CSRF Series
Stackpole Electronics, Inc.
Resistive Product Solutions
Foil on Ceramic Current Sensing Chip Resistor
Features:
High power rating
Wide resistance range
Current handling up to 26 amps
TCR down to ± 50 ppm/C
Other resistance values may be available
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Electrical Specifications - CSRF
Type/Code
Power Rating (W)
CSRF0402 (2)
0.125
CSRF0603 (2)
0.25
CSRF0805 (2)
0.5
CSRF0508 (2)
1
(2)
1
CSRF1206
CSRF0612
1.5
CSRF2010 (1)
1
(2)
2
CSRF2512
TCR (ppm/ºC)
± 300
± 200
± 100
± 150
± 75
± 100
± 50
± 100
± 50
± 100
± 50
± 100
± 75
± 200
± 100
± 50
± 100
± 50
CSRF2817
5
4
3
2
± 50
CSRF4320
5
± 50
Ohmic Range (Ω) and Tolerance
1% and 5%
0.003 - 0.007
0.008 - 0.02
0.002 - 0.004
0.005 - 0.009
0.01 - 0.03
0.003 - 0.01
0.011 - 0.03
0.005 - 0.009
0.01 - 0.062
0.003 - 0.01
0.011 - 0.05
0.002 - 0.004
0.005 - 0.03
0.002
0.003 - 0.009
0.01 - 0.1
0.002 - 0.009
0.01 - 0.56
0.003 - 0.02
0.021 - 0.04
0.041 - 0.06
0.061 - 0.1
0.01 - 0.33
(1) For 2010 size, MOQ of 20K pieces per value is required.
(2) Qualified to AEC-Q200
Electrical Specifications – CSRF-HP
Type/Code
CSRF0402…-HP
Power Rating (W)
(2)
TCR (ppm/ºC)
±400
±300
±200
±100
±100
±75
±100
±50
0.25
CSRF0603…-HP (2)
0.5
CSRF0805…-HP
1
1% and 5%
0.0025
0.003 - 0.004
0.005 - 0.007
0.008 - 0.02
0.002 - 0.009
0.01 - 0.03
0.005 - 0.009
0.01 - 0.03
Rev Date: 11/4/2022
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
www.seielect.com
marketing@seielect.com
CSRF Series
Please refer to the High-Power Resistor Application Note (page 9) for more information on designing and implementing high power
resistor types.
Mechanical Specifications – CSRF0402
Type/Code
CSRF0402
0.003 Ω - 0.007 Ω
CSRF0402
0.008 Ω - 0.02 Ω
L
Body Length
0.039 ± 0.004
1.00 ± 0.10
0.039 ± 0.004
1.00 ± 0.10
W
Body Width
0.022 ± 0.004
0.55 ± 0.10
0.022 ± 0.004
0.55 ± 0.10
H
Body Height
0.018 ± 0.004
0.45 ± 0.10
0.018 ± 0.004
0.45 ± 0.10
T
Bottom Termination
0.014 ± 0.004
0.35 ± 0.10
0.010 ± 0.004
0.25 ± 0.10
Unit
inches
mm
inches
mm
Mechanical Specifications – CSRF0402…-HP
Type/Code
CSRF0402…-HP
0.0025 Ω
CSRF0402… -HP
0.003 Ω - 0.004 Ω
L
Body Length
0.039 ± 0.004
1.00 ± 0.10
0.039 ± 0.004
1.00 ± 0.10
W
Body Width
0.022 ± 0.004
0.55 ± 0.10
0.022 ± 0.004
0.55 ± 0.10
H
Body Height
0.018 ± 0.004
0.45 ± 0.10
0.018 ± 0.004
0.45 ± 0.10
T
Bottom Termination
0.018 ± 0.004
0.45 ± 0.10
0.018 ± 0.004
0.45 ± 0.10
Unit
inches
mm
inches
mm
Type/Code
CSRF0402…-HP
0.005 Ω - 0.007 Ω
CSRF0402…-HP
0.008 Ω - 0.02 Ω
L
Body Length
0.039 ± 0.004
1.00 ± 0.10
0.039 ± 0.004
1.00 ± 0.10
Rev Date: 11/4/2022
W
Body Width
0.022 ± 0.004
0.55 ± 0.10
0.022 ± 0.004
0.55 ± 0.10
2
H
Body Height
0.018 ± 0.004
0.45 ± 0.10
0.018 ± 0.004
0.45 ± 0.10
T
Bottom Termination
0.014 ± 0.004
0.35 ± 0.10
0.010 ± 0.004
0.25 ± 0.10
Unit
inches
mm
inches
mm
www.seielect.com
CSRF Series
Mechanical Specifications – CSRF0603 and CSRF0603…-HP
L
Body Length
CSRF0603
0.063 ± 0.004
0.002 Ω - 0.004 Ω
1.60 ± 0.10
CSRF0603
0.063 ± 0.004
0.005 Ω - 0.03 Ω
1.60 ± 0.10
Note: CSRF0603…2L50 has no marking.
