BRE.3V.200.NAV
BRE.3V.200.NAV
    LEMO(雷莫)
    CONNCAP
BRE.3V.200.NAV 数据手册
BRE.3V.200.NAV www.lemo.com SUMMARY # Wires Image is for illustrative purpose only Series 3V Termination type No contacts / Accessory IP rating 68 when mated AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model BRE*: Cap for receptacle Keying Circular, female Housing Material Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces Weight 32.82 g Performance Configuration Insulator Rated Current Others Endurance (Shell): 1000 mating cycles Temp (min / max): -20°C / +135°C Climatical Category: 20/200/21 Shielding (min): 95 dB (10 MHz) Shielding (min): 80 dB (1 GHz) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Salt Spray Corrosion: >144 hr Pressure: 30 bars DRAWINGS Dimensions A L N S1 mm. 27.8 14.7 120 26 in. 1,09 0,58 4,72 1,02 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
BRE.3V.200.NAV 价格&库存
很抱歉,暂时无法提供与“BRE.3V.200.NAV”相匹配的价格&库存,您可以联系我们找货
