BME.3M.200.XAZ
www.lemo.com
SUMMARY
# Wires
Image is for illustrative purpose only
Series
3M
Termination type
No contacts / Accessory
IP rating
68 when mated
AWG wire size
0.00 - 0.00
Cable Ø
0.00 - 0.00 mm
Status
active
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
BME*: Blanking cap for fixed receptacle(knurled grip)
Keying
Housing Material
Aluminium (nickel plated [SAE AMS QQ N 290], anthracite color) shell and nut, other pieces
bronze/brass
Weight
7.62 g
Performance
Configuration
Insulator
Rated Current
Specifications
Contact LEMO for performance details.
Others
Temp (min / max): -20°C / +135°C
Humidity (max): 21 days at 95%
Gunfire vibration: 25 Hz - 2000 Hz, 3 axis (Apache helicopter)
Vibration-Sine: 30 g, 3 axes, 12 hr [10 Hz - 2000 Hz]
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
Vibration-Random: 37.8 g rms - 3 axes, 4 hr amb [50 Hz - 2000 Hz]
Shock Resistance: 300 g [ 3 ms]
Lighting strike EIA 364-75: 10K amps - 6 times
Thermal shock: 5 cycles: -65°C to +150°C
EMI Shielding EIA 364-66A: >= 80 dB (1 GHz), >=70 dB (3 GHz), >= 58 dB (6 GHz), >= 40 dB (10 GHz)
Salt Spray Corrosion: max. 48 hr
DRAWINGS
Dimensions
A
C
L
N
P
X
mm.
19.6
19.2
23.4
120
3.9
6
in.
0,77
0,76
0,92
4,72
0,15
0,24
RECOMMENDED BY LEMO
Tools
2/2
很抱歉,暂时无法提供与“BME.3M.200.XAZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1014.854801+130.03661
- 10+979.2455310+125.47388