Type/Code
W
Body Width
0.031 ± 0.004
0.80 ± 0.10
0.031 ± 0.004
0.80 ± 0.10
H
Body Height
0.022 ± 0.006
0.55 ± 0.15
0.022 ± 0.006
0.55 ± 0.15
T
Bottom Termination
0.022 ± 0.008
0.55 ± 0.20
0.012 ± 0.008
0.30 ± 0.20
Unit
inches
mm
inches
mm
Mechanical Specifications – CSRF0805
Type/Code
CSRF0805
L
Body Length
0.083 ± 0.008
2.10 ± 0.20
W
Body Width
0.051 ± 0.006
1.30 ± 0.15
H
Body Height
0.028 ± 0.006
0.70 ± 0.15
A
Top Termination
0.016 ± 0.008
0.40 ± 0.20
T
Bottom Termination
0.018 ± 0.008
0.45 ± 0.20
Unit
inches
mm
Mechanical Specifications – CSRF0805…-HP
Type/Code
CSRF0805…-HP
L
Body Length
0.083 ± 0.008
2.10 ± 0.20
W
Body Width
0.051 ± 0.006
1.30 ± 0.15
H
Body Height
0.028 ± 0.006
0.70 ± 0.15
T
Bottom Termination
0.018 ± 0.008
0.45 ± 0.20
Unit
inches
mm
Mechanical Specifications – CSRF0508
Type/Code
CSRF0508
L
Body Length
0.047 ± 0.010
1.20 ± 0.25
Rev Date: 11/4/2022
W
Body Width
0.079 ± 0.010
2.00 ± 0.25
3
H
Body Height
0.026 ± 0.008
0.65 ± 0.20
T
Bottom Termination
0.017 ± 0.008
0.43 ± 0.20
Unit
inches
mm
www.seielect.com
CSRF Series
Mechanical Specifications – CSRF1206
Type/Code
CSRF1206
L
Body Length
0.122 ± 0.008
3.10 ± 0.20
W
Body Width
0.061 ± 0.008
1.55 ± 0.20
H
Body Height
0.031 ± 0.006
0.80 ± 0.15
A
Top Termination
0.020 ± 0.008
0.50 ± 0.20
T
Bottom Termination
0.022 ± 0.008
0.55 ± 0.20
Unit
inches
mm
Mechanical Specifications – CSRF2512
Type/Code
CSRF2512
L
Body Length
0.252 ± 0.012
6.40 ± 0.30
W
Body Width
0.126 ± 0.012
3.20 ± 0.30
H
Body Height
0.030 ± 0.012
0.75 ± 0.30
T
Bottom Termination
0.055 ± 0.022
1.40 ± 0.55
Unit
inches
mm
Mechanical Specifications – CSRF0612
Type/Code
CSRF0612
L
Body Length
0.063 ± 0.008
1.60 ± 0.20
W
Body Width
0.126 ± 0.008
3.20 ± 0.20
H
Body Height
0.024 ± 0.008
0.60 ± 0.20
T
Bottom Termination
0.012 ± 0.008
0.30 ± 0.20
Unit
inches
mm
Mechanical Specifications – CSRF2010
Type/Code
CSRF2010
0.002Ω
CSRF2010
0.003Ω
CSRF2010
0.004Ω-0.005Ω
CSRF2010
>0.005 Ω
L
Body Length
0.197 ± 0.008
5.00 ± 0.20
W
Body Width
t
Body Height
0.098 ± 0.008
2.50 ± 0.20
Rev Date: 11/4/2022
0.030 ± 0.008
0.75 ± 0.20
4
a
Top Termination
0.024 ± 0.012
0.60 ± 0.30
b
Bottom Termination
0.071 ± 0.012
1.80 ± 0.30
0.063 ± 0.012
1.60 ± 0.30
0.051 ± 0.012
1.30 ± 0.30
0.031 ± 0.012
0.80 ± 0.30
Unit
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
CSRF Series
Mechanical Specifications – CSRF2817
Type/Code
Ohmic Value
(Ω)
0.003 - 0.004
CSRF2817
0.005 - 0.1
