NCT5532D
NCT5532D
    NUVOTON(新唐)
    LQFP-64
    NCT5532D
NCT5532D 数据手册
NCT5532D Nuvoton LPC I/O Date: September 30th, 2011 Revision 0.7 NCT5532D Table of Contents – 1. 2. 3. 4. 5. GENERAL DESCRIPTION ......................................................................................................... 1 FEATURES ................................................................................................................................. 2 BLOCK DIAGRAM ...................................................................................................................... 5 PIN LAYOUT ............................................................................................................................... 6 PIN DESCRIPTION..................................................................................................................... 7 5.1 LPC Interface .................................................................................................................. 8 5.2 Serial Port Interface ........................................................................................................ 8 5.3 KBC Interface.................................................................................................................. 8 5.4 CIR Interface................................................................................................................... 9 5.5 Hardware Monitor Interface ............................................................................................ 9 5.6 Intel® PECI Interface .................................................................................................... 10 5.7 Advanced Configuration & Power Interface.................................................................. 10 5.8 Advanced Sleep State Control...................................................................................... 10 5.9 SMBus Interface ........................................................................................................... 11 5.10 Power Pins .................................................................................................................... 11 5.11 AMD Power-On Sequence ........................................................................................... 11 5.12 AMD SB-TSI Interface .................................................................................................. 12 5.13 Dual Voltage Control..................................................................................................... 12 5.14 DSW.............................................................................................................................. 12 5.15 IR .................................................................................................................................. 12 5.16 General Purpose I/O Port ............................................................................................. 12 5.16.1 5.16.2 5.16.3 5.16.4 5.16.5 6. GPIO-2 Interface .......................................................................................................................12 GPIO-4 Interface .......................................................................................................................13 GPIO-5 Interface .......................................................................................................................13 GPIO-7 Interface .......................................................................................................................14 GPIO-8 Interface .......................................................................................................................14 5.17 Strapping Pins............................................................................................................... 15 5.18 Internal pull-up, pull-down pins ..................................................................................... 15 GLUE LOGIC ............................................................................................................................ 17 6.1 ACPI Glue Logic ........................................................................................................... 17 6.2 BKFD_CUT & LATCH_BKFD_CUT.............................................................................. 19 6.3 3VSBSW# ..................................................................................................................... 20 6.4 PSON# Block Diagram ................................................................................................. 21 6.5 PWROK ........................................................................................................................ 22 6.6 Front Panel LEDs.......................................................................................................... 23 6.6.1 6.6.2 6.6.3 6.6.4 6.6.5 6.7 Automatic Mode ..........................................................................................................................23 Manual Mode ..............................................................................................................................24 S0~S5 LED Blink Block Diagram ................................................................................................ 24 LED Pole (LED_POL) .................................................................................................................25 Deeper Sleeping State Detect Function ...................................................................................... 26 Advanced Sleep State Control (ASSC) Function ......................................................... 28 6.7.1 6.7.2 6.7.3 When ASSC is disabled ..............................................................................................................28 When ASSC is enabled (Enter into Deeper Sleeping State) ....................................................... 29 When ASSC is enabled (Exit Deeper Sleeping State) ................................................................ 29 6.7.4 SLP_S5#_LATCH Control Function ............................................................................................30 -I- Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D 6.8 Intel DSW Function ....................................................................................................... 31 6.8.1 6.8.2 6.8.3 Enter DSW State timing diagram ................................................................................................ 31 Exit DSW State timing diagram ...................................................................................................32 Application Circuit .......................................................................................................................32 6.9 7. AMD Power-On Sequence ........................................................................................... 33 CONFIGURATION REGISTER ACCESS PROTOCOL ........................................................... 35 7.1 Configuration Sequence ............................................................................................... 37 7.1.1 7.1.2 7.1.3 7.1.4 8. HARDWARE MONITOR ........................................................................................................... 39 8.1 General Description ...................................................................................................... 39 8.2 Access Interfaces.......................................................................................................... 39 8.3 LPC Interface ................................................................................................................ 39 2 8.4 I C interface .................................................................................................................. 41 8.5 Analog Inputs ................................................................................................................ 42 8.5.1 8.5.2 8.5.3 8.6 8.7 Voltages Over 2.048 V or Less Than 0 V ....................................................................................43 Voltage Data Format ...................................................................................................................43 Temperature Data Format...........................................................................................................43 PECI.............................................................................................................................. 46 Fan Speed Measurement and Control ......................................................................... 48 8.7.1 8.7.2 8.7.3 8.7.4 8.7.5 8.7.6 8.8 Fan Speed Reading ....................................................................................................................48 Fan Speed Calculation by Fan Count Reading ...........................................................................48 Fan Speed Calculation by Fan RPM Reading .............................................................................48 Fan Speed Control ......................................................................................................................48 TM SMART FAN Control ............................................................................................................... 49 Temperature Source & Reading for Fan Control .........................................................................50 SMART FAN 8.8.1 8.8.2 8.9 8.10 8.10.1 8.10.2 8.10.3 8.10.4 8.10.5 TM I ............................................................................................................ 50 Thermal Cruise Mode..................................................................................................................50 Speed Cruise Mode ....................................................................................................................52 SMART FAN 8.9.1 8.9.2 8.9.3 8.9.4 9. Enter the Extended Function Mode ............................................................................................. 37 Configure the Configuration Registers ........................................................................................37 Exit the Extended Function Mode ............................................................................................... 38 Software Programming Example.................................................................................................38 TM IV & Close Loop Fan Control Mode..................................................... 53 Step Up Time / Step Down Time .................................................................................................56 Fan Output Step ..........................................................................................................................56 Revolution Pulse Selection..........................................................................................................57 Weight Value Control ..................................................................................................................57 Alert and Interrupt ......................................................................................................... 59 SMI# Interrupt Mode ..................................................................................................................60 Voltage SMI# Mode ...................................................................................................................60 Fan SMI# Mode .........................................................................................................................60 Temperature SMI# Mode ...........................................................................................................60 OVT# Interrupt Mode .................................................................................................................64 HARDWARE MONITOR REGISTER SET................................................................................ 66 9.1 Address Port (Port x5h) ................................................................................................ 66 9.2 Data Port (Port x6h) ...................................................................................................... 66 9.3 SYSFANOUT PWM Output Frequency Configuration Register – Index 00h (Bank 0) 67 9.4 SYSFANOUT Output Value Select Register – Index 01h (Bank 0).............................. 67 9.5 CPUFANOUT PWM Output Frequency Configuration Register – Index 02h (Bank 0) 68 Publication Release Date: September 30, 2011 -IIVersion: 0.7 NCT5532D 9.6 9.7 9.8 9.9 9.10 9.11 9.12 9.13 9.14 9.15 9.16 9.17 9.18 9.19 9.20 9.21 9.22 9.23 9.24 9.25 9.26 9.27 9.28 9.29 9.30 9.31 9.32 9.33 9.34 9.35 9.36 9.37 9.38 9.39 9.40 9.41 9.42 9.43 9.44 9.45 9.46 9.47 9.48 9.49 9.50 9.51 CPUFANOUT Output Value Select Register – Index 03h (Bank 0) ............................. 69 SYSFANOUT Configuration Register I – Index 04h (Bank 0) ...................................... 69 Reserved Register – Index 05h ~ 0Fh (Bank 0) ........................................................... 70 Reserved Register – Index 10h (Bank 0) ..................................................................... 70 Reserved Register – Index 11h (Bank 0) ..................................................................... 70 Reserved Register – Index 12h (Bank 0) ..................................................................... 70 Reserved Register – Index 13h (Bank 0) ..................................................................... 70 Reserved Register – Index 14h (Bank 0) ..................................................................... 70 Reserved Register – Index 15h (Bank 0) ..................................................................... 70 Reserved Register – Index 16-17h (Bank 0) ................................................................ 70 OVT# Configuration Register – Index 18h (Bank 0) ..................................................... 70 Reserved Registers – Index 19h ~ 1Fh (Bank 0) ......................................................... 70 Value RAM ⎯ Index 27h ~ 3Fh (Bank 0) ..................................................................... 70 Configuration Register – Index 40h (Bank 0) ............................................................... 71 Interrupt Status Register 1 – Index 41h (Bank 0) ......................................................... 72 Interrupt Status Register 2 – Index 42h (Bank 0) ......................................................... 72 SMI# Mask Register 1 – Index 43h (Bank 0) ................................................................ 73 SMI# Mask Register 2 – Index 44h (Bank 0) ................................................................ 73 Interrupt Status Register 4 – Index 45h (Bank 0) ......................................................... 73 SMI# Mask Register 3 – Index 46h (Bank 0) ................................................................ 74 Reserved Register – Index 47h (Bank 0) ..................................................................... 74 Serial Bus Address Register – Index 48h (Bank 0) ...................................................... 74 Reserved Register – Index 49h ~ 4Bh (Bank 0) ........................................................... 75 SMI/OVT Control Register1 – Index 4Ch (Bank 0)....................................................... 75 FAN IN/OUT Control Register – Index 4Dh (Bank 0) ................................................... 75 Bank Select Register – Index 4Eh (Bank 0) ................................................................. 76 Nuvoton Vendor ID Register – Index 4Fh (Bank 0) ...................................................... 76 Reserved Register – Index 50h (Bank 0) ..................................................................... 77 Reserved Register – Index 51h ~ 57h (Bank 0) ........................................................... 77 Chip ID – Index 58h (Bank 0) ....................................................................................... 77 Reserved Register – Index 59h ~ 5Ch (Bank 0)........................................................... 77 VBAT Monitor Control Register – Index 5Dh (Bank 0) ................................................. 77 Current Mode Enable Register – Index 5Eh (Bank 0) .................................................. 78 Reserved Register – Index 5F (Bank 0) ....................................................................... 79 Reserved Register – Index 60 (Bank 0) ....................................................................... 79 Reserved Register – Index 61F ~ 72F (Bank 0) ........................................................... 79 MONITOR TEMPERATURE 1 Register (Integer Value)- Index 73h (Bank 0) ............. 79 MONITOR TEMPERATURE 1 Register (Fractional Value)- Index 74h (Bank 0)......... 79 MONITOR TEMPERATURE 2 Register (Integer Value)- Index 75h (Bank 0) ............. 79 MONITOR TEMPERATURE 2 Register (Fractional Value)- Index 76h (Bank 0)......... 80 Reserved Register - Index 77h (Bank 0) ...................................................................... 80 Reserved Register - Index 78h (Bank 0) ...................................................................... 80 Reserved Register - Index 79h (Bank 0) ...................................................................... 80 Reserved Register - Index 7Ah (Bank 0) ...................................................................... 80 Reserved Register - Index 7Ch (Bank 0)...................................................................... 80 Reserved Register – Index 7Dh~ADh (Bank 0)............................................................ 80 -3- Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D 9.52 PECI Temperature Reading Enable for SMIOVT and SMART FAN Control Register – Index AEh (Bank 0) ......................................................................................................................... 80 9.53 BEEP Control Register 1 – Index B2h (Bank0) ............................................................ 81 9.54 BEEP Control Register 2 – Index B3h (Bank0) ............................................................ 81 9.55 BEEP Control Register 3 – Index B4h (Bank0) ............................................................ 82 9.56 BEEP Control Register 4 – Index B5h (Bank0) ............................................................ 82 9.57 SYSFAN Monitor Temperature Source Select Register/ STOPDUTY Enable Register – Index 00h (Bank 1) .......................................................................................................................... 83 9.58 SYSFAN Target Temperature Register / SYSFANIN Target Speed_L Register – Index 01h (Bank 1) .................................................................................................................................... 84 9.59 SYSFAN MODE Register / SYSFAN TOLERRANCE Register – Index 02h (Bank 1) . 84 9.60 SYSFANOUT Step Up Time Register – Index 03h (Bank 1)........................................ 85 9.61 SYSFANOUT Step Down Time Register – Index 04h (Bank 1) ................................... 85 9.62 SYSFANOUT Stop Value Register – Index 05h (Bank 1) ............................................ 85 9.63 SYSFANOUT Start-up Value Register – Index 06h (Bank 1)....................................... 86 9.64 SYSFANOUT Stop Time Register – Index 07h (Bank 1) ............................................. 86 9.65 Reserved Register – Index 08h (Bank 1) ..................................................................... 86 9.66 SYSFANOUT Output Value Select Register – Index 09h (Bank 1).............................. 86 9.67 Reserved Register – Index 0Ah~0Bh (Bank 1) ............................................................ 87 9.68 SYSFANIN Tolerance_H / Target Speed_H Register – Index 0Ch (Bank 1) ............... 87 9.69 Reserved Register – Index 0Dh~1Fh (Bank 1) ............................................................ 87 9.70 SMART FAN IV SYSFANOUT STEP Register – Index 20h (Bank 1) .......................... 87 TM 9.71 SYSFAN (SMART FAN IV) Temperature 1 Register(T1) – Index 21h (Bank 1) ....... 87 TM 9.72 SYSFAN (SMART FAN IV) Temperature 2 Register(T2) – Index 22h (Bank 1) ....... 88 TM 9.73 SYSFAN (SMART FAN IV) Temperature 3 Register(T3) – Index 23h (Bank 1) ....... 88 TM 9.74 SYSFAN (SMART FAN IV) Temperature 4 Register(T4) – Index 24h (Bank 1) ....... 88 9.75 Reserved Register – Index 25h~26h (Bank 1) ............................................................. 89 TM 9.76 SYSFAN (SMART FAN IV) DC/PWM 1 Register – Index 27h (Bank 1) ................... 89 TM 9.77 SYSFAN (SMART FAN IV) DC/PWM 2 Register – Index 28h (Bank 1) ................... 89 TM 9.78 SYSFAN (SMART FAN IV) DC/PWM 3 Register – Index 29h (Bank 1) ................... 89 TM 9.79 SYSFAN (SMART FAN IV) DC/PWM 4 Register – Index 2Ah (Bank 1)................... 89 9.80 Reserved Register – Index 2Bh~30h (Bank 1) ............................................................. 90 9.81 SYSFAN 3-Wire Enable Register – Index 31h (Bank 1) .............................................. 90 9.82 Reserved Register – Index 32h~34h(Bank 1) .............................................................. 90 TM 9.83 SYSFAN (SMART FAN IV) Critical Temperature Register – Index 35h (Bank 1) .... 90 9.84 SYSFAN Enable Critical Duty – Index 36h (Bank 1) ................................................... 90 9.85 SYSFAN Critical Duty Register – Index 37h (Bank 1) .................................................. 91 9.86 SYSFANOUT Critical Temperature Tolerance Register – Index 38h (Bank 1) ............ 91 9.87 Weight value Configuration Register – Index 39h (Bank 1) ......................................... 91 9.88 SYSFANOUT Temperature Step Register – Index 3Ah (Bank 1) ................................ 92 9.89 SYSFANOUT Temperature Step Tolerance Register – Index 3Bh (Bank 1) ............... 92 9.90 SYSFANOUT Weight Step Register – Index 3Ch (Bank 1) ......................................... 93 9.91 SYSFANOUT Temperature Base Register – Index 3Dh (Bank 1) ............................... 93 9.92 SYSFANOUT Temperature Fan Duty Base Register – index 3Eh (Bank 1) ................ 93 9.93 SYSFAN PECIERR DUTY Enable Register – Index 3Fh (Bank 1) .............................. 93 9.94 Reserved Register – Index 40h (Bank 1) ..................................................................... 94 9.95 SYSFANOUT Pre-Configured Register For PECI Error – Index 41h (Bank 1) ............ 94 -4- Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D 9.96 9.97 9.98 9.99 9.100 Reserved Register – Index 42h ~ 4Fh (Bank 1) ........................................................... 94 SMIOVT2 Temperature Source (High Byte) Register – Index 50h (Bank 1)................ 94 SMIOVT2 Temperature Source (Low Byte) Register – Index 51h (Bank 1)................. 94 SMIOVT2 Temperature Source Configuration Register – Index 52h (Bank 1) ............ 95 SMIOVT2 Temperature Source Hysteresis (High Byte) Register – Index 53h (Bank 1) 95 9.101 SMIOVT2 Temperature Source Hysteresis (Low Byte) Register – Index 54h (Bank 1)95 9.102 SMIOVT2 Temperature Source Over-temperature (High Byte) Register – Index 55h (Bank1) 96 9.103 SMIOVT2 Temperature Source Over-temperature (Low Byte) Register – Index 56h (Bank 1) 96 9.104 Reserved Register – Index 57h ~ FFh (Bank 1) ........................................................... 96 9.105 CPUFAN Monitor Temperature Source Select Register/ STOPDUTY Enable Register – Index 00h (Bank 2) .......................................................................................................................... 96 9.106 CPUFAN Target Temperature Register / CPUFANIN Target Speed_L Register – Index 01h (Bank 2) .................................................................................................................................... 97 9.107 CPUFAN MODE Register / CPUFAN TOLERRANCE Register – Index 02h (Bank 2) 98 9.108 CPUFANOUT Step Up Time Register – Index 03h (Bank 2) ....................................... 98 9.109 CPUFANOUT Step Down Time Register – Index 04h (Bank 2)................................... 98 9.110 CPUFANOUT Stop Value Register – Index 05h (Bank 2)............................................ 99 9.111 CPUFANOUT Start-up Value Register – Index 06h (Bank 2) ...................................... 99 9.112 CPUFANOUT Stop Time Register – Index 07h (Bank 2) ............................................. 99 9.113 Reserved Register – Index 08h (Bank 2) ..................................................................... 99 9.114 CPUFANOUT Output Value Select Register – Index 09h (Bank 2) ............................. 99 9.115 Reserved Register – Index 0Ah~0Bh (Bank 2) .......................................................... 100 9.116 CPUFANIN Tolerance_H / Target Speed_H Register – Index 0Ch (Bank 2)............. 100 9.117 Reserved Register – Index 0Dh~1Fh (Bank 2) .......................................................... 100 9.118 SMART FAN IV CPUFANOUT STEP Register – Index 20h (Bank 2)........................ 100 TM 9.119 CPUFAN (SMART FAN IV) Temperature 1 Register(T1) – Index 21h (Bank 2)..... 100 TM 9.120 CPUFAN (SMART FAN IV) Temperature 2 Register(T2) – Index 22h (Bank 2)..... 101 TM 9.121 CPUFAN (SMART FAN IV) Temperature 3 Register(T3) – Index 23h (Bank 2)..... 101 TM 9.122 CPUFAN (SMART FAN IV) Temperature 4 Register(T4) – Index 24h (Bank 2)..... 101 9.123 Reserved Register – Index 25h~26h (Bank 2) ........................................................... 102 TM 9.124 CPUFAN (SMART FAN IV) PWM1 Register – Index 27h (Bank 2) ........................ 102 TM 9.125 CPUFAN (SMART FAN IV) PWM2 Register – Index 28h (Bank 2) ........................ 102 TM 9.126 CPUFAN (SMART FAN IV) PWM3 Register – Index 29h (Bank 2) ........................ 102 TM 9.127 CPUFAN (SMART FAN IV) PWM4 Register – Index 2Ah (Bank 2)........................ 102 9.128 Reserved Register – Index 2Bh~30h (Bank 2) .......................................................... 103 9.129 CPUFAN 3-Wire FAN Enable Register – Index 31h (Bank 2) .................................... 103 9.130 Reserved Register – Index 32h ~ 34h(Bank 2) .......................................................... 103 TM 9.131 CPUFAN (SMART FAN IV) Critical Temperature Register – Index 35h (Bank 2) .. 103 9.132 CPUFAN Enable Critical Duty – Index 36h (Bank 2)................................................. 103 9.133 CPUFAN Critical Duty Register – Index 37h (Bank 2)................................................ 104 9.134 CPUFANOUT Critical Temperature Tolerance Register – Index 38h (Bank 2).......... 104 9.135 Weight value Configuration Register – Index 39h (Bank 2) ....................................... 104 9.136 CPUFANOUT Temperature Step Register – Index 3Ah (Bank 2) .............................. 105 9.137 CPUFANOUT Temperature Step Tolerance Register – Index 3Bh (Bank 2)............. 105 -5- Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D 9.138 9.139 9.140 9.141 9.142 9.143 9.144 9.145 9.146 9.147 9.148 9.149 9.150 9.151 9.152 9.153 9.154 9.155 9.156 9.157 9.158 9.159 9.160 9.161 9.162 9.163 9.164 9.165 9.166 9.167 9.168 9.169 9.170 9.171 9.172 9.173 9.174 9.175 9.176 9.177 9.178 9.179 9.180 9.181 9.182 9.183 9.184 CPUFANOUT Weight Step Register – Index 3Ch (Bank 2) ....................................... 106 CPUFANOUT Temperature Base Register – Index 3Dh (Bank 2) ............................. 106 CPUFANOUT Temperature Fan Duty Base Register – Index 3Eh (Bank 2) ............. 106 CPUFAN PECIERR DUTY Enable Register – Index 3Fh (Bank 2)............................ 106 Reserved Register – Index 40h (Bank 2) ................................................................... 107 CPUFANOUT Pre-Configured Register For PECI Error – Index 41h (Bank 2) .......... 107 Reserved Register – Index 42h ~ FFh (Bank 1) ......................................................... 107 Reserved Register – Index 00h (Bank 3) ................................................................... 107 Reserved Register – Index 01h (Bank 3) ................................................................... 107 Reserved Register – Index 02h (Bank 3) ................................................................... 107 Reserved Register – Index 03h (Bank 3) ................................................................... 107 Reserved Register – Index 04h (Bank 3) ................................................................... 107 Reserved Register – Index 05h (Bank 3) ................................................................... 107 Reserved Register – Index 06h (Bank 3) ................................................................... 107 Reserved Register – Index 07h (Bank 3) ................................................................... 107 Reserved Register – Index 08h (Bank 3) ................................................................... 107 Reserved Register – Index 09h (Bank 3) ................................................................... 107 Reserved Register – Index 0Ch (Bank 3) ................................................................... 108 Reserved Register – Index 0Dh (Bank 3) ................................................................... 108 Reserved Register – Index 20h (Bank 3) ................................................................... 108 Reserved Register – Index 21h (Bank 3) ................................................................... 108 Reserved Register – Index 22h (Bank 3) ................................................................... 108 Reserved Register – Index 23h (Bank 3) ................................................................... 108 Reserved Register – Index 24h (Bank 3) ................................................................... 108 Reserved Register – Index 25h~26h (Bank 3) ........................................................... 108 Reserved Register – Index 27h (Bank 3) ................................................................... 108 Reserved Register – Index 28h (Bank 3) ................................................................... 108 Reserved Register – Index 29h (Bank 3) ................................................................... 108 Reserved Register – Index 2Ah (Bank 3) ................................................................... 108 Reserved Register – Index Index 2Bh~30h (Bank 3) ................................................. 108 Reserved Register – Index 31h (Bank 3) ................................................................... 108 Reserved Register – Index 32h~34h(Bank 3) ............................................................ 108 Reserved Register – Index 35h (Bank 3) ................................................................... 108 Reserved Register – Index 36h (Bank 3) .................................................................. 108 Reserved Register – Index 37h (Bank 3) ................................................................... 108 Reserved Register – Index 38h (Bank 3) ................................................................... 108 Reserved Register – Index 39h (Bank 3) ................................................................... 108 Reserved Register – Index 3Ah (Bank 3) ................................................................... 108 Reserved Register – Index 3Bh (Bank 3) ................................................................... 109 Reserved Register – Index 3Ch (Bank 3) ................................................................... 109 Reserved Register – Index 3Dh (Bank 3) ................................................................... 109 Reserved Register – Index 3Eh (Bank 3) ................................................................... 109 Reserved Register – Index 3Fh (Bank 3) ................................................................... 109 Reserved Register – Index 40h (Bank 3) ................................................................... 109 Reserved Register – Index 41h (Bank 3) ................................................................... 109 Reserved Register – Index 42h ~ FFh (Bank 3) ......................................................... 109 PCH_CHIP_CPU_MAX_TEMP Register – Index 00h (Bank 4) ................................. 109 -VI- Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D 9.185 9.186 9.187 9.188 9.189 9.190 9.191 9.192 9.193 9.194 9.195 9.196 9.197 9.198 9.199 9.200 9.201 9.202 9.203 9.204 9.205 9.206 9.207 9.208 9.209 9.210 9.211 9.212 9.213 9.214 9.215 9.216 9.217 9.218 9.219 9.220 9.221 9.222 9.223 9.224 9.225 9.226 9.227 9.228 9.229 9.230 9.231 PCH_CHIP_TEMP Register – Index 01h (Bank 4)..................................................... 109 PCH_CPU_TEMP_H Register – Index 02h (Bank 4) ................................................ 109 PCH_CPU_TEMP_L Register – Index 03h (Bank 4)................................................. 110 PCH_MCH_TEMP Register – Index 04h (Bank 4) ..................................................... 110 PCH_DIM0_TEMP Register – Index 05h (Bank 4)..................................................... 110 PCH_DIM1_TEMP Register – Index 06h (Bank 4)..................................................... 111 PCH_DIM2_TEMP Register – Index 07h (Bank 4)..................................................... 111 PCH_DIM3_TEMP Register – Index 08h (Bank 4)..................................................... 111 PCH_TSI0_TEMP_H Register – Index 09h (Bank 4) ................................................. 111 PCH_TSI0_TEMP_L Register – Index 0Ah (Bank 4) ................................................. 112 PCH_TSI1_TEMP_H Register – Index 0Bh (Bank 4)................................................. 112 PCH_TSI1_TEMP_L Register – Index 0Ch (Bank 4) ................................................. 112 PCH_TSI2_TEMP_H Register – Index 0Dh (Bank 4) ................................................ 112 PCH_TSI2_TEMP_L Register – Index 0Eh (Bank 4) ................................................. 113 PCH_TSI3_TEMP_H Register – Index 0Fh (Bank 4)................................................. 113 PCH_TSI3_TEMP_L Register – Index 10h (Bank 4).................................................. 113 PCH_TSI4_TEMP_H Register – Index 11h (Bank 4) ................................................. 114 PCH_TSI4_TEMP_L Register – Index 12h (Bank 4).................................................. 114 PCH_TSI5_TEMP_H Register – Index 13h (Bank 4) ................................................. 114 PCH_TSI5_TEMP_L Register – Index 14h (Bank 4).................................................. 114 PCH_TSI6_TEMP_H Register – Index 15h (Bank 4) ................................................. 115 PCH_TSI6_TEMP_L Register – Index 16h (Bank 4).................................................. 115 PCH_TSI7_TEMP_H Register – Index 17h (Bank 4) ................................................. 115 PCH_TSI7_TEMP_L Register – Index 18h (Bank 4).................................................. 115 ByteTemp_H Register – Index 19h (Bank 4) .............................................................. 116 ByteTemp_L Register – Index 1Ah (Bank 4) .............................................................. 116 Reserved Register – Index 1Bh ~ 22h (Bank 4) ......................................................... 116 Reserved Register – Index 23h (Bank 4) ................................................................... 116 Reserved Register – Index 24h (Bank 4) ................................................................... 116 Reserved Register – Index 25h (Bank 4) ................................................................... 116 Reserved Register – Index 26h (Bank 4) ................................................................... 116 AVCC High Limit Compared Voltage Register – Index 27h (Bank 4)......................... 116 AVCC Low Limit Compared Voltage Register – Index 28h (Bank 4) ......................... 117 Reserved Register – Index 29h ~ 41h (Bank 4) ......................................................... 117 Voltage Comparation Interrupt Status Register - Index 42h (Bank 4) ....................... 117 Reserved Register – Index 43h ~ 49h (Bank 4) ......................................................... 117 Reserved Register – Index 4Ah (Bank 4) ................................................................... 117 Reserved Register – Index 4Bh (Bank 4) ................................................................... 117 VTIN0 Temperature Sensor Offset Register – Index 4Ch (Bank 4) ........................... 117 Reserved Register – Index 4Eh ~ 4Fh (Bank 4)......................................................... 118 Interrupt Status Register 3 – Index 50h (Bank 4) ....................................................... 118 SMI# Mask Register 4 – Index 51h (Bank 4) .............................................................. 118 Reserved Register – Index 52h ~ 53h (Bank 4) ......................................................... 119 Reserved Register – Index 54h (Bank 4) ................................................................... 119 CPUTIN Temperature Sensor Offset Register – Index 55h (Bank 4)......................... 119 AUXTIN0 Temperature Sensor Offset Register – Index 56h (Bank 4)....................... 119 Reserved Register – Index 57h-58h (Bank 4) ............................................................ 119 -VII- Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D 9.232 9.233 9.234 9.235 9.236 9.237 9.238 9.239 9.240 9.241 9.242 9.243 9.244 9.245 9.246 9.247 9.248 9.249 9.250 9.251 9.252 9.253 9.254 9.255 9.256 9.257 9.258 9.259 9.260 9.261 9.262 9.263 9.264 9.265 9.266 9.267 9.268 9.269 9.270 9.271 9.272 9.273 9.274 9.275 9.276 9.277 9.278 Real Time Hardware Status Register I – Index 59h (Bank 4) .................................... 119 Real Time Hardware Status Register II – Index 5Ah (Bank 4) ................................... 120 Real Time Hardware Status Register III – Index 5Bh (Bank 4) .................................. 121 Reserved Register – Index 5Ch ~ 5Fh (Bank 4) ........................................................ 121 Reserved Register – Index 60h (Bank 4) ................................................................... 121 Reserved Register – Index 61h (Bank 4) ................................................................... 121 Reserved Register – Index 62h (Bank 4) ................................................................... 121 Reserved Register – Index 63h (Bank 4) ................................................................... 121 Reserved Register – Index 64h (Bank 4) ................................................................... 121 Reserved Register – Index 65h (Bank 4) ................................................................... 122 Reserved Register – Index 66h (Bank 4) ................................................................... 122 Reserved Register – Index 67h (Bank 4) ................................................................... 122 Reserved Register – Index 68h ~ 7Fh (Bank 4) ......................................................... 122 Value RAM ⎯ Index 80h ~ 96h (Bank 4) ................................................................... 122 (SYSFANIN) FANIN1 COUNT High-byte Register – Index B0h (Bank 4).................. 122 (SYSFANIN) FANIN1 COUNT Low-byte Register – Index B1h (Bank 4)................... 123 (CPUFANIN) FANIN2 COUNT High-byte Register – Index B2h (Bank 4) ................. 123 (CPUFANIN) FANIN2 COUNT Low-byte Register – Index B3h (Bank 4) .................. 123 Reserved Register – Index B4h (Bank 4) ................................................................... 123 Reserved Register – Index B5h (Bank 4) ................................................................... 123 Reserved Register – Index B6h (Bank 4) ................................................................... 124 Reserved Register – Index B7h (Bank 4) ................................................................... 124 Reserved Register – Index B8h (Bank 4) ................................................................... 124 Reserved Register – Index B9h (Bank 4) ................................................................... 124 Reserved Register – Index BAh ~ BFh (Bank 4) ........................................................ 124 SYSFANIN SPEED HIGH-BYTE VALUE (RPM) - Index C0h (Bank 4) .................... 124 SYSFANIN SPEED LOW-BYTE VALUE (RPM) - Index C1h (Bank 4) ..................... 124 CPUFANIN SPEED HIGH-BYTE VALUE (RPM) – Index C2h (Bank 4) .................... 124 CPUFANIN SPEED LOW-BYTE VALUE (RPM) – Index C3h (Bank 4) ..................... 125 Reserved Register – Index C4h (Bank 4) ................................................................... 125 Reserved Register – Index C5h (Bank 4) ................................................................... 125 Reserved Register – Index C6h (Bank 4) ................................................................... 125 Reserved Register – Index C7h (Bank 4) ................................................................... 125 Reserved Register – Index C8h (Bank 4) ................................................................... 125 Reserved Register – Index C9h (Bank 4) ................................................................... 125 Reserved Register – Index 00h ~ 53h (Bank 5) ......................................................... 125 Value RAM 2 ⎯ Index 50h-5Fh (Bank 5) ................................................................... 125 SMI# Mask Register 1 – Index 66h (Bank 5) .............................................................. 126 Interrupt Status Register – Index 67h (Bank 5) .......................................................... 126 Real Time Hardware Status Register – Index 68h (Bank 5) ..................................... 126 Reserved Register – Index 69h ~ FFh (Bank 5) ......................................................... 127 Close-Loop Fan Control RPM mode Register – Index 00 (Bank 6) ........................... 127 SYSFAN RPM Mode Tolerance Register – Index 01 (Bank 6) .................................. 128 CPUFAN RPM Mode Tolerance Register – Index 02 (Bank 6) .................................. 128 Reserved Register – Index 03 (Bank 6) ..................................................................... 128 Reserved Register – Index 04 (Bank 6) ..................................................................... 128 Reserved Register – Index 05 (Bank 6) ..................................................................... 128 -VIII- Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D 9.279 9.280 9.281 9.282 9.283 9.284 9.285 9.286 9.287 9.288 9.289 9.290 9.291 9.292 9.293 9.294 9.295 9.296 9.297 9.298 9.299 9.300 9.301 9.302 9.303 9.304 9.305 9.306 9.307 9.308 9.309 9.310 9.311 9.312 9.313 9.314 9.315 9.316 9.317 9.318 9.319 9.320 9.321 9.322 9.323 9.324 9.325 Enable RPM High Mode Register – Index 00 (Bank 6) .............................................. 128 SMIOVT1 Temperature Source Select Register – Index 21 (Bank 6) ........................ 129 SMIOVT2 Temperature Source Select Register – Index 22 (Bank 6) ........................ 130 Reserved Register – Index 23~39h (Bank 6) ............................................................. 130 (SYSFANIN) Fan Count Limit High-byte Register – Index 3Ah (Bank 6) ................... 131 (SYSFANIN) Fan Count Limit Low-byte Register – Index 3Bh (Bank 6).................... 131 (CPUFANIN) Fan Count Limit High-byte Register – Index 3Ch (Bank 6) .................. 131 (CPUFANIN) Fan Count Limit Low-byte Register – Index 3Dh (Bank 6) ................... 131 Reserved Register – Index 3Eh (Bank 6) ................................................................... 132 Reserved Register – Index 3Fh (Bank 6) ................................................................... 132 Reserved Register – Index 40h (Bank 6) ................................................................... 132 Reserved Register – Index 41h (Bank 6) ................................................................... 132 Reserved Register – Index 42h (Bank 6) ................................................................... 132 Reserved Register – Index 43h (Bank 6) ................................................................... 132 SYSFANIN Revolution Pulses Selection Register – Index 44h (Bank 6) ................... 132 CPUFANIN Revolution Pulses Selection Register – Index 45h (Bank 6)................... 132 Reserved Register – Index 46h (Bank 6) ................................................................... 133 Reserved Register – Index 47h (Bank 6) ................................................................... 133 Reserved Register – Index 48h (Bank 6) ................................................................... 133 Reserved Register – Index 49~FFh (Bank 6) ............................................................. 133 PECI Function Control Registers – Index 01 ~ 04h (Bank 7) ..................................... 133 PECI Enable Function Register – Index 01h (Bank 7) ............................................... 133 PECI Timing Config Register – Index 02h (Bank 7) ................................................... 133 PECI Agent Config Register – Index 03h (Bank 7)..................................................... 134 PECI Temperature Config Register – Index 04h (Bank 7) ......................................... 134 PECI Command Write Date Registers – Index 05 ~ 1Eh (Bank 7) ............................ 135 PECI Command Address Register – Index 05h (Bank 7) .......................................... 135 PECI Command Write Length Register – Index 06h (Bank 7) ................................... 135 PECI Command Read Length Register – Index 07h (Bank 7) ................................... 135 PECI Command Code Register – Index 08h (Bank 7) ............................................... 136 PECI Command Tbase0 Register – Index 09h (Bank 7)............................................ 136 PECI Command Tbase1 Register – Index 0Ah (Bank 7) ........................................... 136 PECI Command Write Data 1 Register – Index 0Bh (Bank 7) ................................... 137 PECI Command Write Data 2 Register – Index 0Ch (Bank 7) ................................... 137 PECI Command Write Data 3 Register – Index 0Dh (Bank 7) ................................... 137 PECI Command Write Data 4 Register – Index 0Eh (Bank 7) ................................... 137 PECI Command Write Data 5 Register – Index 0Fh (Bank 7) ................................... 138 PECI Command Write Data 6 Register – Index 10h (Bank 7).................................... 138 PECI Command Write Data 7 Register – Index 11h (Bank 7).................................... 138 PECI Command Write Data 8 Register – Index 12h (Bank 7).................................... 138 PECI Command Write Data 9 Register – Index 13h (Bank 7).................................... 139 PECI Command Write Data 10 Register – Index 14h (Bank 7).................................. 139 PECI Command Write Data 11 Register – Index 15h (Bank 7).................................. 139 PECI Command Write Data 12 Register – Index 16h (Bank 7).................................. 140 PECI Agent Relative Temperature Register (ARTR) – Index 17h-1Eh (Bank 7) ....... 140 PECI Command Read Date Registers – Index 1F ~ 32h (Bank 7) ............................ 141 PECI Alive Agent Register – Index 1Fh (Bank 7) ....................................................... 141 -9- Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D 9.326 9.327 9.328 9.329 9.330 9.331 9.332 9.333 9.334 9.335 9.336 9.337 9.338 9.339 9.340 9.341 9.342 9.343 9.344 9.345 9.346 9.347 9.348 9.349 9.350 9.351 9.352 9.353 9.354 9.355 9.356 9.357 9.358 9.359 9.360 9.361 9.362 9.363 9.364 9.365 9.366 9.367 9.368 9.369 9.370 9.371 9.372 PECI Temperature Reading Register (Integer) – Index 20h (Bank 7)........................ 142 PECI Temperature Reading Register (Fraction) – Index 21h (Bank 7)...................... 142 PECI Command TN Count Value Register – Index 22h (Bank 7) .............................. 142 PECI Command TN Count Value Register – Index 23h (Bank 7) .............................. 143 PECI Command Warning Flag Register – Index 24h (Bank 7) .................................. 143 PECI Command FCS Data Register – Index 25h (Bank 7) ........................................ 143 PECI Command WFCS Data Register – Index 26h (Bank 7) .................................... 