BGK.0M.200.XAZ
BGK.0M.200.XAZ
    LEMO(雷莫)
    BGK.0M.200.XAZ
BGK.0M.200.XAZ 数据手册
BGK.0M.200.XAZ www.lemo.com SUMMARY # Wires Image is for illustrative purpose only Series 0M Termination type No contacts / Accessory IP rating 68 when mated AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model BGK*: Blanking caps, large washer for fixed sockets(artic grip) Keying Housing Material Aluminium (nickel plated [SAE AMS QQ N 290], anthracite color) shell and nut, other pieces bronze/brass Weight 4.91 g Performance Configuration Insulator Rated Current Specifications Contact LEMO for performance details. Others Temp (min / max): -20°C / +135°C Humidity (max): 21 days at 95% Gunfire vibration: 25 Hz - 2000 Hz, 3 axis (Apache helicopter) Vibration-Sine: 30 g, 3 axes, 12 hr [10 Hz - 2000 Hz] LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Vibration-Random: 37.8 g rms - 3 axes, 4 hr amb [50 Hz - 2000 Hz] Shock Resistance: 300 g [ 3 ms] Lighting strike EIA 364-75: 10K amps - 6 times Thermal shock: 5 cycles: -65°C to +150°C EMI Shielding EIA 364-66A: >= 80 dB (1 GHz), >=70 dB (3 GHz), >= 58 dB (6 GHz), >= 40 dB (10 GHz) Salt Spray Corrosion: max. 48 hr DRAWINGS Dimensions A C L N P X mm. 14.4 13.1 12.7 17 23.4 85 in. 0,57 0,52 0,50 0,67 0,92 3,35 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
BGK.0M.200.XAZ 价格&库存
很抱歉,暂时无法提供与“BGK.0M.200.XAZ”相匹配的价格&库存,您可以联系我们找货