L
Body Length
W
Body Width
H
Body Height
0.280 ± 0.012
7.10 ± 0.30
0.165 ± 0.012
4.20 ± 0.30
0.031 ± 0.008
0.80 ± 0.20
T
Bottom Termination
0.043 ± 0.012
1.10 ± 0.30
0.039 ± 0.012
1.00 ± 0.30
Unit
inches
mm
inches
mm
Mechanical Specifications – CSRF4320
L
Body Length
0.433 ± 0.008
11.00 ± 0.20
Type/Code
CSRF4320
W
Body Width
0.197 ± 0.008
5.00 ± 0.20
H
Body Height
0.026 ± 0.008
0.65 ± 0.20
T
Bottom Termination
0.093 ± 0.012
2.36 ± 0.30
Unit
inches
mm
Performance Characteristics
Test
Test Method
Test Specification Typical
Test Condition
Load Life
MIL-STD-202F-Method 108A
±1%
≤ 0.5%
RCWV at 70°C; 1.5 hours "ON"; 0.5 hour "OFF"
Total 1000 ± 24 hours
Resistance to Soldering Heat
MIL-STD-202F-Method 210E
±1%
≤ 0.3%
260ºC ± 5°C for 10 ± 1 seconds
Solderability
MIL-STD-202F-Method 208H
minimum 95%
coverage
> 95%
245ºC ± 5°C for 2 ± 0.5 seconds
Thermal Shock
MIL-STD-202F-Method 107G
±1%
≤ 0.3%
-55°C to 150°C, 100 cycles
JIS-C-5202-5.5
± 1% + 0.5 mΩ
≤ 0.3%
High Temperature Exposure
Moisture Resistance
MIL- STD-202F-Method 106G
±1%
±1%
≤ 0.2%
≤ 0.5%
Insulation Resistance
MIL-STD-202F-Method 302
1 MΩ minimum
≥ 1 MΩ
Short Time Overload
Sizes 0805-HP, 0508, 2512 and 2817:
2.5 X rated power for 5 seconds
Size 4320: 3 X rated power for 5 seconds
All other sizes: 5 X rated power for 5 seconds
125ºC, 1000 hours
Apply 100VDC for 1 minute
(*) Sufficient copper size and weight required to maintain component temperature below 100°C
Storage Temperature: 5ºC ~ 35°C. humidity: 40% ~ 75%
Operating temperature range: CSRF2817 = -55°C to + 155°C; all other sizes = -55°C to + 170°C
Rev Date: 11/4/2022
5
www.seielect.com
CSRF Series
Power Derating Curve:
Taping Specifications – Paper Tape
Type/Code
CSRF0402
CSRF0603
CSRF0805
CSRF0508
CSRF1206
CSRF0612
A
0.028
0.70
0.043
1.10
0.063
1.60
0.066
1.68
0.079
2.00
0.079
2.00
Type/Code
CSRF0402
CSRF0603
CSRF0805
CSRF0508
CSRF1206
CSRF0612
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
B
± 0.002
± 0.05
± 0.004
± 0.10
± 0.004
± 0.10
± 0.008
± 0.20
± 0.004
± 0.10
± 0.004
± 0.10
P0
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.047
1.20
0.075
1.90
0.094
2.40
0.094
2.38
0.142
3.60
0.142
3.60
0.079
2.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
E
± 0.002
± 0.05
± 0.004
± 0.10
± 0.004
± 0.10
± 0.008
± 0.20
± 0.004
± 0.10
± 0.004
± 0.10
P1
Rev Date: 11/4/2022
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
6
F