144 PECI RFCS Data Register – Index 27h (Bank 7) ....................................................... 144 PECI AWFCS Data Register – Index 28h (Bank 7).................................................... 144 PECI CRC OUT WFCS Data Register – Index 29h (Bank 7)..................................... 145 PECI Command Read Data 1 Register – Index 2Ah (Bank 7) ................................... 145 PECI Command Read Data 2 Register – Index 2Bh (Bank 7) ................................... 145 PECI Command Read Data 3 Register – Index 2Ch (Bank 7) ................................... 145 PECI Command Read Data 4 Register – Index 2Dh (Bank 7) ................................... 146 PECI Command Read Data 5 Register – Index 2Eh (Bank 7) ................................... 146 PECI Command Read Data 6 Register – Index 2Fh (Bank 7) ................................... 146 PECI Command Read Data 7 Register – Index 30h (Bank 7) ................................... 147 PECI Command Read Data 8 Register – Index 31h (Bank 7) ................................... 147 PECI Command Read Data 9 Register – Index 32h (Bank 7) ................................... 147 Reserved Register – Index 00h (Bank 8) ................................................................... 149 Reserved Register – Index 01h (Bank 8) ................................................................... 149 Reserved Register – Index 02h (Bank 8) ................................................................... 149 Reserved Register – Index 03h (Bank 8) ................................................................... 149 Reserved Register – Index 04h (Bank 8) ................................................................... 149 Reserved Register – Index 05h (Bank 8) ................................................................... 149 Reserved Register – Index 06h (Bank 8) ................................................................... 150 Reserved Register – Index 07h (Bank 8) ................................................................... 150 Reserved Register – Index 08h (Bank 8) ................................................................... 150 Reserved Register – Index 09h (Bank 8) ................................................................... 150 Reserved Register – Index 0Ch (Bank 8) ................................................................... 150 Reserved Register – Index 0Dh (Bank 8) ................................................................... 150 Reserved Register – Index 20h (Bank 8) ................................................................... 150 Reserved Register – Index 21h (Bank 8) ................................................................... 150 Reserved Register – Index 22h (Bank 8) ................................................................... 150 Reserved Register – Index 23h (Bank 8) ................................................................... 150 Reserved Register – Index 24h (Bank 8) ................................................................... 150 Reserved Register – Index 25h~26h (Bank 8) ........................................................... 150 Reserved Register – Index 27h (Bank 8) ................................................................... 150 Reserved Register – Index 28h (Bank 8) ................................................................... 150 Reserved Register – Index 29h (Bank 8) ................................................................... 150 Reserved Register – Index 2Ah (Bank 8) ................................................................... 150 Reserved Register – Index Index 2Bh~30h (Bank 8) ................................................. 150 Reserved Register – Index 31h (Bank 8) ................................................................... 150 Reserved Register – Index 32h~34h(Bank 8) ............................................................ 150 Reserved Register – Index 35h (Bank 8) ................................................................... 150 Reserved Register – Index 36h (Bank 8) .................................................................. 150 Reserved Register – Index 37h (Bank 8) ................................................................... 151 -10- Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D 9.373 9.374 9.375 9.376 9.377 9.378 9.379 9.380 9.381 9.382 9.383 9.384 9.385 9.386 9.387 9.388 9.389 9.390 9.391 9.392 9.393 9.394 9.395 9.396 9.397 9.398 9.399 9.400 9.401 9.402 9.403 9.404 9.405 9.406 9.407 9.408 9.409 9.410 9.411 9.412 9.413 9.414 9.415 9.416 9.417 9.418 9.419 Reserved Register – Index 38h (Bank 8) ................................................................... 151 Reserved Register – Index 39h (Bank 8) ................................................................... 151 Reserved Register – Index 3Ah (Bank 8) ................................................................... 151 Reserved Register – Index 3Bh (Bank 8) ................................................................... 151 Reserved Register – Index 3Ch (Bank 8) ................................................................... 151 Reserved Register – Index 3Dh (Bank 8) ................................................................... 151 Reserved Register – Index 3Eh (Bank 8) ................................................................... 151 Reserved Register – Index 3Fh (Bank 8) ................................................................... 151 Reserved Register – Index 40h (Bank 8) ................................................................... 151 Reserved Register – Index 41h (Bank 8) ................................................................... 151 Reserved Register – Index 42h ~ FFh (Bank 8) ......................................................... 151 Reserved Register – Index 00h (Bank 9) ................................................................... 151 Reserved Register – Index 01h (Bank 9) ................................................................... 151 Reserved Register – Index 02h (Bank 9) ................................................................... 151 Reserved Register – Index 03h (Bank 9) ................................................................... 151 Reserved Register – Index 04h (Bank 9) ................................................................... 151 Reserved Register – Index 05h (Bank 9) ................................................................... 151 Reserved Register – Index 06h (Bank 9) ................................................................... 151 Reserved Register – Index 07h (Bank 9) ................................................................... 151 Reserved Register – Index 08h (Bank 9) ................................................................... 151 Reserved Register – Index 09h (Bank 9) ................................................................... 152 Reserved Register – Index 0Ch (Bank 9) ................................................................... 152 Reserved Register – Index 0Dh (Bank 9) ................................................................... 152 Reserved Register – Index 20h (Bank 9) ................................................................... 152 Reserved Register – Index 21h (Bank 9) ................................................................... 152 Reserved Register – Index 22h (Bank 9) ................................................................... 152 Reserved Register – Index 23h (Bank 9) ................................................................... 152 Reserved Register – Index 24h (Bank 9) ................................................................... 152 Reserved Register – Index 25h~26h (Bank 9) ........................................................... 152 Reserved Register – Index 27h (Bank 9) ................................................................... 152 Reserved Register – Index 28h (Bank 9) ................................................................... 152 Reserved Register – Index 29h (Bank 9) ................................................................... 152 Reserved Register – Index 2Ah (Bank 9) ................................................................... 152 Reserved Register – Index Index 2Bh~30h (Bank 9) ................................................. 152 Reserved Register – Index 31h (Bank 9) ................................................................... 152 Reserved Register – Index 32h~34h(Bank 9) ............................................................ 152 Reserved Register – Index 35h (Bank 9) ................................................................... 152 Reserved Register – Index 36h (Bank 9) .................................................................. 152 Reserved Register – Index 37h (Bank 9) ................................................................... 152 Reserved Register – Index 38h (Bank 9) ................................................................... 152 Reserved Register – Index 39h (Bank 9) ................................................................... 152 Reserved Register – Index 3Ah (Bank 9) ................................................................... 153 Reserved Register – Index 3Bh (Bank 9) ................................................................... 153 Reserved Register – Index 3Ch (Bank 9) ................................................................... 153 Reserved Register – Index 3Dh (Bank 9) ................................................................... 153 Reserved Register – Index 3Eh (Bank 9) ................................................................... 153 Reserved Register – Index 3Fh (Bank 9) ................................................................... 153 -XI- Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D 9.420 Reserved Register – Index 40h (Bank 9) ................................................................... 153 9.421 Reserved Register – Index 41h (Bank 9) ................................................................... 153 9.422 Reserved Register – Index 42h ~ FFh (Bank 9) ......................................................... 153 10. UART PORT ........................................................................................................................... 154 10.1 UART Control Register (UCR) (Read/Write) .............................................................. 154 10.2 UART Status Register (USR) (Read/Write) ................................................................ 156 10.3 Handshake Control Register (HCR) (Read/Write) ...................................................... 156 10.4 Handshake Status Register (HSR) (Read/Write) ....................................................... 157 10.5 UART FIFO Control Register (UFR) (Write only) ....................................................... 158 10.6 Interrupt Status Register (ISR) (Read only)................................................................ 158 10.7 Interrupt Control Register (ICR) (Read/Write) ............................................................ 159 10.8 Programmable Baud Generator (BLL/BHL) (Read/Write) .......................................... 160 10.9 User-defined Register (UDR) (Read/Write) ................................................................ 160 10.10 UART RS485 Auto Flow Control ................................................................................ 161 11. KEYBOARD CONTROLLER................................................................................................... 162 11.1 Output Buffer............................................................................................................... 162 11.2 Input Buffer ................................................................................................................. 162 11.3 Status Register ........................................................................................................... 163 11.4 Commands.................................................................................................................. 164 11.5 Hardware GATEA20/Keyboard Reset Control Logic.................................................. 166 11.5.1 11.5.2 12. CONSUMER INFRARED REMOTE (CIR).............................................................................. 168 12.1 CIR Register Table ..................................................................................................... 168 12.1.1 12.1.2 12.1.3 12.1.4 12.1.5 12.1.6 12.1.7 12.1.8 12.1.9 12.1.10 12.1.11 12.1.12 12.1.13 12.1.14 12.1.15 12.1.16 12.1.17 13. KB Control Register (Logic Device 5, CR-F0).......................................................................... 166 Port 92 Control Register (Default Value = 0x24)...................................................................... 167 IR Configuration Register – Base Address + 0 ........................................................................ 168 IR Status Register – Base Address + 1 ................................................................................... 169 IR Interrupt Configuration Register – Base Address + 2 .......................................................... 169 RX FIFO Count– Base Address + 5......................................................................................... 170 IR TX Carrier Prescalar Configuration Register (CP) – Base Address + 4 .............................. 170 IR TX Carrier Period Configuration Register (CC) – Base Address + 5 ................................... 171 IR RX Sample Limited Count High Byte Register (RCLCH) – Base Address + 6 .................... 171 IR RX Sample Limited Count Low Byte Register (RCLCL) – Base Address + 7 ..................... 171 IR FIFO Configuration Register (FIFOCON) – Base Address + 8 ........................................... 171 IR Sample RX FIFO Status Register – Base Address + 9 .................................................. 172 IR Sample RX FIFO Register – Base Address + A ............................................................. 173 TX FIFO Count– Base Address + 5 .................................................................................... 173 IR Sample TX FIFO Register – Base Address + C ............................................................. 173 IR Carrier Count High Byte Register – Base Address + D .................................................. 174 IR Carrier Count Low Byte Register – Base Address + E ................................................... 174 IR FSM Status Register (IRFSM) – Base Address + F ....................................................... 174 IR Minimum Length Register – Base Address + F .............................................................. 175 CONSUMER INFRARED REMOTE (CIR) WAKE-UP............................................................ 176 13.1 CIR WAKE-UP Register Table ................................................................................... 176 13.1.1 13.1.2 13.1.3 13.1.4 IR Configuration Register – Base Address + 0 ........................................................................ 176 IR Status Register – Base Address + 1 ................................................................................... 177 IR Interrupt Configuration Register – Base Address + 2 .......................................................... 177 IR TX Configuration Register – Base Address + 3................................................................... 178 -XII- Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D 13.1.5 13.1.6 13.1.7 13.1.8 13.1.9 13.1.10 13.1.11 13.1.12 13.1.13 13.1.14 13.1.15 13.1.16 13.1.17 14. IR FIFO Compare Tolerance Configuration Register – Base Address + 4 .............................. 178 RX FIFO Count– Base Address + 5......................................................................................... 178 IR RX Sample Limited Count High Byte Register (RCLCH) – Base Address + 6 .................... 179 IR RX Sample Limited Count Low Byte Register (RCLCL) – Base Address + 7 ..................... 179 IR FIFO Configuration Register (FIFOCON) – Base Address + 8 ........................................... 179 IR Sample RX FIFO Status Register – Base Address + 9 .................................................. 180 IR Sample RX FIFO Register – Base Address + A ............................................................. 180 Write FIFO – Base Address + B.......................................................................................... 180 Read FIFO Only – Base Address + C ................................................................................. 181 Read FIFO Index – Base Address + D ............................................................................... 181 Reserved – Base Address + E............................................................................................181 IR FSM Status Register (IRFSM) – Base Address + F ....................................................... 182 IR Minimum Length Register – Base Address + F .............................................................. 182 POWER MANAGEMENT EVENT........................................................................................... 183 14.1 Power Control Logic ................................................................................................... 183 14.1.1 14.1.2 14.2 14.2.1 14.2.2 PSON# Logic ........................................................................................................................... 184 AC Power Failure Resume ...................................................................................................... 184 Wake Up the System by Keyboard and Mouse .......................................................... 185 Waken up by Keyboard events ................................................................................................ 186 Waken up by Mouse events .................................................................................................... 186 14.3 Resume Reset Logic .................................................................................................. 187 SERIALIZED IRQ .................................................................................................................... 188 15.1 Start Frame ................................................................................................................. 188 15.2 IRQ/Data Frame.......................................................................................................... 189 15.3 Stop Frame ................................................................................................................. 189 16. WATCHDOG TIMER............................................................................................................... 191 17. GENERAL PURPOSE I/O....................................................................................................... 192 17.1 GPIO ARCHITECTURE.............................................................................................. 192 17.2 ACCESS CHANNELS ................................................................................................ 195 18. SMBUS MASTER INTERFACE .............................................................................................. 196 18.1 General Description .................................................................................................... 196 18.2 Introduction to the SMBus Master .............................................................................. 196 15. 18.2.1 18.2.2 18.2.3 18.3 18.3.1 18.4 18.4.1 18.5 18.5.1 18.5.2 18.5.3 18.5.4 18.5.5 18.5.6 18.6 Data Transfer Format .............................................................................................................. 196 Arbitration ................................................................................................................................ 196 Clock Synchronization ............................................................................................................. 197 SB-TSI ........................................................................................................................ 198 SB-TSI Address ....................................................................................................................... 198 PCH ............................................................................................................................ 198 Command Summary................................................................................................................198 SMBus Master ............................................................................................................ 199 Block Diagram ......................................................................................................................... 199 Programming Flow .................................................................................................................. 200 TSI Routine.............................................................................................................................. 201 PCH Routine............................................................................................................................ 201 BYTE Ruttine ........................................................................................................................... 202 Manual Mode interface ............................................................................................................ 202 Register Type Abbreviations....................................................................................... 203 -XIII- Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D 18.6.1 18.6.2 18.7 18.7.1 18.7.2 18.7.3 18.7.4 18.7.5 18.7.6 18.7.7 18.7.8 18.7.9 18.7.10 18.7.11 18.7.12 18.7.13 18.7.14 18.7.15 18.7.16 18.7.17 Enter the Extended Function Mode ......................................................................................... 203 Configure the Configuration Registers..................................................................................... 204 SMBus Master Register Set ....................................................................................... 204 SMBus Register Map............................................................................................................... 204 SMBus Data (SMDATA) – Bank 0 ........................................................................................... 204 SMBus Write Data Size (SMWRSIZE) – Bank 0 ..................................................................... 205 SMBus Command (SMCMD) – Bank 0.................................................................................... 205 SMBus INDEX (SMIDX) – Bank 0 ........................................................................................... 206 SMBus Control (SMCTL) – Bank 0 .......................................................................................... 206 SMBus Address (SMADDR) – Bank 0 ..................................................................................... 207 SCL FREQ (SCLFREQ) – Bank 0 ........................................................................................... 207 PCH Address (PCHADDR) – Bank 0.......................................................................................208 SMBus Error Status (Error_status) – Bank 0 ...................................................................... 208 PCH Command (PCHCMD) – Bank 0................................................................................. 209 TSI Agent Enable Register (TSI_AGENT) – Bank .............................................................. 209 SMBus Control 3 Register (SMCTL3) – Bank 0 .................................................................. 210 SMBus Control 2 Register (SMCTL2) – Bank 0 .................................................................. 210 BYTE ADDRESS (BYTE ADDR) – Bank 0 ......................................................................... 211 BYTE INDEX_H (BYTE_IDX_H) – Bank 0.......................................................................... 211 BYTE INDEX_L (BYTE_IDX_L) – Bank 0 ........................................................................... 212 19. CONFIGURATION REGISTER............................................................................................... 213 19.1 Chip (Global) Control Register.................................................................................... 213 19.2 Logical Device 2 (UART A) ......................................................................................... 223 19.3 Logical Device 3 (IR) .................................................................................................. 225 19.4 Logical Device 5 (Keyboard Controller) ...................................................................... 227 19.5 Logical Device 6 (CIR) ................................................................................................ 229 19.6 Logical Device 7 (GPIO7, GPIO8) .............................................................................. 231 19.7 Logical Device 8 (WDT1) ............................................................................................ 235 19.8 Logical Device 9 (GPIO2, GPIO4, GPIO5, GPIO7, GPIO8)....................................... 237 19.9 Logical Device A (ACPI) ............................................................................................. 242 19.10 Logical Device B (Hardware Monitor, Front Panel LED) ............................................ 251 19.11 Logical Device D (WDT1) ........................................................................................... 257 19.12 Logical Device E (CIR WAKE-UP).............................................................................. 258 19.13 Logical Device F (GPIO Push-pull or Open-drain selection) ...................................... 259 19.14 Logical Device 16 (Deep Sleep) ................................................................................. 261 20. SPECIFICATIONS .................................................................................................................. 263 20.1 Absolute Maximum Ratings ........................................................................................ 263 20.2 DC CHARACTERISTICS............................................................................................ 263 21. AC CHARACTERISTICS ........................................................................................................ 266 21.1 Power On / Off Timing ................................................................................................ 266 21.2 AC Power Failure Resume Timing ............................................................................. 267 21.3 Clock Input Timing ...................................................................................................... 270 21.4 PECI Timing ................................................................................................................ 271 21.5 SMBus Timing............................................................................................................. 272 21.6 UART .......................................................................................................................... 273 21.7 Modem Control Timing ............................................................................................... 274 21.7.1 Writing Cycle Timing................................................................................................................ 275 -14- Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D 21.7.2 21.7.3 21.7.4 21.7.5 21.7.6 21.7.7 21.8 21.8.1 22. 23. 24. 25. Read Cycle Timing .................................................................................................................. 275 Send Data to K/B ..................................................................................................................... 275 Receive Data from K/B ............................................................................................................ 276 Input Clock............................................................................................................................... 276 Send Data to Mouse ................................................................................................................ 276 Receive Data from Mouse ....................................................................................................... 276 GPIO Timing Parameters ........................................................................................... 277 GPIO Write Timing .................................................................................................................. 277 TOP MARKING SPECIFICATIONS ........................................................................................ 278 ORDERING INFORMATION................................................................................................... 279 PACKAGE SPECIFICATION .................................................................................................. 280 REVISION HISTORY .............................................................................................................. 282 -15- Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D LIST OF FIGURES Figure 3-1 NCT5532D Block Diagram .............................................................................................. 5 Figure 4-1 NCT5532D Pin Layout ..................................................................................................... 6 Figure 6-1 RSMRST#...................................................................................................................... 17 Figure 6-2 PWROK ......................................................................................................................... 18 Figure 6-3 RSTOUTX# and LRESET#............................................................................................ 18 Figure 6-4 BKFD_CUT and LATCH_BKFD_CUT ........................................................................... 19 Figure 6-5 3VSBSW# ...................................................................................................................... 20 Figure 6-6 PSON# Block Diagram .................................................................................................. 21 Figure 6-7 PWROK Block Diagram ................................................................................................. 22 Figure 6-8 Illustration of Dual Color LED application ...................................................................... 23 Figure 6-9 Illustration of LED polarity .............................................................................................. 25 Figure 6-10 ASSC Application Diagram.......................................................................................... 28 Figure 7-1 Structure of the Configuration Register ......................................................................... 35 Figure 7-2 Configuration Register ................................................................................................... 37 Figure 8-1 LPC Bus’ Reads from / Write to Internal Registers ....................................................... 40 Figure 8-2 Serial Bus Write to Internal Address Register Followed by the Data Byte .................... 41 Figure 8-3 Serial Bus Read from Internal Address Register........................................................... 41 Figure 8-4 Analog Inputs and Application Circuit of the NCT5532D............................................... 42 Figure 8-5 Monitoring Temperature from Thermistor ...................................................................... 44 Figure 8-6 Monitoring Temperature from Thermal Diode (Voltage Mode)...................................... 45 Figure 8-7 Monitoring Temperature from Thermal Diode (Current Mode) ...................................... 45 Figure 8-8 PECI Temperature ......................................................................................................... 46 Figure 8-9 Temperature and Fan Speed Relation after Tbase Offsets .......................................... 47 TM Figure 8-10 SMART FAN Function Block Diagram ..................................................................... 50 TM Figure 8-11 Thermal Cruise Mode Parameters Figure ................................................................ 51 TM Figure 8-12 Mechanism of Thermal Cruise Mode (PWN Duty Cycle) ......................................... 51 TM Figure 8-13 Mechanism of Thermal Cruise Mode (DC Output Voltage) ..................................... 52 TM Figure 8-14 Mechanism of Fan Speed Cruise Mode ................................................................... 52 TM Figure 8-15 SMART FAN IV & Close Loop Fan Control Mechanism .......................................... 55 Figure 8-16 Fan Control Duty Mode Programming Flow ................................................................ 55 Figure 8-17 Close-Loop Fan Control RPM mode Programming Flow ............................................ 56 TM Figure 8-18 CPUFAN SMART FAN IV Table Parameters Figure ............................................... 57 Figure 8-19 Fanout Step Relation of CPUFANOUT ....................................................................... 57 Figure 8-20 SYS TEMP and Weight Value Relations ..................................................................... 58 Figure 8-21 Fan Control Weighting Duty Mode Programming Flow ............................................... 59 Figure 8-22 SMI Mode of Voltage and Fan Inputs .......................................................................... 60 Figure 8-23 Shut-down Interrupt Mode ........................................................................................... 61 Figure 8-24 SMI Mode..................................................................................................................... 61 Figure 8-25 SMI Mode of SYSTIN II ............................................................................................... 62 Figure 8-26 Shut-down Interrupt Mode ........................................................................................... 63 Figure 8-27 SMI Mode of CPUTIN .................................................................................................. 63 Figure 8-28 OVT# Modes of Temperature Inputs ........................................................................... 65 -XVI- Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D Figure 12-1 Keyboard and Mouse Interface.................................................................................. 162 Figure 14-1 Power Control Mechanism......................................................................................... 183 Figure 14-2 Power Sequence from S5 to S0, then Back to S5..................................................... 184 Figure 14-3 The previous state is “on” .......................................................................................... 185 Figure 14-4 The previous state is “off”. ......................................................................................... 185 Figure 14-5 Mechanism of Resume Reset Logic .......................................................................... 187 Figure 15-1 Start Frame Timing with Source Sampled A Low Pulse on IRQ1 ............................. 188 Figure 15-2 Stop Frame Timing with Host Using 17 SERIRQ Sampling Period........................... 190 Figure 18-1 Data Transfer Format ................................................................................................ 196 Figure 18-2 SMBus Arbitration ...................................................................................................... 197 Figure 18-3 Clock synchronization ................................................................................................ 197 Figure 18-4 SMBus Master Block Diagram................................................................................... 199 Figure 18-5 Programming Flow..................................................................................................... 200 Figure 18-6 TSI Routine ................................................................................................................ 201 Figure 18-7 PCH Routine .............................................................................................................. 201 Figure 18-8 PCH Routine .............................................................................................................. 202 Figure 18-9 Manual Mode Programming Flow.............................................................................. 203 -XVII- Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D LIST OF TABLES Table 6-1 Pin Description ................................................................................................................ 17 Table 7-1 Devices of I/O Base Address .......................................................................................... 36 Table 8-1 Temperature Data Format .............................................................................................. 44 Table 8-2 Relative Registers – at Thermal CruiseTM Mode........................................................... 53 Table 8-3 Relative Registers – at Speed CruiseTM Mode.............................................................. 53 TM Table 8-4 Relative Register-at SMART FAN IV Control Mode .................................................... 54 Table 8-5 Relative Register-at Weight Value Control ..................................................................... 58 Table 8-6 Relative Register of SMI functions.................................................................................. 64 Table 8-7 Relative Register of OVT functions................................................................................. 64 Table 10-1 Register Summary for UART ...................................................................................... 155 Table 12-1 Bit Map of Status Register .......................................................................................... 163 Table 12-2 KBC Command Sets ................................................................................................... 164 Table 12-1 CIR Register Table ..................................................................................................... 168 Table 14-1 Bit Map of Logical Device A, CR[E4h], Bits[6:5] ......................................................... 184 Table 14-2 Definitions of Mouse Wake-Up Events ....................................................................... 186 Table 14-3 Timing and Voltage Parameters of RSMRST# ........................................................... 187 Table 15-1 SERIRQ Sampling Periods ......................................................................................... 189 Table 17-1 Relative Control Registers of GPIO 41 that Support Wake-Up Function ................... 192 Table 17-2 GPIO Group Programming Table ............................................................................... 192 Table 17-3 GPIO Register Addresses........................................................................................... 195 Table 18-1 SB-TSI Address Encoding .......................................................................................... 198 Table 18-2 PCH Command Summary .......................................................................................... 198 Table 18-3 SMBus Master Bank 0 Registers ................................................................................ 204 -XVIII- Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 1. GENERAL DESCRIPTION The NCT5532D is a member of Nuvoton’s Super I/O product line. The NCT5532D monitors several critical parameters in PC hardware, including power supply voltages, fan speeds and temperatures. In terms of temperature monitoring, the NCT5532D adopts the Current Mode (dual current source) and thermistor sensor TM approach. The NCT5532D also supports the Smart Fan control system, including “SMART FAN I and SMART TM FAN IV, which makes the system more stable and user-friendly. The NCT5532D provides one high-speed serial communication port (UART), which includes a 16-byte send/receive FIFO, a programmable baud rate generator, complete modem-control capability and a processor interrupt system. The UART supports legacy speeds up to 115.2K bps as well as even higher baud rates of 230K, 460K, or 921K bps to support higher speed modems. The NCT5532D supports keyboard and mouse interface which is 8042-based keyboard controller. The NCT5532D provides flexible I/O control functions through a set of general purpose I/O (GPIO) ports. These GPIO ports may serve as simple I/O ports or may be individually configured to provide alternative functions. ® ® ® The NCT5532D supports the Intel PECI (Platform Environment Control Interface), AMD SB-TSI interface, AMD ® CPU power on sequence, and also partial Intel Deep Sleep Well glue logic to help customers to reduce the external circuits needed while using Deep Sleep Well function. The NCT5532D supports two-color LED control to indicate system power states, Consumer IR function for remote control purpose, and also Advanced Power Saving function to further reduce the power consumption. The configuration registers inside the NCT5532D support mode selection, function enable and disable, and power-down selection. Furthermore, the configurable PnP features are compatible with the plug-and-play feature in Windows, making the allocation of the system resources more efficient than ever. -1 Publication Release Date: September 30, 2011 Version: 0. 7 NCT5532D PRELIMINARY 2. FEATURES General Meet LPC Specification 1.1 SERIRQ (Serialized IRQ) Integrated hardware monitor functions Support DPM (Device Power Management), ACPI (Advanced Configuration and Power Interface) Programmable configuration settings Single 24-MHz or 48-MHz clock input Support selective pins of 5 V tolerance UART One high-speed, 16550-compatible UART with 16-byte send / receive FIFO Support RS485 --- Supports auto flow control Fully programmable serial-interface characteristics: --- 5, 6, 7 or 8-bit characters --- Even, odd or no parity bit generation / detection --- 1, 1.5 or 2 stop-bit generation Internal diagnostic capabilities: --- Loop-back controls for communications link fault isolation --- Break, parity, overrun, framing error simulation 16 Programmable baud rate generator allows division of clock source by any value from 1 to (2 -1) Maximum baud rate for clock source 14.769 MHz is up to 921K bps. The baud rate at 24 MHz is 1.5 M bps. Keyboard Controller 8042-based keyboard controller Asynchronous access to two data registers and one status register Software-compatible with 8042 Support PS/2 mouse Support Port 92 Support both interrupt and polling modes Fast Gate A20 and Hardware Keyboard Reset 12MHz operating frequency Hardware Monitor Functions Two remote temperature sensor inputs Programmable threshold temperature to speed fan fully while current temperature exceeds this threshold in TM the Thermal Cruise mode Support Current Mode (dual current source) temperature sensing method Up to eight voltage inputs (CPUVCORE, VIN2, VIN3, VIN4, 3VCC, AVCC, 3VSB and VBAT) Support Smart Fan I and Smart Fan IV Two fan-speed monitoring inputs -2 Publication Release Date: September 30, 2011 Version: 0. 7 NCT5532D PRELIMINARY Two fan-speed controls Programmable hysteresis and setting points for all monitored items Issue SMI# and OVT# (Over-temperature) to activate system protection via GPIO pins Nuvoton Health Manager support 2 Provide I C master / slave interface to read / write registers CIR and IR (Infrared) Support IrDA version 1.0 SIR protocol with maximum baud rate up to 115.2K bps Support SHARP ASK-IR protocol with maximum baud rate up to 57,600 bps Support Consumer IR, including CIRTX and CIRRX General Purpose I/O Ports Programmable general purpose I/O ports Two access channels, indirect (via 2E/2F or 4E/4F) and direct (Base Address) access. ACPI Configuration Support Glue Logic functions Support general purpose Watch Dog Timer functions via GPIO pins OnNow Functions Keyboard Wake-Up by programmable keys Mouse Wake-Up by programmable buttons OnNow Wake-Up from all of the ACPI sleeping states (S1-S5) PECI Interface Support PECI 1.1, 2.0 and 3.0 specification Support 2 CPU addresses and 2 domains per CPU address AMD SB-TSI Interface ® Support AMD SB-TSI specification SMBus Interface Support SMBus Slave interface to report Hardware Monitor device data Support SMBus Master interface to get thermal data from PCH Support SMBus Master interface to get thermal data from MXM module AMD® CPU Power on Srquence ® Support AMD CPU power on sequence -3 Publication Release Date: September 30, 2011 Version: 0. 7 NCT5532D PRELIMINARY Advanced Power Saving Advanced Sleep State Control to save motherboard Stand-by power consumption Operation voltage 3.3 voltage Package 64-pin LQFP Green -4 Publication Release Date: September 30, 2011 Version: 0. 7 NCT5532D PRELIMINARY 3. BLOCK DIAGRAM Figure 3-1 NCT5532D Block Diagram -5 Publication Release Date: September 30, 2011 Version: 0. 7 nuvo on NCT5532D PRELIMINARY 4. PIN LAYOUT z w ()I 0::: 0 I- :::> I LL a.. Ill 0 I I ::2: () I- >< I- >< 0::: w LL 0::: 0::: u I =1:1: Q; >< I- 0 wz (/)I 0::: I-I " '" a.. (f) a.. a..l Oo ...J...J C} (/)(f) U...J >> I- a.. =1:1: 1.{) I ...J (/) ...... CD 1.{) (") 0 N ""'" ""'" ""'" ""'" ""'" ""'" ""'" ""'" 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 C} ...... C} ...... (/) (/) a.. a.. I Ill > f-C'1 ::2: Ill > RSMRST# VLDT IVIN2 VDIMM IVIN3 AVCC3 CPUVCORE VREF VIN4 I AUXTINO CPUTIN CPUD-1 AGND GP26 ITSIC VTT PECI ITSID CPUFANIN CPUFANOUT SYSFANIN SYSFANOUT 0 S3 or S0->S5, we support two kinds of power off sequence. One is non_level detect: it means VCORE_EN will pull low as long as about 10~15ms after VLDT_EN pull low and PSON will pull high as long as about 10~15ms after VCORE_EN pull low. Two, level detect, means VCORE_EN will pull low depend on delay time and pre-power group VLDT_IN, and PSON will pull high depend on pre-power group (VDIMM_IN, ATXPGD), too. User can set CR27[1] to choose two condition and its default is “0” (level detect). -33 Publication Release Date: September 30, 2011 Version: 0. 7 NCT5532D PRELIMINARY Timing Parameters Parameter Description Min. T1 Period of VDIMM rises to 0.7V to VCORE_EN assertion T2 Typ. Max. Unit 10 15 ms Period of CPUVCORE rises to 0.7V to VLDT_EN assertion 10 15 ms T3 Period of VLDT_IN rises to 0.7V to AMD_PWROK assertion 10 15 ms T4 Period of SLP_S3# deassertion to AMD_PWROK deassertion 10 50 ms T5 Period of CPUPWRGD deassertion to VLDT_EN deassertion 10 15 ms T6 Period of VLDT_EN deassertion to VCORE_EN deassertion 10 15 ms T7 Period of VCORE_EN deassertion to PSON# deassertion 10 15 ms VDDA: 2.5V (not controlled by SIO) VDIMM: DDR 1.8V, DDR3 1.5V (not controlled by SIO) VLDT: 1.2V VCORE: 0.8V ~ 1.55V To support AMD power on sequence,we add some Pinout as VLDT_EN ,VCORE_EN,VLDT,VDIMM。The sequence is follow the figure above。CPU and NB must conform to the SPEC or else the SIO will suspend at the sequence。 -34 Publication Release Date: September 30, 2011 Version: 0. 7 NCT5532D PRELIMINARY 7. CONFIGURATION REGISTER ACCESS PROTOCOL The NCT5532D uses a special protocol to access configuration registers to set up different types of configurations. The NCT5532D has a total of 16 Logical Devices (from Logical Device 1 to Logical Device 16 with the exception of Logical Device 0, 1, 4, C, 10, 11, 12, 13, 14 & 15 for backward compatibility) corresponding to fourteen individual functions: UART A (Logical Device 2), IR (Logical Device 3), Keyboard Controller (Logical Device 5), CIR (Logical Device 6), GPIO7 & 8 (Logical Device 7), WDT1 (Logical Device 8), GPIO2, 4, 5, 7 & 8 (Logical Device 9), ACPI (Logical Device A), Hardware Monitor & Front Panel LED (Logical Device B), WDT1 (Logical Device D), CIRWAKEUP (Logical Device E), GPIO (Logical Device F), and Deep Sleep (Logical Device 16). It would require a large address space to access all of the logical device configuration registers if they were mapped into the normal PC address space. The NCT5532D, then, maps all the configuration registers through two I/O addresses (2Eh/2Fh or 4Eh/4Fh) set at power on by the strap pin 2E_4E_SEL. The two I/O addresses act as an index/data pair to read or write data to the Super I/O. One must write an index to the first I/O address which points to the register and read or write to the second address which acts as a data register. An extra level of security is added by only allowing data updates when the Super I/O is in a special mode, called the Extended Function Mode. This mode is entered by two successive writes of 87h data to the first I/O address. This special mode ensures no false data can corrupt the Super I/O configuration during a program runaway. There are a set of global registers located at index 0h – 2Fh, containing information and configuration for the entire chip. The method to access the control registers of the individual logical devices is straightforward. Simply write the desired logical device number into the global register 07h. Subsequent accesses with indexes of 30h or higher are directly to the logical device registers. Logical Device No. Logical Device Control One Per Logical Device Logical Device Configuration #0 #1 #2 #F Figure 7-1 Structure of the Configuration Register -35 Publication Release Date: September 30, 2011 Version: 0. 