10.5
10.5
80
52
2800
2500
2200
2000
1400
1200
1100
1050
600
540
510
530
490
490
400
380
280
240
210
150
80
80
52
4500
4500
4500
4500
3800
2800
2200
1600
1300
1200
710
700
700
690
520
500
460
250
1100
1250
80
85
88
90
125
140
155
170
210
230
260
240
250
250
265
300
420
510
570
650
1100
1100
1250
55
55
55
55
75
95
130
140
150
180
190
200
230
240
300
320
350
600
DV102M025Z140ETR ꙱꙱
DV222M025J170ETR ꙱꙱
DV3R3M035B055ETR ꙱꙱
DV4R7M035B055ETR ꙱꙱
DV6R8M035B055ETR ꙱꙱
DV100M035B055ETR ꙱꙱
DV100M035C055ETR ꙱꙱
DV150M035C055ETR ꙱꙱
DV220M035C055ETR ꙱꙱
DV220M035E055ETR ꙱꙱
DV270M035E055ETR ꙱꙱
DV330M035E055ETR ꙱꙱
DV330M035F065ETR ꙱꙱
DV470M035E055ETR ꙱꙱
DV470M035F065ETR ꙱꙱
DV560M035E077ETR ꙱꙱
DV680M035E077ETR ꙱꙱
DV101M035E077ETR ꙱꙱
DV101M035F105ETR ꙱꙱
DV151M035F105ETR ꙱꙱
DV221M035F105ETR ꙱꙱
DV331M035G105ETR ꙱꙱
DV471M035Z140ETR ꙱꙱
DV681M035Z140ETR ꙱꙱
DV152M035J170ETR ꙱꙱
DV010M050B055ETR ꙱꙱
DV2R2M050B055ETR ꙱꙱
DV3R3M050B055ETR ꙱꙱
DV4R7M050B055ETR ꙱꙱
DV6R8M050C055ETR ꙱꙱
DV100M050C055ETR ꙱꙱
DV100M050E055ETR ꙱꙱
DV150M050E055ETR ꙱꙱
DV220M050E055ETR ꙱꙱
DV270M050E077ETR ꙱꙱
DV330M050E077ETR ꙱꙱
DV330M050F065ETR ꙱꙱
DV470M050E077ETR ꙱꙱
DV470M050F065ETR ꙱꙱
DV560M050F105ETR ꙱꙱
DV680M050F105ETR ꙱꙱
DV101M050F105ETR ꙱꙱
DV151M050G105ETR ꙱꙱
4
50
63
80
100
Standard
VR
(V)
Vibration-proof
STANDARD RATINGS
CR
(µF)
øD
(mm)
L
(mm)
Z ▪ Max.
Impedance
+20°C ▪ 100kHz
(mΩ)
IR ▪ Max.
Ripple Current
+105°C ▪ 100kHz
(mA rms)
CapXon Part Number
220
330
1000
4.7
10
22
33
47
68
100
100
150
220
470
4.7
10
22
33
47
68
100
220
10
22
33
47
47
68
100
220
10
12.5
16
5
6.3
6.3
8
8
10
10
12.5
12.5
12.5
16
6.3
6.3
6.3
8
10
10
12.5
16
6.3
8
10
10
12.5
12.5
12.5
16
10.5
14
17
5.5
5.5
7.7
10.5
10.5
10.5
10.5
14
14
14
17
5.5
7.7
7.7
10.5
10.5
10.5
14
17
7.7
10.5
10.5
10.5
14
14
14
17
230
210
78
2800
1600
1100
800
550
400
280
260
200
180
85
3800
3000
1700
1100
900
650
420
260
4000
2000
1300
1000
950
600
500
280
650
800
1000
45
80
150
230
260
380
400
520
780
810
1390
50
70
110
200
320
490
580
930
65
110
180
370
480
580
620
1050
DV221M050G105ETR ꙱꙱
DV331M050Z140ETR ꙱꙱
DV102M050J170ETR ꙱꙱
DV4R7M063C055ETR ꙱꙱
DV100M063E055ETR ꙱꙱
DV220M063E077ETR ꙱꙱
DV330M063F105ETR ꙱꙱
DV470M063F105ETR ꙱꙱
DV680M063G105ETR ꙱꙱
DV101M063G105ETR ꙱꙱
DV101M063Z140ETR ꙱꙱
DV151M063Z140ETR ꙱꙱
DV221M063Z140ETR ꙱꙱
DV471M063J170ETR ꙱꙱
DV4R7M080E055ETR ꙱꙱
DV100M080E077ETR ꙱꙱
DV220M080E077ETR ꙱꙱
DV330M080F105ETR ꙱꙱
DV470M080G105ETR ꙱꙱
DV680M080G105ETR ꙱꙱
DV101M080Z140ETR ꙱꙱
DV221M080J170ETR ꙱꙱
DV100M100E077ETR ꙱꙱
DV220M100F105ETR ꙱꙱
DV330M100G105ETR ꙱꙱
DV470M100G105ETR ꙱꙱
DV470M100Z140ETR ꙱꙱
DV680M100Z140ETR ꙱꙱
DV101M100Z140ETR ꙱꙱
DV221M100J170ETR ꙱꙱
꙱꙱: Enter blank for Standard package
꙱꙱: Enter W for Vibration proof version
꙱꙱: Enter X for AEC-Q200
꙱꙱: Enter XW for AEC-Q200 and Vibration proof version
5
±0
DIMENSIONS STANDARD PACKAGE ▪ All dimensions in mm
øD
4.0
5.0
6.3
6.3
8.0
8.0
10.0
12.5
16.0
L
5.5
5.5
5.5
7.7
6.5
10.5
10.5
14.0
17.0
α
Max
Max
0.2
Max
Max
Max
Max
Max
0.5
A ± 0.2
4.3
5.3
6.6
6.6
8.3
8.3
10.3
13.0
17.0
B ± 0.2
4.3
5.3
6.6
6.6
8.3
8.3
10.3
13.0
17.0
C ± 0.2
4.9
5.9
7.2
7.2
9.0
9.0
11.0
13.9
18.0
F
0.3 max.