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
P2
0.002
0.05
0.002
0.05
0.002
0.05
0.004
0.10
0.002
0.05
0.002
0.05
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.061
1.55
0.061
1.55
0.061
1.55
0.059
1.50
0.061
1.55
0.061
1.55
W
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.004
± 0.10
± 0.002
± 0.05
± 0.002
± 0.05
D0
0.002
0.05
0.002
0.05
0.002
0.05
0.004
0.10
0.002
0.05
0.002
0.05
Unit
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
T
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.008
0.20
0.008
0.20
Inches
mm
Inches
mm
Inches
mm
Inches
mm
Inches
mm
Inches
mm
Unit
0.024
0.60
0.028
0.70
0.038
0.97
0.034
0.87
0.038
0.97
0.038
0.97
0.004
0.10
0.004
0.10
0.004
0.10
0.008
0.20
0.004
0.10
0.004
0.10
Inches
mm
Inches
mm
Inches
mm
Inches
mm
Inches
mm
Inches
mm
www.seielect.com
CSRF Series
Taping Specifications – Embossed Plastic Tape
Type/Code
A
0.110
2.80
0.134
3.40
CSRF2010
CSRF2512
Type/Code
B
0.006
0.15
0.008
0.20
0.217
5.50
0.266
6.75
0.004
0.10
0.004
0.10
0.157
4.00
0.157
4.00
P0
0.157
4.00
0.157
4.00
CSRF2010
CSRF2512
E
0.006
0.15
0.008
0.20
0.069
1.75
0.069
1.75
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
P1
F
0.004
0.10
0.004
0.10
0.217
5.50
0.217
5.50
0.002
0.05
0.004
0.10
0.059
1.50
0.059
1.50
P2
W
0.002
0.05
0.004
0.10
0.472
12.00
0.472
12.00
± 0.004
± 0.1
0.10
± 0.004
± 0.10
0.033
0.84
0.039
1.00
D0
Unit
0.012
0.30
0.012
0.30
Inches
mm
Inches
mm
0.008
0.20
0.008
0.20
Inches
mm
Inches
mm
T
Unit
Type/Code
CSRF2817
CSRF4320
A
0.181
4.60
0.211
5.36
Type/Code
CSRF2817
CSRF4320
B
0.004
0.10
0.004
0.10
0.295
7.50
0.462
11.74
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
P1
0.315
8.00
0.315
8.00
E
0.004
0.10
0.004
0.10
0.069
1.75
0.069
1.75
0.004
0.10
0.004
0.10
0.059
1.50
0.059
1.50
P2
F
0.004
0.10
0.004
0.10
0.217
5.50
0.453
11.50
0.004
0.10
0.004
0.10
0.061
1.55
0.059
1.50
D0
W
0.004
0.10
0.004
0.10
0.472
12.00
0.945
24.00
0.004
0.10
0.010
0.25
0.010
0.25
0.013
0.33
D1
P0
0.012
0.30
0.012
0.30
0.157
4.00
0.157
4.00
0.002
0.05
0.004
0.10
0.039
1.00
0.077
1.96
T
Unit
0.004
0.10
0.004
0.10
Inches
mm
Inches
mm
0.004
0.10
0.004
0.10
Inches
mm
Inches
mm
T2
Unit
Recommended Pad Layouts - CSRF
Size
Ohmic Range (Ω)
0.003 - 0.007
CSRF0402
0.008 - 0.02
a
b
c
Unit
0.012
0.30
0.020
0.50
0.024
0.60
0.020
0.50
0.024
0.60
0.024
0.60
inches
mm
inches
mm
Rev Date: 11/4/2022
7
www.seielect.com
CSRF Series
Recommended Pad Layouts – CSRF (cont.)
