INTELIGENT I/O
EXPANSION CHIP
RABBIT RIO®
The Rabbit RIO chip is an intelligent I/O processor
ideally equipped for industrial automation and control
The Rabbit RIO chip offers both I/O expansion and peripheral
features that easily integrate into new or existing designs. It
interfaces to any microcontroller with an available SPI or
parallel port. Multiple peripheral features offer a distinct
advantage for motor control applications. The Rabbit RIO
simply takes the load off the processor, making it ideal for
applications with demanding networking requirements.
configurable for higher drive current operations. The same
signal could be output on multiple pins for applications that
require a higher current. It also provides push pull protection
for sink and source drivers.
The Rabbit RIO is also ideal for machine control applications.
I/Os are 5V tolerant, which also includes pin-pair protection
for applications such as H-bridge drivers. Since multiple
status bits are set from a single match register, pins are easily
BENEFITS
APPLICATION EXAMPLE
– Easily interface to any CPU via an available SPI or
parallel port
CPU INTERFACE (PARALLEL OR SPI)
– Instantly add up to 32 digital I/O lines
– 8 independent functional channels with 4 ports each
Functional channels configurable as:
Bi-directional I/O, PWM or PPM outputs, TRIAC
signal generators, input capture, counter,
Quadrature decode peripheral
– Add I/O and peripheral features to any new or
existing design
– Use multiple Rabbit RIO devices for large I/O
requirements
RELATED PRODUCTS
Rabbit® SBC
BL2100
Series
Rabbit® SBC
BL4S100
Series
Rabbit® SBC
BL4S200
Series
RabbitCore®
RCM3000
Series
Dynamic C®
GLOBAL CONTROL
Block 0
Block 7
PWM, PPM, I/O,
Quadrature Decoder
PWM, PPM, I/O,
Quadrature Decoder
Block 1
Block 6
PWM, PPM, I/O,
Quadrature Decoder
PWM, PPM, I/O,
Quadrature Decoder
Block 2
Block 5
PWM, PPM, I/O,
Quadrature Decoder
PWM, PPM, I/O,
Quadrature Decoder
Block 3
Block 4
PWM, PPM, I/O,
Quadrature Decoder
PWM, PPM, I/O,
Quadrature Decoder
Rabbit RIO® Expansion Chip
SPECIFICATIONS
FEATURES
CLOCK SPEED
Up to 40 MHz
OPERATING VOLTAGE
3.0-3.6VDC
MAXIMUM I/O INPUT VOLTAGE
5.0VDC (3.3VDC typ.)
CORE CURRENT
22 MHz @ 31.3 mA, 25° C
I/O RING
22 MHz @ 1.1 mA, 25° C
OUTPUT DRIVE
8 mA
CPU INTERFACES
SPI or 8-bit parallel
FIXED DIGITAL INPUTS
4
CONFIGURABLE I/O
8 independent channels, each with 4 ports:
• Up to 32 bi-directional I/O lines
• Up to 32 PWM outputs
• Up to 16 PPM outputs
• Up to 32 TRIAC signal generators
• Up to 8 input capture peripherals
• Up to 8 counters
• Up to 8 quadrature decode peripherals
PACKAGE TYPE
64-pin TQFP 10 mm x 10 mm x 1.4 mm
RIO PROGRAMMABLE I/O APPLICATION KIT
APPLICATION KIT CONTENTS:
• RCM4110 module
• Rabbit RIO Prototyping Board
• Universal AC adapter, 12 V DC, 1 A.*
• 10-pin header to DB9 programming cable with integrated
level-matching circuitry
• Plastic and metal standoffs with 4-40 screws
• A bag of jumpers and jumper wires for use on the
Prototyping Board
• Rabbit® 4000 Processor Easy Reference poster
*Included only with Application Kits sold for the North American market. A header plug leading to bare leads is
provided to allow overseas users to connect their own power supply with a DC output of 8–30 V.
PART NUMBERS
DESCRIPTION
101-1147
Rabbit RIO® Programmable I/O Application Kit
20-668-0030
Rio I/O chip
20-101-1187
Rio I/O chip (2 pack)
DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi
is always available to serve you with expert technical support and our industry
leading warranty. For detailed information visit www.digi.com/support.
© 1996-2015 Digi International Inc. All rights reserved.
All trademarks are the property of their respective owners.
91001590
C1/915
DIGI INTERNATIONAL WORLDWIDE HQ
877-912-3444 / 952-912-3444 / www.digi.com
DIGI INTERNATIONAL SINGAPORE
+65-6213-5380
DIGI INTERNATIONAL FRANCE
+33-1-55-61-98-98 / www.digi.fr
DIGI INTERNATIONAL CHINA
+86-21-50492199 / www.digi.com.cn
DIGI INTERNATIONAL JAPAN
+81-3-5428-0261 / www.digi-intl.co.jp
很抱歉,暂时无法提供与“20-668-0030”相匹配的价格&库存,您可以联系我们找货