0.3 max.
0.3 max.
0.3 max.
0.3 max.
0.3 max.
0.3 max.
0.3 max.
0.3 max.
P ± 0.2
1.0
1.4
2.2
2.2
2.3
3.1
4.5
4.5
6.6
W
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
1 to 1.4
1 to 1.4
DIMENSIONS VP PACKAGE (VIBRATION-PROOF) Ø D6.3 ▪ All dimensions in mm
c
±0
c
T
øD
L
α
A ± 0.2
A1 (max.)
B ± 0.2
C (max.)
F
6.3
8.0
0.3
6.6
7.1
6.6
7.8
0 to 0.15
øD
6.3
L
8.0
P ± 0.2
2.2
S ± 0.1
2.9
I ± 0.1
2.4
T ± 0.1
1.1
6
U ± 0.1
1.55
K
0.35
+0.15/-0.2
W ± 0.1
0.65
±0
DIMENSIONS VP PACKAGE (VIBRATION-PROOF) Ø D8 and D10 ▪ All dimensions in mm
T
øD
8
10
L
10.5
10.5
α
0.5
0.5
A ± 0.2
8.3
10.3
A1 (max.)
8.8
10.8
B ± 0.2
8.3
10.3
C (max.)
10.0
12.0
F
0 to 0.15
0 to 0.15
K ± 0.2
0.7
0.7
øD
8
10
L
10.5
10.5
P ± 0.2
3.1
4.6
S ± 0.1
3
3.3
I ± 0.1
3.4
3.5
T ± 0.1
1.4
1.5
U ± 0.1
0.7
0.8
W ± 0.1
1.2
1.2
M ± 0.1
0.7
0.9
±0
DIMENSIONS VP PACKAGE (VIBRATION-PROOF) Ø D12.5 and D16 ▪ All dimensions in mm
T
øD
12.5
16.0
L
14.0
17.0
α
1.0
1.0
A ± 0.2
13.5
17.0
A1 (max.)
13.5
17.0
B ± 0.2
13.5
17.0
C (max.)
15.0
19.0
F
0 to 0.15
0 to 0.15
K ± 0.3
0.7
0.7
øD
12.5
16.0
L
14.0
17.0
P ± 0.2
4.4
6.7
S ± 0.1
6.0
5.8
I ± 0.1
4.7
5.5
T ± 0.1
2.0
2.0
U ± 0.1
2.2
3.0
W ± 0.1
1.2
1.4
M ± 0.1
0.95
1.0
7
MULTIPLIER Kf for RIPPLE CURRENT vs. FREQUENCY
CR (µF) / Frequency (Hz)
50/60
100/120
500
1k
10k
50k ~ 100k
1 ≤ CR ≤ 10
10 < CR ≤ 6800
0.47
0.52
0.59
0.65
0.76
0.8
0.85
0.89
0.97
0.97
1
1
PRECAUTIONS, GUIDELINES AND PACKAGING INFORMATION
nless otherwise agreed in individual specifications, all products are subject to our “General recautions
and Guidelines” as well as our “ ackaging nformation” lease refer to the following links in the table.
General Precautions
& Guidelines
Packaging Information
Vibration Test Profiles
3D Models
Reliability Tests
DISCLAIMER
All product related data (e.g. specification, statements and general information) are subject to change without any notice. It is necessary that the customer
observes all product related technical / application information and handling instructions.
CapXon products are designed and manufactured according to severe quality and safety standards. Under no circumstance, CapXon warrants that any
CapXon product is suitable for the purposes intended for your application, even CapXon knows the application. It is customer's duty and obligation to check
and make sure that CapXon products are suitable for the purposes intended and select the correct and proper CapXon product. Customers are requested to
perform a sufficient validation and reliability evaluation to assure needed safety level and reliability performance by suitable designs and to apply proper
safeguards (e.g. redundancies, protective circuits).
Particular operating conditions (ambient temperature, ripple current, voltage, thermal resistance, etc.) as well as storage, production or assembly may affect
the performance and the lifetime of the capacitor. Please consult CapXon for lifetime estimation, failure mode considerations or worst-case scenarios according to the product technology, product tolerances / deviations or change of the characteristics of the capacitor due to shipment, storage, handling,
production and usage.
or aerospace or military application, life‐saving, life‐sustaining, safety critical applications or any application where failure may cause severe personal injury
or death, please consult us before design‐in the capacitor in your application.
Except for the written expressed warranties, CapXon does not impliedly, by assumption or whatever else, warrant, undertake, promise any other warranty
or guaranty for any CapXon product.
For further information, please visit our website www.capxongroup.com or contact CapXon directly.
8
很抱歉,暂时无法提供与“DV470M035E055ETR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.24480
- 100+0.22880
- 500+0.21280
- 2000+0.18880
- 5000+0.18080
- 10000+0.17600
- 国内价格
- 10+0.79040
- 100+0.47150
- 500+0.33000
- 1000+0.23570
- 2000+0.22400
- 10000+0.20750