Size
Ohmic Range (Ω)
0.002 - 0.004
CSRF0603
0.005 - 0.009
0.01 - 0.03
CSRF0805
All
CSRF0508
All
CSRF1206
All
CSRF0612
All
0.002
CSRF2010
0.003 - 0.009
0.01 - 0.1
CSRF2512
0.002 - 0.003
CSRF2512
0.004 - 0.56
CSRF2817
0.003 - 0.004
CSRF2817
0.005 - 0.1
CSRF4320
All
a
0.014
0.35
0.024
0.60
0.035
0.90
0.047
1.20
0.024
0.60
0.087
2.20
0.024
0.60
0.039
1.00
0.063
1.60
0.106
2.70
0.063
1.60
0.122
3.10
0.161
4.10
0.177
4.50
0.157
4.00
b
0.043
1.10
0.035
0.90
0.028
0.70
0.047
1.20
0.043
1.10
0.051
1.30
0.051
1.30
0.104
2.65
0.093
2.35
0.071
1.80
0.152
3.85
0.122
3.10
0.098
2.50
0.091
2.30
0.197
5.00
c
0.039
1.00
0.039
1.00
0.039
1.00
0.055
1.40
0.091
2.30
0.071
1.80
0.142
3.60
0.114
2.90
0.114
2.90
0.114
2.90
0.141
3.57
0.141
3.57
0.189
4.80
0.189
4.80
0.276
7.00
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Recommended Pad Layouts – CSRF-HP
Size
Ohmic Range (Ω)
CSRF0402…-HP
All
CSRF0603…-HP
0.005 - 0.009
CSRF0603…-HP
0.01 - 0.03
CSRF0805…-HP
All
a
b
c
Unit
0.008
0.20
0.024
0.60
0.035
0.90
0.047
1.20
0.031
0.80
0.035
0.90
0.028
0.70
0.047
1.20
0.024
0.60
0.039
1.00
0.039
1.00
0.055
1.40
inches
mm
inches
mm
inches
mm
inches
mm
Soldering Recommendations:
Peak reflow temperatures and durations:
o IR Reflow Peak = 260°C max for 10 seconds
o Wave Solder = 260°C max for 10 seconds
Compatible with lead and lead-free solder reflow process
Recommended IR Reflow Profile:
Rev Date: 11/4/2022
8
www.seielect.com
CSRF Series
High Power Chip Resistors and Thermal Management
Stackpole has developed several surface mount resistor series in addition to our current sense resistors, which have had
higher power ratings than standard resistor chips. This has caused some uncertainty and even confusion by users as to
how to reliably use these resistors at the higher power ratings in their designs.
The data sheets for the RHC, RMCP, RNCP, CSR, CSRN, CSRF, CSS, and CSSH state that the rated power assumes
an ambient temperature of no more than 100ºC for the CSS / CSSH series and 70ºC for all other high power resistor
series. In addition, IPC and UL best practices dictate that the combined temperature on any resistor due to power
dissipated and ambient air shall be no more than 105ºC. At first glance this wouldn’t seem too difficult, however the graph
below shows typical heat rise for the CSR1206 100 milliohm at full rated power. The heat rise for the RMCP and RNCP
would be similar. The RHC with its unique materials, design, and processes would have less heat rise and therefore
would be easier to implement for any given customer.
The 102ºC heat rise shown here would indicate there will be additional thermal reduction techniques needed to keep this
part under 105 ºC total hot spot temperature if this part is to be used at 0.75 watts of power. However, this same part at
the usual power rating for this size would have a heat rise of around 72ºC. This additional heat rise may be dealt with
using wider conductor traces, larger solder pads and land patterns under the solder mask, heavier copper in the
conductors, vias through PCB, air movement, and heat sinks, among many other techniques. Because of the variety of
methods customers can use to lower the effective heat rise of the circuit, resistor manufacturers simply specify power
ratings with the limitations on ambient air temperature and total hot spot temperatures and leave the details of how to best
accomplish this to the design engineers. Design guidelines for products in various market segments can vary widely so
it would be unnecessarily constraining for a resistor manufacturer to recommend the use of any of these methods over
another.
Note: The final resistance value can be affected by the board layout and assembly process, especially the size of the mounting pads and the amount
of solder used. This is especially notable for resistance values ≤ 50mΩ. This should be taken into account when designing.
Rev Date: 11/4/2022
9
www.seielect.com
CSRF Series
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
CSRF
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
Surface Mount Chip Resistor
SMD
YES
100% Matte Sn over Ni
Jul-04
04/27
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
C
S
R
F
F
T
8
L
H
P
Product Series
Code Description
CSRF Foil/Ceramic
Size
Code
0402
0603
0805
0508
1206
0612
2010
2512
2817
4320
W
Std
0.125
0.25
0.5
1
1
1.5
1
2
2-5
5
-HP
0.25
0.5
1
NA
NA
NA
NA
NA
NA
NA
Tolerance
Code Tol
F
1%
J
5%
Rev Date: 11/4/2022
Code
T
Packaging
Description
Size
Quantity
0402
10000
7" Reel
0603, 0805
Paper Tape 0612, 1206 5000
0508
2010
4000
Embossed
2512
Plastic Tape
2000
2817, 4320
10
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
"L" used as multiplier
-3
of 10 for any value
under 0.1 ohm..
0.005 ohm = 5L00
0.01 ohm = 10L0
0.1 ohm = R100
Special
Code Description
blank
Standard
-HP High Power
www.seielect.com