7 NCT5532D PRELIMINARY Table 7-1 Devices of I/O Base Address LOGICAL DEVICE NUMBER FUNCTION I/O BASE ADDRESS 0 Reserved 1 Reserved 2 UART A 100h ~ FF8h 3 IR 100h ~ FF8h 4 Reserved 5 Keyboard Controller 100h ~ FFFh 6 CIR 100h ~ FF8h 7 GPIO 7 & 8 Reserved 8 WDT1 Reserved 9 GPIO 2, 4, 5, 7 & 8 Reserved A ACPI Reserved B Hardware Monitor & Front Panel LED 100h ~ FFEh C Reserved D WDT1 Reserved E CIRWAKEUP 100h ~ FF8h F GPIO Reserved 10 Reserved 11 Reserved 12 Reserved 13 Reserved 14 Reserved 15 Reserved 16 Deep Sleep -36 Reserved Publication Release Date: September 30, 2011 Version: 0. 7 NCT5532D PRELIMINARY 7.1 Configuration Sequence Power-on Reset Any other I/O transition cycle Wait for key string I/O W rite to 2Eh N Is the data “ 87h"? Any other I/O transition cycle Check Pass Key I/O W rite to 2Eh N Is the data “ 87h" ? Extended Function Mode Figure 7-2 Configuration Register To program the NCT5532D configuration registers, the following configuration procedures must be followed in sequence: (1). Enter the Extended Function Mode. (2). Configure the configuration registers. (3). Exit the Extended Function Mode. 7.1.1 Enter the Extended Function Mode To place the chip into the Extended Function Mode, two successive writes of 0x87 must be applied to Extended Function Enable Registers (EFERs, i.e. 2Eh or 4Eh). 7.1.2 Configure the Configuration Registers The chip selects the Logical Device and activates the desired Logical Devices through Extended Function Index Register (EFIR) and Extended Function Data Register (EFDR). The EFIR is located at the same address as the EFER, and the EFDR is located at address (EFIR+1). First, write the Logical Device Number (i.e. 0x07) to the EFIR and then write the number of the desired Logical Device to the EFDR. If accessing the Chip (Global) Control Registers, this step is not required. -37 Publication Release Date: September 30, 2011 Version: 0. 7 NCT5532D PRELIMINARY Secondly, write the address of the desired configuration register within the Logical Device to the EFIR and then write (or read) the desired configuration register through the EFDR. 7.1.3 Exit the Extended Function Mode To exit the Extended Function Mode, writing 0xAA to the EFER is required. Once the chip exits the Extended Function Mode, it is in the normal running mode and is ready to enter the configuration mode. 7.1.4 Software Programming Example The following example is written in Intel 8086 assembly language. It assumes that the EFER is located at 2Eh, so the EFIR is located at 2Eh and the EFDR is located at 2Fh. If the HEFRAS (CR[26h] bit 6 showing the value of the strap pin at power on) is set, 2Eh can be directly replaced by 4Eh and 2Fh replaced by 4Fh. This example programs the configuration register F0h (clock source) of logical device 1 (UART A) to the value of 3Ch (24MHz). First, one must enter the Extended Function Mode, then setting the Logical Device Number (Index 07h) to 01h. Then program index F0h to 3Ch. Finally, exit the Extended Function Mode. ;----------------------------------------------------; Enter the Extended Function Mode ;----------------------------------------------------MOV DX, 2EH MOV AL, 87H OUT DX, AL OUT DX, AL ;----------------------------------------------------------------------------; Configure Logical Device 1, Configuration Register CRF0 ;----------------------------------------------------------------------------MOV DX, 2EH MOV AL, 07H OUT DX, AL ; point to Logical Device Number Reg. MOV DX, 2FH MOV AL, 01H OUT DX, AL ; select Logical Device 1 ; MOV DX, 2EH MOV AL, F0H OUT DX, AL ; select CRF0 MOV DX, 2FH MOV AL, 3CH OUT DX, AL ; update CRF0 with value 3CH ;----------------------------------------------; Exit the Extended Function Mode ;---------------------------------------------MOV DX, 2EH MOV AL, AAH OUT DX, AL -38 Publication Release Date: September 30, 2011 Version: 0. 7 NCT5532D PRELIMINARY 8. HARDWARE MONITOR 8.1 General Description The NCT5532D monitors several critical parameters in PC hardware, including power supply voltages, fan speeds, and temperatures, all of which are very important for a high-end computer system to work stably and properly. In addition, proprietary hardware reduces the amount of programming and processor intervention to control cooling fan speeds, minimizing ambient noise and maximizing system temperature and reliability. The NCT5532D can simultaneously monitor all of the following inputs: • 8 analog voltage inputs (5 internal voltages CPUVCORE, VBAT, 3VSB, 3VCC and AVCC; 3 external voltage inputs) • 2 fan tachometer inputs • 2 remote temperatures, using either a thermistor or from the CPU thermal diode (voltage or Current Mode measurement method) These inputs are converted to digital values using the integrated, eight-bit analog-to-digital converter (ADC). In response to these inputs, the NCT5532D can generate the following outputs: • 2 PWM (pulse width modulation) and one DC fan outputs for the fan speed control • SMI# via GPIO • OVT# signals for system protection events via GPIO 2 The NCT5532D provides hardware access to all monitored parameters through the LPC or I C interface and TM software access through application software, such as Nuvoton’s Hardware Doctor , or BIOS. The rest of this section introduces the various features of the NCT5532D hardware-monitor capability. These features are divided into the following sections: 8.2 • • • • • • • Access Interfaces Analog Inputs Fan Speed Measurement and Control Smart Fan Control SMI# interrupt mode OVT# interrupt mode Registers and Value RAM Access Interfaces 2 The NCT5532D provides two interfaces, LPC and I C, for the microprocessor to read or write the internal registers of the hardware monitor. 8.3 LPC Interface The internal registers of the hardware monitor block are accessible through two separate methods on the LPC bus. The first set of registers, which primarily enable the block and set its address in the CPU I/O address space are accessed by the Super I/O protocol described in Chapter 7 at address 2Eh/2Fh or 4Eh/4Fh. The bulk of the functionality and internal registers of this block are accessed form an index/data pair of CPU I/O addresses. The standard locations are usually 295h/296h and are set by CR[60h]&CR[61h] accessed using the Super I/O protocol as described in Chapter 7. -39 Publication Release Date: September 30, 2011 Version: 0. 7 NCT5532D PRELIMINARY Due to the number of internal register, it is necessary to separate the register sets into “banks” specified by register 4Eh. The structure of the internal registers is shown in the following figure. Monitor Value Registers BK4 80h~8Eh Configuration Register 40h LPC Bus Interrupt Status Registers 41h, 42h SMI# Mask Registers 43h, 44h, 46h Port 5h Index Register Serial Bus Address 48h SMI#/OVT# Control Register 4Ch Fan IN /OUT Control Register 4Dh Bank Select Register 4Eh Nuvoton Vendor ID Port 6h 4Fh Data Register Chip ID Register 58h Figure 8-1 LPC Bus’ Reads from / Write to Internal Registers -40 Publication Release Date: September 30, 2011 Version: 0. 7 NCT5532D PRELIMINARY 8.4 I2C interface 2 The I C interface is a second, serial port into the internal registers of the hardware monitor function block. The 2 interface is totally compatible with the industry-standard I C specification, allowing external components that are also compatible to read the internal registers of the NCT5532D hardware monitor and control fan speeds. The 2 address of the I C peripheral is set by the register located at index 48h (which is accessed by the index/data pair at I/O address typically at 295h/296h) 2 The two timing diagrams below illustrate how to use the I C interface to write to an internal register and how to read the value in an internal register, respectively. (a) Serial bus write to internal address register followed by the data byte 0 7 8 0 8 7 SCL SDA 0 1 Start By Master 0 1 1 0 1 R/W D7 D6 Ack by 627DHG Frame 1 Serial Bus Address Byte D5 D4 D3 D2 D1 D0 Ack by 627DHG Frame 2 Internal Index Register Byte 0 7 8 SCL (Continued) SDA (Continued) D7 D6 D5 D4 D3 D2 D1 D0 Ack by 627DHG Stop by Master Frame 3 Data Byte Figure 8-2 Serial Bus Write to Internal Address Register Followed by the Data Byte (b) Serial bus read from a register 0 7 8 0 7 8 SCL SDA 0 1 0 Start By Master 1 1 0 1 R/W D7 Ack by 627DHG Frame 1 Serial Bus Address Byte D6 D5 D4 D3 D2 D1 D0 Ack by 627DHG Frame 2 Internal Index Register Byte 0 0 0 Repeat start by Master 7 1 0 1 1 0 1 8 R/W D7 Ack by 627DHG Frame 3 Serial Bus Address Byte 0 7 D6 D5 D4 D3 D2 D1 8 D0 Ack by Master Frame 4 Data Byte Stop by Master 0 Figure 8-3 Serial Bus Read from Internal Address Register -41 Publication Release Date: September 30, 2011 Version: 0. 7 NCT5532D PRELIMINARY 8.5 Analog Inputs The 8 analog inputs of the hardware monitor block connect to an 8-bit Analog to Digital Converter (ADC) and consist of 4 general-purpose inputs connected to external device pins and 4 internal signals connected to the power supplies (AVCC, VBAT, 3VSB and 3VCC). All inputs are limited to a maximum voltage of 2.048V due to an internal setting of 8mV LSB (256 steps x 8mV = 2.048V). All inputs to the ADC must limit the maximum voltage by using a voltage divider. The power supplies have internal resistors, while the external pins require outside limiting resistors as described below. The figure shown below is an illustration. Pin 108 AVCC Power inputs Pin 99 VBAT Pin 85 3VSB Pin 1 3VCC Pin 109 CPUVCORE R1 VIN0 Pin 104 V0 R2 Positive Voltage Input Pin 106 VIN2 Pin 107 VIN3 R3 VIN1 8-bit ADC with 8mV LSB Pin 105 V1 Negative Voltage Input R4 R THM 10K@25℃, beta=3435K R 10K, 1% Pin 110 VREF R 15K, 1% Pin 111 AUXTIN0 CPUTIN Pin 112 Pin 113 Pin 114 Pin 115 Pin 116 SYSTIN AUXTIN1 AUXTIN2 AUXTIN3 CPUD+ CPUD(AGND) CAP,2200p CPUD- (AGND) Pin 117 Figure 8-4 Analog Inputs and Application Circuit of the NCT5532D As illustrated in the figure above, other connections may require some external circuits. The rest of this section provides more information about voltages outside the range of the 8-bit ADC, CPU Vcore voltage detection, and temperature sensing. -42 Publication Release Date: September 30, 2011 Version: 0. 7 NCT5532D PRELIMINARY 8.5.1 Voltages Over 2.048 V or Less Than 0 V Input voltages greater than 2.048 V should be reduced by an external resistor divider to keep the input voltages in the proper range. For example, input voltage V0 (+12 V) should be reduced before it is connected to VIN0 according to the following equation: VIN 0 = V 0 × R2 R1 + R2 R1 and R2 can be set to 56 KΩ and 10 KΩ, respectively, to reduce V0 from +12 V to less than 2.048 V. All the internal inputs of the ADC, AVCC, VBAT, 3VSB and 3VCC utilize an integrated voltage divider with both resistors equal to 34KΩ, yielding a voltage one half of the power supply. Since one would expect a worst-case 10% variation or a 3.63V maximum voltage, the input to the ADC will be 1.815V, well within the maximum range. Vin = VCC × 34KΩ ≅ 1.65V , where VCC is set to 3.3V 34KΩ + 34KΩ The CPUVCORE pin feeds directly into the ADC with no voltage divider since the nominal voltage on this pin is only 1.2V. Negative voltages are handled similarly, though the equation looks a little more complicated. For example, negative voltage V1 (-12V) can be reduced according to the following equation: VIN1 = (V 1 − 2.048) × R4 + 2.048, whereV1 = −12 R3 + R 4 R3 and R4 can be set to 232 KΩ and 10 KΩ, respectively, to reduce negative input voltage V1 from –12 V to less than 2.048 V. Note that R4 is referenced to VREF, or 2.048V instead of 0V to allow for more dynamic range. This is simply good analog practice to yield the most precise measurements. Both of these solutions are illustrated in the figure above. 8.5.2 Voltage Data Format The data format for voltage detection is an eight-bit value, and each unit represents an interval of 8 mV. Detected Voltage = Reading * 0.008 V If the source voltage was reduced by a voltage divider, the detected voltage value must be scaled accordingly. 8.5.2.1. Voltage Reading NCT5532D has 9 voltage reading: Voltage reading Voltage reading 8.5.3 CPUVCORE AVCC 3VCC VIN2 VIN3 Bank4, Index80 Bank4, Index82 Bank4, Index83 Bank4, Index8C Bank4, Index8D 3VSB VBAT VTT VIN4 Bank4, Index87 Bank4, Index88 Bank4, Index89 Bank4, Index86 Temperature Data Format The data format for sensors CPUTIN and AUXTIN0 is 9-bit, two’s-complement. This is illustrated in the table below. There are two sources of temperature data: external thermistors or thermal diodes. -43 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Table 8-1 Temperature Data Format 8-BIT DIGITAL OUTPUT TEMPERATURE 8-BIT BINARY 8-BIT HEX 9-BIT DIGITAL OUTPUT 9-BIT BINARY 9-BIT HEX +125°C 0111,1101 7Dh 0,1111,1010 0FAh +25°C 0001,1001 19h 0,0011,0010 032h +1°C 0000,0001 01h 0,0000,0010 002h +0.5°C - - 0,0000,0001 001h +0°C 0000,0000 00h 0,0000,0000 000h -0.5°C - - 1,1111,1111 1FFh -1°C 1111,1111 FFh 1,1111,1110 1FFh -25°C 1110,0111 E7h 1,1100,1110 1Ceh -55°C 1100,1001 C9h 1,1001,0010 192h 8.5.3.1. Monitor Temperature from Thermistor External haveisa connected β value of in3435K of 10 and KΩ at 25°C. As illustrated the schematicthermistors above, theshould thermistor seriesand witha aresistance 10-KΩ resistor then connects to VREF.in The configuration registers to select a thermistor temperature sensor and the measurement method are found at Bank 0, index 59h, 5Dh, and 5Eh. Figure 8-5 Monitoring Temperature from Thermistor 8.5.3.2. Monitor Temperature from Thermal Diode (Voltage Mode) The thermal diode D- pin is connected to AGND, and the D+ pin is connected to the temperature sensor pin in the NCT5532D. A 15-KΩ resistor is connected to VREF to supply the bias current for the diode, and the 2200-pF, bypass capacitor is added to filter high-frequency noise. The configuration registers to select a thermal diode temperature sensor and the measurement method are found at Bank 0, index 5Dh, and 5Eh. -44 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Figure 8-6 Monitoring Temperature from Thermal Diode (Voltage Mode) 8.5.3.3. Monitor Temperature from Thermal Diode (Current Mode) The NCT5532D can also sense the diode temperature through Current Mode and the circuit is shown in the following figure. Figure 8-7 Monitoring Temperature from Thermal Diode (Current Mode) The pin of processor D- is connected to CPUD- and the pin D+ is connected to temperature sensor pin in the NCT5532D. A bypass capacitor C=2200pF should be added to filter the high frequency noise. The configuration registers to select a thermal diode temperature sensor and the measurement method are found at Bank 0, index 5Dh and 5Eh. 8.5.3.4. Temperature Reading NCT5532D has 6 temperature reading can monitor different temperature sources (ex. CPUTIN, AUXTIN, PECI…etc). SMIOVT1 SMIOVT2 Temperature source select Bank6,index21 bit[4:0] default: SYSTIN Bank6, index22 bit[4:0] default:CPUTIN Temperature reading Bank0, index27 Bank1, index50 & index51 bit7 -45 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Note. If the temperature source is selecting to PECI, please set Bank0 Index AEh first for reading correct value. 8.6 PECI PECI (Platform Environment Control Interface) is a new digital interface to read the CPU temperature of Intel® CPUs. With a bandwidth ranging from 2 Kbps to 2 Mbps, PECI uses a single wire for self-clocking and data ® transfer. By interfacing to the Digital Thermal Sensor (DTS) in the Intel CPU, PECI reports a negative temperature (in counts) relative to the processor’s temperature at which the thermal control circuit (TCC) is activated. At the TCC Activation temperature, the Intel CPU will operate at reduced performance to prevent the device from thermal damage. PECI is one of the temperature sensing methods that the NCT5532D supports. The NCT5532D contains a PECI master and reads the CPU PECI temperature. The CPU is a PECI client. The PECI temperature values returning from the CPU are in “counts” which are approximately linear in relation to changes in temperature in degrees centigrade. However, this linearity is approximate and cannot be guaranteed over the entire range of PECI temperatures. For further information, refer to the PECI specification. All references to “temperature” in this section are in “counts” instead of “°C”. Figure 8-8 PECI Temperature shows a typical fan speed (PWM duty cycle) and PECI temperature relationship. Fan Speed (PWM Duty Cycle) Tcontrol TCC Activation Duty1 Duty2 -20 -10 0 PECI Temperature (counts) Figure 8-8 PECI Temperature In this illustration, when PECI temperature is -20, the PWM duty cycle for fan control is at Duty2. When CPU is getting hotter and the PECI temperature is -10, the PWM duty cycle is at Duty1. At Tcontrol PECI temperature, the recommendation from Intel is to operate the CPU fan at full speed. Therefore Duty1 is 100% if this recommendation is followed. The value of Tcontrol can be obtained by reading the related Machine Specific Register (MSR) in the Intel CPU. The Tcontrol MSR address is usually in the BIOS Writer’s guide for the CPU family in question. Refer to the relevant CPU documentation from Intel for more information. In this example, Tcontrol is -10. When the PECI temperature is below -20, the duty cycle is fixed at Duty2 to maintain a minimum (and constant) RPM for the CPU fan. -46 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY The device also provides an offset register to ‘shift’ the negative PECI readings to positive values. The offset registers are called “Tbase”, which are located at Bank7 Index 09h for Agent0 and Bank7 Index 0Ah for Agent1. All default values of these Tbase registers are 8’h00. The unit of the Tbase register contents is “count” to match that of PECI values. The resultant value (Tbase + PECI) should not be interpreted as the “temperature” (whether in count or °C) of the PECI client (CPU). The Figure 8-9 Temperature and Fan Speed Relation after Tbase Offsets, shows the temperature and fan-speed relationship after Tbase offset is applied (based on Figure 8-8 PECI Temperature). This view is from the perspective of the NCT5532D fan control circuit. Fan Speed (PWM Duty Cycle) Tbase = 100 Tcontrol TCC Activation Duty1 85 = (-15 + 100) (PECI = -15) Duty2 80 = (-20 + 100) (PECI = -20) 90 = (-10 + 100) (PECI = -10) (PECI = 0) Temperature (as seen by the W83677HG-I fan control circuit) Figure 8-9 Temperature and Fan Speed Relation after Tbase Offsets Assuming Tbase is set to 100 and the PECI temperature is -15 , the real-time temperature value to the fan control circuit will be 85 (-15 + 100). The value of 55 (hex) will appear in the relevant real-time temperature register. While using Smart Fan control function of NCT5532D, BIOS/software can include Tbase in determining the (1) thresholds (limits). In this example, assuming Tcontrol is -10 and Tbase is set to 100 , the threshold temperature value corresponding to the “100% fan duty-cycle” event is 90 (-10+100). The value of 5A (hex) should be written to the relevant threshold register. Tcontrol is typically -10 to -20 for PECI-enabled CPUs. Base on that, a value of 85 ~100 for Tbase could be set for proper operation of the fan control circuit. This recommendation is applicable for most designs. In general, the concept presented in this section could be used to determine the optimum value of Tcontrol to match the specific application. -47 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 8.7 Fan Speed Measurement and Control This section is divided into two parts, one to measure the speed and one to control the speed. 8.7.1 Fan Speed Reading The fan speed reading at: FAN COUNT READING 13-bit [12:5] SYSFANIN CPUFANIN 8.7.2 FAN RPM READING 16-bit [4:0] Bank4, indexB0 Bank4, indexB2 [15:8] Bank4, indexB1 Bank4, indexB3 Bank4, indexC0 Bank4, indexC2 [7:0] Bank4, indexC1 Bank4, indexC3 Fan Speed Calculation by Fan Count Reading In 13-bit fan count reading, please read high byte first then low byte. Fan speed RPM can be evaluated by the following equation. 8.7.3 RPM = 1.35 × 10 6 Count Fan Speed Calculation by Fan RPM Reading In 16-bit fan RPM reading, please read high byte first then low byte. Fan speed RPM can be evaluated by translating 16-bit RPM reading from hexadecimal to decimal. Register reading 0x09C4h = 2500 RPM 8.7.4 Fan Speed Control The NCT5532D has 2 output pins for fan control, Only SYSFANOUT offers PWM duty cycle and DC voltage to control the fan speed. The output type (PWM or DC) of each pin is configured by Bank0 index 04h, bits 0 for SYSFANOUT. Output Type Select SYSFANOUT Bank0, index04 bit0 CPUFANOUT Only PWM output Output Type Select (in PWM output) PWM Output Freqency Fan Control Mode Select 0: PWM output 1: DC output (default) CR24 bit4 CR24 bit3 0: open-drain (default) 1: push-pull Bank0, Index00 Bank1, index02, bit[7:4] 0: open-drain (default) 1: push-pull Bank0, Index02 Bank2, index02, bit[7:4] 0h: Manual mode (def.) 1h: Thermal Cruise 0h: Manual mode(def.) 1h: Thermal Cruise -48 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Output Value (write) PWM output (Duty) DC output (Voltage) Current Output Value (read only) 2h: Speed Cruise 4h: SMART FAN IV Bank1, index09 bit[7:0] 2h: Speed Cruise 4h: SMART FAN IV Bank2, index09 bit[7:0] Bank1, index09 bit[7:2] Bank0, index01 Bank0, index03 For PWM, the duty cycle is programmed by eight-bit registers at Bank1 Index 09h for SYSFANOUT, Bank2 Index 09h for CPUFANOUT. The duty cycle can be calculated using the following equation: Dutycycle(%) = Programmed 8 - bit Register Value × 100% 255 The default duty cycle is 7Fh, or 50% for SYSFANOUT and CPUFANOUT. Note.The default speed of fan output is specified in registers CR[E0h] and CR[E1h] of Logical Device B. The PWM clock frequency is programmed at Bank0 Index 00h, Index 02h. For DC, the NCT5532D has a six bit digital-to-analog converter (DAC) that produces 0 to 2.048 Volts DC. The analog output is programmed at Bank1 Index 09h bit [7:2] for SYSFANOUT. The analog output can be calculated using the following equation: OUTPUT Voltage (V) = Vref × Programmed 6 - bit Register Value ` 64 The default value is 111111YY, or nearly 2.048 V, and Y is a reserved bit. 8.7.5 SMART FANTM Control The NCT5532D supports various different fan control features: TM Š SMART FAN I (Thermal Cruise & Speed Cruise) TM Š SMART FAN IV TM Š SMART FAN IV Close-Loop Fan Control RPM mode SYSFANOUT Fan Control Mode Select CPUFANOUT Bank1, index02, bit[7:4] Bank2, index02, bit[7:4] 0h: Manual mode (def.) 1h: Thermal Cruise 2h: Speed Cruise 4h: SMART FAN IV 0h: Manual mode(def.) 1h: Thermal Cruise 2h: Speed Cruise 4h: SMART FAN IV -49 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 8.7.6 Temperature Source & Reading for Fan Control Select temperature source for each fan control output: SYSFANOUT Fan Control Temperature Source Select Fan Control Temperature Reading CPUFANOUT Bank1, index00 bit[4:0] Bank2, index00 bit[4:0] Default: SYSTIN Bank0, index73 & Bank0, index74 bit7 Default: CPUTIN Bank0, index75 & Bank0, index76 bit7 Note. If the temperature source is selecting to PECI, please set Bank0 Index AEh first for reading correct value. Smart Fan4+ Block Slope Slope calculation calculation (12 + 8 bit) Up Curve / Down Curve decision Rise / Down _ SF 4 Y_ Axis Setting RPM to FanCount Generate RiseFan / DownFan indicator FanOut1 SYSFANOUT FanOut21 CPUFANOUT FanOut13 AUXFANOUT0 FanOut14 AUXFANOUT1 FanOut15 AUXFANOUT2 Control Logic Rise/ Down Fan Distributor Rise/ Down_ TCC ThermalCruise control X_ Axis Setting Rise/ Down _ SCC SpeedCruise control TM Figure 8-10 SMART FAN Function Block Diagram SMART FANTM I 8.8 8.8.1 Thermal Cruise Mode Thermal Cruise mode controls the fan speed to keep the temperature in a specified range. First, this range is defined in BIOS a temperature and the 55is°C 3 °C).the Astemperature long as theexceeds current the temperature remains below thebylow end of this range (i.e.,interval 52 °C),(e.g., the fan off.± Once low end, the fan turns on at a speed defined in BIOS (e.g., 20% output). Thermal Cruise mode then controls the fan output according to the current temperature. Three conditions may occur: (1) If the temperature still exceeds the high end, fan output increases slowly. If the fan is operating at full speed but the temperature still exceeds the high end, a warning message is issued to protect the system. (2) If the temperature falls below the high end (e.g., 58°C) but remains above the low end (e.g., 52 °C), fan output remains the same. -50 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY (3) If the temperature falls below the low end (e.g., 52 °C), fan output decreases slowly to zero or to a specified “stop value”. This “stop value” is enabled by the Bank1, Index00h, Bit7 for SYSFANOUT; Bank2, Index00h, Bit7 for CPUFANOUT. The “stop value” itself is separately specified in Bank1 Index05h, Bank2 Index05h. The “stop time” means fan remains at the stop value for the period of time also separately defined in Bank1 Index07h, Bank2 Index07h. Note. The function only support for Thermal Cruise Mode. Fan Duty Cycle Step Down Time Step Up Time 1LSB 1LSB Stop Value Start Up Value Stop Time Fan Turn off state Lowering speed zone Arising speed zone Figure 8-11 Thermal Cruise TM Mode Parameters Figure In general, Thermal Cruise mode means • If the current temperature is higher than the high end, increase the fan speed. • If the current temperature is lower than the low end, decrease the fan speed. • Otherwise, keep the fan speed the same. The following figures illustrate two examples of Thermal Cruise mode. A Tolerance Target Temperature Tolerance B C D 58°C 55°C 52°C PW M Duty Cycle (%) 100 Fan Start = 20% Fan Stop = 10% Fan Start = 20% 50 0 Stop Time TM Figure 8-12 Mechanism of Thermal Cruise -51 Mode (PWN Duty Cycle) Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY A B C D 58°C Tolerance 55°C Target Temperature Tolerance 52°C (V) DC 3.3 Fan Start = 0.62V Fan Stop = 0.31V Fan Start = 0.62V Output Voltage 1.65 0 Stop Time TM Figure 8-13 Mechanism of Thermal Cruise 8.8.2 Mode (DC Output Voltage) Speed Cruise Mode Speed Cruise mode keeps the fan speed in a specified range. First, this range is defined in BIOS by a fan speed count (the amount of time between clock input signals, not the number of clock input signals in a period of time) and an interval (e.g., 160 ± 10). As long as the fan speed count is in the specified range, fan output remains the same. If the fan speed count is higher than the high end (e.g., 170), fan output increases to make the count lower. If the fan speed count is lower than the low end (e.g., 150), fan output decreases to make the count higher. One example is illustrated in this figure. A Count 170 C 160 150 Fan output (%) 100 50 0 Figure 8-14 Mechanism of Fan Speed Cruise TM Mode The following tables show current temperatures, fan output values and the relative control registers at Thermal Cruise and Fan Speed mode. -52 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Table 8-2 Relative Registers – at Thermal CruiseTM Mode THERMAL CRUISE MODE TARGET TEMPERAT URE TOLERANC E SYSFANOUT Bank 1, index 01h bit[7:0] Bank 1, index 02h Bit[2:0] Bank 1, index 06h Bank 1, index 05h CPUFANOUT Bank 2, index 01h bit[7:0] Bank 2, index 02h Bit[2:0] Bank 2, index 06h Bank 2, index 05h THERMAL CRUISE MODE CRITICAL TEMPERATURE SYSFANOUT Bank 1, index 35h Bank 1, Index 02h, bit[7:4] = 01h CPUFANOUT Bank 2, Index 35h Bank 2, Index 02h, bit[7:4] = 01h START-UP VALUE STOP VALUE KEEP MIN. FAN OUTPUT VALUE STOP TIME STEP- UP TIME STEPDOWN TIME Bank 1, Index 00h, bit7 Bank 1, index 07h Bank 1, index 03h Bank 1, index 04h Bank 2, Index 00h, bit7 Bank 2, index 07h Bank 2, index 03h Bank 2, index 04h STEP- UP TIME STEPDOWN TIME ENABLE SPEED CRUISE MODE ENABLE THERMAL CRUISE MODE Table 8-3 Relative Registers – at Speed CruiseTM Mode SPEED CRUISE MODE TARGETSPEED COUNT_L TARGETSPEED COUNT_H TOLERANCE_L TOLERANCE2_H SYSFANOUT Bank 1, Index 01h Bank 1, Index 0C bit[3:0] Bank 1, Index 02 bit[2:0] Bank 1, Index 0C bit[6:4] Bank 1, Index 03h Bank 1, Index 04h Bank 1, Index 02h bit[7:4] = 02h CPUFANOUT Bank 2, Index 01h Bank 2, Index 0C bit[3:0] Bank 2, Index 02 bit[2:0] Bank 2, Index 0C bit[6:4] Bank 2, Index 03h Bank 2, Index 04h Bank 2, Index 02h bit[7:4] = 02h 8.9 SMART FANTM IV & Close Loop Fan Control Mode TM SMART FAN IV and Close Loop Fan Control Mode offer 3 slopes to control the fan speed. Set Critical Temperature, Bank1 Index 35HEX , Bank2 Index 35HEX. • Set the Relative Register-at SMART FANTM IV Control Mode Table If fan control mode is set as Close Loop Fan Control, the unit step is 50RPM. So the maximum controllable RPM is 50*255=12,750RPM. • Set Tolerance of Target Temperature, Bank1 Index 02HEX bit [2:0], Bank2 Index 02HEX bit [2:0]. The 3 slopes can be obtained by setting FanDuty1/RPM1~FanDuty4/RPM4 and T1~T4 through the registers. When the temperature rises, FAN Output will calculate the target FanDuty/RPM based on the current slope. For example, assuming Tx is the current temperature and Ty is the target, then The slope: X2 = (FanDuty3 / RPM 3) − (FanDuty2 / RPM 2 ) (T 3 − T 2) -53 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY TM Table 8-4 Relative Register-at SMART FAN DESCRIPTION IV Control Mode T1 T2 T3 T4 SYSFANOUT Bank 1, Index 21h Bank 1, Index 22h Bank 1, Index 23h Bank 1, Index 24h CPUFANOUT Bank 2, Index 21h Bank 2, Index 22h Bank 2, Index 23h Bank 2, Index 24h DESCRIPTION FD1/PWM1 FD2/PWM2 FD3/PWM3 FD4/PWM4 SYSFANOUT Bank 1, Index 27h Bank 1, Index 28h Bank 1, Index 29h Bank 1, Index 2Ah CPUFANOUT Bank 2, Index 27h Bank 2, Index 28h Bank 2, Index 29h Bank 2, Index 2Ah DESCRIPTION CRITICAL TEMPERAT URE CRITICAL TOLERANCE TEMPERATURE TOLERANCE ENABLE RPM MODE RPM TOLERANCE ENABLE RPM HIGH MODE SYSFANOUT Bank 1, Index 35h Bank 1, Index 38h, bit[2:0] Bank 1, Index 02h, bit[2:0] Bank 6, Index 00h, Bit0 Bank 6, index 01h Bank 6, Index 06h, Bit0 CPUFANOUT Bank 2, Index 35h Bank 2, Index 38h, bit[2:0] Bank 2, Index 02h, bit[2:0] Bank 6, Index 00h, Bit1 Bank 6, index 02h Bank 6, Index 06h, Bit1 -54 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY TM Figure 8-15 SMART FAN IV & Close Loop Fan Control Mechanism FAN CONTROL Load Default Speed Step Up Time Index 03 Temperature Source Select Index 00 [4:0] Step Down Time Index 04 SF4 Table Index 21~ 24 Index 27 ~ 2A Fanout Step Index 20 [0] Critical Temperature Index 35 MODE Index 02 [7:4] Tolerance Index 02 [2:0] Critical Temperature Tolerance Index 38 [2:0] Fan Control Duty Mode Figure 8-16 Fan Control Duty Mode Programming Flow -55 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY FAN CONTROL Load Default Speed Step Up Time Index 03 Temperature Source Select Index 00 [4:0] Step Down Time Index 04 SF4 Table Index 21~ 24 Index 27 ~ 2A RPM Enable Bank6 Index 00 [4:0] Tolerance Index 01~05 [3:0] Critical Temperature Index 35 SF4 MODE Index 02 [7:4] Tolerance Index 02 [2:0] Critical Temperature Tolerance Index 38 [2:0] Close-Loop Fan Control RPM Mode Figure 8-17 Close-Loop Fan Control RPM mode Programming Flow 8.9.1 Step Up Time / Step Down Time TM SMART FAN IV is designed for the smooth operation of the fan. The Up Time / Down Time register defines the time interval between successive duty increases or decreases. If this value is set too small, the fan will not have enough time to speed up after tuning the duty and sometimes may result in unstable fan speed. On the other hand, if Up Time / Down Time is set too large, the fan may not work fast enough to dissipate the heat. 8.9.2 Fan Output Step The “Fanout Step” itself is separately specified in Bank1 Index20h bit0 for SYSFANOUT, Bank2 Index20h bit0 for CPUFANOUT. This example for Fanout Step exposition: -56 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY TM Figure 8-18 CPUFAN SMART FAN IV Table Parameters Figure Figure 8-19 Fanout Step Relation of CPUFANOUT 8.9.3 Revolution Pulse Selection The NCT5532D supports four RPM output of the pulses selection function for different type of FAN which has the character of different pulses per revolution.The others could be set by HM register at Bank6, Index44, Bit1-0 for SYSFANIN; Index45, Bit1-0 for CPUFANIN. All default value of pulse selection registers are 2 pulses of one revolution. Setting description for “Pulse Selections Bits”: 00: 4 pulses per revolution 01: 1 pulse per revolution 10: 2 pulses per revolution (default) 11: 3 pulses per revolution 8.9.4 Weight Value Control The NCT5532D supports weight value control for fan duty output. By register configuration, the results of weight TM value circuit can be added to the fan duty of SMART FAN I or IV and output to the fan. Take CPUFANOUT for TM example, if SMART FAN IV is selected, CPUTIN is the temperature source, and weight value control is enabled, TM SMART FAN IV will calculate the output duty, and weight value circuit will calculate the corresponding weight value based on SYSTIN. As the SYSTIN temperature rises, its corresponding weight value increases. Then, the two values will be summed up and output to CPU fan. In other words, the CPU fan duty is affected not only by the CPUTIN but also the SYSTIN temperature. Figure 8-20 SYS TEMP and Weight Value Relations shows the relation between the SYSTIN temperature and the weight value. Tolerance setup is offered on each change point to avoid weight value fluctuation resulted from -57 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY SYSTIN temperature change. The weight value will increase by one weight value step only when the SYSTIN temperature is higher than the point value plus tolerance. Likewise, the weight value decreases by one weight value step only when the SYSTIN temperature is lower than the point value minus tolerance. Nots:This relative register should not be zero and not support negative temperature. Figure 8-20 SYS TEMP and Weight Value Relations Table 8-5 Relative Register-at Weight Value Control DESCRIPTION ENABLE WEIGHT MODE WEIGHT TEMPERATURE SOURCE SELECT SYSFANOUT Bank 1, Index 39h, bit7 Bank 1, Index 39h, bit[4:0] CPUFANOUT Bank 2, Index 39h, bit7 Bank 2, Index 39h, bit[4:0] DESCRIPTION TEMP BASE DUTY BASE TEMP STEP TEMP STEP TOLERANCE WEIGHT STEP SYSFANOUT Bank 1, Index 3Dh Bank 1, Index 3Eh Bank 1, Index 3Ah Bank 1, Index 3Bh Bank 1, Index 3Ch CPUFANOUT Bank 2, Index 3Dh Bank 2, Index 3Eh Bank 2, Index 3Ah Bank 2, Index 3Bh Bank 2, Index 3Ch -58 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Step Up Time Index 03 FAN CONTROL Load Default Speed Step Down Time Index 04 Weighting Configuration Register Temperature Source Select Index 00 [4:0] SF4 Table Index 21~ 24 Index 27 ~ 2A Critical Temperature Index 35 Fanout Step Index 20 [0] Temperature Step Index 3A MODE Index 02 [7:4] Tolerance Index 02 [2:0] Temperature Step Tolerance Index 3B Weight Step Index 3C Enable Weighting and Temperature Source Select Index 39 Temperature Base Index 3D Temperature Fan Duty Base Index 3E Critical Temperature Tolerance Index 38 [2:0] Fan Control Weighting Duty Mode Figure 8-21 Fan Control Weighting Duty Mode Programming Flow 8.10 Alert and Interrupt NCT5532D supports 6 Temperature Sensors for interrupt detection depending on selective monitor temperature source. Temperature source select Temperature reading (2’s SMIOVT1 SMIOVT2 Bank6, index21 bit[4:0] Bank6, index22 bit[4:0] default: SYSTIN default: CPUTIN Bank0, index27 Bank1, index50 -59 & Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY complement) index51 bit7 Temperature High Limit Bank0, index39 Bank1, index55 & index56 bit7 Temperature Low Limit Bank0, index3A Bank1, index53 & index54 bit7 SMIOVT Relative Temperature Registers 8.10.1 SMI# Interrupt Mode The SMI#/OVT# pin is a multi-function pin. It can be in HM_SMI# mode or in OVT# mode by setting Configuration Register CR24h, bit 2. In HM_SMI# mode, it can monitor voltages, fan counts, or temperatures. 8.10.2 Voltage SMI# Mode The SMI# pin can create an interrupt if a voltage exceeds a specified high limit or falls below a specified low limit. This interrupt must be reset by reading all the interrupt status registers, or subsequent events do not generate interrupts. This mode is illustrated in the following figure. High limit Fan Count limit Low limit * * * * SMI# * * *Interrupt Reset when Interrupt Status Registers are read Figure 8-22 SMI Mode of Voltage and Fan Inputs 8.10.3 Fan SMI# Mode The SMI# pin can create an interrupt if a fan count crosses a specified fan limit (rises above it or falls below it). This interrupt must be reset by reading all the interrupt status registers, or subsequent events do not generate interrupts. This mode is illustrated in the figure above. 8.10.4 Temperature SMI# Mode The SMI# pin can create interrupts that depend on the temperatures measured by CPUTIN, and AUXTIN. 8.10.4.1. Temperature Sensor 1 SMI# Interrupt (Default: SYSTIN) The SMI# pin has four interrupt modes with Temperature Sensor 1. (1) Shut-down Interrupt Mode This mode is enabled by setting Bank0 Index 40h, bit 4 to one. -60 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY In this mode, the SMI# pin can create an interrupt when the current temperature rises above TOL or Shutdown mode high limit temperature, and when the current temperature falls below THYST or Shut-down mode low limit temperature. Once the temperature rises above TOL, however, and generates an interrupt, this mode does not generate additional interrupts, even if the temperature remains above TOL, until the temperature falls below THYST. This interrupt must be reset by reading all the interrupt status registers, or subsequent events do not generate interrupts, except the first time current temperature rises above Shut-down mode high limit temperature. This is illustrated in the following figure. Shut-down mode High Limit Temperature Shut-down mode Low Lim it Tem perature TOL T HTST SMI# * * * * * * * * Interrupt Reset when Interrupt Status Registers are read Figure 8-23 Shut-down Interrupt Mode (2) Comparator Interrupt Mode This mode is enabled by setting THYST (Temperature Hysteresis) to 127°C. This mode is enabled by setting Bank0 Index 40h, bit 4 to 0. In this mode, the SMI# pin can create an interrupt as long as the current temperature exceeds TO (Over Temperature). This interrupt can be reset by reading all the interrupt status registers, or subsequent events do not generate interrupts. If the interrupt is reset, the SMI# pin continues to create interrupts until the temperature goes below TO. This is illustrated in the figure below. THYST 127'C TOI TOI THYST * * * * * * * *Interrupt Reset when Interrupt Status Registers are read Comparator Interrupt Mode Two-Times Interrupt Mode Figure 8-24 SMI Mode -61 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY (3) Two-Times Interrupt Mode This mode is enabled by setting THYST (Temperature Hysteresis) lower than TO and setting Bank0 Index 4Ch, bit 5 to zero. This mode is enabled by setting Bank0 Index 40h, bit 4 to 0. In this mode, the SMI# pin can create an interrupt when the current temperature rises above TO or when the current temperature falls below THYST. Once the temperature rises above TO, however, and generates an interrupt, this mode does not generate additional interrupts, even if the temperature remains above TO, until the temperature falls below THYST. This interrupt must be reset by reading all the interrupt status registers, or subsequent events do not generate interrupts. This is illustrated in the figure above. Figure 3- One-Time Interrupt Mode This mode is enabled by setting THYST (Temperature Hysteresis) lower than TO and setting Bank0 Index 4Ch, bit 5 to one. This mode is enabled by setting Bank0 Index 40h, bit 4 to 0. In this mode, the SMI# pin can create an interrupt when the current temperature rises above TO. Once the temperature rises above TO, however, and generates an interrupt, this mode does not generate additional interrupts, even if the temperature remains above TO, until the temperature falls below THYST. This interrupt must be reset by reading all the interrupt status registers, or subsequent events do not generate interrupts. This is illustrated in the following figure. TOI THYST * * *Interrupt Reset when Interrupt Status Registers are read One-Time Interrupt Mode Figure 8-25 SMI Mode of SYSTIN II 8.10.4.2. SMI# Interrupt of Temperature Sensor 2 (Default: CPUTIN) and Temperature Sensor 3 (Default: AUXTIN) and Temperature Sensor 4 (Default: SYSTIN) and Temperature Sensor 5 (Default: SYSTIN) and Temperature Sensor 6 (Default: SYSTIN). The SMI# pin has 3 interrupt modes with Temperature Sensor 2~6. (1) Shut-down Interrupt Mode This mode is enabled by Bank0 Index 40h, bit5 to one for Temperature Sensor 2; Bank0 Index 40h, bit6 to one for Temperature Sensor 3; Bank6 Index 74h, bit1 to one for Temperature Sensor 4; Bank6 Index 79h, bit1 to one for Temperature Sensor 5 and Bank6 Index 7Eh, bit1 to one for Temperature Sensor 6. In this mode, the SMI# pin can create an interrupt when the current temperature rises above TOL or Shutdown mode high limit temperature, and when the current temperature falls below THYST or Shut-down mode low limit temperature. Once the temperature rises above TOL, however, and generates an interrupt, this mode does not generate additional interrupts, even if the temperature remains above TOL, until the temperature falls below THYST. This interrupt must be reset by reading all the interrupt status registers, or subsequent events do -62 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY not generate interrupts, except the first time current temperature rises above Shut-down mode high limit temperature. This is illustrated in the following figure. Shut-down mode High Limit Temperature Shut-down mode Low Limit Temperature TOL T HTST SMI# * * * * * * * * Interrupt Reset when Interrupt Status Registers are read Figure 8-26 Shut-down Interrupt Mode (2) Comparator Interrupt Mode This mode is enabled by setting Bank0 Index 4Ch, bit 6, to one. In this mode, the SMI# pin can create an interrupt when the current temperature exceeds TO (Over Temperature) and continues to create interrupts until the temperature falls below THYST. This interrupt can be reset by reading all the interrupt status registers, or subsequent events do not generate interrupts. This is illustrated in the figure below. TOI TOI THYST THYST * * * * * * * * *Interrupt Reset when Interrupt Status Registers are read Comparator Interrupt Mode Two-Times Interrupt Mode Figure 8-27 SMI Mode of CPUTIN (3) Two-Times Interrupt Mode This mode is enabled by setting Bank0 Index 4Ch, bit 6, to zero. In this mode, the SMI# pin can create an interrupt when the current temperature rises above TO or when the current temperature falls below THYST. Once the temperature rises above TO, however, and generates an -63 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY interrupt, this mode does not generate additional interrupts, even if the temperature remains above TO, until the temperature falls below THYST. This interrupt must be reset by reading all the interrupt status registers, or subsequent events do not generate interrupts. This is illustrated in the figure above. Table8-6 Relative Register of SMI functions SMIOVT1 SMIOVT2 SHUTDOWN MODE COMPARATOR MODE TWO-TIME INTERRUPT MODE Bank0,Index40_Bit4 (EN_WS=1) Bank0,Index43 _Bit4(TIN=0) Bank0,Index46 _Bit3 (Shut = 0) Bank0,Index43_Bit4 (TIN=0) Bank0,Index3A (Thyst = 8’h7F) Bank0,Index43_Bit4 (TIN=0) Bank0,Index4C_Bit5 (EN_T1_One = 0) Bank0,Index40_Bit5 (EN_WS=1) Bank0,Index43_ Bit5(TIN=0) Bank0,Index46_ Bit 4 (Shut = 0) Bank0,Index43_Bit5 (TIN=0) Bank0,Index4C_ Bit6 (T2T3_INT=1) Bank0,Index43_ Bit5(TIN=0) Bank0,Index4C_ Bit6 (T2T3_INT=0) ONE-TIME INTERRUPT MODE Bank0,Index43_ Bit4 Bank0,Index4C_ Bit5 Table 8-7 Relative Register of OVT functions SMIOVT1 SMIOVT2 Bank0,Index18_Bit6=0 (Enable OVT output) Bank1, Index52_Bit0 0: Start to monitor the source of SMIOVT2 temperature. 1: Stop monitoring the source of SMIOVT2 temperature. Bank0,Index18_Bit4 0: Comparator Mode (def.) 1: Interrupt Mode Bank 0, Inedex4C_Bit 3 0: Disable SMIOVT2 temperature sensor over temperature output 1: Enable SMIOVT2 temperature sensor over temperature output Bank0, Index18_Bit0 0: Start to monitor the source of SMIOVT1 temperature. 1: Stop monitoring the source of SMIOVT1 temperature. Bank 1, Index52_Bit 1 0: Comparator Mode 1: Interrupt Mode Bank 1, Index52_Bit 3~4 Number of faults to detect before setting OVT# output. 8.10.5 OVT# Interrupt Mode -64 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY The SMI#/OVT# pin is a multi-function pin. It can be in SMI# mode or in OVT# mode by setting Configuration Register CR[24h], bit 2 to one or zero, respectively. In OVT# mode, it can monitor temperatures, and OVT pin could be enabled to OVT output by Bank0 Index 18h, bit 6 for Temperature Sensor 1(default: SYSTIN); Bank1 Index 52h, bit 1 for Temperature Sensor 2(default: CPUTIN); Bank2 Index 52h, bit1 for Temperature Sensor 3(default: AUXTIN); Bank6 Index 28h, bit1 for Temperature Sensor 4(default: SYSTIN); Bank6 Index 29h, bit1 for Temperature Sensor 5(default: SYSTIN)and Bank6 Index 2Ah, bit1 for Temperature Sensor 6(default: SYSTIN). The OVT# pin has two interrupt modes, comparator and interrupt. The modes are illustrated in this figure. To THYST OVT# (Comparator Mode; default) OVT# (Interrupt Mode) * * * *Interrupt Reset when Temperature sensor registers are read Figure 8-28 OVT# Modes of Temperature Inputs If Bank0 Index 18h, bit 4, is set to zero, the OVT# pin is in comparator mode. In comparator mode, the OVT# pin can create an interrupt once the current temperature exceeds TO and continues to create interrupts until the temperature falls below THYST. The OVT# pin is asserted once the temperature has exceeded TO and has not yet fallen below THYST. If Bank0 Index 18h, bit 4, is set to one, the OVT# pin is in interrupt mode. In interrupt mode, the OVT# pin can create an interrupt once the current temperature rises above TO or when the temperature falls below THYST. Once the temperature rises above TO, however, and generates an interrupt, this mode does not generate additional interrupts, even if the temperature remains above TO, until the temperature falls below THYST. This interrupt must be reset by reading all the interrupt status registers. The OVT# pin is asserted when an interrupt is generated and remains asserted until the interrupt is reset. -65 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9. HARDWARE MONITOR REGISTER SET The base address of the Address Port and Data Port is specified in registers CR[60h] and CR[61h] of Logical Device B, the hardware monitor device. CR[60h] is the high byte, and CR[61h] is the low byte. The Address Port and Data Port are located at the base address, plus 5h and 6h, respectively. For example, if CR[60h] is 02h and CR[61h] is 90h, the Address Port is at 0x295h, and the Data Port is at 0x296h. Remember that this access is from the host CPU I/O address range. To conserve space in the crowded CPU I/O addresses, many of the hardware monitor registers are “banked” with the bank number located at Bank0, index 04Eh. 9.1 Address Port (Port x5h) Attribute: Size: Bit 6:0 Read/Write , Bit 7: Reserved 8 bits BIT 7 6 5 4 2 1 0 0 0 0 0 BIT 2 BIT 1 BIT 0 DATA NAME DEFAULT 0 0 0 BIT 0 DESCRIPTION RESERVED. 7 6-0 READ/WRITE. BIT 7 BIT 6 BIT 5 Reserved BIT 4 BIT 3 Address Pointer (Power On default 00h) (Power On default 0) 9.2 3 A6 A5 A4 6 5 4 A3 A2 A1 A0 3 2 1 0 0 0 0 0 Data Port (Port x6h) Attribute: Size: Read/Write 8 bits BIT 7 DATA NAME DEFAULT BIT 7-0 0 0 0 0 DESCRIPTION Data to be read from or to be written to Value RAM and Register. -66 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.3 SYSFANOUT PWM Output Frequency Configuration Register – Index 00h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 NAME PWM_CLK_SEL1 DEFAULT 0 6 5 4 3 2 1 0 1 0 0 PWM_SCALE1 0 0 0 0 The register is meaningful only when SYSFANOUT is progarmmed for PWM output (i.e., Bank0, Index 04h, bit 0 is 0). BIT DESCRIPTION 7 PWM_CLK_SEL1. SYSFANOUT PWM Input Clock Source Select. This bit selects the clock source for PWM output frequency. Refer the Divisor table. 