BRR.0S.200.PZSN
BRR.0S.200.PZSN
    LEMO(雷莫)
    CONN SPRING CAP FOR 0S-0B IP61
BRR.0S.200.PZSN 数据手册
BRR.0S.200.PZSN www.lemo.com SUMMARY # Wires Image is for illustrative purpose only Series 0S Termination type No contacts / Accessory IP rating 61 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status obsolete Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model BRR*: Cap spring loaded dust cap for ERA,ERN and EG receptacle or PSA and PK fixed receptacle Keying No keying Housing Material PSU (Polysulfone) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant N : Black Weight .52 g Performance Configuration Insulator Rated Current Others Endurance (Shell): 5000 mating cycles Temp (min / max): -50°C / +150°C LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Axes material: Nickel-plated brass Maximum operating temperature: 100°C Watertightness: IP61 according to IEC 60529 DRAWINGS Dimensions A B C E L M N mm. 11 13.3 9 5.8 5 1.2 15.3 in. 0,43 0,52 0,35 0,23 0,20 0,05 0,60 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
BRR.0S.200.PZSN 价格&库存
很抱歉,暂时无法提供与“BRR.0S.200.PZSN”相匹配的价格&库存,您可以联系我们找货
BRR.0S.200.PZSN
  • 1+110.985011+14.38577