6-0 PWM_SCALE1. SYSFANOUT PWM Pre-Scale divider. The clock source for PWM output is divided by this seven-bit value to calculate the actual PWM output frequency. Refer the Divisor table. The clock source selected by CKSEL will be divided by the divisor and used as a fan PWM output frequency. If CKSEL equals 0, then the output clock is simply equal to 93.9/ (Divisor[6:0]+1) KHz MappedDivisor depends on Divisor[6:0] and is described in the table below. Divisor[6:0] Mapped Divisor Output Frequency 0000000 1 93.9KHz Divisor[6:0] Mapped Divisor Output Frequency 0000001 2 46.95KHz 0000010 3 31.3KHz 0000011 4 23.47KHz 0000100 5 18.78KHz 0001111 16 5.86KHz 0000101 6 15.65KHz 0011111 32 2.93KHz 0000110 7 13.41KHz 0111111 64 1.46KHz 0000111 8 11.73KHz 1111111 128 734Hz ………………………………………….. If CKSEL equals 1, then the output clock is simply equal to 1008/ Mapped Divisor Hz MappedDivisor depends on Divisor[3:0] and is described in the table below. 9.4 Divisor[3:0] Mapped Divisor Output Frequency Divisor[3:0] Mapped Divisor Output Frequency 0000 1 1008Hz 1000 12 84Hz 0001 2 504Hz 1001 16 63Hz 0010 3 336Hz 1010 32 31.5Hz 0011 4 252Hz 1011 64 15.75Hz 0100 5 201Hz 1100 128 7.875Hz 0101 6 168Hz 1101 256 3.94Hz 0110 7 144Hz 1110 512 1.97Hz 0111 8 126Hz 1111 1024 0.98Hz SYSFANOUT Output Value Select Register – Index 01h (Bank 0) -67 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Attribute: Size: Read Only 8 bits BIT 7 6 5 4 3 2 NAME SYSFANOUT Value DEFAULT 7Fh 7 FUNCTION MODE PWM Output (Bank0, Index 04h, bit 0 is 0) DESCRIPTION DC Voltage Output Bank0, Index 04h, bit 0 is 1) 6 5 4 1 3 2 0 1 0 The PWM duty cycle is equal to this eight-bit value, divided by 255, times 100%. FFh creates a duty cycle of 100%, and 00h creates a duty cycle of 0%. SYSFANOUT voltage control. The output voltage is calculated according to this equation. DESCRIPTION OUTPUT Voltage = Vref * Reserved FANOUT 64 Note. VREF is approx 2.048V. This register could be programmed by Bank1, Index 09 9.5 CPUFANOUT PWM Output Frequency Configuration Register – Index 02h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 NAME PWM_CLK_SEL2 DEFAULT 0 6 5 4 3 2 1 0 1 0 0 PWM_SCALE2 0 0 0 0 The register is meaningful only when CPUFANOUT is programmed for PWM output. BIT DESCRIPTION 7 PWM_CLK_SEL2. CPUFANOUT PWM Input Clock Source Select. This bit selects the clock source for the PWM output. Refer the Divisor table. 6-0 PWM_SCALE2. CPUFANOUT PWM Pre-Scale divider. The clock source for PWM output is divided by this seven-bit value to calculate the actual PWM output frequency. Refer the Divisor table. The clock source selected by CKSEL will be divided by the divisor and used as a fan PWM output frequency. If CKSEL equals 0, then the output clock is simply equal to 93.9/ (Divisor[6:0]+1) KHz MappedDivisor depends on Divisor[6:0] and is described in the table below. Divisor[6:0] Mapped Divisor Output Frequency 0000000 1 93.9KHz 0000001 2 46.95KHz 0000010 3 31.3KHz 0000011 4 23.47KHz 0000100 5 18.78KHz Divisor[6:0] Mapped Divisor Output Frequency ………………………………………….. 0001111 -68 16 5.86KHz Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Divisor[6:0] Mapped Divisor Output Frequency Divisor[6:0] Mapped Divisor Output Frequency 0000101 6 15.65KHz 0011111 32 2.93KHz 0000110 7 13.41KHz 0111111 64 1.46KHz 0000111 8 11.73KHz 1111111 128 734Hz If CKSEL equals 1, then the output clock is simply equal to 1008/ Mapped Divisor Hz MappedDivisor depends on Divisor[3:0] and is described in the table below. 9.6 Divisor[3:0] Mapped Divisor Output Frequency Divisor[3:0] Mapped Divisor Output Frequency 0000 1 1008Hz 1000 12 84Hz 0001 2 504Hz 1001 16 63Hz 0010 3 336Hz 1010 32 31.5Hz 0011 4 252Hz 1011 64 15.75Hz 0100 5 201Hz 1100 128 7.875Hz 0101 6 168Hz 1101 256 3.94Hz 0110 7 144Hz 1110 512 1.97Hz 0111 8 126Hz 1111 1024 0.98Hz CPUFANOUT Output Value Select Register – Index 03h (Bank 0) Attribute: Size: Read Only 8 bits BIT 7 6 5 4 3 2 NAME CPUFANOUT Value DEFAULT 7Fh 7 FUNCTION MODE PWM Output DESCRIPTION 6 5 4 3 1 2 0 1 0 CPUFANOUT PWM Duty. The PWM duty cycle is equal to this 8-bit value, divided by 255, times 100%. FFh creates a duty cycle of 100%, and creates a duty cycle of 0%. This register could be programmed by Bank2, Index 09 9.7 SYSFANOUT Configuration Register I – Index 04h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 DEFAULT 7-1 0 3 2 1 RESERVED NAME BIT 4 0 0 0 0 0 0 SYSFANOUT_SEL 0 0 1 DESCRIPTION Reserved. SYSFANOUT Output Mode Selection. 0: SYSFANOUT pin produces a PWM duty cycle output. 1: SYSFANOUT pin produces DC output. (Default) -69 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.8 Reserved Register – Index 05h ~ 0Fh (Bank 0) 9.9 Reserved Register – Index 10h (Bank 0) 9.10 Reserved Register – Index 11h (Bank 0) 9.11 Reserved Register – Index 12h (Bank 0) 9.12 Reserved Register – Index 13h (Bank 0) 9.13 Reserved Register – Index 14h (Bank 0) 9.14 Reserved Register – Index 15h (Bank 0) 9.15 Reserved Register – Index 16-17h (Bank 0) 9.16 OVT# Configuration Register – Index 18h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 BIT RESERVED DIS_OVT1 RESERVED OVT1_Mode DEFAULT 0 1 0 0 BIT 3 2 RESERVED 0 0 Reserved. 6 DIS_OVT1. 0: Enable SMIOVT1 OVT# output. (Default) 1: Disable temperature sensor SMIOVT1 over-temperature (OVT#) output. 5 Reserved. 4 OVT1_Mode. SMIOVT1 Mode Select. 0 : Compare Mode. (Default) 1 : Interrupt Mode. 0 0 STOP 0 0 DESCRIPTION 7 3-1 1 Reserved. STOP. 0: Monitor SMIOVT1 temperature source. 1: Stop monitoring SMIOVT1 temperature source. 9.17 Reserved Registers – Index 19h ~ 1Fh (Bank 0) 9.18 Value RAM ⎯ Index 27h ~ 3Fh (Bank 0) ADDRESS A6-A0 27h DESCRIPTION SMIOVT1 temperature source reading. -70 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY ADDRESS A6-A0 DESCRIPTION 2Bh CPUVCORE High Limit 2Ch CPUVCORE Low Limit 2Dh Reserved 2Eh Reserved 2Fh AVCC High Limit 30h AVCC Low Limit 31h 3VCC High Limit 32h 3VCC Low Limit 33h Reserved 34h Reserved 35h Reserved 36h Reserved 37h VIN4 High Limit 38h VIN4 Low Limit 39h SMIOVT1 temperature sensor High Limit 3Ah SMIOVT1 temperature sensor Hysteresis Limit 9.19 Configuration Register – Index 40h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME INITIALIZATION RESERVED EN_WS1 EN_WS INT_CLEAR RESERVED SMI#ENABLE START DEFAULT 0 0 0 0 0 0 1 1 BIT DESCRIPTION 7 Initialization. A one restores the power-on default values to some registers. This bit clears itself since the power-on default of this bit is zero. 6 RESERVED 5 Output type of SMIOVT2: 1: SMI# output type of SMIOVT Source2 temperature (Default: CPUTIN) is Shut-down Interrupt Mode. 0: Depond on the value of Bank0, Index 4C, bit6. 4 Output type of SMIOVT1 1: SMI# output type of SMIOVT Source1 temperature (Default: SYSTIN) is Shut-down Interrupt Mode. 0: Depond on the value of Bank0, Index 4C, bit5. 3 INT_Clear. A one disables the SMI# output without affecting the contents of Interrupt Status Registers. The device will stop monitoring. It will resume upon clearing of this bit. 2 Reserved. 1 SMI# Enable. A one enables the SMI# Interrupt output. -71 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT DESCRIPTION 1: Enable SMI# function (Deafult) 0: Disable SMI# function Start. A one enables startup of monitoring operations. A zero puts the part in standby mode. Note: Unlike the “INT_Clear” bit, the outputs of interrupt pins will not be cleared if the user writes a zero to this location after an interrupt has occurred. 0 9.20 Interrupt Status Register 1 – Index 41h (Bank 0) Attribute: Size: Read Clear 8 bits BIT 7 6 5 4 3 2 1 0 NAME CPUFANIN SYSFANIN SOURCE2 _ SMI SOURCE1 _ SMI 3VCC AVCC Reserved CPUVCORE DEFAULT 0 0 0 0 0 0 0 0 BIT DESCRIPTION 7 CPUFANIN. A one indicates the fan count limit of CPUFANIN has been exceeded. 6 SYSFANIN. A one indicates the fan count limit of SYSFANIN has been exceeded. 5 SMIOVT2. A one indicates the high limit of SMIOVT2 temperature has been exceeded. (CPUTIN is default temperature) 4 SMIOVT1. A one indicates the high limit of SMIOVT1 temperature has been exceeded. (SYSTIN is default temperature) 3 3VCC. A one indicates the high or low limit of 3VCC has been exceeded. 2 AVCC (Pin 106). A one indicates the high or low limit of AVCC has been exceeded. 1 Reserved 0 CPUVCORE. A one indicates the high or low limit of CPUVCORE has been exceeded. 9.21 Interrupt Status Register 2 – Index 42h (Bank 0) Attribute: Size: Read Clear 8 bits BIT 7 6 5 4 3 2 1 0 NAME Reserved. Reserved Reserved Reserved Reserved Reserved VIN4 Reserved DEFAULT 0 0 0 0 0 0 0 0 BIT 7-2 1 0 DESCRIPTION Reserved VIN4. A one indicates the high or low limit of VIN4 has been exceeded. Reserved -72 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.22 SMI# Mask Register 1 – Index 43h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME CPUFANIN SYSFANIN SMIOVT2 SMIOVT1 3VCC AVCC Reserved CPUVCORE DEFAULT 1 1 1 1 1 1 1 1 BIT DESCRIPTION 7 6 CPUFANIN 5 SMIOVT2 A one disables the corresponding interrupt 4 SMIOVT1 3 3VCC 2 AVCC status bit for the SMI interrupt. (See Interrupt Status Register 1 – Index 41h (Bank0)) 1 Reserved 0 CPUVCORE SYSFANIN 9.23 SMI# Mask Register 2 – Index 44h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME TAR2 TAR1 Reserved Reserved Reserved VIN4 Reserved Reserved DEFAULT 1 1 1 1 1 1 1 1 BIT DESCRIPTION 7 TAR2 6 TAR1 5 Reserved 4 Reserved 3 Reserved 2 VIN4 1 Reserved 0 Reserved A one disables the corresponding interrupt status bit for the interrupt. (See Interrupt Status Register 2 – Index 42h (Bank 0)) 9.24 Interrupt Status Register 4 – Index 45h (Bank 0) Attribute: Size: Read Clear 8 bits BIT 7 NAME Reserved DEFAULT 0 6 0 5 0 4 3 2 1 0 CPU FANOUT SYS FANOUT RESERVED Shut_ SOURCE2_SMI Shut_ SOURCE1_SMI 0 0 0 0 0 -73 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT DESCRIPTION 7 RESERVED 6 RESERVED 5 Reserved 4 CPUFANOUT. “1” indicates that CPUFANOUT works for three minutes at the full fan speed. 3 SYSFANOUT. “1” indicates that SYSFANOUT works for three minutes at the full fan speed. 2 RESERVED 1 Shut_SOURCE2_SMI. “1” indicates the high limit of SMIOVT _SOURCE2 temperature of SMI# Shut-down mode has been exceeded. (CPUTIN is default temperature) 0 Shut_SOURCE1_SMI. “1” indicates the high limit of SMIOVT _SOURCE1 temperature of SMI# Shut-down mode has been exceeded. (SYSTIN is default temperature) 9.25 SMI# Mask Register 3 – Index 46h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 NAME 5 Reserved DEFAULT 0 0 4 3 Shut_CPU Shut_SYS 1 1 0 BIT 2 1 0 Reserved 1 1 0 DESCRIPTION 7-6 Reserved 5 RESERVED “1” disables the corresponding interrupt 4 Shut_SOURCE2_SMI 3 Shut_SOURCE1_SMI status bit for the SMI interrupt. (See Interrupt Status Register 4 – Index 45h (Bank 0)). Reserved 2-0 9.26 Reserved Register – Index 47h (Bank 0) 9.27 Serial Bus Address Register – Index 48h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 NAME RESERVED DEFAULT 0 6 4 3 2 1 0 0 1 SERIAL BUS ADDRESS 0 BIT 7 5 1 0 1 1 DESCRIPTION Reserved (Read Only). -74 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 6-0 DESCRIPTION Serial Bus Address 9.28 Reserved Register – Index 49h ~ 4Bh (Bank 0) 9.29 SMI/OVT Control Register1 – Index 4Ch (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 NAME Reserved T2ToT6_INT MODE EN_T1 _ONE RESERVED DIS_ OVT2 OVTPOL DEFAULT 0 0 0 0 1 0 BIT 1 0 RESERVED 0 0 DESCRIPTION 7 Reserved 6 T2ToT6_INTMode. 1: SMI# output type of Temperature SMIOVT2, SMIOVT3, SMIOVT4, SMIOVT5 and SMIOVT6 temperature source is in Comparator Interrupt mode. 0: SMI# output type of Temperature SMIOVT2, SMIOVT3, SMIOVT4, SMIOVT5 and SMIOVT6 temperature source is in Two-Times Interrupt mode. (Default) 5 EN_T1_ONE. 1: SMI# output type of SMIOVT Source1 temperature (Default: SYSTIN) is One-Time Interrupt Mode. 0: SMI# output type is in Two-Times Interrupt Mode. (Default) 4 RESERVED 3 DIS_OVT2. 1: Disable SMIOVT Source2 temperature sensor (Default: CPUTIN) over-temperature (OVT) output. 0: Enable SMIOVT Source2 temperature OVT output through pin OVT#. (Default) 2 OVTPOL (Over-temperature polarity). 1: OVT# is active high. 0: OVT# is active low (Default). 1-0 Reserved. 9.30 FAN IN/OUT Control Register – Index 4Dh (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 4 Reserved NAME DEFAULT 0 BIT 7-4 5 1 0 1 3 2 1 0 FANOPV2 FANINC2 FANOPV1 FANINC1 0 1 0 1 DESCRIPTION Reserved -75 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 3 2 DESCRIPTION FANOPV2. CPUFANIN output value, only if bit 2 is set to zero. 1: Pin 61 (CPUFANIN) generates a logic-high signal. 0: Pin 61 generates a logic-low signal. (Default) FANINC2. CPUFANIN Input Control. 1: Pin 61 (CPUFANIN) acts as a fan tachometer input. (Default) 0: Pin 61 acts as a fan control signal, and the output value is set by bit 3. 1 FANOPV1. SYSFANIN output value, only if bit 0 is set to zero. 1: Pin 63 (SYSFANIN) generates a logic-high signal. 0: Pin 63 generates a logic-low signal. (Default) 0 FANINC1. SYSFANIN Input Control. 1: Pin 63 (SYSFANIN) acts as a fan tachometer input. (Default) 0: Pin 63 acts as a fan control signal, and the output value is set by bit 1. 9.31 Bank Select Register – Index 4Eh (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 NAME HBACS DEFAULT 1 6 5 4 Reserved. 0 0 BIT 3 2 1 0 BANK SEL3 BANK SEL2 BANK SEL1 BANK SEL0 0 0 0 0 0 DESCRIPTION 7 HBACS. HBACS – High Byte Access. 1: Access Index 4Fh high-byte register. (Default) 0: Access Index 4Fh low-byte register. 6 Reserved. 5 Reserved. 4 Reserved. 3 BANKSEL3. 2 BANKSEL2. 1 BANKSEL1. 0 BANKSEL0. Bank Select for Bank0 to Bank7. The Three -bit binary value corresponds to the bank number. For example, "0010" selects bank2. 9.32 Nuvoton Vendor ID Register – Index 4Fh (Bank 0) Attribute: Size: Read Only 16 bits BIT 15 14 13 12 10 9 8 1 1 0 0 VIDH NAME DEFAULT 11 0 1 0 1 -76 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7 6 5 4 3 2 1 0 0 0 1 1 2 1 0 0 0 1 3 2 1 0 0 0 0 1 VIDL NAME DEFAULT 1 0 1 BIT 0 DESCRIPTION Vendor ID High-Byte, if Index 4Eh, bit 7 is 1. Default 5Ch. Vendor ID Low-Byte, if Index 4Eh, bit 7 is 0. Default A3h. 15-8 7-0 9.33 Reserved Register – Index 50h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 NAME 3 Reserved DEFAULT 0 0 0 BIT 0 0 DESCRIPTION Reserved 7-0 9.34 Reserved Register – Index 51h ~ 57h (Bank 0) 9.35 Chip ID – Index 58h (Bank 0) Attribute: Size: Read Only 8 bits BIT 7 6 5 4 CHIPID NAME DEFAULT 1 1 0 BIT 0 DESCRIPTION 7-0 Nuvoton Chip ID number. Default C1h. 9.36 Reserved Register – Index 59h ~ 5Ch (Bank 0) 9.37 VBAT Monitor Control Register – Index 5Dh (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME Reserved DIODES6 DIODES5 DIODES4 DIODES3 DIODES2 DIODES1 EN_ VBAT _MNT DEFAULT 0 0 0 0 0 1 0 0 -77 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT DESCRIPTION Reserved 7 DIODES 6. Sensor type selection for VTIN0. 1: Diode sensor. 0: Thermistor sensor. (default) 6 DIODES 5. Sensor type selection for AUXTIN2. 1: Diode sensor. 0: Thermistor sensor. (default) 5 DIODES 4. Sensor type selection for AUXTIN1. 1: Diode sensor. 0: Thermistor sensor. (default) 4 DIODES 3. Sensor type selection for AUXTIN0. 1: Diode sensor. 0: Thermistor sensor. (default) 3 DIODES 2. Sensor type selection for CPUTIN. 1: Diode sensor. (default) 0: Thermistor sensor. 2 DIODES 1. Sensor type selection for SYSTIN. 1: Diode sensor. 0: Thermistor sensor. (default) 1 EN_VBAT_MNT. 1: Enable battery voltage monitor. When this bit changes from zero to one, it takes one monitor cycle time to update the VBAT reading value register. 0: Disable battery voltage monitor. 0 9.38 Current Mode Enable Register – Index 5Eh (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME Reserved EN_ VTIN0 CURRENT MODE EN_ AUXTIN2 CURRENT MODE EN_ AUXTIN1 CURRENT MODE EN_ AUXTIN0 CURRENT MODE EN_ CPUTIN CURRENT MODE EN_ SYSTIN CURRENT MODE Reserved DEFAULT 0 0 0 0 0 1 0 0 BIT 7-4 3 DESCRIPTION Reserved Enable AUXTIN0 Current Mode. With AUXTIN0 is selected to Diode sensor (Bank0, Index 5Dh, Bit 3 = 1). 1: Temperature sensing of AUXTIN0 by Current Mode. 0: Temperature sensing of AUXTIN0 depends on the setting of Index 5Dh. (Default) Enable CPUTIN Current Mode. With CPUTIN is selected to Diode sensor (Bank0, Index 2 5Dh, Bit 2 = 1). 1: Temperature sensing of CPUTIN by Current mode. (Default) 0: Temperature sensing of CPUTIN depends on the setting of Index 5Dh. -78 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 1-0 DESCRIPTION Reserved. 9.39 Reserved Register – Index 5F (Bank 0) 9.40 Reserved Register – Index 60 (Bank 0) 9.41 Reserved Register – Index 61F ~ 72F (Bank 0) 9.42 MONITOR TEMPERATURE 1 Register (Integer Value)- Index 73h (Bank 0) Attribute: Size: Read Only 8 bits BIT 7 6 5 NAME 4 3 2 1 0 0 0 MONITOR TEMPERATURE 1 [8:1] DEFAULT 0 0 0 0 0 0 BIT DESCRIPTION 7-0 MONITOR TEMPERATURE 1 [8:1] SYSFANOUT fan control temperature reading. (Source is selected by Bank1, Index00 bit[4:0]) 9.43 MONITOR TEMPERATURE 1 Register (Fractional Value)- Index 74h (Bank 0) Attribute: Size: Read Only 8 bits BIT 7 NAME MONITOR TEMPERATURE 1 [0] DEFAULT 0 6 5 4 3 2 1 0 0 0 0 Reserved 0 0 0 0 BIT DESCRIPTION 7 MONITOR TEMPERATURE 1 [0] SYSFANOUT fan control temperature reading. (Source is selected by Bank1, Index00 bit[4:0]) Reserved 6-0 9.44 MONITOR TEMPERATURE 2 Register (Integer Value)- Index 75h (Bank 0) Attribute: Size: Read Only 8 bits BIT NAME 7 6 5 4 3 2 1 0 MONITOR TEMPERATURE 2 [8:1] -79 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY DEFAULT 0 0 0 0 0 0 0 0 BIT DESCRIPTION 7-0 MONITOR TEMPERATURE 2 [8:1] CPUFANOUT fan control temperature reading. (Source is selected by Bank2, Index00 bit[4:0]) 9.45 MONITOR TEMPERATURE 2 Register (Fractional Value)- Index 76h (Bank 0) Attribute: Size: Read Only 8 bits BIT 7 NAME MONITOR TEMPERATURE 2 [0] DEFAULT 0 6 5 4 3 2 1 0 0 0 0 Reserved 0 0 0 0 BIT DESCRIPTION 7 MONITOR TEMPERATURE 2 [0] CPUFANOUT fan control temperature reading. (Source is selected by Bank2, Index00 bit[4:0]) Reserved 6-0 9.46 Reserved Register - Index 77h (Bank 0) 9.47 Reserved Register - Index 78h (Bank 0) 9.48 Reserved Register - Index 79h (Bank 0) 9.49 Reserved Register - Index 7Ah (Bank 0) 9.50 Reserved Register - Index 7Ch (Bank 0) 9.51 Reserved Register – Index 7Dh~ADh (Bank 0) 9.52 PECI Temperature Reading Enable for SMIOVT and SMART FAN Control Register – Index AEh (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 4 3 2 Reserved NAME DEFAULT 5 0 0 0 0 -80 0 0 1 0 EN_PECI1 EN_PECI0 0 0 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT DESCRIPTION Reserved. 7-2 Enable PECI Agent1 1 Enable PECI Agent0 0 Note. If the temperature source is selecting to PECI, please set Bank0 Index AEh first for reading correct value. 9.53 BEEP Control Register 1 – Index B2h (Bank0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME En3VSB_ BP EnVIN4_ BP Reserved Reserved En3VCC_ BP EnAVCC_ BP Reserved EnCPUVCORE_ BP DEFAULT 0 0 0 0 0 0 0 0 BIT DESCRIPTION 7 En3VSB_BP 1 : Enable 3VSB Beep function 0 : Disable 3VSB Beep fuction 6 EnVIN4_BP 1 : Enable VIN4 Beep function 0 : Disable VIN4 Beep fuction 5 Reserved 4 Reserved 3 En3VCC_BP 1 : Enable 3VCC Beep function 0 : Disable 3VCC Beep fuction 2 EnAVCC_BP 1 : Enable AVCC Beep function 0 : Disable AVCC Beep fuction 1 Reserved 0 EnCPUVCORE_BP 1 : Enable CPUVCORE Beep function 0 : Disable CPUVCORE Beep fuction 9.54 BEEP Control Register 2 – Index B3h (Bank0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME User Mode Reserved EnVIN3_ BP EnVIN2_ BP Reserved Reserved EnVTT_ BP EnVBAT_ BP DEFAULT 0 0 0 0 0 0 0 0 -81 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT DESCRIPTION 7 User control for Beep alarm 1 : Enable 0 : Disable 6 Reserved 5 EnVIN3_BP 1 : Enable VIN3 Beep function 0 : Disable VIN3 Beep fuction 4 EnVIN2_BP 1 : Enable VIN2 Beep function 0 : Disable VIN2 Beep fuction 3 Reserved 2 Reserved 1 EnVTT_BP 1 : Enable VTT Beep function 0 : Disable VTT Beep fuction 0 EnVBAT_BP 1 : Enable VBAT Beep function 0 : Disable VBAT Beep fuction Note: For each beep alarm event, please set “Bank0, Index B5, bit0” to 1. 9.55 BEEP Control Register 3 – Index B4h (Bank0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED EnT2 _BP EnT1 _BP DEFAULT 0 0 0 0 0 0 0 0 BIT 7-2 DESCRIPTION Reserved 0 EnT2_BP 1 : Enable SMIOVT2 Beep function 0 : Disable SMIOVT2 Beep fuction 0 EnT1_BP 1 : Enable SMIOVT1 Beep function 0 : Disable SMIOVT1 Beep fuction Note: For each beep alarm event, please set “Bank0, Index B5, bit0” to 1. 9.56 BEEP Control Register 4 – Index B5h (Bank0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 4 -82 3 2 1 0 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Reserved NAME DEFAULT 0 0 0 BIT 7-3 2 0 En CPUFANIN _BP En SYSFANIN _BP En_Beep 0 0 0 0 DESCRIPTION Reserved En CPUFANIN _BP 1 : Enable CPUFANIN Beep function 0 : Disable CPUFANIN Beep fuction 1 En SYSFANIN _BP 1 : Enable SYSFANIN Beep function 0 : Disable SYSFANIN Beep fuction 0 Enable Beep Function: 1 : Enable Beep Function 0 : Disable Beep Fuction Note: For each beep alarm event, please set “Bank0, Index B5, bit0” to 1. 9.57 SYSFAN Monitor Temperature Source Select Register/ STOPDUTY Enable Register – Index 00h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 NAME Stopduty_En DEFAULT 0 BIT 7 6 5 4 Reserved 0 3 2 1 0 SYSFAN SOURCE[4:0] 0 0 0 0 0 1 DESCRIPTION Stopduty_En: 0: FANOUT will decrease to zero value at most if necessary. 1: FANOUT will decrease to SYSFANOUT Stop Value (Bank1, index05h) at most if necessary. (This function is for Thermal Cruise mode.) 6-5 Reserved 4-0 SYSFAN Temperature Source Select: Bits 43210 0 0 0 0 1: Select SYSTIN as SYSFAN monitoring source. (Default) 0 0 0 1 0: Select CPUTIN as SYSFAN monitoring source. 0 0 0 1 1: Select AUXTIN0 as SYSFAN monitoring source. 0 0 1 0 0: Select AUXTIN1 as SYSFAN monitoring source. 0 0 1 0 1: Select AUXTIN2 as SYSFAN monitoring source. 0 0 1 1 0: Select VTIN0 as SYSFAN monitoring source. 0 0 1 1 1: Reserved. 0 1 0 0 0: Select SMBUSMASTER 0 as SYSFAN monitoring source. -83 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT DESCRIPTION 0 1 0 0 1: Select SMBUSMASTER 1 as SYSFAN monitoring source. 0 1 0 1 0: Select SMBUSMASTER 2 as SYSFAN monitoring source. 0 1 0 1 1: Select SMBUSMASTER 3 as SYSFAN monitoring source. 0 1 1 0 0: Select SMBUSMASTER 4 as SYSFAN monitoring source. 0 1 1 0 1: Select SMBUSMASTER 5 as SYSFAN monitoring source. 0 1 1 1 0: Select SMBUSMASTER 6 as SYSFAN monitoring source. 0 1 1 1 1: Select SMBUSMASTER 7 as SYSFAN monitoring source. 1 0 0 0 0: Select PECI Agent 0 as SYSFAN monitoring source. 1 0 0 0 1: Select PECI Agent 1 as SYSFAN monitoring source. 1 0 0 1 0: Select PCH_CHIP_CPU_MAX_TEMP as SYSFAN monitoring source. 1 0 0 1 1: Select PCH_CHIP_TEMP as SYSFAN monitoring source. 1 0 1 0 0: Select PCH_CPU_TEMP as SYSFAN monitoring source. 1 0 1 0 1: Select PCH_MCH_TEMP as SYSFAN monitoring source. 1 0 1 1 0: Select PCH_DIM0_TEMP as SYSFAN monitoring source. 1 0 1 1 1: Select PCH_DIM1_TEMP as SYSFAN monitoring source. 1 1 0 0 0: Select PCH_DIM2_TEMP as SYSFAN monitoring source. 1 1 0 0 1: Select PCH_DIM3_TEMP as SYSFAN monitoring source. 1 1 0 1 0: Select BYTE_TEMP as SYSFAN monitoring source. Note. If the temperature source is selecting to PECI, please set Bank0 Index AEh first for reading correct value. 9.58 SYSFAN Target Temperature Register / SYSFANIN Target Speed_L Register – Index 01h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 0 0 SYSTIN Target Temperature / SYSFANIN Target Speed_L NAME DEFAULT 0 0 0 0 7 FUNCTION MODE 0 6 0 5 4 3 2 1 Thermal CruiseTM DESCRIPTION SYSFAN Target Temperature Fan Speed CruiseTM DESCRIPTION SYSFANIN Target Speed [7:0], [11:8] associate index 0C [3:0] 0 9.59 SYSFAN MODE Register / SYSFAN TOLERRANCE Register – Index 02h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 BIT 5 4 SYSFAN MODE NAME DEFAULT 6 0 0 3 2 Reserved 0 0 0 1 0 Tolerance of SYSFAN Target Temperature or SYSFANIN Target Speed_L 0 0 0 DESCRIPTION -84 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY SYSFANOUT Mode Select. 0000: SYSFANOUT is in Manual Mode. (Default) 0001: SYSFANOUT is in Thermal Cruise Mode. 0010: SYSFANOUT is in Speed Cruise Mode. 0100: SYSFANOUT is in SMART FAN IV Mode. 7-4 3 Reserved 2-0 Tolerance of SYSFAN Target Temperature or SYSFANIN Target Speed_L. 9.60 SYSFANOUT Step Up Time Register – Index 03h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 0 1 0 SYSFANOUT Value Step Up Time NAME DEFAULT 0 0 0 0 1 TM In SMART FAN mode, this register determines the amount of time SYSFANOUT takes to increase its value by one step. (1) For PWM output: The units are intervals of 0.1 second. The default time is 1 second. (2) For DC output: The units are intervals of 0.4 second. The default time is 4 seconds. 9.61 SYSFANOUT Step Down Time Register – Index 04h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 0 1 0 SYSFANOUT Value Step Down Time NAME DEFAULT 0 0 0 0 1 TM In SMART FAN mode, this register determines the amount of time SYSFANOUT takes to decrease its value by one step. (1) For PWM output: The units are intervals of 0.1 second. The default time is 1 second. (2) For DC output: The units are intervals of 0.4 second. The default time is 4 seconds. 9.62 SYSFANOUT Stop Value Register – Index 05h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 2 1 0 0 0 1 SYSFANOUT Stop Value NAME DEFAULT 4 0 0 0 0 -85 0 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY In Thermal Cruise mode, the SYSFANOUT value decreases to this eight-bit value if the temperature stays below the lowest temperature limit. This value should not be zero. Please note that Stop Value does not mean that the fan really stops. It means that if the temperature keeps below low temperature limit, then the fan speed keeps on decreasing until reaching a minimum value, and this is Stop Value. 9.63 SYSFANOUT Start-up Value Register – Index 06h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 0 0 1 SYSFANOUT Start-Up Value NAME DEFAULT 0 0 0 0 0 In Thermal Cruise mode, SYSFANOUT value increases from zero to this eight-bit register value to provide a minimum value to turn on the fan. This value should not be zero. 9.64 SYSFANOUT Stop Time Register – Index 07h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 1 0 0 SYSFANOUT Value Stop Time NAME DEFAULT 0 0 1 1 1 In Thermal Cruise mode, this register determines the amount of time it takes SYSFANOUT value to fall from the stop value to zero. (1) For PWM output: The units are intervals of 0.1 second. The default time is 1 second. (2) For DC output: The units are intervals of 0.4 second. The default time is 4 seconds. 9.65 Reserved Register – Index 08h (Bank 1) 9.66 SYSFANOUT Output Value Select Register – Index 09h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 NAME DEFAULT 4 3 2 1 0 1 1 1 SYSFANOUT Value 0 1 1 1 1 The default speed of fan output is specified in registers CR[E0h] to CR[E4h] of Logical Device B, CR[E0h] is the Default Speed Configuration Register of SYSFANOUT. -86 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 7 FUNCTION MODE PWM Output (Bank0, Index 04h, bit 0 is 0) 5 4 3 2 1 0 The PWM duty cycle is equal to this eight-bit value, divided by 255, times 100%. FFh creates a duty cycle of 100%, and 00h creates a duty cycle of 0%. DESCRIPTION DC Voltage Output Bank0, Index 04h, bit 0 is 1) 6 SYSFANOUT voltage control. The output voltage is calculated according to this equation. DESCRIPTION OUTPUT Voltage = Vref * Reserved FANOUT 64 Note. VREF is approx 2.048V. 9.67 Reserved Register – Index 0Ah~0Bh (Bank 1) 9.68 SYSFANIN Tolerance_H / Target Speed_H Register – Index 0Ch (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 NAME Reserved SYSFANIN TOL_H SYSFANIN Target Speed_H DEFAULT 0 0 0 6 5 4 BIT 3 2 1 0 DESCRIPTION Reserved 7 6-4 SYSFANIN Tolerance_H [5:3] 3-0 SYSFANIN Target Speed_H [11:8] 9.69 Reserved Register – Index 0Dh~1Fh (Bank 1) 9.70 SMART FAN IV SYSFANOUT STEP Register – Index 20h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 0 BIT 7-1 0 3 2 1 Reserved NAME DEFAULT 4 0 0 0 0 En_SYSFANOUT_STEP 0 0 0 0 DESCRIPTION Reserved En_SYSFANOUT_STEP 0: Disable SMART FAN IV has Stepping SYSFANOUT. (default) 1: Enable SMART FAN IV has Stepping SYSFANOUT. 9.71 SYSFAN (SMART FANTM IV) Temperature 1 Register(T1) – Index 21h (Bank 1) -87 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 TM SYSFAN (SMART FAN NAME DEFAULT 0 0 0 BIT 7-0 4 1 2 1 0 0 1 IV) Temperature 1 1 0 DESCRIPTION TM SYSFAN (SMART FAN IV) Temperature 1 Register (T1). 9.72 SYSFAN (SMART FANTM IV) Temperature 2 Register(T2) – Index 22h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 TM SYSFAN (SMART FAN NAME DEFAULT 0 0 1 BIT 7-0 4 0 2 1 0 1 1 IV) Temperature 2 0 0 DESCRIPTION TM SYSFAN (SMART FAN IV) Temperature 2 Register (T2). 9.73 SYSFAN (SMART FANTM IV) Temperature 3 Register(T3) – Index 23h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 NAME DEFAULT 0 0 1 BIT 7-0 4 3 2 1 0 0 1 SYSFAN (SMART FANTM IV) Temperature 3 0 1 1 DESCRIPTION TM SYSFAN (SMART FAN IV) Temperature 3 Register (T3). 9.74 SYSFAN (SMART FANTM IV) Temperature 4 Register(T4) – Index 24h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 TM SYSFAN (SMART FAN NAME DEFAULT 0 0 1 BIT 7-0 4 1 2 1 0 1 1 IV) Temperature 4 0 1 DESCRIPTION TM SYSFAN (SMART FAN IV) Temperature 4 Register (T4). -88 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.75 Reserved Register – Index 25h~26h (Bank 1) 9.76 SYSFAN (SMART FANTM IV) DC/PWM 1 Register – Index 27h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 TM SYSFAN (SMART FAN NAME DEFAULT 1 0 0 BIT 7-0 4 0 2 1 0 0 0 1 0 1 0 1 0 0 0 1 0 1 0 IV) DC/PWM 1 1 1 DESCRIPTION TM SYSFAN (SMART FAN IV) DC/PWM 1 Register. 9.77 SYSFAN (SMART FANTM IV) DC/PWM 2 Register – Index 28h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 NAME DEFAULT 1 0 1 BIT 7-0 4 3 2 SYSFAN (SMART FANTM IV) DC/PWM 2 0 1 0 DESCRIPTION TM SYSFAN (SMART FAN IV) DC/PWM 2 Register. 9.78 SYSFAN (SMART FANTM IV) DC/PWM 3 Register – Index 29h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 TM SYSFAN (SMART FAN NAME DEFAULT 1 1 0 BIT 7-0 4 0 2 IV) DC/PWM 3 1 0 DESCRIPTION TM SYSFAN (SMART FAN IV) DC/PWM 3 Register. 9.79 SYSFAN (SMART FANTM IV) DC/PWM 4 Register – Index 2Ah (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 4 3 TM SYSFAN (SMART FAN NAME DEFAULT 5 1 1 1 0 -89 2 IV) DC/PWM 4 0 1 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7-0 DESCRIPTION TM SYSFAN (SMART FAN IV) DC/PWM 4 Register. 9.80 Reserved Register – Index 2Bh~30h (Bank 1) 9.81 SYSFAN 3-Wire Enable Register – Index 31h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME Reserved EN_SYS_3WFAN DEFAULT 0 0 BIT 7-1 0 DESCRIPTION Reserved EN_SYS_3WFAN (SYSFAN type setting) 0: 4-wire fan 1: 3-wire fan 9.82 Reserved Register – Index 32h~34h(Bank 1) 9.83 SYSFAN (SMART FANTM IV) Critical Temperature Register – Index 35h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 TM SYSFAN (SMART FAN NAME DEFAULT 0 0 1 BIT 7-0 4 2 1 0 0 0 IV) Temperature Critical 1 1 1 DESCRIPTION TM SYSFAN (SMART FAN IV) Critical Temperature Register. 9.84 SYSFAN Enable Critical Duty – Index 36h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME Reserved En_SYS_CRITICA L_DUTY DEFAULT 0 0 BIT 7-1 DESCRIPTION Reserved -90 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 0 En_SYS_CRITICAL_DUTY 0: Load default Full Speed 8’hFF for SYSFANOUT. 1: Used Index 37 CRITICAL_DUTY Value for SYSFANOUT. 9.85 SYSFAN Critical Duty Register – Index 37h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 NAME SYSFAN Critical Duty DEFAULT CC BIT 1 0 DESCRIPTION 7-0 SYSFAN Critical Duty. 9.86 SYSFANOUT Critical Temperature Tolerance Register – Index 38h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 NAME Reserved DEFAULT 0 4 3 2 1 0 SYSFANOUT Critical Temperature Tolerance 0 BIT 0 0 DESCRIPTION 7-3 Reserved 2-0 SYSFANOUT Critical Temperature Tolerance 9.87 Weight value Configuration Register – Index 39h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 NAME EN_SYSFAN_WEIGHT Reserved DEFAULT 0 0 BIT 7 6-5 4-0 6 5 4 3 2 1 0 SYS_WEIGHT_SEL 0 0 0 0 1 DESCRIPTION EN_SYSFAN_WEIGHT. 0: Disable Weight Value Control for SYSFAN. 1: Enable Weight Value Control for SYSFAN. Reserved SYSFAN Weighting Temperature Source Select: Bits 43210 0 0 0 0 1: Select SYSTIN as SYSFAN monitoring source. (Default) -91 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT DESCRIPTION 0 0 0 1 0: Select CPUTIN as SYSFAN monitoring source. 0 0 0 1 1: Select AUXTIN0 as SYSFAN monitoring source. 0 0 1 0 0: Select AUXTIN1 as SYSFAN monitoring source. 0 0 1 0 1: Select AUXTIN2 as SYSFAN monitoring source. 0 0 1 1 0: Select VTIN0 as SYSFAN monitoring source. 0 0 1 1 1: Reserved. 0 1 0 0 0: Select SMBUSMASTER 0 as SYSFAN monitoring source. 0 1 0 0 1: Select SMBUSMASTER 1 as SYSFAN monitoring source. 0 1 0 1 0: Select SMBUSMASTER 2 as SYSFAN monitoring source. 0 1 0 1 1: Select SMBUSMASTER 3 as SYSFAN monitoring source. 0 1 1 0 0: Select SMBUSMASTER 4 as SYSFAN monitoring source. 0 1 1 0 1: Select SMBUSMASTER 5 as SYSFAN monitoring source. 0 1 1 1 0: Select SMBUSMASTER 6 as SYSFAN monitoring source. 0 1 1 1 1: Select SMBUSMASTER 7 as SYSFAN monitoring source. 1 0 0 0 0: Select PECI Agent 0 as SYSFAN monitoring source. 1 0 0 0 1: Select PECI Agent 1 as SYSFAN monitoring source. 1 0 0 1 0: Select PCH_CHIP_CPU_MAX_TEMP as SYSFAN monitoring source. 1 0 0 1 1: Select PCH_CHIP_TEMP as SYSFAN monitoring source. 1 0 1 0 0: Select PCH_CPU_TEMP as SYSFAN monitoring source. 1 0 1 0 1: Select PCH_MCH_TEMP as SYSFAN monitoring source. 1 0 1 1 0: Select PCH_DIM0_TEMP as SYSFAN monitoring source. 1 0 1 1 1: Select PCH_DIM1_TEMP as SYSFAN monitoring source. 1 1 0 0 0: Select PCH_DIM2_TEMP as SYSFAN monitoring source. 1 1 0 0 1: Select PCH_DIM3_TEMP as SYSFAN monitoring source. 1 1 0 1 0: Select BYTE_TEMP as SYSFAN monitoring source. 9.88 SYSFANOUT Temperature Step Register – Index 3Ah (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 NAME SYSFANOUT Temperature Step (SYS_TEMP_STEP) DEFAULT 0 BIT 7-0 1 0 DESCRIPTION SYSFANOUT Temperature Step 9.89 SYSFANOUT Temperature Step Tolerance Register – Index 3Bh (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 NAME SYSFANOUT Temperature Step Tolerance (SYS_TEMP_STEP_TOL) DEFAULT 0 -92 0 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7-0 DESCRIPTION SYSFANOUT Temperature Step Tolerance 9.90 SYSFANOUT Weight Step Register – Index 3Ch (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 NAME SYSFANOUT Weight Step (SYS_WEIGHT_STEP) DEFAULT 0 BIT 7-0 1 0 1 0 DESCRIPTION SYSFANOUT Weight Step 9.91 SYSFANOUT Temperature Base Register – Index 3Dh (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 NAME SYSFANOUT Temperature Base (SYS_TEMP_BASE) DEFAULT 0 BIT 7-0 DESCRIPTION SYSFANOUT Temperature Base 9.92 SYSFANOUT Temperature Fan Duty Base Register – index 3Eh (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 NAME SYSFANOUT Temperature Base (SYS_FC_BASE) DEFAULT 0 BIT 7-0 0 DESCRIPTION SYSFANOUT Start point of Fan Duty increasing 9.93 SYSFAN PECIERR DUTY Enable Register – Index 3Fh (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 NAME Reserved DEFAULT 0 3 2 1 0 EN_SYS_PECIERR_DUTY 0 -93 0 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7-2 1-0 DESCRIPTION Reserved EN_SYS_PECIERR_DUTY 00: Disable PECIERR DUTY FANOUT (default) 01: Enable PECIERR DUTY FANOUT, Used Index 41 PECI_ERR_SYSOUT Value for SYSFANOUT. 10,11: Keep Full Speed 9.94 Reserved Register – Index 40h (Bank 1) 9.95 SYSFANOUT Pre-Configured Register For PECI Error – Index 41h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 2 1 0 SYSFANOUT pre-configured register for PECI error (PECI_ERR_SYSOUT) NAME DEFAULT 1 1 1 BIT 7-0 4 1 1 1 1 1 DESCRIPTION SYSFANOUT pre-configured register for PECI error. 9.96 Reserved Register – Index 42h ~ 4Fh (Bank 1) 9.97 SMIOVT2 Temperature Source (High Byte) Register – Index 50h (Bank 1) Attribute: Size: Read Only 8 bits BIT 7 6 5 4 3 2 1 0 TEMP NAME BIT DESCRIPTION 7-0 Temperature (default: CPUTIN temperature source). The nine-bit value is in units of 0.5℃. 9.98 SMIOVT2 Temperature Source (Low Byte) Register – Index 51h (Bank 1) Attribute: Size: Read Only 8 bits BIT 7 NAME TEMP 6 5 4 3 2 1 0 RESERVED BIT DESCRIPTION 7 Temperature (default: CPUTIN temperature source). The nine-bit value is in units of 0.5°C. 6-0 Reserved. -94 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.99 SMIOVT2 Temperature Source Configuration Register – Index 52h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 RESERVED NAME DEFAULT 0 0 FAULT 0 BIT 0 0 2 1 0 RESERVED OVTMOD STOP 0 0 0 DESCRIPTION 7-5 Reserved. This bit should be set to zero. 4-3 Fault. Number of faults to detect before setting OVT# output. This avoids false strapping due to noise. 2 Reserved. This bit should be set to zero. 1 OVTMOD. SMIOVT2 Mode Select. 0 : Compare Mode. (Default) 1: Interrupt Mode. 0 STOP. 0: Monitor SMIOVT2 temperature source. 1: Stop monitoring SMIOVT2 temperature source. 9.100 SMIOVT2 Temperature Source Hysteresis (High Byte) Register – Index 53h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 DEFAULT 7-0 2 1 0 0 1 1 THYST NAME BIT 3 0 1 0 0 1 DESCRIPTION THYST. Hysteresis temperature bits 8-1. The nine-bit value is in units of 0.5°C, and the default is 75°C. 9.101 SMIOVT2 Temperature Source Hysteresis (Low Byte) Register – Index 54h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 NAME THYST DEFAULT 0 BIT 7 6-0 6 5 4 3 2 1 0 0 0 0 RESERVED 0 0 0 0 DESCRIPTION THYST. Hysteresis temperature bit 0. The nine-bit value is in units of 0.5°C. Reserved. -95 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.102 SMIOVT2 Temperature Source Over-temperature (High Byte) Register – Index 55h (Bank1) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 0 0 0 0 TOVF NAME DEFAULT 0 1 0 1 BIT DESCRIPTION 7-0 TOVF.° Over-temperature bits 8-1. The nine-bit value is in units of 0.5°C, and the default is 80 C. 9.103 SMIOVT2 Temperature Source Over-temperature (Low Byte) Register – Index 56h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 NAME TOVF DEFAULT 0 6 5 6-0 3 2 1 0 0 0 0 RESERVED 0 0 BIT 7 4 0 0 DESCRIPTION TOVF. Over-temperature bit 0. The nine-bit value is in units of 0.5°C. Reserved. 9.104 Reserved Register – Index 57h ~ FFh (Bank 1) 9.105 CPUFAN Monitor Temperature Source Select Register/ STOPDUTY Enable Register – Index 00h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 NAME Stopduty_En DEFAULT 0 BIT 7 6 5 4 Reserved 0 3 2 1 0 CPUFAN SOURCE[4:0] 0 0 0 0 1 0 DESCRIPTION Stopduty_En: 0: FANOUT will decrease to zero value at most if necessary. 1: FANOUT will decrease to CPUFANOUT Stop Value (Bank2, index05h) at most if necessary. (This function is for Thermal Cruise mode.) -96 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT DESCRIPTION 6-5 Reserved 4-0 CPUFAN Temperature Source Select: Bits 43210 0 0 0 0 1: Select SYSTIN as SYSFAN monitoring source. (Default) 0 0 0 1 0: Select CPUTIN as SYSFAN monitoring source. 0 0 0 1 1: Select AUXTIN0 as SYSFAN monitoring source. 0 0 1 0 0: Select AUXTIN1 as SYSFAN monitoring source. 0 0 1 0 1: Select AUXTIN2 as SYSFAN monitoring source. 0 0 1 1 0: Select VTIN0 as SYSFAN monitoring source. 0 0 1 1 1: Reserved. 0 1 0 0 0: Select SMBUSMASTER 0 as SYSFAN monitoring source. 0 1 0 0 1: Select SMBUSMASTER 1 as SYSFAN monitoring source. 0 1 0 1 0: Select SMBUSMASTER 2 as SYSFAN monitoring source. 0 1 0 1 1: Select SMBUSMASTER 3 as SYSFAN monitoring source. 0 1 1 0 0: Select SMBUSMASTER 4 as SYSFAN monitoring source. 0 1 1 0 1: Select SMBUSMASTER 5 as SYSFAN monitoring source. 0 1 1 1 0: Select SMBUSMASTER 6 as SYSFAN monitoring source. 0 1 1 1 1: Select SMBUSMASTER 7 as SYSFAN monitoring source. 1 0 0 0 0: Select PECI Agent 0 as SYSFAN monitoring source. 1 0 0 0 1: Select PECI Agent 1 as SYSFAN monitoring source. 1 0 0 1 0: Select PCH_CHIP_CPU_MAX_TEMP as SYSFAN monitoring source. 1 0 0 1 1: Select PCH_CHIP_TEMP as SYSFAN monitoring source. 1 0 1 0 0: Select PCH_CPU_TEMP as SYSFAN monitoring source. 1 0 1 0 1: Select PCH_MCH_TEMP as SYSFAN monitoring source. 1 0 1 1 0: Select PCH_DIM0_TEMP as SYSFAN monitoring source. 1 0 1 1 1: Select PCH_DIM1_TEMP as SYSFAN monitoring source. 1 1 0 0 0: Select PCH_DIM2_TEMP as SYSFAN monitoring source. 1 1 0 0 1: Select PCH_DIM3_TEMP as SYSFAN monitoring source. 1 1 0 1 0: Select BYTE_TEMP as SYSFAN monitoring source. Note. If the temperature source is selecting to PECI, please set Bank0 Index AEh first for reading correct value. 9.106 CPUFAN Target Temperature Register / CPUFANIN Target Speed_L Register – Index 01h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 0 0 CPUTIN Target Temperature / CPUFANIN Target Speed_L NAME DEFAULT 0 0 Thermal Cruise TM Fan Speed Cruise 0 7 FUNCTION MODE TM 0 0 6 5 0 4 3 2 DESCRIPTION CPUFAN Target Temperature DESCRIPTION CPUFANIN Target Speed [7:0], [11:8] associate index 0C [3:0] -97 1 0 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.107 CPUFAN MODE Register / CPUFAN TOLERRANCE Register – Index 02h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 CPUFAN MODE NAME DEFAULT 0 0 0 BIT 3 2 Reserved 0 1 0 Tolerance of CPUFAN Target Temperature or CPUFANIN Target Speed_L 0 0 1 0 DESCRIPTION CPUFANOUT Mode Select. 0000: CPUFANOUT is in Manual Mode. (Default) 0001: CPUFANOUT is in Thermal Cruise Mode. 0010: CPUFANOUT is in Speed Cruise Mode. 0100: CPUFANOUT is in SMART FAN IV Mode. 7-4 3 Reserved 2-0 Tolerance of CPUFAN Target Temperature or CPUFANIN Target Speed_L. 9.108 CPUFANOUT Step Up Time Register – Index 03h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 0 1 0 CPUFANOUT Value Step Up Time NAME DEFAULT 0 0 0 0 1 TM In SMART FAN mode, this register determines the amount of time CPUFANOUT takes to increase its value by one step. (1) For PWM output: The units are intervals of 0.1 second. The default time is 1 second. 9.109 CPUFANOUT Step Down Time Register – Index 04h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 NAME DEFAULT 4 3 2 1 0 0 1 0 CPUFANOUT Value Step Down Time 0 0 0 0 1 TM In SMART FAN mode, this register determines the amount of time CPUFANOUT takes to decrease its value by one step. (1) For PWM output: The units are intervals of 0.1 second. The default time is 1 second. -98 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.110 CPUFANOUT Stop Value Register – Index 05h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 0 0 1 CPUFANOUT Stop Value NAME DEFAULT 0 0 0 0 0 In Thermal Cruise mode, the CPUFANOUT value decreases to this eight-bit value if the temperature stays below the lowest temperature limit. This value should not be zero. Please note that Stop Value does not mean that the fan really stops. It means that if the temperature keeps below low temperature limit, then the fan speed keeps on decreasing until reaching a minimum value, and this is Stop Value. 9.111 CPUFANOUT Start-up Value Register – Index 06h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 0 0 1 CPUFANOUT Start-Up Value NAME DEFAULT 0 0 0 0 0 In Thermal Cruise mode, CPUFANOUT value increases from zero to this eight-bit register value to provide a minimum value to turn on the fan. This value should not be zero. 9.112 CPUFANOUT Stop Time Register – Index 07h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 1 0 0 CPUFANOUT Value Stop Time NAME DEFAULT 0 0 1 1 1 In Thermal Cruise mode, this register determines the amount of time it takes CPUFANOUT value to fall from the stop value to zero. (1) For PWM output: The units are intervals of 0.1 second. The default time is 1 second. 9.113 Reserved Register – Index 08h (Bank 2) 9.114 CPUFANOUT Output Value Select Register – Index 09h (Bank 2) Attribute: Size: Read/Write 8 bits BIT NAME 7 6 5 4 3 2 1 0 CPUFANOUT Value -99 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY DEFAULT 0 1 1 1 1 1 1 1 The default speed of fan output is specified in registers CR[E0h] to CR[E4h] of Logical Device B, CR[E1h] is the Default Speed Configuration Register of CPUFANOUT. 7 FUNCTION MODE PWM Output Only 6 5 4 3 2 1 0 The PWM duty cycle is equal to this eight-bit value, divided by 255, times 100%. FFh creates a duty cycle of 100%, and 00h creates a duty cycle of 0%. DESCRIPTION 9.115 Reserved Register – Index 0Ah~0Bh (Bank 2) 9.116 CPUFANIN Tolerance_H / Target Speed_H Register – Index 0Ch (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 NAME Reserved CPUFANIN TOL_H CPUFANIN Target Speed_H DEFAULT 0 0 0 6 5 4 BIT 3 2 1 0 DESCRIPTION Reserved 7 6-4 CPUFANIN Tolerance_H [5:3] 3-0 CPUFANIN Target Speed_H [11:8] 9.117 Reserved Register – Index 0Dh~1Fh (Bank 2) 9.118 SMART FAN IV CPUFANOUT STEP Register – Index 20h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 0 BIT 7-1 0 3 2 1 Reserved NAME DEFAULT 4 0 0 0 0 En_CPUFANOUT_STEP 0 0 0 0 DESCRIPTION Reserved En_CPUFANOUT_STEP 0: Disable SMART FAN IV has Stepping CPUFANOUT. (default) 1: Enable SMART FAN IV has Stepping CPUFANOUT. 9.119 CPUFAN (SMART FANTM IV) Temperature 1 Register(T1) – Index 21h (Bank 2) -100 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 TM CPUFAN (SMART FAN NAME DEFAULT 0 0 1 BIT 7-0 4 0 2 1 0 0 0 IV) Temperature 1 1 0 DESCRIPTION TM CPUFAN (SMART FAN IV) Temperature 1 Register (T1). 9.120 CPUFAN (SMART FANTM IV) Temperature 2 Register(T2) – Index 22h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 TM CPUFAN (SMART FAN NAME DEFAULT 0 0 1 BIT 7-0 4 1 2 1 0 1 0 IV) Temperature 2 0 0 DESCRIPTION TM CPUFAN (SMART FAN IV) Temperature 2 Register (T2). 9.121 CPUFAN (SMART FANTM IV) Temperature 3 Register(T3) – Index 23h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 NAME DEFAULT 0 0 1 BIT 7-0 4 3 2 1 0 0 0 CPUFAN (SMART FANTM IV) Temperature 3 1 1 1 DESCRIPTION TM CPUFAN (SMART FAN IV) Temperature 3 Register (T3). 9.122 CPUFAN (SMART FANTM IV) Temperature 4 Register(T4) – Index 24h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 TM CPUFAN (SMART FAN NAME DEFAULT 0 1 0 BIT 7-0 4 0 2 1 0 1 0 IV) Temperature 4 0 1 DESCRIPTION TM CPUFAN (SMART FAN IV) Temperature 4 Register (T4). -101 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.123 Reserved Register – Index 25h~26h (Bank 2) 9.124 CPUFAN (SMART FANTM IV) PWM1 Register – Index 27h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 TM CPUFAN (SMART FAN NAME DEFAULT 1 0 0 BIT 7-0 4 0 2 1 0 1 0 0 2 1 0 0 1 0 2 1 0 0 0 0 2 1 0 1 1 0 IV) PWM 1 1 DESCRIPTION TM CPUFAN (SMART FAN IV) PWM1 Register. 9.125 CPUFAN (SMART FANTM IV) PWM2 Register – Index 28h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 NAME DEFAULT 1 0 1 BIT 7-0 4 3 CPUFAN (SMART FANTM IV) PWM 2 0 1 DESCRIPTION TM CPUFAN (SMART FAN IV) PWM2 Register. 9.126 CPUFAN (SMART FANTM IV) PWM3 Register – Index 29h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 TM CPUFAN (SMART FAN NAME DEFAULT 1 1 0 BIT 7-0 4 0 IV) PWM 3 1 DESCRIPTION TM CPUFAN (SMART FAN IV) PWM3 Register. 9.127 CPUFAN (SMART FANTM IV) PWM4 Register – Index 2Ah (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 TM CPUFAN (SMART FAN NAME DEFAULT 4 1 1 1 0 -102 0 IV) PWM4 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7-0 DESCRIPTION TM CPUFAN (SMART FAN IV) PWM4 Register. 9.128 Reserved Register – Index 2Bh~30h (Bank 2) 9.129 CPUFAN 3-Wire FAN Enable Register – Index 31h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME Reserved EN_CPU_3WFA N DEFAULT 0 0 BIT 7-1 0 DESCRIPTION Reserved EN_CPU_3WFAN (CPUFAN type setting) 0: 4-wire fan 1: 3-wire fan 9.130 Reserved Register – Index 32h ~ 34h(Bank 2) 9.131 CPUFAN (SMART FANTM IV) Critical Temperature Register – Index 35h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 TM CPUFAN (SMART FAN NAME DEFAULT 0 1 0 BIT 7-0 4 2 1 0 1 1 IV) Temperature Critical 0 1 0 DESCRIPTION TM CPUFAN (SMART FAN IV) Critical Temperature Register. 9.132 CPUFAN Enable Critical Duty – Index 36h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME Reserved En_CPU_CRITICA L_DUTY DEFAULT 0 0 BIT DESCRIPTION -103 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 7-1 Reserved 0 En_CPU_CRITICAL_DUTY 0: Load default Full Speed 8’hFF for CPUFANOUT. 1: Used Index 37 CRITICAL_DUTY Value for CPUFANOUT. 9.133 CPUFAN Critical Duty Register – Index 37h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 NAME CPUFAN Critical Duty DEFAULT CC BIT 1 0 DESCRIPTION 7-0 CPUFAN Critical Duty. 9.134 CPUFANOUT Critical Temperature Tolerance Register – Index 38h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 NAME Reserved DEFAULT 0 4 3 2 1 0 CPUFANOUT Critical Temperature Tolerance 0 BIT 0 0 DESCRIPTION 7-3 Reserved 2-0 CPUFANOUT Critical Temperature Tolerance 9.135 Weight value Configuration Register – Index 39h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 NAME EN_CPUFAN_ WEIGHT Reserved DEFAULT 0 0 BIT 7 6-5 4-0 6 5 4 3 2 1 0 CPU_WEIGHT_SEL 0 0 0 0 1 DESCRIPTION EN_CPUFAN_WEIGHT. 0: Disable Weight Value Control for CPUFAN. 1: Enable Weight Value Control for CPUFAN. Reserved CPUFAN Weighting Temperature Source Select: Bits -104 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT DESCRIPTION 43210 0 0 0 0 1: Select SYSTIN as SYSFAN monitoring source. (Default) 0 0 0 1 0: Select CPUTIN as SYSFAN monitoring source. 0 0 0 1 1: Select AUXTIN0 as SYSFAN monitoring source. 0 0 1 0 0: Select AUXTIN1 as SYSFAN monitoring source. 0 0 1 0 1: Select AUXTIN2 as SYSFAN monitoring source. 0 0 1 1 0: Select VTIN0 as SYSFAN monitoring source. 0 0 1 1 1: Reserved. 0 1 0 0 0: Select SMBUSMASTER 0 as SYSFAN monitoring source. 0 1 0 0 1: Select SMBUSMASTER 1 as SYSFAN monitoring source. 0 1 0 1 0: Select SMBUSMASTER 2 as SYSFAN monitoring source. 0 1 0 1 1: Select SMBUSMASTER 3 as SYSFAN monitoring source. 0 1 1 0 0: Select SMBUSMASTER 4 as SYSFAN monitoring source. 0 1 1 0 1: Select SMBUSMASTER 5 as SYSFAN monitoring source. 0 1 1 1 0: Select SMBUSMASTER 6 as SYSFAN monitoring source. 0 1 1 1 1: Select SMBUSMASTER 7 as SYSFAN monitoring source. 1 0 0 0 0: Select PECI Agent 0 as SYSFAN monitoring source. 1 0 0 0 1: Select PECI Agent 1 as SYSFAN monitoring source. 1 0 0 1 0: Select PCH_CHIP_CPU_MAX_TEMP as SYSFAN monitoring source. 1 0 0 1 1: Select PCH_CHIP_TEMP as SYSFAN monitoring source. 1 0 1 0 0: Select PCH_CPU_TEMP as SYSFAN monitoring source. 1 0 1 0 1: Select PCH_MCH_TEMP as SYSFAN monitoring source. 1 0 1 1 0: Select PCH_DIM0_TEMP as SYSFAN monitoring source. 1 0 1 1 1: Select PCH_DIM1_TEMP as SYSFAN monitoring source. 1 1 0 0 0: Select PCH_DIM2_TEMP as SYSFAN monitoring source. 1 1 0 0 1: Select PCH_DIM3_TEMP as SYSFAN monitoring source. 1 1 0 1 0: Select BYTE_TEMP as SYSFAN monitoring source. 9.136 CPUFANOUT Temperature Step Register – Index 3Ah (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 BIT CPUFANOUT Temperature Step (CPU_TEMP_STEP) DEFAULT 0 BIT 7-0 1 0 DESCRIPTION CPUFANOUT Temperature Step 9.137 CPUFANOUT Temperature Step Tolerance Register – Index 3Bh (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 BIT CPUFANOUT Temperature Step Tolerance (CPU_TEMP_STEP_TOL) DEFAULT 0 -105 0 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7-0 DESCRIPTION CPUFANOUT Temperature Step Tolerance 9.138 CPUFANOUT Weight Step Register – Index 3Ch (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 BIT CPUFANOUT Weight Step (CPU_WEIGHT_STEP) DEFAULT 0 BIT 7-0 1 0 1 0 DESCRIPTION CPUFANOUT Weight Step 9.139 CPUFANOUT Temperature Base Register – Index 3Dh (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 NAME CPUFANOUT Temperature Base (CPU_TEMP_BASE) DEFAULT 0 BIT 7-0 DESCRIPTION CPUFANOUT Temperature Base 9.140 CPUFANOUT Temperature Fan Duty Base Register – Index 3Eh (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 NAME CPUFANOUT Temperature Base (CPU_FC_BASE) DEFAULT 0 BIT 7-0 0 DESCRIPTION CPUFANOUT Start point of Fan Duty increasing 9.141 CPUFAN PECIERR DUTY Enable Register – Index 3Fh (Bank 2) Attribute: Size: Read/Write 8 bits BIT NAME 7 6 5 4 3 Reserved 2 1 0 EN_CPU_PECIERR_DUTY -106 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY DEFAULT 0 BIT 7-2 1-0 0 0 DESCRIPTION Reserved EN_CPU_PECIERR_DUTY 00: Disable PECIERR DUTY FANOUT (default) 01: Enable PECIERR DUTY FANOUT, Used Index 41 PECI_ERR_CPUOUT Value for CPUFANOUT. 10,11: Keep Full Speed 9.142 Reserved Register – Index 40h (Bank 2) 9.143 CPUFANOUT Pre-Configured Register For PECI Error – Index 41h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 DEFAULT 7-0 5 4 3 2 1 0 CPUFANOUT pre-configured register for PECI error (PECI_ERR_CPUOUT) NAME BIT 6 1 1 1 1 1 1 1 1 DESCRIPTION CPUFANOUT pre-configured register for PECI error. 9.144 Reserved Register – Index 42h ~ FFh (Bank 1) 9.145 Reserved Register – Index 00h (Bank 3) 9.146 Reserved Register – Index 01h (Bank 3) 9.147 Reserved Register – Index 02h (Bank 3) 9.148 Reserved Register – Index 03h (Bank 3) 9.149 Reserved Register – Index 04h (Bank 3) 9.150 Reserved Register – Index 05h (Bank 3) 9.151 Reserved Register – Index 06h (Bank 3) 9.152 Reserved Register – Index 07h (Bank 3) 9.153 Reserved Register – Index 08h (Bank 3) 9.154 Reserved Register – Index 09h (Bank 3) -107 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.155 Reserved Register – Index 0Ch (Bank 3) 9.156 Reserved Register – Index 0Dh (Bank 3) 9.157 Reserved Register – Index 20h (Bank 3) 9.158 Reserved Register – Index 21h (Bank 3) 9.159 Reserved Register – Index 22h (Bank 3) 9.160 Reserved Register – Index 23h (Bank 3) 9.161 Reserved Register – Index 24h (Bank 3) 9.162 Reserved Register – Index 25h~26h (Bank 3) 9.163 Reserved Register – Index 27h (Bank 3) 9.164 Reserved Register – Index 28h (Bank 3) 9.165 Reserved Register – Index 29h (Bank 3) 9.166 Reserved Register – Index 2Ah (Bank 3) 9.167 Reserved Register – Index Index 2Bh~30h (Bank 3) 9.168 Reserved Register – Index 31h (Bank 3) 9.169 Reserved Register – Index 32h~34h(Bank 3) 9.170 Reserved Register – Index 35h (Bank 3) 9.171 Reserved Register – Index 36h (Bank 3) 9.172 Reserved Register – Index 37h (Bank 3) 9.173 Reserved Register – Index 38h (Bank 3) 9.174 Reserved Register – Index 39h (Bank 3) 9.175 Reserved Register – Index 3Ah (Bank 3) -108 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.176 Reserved Register – Index 3Bh (Bank 3) 9.177 Reserved Register – Index 3Ch (Bank 3) 9.178 Reserved Register – Index 3Dh (Bank 3) 9.179 Reserved Register – Index 3Eh (Bank 3) 9.180 Reserved Register – Index 3Fh (Bank 3) 9.181 Reserved Register – Index 40h (Bank 3) 9.182 Reserved Register – Index 41h (Bank 3) 9.183 Reserved Register – Index 42h ~ FFh (Bank 3) 9.184 PCH_CHIP_CPU_MAX_TEMP Register – Index 00h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 NAME DEFAULT 0 0 0 BIT 7-0 4 3 2 1 0 0 0 0 PCH_CHIP_CPU_MAX_TEMP 0 0 DESCRIPTION PCH_CHIP_CPU_MAX_TEMP: The maximum temperature in absolute degree C, of the CPU and MCH. 9.185 PCH_CHIP_TEMP Register – Index 01h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 NAME DEFAULT 0 0 BIT 7-0 4 3 2 1 0 0 0 0 PCH_CHIP_TEMP 0 0 0 DESCRIPTION PCH_CHIP_TEMP The IBX_CHIP temperature in degree C. 9.186 PCH_CPU_TEMP_H Register – Index 02h (Bank 4) Attribute: Size: Read 8 bits -109 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7 6 5 3 2 1 0 0 0 0 1 0 PCH_CPU_TEMP_H NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 DESCRIPTION PCH_CPU_TEMP_H The CPU temperature in degree C. (Integer Part) 9.187 PCH_CPU_TEMP_L Register – Index 03h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 2 Reserved Reading _Flag DEFAULT 0 0 0 BIT 0 3 PCH_CPU_TEMP_L NAME 7-2 1 4 0 0 0 0 0 DESCRIPTION PCH_CPU_TEMP_L The CPU temperature in degree C. (Fractional Part) Reserved Reading_Flag: If there is an error when the IBX read the data from the CPU, then Bit0 is set to ‘1’. 9.188 PCH_MCH_TEMP Register – Index 04h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 3 2 1 0 0 0 0 2 1 0 0 0 0 PCH_MCH_TEMP NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 DESCRIPTION PCH_MCH_TEMP The MCH temperature in degree C. 9.189 PCH_DIM0_TEMP Register – Index 05h (Bank 4) Attribute: Size: BIT Read 8 bits 7 6 5 BIT 3 PCH_DIM0_TEMP NAME DEFAULT 4 0 0 0 0 0 DESCRIPTION -110 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7-0 DESCRIPTION PCH_DIM0_TEMP The DIM0 temperature in degree C. 9.190 PCH_DIM1_TEMP Register – Index 06h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 3 2 1 0 0 0 0 2 1 0 0 0 0 2 1 0 0 0 0 2 1 0 0 0 0 PCH_DIM1_TEMP NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 DESCRIPTION PCH_DIM1_TEMP The DIM1 temperature in degree C. 9.191 PCH_DIM2_TEMP Register – Index 07h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 NAME DEFAULT 0 0 0 BIT 7-0 4 3 PCH_DIM2_TEMP 0 0 DESCRIPTION PCH_DIM2_TEMP The DIM2 temperature in degree C. 9.192 PCH_DIM3_TEMP Register – Index 08h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 NAME DEFAULT 0 0 0 BIT 7-0 4 3 PCH_DIM3_TEMP 0 0 DESCRIPTION PCH_DIM3_TEMP The DIM3 temperature in degree C. 9.193 PCH_TSI0_TEMP_H Register – Index 09h (Bank 4) Attribute: Size: BIT Read 8 bits 7 6 5 3 PCH_TSI0_TEMP_H NAME DEFAULT 4 0 0 0 0 0 -111 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7-0 DESCRIPTION PCH_TSI0_TEMP_H The TSI High-Byte temperature in degree C. 9.194 PCH_TSI0_TEMP_L Register – Index 0Ah (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 DEFAULT 0 0 2 1 0 0 0 2 1 0 0 0 0 1 0 0 0 Reserved 0 BIT 4-0 3 PCH_TSI0_TEMP_L NAME 7-5 4 0 0 0 DESCRIPTION PCH_TSI0_TEMP_L Reserved The TSI Low-Byte temperature in degree C. 9.195 PCH_TSI1_TEMP_H Register – Index 0Bh (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 3 PCH_TSI1_TEMP_H NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 DESCRIPTION PCH_TSI1_TEMP_H The TSI High-Byte temperature in degree C. 9.196 PCH_TSI1_TEMP_L Register – Index 0Ch (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 DEFAULT 0 0 BIT 4-0 4 3 PCH_TSI1_TEMP_L NAME 7-5 5 2 Reserved 0 0 0 0 DESCRIPTION PCH_TSI1_TEMP_L Reserved The TSI Low-Byte temperature in degree C. 9.197 PCH_TSI2_TEMP_H Register – Index 0Dh (Bank 4) Attribute: Size: Read 8 bits -112 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7 6 5 3 2 1 0 0 0 0 1 0 0 0 2 1 0 0 0 0 1 0 0 0 PCH_TSI2_TEMP_H NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 DESCRIPTION PCH_TSI2_TEMP_H The TSI High-Byte temperature in degree C. 9.198 PCH_TSI2_TEMP_L Register – Index 0Eh (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 DEFAULT 0 0 2 Reserved 0 BIT 4-0 3 PCH_TSI2_TEMP_L NAME 7-5 4 0 0 0 DESCRIPTION PCH_TSI2_TEMP_L Reserved The TSI Low-Byte temperature in degree C. 9.199 PCH_TSI3_TEMP_H Register – Index 0Fh (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 3 PCH_TSI3_TEMP_H NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 DESCRIPTION PCH_TSI3_TEMP_H The TSI High-Byte temperature in degree C. 9.200 PCH_TSI3_TEMP_L Register – Index 10h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 DEFAULT 0 0 BIT 4-0 4 3 PCH_TSI3_TEMP_L NAME 7-5 5 2 Reserved 0 0 0 0 DESCRIPTION PCH_TSI3_TEMP_L Reserved The TSI Low-Byte temperature in degree C. -113 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.201 PCH_TSI4_TEMP_H Register – Index 11h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 3 2 1 0 0 0 0 1 0 0 0 2 1 0 0 0 0 1 0 0 0 PCH_TSI4_TEMP_H NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 DESCRIPTION PCH_TSI4_TEMP_H The TSI High-Byte temperature in degree C. 9.202 PCH_TSI4_TEMP_L Register – Index 12h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 DEFAULT 0 0 2 Reserved 0 BIT 4-0 3 PCH_TSI4_TEMP_L NAME 7-5 4 0 0 0 DESCRIPTION PCH_TSI4_TEMP_L Reserved The TSI Low-Byte temperature in degree C. 9.203 PCH_TSI5_TEMP_H Register – Index 13h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 3 PCH_TSI5_TEMP_H NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 DESCRIPTION PCH_TSI5_TEMP_H The TSI High-Byte temperature in degree C. 9.204 PCH_TSI5_TEMP_L Register – Index 14h (Bank 4) Attribute: Size: BIT Read 8 bits 7 BIT 5 4 3 PCH_TSI5_TEMP_L NAME DEFAULT 6 0 0 2 Reserved 0 0 0 0 DESCRIPTION -114 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7-5 4-0 DESCRIPTION PCH_TSI5_TEMP_L Reserved The TSI Low-Byte temperature in degree C. 9.205 PCH_TSI6_TEMP_H Register – Index 15h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 3 2 1 0 0 0 0 1 0 0 0 2 1 0 0 0 0 1 0 PCH_TSI6_TEMP_H NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 DESCRIPTION PCH_TSI6_TEMP_H The TSI High-Byte temperature in degree C. 9.206 PCH_TSI6_TEMP_L Register – Index 16h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 NAME DEFAULT 4-0 3 0 0 2 Reserved 0 BIT 7-5 4 PCH_TSI6_TEMP_L 0 0 0 DESCRIPTION PCH_TSI6_TEMP_L Reserved The TSI Low-Byte temperature in degree C. 9.207 PCH_TSI7_TEMP_H Register – Index 17h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 3 PCH_TSI7_TEMP_H NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 DESCRIPTION PCH_TSI7_TEMP_H The TSI High-Byte temperature in degree C. 9.208 PCH_TSI7_TEMP_L Register – Index 18h (Bank 4) Attribute: Size: BIT Read 8 bits 7 6 5 4 3 -115 2 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY PCH_TSI7_TEMP_L NAME DEFAULT 0 0 Reserved 0 BIT 7-5 4-0 0 0 0 0 0 2 1 0 0 0 0 2 1 0 0 0 0 DESCRIPTION PCH_TSI7_TEMP_L Reserved The TSI Low-Byte temperature in degree C. 9.209 ByteTemp_H Register – Index 19h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 3 ByteTemp_H NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 DESCRIPTION ByteTemp_H The TSI Byte format High-Byte temperature in degree C. 9.210 ByteTemp_L Register – Index 1Ah (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 3 ByteTemp_L NAME DEFAULT 0 0 BIT 7-0 4 0 0 0 DESCRIPTION ByteTemp_L The TSI Byte format Low-Byte temperature in degree C. 9.211 Reserved Register – Index 1Bh ~ 22h (Bank 4) 9.212 Reserved Register – Index 23h (Bank 4) 9.213 Reserved Register – Index 24h (Bank 4) 9.214 Reserved Register – Index 25h (Bank 4) 9.215 Reserved Register – Index 26h (Bank 4) 9.216 AVCC High Limit Compared Voltage Register – Index 27h (Bank 4) Attribute: Size: Read/Write 8 bits -116 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7 6 5 3 2 1 0 0 1 1 0 1 0 AVCC High Limit Compared Voltage (AVCC _LimtH) NAME DEFAULT 1 1 1 BIT 7-0 4 0 0 0 DESCRIPTION AVCC High Limit Compared Voltage. Default: 0xE1h (1.8V *2) 9.217 AVCC Low Limit Compared Voltage Register – Index 28h (Bank 4) Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 2 AVCC Low Limit Compared Voltage (AVCC_LimtH) NAME DEFAULT 1 0 0 BIT 7-0 4 1 0 1 DESCRIPTION AVCC Low Limit Compared Voltage (AVCC_LimtH). Default: 0x96h (1.2V *2) 9.218 Reserved Register – Index 29h ~ 41h (Bank 4) 9.219 Voltage Comparation Interrupt Status Register - Index 42h (Bank 4) Attribute: Size: Read Only 8 bits BIT 7 6 NAME 0 BIT 2 1-0 4 3 RESERVED DEFAULT 7-3 5 0 0 0 0 2 1 0 AVCC_Warn Reserved Reserved 0 0 0 DESCRIPTION Reserved AVCC_Warn. A one indicates the limit of AVCC voltage has been exceeded. Reserved 9.220 Reserved Register – Index 43h ~ 49h (Bank 4) 9.221 Reserved Register – Index 4Ah (Bank 4) 9.222 Reserved Register – Index 4Bh (Bank 4) 9.223 VTIN0 Temperature Sensor Offset Register – Index 4Ch (Bank 4) Attribute: Read/Write -117 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Size: 8 bits BIT 7 6 5 4 3 2 1 0 0 0 0 OFFSET NAME DEFAULT 0 0 0 0 0 BIT DESCRIPTION 7-0 VTIN0 Temperature Offset Value. The value in this register is added to the monitored value so that the read value will be the sum of the monitored value and this offset value. 9.224 Reserved Register – Index 4Eh ~ 4Fh (Bank 4) 9.225 Interrupt Status Register 3 – Index 50h (Bank 4) Attribute: Size: Read Clear 8 bits BIT 7 6 5 4 2 RESERVED NAME DEFAULT 0 0 0 BIT 7-3 3 0 0 1 0 VBAT 3VSB 0 0 0 DESCRIPTION Reserved. 1 VBAT. A one indicates the high or low limit of VBAT has been exceeded. 0 3VSB. A one indicates the high or low limit of 3VSB has been exceeded. 9.226 SMI# Mask Register 4 – Index 51h (Bank 4) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 NAME RESERVED TAR5 TAR4 TAR3 DEFAULT 0 1 1 1 BIT 3 2 RESERVED 0 0 1 0 SMSKVBAT SMSKVSB 1 1 DESCRIPTION 7 Reserved. 6 TAR5. A one disables the corresponding interrupt status bit for the SMI interrupt. (See Interrupt Status Register 3 – Index 50h (Bank 4)) 5 TAR4. A one disables the corresponding interrupt status bit for the SMI interrupt. (See Interrupt Status Register 3 – Index 50h (Bank 4)) 4 TAR3. A one disables the corresponding interrupt status bit for the SMI interrupt. (See Interrupt Status Register 3 – Index 45h (Bank 0)) 3-2 Reserved. -118 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 1 0 DESCRIPTION SMSKVBAT. A one disables the corresponding interrupt status bit for the SMI interrupt. (See Interrupt Status Register 3 – Index 50h (Bank 4)) SMSKVSB. A one disables the corresponding interrupt status bit for the SMI interrupt. (See Interrupt Status Register 3 – Index 50h (Bank 4)) 9.227 Reserved Register – Index 52h ~ 53h (Bank 4) 9.228 Reserved Register – Index 54h (Bank 4) 9.229 CPUTIN Temperature Sensor Offset Register – Index 55h (Bank 4) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 0 0 0 OFFSET NAME DEFAULT 0 0 0 0 0 BIT DESCRIPTION 7-0 CPUTIN Temperature Offset Value. The value in this register will be added to the monitored value so that the read value is the sum of the monitored value and this offset value. 9.230 AUXTIN0 Temperature Sensor Offset Register – Index 56h (Bank 4) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 0 0 0 OFFSET NAME DEFAULT 0 0 0 0 0 BIT DESCRIPTION 7-0 AUXTIN0 Temperature Offset Value. The value in this register is added to the monitored value so that the read value is the sum of the monitored value and this offset value. 9.231 Reserved Register – Index 57h-58h (Bank 4) 9.232 Real Time Hardware Status Register I – Index 59h (Bank 4) Attribute: Size: Read Only 8 bits BIT 7 6 5 4 3 2 1 0 NAME CPUFANIN _STS SYSFANIN _STS CPUTIN _STS Reserved 3VCC _STS AVCC _STS Reserved CPUVCORE _STS -119 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY DEFAULT 0 0 0 BIT 7 6 5 0 0 0 0 0 DESCRIPTION CPUFANIN_STS. CPUFANIN Status. 1: Fan speed count is over the threshold value. 0: Fan speed count is in the allowed range. SYSFANIN_STS. SYSFANIN Status. 1: Fan speed count is over the threshold value. 0: Fan speed count is in the allowed range. CPUTIN_STS. CPUTIN Temperature Sensor Status. 1: Temperature exceeds the over-temperature value. 0: Temperature is under the hysteresis value. 4 Reserved 3 3VCC_STS. 3VCC Voltage Status. 1: 3VCC voltage is over or under the allowed range. 0: 3VCC voltage is in the allowed range. 2 AVCC_STS. AVCC Voltage Status. 1: AVCC voltage is over or under the allowed range. 0: AVCC voltage is in the allowed range. 1 Reserved 0 CPUVCORE_STS. CPUVCORE Voltage Status. 1: CPUVCORE voltage is over or under the allowed range. 0: CPUVCORE voltage is in the allowed range. 9.233 Real Time Hardware Status Register II – Index 5Ah (Bank 4) Attribute: Size: Read Only 8 bits BIT 7 6 5 NAME TAR2 _STS TAR1 _STS AUXTIN _STS DEFAULT 0 0 0 4 3 2 1 0 0 0 Reserved 0 0 0 BIT DESCRIPTION 7 TAR2_STS. Smart Fan of CPUFANIN Warning Status. 1: Selected temperature has been over the target temperature for three minutes at full fan TM speed in Thermal Cruise Mode and SMART FAN IV. 0: Selected temperature has not reached the warning range. 6 TAR1_STS. Smart Fan of SYSFANIN Warning Status. 1: SYSTIN temperature has been over the target temperature for three minutes at full fan TM speed in Thermal Cruise Mode and SMART FAN IV. 0: SYSTIN temperature has not reached the warning range. 5 AUXTIN_STS. AUXTIN Temperature Sensor Status. 1: Temperature exceeds the over-temperature value. 0: Temperature is under the hysteresis value. 4-0 Reserved -120 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.234 Real Time Hardware Status Register III – Index 5Bh (Bank 4) Attribute: Size: Read Only 8 bits BIT 7 6 5 4 3 2 1 0 NAME Reserved TAR5 _STS Reserved VIN4 _STS TAR4 _STS TAR3 _STS VBAT _STS VSB _STS DEFAULT 0 0 0 0 0 0 0 0 BIT DESCRIPTION 7 Reserved 6 TAR5_STS. Smart Fan of AUXFANIN2 Warning Status. 1: The selected temperature has been over the target temperature for three minutes at full TM fan speed in Thermal Cruise Mode and SMART FAN IV. 0: The selected temperature has not reached the warning range. 5 Reserved 4 VIN4_STS. VIN4 Voltage Status. 1: VIN4 voltage is over or under the allowed range. 0: VIN4 voltage is in the allowed range. 3 TAR4_STS. Smart Fan of AUXFANIN1 Warning Status. 1: The selected temperature has been over the target temperature for three minutes at full TM fan speed in Thermal Cruise Mode and SMART FAN IV. 0: The selected temperature has not reached the warning range. 2 TAR3_STS. Smart Fan of AUXFANIN0 Warning Status. 1: The selected temperature has been over the target temperature for three minutes at full TM fan speed in Thermal Cruise Mode and SMART FAN IV. 0: The selected temperature has not reached the warning range. 1 VBAT_STS. VBAT Voltage Status. 1: The VBAT voltage is over or under the allowed range. 0: The VBAT voltage is in the allowed range. 0 VSB_STS. 3VSB Voltage Status. 1: The 3VSB voltage is over or under the allowed range. 0: The 3VSB voltage is in the allowed range. 9.235 Reserved Register – Index 5Ch ~ 5Fh (Bank 4) 9.236 Reserved Register – Index 60h (Bank 4) 9.237 Reserved Register – Index 61h (Bank 4) 9.238 Reserved Register – Index 62h (Bank 4) 9.239 Reserved Register – Index 63h (Bank 4) 9.240 Reserved Register – Index 64h (Bank 4) -121 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.241 Reserved Register – Index 65h (Bank 4) 9.242 Reserved Register – Index 66h (Bank 4) 9.243 Reserved Register – Index 67h (Bank 4) 9.244 Reserved Register – Index 68h ~ 7Fh (Bank 4) 9.245 Value RAM ⎯ Index 80h ~ 96h (Bank 4) ADDRESS A6-A0 DESCRIPTION 80h CPUVCORE reading 81h Reserved 82h AVCC reading 83h 3VCC reading 84h Reserved 85h Reserved 86h VIN4 reading 87h 3VSB reading 88h VBAT reading 89h VTT reading 8Ah Reserved 8Bh Reserved 8Ch VIN2 reading 8Dh VIN3 reading 8Eh Reserved 8Fh Reserved 90h Reserved 91h CPUTIN temperature reading 92h AUXTIN0 temperature reading 93h Reserved 94h Reserved 95h VTIN0 temperature reading 9.246 (SYSFANIN) FANIN1 COUNT High-byte Register – Index B0h (Bank 4) Attribute: Size: BIT Read 8 bits 7 6 5 3 2 1 0 1 1 1 FANCNT1 [12:5] NAME DEFAULT 4 1 1 1 1 1 -122 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7-0 DESCRIPTION FANCNT1_H: 13-bit SYSFANIN Fan Count, High Byte 9.247 (SYSFANIN) FANIN1 COUNT Low-byte Register – Index B1h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 4 3 2 NAME RESERVED FANCNT1 [4:0] DEFAULT 0 1F BIT 1 0 DESCRIPTION 7-5 Reserved. 4-0 FANCNT1_L: 13-bit SYSFANIN Fan Count, Low Byte 9.248 (CPUFANIN) FANIN2 COUNT High-byte Register – Index B2h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 NAME DEFAULT 1 1 1 BIT 7-0 4 3 2 1 0 1 1 1 FANCNT2 [12:5] 1 1 DESCRIPTION FANCNT2_H: 13-bit CPUFANIN Fan Count, High Byte 9.249 (CPUFANIN) FANIN2 COUNT Low-byte Register – Index B3h (Bank 4) Attribute: Size: Read 8 bits BIT 7 6 5 4 3 2 NAME RESERVED FANCNT2 [4:0] DEFAULT 0 1F BIT 1 0 DESCRIPTION 7-5 Reserved. 4-0 FANCNT2_L: 13-bit CPUFANIN Fan Count, Low Byte 9.250 Reserved Register – Index B4h (Bank 4) 9.251 Reserved Register – Index B5h (Bank 4) -123 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.252 Reserved Register – Index B6h (Bank 4) 9.253 Reserved Register – Index B7h (Bank 4) 9.254 Reserved Register – Index B8h (Bank 4) 9.255 Reserved Register – Index B9h (Bank 4) 9.256 Reserved Register – Index BAh ~ BFh (Bank 4) 9.257 SYSFANIN SPEED HIGH-BYTE VALUE (RPM) - Index C0h (Bank 4) Attribute: Size: Read Only 8 bits BIT 7 6 5 3 2 1 0 0 0 0 2 1 0 0 0 0 1 0 0 0 SYSFANIN SPEED HIGH-BYTE VALUE NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 DESCRIPTION SYSFANIN SPEED HIGH-BYTE VALUE. 9.258 SYSFANIN SPEED LOW-BYTE VALUE (RPM) - Index C1h (Bank 4) Attribute: Size: Read Only 8 bits BIT 7 6 5 3 SYSFANIN SPEED LOW-BYTE VALUE NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 DESCRIPTION SYSFANIN SPEED LOW-BYTE VALUE. 9.259 CPUFANIN SPEED HIGH-BYTE VALUE (RPM) – Index C2h (Bank 4) Attribute: Size: Read Only 8 bits BIT 7 6 DEFAULT 7-0 4 3 2 CPUFANIN SPEED HIGH-BYTE VALUE NAME BIT 5 0 0 0 0 0 0 DESCRIPTION CPUFANIN SPEED HIGH-BYTE VALUE. -124 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.260 CPUFANIN SPEED LOW-BYTE VALUE (RPM) – Index C3h (Bank 4) Attribute: Size: Read Only 8 bits BIT 7 6 5 3 2 1 0 0 0 0 CPUFANIN SPEED LOW-BYTE VALUE NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 DESCRIPTION CPUFANIN SPEED LOW-BYTE VALUE. 9.261 Reserved Register – Index C4h (Bank 4) 9.262 Reserved Register – Index C5h (Bank 4) 9.263 Reserved Register – Index C6h (Bank 4) 9.264 Reserved Register – Index C7h (Bank 4) 9.265 Reserved Register – Index C8h (Bank 4) 9.266 Reserved Register – Index C9h (Bank 4) 9.267 Reserved Register – Index 00h ~ 53h (Bank 5) 9.268 Value RAM 2 ⎯ Index 50h-5Fh (Bank 5) ADDRESS A6-A0 54h 3VSB High Limit 55h 3VSB Low Limit 56h VBAT High Limit 57h VBAT Low Limit 58h VTT High Limit 59h VTT Low Limit 5Ah Reserved 5Bh Reserved 5Ch Reserved 5Dh Reserved 5Eh VIN2 High Limit 5Fh VIN2 Low Limit 60h VIN3 High Limit -125 DESCRIPTION Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY ADDRESS A6-A0 DESCRIPTION 61h VIN3 Low Limit 62h Reserved 63h Reserved 9.269 SMI# Mask Register 1 – Index 66h (Bank 5) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved VIN3 VIN2 Reserved Reserved VTT DEFAULT 0 0 1 1 1 1 1 1 BIT DESCRIPTION 7 6 Reserved 5 Reserved 4 VIN3 3 VIN2 2 Reserved 1 Reserved 0 VTT Reserved A one disables the corresponding interrupt status bit for the SMI interrupt. (See Interrupt Status Register 1 – Index 41h (Bank0)) 9.270 Interrupt Status Register – Index 67h (Bank 5) Attribute: Size: Read Clear 8 bits BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved VIN3 VIN2 reserved Reserved VTT DEFAULT 0 0 0 0 0 0 0 0 BIT DESCRIPTION 7 6 Reserved 5 Reserved 4 VIN3. A one indicates the high or low limit of VIN3 has been exceeded. 3 VIN2. A one indicates the high or low limit of VIN2 has been exceeded. 2 Reserved 1 Reserved 0 VTT. A one indicates the high or low limit of VTT has been exceeded. Reserved 9.271 Real Time Hardware Status Register – Index 68h (Bank 5) -126 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Attribute: Size: Read Only 8 bits BIT 7 6 Reserved NAME DEFAULT Reserved 0 0 5 4 3 2 1 0 Reserved VIN3 _STS VIN2 _STS Reserved Reserved VTT _STS 0 0 0 0 0 0 BIT DESCRIPTION 7 6 Reserved 5 Reserved 4 VIN3_STS. VIN3 Voltage Status. 1: VIN3 voltage is over or under the allowed range. 0: VIN3 voltage is in the allowed range. 3 VIN2_STS. VIN2 Voltage Status. 1: VIN2 voltage is over or under the allowed range. 0: VIN2 voltage is in the allowed range. 2 Reserved 1 Reserved 0 VTT_STS. VTT Voltage Status. 1: VTT voltage is over or under the allowed range. 0: VTT voltage is in the allowed range. Reserved 9.272 Reserved Register – Index 69h ~ FFh (Bank 5) 9.273 Close-Loop Fan Control RPM mode Register – Index 00 (Bank 6) Attribute: Size: BIT Read/Write 8 bits 7 6 0 BIT 7-2 1 0 4 3 2 RESERVED NAME DEFAULT 5 0 0 0 1 0 En_CPU_RP M En_SYS_RP M 0 0 DESCRIPTION RESERVED En_CPU_RPM TM 0: Disable SMART FAN IV Close Loop Fan Control RPM Mode. TM 1: Enable SMART FAN IV Close Loop Fan Control RPM Mode. En_SYS_RPM TM 0: Disable SMART FAN IV Close Loop Fan Control RPM Mode. TM 1: Enable SMART FAN IV Close Loop Fan Control RPM Mode. -127 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.274 SYSFAN RPM Mode Tolerance Register – Index 01 (Bank 6) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME RESERVED Generic_Tol_ SYS_RPM DEFAULT 0 0 BIT DESCRIPTION 7-4 RESERVED 3-0 Tolerance of RPM mode, unit 50 RPM. If Enable RPM High Mode(Bank6 index6 bit0), unit is 100 RPM. 9.275 CPUFAN RPM Mode Tolerance Register – Index 02 (Bank 6) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME RESERVED Generic_Tol_ CPU_RPM DEFAULT 0 0 BIT DESCRIPTION 7-4 RESERVED 3-0 Tolerance of RPM mode, unit 50 RPM. If Enable RPM High Mode(Bank6 index6 bit1), unit is 100 RPM. 9.276 Reserved Register – Index 03 (Bank 6) 9.277 Reserved Register – Index 04 (Bank 6) 9.278 Reserved Register – Index 05 (Bank 6) 9.279 Enable RPM High Mode Register – Index 00 (Bank 6) Attribute: Size: BIT Read/Write 8 bits 7 6 BIT 4 3 2 RESERVED NAME DEFAULT 5 0 0 0 0 1 0 En_CPU_RP M_HIGH En_SYS_RP M_HIGH 0 0 DESCRIPTION -128 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 7-2 RESERVED 1 En_CPU_RPM_HIGH For High Speed Fan Control at RPM Mode, the unit is 100 RPM. Support 100 rpm ~ 25500 rpm Fan, 0: Disable 1: Enable 0 En_SYS_RPM_HIGH For High Speed Fan Control at RPM Mode, the unit is 100 RPM. Support 100 rpm ~ 25500 rpm Fan, 0: Disable 1: Enable 9.280 SMIOVT1 Temperature Source Select Register – Index 21 (Bank 6) Attribute: Size: BIT Read/Write 8 bits 7 5 4 3 RESERVED NAME DEFAULT 6 0 BIT 0 2 1 0 0 1 SMIOVT_SRC1 0 0 0 0 DESCRIPTION 7-5 RESERVED 4-0 SMIOVT1 Temperature selection. Bits 43210 0 0 0 0 1: Select SYSTIN as SYSFAN monitoring source. (Default) 0 0 0 1 0: Select CPUTIN as SYSFAN monitoring source. 0 0 0 1 1: Select AUXTIN0 as SYSFAN monitoring source. 0 0 1 0 0: Select AUXTIN1 as SYSFAN monitoring source. 0 0 1 0 1: Select AUXTIN2 as SYSFAN monitoring source. 0 0 1 1 0: Select VTIN0 as SYSFAN monitoring source. 0 0 1 1 1: Reserved. 0 1 0 0 0: Select SMBUSMASTER 0 as SYSFAN monitoring source. 0 1 0 0 1: Select SMBUSMASTER 1 as SYSFAN monitoring source. 0 1 0 1 0: Select SMBUSMASTER 2 as SYSFAN monitoring source. 0 1 0 1 1: Select SMBUSMASTER 3 as SYSFAN monitoring source. 0 1 1 0 0: Select SMBUSMASTER 4 as SYSFAN monitoring source. 0 1 1 0 1: Select SMBUSMASTER 5 as SYSFAN monitoring source. 0 1 1 1 0: Select SMBUSMASTER 6 as SYSFAN monitoring source. 0 1 1 1 1: Select SMBUSMASTER 7 as SYSFAN monitoring source. 1 0 0 0 0: Select PECI Agent 0 as SYSFAN monitoring source. 1 0 0 0 1: Select PECI Agent 1 as SYSFAN monitoring source. 1 0 0 1 0: Select PCH_CHIP_CPU_MAX_TEMP as SYSFAN monitoring source. 1 0 0 1 1: Select PCH_CHIP_TEMP as SYSFAN monitoring source. 1 0 1 0 0: Select PCH_CPU_TEMP as SYSFAN monitoring source. 1 0 1 0 1: Select PCH_MCH_TEMP as SYSFAN monitoring source. 1 0 1 1 0: Select PCH_DIM0_TEMP as SYSFAN monitoring source. -129 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 1 0 1 1 1: Select PCH_DIM1_TEMP as SYSFAN monitoring source. 1 1 0 0 0: Select PCH_DIM2_TEMP as SYSFAN monitoring source. 1 1 0 0 1: Select PCH_DIM3_TEMP as SYSFAN monitoring source. 1 1 0 1 0: Select BYTE_TEMP as SYSFAN monitoring source. 9.281 SMIOVT2 Temperature Source Select Register – Index 22 (Bank 6) Attribute: Size: BIT Read/Write 8 bits 7 NAME DEFAULT 6 5 4 3 RESERVED 0 BIT 0 2 1 0 1 0 SMIOVT_SRC2 0 0 0 0 DESCRIPTION 7-5 RESERVED 4-0 SMIOVT2 Temperature selection. Bits 43210 0 0 0 0 1: Select SYSTIN as SYSFAN monitoring source. (Default) 0 0 0 1 0: Select CPUTIN as SYSFAN monitoring source. 0 0 0 1 1: Select AUXTIN0 as SYSFAN monitoring source. 0 0 1 0 0: Select AUXTIN1 as SYSFAN monitoring source. 0 0 1 0 1: Select AUXTIN2 as SYSFAN monitoring source. 0 0 1 1 0: Select VTIN0 as SYSFAN monitoring source. 0 0 1 1 1: Reserved. 0 1 0 0 0: Select SMBUSMASTER 0 as SYSFAN monitoring source. 0 1 0 0 1: Select SMBUSMASTER 1 as SYSFAN monitoring source. 0 1 0 1 0: Select SMBUSMASTER 2 as SYSFAN monitoring source. 0 1 0 1 1: Select SMBUSMASTER 3 as SYSFAN monitoring source. 0 1 1 0 0: Select SMBUSMASTER 4 as SYSFAN monitoring source. 0 1 1 0 1: Select SMBUSMASTER 5 as SYSFAN monitoring source. 0 1 1 1 0: Select SMBUSMASTER 6 as SYSFAN monitoring source. 0 1 1 1 1: Select SMBUSMASTER 7 as SYSFAN monitoring source. 1 0 0 0 0: Select PECI Agent 0 as SYSFAN monitoring source. 1 0 0 0 1: Select PECI Agent 1 as SYSFAN monitoring source. 1 0 0 1 0: Select PCH_CHIP_CPU_MAX_TEMP as SYSFAN monitoring source. 1 0 0 1 1: Select PCH_CHIP_TEMP as SYSFAN monitoring source. 1 0 1 0 0: Select PCH_CPU_TEMP as SYSFAN monitoring source. 1 0 1 0 1: Select PCH_MCH_TEMP as SYSFAN monitoring source. 1 0 1 1 0: Select PCH_DIM0_TEMP as SYSFAN monitoring source. 1 0 1 1 1: Select PCH_DIM1_TEMP as SYSFAN monitoring source. 1 1 0 0 0: Select PCH_DIM2_TEMP as SYSFAN monitoring source. 1 1 0 0 1: Select PCH_DIM3_TEMP as SYSFAN monitoring source. 1 1 0 1 0: Select BYTE_TEMP as SYSFAN monitoring source. 9.282 Reserved Register – Index 23~39h (Bank 6) -130 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.283 (SYSFANIN) Fan Count Limit High-byte Register – Index 3Ah (Bank 6) Attribute: Size: Read /Write 8 bits BIT 7 6 5 3 2 1 0 0 0 0 FANIN1_HL [12:5] NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 DESCRIPTION FANIN1_HL: 13-bit SYSFANIN Fan Count Limit, High Byte 9.284 (SYSFANIN) Fan Count Limit Low-byte Register – Index 3Bh (Bank 6) Attribute: Size: Read /Write 8 bits BIT 7 6 5 4 3 2 NAME RESERVED FANIN1_HL [4:0] DEFAULT 0 0 BIT 1 0 DESCRIPTION 7-5 Reserved. 4-0 FANIN1_HL: 13-bit SYSFANIN Fan Count Limit, Low Byte 9.285 (CPUFANIN) Fan Count Limit High-byte Register – Index 3Ch (Bank 6) Attribute: Size: Read /Write 8 bits BIT 7 6 5 3 2 1 0 0 0 0 FANIN2_HL [12:5] NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 DESCRIPTION FANIN2_HL: 13-bit CPUFANIN Fan Count Limit, High Byte 9.286 (CPUFANIN) Fan Count Limit Low-byte Register – Index 3Dh (Bank 6) Attribute: Size: BIT Read /Write 8 bits 7 6 5 4 3 2 NAME RESERVED FANIN2_HL [4:0] DEFAULT 0 0 BIT 1 0 DESCRIPTION -131 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 7-5 Reserved. 4-0 FANIN2_HL: 13-bit CPUFANIN Fan Count Limit, Low Byte 9.287 Reserved Register – Index 3Eh (Bank 6) 9.288 Reserved Register – Index 3Fh (Bank 6) 9.289 Reserved Register – Index 40h (Bank 6) 9.290 Reserved Register – Index 41h (Bank 6) 9.291 Reserved Register – Index 42h (Bank 6) 9.292 Reserved Register – Index 43h (Bank 6) 9.293 SYSFANIN Revolution Pulses Selection Register – Index 44h (Bank 6) Attribute: Size: Read /Write 8 bits BIT 7 6 5 4 3 2 Reserved NAME DEFAULT 0 0 0 BIT 1 0 HM_Rev_Pulse_Fan1_Sel 0 0 0 1 0 DESCRIPTION 7-2 Reserved 1-0 SYSFANIN Revolution Pulses Selection = 00, four pulses per revolution. = 01, one pulse per revolution. = 10, two pulses per revolution. (default) = 11, three pulses per revolution. 9.294 CPUFANIN Revolution Pulses Selection Register – Index 45h (Bank 6) Attribute: Size: Read /Write 8 bits BIT 7 6 5 4 3 2 Reserved NAME DEFAULT 0 BIT 0 0 1 0 HM_Rev_Pulse_Fan2_Sel 0 0 0 1 0 DESCRIPTION 7-2 Reserved 1-0 CPUFANIN Revolution Pulses Selection = 00, four pulses per revolution. -132 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY = 01, one pulse per revolution. = 10, two pulses per revolution. (default) = 11, three pulses per revolution. 9.295 Reserved Register – Index 46h (Bank 6) 9.296 Reserved Register – Index 47h (Bank 6) 9.297 Reserved Register – Index 48h (Bank 6) 9.298 Reserved Register – Index 49~FFh (Bank 6) 9.299 PECI Function Control Registers – Index 01 ~ 04h (Bank 7) 9.300 PECI Enable Function Register – Index 01h (Bank 7) Attribute: Read/Write Size: 8 bits BIT 7 NAME PECI_En DEFAULT 0 6 5 4 3 Reserved 0 1 0 2 1 0 Is_PECI30 Manual_En Routine_En 1 0 0 0 BIT READ / WRITE DESCRIPTION 7 R/W Enable PECI Function. (PECI_En) 6~3 R/W Reserved 2 R/W Enable PECI 3.0 Command function (Is_PECI30) 1 R/W Enable PECI 3.0 Manual Function (Manual_En) (One-shot clear) 0 R/W Enable PECI 3.0 Routine Function (Routine_En) 9.301 PECI Timing Config Register – Index 02h (Bank 7) Attribute: Read/Write Size: 8 bits BIT 7 Reserved NAME DEFAULT 6 0 5 4 3 TN_Extend 0 0 0 BIT READ / WRITE 7~6 R/W Reserve 5 R/W TN_Extend[1:0] Adjust Transaction Rate. 2 1 Adj[2:0] 0 0 0 PECI_DC 1 0 DESCRIPTION -133 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT READ / WRITE 4 R/W 3 R/W 2 R/W 1 R/W 0 R/W DESCRIPTION 00BIN = 01BIN = 10BIN = 11BIN = 1.5 MHz (Default) 750 KHz 375 KHz 187.5 KHz Adj[2:0] Compensate the effect of rising time on physical bus Default Value = 001 Adjust PECI Tbit Duty cycle selection. (PECI_DC) 0 = 75% Tbit high duty cycle time. (Default) 1 = 68% Tbit high duty cycle time. 9.302 PECI Agent Config Register – Index 03h (Bank 7) Attribute: Read/Write Size: 8 bits BIT 7 Reserved NAME DEFAULT 6 0 5 4 3 En_Agt[1:0] 0 0 2 Reserved 0 0 BIT READ / WRITE 7~6 R/W 5 R/W 4 R/W 3~2 R/W Reserved 1 R/W Enable domain 1 for Agent1 0 = Agent1 without domain1 1 = Agent1 with domain 1 0 R/W Enable domain 1 for Agent0 0 = Agent0 without domain 1 1 = Agent0 with domain 1 1 0 Domain1_Agt1 Domain1_Agt0 0 0 0 DESCRIPTION Reserved En_Agt[1:0] Enable Agent 00 = Disable Agent. 01= Enable Agent0. 10 = Reserved. 11 = Enable Agent0 and Agent1. 9.303 PECI Temperature Config Register – Index 04h (Bank 7) Attribute: Read/Write Size: 8 bits BIT 7 NAME Virtual_En DEFAULT 0 6 5 Reserved 0 0 4 3 Clamp Reserved 0 0 -134 2 1 RtDmn_Agt[1:0] 0 0 0 RtHigher 0 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT READ / WRITE DESCRIPTION 7 R/W Virtual Temp Function Enable.( Virtual_En) When enable this function, the temperature raw data can use LPC to write raw data to CR 17HEX ~ CR 1EHEX 6~5 R/W Reserved 4 R/W When temperature data reading is positive or less than -128, can enable this function to clamp temperature data.(Clamp) 3 R/W Reserved 2 R/W 1 R/W RtDmn_Agt[1:0] Agent 1 – Agent 0 always return the relative domain Temperature. 0 = Agent always returns the relative temperature from domain 0. 1 = Agent always returns the relative temperature from domain 1. 0 R/W Return High Temperature of doamin0 or domain1.(RtHigher) 0 = The temperature of each agent is returned from domain 0 or domain 1, which is controlled by (CR 04HEX) 1 = Return the highest temperature in domain 0 and domain 1 of individual Agent. 9.304 PECI Command Write Date Registers – Index 05 ~ 1Eh (Bank 7) 9.305 PECI Command Address Register – Index 05h (Bank 7) Attribute: Size: Read/Write 8 bits BIT 7 6 5 NAME DEFAULT 0 0 0 BIT 7~0 4 3 2 1 0 0 0 0 2 1 0 0 0 0 PECI Command Address 0 0 DESCRIPTION The data would be sent to client. Default value is 00HEX. 9.306 PECI Command Write Length Register – Index 06h (Bank 7) Attribute: Size: Read/Write 8 bits BIT 7 6 5 BIT 7~0 3 PECI Command Write Length NAME DEFAULT 4 0 0 0 0 0 DESCRIPTION The data would be sent to client. Default value is 00HEX. 9.307 PECI Command Read Length Register – Index 07h (Bank 7) -135 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Attribute: Size: Read/Write 8 bits BIT 7 6 5 0 0 0 BIT 7~0 3 2 1 0 0 0 0 2 1 0 0 0 0 2 1 0 0 0 0 2 1 0 0 0 0 PECI Command Read Length NAME DEFAULT 4 0 0 DESCRIPTION The data would be sent to client. Default value is 00HEX. 9.308 PECI Command Code Register – Index 08h (Bank 7) Attribute: Size: Read/Write 8 bits BIT 7 6 5 0 0 0 BIT 7~0 3 PECI Command Code NAME DEFAULT 4 0 0 DESCRIPTION The data would be sent to client. Default value is 00HEX. 9.309 PECI Command Tbase0 Register – Index 09h (Bank 7) Attribute: Size: Read/Write 8 bits BIT 7 NAME Reserved DEFAULT 0 6 5 3 Tbase 0 0 0 BIT 7~0 4 0 0 DESCRIPTION The data would be sent to client. Default value is 00HEX. 9.310 PECI Command Tbase1 Register – Index 0Ah (Bank 7) Attribute: Size: Read/Write 8 bits BIT 7 NAME Reserved DEFAULT 0 BIT 7~0 6 5 4 3 Tbase 1 0 0 0 0 DESCRIPTION The data would be sent to client. Default value is 00HEX. -136 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.311 PECI Command Write Data 1 Register – Index 0Bh (Bank 7) Attribute: Size: Read/Write 8 bits BIT 7 6 5 0 0 0 BIT 7~0 3 2 1 0 0 0 0 2 1 0 0 0 0 2 1 0 0 0 0 2 1 0 0 0 0 PECI Write Data 1 NAME DEFAULT 4 0 0 DESCRIPTION The data would be sent to client. Default value is 00HEX. 9.312 PECI Command Write Data 2 Register – Index 0Ch (Bank 7) Attribute: Size: Read/Write 8 bits BIT 7 6 5 0 0 0 BIT 7~0 3 PECI Write Data 2 NAME DEFAULT 4 0 0 DESCRIPTION The data would be sent to client. Default value is 00HEX. 9.313 PECI Command Write Data 3 Register – Index 0Dh (Bank 7) Attribute: Size: Read/Write 8 bits BIT 7 6 5 0 0 0 BIT 7~0 3 PECI Write Data 3 NAME DEFAULT 4 0 0 DESCRIPTION The data would be sent to client. Default value is 00HEX. 9.314 PECI Command Write Data 4 Register – Index 0Eh (Bank 7) Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 PECI Write Data 4 NAME DEFAULT 4 0 0 0 0 -137 0 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7~0 DESCRIPTION The data would be sent to client. Default value is 00HEX. 9.315 PECI Command Write Data 5 Register – Index 0Fh (Bank 7) Attribute: Size: Read/Write 8 bits BIT 7 6 5 0 0 0 BIT 7~0 3 2 1 0 0 0 0 2 1 0 0 0 0 2 1 0 0 0 0 PECI Write Data 5 NAME DEFAULT 4 0 0 DESCRIPTION The data would be sent to client. Default value is 00HEX. 9.316 PECI Command Write Data 6 Register – Index 10h (Bank 7) Attribute: Size: Read/Write 8 bits BIT 7 6 5 0 0 0 BIT 7~0 3 PECI Write Data 6 NAME DEFAULT 4 0 0 DESCRIPTION The data would be sent to client. Default value is 00HEX. 9.317 PECI Command Write Data 7 Register – Index 11h (Bank 7) Attribute: Size: Read/Write 8 bits BIT 7 6 5 0 BIT 7~0 3 PECI Write Data 7 NAME DEFAULT 4 0 0 0 0 DESCRIPTION The data would be sent to client. Default value is 00HEX. 9.318 PECI Command Write Data 8 Register – Index 12h (Bank 7) Attribute: Size: Read/Write 8 bits -138 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7 6 5 0 0 0 BIT 7~0 3 2 1 0 0 0 0 2 1 0 0 0 0 2 1 0 0 0 0 2 1 0 0 0 0 PECI Write Data 8 NAME DEFAULT 4 0 0 DESCRIPTION The data would be sent to client. Default value is 00HEX. 9.319 PECI Command Write Data 9 Register – Index 13h (Bank 7) Attribute: Size: Read/Write 8 bits BIT 7 6 5 0 0 0 BIT 7~0 3 PECI Write Data 9 NAME DEFAULT 4 0 0 DESCRIPTION The data would be sent to client. Default value is 00HEX. 9.320 PECI Command Write Data 10 Register – Index 14h (Bank 7) Attribute: Size: Read/Write 8 bits BIT 7 6 5 0 0 0 BIT 7~0 3 PECI Write Data 10 NAME DEFAULT 4 0 0 DESCRIPTION The data would be sent to client. Default value is 00HEX. 9.321 PECI Command Write Data 11 Register – Index 15h (Bank 7) Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 PECI Write Data 11 NAME DEFAULT 4 0 0 0 0 -139 0 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7~0 DESCRIPTION The data would be sent to client. Default value is 00HEX. 9.322 PECI Command Write Data 12 Register – Index 16h (Bank 7) Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 2 1 0 0 0 0 PECI Write Data 12 NAME DEFAULT 0 0 BIT 7~0 4 0 0 0 DESCRIPTION The data would be sent to client. Default value is 00HEX. 9.323 PECI Agent Relative Temperature Register (ARTR) – Index 17h-1Eh (Bank 7) These registers return the “raw data” retrieved from PECI GetTemp() command. These data could be the error codes (range: 8000H~81FFH) or relative temperatures to process the defined Tbase. The error code will only be update in ARTR; while “Temperature Reading Register”, Bank7 Index 20h and 21h, will not be updated when the error code is received. If the RtHigher mechanism is activated, the normal temperature will always be returned first. In case both 2 domains return errors, the return priority will be Overflow Error > Underflow Error > Missing Diode > General Error. The reset value is 8001HEX, in that PECI is defaulted to be off. In PECI, 8001HEX means the diode is missing. Attribute: Read / Write(When Virtual_En enable) ADDRESS 17-1E DESCRIPTION 17h[15:8],18h[7:0] Domain0 Relative Temperature Agent0 [15:0] 19h[15:8],1Ah[7:0] Domain1 Relative Temperature Agent0 [15:0] 1Bh[15:8],1Ch[7:0] Domain0 Relative Temperature Agent1 [15:0] 1Dh[15:8],1Eh[7:0] Domain1 Relative Temperature Agent1 [15:0] GetTemp() PECI Temperature format: BIT DESCRIPTION 15 Sign Bit. (Sign) In PECI Protocol, this bit should always be 1 to represent a negative temperature. 14-6 The integer part of the relative temperature. (Temperature[8:0]) 5 TEMP_2. 0.5℃ unit. 4 TEMP_4. 0.25℃ unit. 3 TEMP_8. 0.125℃ unit. 2 TEMP_16. 0.0625℃ unit. 1 TEMP_32. 0.03125℃ unit. 0 TEMP_64. 0.015625℃ unit. -140 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY GetTemp() Response Definition: RESPONSE MEANING General Sensor Error (GSE) Thermal scan did not complete in time. Retry is appropriate. 0x0000 Processor is running at its maximum temperature or is currently being reset. All other data Valid temperature reading, reported as a negative offset from the TCC activation temperature. The valide temperature reading is referred to GetTemp() PECI Temperature format Error Code Description Host operation 8000HEX General Sensor Error No further processing. 8001HEX Sensing Device Missing 8002HEX Operational, but the temperature is Compulsorily write 0℃ back to the temperature lower than the sensor operation readouts. range. 8003HEX Operational, but the temperature is Compulsorily write 127℃ back to the temperature higher than the sensor operation readouts. range. 8004HEX Reserved. No further operation. ≀ 81FFHEX 9.324 PECI Command Read Date Registers – Index 1F ~ 32h (Bank 7) 9.325 PECI Alive Agent Register – Index 1Fh (Bank 7) Attribute: Read only Size: 8 bits Record which agentis able to respond to Ping().Default value is 00HEX. 1: agent is able to respond to Ping() command. Agent alive 0: agent isn’t able to respond to Ping() command. Agent is not alive BIT 7 6 5 0 BIT 7~2 1 3 2 Reserved NAME DEFAULT 4 0 0 1 0 PECI Alive Agent 0 0 0 0 0 DESCRIPTION Reserve 1: agent1 is able to respond to Ping() command. Agent alive 0: agent1 isn’t able to respond to Ping() command. Agent is not alive -141 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 0 DESCRIPTION 1: agent0 is able to respond to Ping() command. Agent alive 0: agent0 isn’t able to respond to Ping() command. Agent is not alive 9.326 PECI Temperature Reading Register (Integer) – Index 20h (Bank 7) Attribute: Size: Read only 8 bits BIT 7 6 NAME 5 3 2 1 0 0 0 PECI Temperature Reading---Integer [9:2] DEFAULT 0 0 1 BIT 7~0 4 0 1 0 DESCRIPTION Temperature value [9] (Sign bit) Temperature value [8:2] (Integer bits) Temperature value [1:0] (Fraction bits) Note. Temperature reading register is count from raw data and Tbase, for example: Raw data Bank7, Index [17][18] + Tbase = Temp Reading + Bank7, Index [09] = Bank7, Index [20][21] 9.327 PECI Temperature Reading Register (Fraction) – Index 21h (Bank 7) Attribute: Size: Read only 8 bits BIT 7 6 5 NAME 3 2 0 0 0 BIT 1 0 PECI Temperature Vaule[1:0] Reserved DEFAULT 7~0 4 0 0 0 0 0 1 0 DESCRIPTION Temperature value [9] (Sign bit) Temperature value [8:2] (Integer bits) Temperature value [1:0] (Fraction bits) 9.328 PECI Command TN Count Value Register – Index 22h (Bank 7) Attribute: Size: Read only 8 bits BIT NAME 7 6 5 4 3 2 PECI Timing Negotiation count Value[7:0] -142 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY DEFAULT 0 0 0 0 BIT 7~0 0 0 0 0 1 0 DESCRIPTION The data would be get from client. Default value is 00HEX. 9.329 PECI Command TN Count Value Register – Index 23h (Bank 7) Attribute: Size: Read only 8 bits BIT 7 6 NAME 5 4 Reserved DEFAULT 0 0 2 PECI Timing Negotiation count Value[11:8] 0 0 BIT 7~0 3 0 0 0 0 1 0 DESCRIPTION The data would be get from client. Default value is 00HEX. 9.330 PECI Command Warning Flag Register – Index 24h (Bank 7) Attribute: Size: Read only 8 bits BIT 7 6 5 4 2 Reserved NAME DEFAULT 0 0 0 Alert Value[1:0] 0 BIT 1~0 3 0 0 0 0 DESCRIPTION Agent Alert Bit (Default value is 0) 0: Agent has valid FCS. 1: Agent has invalid FCS in the previous 3 transactions. Default value is 00HEX. 9.331 PECI Command FCS Data Register – Index 25h (Bank 7) Attribute: Size: Read only 8 bits BIT NAME DEFAULT 7 6 Reserve 0 0 5 4 3 2 1 0 Wraning CC_Fail ZeroWFCS AbortWFCS BadRFCS BadWFCS 0 0 0 0 0 0 -143 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 5~0 DESCRIPTION Retrieve PECI related data from client and host. Default value is 00HEX. 9.332 PECI Command WFCS Data Register – Index 26h (Bank 7) Attribute: Size: Read only 8 bits BIT 7 6 5 4 2 1 0 0 0 0 2 1 0 0 0 0 2 1 0 0 0 0 PECI WFCS NAME DEFAULT 0 0 0 BIT 7~0 3 0 0 DESCRIPTION Retrieve PECI WFCS related data from client. Default value is 00HEX. 9.333 PECI RFCS Data Register – Index 27h (Bank 7) Attribute: Size: Read only 8 bits BIT 7 6 5 4 PECI RFCS NAME DEFAULT 0 0 0 BIT 7~0 3 0 0 DESCRIPTION Retrieve PECI related data from client. Default value is 00HEX. 9.334 PECI AWFCS Data Register – Index 28h (Bank 7) Attribute: Size: Read only 8 bits BIT 7 6 5 4 PECI AWFCS NAME DEFAULT BIT 7~0 3 0 0 0 0 0 DESCRIPTION Retrieve PCI related data from client. Default value is 00HEX. -144 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.335 PECI CRC OUT WFCS Data Register – Index 29h (Bank 7) Attribute: Size: Read only 8 bits BIT 7 6 5 3 2 1 0 0 0 0 2 1 0 0 0 0 2 1 0 0 0 0 1 0 PECI CRC OUT WFCS NAME DEFAULT 0 0 0 BIT 7~0 4 0 0 DESCRIPTION Retrieve PECI related data from client. Default value is 00HEX. 9.336 PECI Command Read Data 1 Register – Index 2Ah (Bank 7) Attribute: Size: Read only 8 bits BIT 7 6 5 3 PECI Read Data 1 NAME DEFAULT 0 0 0 BIT 7~0 4 0 0 DESCRIPTION The data would be get from client. Default value is 00HEX. 9.337 PECI Command Read Data 2 Register – Index 2Bh (Bank 7) Attribute: Size: Read only 8 bits BIT 7 6 5 3 PECI Read Data 2 NAME DEFAULT 0 0 0 BIT 7~0 4 0 0 DESCRIPTION The data would be get from client. Default value is 00HEX. 9.338 PECI Command Read Data 3 Register – Index 2Ch (Bank 7) Attribute: Size: Read only 8 bits BIT 7 6 5 4 -145 3 2 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY NAME PECI Read Data 3 DEFAULT 0 0 0 BIT 7~0 0 0 0 0 0 2 1 0 0 0 0 2 1 0 0 0 0 2 1 0 0 0 0 DESCRIPTION The data would be get from client. Default value is 00HEX. 9.339 PECI Command Read Data 4 Register – Index 2Dh (Bank 7) Attribute: Size: Read only 8 bits BIT 7 6 5 3 PECI Read Data 4 NAME DEFAULT 0 0 0 BIT 7~0 4 0 0 DESCRIPTION The data would be get from client. Default value is 00HEX. 9.340 PECI Command Read Data 5 Register – Index 2Eh (Bank 7) Attribute: Size: Read only 8 bits BIT 7 6 5 3 PECI Read Data 5 NAME DEFAULT 0 0 0 BIT 7~0 4 0 0 DESCRIPTION The data would be get from client. Default value is 00HEX. 9.341 PECI Command Read Data 6 Register – Index 2Fh (Bank 7) Attribute: Size: Read only 8 bits BIT 7 6 5 BIT 3 PECI Read Data 6 NAME DEFAULT 4 0 0 0 0 0 DESCRIPTION -146 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7~0 DESCRIPTION The data would be get from client. Default value is 00HEX. 9.342 PECI Command Read Data 7 Register – Index 30h (Bank 7) Attribute: Size: Read only 8 bits BIT 7 6 5 3 2 1 0 0 0 0 2 1 0 0 0 0 2 1 0 0 0 0 PECI Read Data 7 NAME DEFAULT 0 0 0 BIT 7~0 4 0 0 DESCRIPTION The data would be get from client. Default value is 00HEX. 9.343 PECI Command Read Data 8 Register – Index 31h (Bank 7) Attribute: Size: Read only 8 bits BIT 7 6 5 3 PECI Read Data 8 NAME DEFAULT 0 0 0 BIT 7~0 4 0 0 DESCRIPTION The data would be get from client. Default value is 00HEX. 9.344 PECI Command Read Data 9 Register – Index 32h (Bank 7) Attribute: Size: Read only 8 bits BIT 7 6 5 0 0 BIT 7~0 3 PECI Read Data 9 NAME DEFAULT 4 0 0 0 DESCRIPTION The data would be get from client. Default value is 00HEX. PECI Manual Command Address Table Command Bank 7 Address CR 05HEX WriteLength CR 06HEX -147 Read Length CR 07HEX Command Code CR 08HEX Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Ping 00 00 GetDIB 01 08 F7 GetTemp 01 02 01 PCIRd30 06 02 / 03 / 05 61 PCIWr30 08 / 09 / 0B 01 65 05 02 / 03 / 05 E1 PCIWrLocal30 07 / 08 / 0A 01 E5 PKGRd30 05 02 / 03 / 05 A1 PKGWr30 07 / 08 / 0A 01 A5 IAMSRRd30 05 02 / 03 / 05 / 09 B1 IAMSRWr30 07 / 08 / 0A / 0E 01 B5 Addr PCIRdLocal30 PECI Manual Command Read Data Table Command PCI Rd30 PCI Wr30 PCIRd Local30 PCIWr Local30 PKG Rd30 PKG Wr30 IAMSR Rd30 IAMSR Wr30 GetDIB GetTemp Command Code 61 65 E1 E5 A1 A5 B1 B5 F7 01 RdData 1 CR 2AHEX Ccode Ccode Ccode Ccode Ccode Ccode Ccode Ccode X X RdData 2 CR 2BHEX X X X X X X Data LSB_1 X Device Info X RdData 3 CR 2CHEX X X X X X X Data LSB_2 X Revision Number X RdData 4 CR 2DHEX X X X X X X Data LSB_3 X Reserved 1 X RdData 5 CR 2EHEX X X x X X X Data LSB_4 X Reserved 2 X RdData 6 CR 2FHEX Data LSB_1 X Data LSB_1 X Data LSB_1 X Data LSB_5 X Reserved 3 X RdData 7 CR 30HEX Data LSB_2 X Data LSB_2 X Data LSB_2 X Data LSB_6 X Reserved 4 X RdData 8 CR 31HEX Data LSB_3 X Data LSB_3 X Data LSB_3 X Data LSB_7 X Reserved 5 Temp_LB RdData 9 CR 32HEX Data MSB x Data MSB X Data MSB X Data MSB X Reserved 6 Temp_HB -148 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY PECI Manual Command Write Data Table Command PCI Rd30 PCI Wr30 PCIRd Local30 PCIWr Local30 PKG Rd30 PKG Wr30 IAMSR Rd30 IAMSR Wr30 Command Code 61 65 E1 E5 A1 A5 B1 B5 WrData 1 CR 0BHEX Host ID Host ID Host ID Host ID Host ID Host ID Host ID Host ID WrData 2 CR 0CHEX Addr LSB_1 Addr LSB_1 Addr LSB_1 Addr LSB_1 Index Index Process or ID Process or ID WrData 3 CR 0DHEX Addr LSB_2 Addr LSB_2 Addr LSB_2 Addr LSB_2 Param LSB Param LSB Addr LSB Addr LSB WrData 4 CR 0EHEX Addr LSB_3 Addr LSB_3 Addr MSB Addr MSB Param MSB Param MSB Addr MSB Addr MSB WrData 5 CR 0FHEX Addr MSB Addr MSB X Data LSB_1 X Data LSB_1 X Data LSB_1 WrData 6 CR 10HEX X Data LSB_1 X Data LSB_2 X Data LSB_2 X Data LSB_2 WrData 7 CR 11HEX X Data LSB_2 X Data LSB_3 X Data LSB_3 X Data LSB_3 WrData 8 CR 12HEX X Data LSB_3 X Data MSB X Data MSB X Data LSB_4 WrData 9 CR 13HEX X Data MSB X X X X X Data LSB_5 WrData10 CR 14HEX X X X X X X X Data LSB_6 WrData11 CR 15HEX X X X X X X X Data LSB_7 WrData12 CR 16HEX X X X X X X X Data MSB 9.345 Reserved Register – Index 00h (Bank 8) 9.346 Reserved Register – Index 01h (Bank 8) 9.347 Reserved Register – Index 02h (Bank 8) 9.348 Reserved Register – Index 03h (Bank 8) 9.349 Reserved Register – Index 04h (Bank 8) 9.350 Reserved Register – Index 05h (Bank 8) -149 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.351 Reserved Register – Index 06h (Bank 8) 9.352 Reserved Register – Index 07h (Bank 8) 9.353 Reserved Register – Index 08h (Bank 8) 9.354 Reserved Register – Index 09h (Bank 8) 9.355 Reserved Register – Index 0Ch (Bank 8) 9.356 Reserved Register – Index 0Dh (Bank 8) 9.357 Reserved Register – Index 20h (Bank 8) 9.358 Reserved Register – Index 21h (Bank 8) 9.359 Reserved Register – Index 22h (Bank 8) 9.360 Reserved Register – Index 23h (Bank 8) 9.361 Reserved Register – Index 24h (Bank 8) 9.362 Reserved Register – Index 25h~26h (Bank 8) 9.363 Reserved Register – Index 27h (Bank 8) 9.364 Reserved Register – Index 28h (Bank 8) 9.365 Reserved Register – Index 29h (Bank 8) 9.366 Reserved Register – Index 2Ah (Bank 8) 9.367 Reserved Register – Index Index 2Bh~30h (Bank 8) 9.368 Reserved Register – Index 31h (Bank 8) 9.369 Reserved Register – Index 32h~34h(Bank 8) 9.370 Reserved Register – Index 35h (Bank 8) 9.371 Reserved Register – Index 36h (Bank 8) -150 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.372 Reserved Register – Index 37h (Bank 8) 9.373 Reserved Register – Index 38h (Bank 8) 9.374 Reserved Register – Index 39h (Bank 8) 9.375 Reserved Register – Index 3Ah (Bank 8) 9.376 Reserved Register – Index 3Bh (Bank 8) 9.377 Reserved Register – Index 3Ch (Bank 8) 9.378 Reserved Register – Index 3Dh (Bank 8) 9.379 Reserved Register – Index 3Eh (Bank 8) 9.380 Reserved Register – Index 3Fh (Bank 8) 9.381 Reserved Register – Index 40h (Bank 8) 9.382 Reserved Register – Index 41h (Bank 8) 9.383 Reserved Register – Index 42h ~ FFh (Bank 8) 9.384 Reserved Register – Index 00h (Bank 9) 9.385 Reserved Register – Index 01h (Bank 9) 9.386 Reserved Register – Index 02h (Bank 9) 9.387 Reserved Register – Index 03h (Bank 9) 9.388 Reserved Register – Index 04h (Bank 9) 9.389 Reserved Register – Index 05h (Bank 9) 9.390 Reserved Register – Index 06h (Bank 9) 9.391 Reserved Register – Index 07h (Bank 9) 9.392 Reserved Register – Index 08h (Bank 9) -151 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.393 Reserved Register – Index 09h (Bank 9) 9.394 Reserved Register – Index 0Ch (Bank 9) 9.395 Reserved Register – Index 0Dh (Bank 9) 9.396 Reserved Register – Index 20h (Bank 9) 9.397 Reserved Register – Index 21h (Bank 9) 9.398 Reserved Register – Index 22h (Bank 9) 9.399 Reserved Register – Index 23h (Bank 9) 9.400 Reserved Register – Index 24h (Bank 9) 9.401 Reserved Register – Index 25h~26h (Bank 9) 9.402 Reserved Register – Index 27h (Bank 9) 9.403 Reserved Register – Index 28h (Bank 9) 9.404 Reserved Register – Index 29h (Bank 9) 9.405 Reserved Register – Index 2Ah (Bank 9) 9.406 Reserved Register – Index Index 2Bh~30h (Bank 9) 9.407 Reserved Register – Index 31h (Bank 9) 9.408 Reserved Register – Index 32h~34h(Bank 9) 9.409 Reserved Register – Index 35h (Bank 9) 9.410 Reserved Register – Index 36h (Bank 9) 9.411 Reserved Register – Index 37h (Bank 9) 9.412 Reserved Register – Index 38h (Bank 9) 9.413 Reserved Register – Index 39h (Bank 9) -152 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 9.414 Reserved Register – Index 3Ah (Bank 9) 9.415 Reserved Register – Index 3Bh (Bank 9) 9.416 Reserved Register – Index 3Ch (Bank 9) 9.417 Reserved Register – Index 3Dh (Bank 9) 9.418 Reserved Register – Index 3Eh (Bank 9) 9.419 Reserved Register – Index 3Fh (Bank 9) 9.420 Reserved Register – Index 40h (Bank 9) 9.421 Reserved Register – Index 41h (Bank 9) 9.422 Reserved Register – Index 42h ~ FFh (Bank 9) -153 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 10. UART PORT 10.1 UART Control Register (UCR) (Read/Write) The UART Control Register defines and controls the protocol for asynchronous data communications, including data length, stop bit, parity, and baud rate selection. BIT 7 6 5 4 3 2 1 0 NAME BDLAB SSE PBFE EPE PBE MSBE DLS1 DLS0 DEFAULT 0 0 0 0 0 0 0 0 BIT DESCRIPTION 7 BDLAB (Baud Rate Divisor Latch Access Bit). When this bit is set to logic 1, designers can access the divisor (in 16-bit binary format) from the divisor latches of the baud-rate generator during a read or write operation. When this bit is set to logic 0, the Receiver Buffer Register, the Transmitter Buffer Register, and the Interrupt Control Register can be accessed. 6 SSE (Set Silence Enable). A logic 1 forces the Serial Output (SOUT) to a silent state (a logical 0). Only IRTX is affected by this bit; the transmitter is not affected. 5 PBFE (Parity Bit Fixed Enable). When PBE and PBFE of UCR are both set to logic 1, (1) if EPE is logic 1, the parity bit is logical 0 when transmitting and checking; (2) if EPE is logic 0, the parity bit is logical 1 when transmitting and checking. 4 EPE (Even Parity Enable). When PBE is set to logic 1, this bit counts the number of logic 1’s in the data word bits and determines the parity bit. When this bit is set to logic 1, the parity bit is set to logic 1 if an even number of logic 1’s are sent or checked. When the bit is set to logic 0, the parity bit is logic 1, if an odd number of logic 1’s are sent or checked. 3 PBE (Parity Bit Enable). When this bit is set to logic 1, the transmitter inserts a stop bit between the last data bit and the stop bit of the SOUT, and the receiver checks the parity bit in the same position. 2 MSBE (Multiple Stop Bit Enable). Defines the number of stop bits in each serial character that is transmitted or received. (1) If MSBE is set to logic 0, one stop bit is sent and checked. (2) If MSBE is set to logic 1 and the data length is 5 bits, one-and-a-half stop bits are sent and checked. (3) If MSBE is set to logic 1 and the data length is 6, 7, or 8 bits, two stop bits are sent and checked. 1 DLS1 (Data Length Select Bit 1). Defines the number of data bits that are sent or checked in each serial character. 0 DLS0 (Data Length Select Bit 0). Defines the number of data bits that are sent or checked in each serial character. DLS1 DLS0 DATA LENGTH 0 0 5 bits 0 1 6 bits 1 0 7 bits -154 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY DLS1 DLS0 DATA LENGTH 1 1 8 bits The following table identifies the remaining UART registers. Each one is described separately in the following sections. Table 10-1 Register Summary for UART Bit Number Register Address Base 0 1 2 3 4 5 6 7 +0 BDLAB = 0 Receiver Buffer Register (Read Only) RBR RX Data Bit 0 RX Data Bit 1 RX Data Bit 2 RX Data Bit 3 RX Data Bit 4 RX Data Bit 5 RX Data Bit 6 RX Data Bit 7 +0 BDLAB = 0 Transmitter Buffer Register (Write Only) TBR TX Data Bit 0 TX Data Bit 1 TX Data Bit 2 TX Data Bit 3 TX Data Bit 4 TX Data Bit 5 TX Data Bit 6 TX Data Bit 7 +1 Interrupt Control Register BDLAB = 0 ICR RBR Data Ready Interrupt Enable (ERDRI) TBR Empty Interrupt Enable (ETBREI) USR Interrupt Enable (EUSRI) HSR Interrupt Enable (EHSRI) 0 0 0 0 FIFOs Enabled ** FIFOs Enabled ** +2 Interrupt Status Register (Read Only) ISR “0” if Interrupt Pending Interrupt Status Bit (0) Interrupt Status Bit (1) Interrupt Status Bit (2)** 0 0 +2 UART FIFO Control Register (Write Only) UFR FIFO Enable RCVR FIFO Reset XMIT FIFO Reset DMA Mode Select Reserved Reversed +3 UART Control Register UCR Data Length Select Bit 0 (DLS0) Data Length Select Bit 1 (DLS1) Multiple Stop Bits Enable (MSBE) Parity Bit Enable (PBE) Even Parity Enable (EPE) Parity Bit Fixed Enable PBFE) Set Silence Enable (SSE) Baudrate Divisor Latch Access Bit (BDLAB) +4 Handshake Control Register HCR Data Terminal Ready (DTR) Request to Send (RTS) Loopback RI Input IRQ Enable Internal Loopback Enable 0 0 0 +5 UART Status Register USR RBR Data Ready (RDR) Overrun Error (OER) Parity Bit Error (PBER) No Stop Bit Error (NSER) Silent Byte Detected (SBD) TBR Empty (TBRE) TSR Empty (TSRE) RX FIFO Error Indication (RFEI) ** +6 Handshake Status Register HSR CTS Toggling (TCTS) DSR Toggling (TDSR) RI Falling Edge (FERI) DCD Toggling (TDCD) Clear to Send (CTS) Data Set Ready (DSR) Ring Indicator (RI) Data Carrier Detect (DCD) +7 User Defined Register UDR Bit 0 Bit 1 Bit 2 Bit 3 Bit 4 Bit 5 Bit 6 Bit 7 +0 BDLAB = 1 Baudrate Divisor Latch Low BLL Bit 0 Bit 1 Bit 2 Bit 3 Bit 4 Bit 5 Bit 6 Bit 7 +1 BDLAB = 1 Baudrate Divisor Latch High BHL Bit 8 Bit 9 Bit 10 Bit 11 Bit 12 Bit 13 Bit 14 Bit 15 RX Interrupt RX Interrupt Active Level Active Level (LSB) (MSB) *: Bit 0 is the least significant bit. The least significant bit is the first bit serially transmitted or received. **: These bits are always 0 in 16450 Mode. -155 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 10.2 UART Status Register (USR) (Read/Write) This 8-bit register provides information about the status of data transfer during communication. BIT 7 6 5 4 3 2 1 0 NAME RF EI TSRE TBRE SBD NSER PBER OER RDR DEFAULT 0 1 1 0 0 0 0 0 BIT DESCRIPTION 7 RF EI (RX FIFO Error Indication). In 16450 mode, this bit is always set to logical 0. in 16550 mode, this bit is set to logical 1 when there is at least one parity-bit error and no stop0bit error or silent-byte detected in the FIFO. In 16550 mode, this bit is cleared to logical 0 by reading from the USR if there are no remaining errors left in the FIFO. 6 TSRE (Transmitter Shift Register Empty). In 16450 mode, this bit is set to logical 1 when TBR and TSR are both empty. In 16550 mode, it is set to logical 1 when the transmit FIFO and TSR are both empty. Otherwise, this bit is set to logical 0. 5 TBRE (Transmitter Buffer Register Empty). In 16450 mode, when a data character is transferred from TBR to TSR, this bit is set to logical 1. If ETREI of ICR is high, and interrupt is generated to notify the CPU to write next data. In 16550 mode, this bit is set to logical 1 when the transmit FIFO is empty. It is set to logical 0 when the CPU writes data into TBR or the FIFO. 4 SBD (Silent Byte Detected). This bit is set to logical 1 to indicate that received data are kept in silent state for the time it takes to receive a full word, which includes the start bit, data bits, parity bit, and stop bits. In 16550 mode, it indicates the same condition for the data on the top of the FIFO. When the CPU reads USR, it sets this bit to logical 0. 3 NSER (No Stop Bit Error). This bit is set to logical 1 to indicate that the received data have no stop bit. In 16550 mode, it indicates the same condition for the data on the top of the FIFO. When the CPU reads USR, it sets this bit to logical 0. 2 PBER (Parity Bit Error). This bit is set to logical 1 to indicate that the received data has the wrong parity bit. In 16550 mode, it indicates the same condition for the data on the top of the FIFO. When the CPU reads USR, it sets this bit to logical 0. 1 OER (Overrun Error). This bit is set to logical 1 to indicate that the received data have been overwritten by the next received data before they were read by the CPU. In 16550 mode, it indicates the same condition, instead of FIFO full. When the CPU reads USR, it sets this bit to logical 0. 0 RDR (RBR Data Ready). This bit is set to logical 1 to indicate that the received data are ready to be read by the CPU in the RBR or FIFO. When no data are left in the RBR or FIFO, the bit is set to logical 0. 10.3 Handshake Control Register (HCR) (Read/Write) This register controls pins used with handshaking peripherals such as modems and also controls the diagnostic mode of the UART. BIT 7 6 5 4 3 2 1 0 NAME DEFAULT RESERVED 0 0 0 INTERNAL LOOPBACK ENABLE IRQ ENABLE LOOPBACK RI INPUT RTS DTR 0 0 0 0 0 -156 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT DESCRIPTION 7-5 Reserved. Internal Loopback Enable. When this bit is set to logic 1, the UART enters diagnostic mode, as follows: (1) SOUT is forced to logic 1, and SIN is isolated from the communication link. (2) The modem output pins are set to their inactive state. (3) The modem input pins are isolated from the communication link and connect internally as DTR (bit 0 of HCR) →DSR#, RTS ( bit 1 of HCR) →CTS#, Loopback RI input ( bit 2 of HCR) → RI# and IRQ enable ( bit 3 of HCR) →DCD#. Aside from the above connections, the UART operates normally. This method allows the CPU to test the UART in a convenient way. 4 3 IRQ Enable. The UART interrupt output is enabled by setting this bit to logic 1. In diagnostic mode, this bit is internally connected to the modem control input DCD#. 2 Loopback RI Input. This bit is only used in the diagnostic mode. In diagnostic mode, this bit is internally connected to the modem control input RI#. 1 RTS (Request to Send). This bit controls the RTS# output. The value of this bit is inverted and output to RTS#. 0 DTR (Data Terminal Ready). This bit controls the DTR# output. The value of this bit is inverted and output to DTR#. 10.4 Handshake Status Register (HSR) (Read/Write) This register reflects the current state of four input pins used with handshake peripherals such as modems and records changes on these pins. BIT 7 6 5 4 3 2 1 0 NAME DCD RI DSR CTS TDCD FERI TDSR TCTS DEFAULT NA NA NA NA NA NA NA NA BIT 7 6 DESCRIPTION DCD (Data Carrier Detect). This bit is the inverse of the DCD# input and is equivalent to bit 3 of HCR in Loopback mode. RI (Ring Indicator). This bit is the inverse of the RI# input and is equivalent to bit 2 of HCR in Loopback mode. 5 DSR (Data Set Ready). This bit is the inverse of the DSR# input and is equivalent to bit 0 of HCR in Loopback mode. 4 CTS (Clear to Send). This bit is the inverse of the CTS# input and is equivalent to bit 1 of HCR in Loopback mode. 3 TDCD (DCD# Toggling). This bit indicates that the state of the DCD# pin has changed after HSR is read by the CPU. 2 FERI (RI Falling Edge). This bit indicates that the RI# pin has changed from low to high after HSR is read by the CPU. 1 TDSR (DSR# Toggling). This bit indicates that the state of the DSR# pin has changed after HSR is read by the CPU. 0 TCTS (CTS# Toggling). This bit indicates that the state of the CTS# pin has changed after HSR is read by the CPU. -157 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 10.5 UART FIFO Control Register (UFR) (Write only) This register is used to control the FIFO functions of the UART. 7 BIT 6 NAME MSB LSB DEFAULT 0 0 5 4 3 RESERVED NA 2 1 0 DMA MODE SELECT TRANSMITTER FIFO RESET RECEIVER FIFO RESET FIFO ENABLE 0 0 0 0 NA BIT DESCRIPTION 7 MSB (RX Interrupt Active Level). 6 LSB (RX Interrupt Active Level). 5-4 These two bits are used to set the active level of the receiver FIFO interrupt. The active level is the number of bytes that must be in the receiver FIFO to generate an interrupt. RESERVED. 3 DMS MODE SELECT. When this bit is set to logic 1, DMA mode changes from mode 0 to mode 1 if UFR bit 0 = 1. 2 TRANSMITTER FIFO RESET. Setting this bit to logic 1 resets the TX FIFO counter logic to its initial state. This bit is automatically cleared afterwards. 1 RECEIVER FIFO RESET. Setting this bit to logic 1 resets the RX FIFO counter logic to its initial state. This bit is automatically cleared afterwards. 0 FIFO ENABLE. This bit enables 16550 (FIFO) mode. This bit should be set to logic 1 before other UFR bits are programmed. BIT 7 BIT 6 RX FIFO INTERRUPT ACTIVE LEVEL (BYTES) 0 0 01 0 1 04 1 0 08 1 1 14 10.6 Interrupt Status Register (ISR) (Read only) This register reflects the UART interrupt status. BIT NAME DEFAULT 7 FIFOS ENABLED 0 BIT 7-6 5-4 3 6 0 5 4 RESERVED 0 3 2 1 0 INTERRUPT STATUS BIT 2 INTERRUPT STATUS BIT 1 INTERRUPT STATUS BIT 0 0 IF INTERRUPT PENDING 0 0 0 1 0 DESCRIPTION FIFOS ENABLED. Set to logical 1 when UFR, bit 0 = 1. RESERVED. INTERRUPT STATUS BIT 2. In 16450 mode, this bit is logical 0. In 16550 mode, bits 3 and 2 are set to logical 1 when a time-out interrupt is pending. Please see the table below. -158 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY These two bits identify the priority level of the pending interrupt, as shown in the table below. 2 INTERRUPT STATUS BIT 1. 1 INTERRUPT STATUS BIT 0. 0 0 IF INTERRUPT PENDING. This bit is logic 1 if there is no interrupt pending. If one of the interrupt sources has occurred, this bit is set to logical 0. ISR INTERRUPT SET AND FUNCTION Bit 3 Bit 2 Bit 1 Bit 0 Interrupt priority Interrupt Type Interrupt Source 0 0 0 1 - 0 1 1 0 First UART Receive Status 1. OER = 1 2. PBER =1 3. NSER = 1 4. SBD = 1 Read USR 0 1 0 0 Second RBR Data Ready 1. RBR data ready 2. FIFO interrupt active level reached 1. Read RBR 2. Read RBR until FIFO data under active level 1 1 0 0 Second FIFO Data Timeout Data present in RX FIFO for 4 characters period of time since last access of RX FIFO. Read RBR 0 0 1 0 Third TBR Empty TBR empty 1. Write data into TBR 2. Read ISR (if priority is third) 0 0 0 0 Fourth Handshake status 1. TCTS = 1 2. TDSR = 1 3. FERI = 1 4. TDCD = 1 Read HSR - Clear Interrupt No Interrupt pending - ** Bit 3 of ISR is enabled when bit 0 of UFR is logical 1. 10.7 Interrupt Control Register (ICR) (Read/Write) This 8-bit register enables and disables the five types of controller interrupts separately. A selected interrupt can be enabled by setting the appropriate bit to logical 1. The interrupt system can be totally disabled by setting bits 0 through 3 to logical 0. BIT 7 6 NAME En_address_byte RX_ctrl DEFAULT 0 0 BIT 5 4 RESERVED 0 3 2 1 0 EHSRI EUSRI ETBREI ERDRI 0 0 0 0 0 DESCRIPTION 7 En_address_byte. 0: Tx block will send data byte. (If enable 9bit mode function CRF2 Bit0=1) 1: Tx block will send address byte. (If enable 9bit mode function CRF2 Bit0=1) 6 RX_ctrl. 0: Rx block could receive data byte. (If enable 9bit mode function CRF2 Bit0=1) 1: Rx block could receive address byte. (If enable 9bit mode function CRF2 Bit0=1) 5-4 RESERVED. 3 EHSRI (Handshake Status Interrupt Enable). Set this bit to logical 1 to enable the handshake status register interrupt. 2 EUSRI (UART Receive Status Interrupt Enable). Set this bit to logical 1 to enable the UART status register interrupt. 1 ETBREI (TBR Empty Interrupt Enable). Set this bit to logical 1 to enable the TBR empty -159 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 0 DESCRIPTION interrupt. ERDRI (RBR Data Ready Interrupt Enable). Set this bit to logical 1 to enable the RBR data ready interrupt. 10.8 Programmable Baud Generator (BLL/BHL) (Read/Write) Two 8-bit registers, BLL and BHL, compose a programmable baud generator that uses 24 MHz to generate a 16 1.8461 MHz frequency and divide it by a divisor from 1 to (2 –1). The output frequency of the baud generator is the baud rate multiplied by 16, and this is the base frequency for the transmitter and receiver. The table below illustrates the use of the baud generator with a frequency of 1.8461 MHz. In high-speed UART mode (CR0C, bits 7 and 6), the programmable baud generator directly uses 24 MHz and the same divisor as the normal speed divisor. As a result, in high-speed mode, the data transmission rate can be as high as 1.5M bps. BAUD RATE FROM DIFFERENT PRE-DIVIDER PRE-DIV: 13 1.8461M HZ PREDIV:1.625 14.769M HZ PRE-DIV: 1.0 24M HZ DECIMAL DIVISOR USED TO GENERATE 16X CLOCK ERROR PERCENTAGE 50 400 650 2304 ** 75 600 975 1536 ** 110 880 1430 1047 0.18% 134.5 1076 1478.5 857 0.099% 150 1200 1950 768 ** 300 2400 3900 384 ** 600 4800 7800 192 ** 1200 9600 15600 96 ** 1800 14400 23400 64 ** 2000 16000 26000 58 0.53% 2400 19200 31200 48 ** 3600 28800 46800 32 ** 4800 38400 62400 24 ** 7200 57600 93600 16 ** 9600 76800 124800 12 ** 19200 153600 249600 6 ** 38400 307200 499200 3 ** 57600 460800 748800 2 ** 115200 921600 1497600 1 ** ** Unless specified, the error percentage for all of the baud rates is 0.16%. Note: Pre-Divisor is determined by CRF0 of UART A and B. 10.9 User-defined Register (UDR) (Read/Write) This is a temporary register that can be accessed and defined by the user. -160 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 10.10 UART RS485 Auto Flow Control NCT5532D supports RS485 auto flow control function for UARTA. When enabling the RS485 auto control function, it will automatically drive RTS# pin to logic high or low for UARTA when UART TX block transmits the data. The diagram shown below illustrates the RS485 auto flow control function for UARTA. The default behavior of RTS# pin will drive logic high the time edge between Start bit and bit0 when the UART TX Block start to transmits the data on SOUT pin. Then the RTS# pin will drive logic low later than Stop bit about 1~2 x Bit-time when UART TX Block completes the data transmission. The driving behavior of RTS# will be inverted when we set RS485_RTS_inv_sel bit = 1’b1. (Bit-time: Depends on the baud rate of transmission) The bellowing control register table relates to the RS485 auto flow control function for UARTA. UARTA RTS485_enable Logic Device 2, CRF2_Bit7 RTS485_inv_sel Logic Device 2, CRF2_Bit6 -161 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 11. KEYBOARD CONTROLLER The NCT5532D KBC (8042 with licensed KB BIOS) circuit is designed to provide the functions needed to interface a CPU with a keyboard and/or a PS/2 mouse and can be used with IBM®-compatible personal computers or PS/2-based systems. The controller receives serial data from the keyboard or PS/2 mouse, checks the parity of the data, and presents the data to the system as a byte of data in its output buffer. Then, the controller asserts an interrupt to the system when data are placed in its output buffer. The keyboard and PS/2 mouse are required to acknowledge all data transmissions. No transmission should be sent to the keyboard or PS/2 mouse until an acknowledgement is received for the previous data byte. KINH P17 8042 P24 KIRQ P25 MIRQ P21 GATEA20 P20 KBRST P27 KDAT P10 P26 KCLK T0 GP I/O PINS Multiplex I/O PINS MCLK P23 P12~P16 T1 MDAT P22 P11 Figure 11-1 Keyboard and Mouse Interface 11.1 Output Buffer The output buffer is an 8-bit, read-only register at I/O address 60H (Default, PnP programmable I/O address LD5CR60 and LD5-CR61). The keyboard controller uses the output buffer to send the scan code (from the keyboard) and required command bytes to the system. The output buffer can only be read when the output buffer full bit in the register (in the status register) is logical 1. 11.2 Input Buffer The input buffer is an 8-bit, write-only register at I/O address 60h or 64h (Default, PnP programmable I/O address LD5-CR60, LD5-CR61, LD5-CR62, and LD5-CR63). Writing to address 60h sets a flag to indicate a data write; writing to address 64h sets a flag to indicate a command write. Data written to I/O address 60h is sent to the keyboard (unless the keyboard controller is expecting a data byte) through the controller’s input buffer only if the input buffer full bit (in the status register) is logical 0. -162 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 11.3 Status Register The status register is an 8-bit, read-only register at I/O address 64h (Default, PnP programmable I/O address LD5-CR62 and LD5-CR63) that holds information about the status of the keyboard controller and interface. It may be read at any time. Table 11-1 Bit Map of Status Register BIT BUT FUNCTION 0 Output Buffer Full 1 Input Buffer Full 2 System Flag 3 Command/Data 4 Inhibit Switch 5 Auxiliary Device Output Buffer 6 General Purpose Timeout 7 Parity Error DESCRIPTION 0: Output buffer empty 1: Output buffer full 0: Input buffer empty 1: Input buffer full This bit may be set to 0 or 1 by writing to the system flag bit in the command byte of the keyboard controller. It defaults to 0 after a power-on reset. 0: Data byte 1: Command byte 0: Keyboard is inhibited 1: Keyboard is not inhibited 0: Auxiliary device output buffer empty 1: Auxiliary device output buffer full 0: No time-out error 1: Time-out error 0: Odd parity 1: Even parity (error) -163 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 11.4 Commands Table 11-2 KBC Command Sets COMMAND FUNCTION 20h Read Command Byte of Keyboard Controller 60h Write Command Byte of Keyboard Controller BIT 7 A4h BIT DEFINITION Reserved 6 IBM Keyboard Translate Mode 5 Disable Auxiliary Device 4 Disable Keyboard 3 Reserve 2 System Flag 1 Enable Auxiliary Interrupt 0 Enable Keyboard Interrupt A7h Test Password Returns 0Fah if Password is loaded Returns 0F1h if Password is not loaded Load Password Load Password until a logical 0 is received from the system Enable Password Enable the checking of keystrokes for a match with the password Disable Auxiliary Device Interface A8h Enable Auxiliary Device Interface A9h Interface Test A5h A6h BIT Aah Abh 00 No Error Detected 01 Auxiliary Device "Clock" line is stuck low 02 Auxiliary Device "Clock" line is stuck high 03 Auxiliary Device "Data" line is stuck low 04 Auxiliary Device "Data" line is stuck low Self-test Returns 055h if self-test succeeds Interface Test BIT Adh BIT DEFINITION BIT DEFINITION 00 No Error Detected 01 Keyboard "Clock" line is stuck low 02 Keyboard "Clock" line is stuck high 03 Keyboard "Data" line is stuck low 04 Keyboard "Data" line is stuck high Disable Keyboard Interface -164 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY COMMAND FUNCTION Aeh Enable Keyboard Interface C0h Read Input Port (P1) and send data to the system C1h Continuously puts the lower four bits of Port1 into the STATUS register C2h Continuously puts the upper four bits of Port1 into the STATUS register D0h Send Port 2 value to the system D1h Only set / reset GateA20 line based on system data bit 1 D2h Send data back to the system as if it came from the Keyboard D3h Send data back to the system as if it came from Auxiliary Device D4h Output next received byte of data from system to Auxiliary Device E0h Reports the status of the test inputs FXh Pulse only RC (the reset line) low for 6μs if the Command byte is even -165 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 11.5 Hardware GATEA20/Keyboard Reset Control Logic The KBC includes hardware control logic to speed-up GATEA20 and KBRESET. This control logic is controlled by LD5-CRF0 as follows: 11.5.1 KB Control Register (Logic Device 5, CR-F0) BIT 7 6 NAME KCLKS1 KCLKS0 DEFAULT 1 0 BIT 4 3 RESERVED 0 0 0 2 1 0 P92EN HGA20 HKBRST# 0 0 0 DESCRIPTION 7 KCLKS1. 6 KCLKS0. 5-3 5 Select the KBC clock rate. Bits 76 0 0: Reserved 0 1: Reserved 1 0: KBC clock input is 12 MHz. 1 1: Reserved RESERVED. 2 P92EN (Port 92 Enable). 1: Enables Port 92 to control GATEA20 and KBRESET. 0: Disables Port 92 functions. 1 HGA20 (Hardware GATEA 20). 1: Selects hardware GATE A20 control logic to control GATE A20 signal. 0: Disables GATEA20 control logic functions. 0 HKBRST# (Hardware Keyboard Reset). 1: Selects hardware KB RESET control logic to control KBRESET signal. 0: Disables hardware KB RESET control logic function. When the KBC receives data that follows a “D1” command, the hardware control logic sets or clears GATE A20 according to received data bit 1. Similarly, the hardware control logic sets or clears KBRESET depending on received data bit 0. When the KBC receives an “FE” command, the KBRESET is pulse low for 6 μs (Min.) with a 14 μs (Min.) delay. GATE A20 and KBRESET are controlled by either software or hardware logic, and they are mutually exclusive. Then, GATE A20 and KBRESET are merged with Port92 when the P92EN bit is set. -166 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 11.5.2 Port 92 Control Register (Default Value = 0x24) BIT 7 NAME DEFAULT 6 RES. (0) 0 5 4 RES. (1) 0 3 RES. (0) 1 0 BIT 0 2 1 0 RES. (1) SGA20 PLKBRST# 1 0 0 DESCRIPTION 7-6 RES. (0) 5 RES. (1) 4-3 RES. (0) 2 RES. (1) 1 SGA20 (Special GATE A20 Control) 1: Drives GATE A20 signal to high. 0: Drives GATE A20 signal to low. 0 PLKBRST# (Pulled-low KBRESET). A logical 1 on this bit causes KBRESET to drive low for 6 μS(Min.) with a 14 μS(Min.) delay. Before issuing another keyboard-reset command, the bit must be cleared. -167 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 12. CONSUMER INFRARED REMOTE (CIR) Regarding the receiving of IR Block, the hardware uses the sampling rates of 1us, 25us, 50us and 100us to calculate the widths of H Level and L Level. The results are saved/stored in 32*8 RX FIFO. The max widths of H Level and L Level will be determined by Sample Limit Count Register. During the receiving, the hardware will reflect the FIFO status in RX FIFO Status Register. In addition, the hardware also generates status, such as Data Ready, Trigger Level Reach, FIFO Overrun and FIFO underrun, in RC Status Register. As for the transmission, the user has to set up the Carrier frequency and the transmission mode first and then writes the widths of H Level and L Level via TX FIFO. The hardware will add Carrier to H Level according to the transmission mode. 12.1 CIR Register Table Table 12-1 CIR Register Table RC Block 4 ExtAddr Name 7 6 5 3 2 base+0 IRCON R WIREN TXEN RXEN WRXINV RXINV 1 0 base+1 IRSTS RDR RTR PE RFO TE TTR TFU GH base+2 IREN RDR RTR PE RFO TE TTR TFU GH base+3 RXFCONT base+4 CP Sample Period Select RXFIFO Count MODE Carrier Prescalar Reserved base+5 CC Carrier Period base+6 SLCH Sample Limit Count High Byte base+7 SLCL Sample Limit Count Low Byte base+8 FIFOCON TXFIFOCLR R base+9 base+A base+B base+C base+D base+E base+F IRFIFOSTS SRXFIFO TXFCONT STXFIFO FCCH FCCL IRFSM IR_Pending RX_GS R Tx Trigger Level RXFIFOCLR R Rx Trigger Level RX_FTA RX_Empty RX_Full TX_FTA TX_Empty TX_Full Sample RX FIFO TX FIFO Count Sample TX FIFO Frame Carrier Count High Byte Frame Carrier Count Low Byte Decoder FSM R Encoder FSM 12.1.1 IR Configuration Register – Base Address + 0 Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 NAME Received WIREN TXEN RXEN WRXINV RXINV DEFAULT 0 0 0 0 0 1 BIT 7 6 1 0 Sample Period Select 0 0 DESCRIPTION Received. Wide-band IR Enable -168 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 5 TX Enable 1: Transmission Enable. After confirming that FIFO is not empty, the transmission starts (the hardware will wait until TX FIFO data are written). If TX Enable is set to 0 during the transmission, the transmission stops when the transmission of FIFO data is completed. 0: Transmission Disable. 4 RX Enable 3 Wide-band IR Rx Invert Enable 0: Dongle Carrier ON is high, OFF (Idle) is low. 1: Dongle Carrier ON is low, OFF (Idle) is high. 2 IR Rx Invert Enable 0: Dongle Carrier ON is high, OFF (Idle) is low. 1: Dongle Carrier ON is low, OFF (Idle) is high. 1~0 Sample Period Select 00:1us, 01: 25us, 10: 50us, 11: 100us Note: In the 1us mode, the pulse mode will not function due to the IR regulations. 12.1.2 IR Status Register – Base Address + 1 Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 Name RDR RTR PE RFO TE TTR TFU GH DEFAULT 0 0 0 0 0 0 0 0 BIT DESCRIPTION 7 RX Data Ready (Writing 1 will clear the bit). 6 RX FIFO Trigger Level Reach (Writing 1 will clear the bit). 5 Packet End (Writing 1 will clear the bit). 4 RX FIFO Overrun (Overrun and Data Ready will be simultaneously generated. Writing 1 will clear the bit). 3 TX FIFO Empty (Writing 1 will clear the bit). 2 TX FIFO Trigger Level Reach (Writing 1 will clear the bit). 1 TX FIFO Underrun (Writing 1 will clear the bit). 0 Min Length Detected (Writing 1 will clear the bit) 1: The IR Data length received is shorter than the default value. 0: The IR Data length received is longer than the default value. 12.1.3 IR Interrupt Configuration Register – Base Address + 2 Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 -169 3 2 1 0 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY NAME RDR RTR PE RFO TE TTR TFU GH DEFAULT 0 0 0 0 0 0 0 0 1: Enable interrupt; 0: Disable interrupt BIT DESCRIPTION 7 RX Data Ready 6 RX FIFO Trigger Level Reach 5 Packet End 4 RX FIFO Overrun (Overrun and Data Ready will be simultaneously generated). 3 TX FIFO Empty 2 TX FIFO Trigger Level Reach 1 TX FIFO Underrun 0 Min Length Detected Note. When an Interrupt occurs, it only can be cleared by writing IR Status Register to 1. 12.1.4 RX FIFO Count– Base Address + 5 Attribute: Size: Read 8 bits BIT 7 6 5 4 3 2 1 0 0 0 0 1 0 FIFO Count NAME DEFAULT 0 0 0 0 0 1: Enable; 0: Disable BIT 7~0 DESCRIPTION RX FIFO Count 12.1.5 IR TX Carrier Prescalar Configuration Register (CP) – Base Address + 4 Attribute: Size: Read/Write 8 bits BIT 7 NAME Mode DEFAULT 0 BIT 7 6~1 6 5 4 3 2 Reserved 0 0 0 CP 0 0 0 0 DESCRIPTION Mode 0 : DC Mode 1 : Pulse Mode Reserved. -170 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 0 Carrier Prescalar (CP). This bit is set for the Prescalar value of the IR TX carrier frequency. 12.1.6 IR TX Carrier Period Configuration Register (CC) – Base Address + 5 Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 0 0 0 Carrier Period (CC) NAME DEFAULT 0 0 0 0 0 BIT DESCRIPTION 7~0 This byte is set for IR TX carrier period. The actual carrier period will be: Period = 2 * (2 ^ (CP*2)) * (CC+1) / (System Clock), where the frequency = 1 / period, and System Clock = 24MHz. Setting CP and CC to 0 will cause stop the device to from use using anyno carrier at all (that is, no light modulation, just constant on and off periods). The period count value CC can be any number from 0 to 255. 12.1.7 IR RX Sample Limited Count High Byte Register (RCLCH) – Base Address + 6 Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 2 1 0 0 0 0 Sample Limited Count High Byte NAME DEFAULT 0 0 0 BIT 7~0 4 0 0 DESCRIPTION This byte is defined as the high byte of the limited count in the IR RX mode. 12.1.8 IR RX Sample Limited Count Low Byte Register (RCLCL) – Base Address + 7 Attribute: Size: Read/Write 8 bits BIT 7 6 5 DEFAULT 7~0 3 2 1 0 0 0 0 Sample Limited Count low Byte NAME BIT 4 0 0 0 0 0 DESCRIPTION This byte is defined as the low byte of the limited count in the IR RX mode. Note. (RCLCH, RCLCL) is defined as 16 bits value of the limited count in the IR RX mode. When the RX date length reaches the limited count, Packet End status will appear. 12.1.9 IR FIFO Configuration Register (FIFOCON) – Base Address + 8 -171 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Attribute: Size: Read/Write 8 bits BIT 7 6 NAME TXFIFOCLR Reserved DEFAULT 0 0 5 4 TX Trigger Level 0 BIT 3 2 RXFIFOCLR Reserved 0 0 0 1 0 RX Trigger Level 0 0 DESCRIPTION 7 6 TX FIFO Cleared. Reserved. 5~4 TX Trigger Level Bits 54 0 0: 31 0 1: 24 1 0: 16 1 1: 8 3 RX FIFO Cleared. 2 Reserved. 1~0 RX Trigger Level Bits 10 0 0: 1 0 1: 8 1 0: 16 1 1: 24 12.1.10IR Sample RX FIFO Status Register – Base Address + 9 Attribute: Size: Read Only 8 bits BIT 7 6 5 4 3 2 1 0 NAME IR_Pending RX_GS RX_FTA RX_Empty RX_Full TX_FTA TX_Empty TX_Full DEFAULT 0 0 0 0 0 0 0 0 BIT 7 DESCRIPTION 6 IR Pending 1: No Interrupt 0: Interrupt issue Minimum Length Detect Status. This bit will be cleared when Packet End appears. 5 RX FIFO Trigger Level Active. 4 RX FIFO Empty Flag. 3 RX FIFO Full Flag. -172 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT DESCRIPTION 2 TX FIFO Trigger Level Active. 1 TX FIFO Empty Flag. 0 TX FIFO Full Flag. 12.1.11IR Sample RX FIFO Register – Base Address + A Attribute: Size: Read Only 8 bits BIT 7 NAME Voltage Level 6 5 6~0 3 2 1 0 Sample RX FIFO BIT 7 4 DESCRIPTION Voltage Level 0: Low, 1: High RX data length (Unit : Sample Period) Note: 1. 0x80 is Packet End. The hardware enters the Idle state after checking Rx Channel. 2. When 0x00 represents the glitch packet, it means pulses shorter than 3/4 sample period are received. 3. Pulses that are shorter than 1/4 sample periods will be ignored automatically. 12.1.12TX FIFO Count– Base Address + 5 Attribute: Size: Read 8 bits BIT 7 6 5 4 3 2 1 0 0 0 0 2 1 0 TX FIFO Count NAME DEFAULT 0 0 0 0 0 1: Enable; 0: Disable BIT 7~0 DESCRIPTION TX FIFO Count 12.1.13IR Sample TX FIFO Register – Base Address + C Attribute: Size: Read Only 8 bits BIT 7 NAME Voltage Level 6 5 4 3 Sample TX FIFO -173 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7 6~0 DESCRIPTION Voltage Level 0: Low, 1: High TX data length (Unit : Sample Period) 12.1.14IR Carrier Count High Byte Register – Base Address + D Attribute: Size: Read Only 8 bits BIT 7 6 5 4 3 2 1 0 Carrier Count High Byte NAME BIT DESCRIPTION 7~0 Carrier Count High Byte. This byte records the total amount of the total rising edges until time-out event appears. 12.1.15IR Carrier Count Low Byte Register – Base Address + E Attribute: Size: Read Only 8 bits BIT 7 6 5 4 3 2 1 0 Carrier Count Low Byte NAME BIT DESCRIPTION 7~0 Carrier Count Low Byte. This byte records the total amount of the the rising edges until time-out event appears. After a time-out of reception on the learning receiver, this response is sent to tell the host the carrier frequency of the previous sample. The Carrier Count High Byte (ch) and Carrier Count Low Byte (cl) specify the cycle counts of cycles of the carrier. Carrier counts can also be thought ofregarded as the number of leading edges in the previous sample. This is used toe calculation of the calculate carrier frequency is as followsfollowed: lastCarrierCount(decimal) = ch*256+cl; Thus, Carrier frequency = (lastCarrierCount) / (irPacketOnDuration); The irPacketOnDuration value is the total amount of time that the envelope of the signal was is high. The IR receiver should keep track of the time that of the high envelope is high and return it using this response. This response is unsolicited. It is returned by the receiver when IR arrives but is never explicitly requested. 12.1.16IR FSM Status Register (IRFSM) – Base Address + F Attribute: Size: Read Only 8 bits -174 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7 NAME Reserved DEFAULT 0 6 5 4 Decoder FSM 0 0 BIT 3 2 Reserved 0 0 1 0 Encoder FSM 0 0 0 2 1 0 0 0 0 DESCRIPTION 7 6 Reserved. 5 Decoder continuing status 4 Decoder wait H status 1: idle, 0: RX busy 3 Reserved. 2 Encoder Idle Status. 1: idle, 0: TX busy 1 Encoder Read Status 0 Encoder Level Output Status Decoder over status 12.1.17IR Minimum Length Register – Base Address + F Attribute: Size: Write Only 8 bits BIT 7 6 5 4 3 Min Length Register NAME DEFAULT 0 0 0 0 0 BIT DESCRIPTION 7~0 Min Length Register. Set up the shortest expected length of each carrier on the RX receiver (Unit: Sample Clock). -175 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 13. CONSUMER INFRARED REMOTE (CIR) WAKE-UP One of the features of the NCT5532D is system boot-up by a remote controller. The hardware will store a specifically appointed key command from the IR remote controller in the FIFO of 67Byte. The same key is required to re-boot the system after the computer shut-down. Such way can be applied to any remote controllers. Learning is necessary only at the first time. 13.1 CIR WAKE-UP Register Table RC Block 4 ExtAddr Name 7 6 5 3 2 base+0 IRCON DEC_RST Mode[1] Mode[0] RXEN IgnoreEN RXINV base+1 IRSTS RDR RTR PE RFO GH R base+2 IREN RDR RTR PE RFO GH FIFO_COMPARE_DEEP base+4 base+5 FIFO_COMPARE_TOLERANCE FIFO_Count Base+6 SLCH Sample Limit Count High Byte base+7 SLCL Sample Limit Count Low Byte base+8 FIFOCON base+9 base+A base+B Base+C Base+D Base+E SRXFSTS GS Base+F IRFSM R RXFIFOCLR FTA Empty 0 R IR Pending R Base+3 R 1 Sample Period Select R Full Sample RX FIFO WR_FIFO_DATA Read FIFO Only Read FIFO Only Index FIFO_Ignore Decoder FSM Rx Trigger Level R Wakeup Event R 13.1.1 IR Configuration Register – Base Address + 0 Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 NAME DEC_RST Mode[1] Mode[0] RXEN Received RXINV DEFAULT 0 0 1 0 0 1 BIT 1 0 Sample Period Select 1 0 DESCRIPTION 7 Reset CIR DECODER ( Write 1 to clear) 6 Mode[1] : 0: FIFO can’t be written 1: FIFO can be written 5 Mode[0] 0: Learning Mode 1: Wake up Mode (Before enter in Power S3 state, this bit should be set) This bit reset by VCC. -176 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT DESCRIPTION 4 RX Enable 3 Ignore Bit Enable 2 IR Rx Invert Enable 0: Dongle Carrier ON is high, OFF (Idle) is low. 1: Dongle Carrier ON is low, OFF (Idle) is high. 1~0 Sample Period Select 00:1us, 01: 25us, 10: 50us, 11: 100us Note: In the 1us mode, the pulse mode will not function due to the IR regulations. 13.1.2 IR Status Register – Base Address + 1 Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 NAME RDR RTR PE RFO GH DEFAULT 0 0 0 0 0 BIT 2 1 0 Received 0 IR_Pending 0 0 DESCRIPTION 7 6 RX Data Ready (Writing 1 will clear the bit). RX FIFO Trigger Level Reach (Writing 1 will clear the bit). 5 Packet End (Writing 1 will clear the bit). 4 RX FIFO Overrun (Overrun and Data Ready will be simultaneously generated. Writing 1 will clear the bit). 3 Min Length Detected (Writing 1 will clear the bit) 1: The IR Data length received is shorter than the default value. 0: The IR Data length received is longer than the default value. 2~1 0 Reserved. IR Pending 1: No Interrupt 0: Interrupt issue 13.1.3 IR Interrupt Configuration Register – Base Address + 2 Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 NAME RDR RTR PE RFO GH DEFAULT 0 0 0 0 0 2 1 0 Reserved 0 0 0 1: Enable interrupt; 0: Disable interrupt BIT DESCRIPTION -177 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 7 RX Data Ready 6 RX FIFO Trigger Level Reach 5 Packet End 4 RX FIFO Overrun (Overrun and Data Ready will be simultaneously generated). 3 Min Length Detected 2~0 Reserved Note. When an Interrupt occurs, it only can be cleared by writing IR Status Register to 1. 13.1.4 IR TX Configuration Register – Base Address + 3 Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 0 1 1 2 1 0 0 0 0 FIFO Compare Deep NAME DEFAULT 0 1 0 0 0 1: Enable; 0: Disable BIT 7~0 DESCRIPTION When in S3 state, how many bytes need to compare. Default is 67 bytes. 13.1.5 IR FIFO Compare Tolerance Configuration Register – Base Address + 4 Attribute: Size: Read/Write 8 bits BIT 7 6 5 3 FIFO Compare Tolerance NAME DEFAULT 0 0 0 BIT 7~0 4 0 0 DESCRIPTION FIFO Data Tolerance between Learning mode and Wakeup mode. (Every byte) FIFO Date Tolerance = (Learning mode data) – (Wakeup mode data) 13.1.6 RX FIFO Count– Base Address + 5 Attribute: Size: Read 8 bits BIT 7 6 5 3 2 1 0 0 0 0 FIFO Count NAME DEFAULT 4 0 0 0 0 0 1: Enable; 0: Disable BIT DESCRIPTION -178 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 7~0 RX FIFO Count 13.1.7 IR RX Sample Limited Count High Byte Register (RCLCH) – Base Address + 6 Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 2 1 0 0 0 0 Sample Limited Count High Byte NAME DEFAULT 0 0 0 0 BIT 7~0 3 0 DESCRIPTION This byte is defined as the high byte of the limited count in the IR RX mode. 13.1.8 IR RX Sample Limited Count Low Byte Register (RCLCL) – Base Address + 7 Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 2 1 0 0 0 0 Sample Limited Count low Byte NAME DEFAULT 0 0 0 0 BIT 7~0 3 0 DESCRIPTION This byte is defined as the low byte of the limited count in the IR RX mode. Note. (RCLCH, RCLCL) is defined as 16 bits value of the limited count in the IR RX mode. When the RX date length reaches the limited count, Packet End status will appear. 13.1.9 IR FIFO Configuration Register (FIFOCON) – Base Address + 8 Attribute: Size: Read/Write 8 bits BIT 7 5 4 Reserved NAME DEFAULT 0 BIT 0 0 3 2 RXFIFOCLR Reserved 0 0 0 1 0 RX Trigger Level 0 0 DESCRIPTION 7~4 3 Reserved 2 Reserved. 1~0 6 RX FIFO Cleared. RX Trigger Level Bits 10 0 0: 67 0 1: 66 -179 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 1 0: 65 1 1: 64 13.1.10IR Sample RX FIFO Status Register – Base Address + 9 Attribute: Size: Read Only 8 bits BIT 7 6 5 4 NAME GS FTA Empty Full DEFAULT 0 0 0 0 BIT 3 2 1 0 0 0 Reserved 0 0 DESCRIPTION 7 6 Minimum Length Detect Status. This bit will be cleared when Packet End appears. 5 RX FIFO Empty Flag. 4 RX FIFO Full Flag. 3~0 RX FIFO Trigger Level Active. Reserved 13.1.11IR Sample RX FIFO Register – Base Address + A Attribute: Size: Read Only 8 bits BIT 7 NAME Voltage Level 6 5 0 3 2 1 0 Sample RX FIFO BIT 7~6 4 DESCRIPTION Voltage Level 0: Low, 1: High RX data length (Unit : Sample Period) Note: 1. 0x80 is Packet End. The hardware enters the Idle state after checking Rx Channel. 2. When 0x00 represents the glitch packet, it means pulses shorter than 3/4 sample period are received. 3. Pulses that are shorter than 1/4 sample periods will be ignored automatically. 13.1.12Write FIFO – Base Address + B Attribute: Size: Write Only 8 bits BIT 7 NAME Voltage Level BIT 6 5 4 3 2 1 0 Write Sample RX FIFO DESCRIPTION -180 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7~6 0 DESCRIPTION Voltage Level 0: Low, 1: High RX data length (Unit : Sample Period) Note. Before writing FIFO Data, mode[1] register should be set. 13.1.13Read FIFO Only – Base Address + C Attribute: Size: Read Only 8 bits BIT 7 NAME Voltage Level 6 5 4 0 2 1 0 2 1 0 Sample RX FIFO BIT 7~6 3 DESCRIPTION Voltage Level 0: Low, 1: High RX data length (Unit : Sample Period) Note. Only Read FIFO Data. 13.1.14Read FIFO Index – Base Address + D Attribute: Size: Read Only 8 bits BIT 7 6 4 3 FIFO Index NAME BIT 7~0 5 DESCRIPTION Indicate that FIFO Index when only read FIFO data(Base Address + C) Note. Only Read FIFO Data. 13.1.15Reserved – Base Address + E -181 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 13.1.16 IR FSM Status Register (IRFSM) – Base Address + F Attribute: Size: Read Only 8 bits BIT 7 NAME Reserved DEFAULT 0 6 5 0 2 0 1 Wake up event Reserved 0 0 0 0 0 0 DESCRIPTION Reserved 6~4 CIR State Machine 3~1 Reserved 0 3 Decoder FSM BIT 7 4 Wake up event: 0: CIR wake up event has not been triggered. 1: CIR wake up event has been triggered. (Wake up event clear: Write 11b to “Logic Decice A, CRE8h, bit7~6” then 00b.) 13.1.17IR Minimum Length Register – Base Address + F Attribute: Size: Write Only 8 bits BIT 7 6 5 4 3 2 1 0 0 0 0 Min Length Register NAME DEFAULT 0 0 0 0 0 BIT DESCRIPTION 7~0 Min Length Register. Set up the shortest expected length of each carrier on the RX receiver (Unit: Sample Clock). -182 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 14. POWER MANAGEMENT EVENT The PME# signal is connected to the South Bridge and is used to wake up the system from S1 ~ S5 sleeping states. One control bit and four registers in the NCT5532D are associated with the PME function. The control bit is at Logical Device A, CR[F2h], bit[0] and is for enabling or disabling the PME function. If this bit is set to “0”, the NCT5532D won’t output any PME signal when any of the wake-up events has occurred and is enabled. The four Note.1 registers are divided into PME status registers and PME interrupt registers of wake-up events . 1) The PME status registers of wake-up event: - At Logical Device A, CR[F3h] and CR[F4h] - Each wake-up event has its own status - The PME status should be cleared by writing a “1” before enabling its corresponding bit in the PME interrupt registers 2) The PME interrupt registers of wake-up event: - At Logical Device A, CR[F6h] and CR[F7h] - Each wake-up event can be enabled / disabled individually to generate a PME# signal Note.1 PME wake-up events that the NCT5532D supports include: z Mouse event* z Keyboard event* z GP41 events * z CIR* z UART A IRQ event z IR IRQ event z Hardware Monitor IRQ event z WDT1 event z RIA (UARTA Ring Indicator) event Note.2 All the above support both S0 and S1 states. Events with the “*” mark also support S3 ~ S5 states. 14.1 Power Control Logic This chapter describes how the NCT5532D implements its ACPI function via these power control pins: PSIN#, PSOUT#, SLP_S3# and PSON#. The following figure illustrates the relationships. Figure 14-1 Power Control Mechanism -183 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 14.1.1 PSON# Logic 14.1.1.1. Normal Operation The PSOUT# signal will be asserted low if the PSIN# signal is asserted low. The PSOUT# signal is held low for as long as the PSIN# is held low. The South Bridge controls the SLP_S3# signal through the PSOUT# signal. The PSON# is directly connected to the power supply to turn on or off the power. Figure 14-2 shows the power on and off sequences. The ACPI state changes from S5 to S0, then to S5 Figure 14-2 Power Sequence from S5 to S0, then Back to S5 14.1.2 AC Power Failure Resume By definition, AC power failure means that the standby power is removed. The power failure resume control logic of the NCT5532D is used to recover the system to a pre-defined state after AC power failure. Two control bits at Logical Device A, CR[E4h], bits[6:5] indicate the pre-defined state. The definition of these two bits is listed in the following table: Table 14-1 Bit Map of Logical Device A, CR[E4h], Bits[6:5] -184 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY LOGICAL DEVICE A, CR[E4H], BITS[6 :5] DEFINITION 00 System always turns off when it returns from AC power failure 01 System always turns on when it returns from AC power failure 10 System turns off / on when it returns from power failure depending on the state before the power failure. (Please see Note 1) 11 User defines the state before the power failure. (The previous state is set at CRE6[4]. Please see Note 2) Note1. The NCT5532D detects the state before power failure (on or off) through the SLP_S3# signal and the 3VCC power. The relation is illustrated in the following two figures. 3VCC SLP_S3# Figure 14-3 The previous state is “on” 3VCC falls to 2.6V and SLP_S3# keeps at 2.0V. 3VCC SLP_S3# Figure 14-4 The previous state is “off”. 3VCC falls to 2.6V and SLP_S3# keeps at 0.8V. Note 2. Logical Device A, CR[E6h] bit [4] Definition 0 User defines the state to be “on” 1 User defines the state to be “off” To ensure that VCC does not fall faster than VSB in various ATX Power Supplies, the NCT5532D adds the option of “user define mode” for the pre-defined state before AC power failure. BIOS can set the pre-defined state to be “On” or “Off”. According to this setting, the system is returned to the pre-defined state after the AC power recovery. 14.2 Wake Up the System by Keyboard and Mouse -185 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY The NCT5532D generates a low pulse through the PSOUT# pin to wake up the system when it detects a key code pressed or mouse button clicked. The following sections describe how the NCT5532D works. 14.2.1 Waken up by Keyboard events The keyboard Wake-Up function is enabled by setting Logical Device A, CR[E0h], bit 6 to “1”. There are two keyboard events can be used for the wake-up 1) Any key – Set bit 0 at Logical Device A, CR[E0h] to “1” (Default). 2) Specific keys (Password) – Set bit 0 at Logical Device A, CR[E0h] to “0”. Three sets of specific key combinations are stored at Logical Device A. CR[E1h] is an index register to indicate which byte of key code storage (0x00h ~ 0x0Eh, 0x30h ~ 0x3Eh, 0x40h ~ 0x4Eh) is going to be read or written through CR[E2h]. According to IBM 101/102 keyboard specification, a complete key code contains a 1-byte make code and a 2-byte break code. For example, the make code of “0” is 0x45h, and the corresponding break code is 0xF0h, 0x45h. The approach to implement Keyboard Password Wake-Up Function is to fill key codes into the password storage. Assume that we want to set “012” as the password. The storage should be filled as below. Please note that index 0x09h ~ 0x0Eh must be filled as 0x00h since the password has only three numbers. Index(CRE1)Æ 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E D a t a (CRE2)Æ 1E F0 1E 16 F0 16 45 F0 45 00 00 00 00 00 00 First-pressed key “0” Second-pressed key “1” Third-pressed key “2” 14.2.2 Waken up by Mouse events The mouse Wake-Up function is enabled by setting Logical Device A, CR[E0h], bit 5 to “1”. The following specific mouse events can be used for the wake-up: z Any button clicked or any movement z One click of the left or the right button z One click of the left button z One click of the right button z Two clicks of the left button z Two clicks of the right button. Three control bits (ENMDAT_UP, MSRKEY, MSXKEY) define the combinations of the mouse wake-up events. Please see the following table for the details. Table 14-2 Definitions of Mouse Wake-Up Events ENMDAT_UP (LOGICAL DEVICE A, CR[E6H], BIT 7) MSRKEY (LOGICAL DEVICE A, CR[E0H], BIT 4) MSXKEY (LOGICAL DEVICE A, CR[E0H], BIT 1) -186 WAKE-UP EVENT Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY ENMDAT_UP (LOGICAL DEVICE A, CR[E6H], BIT 7) MSRKEY (LOGICAL DEVICE A, CR[E0H], BIT 4) MSXKEY (LOGICAL DEVICE A, CR[E0H], BIT 1) 1 x 1 Any button clicked or any movement. 1 x 0 One click of the left or right button. 0 0 1 One click of the left button. 0 1 1 One click of the right button. 0 0 0 Two clicks of the left button. 0 1 0 Two clicks of the right button. WAKE-UP EVENT 14.3 Resume Reset Logic The RSMRST# signal is a reset output and is used as the VSB power on reset signal for the South Bridge. When the NCT5532D detects the 3VSB voltage rises to “V1”, it then starts a delay – “t1” before the rising edge of RSMRST# asserting. If the 3VSB voltage falls below “V2”, the RSMRST# de-asserts immediately. Timing and voltage parameters are shown in Figure 14-5 and Table 14-3. 3VSB V1 V2 RSMRST# t1 Figure 14-5 Mechanism of Resume Reset Logic Table 14-3 Timing and Voltage Parameters of RSMRST# NAME PARAMETER V1 3VSB Valid Voltage V2 3VSB Ineffective Voltage t1 Valid 3VSB to RSMRST# inactive -187 MIN. MAX. UNIT - 3.033 V 2.882 - V 100 200 mS Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 15. SERIALIZED IRQ The NCT5532D supports a serialized IRQ scheme. This allows a signal line to be used to report the parallel interrupt requests. Since more than one device may need to share the signal serial SERIRQ signal, an open drain signal scheme is employed. The clock source is the PCI clock. The serialized interrupt is transferred on the SERIRQ signal, one cycle consisting of three frames types: the Start Frame, the IRQ/Data Frame, and the Stop Frame. 15.1 Start Frame There are two modes of operation for the SERIRQ Start Frame: Quiet mode and Continuous mode. In the Quiet mode, the NCT5532D drives the SERIRQ signal active low for one clock, and then tri-states it. This brings all the state machines of the NCT5532D from idle to active states. The host controller (the South Bridge) then takes over driving SERIRQ signal low in the next clock and continues driving the SERIRQ low for programmable 3 to 7 clock periods. This makes the total number of clocks low 4 to 8 clock periods. After these clocks, the host controller drives the SERIRQ high for one clock and then tri-states it. In the Continuous mode, the START Frame can only be initiated by the host controller to update the information of the IRQ/Data Frame. The host controller drives the SERIRQ signal low for 4 to 8 clock periods. Upon a reset, the SERIRQ signal is defaulted to the Continuous mode for the host controller to initiate the first Start Frame. Please see the diagram below for more details. Start Frame Timing with source sampled a low pulse on IRQ1. START FRAME SL or H H R T IRQ0 FRAME IRQ1 FRAME S S R T R T SMI# FRAME S R T PCICLK START 1 SERIRQ 2 Drive Source IRQ1 None Host Controller IRQ1 None Figure 15-1 Start Frame Timing with Source Sampled A Low Pulse on IRQ1 H=Host Control SL=Slave Control R=Recovery T=Turn-around S=Sample Note: 1. The Start Frame pulse can be 4-8 clocks wide. 2. The first clock of Start Frame is driven low by the NCT5532D because IRQ1 of the NCT5532D needs an interrupt request. Then the host takes over and continues to pull the SERIRQ low. -188 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 15.2 IRQ/Data Frame Once the Start Frame has been initiated, the NCT5532D must start counting frames based on the rising edge of the start pulse. Each IRQ/Data Frame has three clocks: the Sample phase, the Recovery phase, and the Turnaround phase. During the Sample phase, the NCT5532D drives SERIRQ low if the corresponding IRQ is active. If the corresponding IRQ is inactive, then SERIRQ must be left tri-stated. During the Recovery phase, the NCT5532D device drives the SERIRQ high. During the Turn-around phase, the NCT5532D device leaves the SERIRQ tristated. The NCT5532D starts to drive the SERIRQ line from the beginning of “IRQ0 FRAME” based on the rising edge of PCICLK. The IRQ/Data Frame has a specific numeral order, as shown in Table 15-1. Table 15-1 SERIRQ Sampling Periods SERIRQ SAMPLING PERIODS IRQ/DATA FRAME SIGNAL SAMPLED # OF CLOCKS PAST START EMPLOYED BY 1 IRQ0 2 Reserved 2 IRQ1 5 Keyboard 3 SMI# 8 H/W Monitor & SMI 4 IRQ3 11 IR 5 IRQ4 14 UART A 6 IRQ5 17 - 7 IRQ6 20 Reserved 8 IRQ7 23 Reserved 9 IRQ8 26 - 10 IRQ9 29 - 11 IRQ10 32 - 12 IRQ11 35 - 13 IRQ12 38 Mouse 14 IRQ13 41 Reserved 15 IRQ14 44 - 16 IRQ15 47 - 17 IOCHCK# 50 - 18 INTA# 53 - 19 INTB# 56 - 20 INTC# 59 - 21 INTD# 62 - 32:22 Unassigned 95 - 15.3 Stop Frame -189 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY After all IRQ/Data Frames have completed, the host controller will terminates SERIRQ with a Stop frame. Only the host controller can initiate the Stop Frame by driving SERIRQ low for 2 or 3 clocks. If the Stop Frame is low for 2 clocks, the Sample mode of next SERIRQ cycle’s Sample mode is the Quiet mode. If the Stop Frame is low for 3 clocks, the Sample mode of next SERIRQ cycle is the Continuous mode. Please see the diagram below for more details. Stop Frame Timing with Host Using 17 SERIRQ sampling period. IRQ14 FRAME S R IRQ15 FRAME T S R IOCHCK# FRAME T S R T STOP FRAME I1 H R NEXT CYCLE T PCICLK STOP SERIRQ Driver None IRQ15 None START 2 Host Controller Figure 15-2 Stop Frame Timing with Host Using 17 SERIRQ Sampling Period H=Host Control R=Recovery T=Turn-around S=Sample I= Idle. Note: 1. There may be none, one or more Idle states during the Stop Frame. 2. The Start Frame pulse of next SERIRQ cycle may or may not start immediately after the turn-around clock of the Stop Frame. -190 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 16. WATCHDOG TIMER The Watchdog Timer of the NCT5532D consists of an 8-bit programmable time-out counter and a control and status register. GPIO2, GPIO4, GPIO5, GPIO7 provides an alternative WDT1 function. This function can be configured by the relative GPIO control register. The units of Watchdog Timer counter can be selected at Logical Device 8, CR[F5h], bit[3]. The time-out value is set at Logical Device 8, CR[F6h]. Writing zero disables the Watchdog Timer function. Writing any non-zero value to this register causes the counter to load this value into the Watchdog Timer counter and start counting down. When Watchdog Timer 1 time-out event is occurring, GPIO2, GPIO4, bit[0] & [4] and GPIO7, bit[0] will trigger a low pluse apporx 100mS or low level by Logical Device 8 CR[F5h], bit[0]. In other words, when the value is counted down to zero, the timer stops, and the NCT5532D sets the WDT1 status bit in Logical Device 8, CR[F7h], bit[4]. Writing a zero will clear the status bit. it. This bit will also be cleared if LRESET# or PWROK# signal is asserted. -191 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 17. GENERAL PURPOSE I/O 17.1 GPIO ARCHITECTURE The NCT5532D provides 23 input/output ports that can be individually configured to perform a simple basic I/O function or alternative, pre-defined function. Users can configure each individual port to be an input or output port by programming respective bit in selection register (0 = output, 1 = input). Invert port value by setting inversion register (0 = non–inverse, 1 = inver-se). Port value is read/write through data register. In addition, only GP41 is designed to be able to assert PSOUT# or PME# signal to wake up the system if any of them has any transitions. There are about 16ms debounced circuit inside GP41 and it can be disabled by programming respective bit (LD9, CR[Feh] bit 4~7). The following table gives more detailed register map on GP41. Table 17-1 Relative Control Registers of GPIO 41 that Support Wake-Up Function GPIO41 (PIN52) EVENTROUTE I (PSOUT#) EVENTROUTE II (PME#) EVENT DEBOUNCED 0 : DISABLE 1 : ENABLE 0 : DISABLE 1 : ENABLE 0 : ENABLE 1 : DISABLE LDA, CR[FEh] bit7 LDA, CR[FEh] bit3 LD9, CR[FEh] bit4 Table 17-2 GPIO Group Programming Table Equips maximum 23-pin GPIOs GPIO2 Group Enable: Logic Device 9, CR30[2] Data: Logic Device 9, E0~E3 Multi-function: WDTO, SMI, BEEP, GRN, OVT (Logic Device 9, CRE9[0~7]) Reset: Logic Device A, CRE9[2] OD/PP: Logic Device F, CRE1 Name Pin Default function Default type GPIO power plane Switch default function to GPIO GP20 27 KDAT Bi-direction 3VSB GP21 26 KCLK Bi-direction 3VSB GP22 25 MDAT Bi-direction 3VSB GP23 24 MCLK Bi-direction 3VSB GP24 46 CIRRX Input 3VSB GP25 47 CIRTX Output 3VSB GP26 58 TSIC Input 3VSB CR2A[0]=1 CR2A[1]=1 CR27[3]=0, CR1B[4]=0 CR2C[0]=0 GPIO4 Group Enable: Logic Device 9, CR30[4] Data: Logic Device 9, F0~F2, E8 Multi-function: SMI, BEEP (Logic Device 9, CREE[0~7]) Reset: Logic Device A, CRE9[4] -192 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY OD/PP: Logic Device F, CRE3 Name Pin Default function { LPT_EN } GP41 23 0 1 Default type GPIO power plane Switch default function to GPIO { LPT_EN } MSCL 0 Input INIT# 1 Otput { LPT_EN } { LPT_EN } 0 MSDA 0 Input GP42 22 1 SLIN# 1 Output 0 GRN_LED 0 Output 1 BUSY 1 Input 3VSB CR1A[3:2]=10, LPT_EN=0 3VSB CR1B[2:1]=11, LPT_EN=0 GPIO5 Group Enable: Logic Device 9, CR30[5] Data: Logic Device 9, F4~F7 Multi-function: WDT, SLPS5_LATCH, GRN, YLW (Logic Device 8, CREB[0~7]) Reset: Logic Device A, CRE9[5] OD/PP: Logic Device F, CRE4 Name Pin Default function { DSW_EN } GP54 44 0 1 0 Input SLP_SUS# 1 Input 1 GP56 42 0 SLP_SUS_FET 1 Output 0 0 Input 1 Output (OD) VCORE_EN { AMDPWR_EN } { AMDPWR_EN } 0 0 Input 1 Output (OD) 1 GP57 VLDT_EN 3VSB Input { AMDPWR_EN } GP56 3VSB { DSW_EN } { AMDPWR_EN } 1 GP57 41 GP55 GPIO power plane Switch default function to GPIO { DSW_EN } GP54 { DSW_EN } GP55 43 0 Default type 3VSB Strapping by AMDPWR_EN or CR2F[5] 3VSB GPIO7 Group Enable: Logic Device 9, CR30[7] Data: Logic Device 7, E0~E3 Multi-function: GRN, BEEP (Logic Device 7, CREC[0~3]) Reset: Logic Device A, CRE5[4] OD/PP: Logic Device F, CRE6 Name Pin Default function Default type GPIO power plane Switch default function to GPIO GP74 36 RSTOUT0# Output 3VSB -193 CR2B[5]=1 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY GP75 35 RSTOUT1# Output 3VSB CR2B[6]=1 GPIO8 Group Enable: Logic Device 9, CR30[0] Data: Logic Device 7, E4~E7 Multi-function: YLW, BEEP, SMI, WDTO (Logic Device 7, CRED[0~6]) Reset: Logic Device A, CRE5[5] OD/PP: Logic Device F, CRE7 Name Pin Default function Default type GPIO power plane Switch default function to GPIO GP80 13 GP80 Input 3VSB GP81 14 GP81 Input 3VSB GP82 15 GP82 Input 3VSB GP83 16 GP83 Input 3VSB GP84 17 GP84 Input 3VSB { UARTP80_EN } GP85 18 0 1 { UARTP80_EN } GP85 0 Input SOUTA_P80 1 Output 3VSB GP86 19 GP86 Input 3VSB GP87 20 GP87 Input 3VSB -194 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 17.2 ACCESS CHANNELS There are two different channels to set up/access the GPIO ports. The first one is the indirect access via register 2E/2F (4E/4F, it depends by HEFRAS trapping). The registers can be read / written only when the respective logical device ID and port number are selected. The other is the direct access through GPIO register table that can be configured by {CR61, CR60} of logic device 8. The mapped 7 registers are defined in table 17-3. Base address plus 0 to 4 are GPIO registers, base address plus 5 and 6 are watchdog registers.Since the base address is set, the GPIO number can be selected by writing the group number to GSR [INDEX] (GPIO Select Register, #0~#7 for GPIO0 ~ GPIO7 respectively). Then the I/O register, the Data register and the Inversion register are mapped to addresses Base+0, Base+1 and Base+2 respectively. Only one GPIO can be accessed at one time. Table 17-3 GPIO Register Addresses ADDRESS ABBR Base + 0 GSR IOR DAT INV DST Wdtmod Wdttim Base + 1 Base + 2 Base + 3 Base + 4 Base + 5 Base + 6 7 6 5 BIT NUMBER 4 3 2 1 0 Reserved INDEX GPIO I/O Register GPIO Data Register GPIO Inversion Register GPIO Status Register Watchdog Timer I (WDT1) and KBC P20 Control Mode Register Watchdog Timer I (WDT1) Control Register -195 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 18. SMBUS MASTER INTERFACE 18.1 General Description The SMBus interface module is two wire serial interface compatible to the SMBus physical layer. It is also 2 compatible with Intel’s SMBus and Philips’ I C bus. The rest of this section introduces the various features of the SMBus master capability. These features are divided into the following sections: 2 ‹ SMBus and I C compliant ‹ AMD-TSI ‹ PCH ‹ SMBus master 18.2 Introduction to the SMBus Master 18.2.1 Data Transfer Format Every byte transferred on the bus consists of 8 bits. After the start condition, the master places the 7-bit address to the slave device it wants to address on the bus. The address followed an eight bit indicating the direction of the data transfer (R/W#); a zero indicates a transmission for data while a one indicates a request for data. Each byte is transferred with the most significant bit first, and after each byte, an acknowledge signal must follow. A data transfer is always terminated by stop condition generated by master. Figure 18-1 Data Transfer Format 18.2.2 Arbitration Arbitration takes place on the SMBDAT data line while the SMBCLK line is high. Two devices may generate a start condition at the same time and enter the arbitration procedure. Arbitration continues until one master generates a HIGH level on the SMBDAT line while another competing master generates a LOW level on the SMBDAT line while SMBCLK is high. The master device which generated the HIGH level on SMBDAT loses arbitration. If a device loses arbitration during the first byte following a start condition i.e. while transmitting a slave address it becomes a slave receiver and monitors the address for a potential match. Arbitration may also be lost in the master receive mode during the acknowledge cycle. -196 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Figure 18-2 SMBus Arbitration 18.2.3 Clock Synchronization Clock synchronization is performed while the arbitration procedure described above is in effect. Clock Synchronization takes place between two competing devices by utilizing the wired-AND nature of the SMBCLK line. The SMBCLK line will go low as soon as the master with the shortest high time pulls SMBCLK low. SMBCLK will remain low until the device with the longest SMBCLK low time relinquishes the SMBCLK line. Therefore the SMBCLK high time is determined by device with the shortest high time while the SMBCLK low time is determined by the device with the longest low time. Figure 18-3 Clock synchronization -197 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 18.3 SB-TSI The combined-format repeated start sequence is not supported in standard-mode and fast-mode. ‹ ‹ ‹ ‹ ‹ Only 7-bit SMBus addresses are supported. SB-TSI implements the Send/Receive Byte and Read/Write Byte protocols. SB-TSI registers can only by written using a write byte command. Address Resolution Protocol (ARP) is not implemented. Packet Error Checking (PEC) is not supported. 18.3.1 SB-TSI Address The SMBus address is really 7 bits. The SB-TSI address is normally 98h or 4Ch. The address could vary with address select bits. Table 18-1 SB-TSI Address Encoding Address Select Bits SB-TSI Address 000b 98h 001b 9Ah 010b 9Ch 011b 9Eh 100b 90h 101b 92h 110b 94h 111b 96h 18.4 PCH The PCH provide system thermal data to EC. The EC can manage the fans and other cooling elements based on this data. A subset of the thermal collection is that the PCH and be programmed to alert the EC when a device has gone outside of its temperature limits. 18.4.1 Command Summary Table 18-2 PCH Command Summary Trans-action Slave Addr. Data Byte 0 =Com mand Data Byte 1 =Byte Count Data Byte 2 Data Byte 3 Data Byte 4 Write STS Preferences I2C 0x41 0x6 STS [47:40] STS [39:32] Write CPU Temp Limits I2C 0x42 0x6 Lower Limit [15:8] Lower Upper Limit [7:0] Limit [15:8] Write MCH Temp Limits I2C 0x43 0x2 Lower Upper Limit [7:0] Limit [7:0] -198 STS [31:24] na Data Byte 5 STS [23:16] Data Byte 6 STS [15:8] Data Byte 7 STS [7:0] Upper Limit [15:8] na Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Write IBX Temp Limits I2C 0x44 0x2 Lower Upper Limit [7:0] Limit [7:0] na na Write DIMM Temp Limits I2C 0x45 0x2 Lower Upper Limit [7:0] Limit [7:0] na na Write MPC CPU Power Clamp I2C 0x50 0x2 Lower Power Limit [7:0] Clamp [7:0] 0x40 Block Read Address Byte Count Block Read Block Read Address Data 0 Data N PEC (optional) 18.5 SMBus Master 18.5.1 Block Diagram LPC DAT DAT_EN DAT_AVIL F-Full RE# MU_SET SMBADDR SMWRCNT SMCTL2 INT PCHADDR ACBCTL SMCTL3 I2C Module SCL OUT SDA OUT IIC FSM WE# SMBCMD SMRDCNT SMBCTL Packet FSM CS CFG DAT_OUT CRC8 G/C Scl in Sda_in Figure 18-4 SMBus Master Block Diagram . -199 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 18.5.2 Programming Flow Function Start Manual Mode Set Mode Sel Routine Polling SMADDR SMDATA SMCMD PCH_EN SMWR/RDCNT TSI_EN SMCTL (EN) Set_manual_mode Enable TSI ?? TSI Routine Finished 1 pack? Enable PCH ?? PCH Routine Manual Trans Wait for Refresh Figure 18-5 Programming Flow -200 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 18.5.3 TSI Routine Figure 18-6 TSI Routine 18.5.4 PCH Routine Figure 18-7 PCH Routine -201 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 18.5.5 BYTE Ruttine Figure 18-8 PCH Routine 18.5.6 Manual Mode interface The SMBus host supports Block/Word/Byte Write and Block/Word/Byte read with PEC. The SMBus host can use the interface to access the smbus slave. The timing diagrams below illustrate how to use the smbus interface to write the data or read the data to the smbus slave. -202 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Figure 18-9 Manual Mode Programming Flow 18.6 Register Type Abbreviations The following abbreviations are used to indicate the Register Type: ‹ ‹ ‹ R/W = Read/Write. R = Read from register. W = Write. ‹ RO = Read-only. To program the SMBus master configuration registers, the following configuration procedures must be followed in sequence: (1). Enter the Extended Function Mode. (2). Configure the configuration registers. 18.6.1 Enter the Extended Function Mode To place the chip into the Extended Function Mode, two successive writes of 0x26 must be applied to Extended Function Enable Registers (EFERs, i.e. 2Eh or 4Eh). -203 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 18.6.2 Configure the Configuration Registers The chip selects the Logical Device and activates the desired Logical Devices through Extended Function Index Register (EFIR) and Extended Function Data Register (EFDR). The EFIR is located at the same address as the EFER, and the EFDR is located at address (EFIR+1). First, write the Logical Device Number (i.e. 0x07) to the EFIR and then write the number of the desired Logical Device to the EFDR. If accessing the Chip (Global) Control Registers, this step is not required. Secondly, write the address of the desired configuration register within the Logical Device to the EFIR and then write (or read) the desired configuration register through the EFDR. 18.7 SMBus Master Register Set 18.7.1 SMBus Register Map SMBus Master base address in register Logic Device B CR62h(MSB), CR63h(LSB). Table 18-3 SMBus Master Bank 0 Registers Offset Type Name Section 0 R/W SMBus Data 19.7.2 1 R/W SMBus Write Data Size 19.7.3 2 R/W SMBus Command 19.7.4 3 R/W SMBus Index 19.7.5 4 R/W SMBus Control 19.7.6 5 R/W SMBus Address 19.7.7 6 R/W SMBCLK Frequency 19.7.8 7 RO Reserved 8 R/W PCH Address 19.7.9 9 R/W Error status 19.7.10 A R/W Reserved B R/W PCH Command 19.7.11 D R/W TSI Agent Enable 19.7.12 E R/W SMBus Control 3 Register 19.7.13 F R/W SMBus Control 3 Register 19.7.14 10 R/W BYTE_ADDR 19.7.15 11 R/W BYTE Index High Byte 19.7.16 12 R/W BYTE Index Low Byte 19.7.17 13 R/W Reserved 14 R/W Reserved -- -- 18.7.2 SMBus Data (SMDATA) – Bank 0 This 32 bits register is the data in and out register of SMBus data register. Before writing to SMDATA register, this register contains the input data, after writing to SMDATA register, this register contains the output data. -204 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Offset: 0h Type: R/W Byte 3 2 1 0 Name SMFIFO3 SMFIFO2 SMFIFO1 SMFIFO0 Default 00h 00h 00h 00h Byte Description 3 SMFIFO3 (SMBus FIFO 3). This byte represents the high byte of the 32 bits SMBus data. 2 SMFIFO2 (SMBus FIFO 2). This byte represents the second byte of the 32 bits SMBus data. 1 SMFIFO1 (SMBus FIFO 1). This byte represents the first byte of the 32 bits SMBus data. 0 SMFIFO0 (SMBus FIFO 0). This byte represents the low byte of the 32 bits SMBus data. 18.7.3 SMBus Write Data Size (SMWRSIZE) – Bank 0 Offset: 1h Type: R/W Bit 7 6 5 4 3 Reserved Name Default 0 0 2 1 0 0 0 SMWRSIZE 0 Bit 0 0 0 Description 7-5 Reserved. 4-0 SMWRSIZE (SMBus Write Byte Counter). This field sets the write byte counter, the max counter size is 32 bytes, and the minimal size is 1 bytes. 18.7.4 SMBus Command (SMCMD) – Bank 0 Offset: 2h Type: R/W Bit 7 6 NAME Default 4 3 REV 0 Bit 7-4 5 0 2 1 0 SMBus CMD 0 0 0 0 0 0 Description Reserved. -205 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 3-0 SMBCMD (SMBus Command). This field sets SMBus Command: 0000 : Read Byte (Default) 0001 : Read Word 0010 : Read Block 0011 : Block Write and Read Process Call 0100 : Process Call 1000 : Write Byte 1001 : Write Word 1010 : Write Block 18.7.5 SMBus INDEX (SMIDX) – Bank 0 Offset: 3h Type: R/W Bit 7 6 5 4 Default 0 0 0 Bit 7-0 3 2 1 0 0 0 0 0 1 0 SMCMD Name 0 Description SMIDX (SMBus INDEX). This field represents the index data of the SMBus. 18.7.6 SMBus Control (SMCTL) – Bank 0 Offset: 4h Type: R/W Bit 7 Name MMODE_S Default 0 6 S_RST 5 CRC8_EN 0 Bit 7 2 REFLASH_CLK 0 0 BYTE_EN 0 0 PCH_EN 0 MMODE_S (Manual Mode Set). 0 : Disable. : Enable. S_RST (Soft Reset SMBus). 0 : Disable. 1 5 0 3 Description 1 6 4 : Enable. CRC8_EN (CRC8 Enable). 0 : CRC8 function is disable. 1 : CRC8 function is enable. -206 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 4-2 REFRASH_CLK (Refrash Clock Select). 000, 100 – 128ms 001, 101 – 256ms 010, 110 – 512ms 011, 111 – 64ms (1KHz) 1 BYTE_EN (BYTE Enable). 0 : BYTE function is disable. 1 0 : BYTE function is enable. PCH_EN (PCH Enable). 0 : PCH function is disable. 1 : PCH function is enable. 18.7.7 SMBus Address (SMADDR) – Bank 0 Offset: 5h Type: R/W Bit 7 6 5 Name 0 0 0 Bit 0 3 2 1 SMADDR Default 7-1 4 0 0 REV 0 0 0 0 1 0 1 1 Description SMADDR (SMBus Address). AMD-TSI only supports 7-bit SMBus address. Reserved: 0 : Write. If the protocol is write, the WR_SIZE can’t be zero. (Default) 18.7.8 SCL FREQ (SCLFREQ) – Bank 0 Offset: 6h Type: R/W Bit 7 6 5 4 3 Reserved: Default 0 Bit 7-4 0 0 2 SCLFREQ 0 0 1 Description Reserved -207 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 3-0 SCLFQ (SMBCLK Frequency). This field defines the SMBCLK period (low time and high time). The clock low time and high time ate defined as follows: 0000 : 365KHz 0001 : 261KHz 0010 : 200KHz 0011 : 162KHz 0100 : 136KHz 0101 : 117KHz 0110 : 103KHz 0111 : 92KHz (Default) 1000 : 83KHz 1001 : 76KHz 1010 : 71KHz 1011 : 65KHz 1100 : 61KHz 1101 : 57KHz 1110 : 53KHz 1111 : 47KHz 18.7.9 PCH Address (PCHADDR) – Bank 0 Offset: 8h Type: R/W Bit 7 6 5 3 2 1 PCHADDR Name Default 1 0 0 Bit 7-1 4 0 REV 1 0 1 0 0 Description PCHADDR (PCH Address). PCH supports 8-bit SMBus address. The default address is 94h. The last bit is read or write bit. It needs to set to “0”. 18.7.10SMBus Error Status (Error_status) – Bank 0 Offset: 9h Type: RO/W1C Bit 7 REV Name Default 6 1 Bit 5 ADNACK 0 0 4 Timeout 3 Reserved 1 0 2 BER 1 1 NACK 0 0 Reserve d 0 Description 7-6 Reserved. 5 ADDR Non ACK. This bit reflects SMBus occurred ADDRESS NON ACK in Manual mode.. 4 Timeout. This bit reflects when SMBus occurs timeout. -208 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 3 Reserved. 2 BER (Bus Error). This bit reflects when a start or stop condition is detected during data transfer, or when an arbitration problem is detected. 1 NACK (Negative acknowledge). This bit is set by hardware when a transmission is not acknowledged on the ninth clock. While NACK is set SCL will be drive low and subsequent bus transactions are stalled until NACK is cleared. 0 Reserved. 18.7.11PCH Command (PCHCMD) – Bank 0 Offset: Bh Type: R/W Bit 7 6 5 4 Default 0 1 0 Bit 7-0 3 2 1 0 0 0 0 0 PCHCMD Name 0 Description PCHCMD (PCH Command). This field represents the command data of the PCH. The default command is block read (40h). 18.7.12TSI Agent Enable Register (TSI_AGENT) – Bank Offset: Dh Type: RO Bit Name Default 7 6 5 4 3 2 1 0 AG7 AG6 AG5 AG4 AG3 AG2 AG1 AG0 0 0 0 0 0 0 0 0 Bit Description 7 TSI AGENT7 Enable. : This bit reflects AMD-TSI Agent enbale. 0: Diable 1: Enable 6 TSI AGENT6 Enable. : This bit reflects AMD-TSI Agent enbale. 0: Diable 1: Enable 5 TSI AGENT5 Enable. : This bit reflects AMD-TSI Agent enbale. 0: Diable 1: Enable 4 TSI AGENT4 Enable. : This bit reflects AMD-TSI Agent enbale. 0: Diable 1: Enable -209 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 3 TSI AGENT3 Enable. : This bit reflects AMD-TSI Agent enbale. 0: Diable 1: Enable 2 TSI AGENT2 Enable. : This bit reflects AMD-TSI Agent enbale. 0: Diable 1: Enable 1 TSI AGENT1 Enable. : This bit reflects AMD-TSI Agent enbale. 0: Diable 1: Enable 0 TSI AGENT0 Enable. : This bit reflects AMD-TSI Agent enbale. 0: Diable 1: Enable 18.7.13SMBus Control 3 Register (SMCTL3) – Bank 0 Offset: Eh Type: RO Bit 7 6 5 4 Reserved Name Default 0 0 3 CRC_CHK 0 Bit 0 0 1 0 F_FULL F_EMPT 0 0 0 2 1 0 Description 7-4 Reserved 3 CRC_CHK (CRC Check). 0 : incorrect 1 : correct 2 M_MODE (Manual Mode). 0 : Non-active 1 : Active 1 F_FULL (fifo_full). : This bit reflects SMBus data fifo is full. 0 1 0 2 M_MODE : Non-full : Full F_EMPT (fifo empty). : This bit reflects the SMBus data fifo is empty. 0 : Non-empty 1 : Empty 18.7.14SMBus Control 2 Register (SMCTL2) – Bank 0 Offset: Fh Type: R/W Bit 7 Reserved Name Default 6 0 5 4 INT_LCH_E 0 0 3 Reserved 0 BYTE_SEL 0 -210 0 BANKSEL 0 0 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Bit Description 7-6 Reserved. 5 2 INT_LCH_E (Interrupt Latch Enable). : This bit will latch the I2CSTA register. 0 : Disable. 1 : Enable. BYTE_SEL :This field represents byte polling 8-bit/16bit select bits. 0: BYTE_TEMP is 16 bit data 1: BYTE_TEMP is 8 bit data 1-0 BANKSEL (Bank Select). 00 – Bank 0. 01 – Bank 1. 10 – Bank 2. 18.7.15BYTE ADDRESS (BYTE ADDR) – Bank 0 Offset: 10h Type: R/W Bit 7 6 5 Name 3 2 1 0 0 0 0 0 3 2 1 0 0 0 1 BYTE_ADDRESS Default 0 1 0 Bit 7-0 4 0 Description BYTE ADDRESS (BYTE ADDR). This field represents the address data of the BYTE. 18.7.16BYTE INDEX_H (BYTE_IDX_H) – Bank 0 Offset: 11h Type: R/W Bit 7 6 5 Name Default Bit 7-0 4 BYTE_IDX_H 0 0 0 0 0 Description BYTE_IDX_H (High BYTE INDEX). This field represents the high byte index of the Byte polling. The default command is byte read (01h). -211 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 18.7.17BYTE INDEX_L (BYTE_IDX_L) – Bank 0 Offset: 12h Type: R/W Bit 7 6 5 Name Default Bit 7-0 4 3 2 1 0 0 0 0 BYTE_IDX_L 0 0 0 1 0 Description BYTE_IDX_L (LOW BYTE INDEX). This field represents the low byte index of the Byte polling. The default command is byte read (10h). The EC may read thermal information from IBX using the SMBus block read command. The IBX doesn’t support byte-read or word-read SMBus commands. The read use a different address that the writes. The address must be different so that the IBX knows which target Is intended, either the I2C target or the block read buffer. The IBX and EC are set up by BIOS with the length of the read that is supported by the platform. The EC must always do reads of the lengths set up by BIOS. There is no way to change the length of the read after BIOS has set things up. An EC that only wants the single highest temperature among MCH, and CPU could read one byte. A 2 byte read would provide both IBX and CPU/MCH package temperature. An EC that wanted each components temperature would do a 4 byte read. An EC that also wanted DIMM information would read 9 bytes. If an EC wanted to read the HOST STS status, it must read 19 bytes. An EC can also read the energy data provided by the CPU by reading 12 bytes. -212 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 19. CONFIGURATION REGISTER 19.1 Chip (Global) Control Register Default Value of Global Control Register: Register Default Register Default Register Default CR 07h 00h CR 20h C5h (ID_H) CR 2Bh 00h CR 10h FFh CR 21h 61h (ID_L) CR 2Ch 01h CR 11h FFh CR 22h FFh CR 2Fh 0ss0ssssb CR 13h 00h CR 24h 04h CR 14h 00h CR 25h 00h CR 1Ah 00h CR 26h 0s000000b CR 1Bh 70h CR 27h 00h CR 1Ch 10h CR 28h 00h CR 1Dh 00h CR 2Ah C0h Note. The value of “s” means hardware strapping result: strapping high will report 1; strapping low will report 0. In addition, BIOS can write the value of strapping result after hardware strapping. Note. The CR21h is low-byte of the Chip-ID; the “X” means IC version. EX. 61=A version, 62=B version, 63=C version. Reserved Registers of Global Control Register: Register Default Register Default CR 02h 00h CR 1Eh FFh CR 12h FFh CR 1Fh FFh CR 15h FFh CR 23h 00h CR 16h FFh CR 29h FFh CR 17h FFh CR 2Dh FFh CR 18h FFh CR 2Eh 00h CR 19h FFh Note. All reserved registers must keep default value. Note. Before accessing CR10, CR11, CR13 and CR14, CR26 [Bit4] must be set to logic 1. CR 07h. Logical Device Selection Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE 7-0 R/W DESCRIPTION Logical Device Number. -213 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY CR 10h. Device IRQ TYPE Selection Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : FFh BIT READ / WRITE 7-6 Reserved. 5 4 R/W DESCRIPTION UARTA IRQ TYPE SELECT (note1.) 0: Edge. 1: Level. Reserved 3 R/W KBC IRQ TYPE SELECT (note1.) 0: Edge. 1: Level. 2 R/W MOUSE IRQ TYPE SELECT (note1.) 0: Edge. 1: Level. 1 R/W CIR IRQ TYPE SELECT (note1.) 0: Edge. 1: Level. 0 R/W CIRWAKUP IRQ TYPE SELECT (note1.) 0: Edge. 1: Level. Note1: Before accessing CR10, CR11, CR13 and CR14, CR26 [Bit4] must be set to logic 1. CR 11h. Device IRQ TYPE Selection Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : FFh BIT READ / WRITE DESCRIPTION 7 R/W HM IRQ TYPE SELECT (note1.) 0: Edge. 1: Level. 6 R/W WDTO IRQ TYPE SELECT (note1.) 0: Edge. 1: Level. 5-2 Reserved. 1 R/W 0 Reserved. SMI IRQ TYPE SELECT (note1.) 0: Edge. 1: Level. -214 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Note1: Before accessing CR10, CR11, CR13 and CR14, CR26 [Bit4] must be set to logic 1. CR 13h. Device IRQ Polarity Selection Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT 7-0 READ / WRITE R/W DESCRIPTION IRQ Channel Polarity (note1.) 0: High. 1: Low. Note1: Before accessing CR10, CR11, CR13 and CR14, CR26 [Bit4] must be set to logic 1. CR 14h. Device IRQ Polarity Selection Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE 7-0 R/W DESCRIPTION IRQ Channel Polarity (note1.) 0: High. 1: Low. Note1: Before accessing CR10, CR11, CR13 and CR14, CR26 [Bit4] must be set to logic 1. CR 1Ah. Multi Function Selection Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 00h BIT READ / WRITE 7-4 Reserved DESCRIPTION Pin23 function selection 3-2 1-0 R/W TEST MODE1 CR1A [Bit3-2] Pin23 1 xx Reserved 0 00 MSCL 0 01 SCL 0 10 GP41 0 11 MSCL Reserved. -215 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY CR 1Bh. Multi Function Selection Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 70h BIT READ / WRITE 7-5 Reserved DESCRIPTION Pin46 function selection 4 3 R/W CR1B [Bit4] CR27 [Bit3] Pin46 1 x CIRRX 0 0 GP24 0 1 IRRX1 TEST MODE1 CR1B [Bit2-1] Pin22 1 x Reserved 0 00 MSDA 0 01 SDA 0 10 BEEP 0 11 GP42 Reserved Pin22 function selection 2-1 0 R/W Reserved CR 1Ch. Multi Function Selection Attribute: Read/Write Power Well: VSB Reset by: PWROK Default : 10h BIT READ / WRITE 7-0 Reserved DESCRIPTION CR 1Dh. Multi Function Selection Attribute: Read/Write Power Well: VSB Reset by: PWROK Default : 00h BIT READ / WRITE 7-0 Reserved DESCRIPTION CR 20h. Chip ID (High Byte) Attribute: Read Only -216 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Power Well: VCC Reset by: None Default : C5h BIT READ / WRITE 7-0 Read Only DESCRIPTION Chip ID number = C5h (high byte). CR 21h. Chip ID (Low Byte) Attribute: Read Only Power Well: VCC Reset by: None Default : 61h BIT READ / WRITE 7-0 Read Only DESCRIPTION Chip ID number = 61h (low byte) CR 22h. Device Power Down Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : FFh BIT READ / WRITE 7-5 Reserved. 4 3-0 R/W DESCRIPTION UARTA Power Down. 0: Powered down. 1: Not powered down. Reserved. CR 24h. Global Option Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 04h BIT 7-5 READ / WRITE DESCRIPTION Reserved 4 R/W Select output type of SYSFANOUT =0 SYSFANOUT is Open-drain. =1 SYSFANOUT is Push-pull. 3 R/W Select output type of CPUFANOUT =0 CPUFANOUT is Open-drain. =1 CPUFANOUT is Push-pull. 2-1 0 Reserved. R/W PNPCVS => =0 The compatible PNP address-select registers have default values. =1 The compatible PNP address-select registers have no default values. -217 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY CR 25h. Interface Tri-state Enable Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE 7-3 Reserved. 2 1-0 R/W 7 UARTATRI Reserved. CR 26h. Global Option Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 0s000000b BIT DESCRIPTION s: value by strapping READ / WRITE DESCRIPTION Reserved. 6 R/W HEFRAS => =0 Write 87h to location 2E twice. =1 Write 87h to location 4E twice. The corresponding power-on strapping pin is RTSA# (Pin 15). 5 R/W LOCKREG => =0 Enable R/W configuration registers. =1 Disable R/W configuration registers. 4-2 1 0 Reserved. R/W DSUALGRQ => =0 Enable UART A legacy mode for IRQ selection. Then HCR register (base address + 4) bit 3 is effective when selecting IRQ. =1 Disable UART A legacy mode for IRQ selection. Then HCR register (base address + 4) bit 3 is not effective when selecting IRQ. R/W DSUBLGRQ => =0 Enable IR legacy mode for IRQ selection. Then HCR register (base address + 4) bit 3 is effective when selecting IRQ. =1 Disable IR legacy mode for IRQ selection. Then HCR register (base address + 4) bit 3 is not effective when selecting IRQ. CR 27h. Global Option Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 00h BIT READ / WRITE DESCRIPTION -218 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT READ / WRITE 7-4 Reserved. DESCRIPTION Pin46 function selection 3 2 1 0 R/W CR1B [Bit4] CR27 [Bit3] Pin46 1 x CIRRX 0 0 GP24 0 1 IRRX1 CR2A [Bit3] CR27 [Bit3] Pin47 1 x CIRTX1 0 0 GP25 0 1 IRTX1 Pin47 function selection Reserved R/W LV_DETECT_L 0: AMD power sequence detect level and time delay 1: AMD power sequence non detect level but time delay Reserved. CR 28h. Global Option Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE 7-0 Reserved. DESCRIPTION CR 2Ah. Multi Function Selection Attribute: Read/Write Power Well: VSB Reset by: RSMRST#, GP2X_MRST(Bit0) Default : C0h BIT READ / WRITE DESCRIPTION Pin13 function selection 7 R/W CR2A [Bit7] Pin13 0 CTSA# 1 GP80 -219 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT READ / WRITE DESCRIPTION Pin14 function selection CR2A [Bit7] Pin14 0 DSRA# 1 GP81 Pin15 function selection CR2A [Bit7] Pin15 0 RTSA# 1 GP82 Pin16 function selection CR2A [Bit7] Pin16 0 DTRA# 1 GP83 Pin17 function selection 7 R/W CR2A [Bit7] Pin17 0 SINA 1 GP84 Pin18 function selection CR2A [Bit7] Pin18 0 SOUTA 1 GP85 Pin19 function selection CR2A [Bit7] Pin19 0 DCDA# 1 GP86 Pin20 function selection 6-4 CR2A [Bit7] Pin20 0 RIA# 1 GP87 Reserved. Pin47 function selection 3 R/W CR2A [Bit3] CR27 [Bit3] Pin47 1 x CIRTX1 0 0 GP25 0 1 IRTX1 -220 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 2 READ / WRITE R/W DESCRIPTION Enable Over Temperature shutdown Protection (OVT#) = 0 The thermal shutdown function is disabled. (Default) = 1 Enable thermal shutdown function. (If set this bit to 1, the relative registers of OVT# event are: Bank0, CR18 ,Bit6 → SMIOVT1 OVT# (Default SYSTIN) Bank0, CR4C ,Bit4 → SMIOVT3 OVT# (Default AUXTIN) Bank0, CR4C ,Bit3 → SMIOVT2 OVT# (Default CPUTIN) If current temperature exceeds high-limit setting, OVT# event will be triggered and PSON# will inactive immediately. ) Pin24 function selection R/W 1 CR2A [Bit1] Pin24 0 MCLK 1 GP23 Pin25 function selection CR2A [Bit1] Pin25 0 MDAT 1 GP22 Pin26 function selection CR2A [Bit0] Pin26 0 KCLK 1 GP21 R/W 0 Pin27 function selection CR2A [Bit0] Pin27 0 KDAT 1 GP20 CR 2Bh. Multi Function Selection Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 00h BIT 7 READ / WRITE DESCRIPTION Reserved Pin35 function selection 6 R/W CR2B [Bit6] Pin35 0 RSTOUT1# 1 GP75 -221 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT READ / WRITE DESCRIPTION Pin36 function selection 5 4-0 R/W CR2B [Bit5] Pin36 0 RSTOUT0# 1 GP74 Reserved. CR 2Ch. Multi Function Selection Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 01h BIT READ / WRITE 7-1 Reserved. DESCRIPTION Pin58 function selection 0 R/W CR2C [Bit0] Pin58 0 GP26 1 TSIC Pin60 function selection CR2C [Bit0] Pin60 0 PECI 1 TSID CR 2Fh. Strapping Function Result Location: Address 2Fh Attribute: Read/Write Power Well: VSB Reset by: RSMRST#(Bit5-2), PWROK(Bit0), LRESET#(Bit6, 1) Default : by 0ss0_ssss Size: 8 bits BIT READ / WRITE 7-6 Reserved. 5 4-2 R/W DESCRIPTION AMDPWR_EN Strapping result reading Reserved. 1 R/W TEST MODE1 Strapping result reading 0 R/W 24M_48M_SEL Strapping result reading Note. All Strapping results can be programming by LPC Interface. There are three conditions below: 4) VSB Strapping result can be programming by LPC, and reset by RSMRST# 5) VCC Strapping result can be programming by LPC, and reset by PWROK 6) LRESET Strapping (2E_4E_SEL) : No change -222 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 19.2 Logical Device 2 (UART A) CR 30h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 01h BIT READ / WRITE 7-1 Reserved. 0 R/W DESCRIPTION 0: The logical device is inactive. 1: The logical device is active. CR 60h, 61h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 03h, F8h BIT READ / WRITE DESCRIPTION 7-0 R/W These two registers select Serial Port 1 I/O base address on 8 bytes boundary. CR 70h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 04h BIT READ / WRITE 7-4 Reserved. 3-0 R/W DESCRIPTION These bits select IRQ resource for Serial Port 1. CR F0h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE 7 R/W 0: Delay RXCLK for 5 ns for LG issue. 1: No delay of 5 ns for RXCLK. 6 R/W 0: IRQ is the level mode. 1: IRQ is the pulse mode for IRQ sharing function. 5 R/W 0: Using the original RX FIFO Error Indication signal (USR bit 7). 1: Using new RX FIFO Error Indication signal to solve some issues. 4-2 DESCRIPTION Reserved. -223 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 1-0 READ / WRITE R/W DESCRIPTION Bits 10 0 0: UART A clock source is 1.8462 MHz (24 MHz / 13). 0 1: UART A clock source is 2 MHz (24 MHz / 12). 1 0: UART A clock source is 24 MHz (24 MHz / 1). 0 0: IR clock source is 14.769 MHz (24 MHz / 1.625). CR F2h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE 7 R/W UARTA_RS485_enable 0: Disable RS485 auto flow control function for UARTA 1: Enable RS485 auto flow control function for UARTA 6 R/W UARTA_RS485_inv_sel (Available only when CRF2_Bit7=1) 0: Do not invert the behavior of RTSA# pin for RS485 auto flow control. 1: Invert the behavior of RTSA# pin for RS485 auto flow control. 5-0 DESCRIPTION Reserved. -224 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 19.3 Logical Device 3 (IR) CR 30h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 01h BIT READ / WRITE 7-1 Reserved. 0 R/W DESCRIPTION 0: The logical device is inactive. 1: The logical device is active. CR 60h, 61h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 02h, F8h BIT READ / WRITE DESCRIPTION 7-0 R/W These two registers select IR I/O base address on eightbyte boundary. CR 70h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 03h BIT READ / WRITE 7-4 Reserved. 3-0 R/W DESCRIPTION These bits select IRQ resource for IR. CR F0h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE DESCRIPTION 7 R/W 0: Delay RXCLK for 5 ns for LG issue. 1: No delay of 5 ns for RXCLK. 6 R/W 0: IRQ is the level mode. 1: IRQ is the pulse mode for IRQ sharing function. 5 R/W 0: Using the original RX FIFO Error Indication signal (USR bit 7). 1: Using new RX FIFO Error Indication signal to solve some issues. -225 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT READ / WRITE 4-2 Reserved. 1-0 DESCRIPTION Bits 10 0 0: IR clock source is 1.8462 MHz (24 MHz / 13). 0 1: IR clock source is 2 MHz (24 MHz / 12). 0 0: IR clock source is 24 MHz (24 MHz / 1). 0 0: IR clock source is 14.769 MHz (24 MHz / 1.625). R/W CR F1h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE DESCRIPTION 7 Reserved. 6 R/W IRLOCSEL => IR I/O pins’ location selection. 0: reserved. 1: Through IRRX / IRTX. 5-3 R/W IRMODE => IR function mode selection. See the table below. 2 R/W IR half / full duplex function selection. 0: IR function is Full Duplex. 1: IR function is Half Duplex. 1 R/W 0: IRTX pin of IR function in normal condition. 1: Inverse IRTX pin of IR function. 0 R/W 0: IRRX pin of IR function in normal condition. 1: Inverse IRRX pin of IR function. IR MODE IR FUNCTION IRTX IRRX 00X Disable Tri-state High 010* IrDA Demodulation into SINB/IRRX 011* IrDA Active pulse 1.6 μS Active pulse 3/16 bit time Demodulation into SINB/IRRX 100 ASK-IR Inverting IRTX/SOUTB pin Routed to SINB/IRRX 101 ASK-IR 110 ASK-IR 111* ASK-IR Inverting IRTX/SOUTB & 500 KHZ clock Inverting IRTX/SOUTB Inverting IRTX/SOUTB & 500 KHZ clock Routed to SINB/IRRX Demodulation into SINB/IRRX Demodulation into SINB/IRRX Note: The notation is normal mode in the IR function. -226 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 19.4 Logical Device 5 (Keyboard Controller) CR 30h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE 7-1 Reserved. 0 R/W DESCRIPTION 0: The logical device is inactive. 1: The logical device is active. CR 60h, 61h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h, 00h BIT READ / WRITE DESCRIPTION 7-0 R/W These two registers select the first KBC I/O base address on 1-byte boundary. CR 62h, 63h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h, 00h BIT READ / WRITE DESCRIPTION 7-0 R/W These two registers select the second KBC I/O base address on 1 byte boundary. CR 70h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE 7-4 Reserved. 3-0 R/W DESCRIPTION These bits select IRQ resource for KINT. (Keyboard interrupt) CR 72h. Attribute: Read/Write Power Well: VCC -227 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Reset by: LRESET# Default : 00h BIT READ / WRITE 7-4 Reserved. 3-0 R/W DESCRIPTION These bits select IRQ resource for MINT. (PS/2 Mouse interrupt) CR F0h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 83h BIT READ / WRITE 7-6 R/W 5-3 Reserved. DESCRIPTION KBC clock rate selection Bits 76 0 0: Reserved 0 1: Reserved 1 0: 12MHz 1 1: Reserved 2 R/W 0: Port 92 disabled. 1: Port 92 enabled. 1 R/W 0: Gate A20 software control. 1: Gate A20 hardware speed up. 0 R/W 0: KBRST# software control. 1: KBRST# hardware speed up. -228 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 19.5 Logical Device 6 (CIR) CR 30h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE 7-1 Reserved. 0 R/W DESCRIPTION 0: CIR Interface is inactive. 1: CIR Interface is active. CR 60h, 61h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h, 00h BIT READ / WRITE DESCRIPTION 7-0 R/W These two registers select CIR Interface I/O base address on 1 byte boundary. CR 70h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE 7-4 Reserved. 3-0 R/W DESCRIPTION These bits select IRQ resource for CIR. CR F0h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 08h BIT READ / WRITE 7-4 Reserved. 3 R/W DESCRIPTION CIR wide band filter select 0: Low-pass filter 1: Band-pass filter -229 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 2-1 0 READ / WRITE DESCRIPTION R/W Timeout margin selection of CIR wide band band-pass filter 00: 200% recording carrier period 01: 100% recording carrier period 10: 50% recording carrier period 11: 25% recording carrier period R/W Carrier recording mode CIR wide band band-pass filter 0: Second carrier 1: Every carrier CR F1h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 09h BIT READ / WRITE DESCRIPTION 7-6 R/W Reserved. 5-0 R/W Highest input period of CIR wide band band-pass filter (unit : us) CR F2h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 32h BIT READ / WRITE DESCRIPTION 7-6 R/W Reserved. 5-0 R/W Lowest input period of CIR wide band band-pass filter (unit : us) CR F3h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE DESCRIPTION 7-6 R/W Reserved. 5-0 R/W Recording carrier period of CIR wide band band-pass filter (unit : us) -230 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 19.6 Logical Device 7 (GPIO7, GPIO8) CR E0h. GPIO7 I/O Register Attribute: Read/Write Power Well: VSB Reset by: GP7X_MRST Default : 0Fh BIT READ / WRITE 7-4 Reserved 3-0 R/W DESCRIPTION GPIO7 I/O register 0: The respective GPIO7 PIN is programmed as an output port 1: The respective GPIO7 PIN is programmed as an input port. CR E1h. GPIO7 Data Register Attribute: Read/Write Power Well: VSB Reset by: GP7X_MRST Default : 00h BIT READ / WRITE 7-4 Reserved DESCRIPTION R/W GPIO7 Data register For output ports, the respective bits can be read/written and produced to pins. Read Only For input ports, the respective bits can be read only from pins. Write accesses will be ignored. 3-0 CR E2h. GPIO7 Inversion Register Attribute: Read/Write Power Well: VSB Reset by: GP7X_MRST Default : 00h BIT READ / WRITE 7-4 Reserved 3-0 R/W DESCRIPTION GPIO7 Inversion register 0: The respective bit and the port value are the same. 1: The respective bit and the port value are inverted. (Both Input & Output ports) CR E3h. GPIO7 Status Register Attribute: Read Only Power Well: VSB Reset by: GP7X_MRST Default : 00h -231 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT READ / WRITE 7-4 Reserved 3-0 Read Only Read-Clear DESCRIPTION GPIO7 Event Status Bit 7-0 corresponds to GP77-GP70, respectively. 0 : No active edge (rising/falling) has been detected 1 : An active edge (rising/falling) has been detected Read the status bit clears it to 0. CR E4h. GPIO8 I/O Register Location: Address E4h Attribute: Read/Write Power Well: VSB Reset by: GP8X_MRST Default : FFh Size: 8 bits BIT 7-0 READ / WRITE R/W DESCRIPTION GPIO8 I/O register 0: The respective GPIO8 PIN is programmed as an output port 1: The respective GPIO8 PIN is programmed as an input port. CR E5h. GPIO8 Data Register Location: Address E5h Attribute: Read/Write Power Well: VSB Reset by: GP8X_MRST Default : 00h Size: 8 bits BIT READ / WRITE DESCRIPTION R/W GPIO8 Data register For output ports, the respective bits can be read/written and produced to pins. Read Only For input ports, the respective bits can be read only from pins. Write accesses will be ignored. 7-0 CR E6h. GPIO8 Inversion Registe Location: Address E6h Attribute: Read/Write Power Well: VSB Reset by: GP8X_MRST Default : 00h Size: 8 bits BIT READ / WRITE DESCRIPTION -232 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7-0 READ / WRITE DESCRIPTION R/W GPIO8 Inversion register 0: The respective bit and the port value are the same. 1: The respective bit and the port value are inverted. (Both Input & Output ports) CR E7h. GPIO8 Status Register Location: Address E7h Attribute: Read Only Power Well: VSB Reset by: GP8X_MRST Default : 00h Size: 8 bits BIT 7-0 READ / WRITE Read Only Read-Clear DESCRIPTION GPIO8 Event Status Bit 7-0 corresponds to GP87-GP80, respectively. 0 : No active edge (rising/falling) has been detected 1 : An active edge (rising/falling) has been detected Read the status bit clears it to 0. CR ECh. GPIO7 Multi-function Select Register Attribute: Read/Write Power Well: VSB Reset by: GP7X_MRST Default : 00h BIT READ / WRITE 7-6 Reserved DESCRIPTION 5 R/W 0: GPIO75 1: GPIO75 Æ BEEP (Please also set this GPIO to “output” type.) 4 R/W 0: GPIO74 1: GPIO74 Æ GRN (Please also set this GPIO to “output” type.) 3-0 Reserved CR EDh. GPIO8 Multi-function Select Register Location: Address EDh Attribute: Read/Write Power Well: VSB Reset by: GP8X_MRST Default : 00h Size: 8 bits BIT READ / WRITE 7 R/W DESCRIPTION 0: GPIO87 1: GPIO87 Æ YLW -233 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT READ / WRITE DESCRIPTION 6 R/W 0: GPIO86 1: GPIO86 Æ BEEP 5 R/W 0: GPIO85 1: GPIO85 Æ SMI 4 R/W 0: GPIO84 1: GPIO84 Æ WDTO 3 R/W 0: GPIO83 1: GPIO83 Æ YLW 2 R/W 0: GPIO82 1: GPIO82 Æ BEEP 1 R/W 0: GPIO81 1: GPIO81 Æ SMI 0 R/W 0: GPIO80 1: GPIO80 Æ WDTO -234 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 19.7 Logical Device 8 (WDT1) CR 30h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE 7-4 Reserved 3 2-1 0 R/W DESCRIPTION 0: GPIO Base Address mode is inactive 1: GPIO Base Address mode is active Reserved R/W 0: WDT1 is inactive. 1: WDT1 is active. CR 60h, 61h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h, 00h BIT READ / WRITE DESCRIPTION 7-0 R/W These two registers select GPIO Interface I/O base address on 1 byte boundary. CR F5h. Watchdog Timer I (WDT1) and KBC P20 Control Mode Register Attribute: Read/Write Power Well: VCC Reset by: LRESET# or PWROK(see LDA E7[3]) Default : 00h BIT READ / WRITE 7-5 Reserved. 4 3 2 DESCRIPTION R/W Watchdog Timer I count mode is 1000 times faster. 0: Disable. 1: Enable. (If bit-3 is 0, the count mode is 1/1000 seconds mode.) (If bit-3 is 1, the count mode is 1/1000 minutes mode.) R/W Select Watchdog Timer I count mode. 0: Second Mode. 1: Minute Mode. R/W Enable the rising edge of a KBC reset to issue a time-out event. 0: Disable. 1: Enable. -235 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 1 0 READ / WRITE DESCRIPTION R/W Disable / Enable the Watchdog Timer I output low pulse to the KBRST# pin 0: Disable. 1: Enable. R/W Pulse or Level mode select 0: Pulse mode 1: Level mode CR F6h. Watchdog Timer I (WDT1) Counter Register Attribute: Read/Write Power Well: VCC Reset by: LRESET# or PWROK(see LDA E7[3]) Default : 00h BIT 7-0 READ / WRITE R/W DESCRIPTION Watch Dog Timer I Time-out value. Writing a non-zero value to this register causes the counter to load the value into the Watch Dog Counter and start counting down. If CR F7h, bits 7 and 6 are set, any Mouse Interrupt or Keyboard Interrupt event causes the previously-loaded, non-zero value to be reloaded to the Watch Dog Counter and the count down resumes. Reading this register returns the current value in the Watch Dog Counter, not the Watch Dog Timer Time-out value. 00h: Time-out Disable 01h: Time-out occurs after one cycle time, the cycle time is base on LD8 CRF5, bit[3], by analogy. CR F7h. Watchdog Timer I (WDT1) Control & Status Register Attribute: Read/Write Power Well: VCC Reset by: LRESET# or PWROK(see LDA E7[3]) Default : 00h BIT READ / WRITE DESCRIPTION R/W Mouse interrupt reset enables watch-dog timer reload 0: Watchdog Timer I is not affected by mouse interrupt. 1: Watchdog Timer I is reset by mouse interrupt. 6 R/W Keyboard interrupt reset enables watch-dog timer reload 0: Watchdog Timer I is not affected by keyboard interrupt. 1: Watchdog Timer I is reset by keyboard interrupt. 5 Write “1” Only Trigger Watchdog Timer I event. This bit is self-clearing. 4 R/W Write “0” Clear Watchdog Timer I status bit 0: Watchdog Timer I is running. 1: Watchdog Timer I issues time-out event. 3-0 R/W 7 These bits select the IRQ resource for the Watchdog Timer I -236 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 19.8 Logical Device 9 (GPIO2, GPIO4, GPIO5, GPIO7, GPIO8) CR 30h. Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 00h BIT READ / WRITE 7 R/W 6 DESCRIPTION 0: GPIO7 is inactive. 1: GPIO7 is active Reserved 5 R/W 0: GPIO5 is inactive. 1: GPIO5 is active. 4 R/W 0: GPIO4 is inactive. 1: GPIO4 is active. 0: GPIO2 is inactive. 1: GPIO2 is active. 0: GPIO8 is inactive. 1: GPIO8 is active. 3 2 1 0 Reserved R/W Reserved R/W CR E0h. GPIO2 I/O Register Attribute: Read/Write Power Well: VSB Reset by: GP2X_MRST Default : FFh BIT 7-0 READ / WRITE R/W DESCRIPTION GPIO2 I/O register 0: The respective GPIO2 PIN is programmed as an output port 1: The respective GPIO2 PIN is programmed as an input port. CR E1h. GPIO2 Data Register Attribute: Read/Write Power Well: VSB Reset by: GP2X_MRST Default : 00h BIT READ / WRITE R/W 7-0 Read Only DESCRIPTION GPIO2 Data register For output ports, the respective bits can be read and written by the pins. For Input ports, the respective bits can only be read by the pins. Write accesses are ignored. CR E2h. GPIO2 Inversion Register Attribute: Read/Write Power Well: VSB Reset by: GP2X_MRST -237 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Default : 00h BIT 7-0 READ / WRITE DESCRIPTION R/W GPIO2 Inversion register 0: The respective bit and the port value are the same. 1: The respective bit and the port value are inverted. (Applies to both input and output ports) CR E3h. GPIO2 Status Register Attribute: Read Only Power Well: VSB Reset by: GP2X_MRST Default : 00h BIT 7-0 READ / WRITE Read Only Read-Clear DESCRIPTION GPIO2 Event Status Bit 7-0 corresponds to GP27-GP20, respectively. 0 : No active edge (rising/falling) has been detected 1 : An active edge (rising/falling) has been detected Read the status bit clears it to 0. CR E9h. GPIO2 Multi-function Select Register Attribute: Read/Write Power Well: VSB Reset by: GP2X_MRST Default : 00h BIT 7 READ / WRITE DESCRIPTION Reserved 6 R/W 0: GPIO26 1: GPIO26 Æ BEEP (Please also set this GPIO to “output” type.) 5 R/W 0: GPIO25 1: GPIO25 Æ SMI (Please also set this GPIO to “output” type.) 4 R/W 0: GPIO24 1: GPIO24 Æ OVT (Please also set this GPIO to “output” type.) 3 R/W 0: GPIO23 1: GPIO23 Æ GRN (Please also set this GPIO to “output” type.) 2 R/W 0: GPIO22 1: GPIO22 Æ BEEP (Please also set this GPIO to “output” type.) 1 R/W 0: GPIO21 1: GPIO21 Æ SMI (Please also set this GPIO to “output” type.) 0 R/W 0: GPIO20 1: GPIO20 Æ WDTO (Please also set this GPIO to “output” type.) CR EBh. GPIO5 Multi-function Select Register -238 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Attribute: Read/Write Power Well: VSB Reset by: GP5X_MRST Default : 00h BIT READ / WRITE 7 R/W 0: GPIO57 1: GPIO57 Æ YLW (Please also set this GPIO to “output” type.) 6 R/W 0: GPIO56 1: GPIO56 Æ GRN (Please also set this GPIO to “output” type.) 5 R/W 0: GPIO55 1: GPIO55 Æ SLPS5_LATCH (Please also set this GPIO to “output” type.) 4 R/W 0: GPIO54 1: GPIO54 Æ WDT (Please also set this GPIO to “output” type.) 3-0 DESCRIPTION Reserved CR F0h. GPIO4 I/O Register Attribute: Read/Write Power Well: VSB Reset by: GP4X_MRST Default : FFh BIT 7-0 READ / WRITE R/W DESCRIPTION GPIO4 I/O register 0: The respective GPIO4 PIN is programmed as an output port 1: The respective GPIO4 PIN is programmed as an input port. CR F1h. GPIO4 Data Register Attribute: Read/Write Power Well: VSB Reset by: GP4X_MRST Default : 00h BIT READ / WRITE R/W 7-0 Read Only DESCRIPTION GPIO4 Data register For output ports, the respective bits can be read and written by the pins. For Input ports, the respective bits can only be read by the pins. Write accesses are ignored. CR F2h. GPIO4 Inversion Register Attribute: Read/Write Power Well: VSB Reset by: GP4X_MRST Default : 00h BIT READ / WRITE DESCRIPTION -239 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7-0 READ / WRITE DESCRIPTION R/W GPIO4 Inversion register 0: The respective bit and the port value are the same. 1: The respective bit and the port value are inverted. (Applies to both input and output ports) CR E8h. GPIO4 Status Register Attribute: Read Only Power Well: VSB Reset by: GP4X_MRST Default : 00h BIT 7-0 READ / WRITE Read Only Read-Clear DESCRIPTION GPIO4 Event Status Bit 7-0 corresponds to GP47-GP40, respectively. 0 : No active edge (rising/falling) has been detected 1 : An active edge (rising/falling) has been detected Read the status bit clears it to 0. CR EEh. GPIO4 Multi-function Select Register Attribute: Read/Write Power Well: VSB Reset by: GP4X_MRST Default : 00h BIT READ / WRITE 7-3 Reserved DESCRIPTION 2 R/W 0: GPIO42 1: GPIO42 Æ BEEP (Please also set this GPIO to “output” type.) 1 R/W 0: GPIO41 1: GPIO41 Æ SMI (Please also set this GPIO to “output” type.) 0 Reserved CR F4h. GPIO5 I/O Register Attribute: Read/Write Power Well: VSB Reset by: GP5X_MRST Default : FFh BIT 7-0 READ / WRITE R/W DESCRIPTION GPIO5 I/O register 0: The respective GPIO5 PIN is programmed as an output port 1: The respective GPIO5 PIN is programmed as an input port. CR F5h. GPIO5 Data Register -240 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Attribute: Read/Write Power Well: VSB Reset by: GP5X_MRST Default : 00h BIT READ / WRITE R/W 7-0 Read Only DESCRIPTION GPIO5 Data register For output ports, the respective bits can be read and written by the pins. For input ports, the respective bits can only be read by the pins. Write accesses are ignored. CR F6h. GPIO5 Inversion Register Attribute: Read/Write Power Well: VSB Reset by: GP5X_MRST Default : 00h BIT 7-0 READ / WRITE DESCRIPTION R/W GPIO5 Inversion register 0: The respective bit and the port value are the same. 1: The respective bit and the port value are inverted. (Applies to both input and output ports) CR F7h. GPIO5 Status Register Attribute: Read Only Power Well: VSB Reset by: GP5X_MRST Default : 00h BIT 7-0 READ / WRITE Read Only Read-Clear DESCRIPTION GPIO5 Event Status Bit 7-0 corresponds to GP57-GP50, respectively. 0 : No active edge (rising/falling) has been detected 1 : An active edge (rising/falling) has been detected Read the status bit clears it to 0. CR FEh. Input Detected Type Register Attribute: Read/Write Power Well: VSB Reset by: GP3X_MRST(Bit7-6), GP4X_MRST(Bit5-4) Default : 00h BIT READ / WRITE 7-4 Reserved 4 3-0 R/W DESCRIPTION 0: Enable GP41 input de-bouncer 1: Disable GP41 input de-bouncer Reserved -241 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 19.9 Logical Device A (ACPI) CR E0h. Attribute: Read/Write Power Well: VRTC Reset by: Battery reset Default : 01h BIT READ / WRITE DESCRIPTION 7 R/W DIS_PSIN => Disable the panel switch input to turn on the system power supply. 0: PSIN is wire-AND and connected to PSOUT#. 1: PSIN is blocked and cannot affect PSOUT#. 6 R/W Enable KBC wake-up 0: Disable keyboard wake-up function via PSOUT#. 1: Enable keyboard wake-up function via PSOUT#. 5 R/W Enable Mouse wake-up 0: Disable mouse wake-up function via PSOUT#. 1: Enable mouse wake-up function via PSOUT#. MSRKEY => Three keys (ENMDAT_UP, CRE6[7]; MSRKEY, CRE0[4]; MSXKEY, CRE0[1]) define the combinations of the mouse wake-up events. Please see the following table for the details. ENMDAT_UP MSRKEY 4 R/W MSXKEY Wake-up event 1 x 1 Any button clicked or any movement. 1 x 0 One click of left or right button. 0 0 0 0 0 1 0 1 1 1 0 0 One click of the left button. One click of the right button. Two clicks of the left button. Two clicks of the right button. 3 R/W Enable CIR wake-up 0: Disable CIR wake-up function via PSOUT#. 1: Enable CIR wake-up function via PSOUT#. 2 R/W Keyboard / Mouse swap enable 0: Normal mode. 1: Keyboard / Mouse ports are swapped. R/W MSXKEY => Three keys (ENMDAT_UP, CRE6[7]; MSRKEY, CRE0[4]; MSXKEY, CRE0[1]) define the combinations of the mouse wake-up events. Please check out the table in CRE0[4] for the detailed. R/W KBXKEY => 0: Only the pre-determined key combination in sequence can wake up the system. 1: Any character received from the keyboard can wake up the system. 1 0 -242 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY CR E1h. KBC Wake-Up Index Register Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 00h BIT 7-0 READ / WRITE DESCRIPTION R/W Keyboard wake-up index register. This is the index register of CRE2, which is the access window for the keyboard’s pre-determined key key-combination characters. The first set of wake-up keys is in of 0x00 – 0x0E, the second set 0x30 – 0x3E, and the third set 0x40 – 0x4E. Incoming key combinations can be read through 0x10 – 0x1E. CR E2h. KBC Wake-Up Data Register Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 00h BIT READ / WRITE DESCRIPTION 7-0 R/W Keyboard wake-up data register. This is the data register for the keyboard’s pre-determined keycombination characters, which is indexed by CRE1. CR E3h. Event Status Register Attribute: Read Only Power Well: VRTC Reset by: Battery reset Default : 00h BIT READ / WRITE 7-5 Reserved. Read Only Read-Clear 4 DESCRIPTION This status flag indicates VSB power off/on. 3 Read Only Read-Clear Thermal shutdown status. 0: No thermal shutdown event issued. 1: Thermal shutdown event issued. 2 Read Only Read-Clear PSIN_STS 0: No PSIN event issued. 1: PSIN event issued. 1 Read Only Read-Clear MSWAKEUP_STS => The bit is latched by the mouse wake-up event. 0: No mouse wake-up event issued. 1: Mouse wake-up event issued. 0 Read Only Read-Clear KBWAKEUP_STS => The bit is latched by the keyboard wake-up event. 0: No keyboard wake-up event issued. 1: Keyboard wake-up event issued. -243 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY CR E4h. Attribute: Read/Write Power Well: VRTC Reset by: Battery reset, PWROK(Bit4), LRESET#(Bit3-2) Default : 00h BIT 7 READ / WRITE DESCRIPTION Reserved Note Power-loss control (These two bits will determine the system turn on or off after AC resume, from G3 to S5 state.) 6-5 R/W 4 R/W 3 R/W 2 R/W Bits 65 0 0: Always turn off. 0 1: Always turn on. (PSON# will active when S3# is high.) 1 0: Pre-state. (System turns On or Off which depends on the state before the power loss. Pease check the definition of the pre-state is “ON” or “OFF” in chapter 26.2.) 1 1: User defined mode for power loss last-state. (The last-state flag is located on “CRE6h, bit4.”) 3VSBSW# enable bit 0: Disable. 1: Enable. Keyboard wake-up options. 0: Password or sequence hot keys programmed in the registers. 1: Any key. Enable the hunting mode for wake-up events set in CRE0. This bit is cleared when any wake-up event is captured. (Note. This bit is use for KB and MS to generate PSOUT# while VCC valid, for example, wake-up from S1 to S0 via PSOUT#.) 0: Disable.(Default) 1: Enable. 1-0 Reserved. Note. Whether “Always turn on”, “Pre-state” or “User defined mode”, the PSON#’s active condition for system to turn-on is S3# goes high. For south-bridge which S3# default is low while AC resume, please refer “CRE7h, bit4” to achieve the power-loss control application. CR E5h. GPIOs Reset Source Register Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 02h BIT READ / WRITE 7-6 Reserved. 5 R/W DESCRIPTION GP8X_MRST 0: GP8X reset by RSMRST#. (Default) 1: GP8X reset by SLPS5. -244 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT READ / WRITE 4 R/W 3-2 1 0 DESCRIPTION GP7X_MRST 0: GP7X reset by RSMRST#. (Default) 1: GP7X reset by SLPS5. Reserved R/W Route to PWROK source selection. 0: PSON#. 1: SLP_S3#. (Default) R/W ATXPGD signal to control PWROK 0: Enable. (Default) 1: Disable. CR E6h. Attribute: Read/Write Power Well: VRTC Reset by: RSMRST#(Bit7, Bit5, Bit3-1), Battery reset(Bit6, Bit4), PWROK(Bit0) Default : 1Ch BIT READ / WRITE 7 6-5 4 R/W DESCRIPTION ENMDAT => Three keys (ENMDAT_UP, CRE6[7]; MSRKEY, CRE0[4]; MSXKEY, CRE0[1]) define the combinations of the mouse wake-up events. Please see the table in CRE0, bit 4 for the details. Reserved R/W 3-1 R/W 0 R/W Power-loss Last State Flag. 0: ON 1: OFF. (Default) PWROK_DEL Set the delay time when rising from 3VCC to PWROK Bits 321 0 0 0: 300 ~ 600mS 0 0 1: 330 ~ 670mS 0 1 0: 390 ~ 730mS 0 1 1: 520 ~ 860mS 1 0 0: 200 ~ 300mS 1 0 1: 230 ~ 370mS 1 1 0: 290 ~ 430mS (Default) 1 1 1: 420 ~ 560mS PWROK_TRIG => 0: PWROK work normally. (Default) 1: Write 1 will let PWROK keep low or from high to low immediately. CR E7h. Attribute: Read/Write Power Well: VRTC -245 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Reset by: RSMRST#(Bit7-5, Bit3-2), Battery reset(Bit4, Bit1-0) Default : 00h BIT 7 6 READ / WRITE DESCRIPTION R/W ENKD3 => Enable the third set of keyboard wake-up key combination. Its values are accessed through keyboard wake-up index register (CRE1) and keyboard wake-up data register (CRE2) at the index from 40h to 4eh. 0: Disable the third set of the key combinations. 1: Enable the third set of the key combinations. R/W ENKD2 => Enable the second set of keyboard wake-up key combination. Its values are accessed through keyboard wake-up index register (CRE1) and keyboard wake-up data register (CRE2) at the index from 30h to 3eh. 0: Disable the second set of the key combinations. 1: Enable the second set of the key combinations. 5 R/W 4 R/W 3 R/W 2-1 0 ENWIN98KEY => Enable Win98 keyboard dedicated key to wake-up system via PSOUT# when keyboard wake-up function is enabled. 0: Disable Win98 keyboard wake-up. 1: Enable Win98 keyboard wake-up. EN_ONPSOUT (VBAT) Disable/Enable to issue a 0.5s delay PSOUT# level when system returns from power loss state and is supposed to be on as described in CRE4[6:5], logic device A. (For southbridge which S3# default is low when AC resume, like VIA, AMD…etc.) 0: Disable. (Default) 1: Enable. Select WDT1 reset source 0: Watchdog timer is reset by LRESET#. 1: Watchdog timer is reset by PWROK. Reserved. R/W Hardware Monitor RESET source select 0: PWROK. (Default) 1: LRESET#. CR E9h. GPIOs Reset Source Register Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 00h BIT READ / WRITE 7-6 Reserved. 5 R/W DESCRIPTION GP5X_MRST 0: GP5X reset by RSMRST#. 1: GP5X reset by SLPS5. -246 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 4 3 2 1-0 READ / WRITE R/W DESCRIPTION GP4X_MRST 0: GP4X reset by RSMRST#. 1: GP4X reset by SLPS5. Reserved R/W GP2X_MRST 0: GP2X reset by RSMRST#. 1: GP2X reset by SLPS5. Reserved CR F0h. Attribute: Read/Write Power Well: VRTC Reset by: Battery reset Default : 00h BIT READ / WRITE DESCRIPTION Pin33 function selection 7-5 4-0 R/W LDA CRF0 [Bit7-5] Pin33 000 DEEP_S5_0 001 3VSBSW 010 LATCH_BKFD_CUT 011 ATXPGDO 1xx PWROK Reserved. CR F2h. Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 5Ch BIT READ / WRITE 7-6 Reserved 5 4 3 R/W DESCRIPTION Block SLP_S3# to PSON# 0: Disable 1: Enable Reserved R/W Enable RSTOUT1# function. 0: Disable RSTOUT1#. 1: Enable RSTOUT1#. (Default) -247 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT READ / WRITE 2 R/W 1 Reserved. 0 R/W DESCRIPTION Enable RSTOUT0# function. 0: Disable RSTOUT0#. 1: Enable RSTOUT0#. (Default) EN_PME 0 : Disable PME. (Default) 1 : Enable PME. CR F3h. Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 00h BIT READ / WRITE 7-6 Reserved DESCRIPTION 5 R / W-Clear PME status of the Mouse event. Write 1 to clear this status. 4 R / W-Clear PME status of the KBC event. Write 1 to clear this status. 3-2 1 0 Reserved R / W-Clear PME status of the URA IRQ event. Write 1 to clear this status. Reserved CR F4h. Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 00h BIT READ / WRITE 7-4 Reserved DESCRIPTION 3 R / W-Clear PME status of the HM IRQ event. Write 1 to clear this status. 2 R / W-Clear PME status of the WDT1 event. Write 1 to clear this status. 1 R / W-Clear PME status of the RIA event. Write 1 to clear this status. 0 Reserved CR F6h. Attribute: Read/Write -248 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Power Well: VSB Reset by: LRESET#(Bit7), RSMRST# Default : 00h BIT READ / WRITE 7 R/W 6 DESCRIPTION 0: Disable KB, MS interrupt of the KBC password event. 1: Enable KB, MS interrupt of the KBC password event. Reserved 5 R/W 0: Disable PME interrupt of the Mouse event. 1: Enable PME interrupt of the Mouse event. 4 R/W 0: Disable PME interrupt of the KBC event. 1: Enable PME interrupt of the KBC event. 3-2 1 0 Reserved R/W 0: Disable PME interrupt of the URA IRQ event. 1: Enable PME interrupt of the URA IRQ event. Reserved CR F7h. Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : C0h BIT 7 6 5 READ / WRITE DESCRIPTION Reserved R/W RSTOUT1# Push-Pull/OD select 0: Open Drain 1: Push-Pull (Default) Reserved 4 R/W 0: Disable PME interrupt of the CIRWAKEUP IRQ event. 1: Enable PME interrupt of the CIRWAKEUP IRQ event. 3 R/W 0: Disable PME interrupt of the HM IRQ event. 1: Enable PME interrupt of the HM IRQ event. 2 R/W 0: Disable PME interrupt of the WDT1 event. 1: Enable PME interrupt of the WDT1 event. 1 R/W 0: Disable PME interrupt of the RIA event. 1: Enable PME interrupt of the RIA event. 0 Reserved CR FEh. GPIO41 Event Route Selection Register Attribute: Read/Write Power Well: VRTC Reset by: Battery reset Default : 00h -249 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT READ / WRITE 7 R/W 6-4 3 2-0 DESCRIPTION 0: Disable GP41 event route to PSOUT#. 1: Enable GP41 event route to PSOUT#. Reserved R/W 0: Disable GP41 event route to PME#. 1: Enable GP41 event route to PME#. Reserved -250 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 19.10 Logical Device B (Hardware Monitor, Front Panel LED) CR 30h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE 7-1 Reserved. 0 R/W DESCRIPTION 0: Hardware Monitor & SB-TSI device is inactive. 1: Hardware Monitor & SB-TSI device is active. CR 60h, 61h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h, 00h BIT READ / WRITE DESCRIPTION 7-0 R/W These two registers select the HM base address along a two-byte boundary. CR 62h, 63h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h, 00h BIT READ / WRITE DESCRIPTION 7-0 R/W These two registers select the SB-TSI base address along a two-byte boundary. CR 70h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE 7-4 Reserved. 3-0 R/W DESCRIPTION These bits select the IRQ resource for HM. CR E0h. SYSFAN Duty Cycle Register Attribute: Read/Write Power Well: VSB Reset by: RSMRST# -251 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Default : 7Fh BIT READ / WRITE 7-0 R/W DESCRIPTION SYSFAN Duty Cycle Register CR E1h. CPUFAN Duty Cycle Register Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 7Fh BIT READ / WRITE 7-0 R/W DESCRIPTION CPUFAN Duty Cycle Register CR F0h. FANIN De-bouncer Register Attribute: Read/Write Power Well: VSB Reset by: LRESET# Default : 00h BIT READ / WRITE 7-3 Reserved. DESCRIPTION 2 R/W 1: Enable CPUFANIN input de-bouncer. 0: Disable CPUFANIN input de-bouncer. 1 R/W 1: Enable SYSFANIN input de-bouncer. 0: Disable SYSFANIN input de-bouncer. 0 Reserved. CR F1h. SMI IRQ Register Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE 7 R/W 6-0 DESCRIPTION SMI IRQ Enable Reserved. CR F2h. Deep S3 Sleeping State Front panel Green & Yellow LED control register Attribute: Read/Write Power Well: VRTC Reset by: Battery reset Default : 00h BIT READ / WRITE DESCRIPTION -252 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 7-4 3-0 READ / WRITE DESCRIPTION R/W Deep S3_YLW_BLK_FREQ bits (This function affects by LDB CRF9 Bit 7) 0000: High-Z. (The output type of YLW_LED is open-drain.) (Default) 0001: YLW_LED outputs 0.0625Hz. 0010: YLW_LED outputs 0.125Hz. 0011: YLW_LED outputs 0.25Hz. 0100: YLW_LED outputs 0.5Hz 0101: YLW_LED outputs 1Hz. 0110: YLW_LED outputs 2Hz. 0111: YLW_LED outputs low. 1XXX: Fading LED. R/W Deep S3_GRN_BLK_FREQ bits (This function affects by LDB CRF9 Bit 6) 0000: High-Z. (The output type of YLW_LED is open-drain.) (Default) 0001: GRN_LED outputs 0.0625Hz. 0010: GRN_LED outputs 0.125Hz. 0011: GRN_LED outputs 0.25Hz. 0100: GRN_LED outputs 0.5Hz 0101: GRN_LED outputs 1Hz. 0110: GRN_LED outputs 2Hz. 0111: GRN_LED outputs low. 1XXX: Fading LED. CR F5h. SMBus de-bouncer Register Attribute: Read/Write Power Well: VSB Reset by: RSMRST#, PWROK(Bit7-5) Default : 00h BIT READ / WRITE 7-5 R/W 4-3 Reserved. DESCRIPTION MLED Frequency 000: always high 001: always low 010: 4 Hz 011: 2 Hz 100: 1 Hz 101: 1/2 Hz 110: 1/4 Hz 111: 1/8 Hz 1 R/W 1: Enable SCL input de-bouncer 160ns. 0: Disable SCL input de-bouncer. 0 R/W 1: Enable SDA input de-bouncer 160ns. 0: Disable SDA input de-bouncer. CR F6h. Deep S5 Front Panel Green & Yellow LED control register -253 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Attribute: Read/Write Power Well: VRTC Reset by: Battery reset Default : 00h BIT 7-4 3-0 READ / WRITE DESCRIPTION R/W Deep S5_YLW_BLK_FREQ bits (This function affects by LDB CRF9 Bit 5) 0000: High-Z. (The output type of YLW_LED is open-drain.) (Default) 0001: YLW_LED outputs 0.0625Hz. 0010: YLW_LED outputs 0.125Hz. 0011: YLW_LED outputs 0.25Hz. 0100: YLW_LED outputs 0.5Hz 0101: YLW_LED outputs 1Hz. 0110: YLW_LED outputs 2Hz. 0111: YLW_LED outputs low. 1XXX: Fading LED. R/W Deep S5_GRN_BLK_FREQ bits (This function affects by LDB CRF9 Bit 4) 0000: High-Z. (The output type of YLW_LED is open-drain.) (Default) 0001: GRN_LED outputs 0.0625Hz. 0010: GRN_LED outputs 0.125Hz. 0011: GRN_LED outputs 0.25Hz. 0100: GRN_LED outputs 0.5Hz 0101: GRN_LED outputs 1Hz. 0110: GRN_LED outputs 2Hz. 0111: GRN_LED outputs low. 1XXX: Fading LED. CR F7h. Front Panel Green LED (GRN_LED) control register Attribute: Read/Write Power Well: VRTC Reset by: Battery reset Default : 87h BIT READ / WRITE DESCRIPTION 7 R/W AUTO_EN (Powered by VSB, RSMRST# reset , default = 1) 0: GRN_LED and YLW_LED are controlled by GRN_ LED_ RST, GRN_BLK_FREQ and YLW_LED_RST, YLW_BLK_FREQ bits. 1: GRN_LED and YLW_LED are controlled by “SLP_S5#” and “SLP_S3#”. 6 R/W GRN_LED_RST# (Default= 0) 0: GRN_BLK_FREQ will be set to “0000” (High-Z) when into S3~S5 state. 1: GRN_BLK_FREQ will be kept when into S3~S5 state. 5 R/W GRN_LED_POL 0: GRN_LED output is active low. (Default) 1: GRN_LED output is active high. 4 Reserved. -254 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 3-0 READ / WRITE R/W DESCRIPTION GRN_BLK_FREQ bits (The reset depends on bit6, GRN_LED_RST#) 0000: High-Z. (The output type of YLW_LED is open-drain.) 0001: GRN_LED outputs 0.0625Hz. 0010: GRN_LED outputs 0.125Hz. 0011: GRN_LED outputs 0.25Hz. 0100: GRN_LED outputs 0.5Hz 0101: GRN_LED outputs 1Hz. 0110: GRN_LED outputs 2Hz. 0111: GRN_LED outputs low. (Default) 1XXX: Fading LED. CR F8h. Front Panel Yellow LED (YLW_LED) control register Attribute: Read/Write Power Well: VRTC Reset by: Battery reset Default : 47h BIT READ / WRITE DESCRIPTION 7 Reserved. 6 R/W YLW_LED_RST# (Default =1) 0: YLW_BLK_FREQ will be set to “0000” (High-Z) when into S3~S5 state. 1: YLW_BLK_FREQ will be kept when into S3~S5 state. 5 R/W YLW_LED_POL 0: YLW_LED output is active low. (Default) 1: YLW_LED output is active high. 4 Reserved. 3-0 R/W YLW_BLK_FREQ bits (The reset depends on bit6,YLW_LED_RST#) 0000: High-Z. (The output type of YLW_LED is open-drain.) 0001: YLW_LED outputs 0.0625Hz. 0010: YLW_LED outputs 0.125Hz. 0011: YLW_LED outputs 0.25Hz. 0100: YLW_LED outputs 0.5Hz 0101: YLW_LED outputs 1Hz. 0110: YLW_LED outputs 2Hz. 0111: YLW_LED outputs low. (Default) 1XXX: Fading LED. CR F9h. Deep Sleep LED Eanble register Attribute: Read/Write Power Well: VRTC Reset by: Battery reset Default : 00h BIT READ / WRITE DESCRIPTION -255 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT READ / WRITE 7 R/W Deep S3_YLW_BLK_FREQ : 0: Depend on setting of CRF2h, bit7~4. 1: Always output high. 6 R/W Deep S3_GRN_BLK_FREQ : 0: Depend on setting of CRF2h, bit3~0. 1: Always output high. 5 R/W Deep S5_YLW_BLK_FREQ : 0: Depend on setting of CRF6h, bit7~4. 1: Always output high. 4 R/W Deep S5_GRN_BLK_FREQ : 0: Depend on setting of CRF2h, bit3~0. 1: Always output high. 3-0 DESCRIPTION Reserved. -256 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 19.11 Logical Device D (WDT1) CR F0h. Register Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 00h BIT READ / WRITE 7 RO 6-0 DESCRIPTION Mask WDT1 to affect PWROK 0: Mask disable. (WDT1 default affect PWROK) 1: Mask enable. (WDT1 not affect PWROK) Reserved. -257 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 19.12 Logical Device E (CIR WAKE-UP) CR 30h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE 7-1 Reserved. 0 R/W DESCRIPTION 0: CIR Wake-up is inactive. 1: CIR Wake-up Interface is active. CR 60h, 61h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h, 00h BIT READ / WRITE DESCRIPTION 7-0 R/W These two registers select CIR Wake-up Interface I/O base address on 1 byte boundary. CR 70h. Attribute: Read/Write Power Well: VCC Reset by: LRESET# Default : 00h BIT READ / WRITE 7-4 Reserved. 3-0 R/W DESCRIPTION These bits select IRQ resource for CIR Wake-up. -258 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 19.13 Logical Device F (GPIO Push-pull or Open-drain selection) CR E1h. Attribute: Read/Write Power Well: VSB Reset by: GP2X_MRST Default : FFh BIT 7-0 READ / WRITE R/W DESCRIPTION GP2 Push-Pull/OD select 0:Push-Pull 1:Open Drain CR E3h. Attribute: Read/Write Power Well: VSB Reset by: GP4X_MRST Default : FFh BIT 7-0 READ / WRITE R/W DESCRIPTION GP4 Push-Pull/OD select 0:Push-Pull 1:Open Drain CR E4h. Attribute: Read/Write Power Well: VSB Reset by: GP5X_MRST Default : FFh BIT 7-0 READ / WRITE R/W DESCRIPTION GP5 Push-Pull/OD select 0:Push-Pull 1:Open Drain CR E6h. Attribute: Read/Write Power Well: VSB Reset by: GP7X_MRST Default : 0Fh BIT READ / WRITE 7-4 Reserved 3-0 R/W DESCRIPTION GP7 Push-Pull/OD select 0:Push-Pull 1:Open Drain -259 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY CR E7h. Location: Address E7h Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : FFh Size: 8 bits BIT READ / WRITE 7-0 R/W DESCRIPTION GP8 Push-Pull/OD select 0:Push-Pull 1:Open Drain CR F0h. I2C Control & Address Register Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 9Dh BIT READ / WRITE DESCRIPTION 7 R/W Enable I2C_Slave 6-0 R/W I2C Address CR F1h. I2C to 80PORT Control Register Attribute: Read/Write Power Well: VSB Reset by: LRESET# Default : 00h BIT READ / WRITE 7-2 Reserved. DESCRIPTION 1 R/W 80PORT Display 0: Enable 1: Disable 0 R/W LPC or I2C to 80PORT switch CR F2h. I2C to 80PORT Data Register Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 00h BIT READ / WRITE 7-0 R/W DESCRIPTION I2C to 80PORT Data -260 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 19.14 Logical Device 16 (Deep Sleep) CR 30h. Deep Sleep configuration register Attribute: Read/Write Power Well: VRTC Reset by: Battery reset Default : 20h BIT READ / WRITE 7 R/W 6 R/W DESCRIPTION DIS_SLPSUS_PULLUP (test mode) 0: Enable pin 44 (SLP_SUS#) internal pull-up. 1: Disable pin 44 (SLP_SUS#) internal pull-up. RSMRST# Detect Source Select for Deep Sleep Mode. 0: RSMRST# detected source from PSOUT# voltage (Pin28). 1: Reserved Note. Set to 0, if Deep S5 is enabled. Set to 1, if DSW is enabled. 5 4 Reserved R/W dsw_wake_opt (test mode) 0: The PSOUT# will assert until SLPS3# high when deep s5 wakeup event happened. 1: The PSOUT# will assert until RSMRST_L high and SLP_SUS_L high when deep s5 wakeup event happened. PS. This bit only active when PCH_DSW_EN & (Deep S5 Enable | Deep S3 Enable) 3 R/W PCH DSW Enable 0: If PCH disable DSW function. 1: if PCH enable DSW function. (SLP_SUS# affects RSMRST#) 2 R/W Reserved R/W Deep S3 Enable 0: If SLP_S3# state will not enter Deep S3 state. 1: If SLP_S3# state will enter Deep S3 state. R/W Deep S5 Enable 0: Disable Deep S5 function when into S5 state (SLP_S5#). 1: Enable Deep S5 function when into S5 state (SLP_S5#). 1 0 CR E0h. Deep Sleep wake up PSOUT# delay time Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 20h (Default: 512ms) BIT READ / WRITE 7-6 Reserved. DESCRIPTION -261 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY BIT 5-0 READ / WRITE DESCRIPTION R/W Deep Sleep wake up PSOUT# delay time. When system wake up from deep sleep state, IO will issue a low pulse via PSOUT# after SYS_3VSB and wait a delay time. DELAY TIME = (Setting Value) * 16ms Example : maximum delay time = (3F)hex * 16ms = 1008ms CR E1h. Deep Sleep wake up PSOUT# pulse width Attribute: Read/Write Power Well: VSB Reset by: RSMRST# Default : 04h (Default: 128 ms) BIT READ / WRITE 7-4 Reserved. 3-0 R/W DESCRIPTION Deep Sleep wake up PSOUT# pulse width. When system wake up from deep sleep state, IO will issue a low pulse via PSOUT#.. Pulse Width = (Setting Value) * 32ms Example : maximum pulse width = (F)hex * 32ms = 480ms CR E2h. Deep Sleep Delay Time Control Attribute: Read/Write Power Well: VRTC Reset by: Battery reset Default : 05h BIT READ / WRITE 7 R/W 0: The unit of deep sleep delay time is second. 1: The unit of deep sleep delay time is Minute. R/W Deep Sleep Delay Time Control. When system leaves S0 State, IO will wait a delay time before entering into Deep Sleep State. Example: maximum delay time = 127 second/minute 6-0 DESCRIPTION -262 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 20. SPECIFICATIONS 20.1 Absolute Maximum Ratings SYMBOL PARAMETER RATING UNIT 3VCC Power Supply Voltage (3.3V) -0.3 to 3.6 V -0.3 to 3VCC+0.3 V -0.3 to 5.5 V 0 to +70 °C -55 to +150 °C Input Voltage VI Input Voltage (5V tolerance) TA Operating Temperature TSTG Storage Temperature Note: Exposure to conditions beyond those listed under Absolute Maximum Ratings may adversely affect the life and reliability of the device. 20.2 DC CHARACTERISTICS (TA = 0°C to +70°C, VDD = 3.3V ± 5%, VSS = 0V) PARAMETER Battery Quiescent Current ACPI Stand-by Power Supply Quiescent Current VCC Quiescent Current Vtt Quiescent Current SYM MIN IBAT IVSB TYP MAX. UNIT 2.4 μA 8.0 IVCC 25 IVTT 1 CONDITIONS VBAT = 2.5 V mA VSB = 3.3 V, All ACPI pins are not connected. mA VSB = 3.3 V VCC (AVCC)= 3.3 V LRESET = High IOCLK = 48MHz CASEOPEN Pull-Up to VBAT mA VSB = 3.3 V VCC (AVCC)= 3.3 V VTT = 1.2V LRESET = High IOCLK = 48MHz CASEOPEN Pull-Up to VBAT AIN – Analog input AOUT – Analog output INtp3 – 3.3V TTL-level input pin -263 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY PARAMETER SYM MIN TYP MAX. UNIT 0.8 V Input Low Voltage VIL Input High Voltage VIH Input High Leakage ILIH +10 Input Low Leakage ILIL -10 μA 2.0 CONDITIONS V INtsp3 – 3.3V TTL-level, Schmitt-trigger input pin μA VIN = 3.3V VIN = 0 V Input Low Threshold Voltage Vt- 0.5 0.8 1.1 V VCC = 3.3 V Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V VCC = 3.3 V Hystersis VTH 0.5 1.2 V VCC = 3.3 V Input High Leakage ILIH +10 VIN = 3.3 V Input Low Leakage ILIL -10 μA INgp5 – 5V GTL-level input pin μA Input Low Voltage VIL 0.72 V Input High Voltage VIH 0.72 V Input High Leakage ILIH +10 Input Low Leakage ILIL -10 μA Input Low Voltage VIL 0.8 V Input High Voltage VIH Input High Leakage ILIH +10 Input Low Leakage ILIL -10 INtp5 – 5V TTL-level input pin 2.0 μA VIN = 0 V VIN = 3.3V VIN = 0 V V INtscup5 – 5V TTL-level, Schmitt-trigger input buffer with controllable pull-up μA μA VIN = 3.3V VIN = 0 V Input Low Threshold Voltage Vt- 0.5 0.8 1.1 V VCC = 3.3 V Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V VCC = 3.3 V Hystersis VTH 0.5 1.2 V VCC = 3.3 V Input High Leakage ILIH +10 VIN = 3.3 V Input Low Leakage ILIL -10 μA INtsp5 – 5V TTL-level, Schmitt-trigger input pin μA VIN = 0 V Input Low Threshold Voltage Vt- 0.5 0.8 1.1 V VCC = 3.3 V Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V VCC = 3.3 V Hystersis VTH 0.5 1.2 V VCC = 3.3 V Input High Leakage ILIH +10 VIN = 3.3 V Input Low Leakage ILIL -10 μA 0.8 V INtdp5 – 5V TTL-level input pin with internal pull-down resistor Input Low Voltage VIL Input High Voltage VIH 2.0 -264 μA VIN = 0 V V Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY PARAMETER SYM MIN TYP MAX. UNIT CONDITIONS VIN = 3.3V Input High Leakage ILIH +10 Input Low Leakage ILIL -10 μA 0.4 V IOL = 8 mA V IOH = -8 mA 0.4 V IOL = 8 mA 0.4 V IOL = 12 mA V IOH = -12 mA 0.4 V IOL = 12 mA 0.4 V IOL = 24 mA V IOH = -24 mA 0.4 V IOL = 24 mA 0.4 V IOL = 48 mA V IOH = -48 mA V IOL = 48 mA O8 – Output pin with 8mA source-sink capability Output Low Voltage VOL Output High Voltage VOH μA 2.4 VIN = 0 V OD8 – Open-drain output pin with 8mA sink capability Output Low Voltage VOL O12 – Output pin with 12mA source-sink capability Output Low Voltage VOL Output High Voltage VOH 2.4 OD12 – Open-drain output pin with 12mA sink capability Output Low Voltage VOL O24 – Output pin with 24mA source-sink capability Output Low Voltage VOL Output High Voltage VOH 2.4 OD24 – Open-drain output pin with 24mA sink capability Output Low Voltage VOL O48 – Output pin with 48mA source-sink capability Output Low Voltage VOL Output High Voltage VOH 2.4 OD48 – Open-drain output pin with 48mA sink capability Output Low Voltage VOL 0.4 ® I/OV3 – Bi-direction pin with source capability of 6 mA and sink capability of 1 mA for INTEL PECI Input Low Voltage VIL 0.275*Vtt 0.5*Vtt V Input High Voltage VIH 0.55*Vtt 0.725*Vtt V Output Low Voltage VOL 0.25*Vtt V Output High Voltage VOH 0.75*Vtt V Hysterisis VHys 0.1*Vtt V O12cu – Output pin 12mA source-sink capability with controllable pull-up Output Low Voltage VOL Output High Voltage VOH 0.4 2.4 V IOL = 12 mA V IOH = -12 mA V IOL = 12 mA OD12cu – Open-drain 12mA sink capability output pin with controllable pull-up Output Low Voltage VOL 0.4 -265 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 21. AC CHARACTERISTICS 21.1 Power On / Off Timing PSON# T3 T4 SLP_S3# (Intel Chipset) S3# (Other Chipset) PSOUT# T1 PSIN# T2 3VSB G3 IDEAL TIMING S0 S5 S5 T1 T2 T3 T4 64ms Over 64ms at least < 10ns 32ms -266 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 21.2 AC Power Failure Resume Timing (1) Logical Device A, CR [E4h] bits [6:5] =00 means “OFF” state (“OFF” means the system is always turned off after the AC power loss recovered.) 3VCC PSOUT# PSON# SLP_S3# RSMRST# 3VSB ACLOSS -267 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY (2) Logical Device A, CR [E4h] bits [6:5]=01 means “ON” state. (“ON” means the system is always turned on after AC power loss recovered.) 3VCC PSOUT# PSON# SLP_S3# RSMRST# 3VSB ACLOSS -268 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY ** What’s the definition of former state at AC power failure? 1) The previous state is “ON” VCC falls to 2.6V and SLP_S3# keeps at VIH 2.0V 3VCC SLP_S3# 2) The previous state is “OFF” VCC fall to 2.6V and SLP_S3# keeps at VIL 0.8V 3VCC SLP_S3# To ensure that VCC does not fall faster than VSB in various ATX Power Supplies, the NCT5532D adds the option of “user define mode” for the pre-defined state before AC power failure. BIOS can set the pre-defined state for the system to be “On” or “Off”. According to this setting, the system chooses the state after the AC power recovery. Please refer to the descriptions of bit 6~5 of CR E4h and bit 4 of CR E6h in Logical Device A. CR E4h BIT READ/WRITE DESCRIPTION R/W Power-loss control bits => (VBAT) 0 0: System always turns off when it returns from power-loss state. 0 1: System always turns on when it returns from power-loss state. 1 0: System turns off / on when it returns from power-loss state depending on the state before the power loss. 1 1: User defines the resuming state before power loss.(refer to Logic Device A, CRE6[4]) BIT READ/WRITE DESCRIPTION 4 R/W 6~5 CR E6h Power loss Last State Flag. (VBAT) 0: ON 1: OFF -269 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 21.3 Clock Input Timing 48MHZ / 24MHZ PARAMETER MIN Cycle to cycle jitter Duty cycle UNIT MAX 300/500 ps 55 % 45 t1 t2 t3 PARAMETER 48MHZ / 24MHZ DESCRIPTION MIN t1 Clock cycle time t2 Clock high time/low time t3 Clock rising time/falling time (0.4V~2.4V) 9 / 19 TYP UNIT MAX 20.8 / 41.7 ns 10 / 21 ns 3 -270 ns Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 21.4 PECI Timing SYMBOL tBIT MIN TYP MAX UNITS μs Client 0.495 500 Originator 0.495 250 tH1 0.6 3/4 0.8 × tBIT tH0 0.2 1/4 0.4 × t BIT -271 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 21.5 SMBus Timing TLOW TR TF SMBCLK THIGH THD:STA TSU:DAT TSU:STO TSU:STA THD:DAT SMBDAT TBUF P S S -272 P Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 21.6 UART PARAMETER SYMBOL TEST CONDITIONS MIN. MAX. UNIT Delay from Stop to Set Interrupt TSINT 9/16 Delay from IOR Reset Interrupt TRINT 9 1000 nS Delay from Initial IRQ Reset to Transmit Start TIRS 1/16 8/16 Baud Rate Delay from to Reset interrupt THR 175 nS Delay from Initial IOW to interrupt TSI 16/16 Baud Rate Delay from Stop to Set Interrupt TSTI 8/16 Baud Rate Delay from IOR to Reset Interrupt TIR 8 250 nS TMWO 6 200 nS Set Interrupt Delay from Modem Input TSIM 18 250 nS Reset Interrupt Delay from IOR TRIM 9 250 nS Delay from IOR to Output 9/16 N Baud Divisor Baud Rate 216-1 100 pF Loading UART Receiver Timing Receiver Timing SIN (RECEIVER INPUT DATA) START DATA BITS (5-8) PARITY STOP TSINT IRQ (INTERNAL SIGNAL) TSTI IRQ# (INTERNAL SIGNAL. READ RECEIVER BUFFER REGISTER) UART Transmitter Timing SOUT (SERIAL OUT) START DATA BITS (5-8) PARITY TIRS IRQ (INTERNAL SIGNAL) STOP (1-2) TSTI START THR TSI THR IOW# (INTERNAL SIGNAL, WRITE THR) TIR IOR# (INTERNAL SIGNAL, READ TIR) -273 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 21.7 Modem Control Timing Modem Control Timing MODEM Control Timing START IOW# (INTERNAL SIGNAL, WRITE MCR) TMWO TMWO RTS#, DTR# CTS#, DSR#, DCD# TSIM TSIM IRQ (INTERNAL SIGNAL) IOR# (INTERNAL SIGNAL READ MSR) TRIM TRIM TSIM RI# -274 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 21.7.1 Writing Cycle Timing Write Cycle Timing A2, CSB T1 T3 WRB T5 ACTIVE T7 T8 D0 ~ D7 DATA IN T9 GA20 OUTPUT PORT 21.7.2 Read Cycle Timing Read Cycle A2, CSB AEN T2 T6 T4 RDB ACTIVE T11 T10 D0 ~ D7 DATA OUT 21.7.3 Send Data to K/B Send Data to K/B CLOCK (KCLK) T14 T12 SERIAL DATA (KDAT) START D0 D1 D2 D3 T13 D4 -275 T26 D5 D6 D7 P STOP Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 21.7.4 Receive Data from K/B Receive Data from K/B CLOCK (KCLK) T14 T15 SERIAL DATA (T1) START D0 D1 D2 T13 D3 D4 D5 D6 D7 P STOP T20 21.7.5 Input Clock Input Clock CLOCK T21 21.7.6 Send Data to Mouse Send Data to Mouse MCLK T25 MDAT START Bit T23 T22 D0 D1 D2 D3 T24 D4 D5 D6 D7 P STOP Bit 21.7.7 Receive Data from Mouse Receive Data from Mouse MCLK T27 T26 T29 MDAT T28 START D0 D1 D2 D3 D4 D5 -276 D6 D7 P STOP Bit Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 21.8 GPIO Timing Parameters SYMBOL tWGO PARAMETER MIN. Write data to GPIO update MAX. UNIT 300(Note 1) ns Note: Refer to Microprocessor Interface Timing for Read Timing. 21.8.1 GPIO Write Timing GPIO Write Timing diagram A0-A15 VALID IOW D0-7 GPIO10-17 GPIO20-25 VALID PREVIOUS STATE VALID tWGO -277 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 22. TOP MARKING SPECIFICATIONS NCT5532D 28201234 123G9AFA 1st line: Nuvoton logo 2nd line: part number: NCT5532D (Green package) 3rd line: wafer production series lot number: 28201234 4th line: tracking code 123G9AFA 123: packages made in 2011, week 23 G: assembly house ID; G means GR, A means ASE, etc 9: code version; 9 means code 009 A: IC revision; A means version A; B means version B, and C means version C FA: Nuvoton internal use -278 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 23. ORDERING INFORMATION PART NUMBER PACKAGE TYPE PRODUCTION FLOW NCT5532D 64Pin LQFP (Green package) Commercial, 0°C to +70°C -279 Publication Release Date: September 30, 2011 Version: 0.7 nuvoTon NCT5532D PRELIMINARY 24. PACKAGE SPECIFICATION D 4! I I --t -- w w I 1& I 3 I C'I C\1 ci GAUGE PLANE-I::=t;::::::::i SEATING PI..ANE-I e DETAIL "A" -280 Puhlication RElease Date: September 30,2011 Version: 0.7 NCT5532D PRELIMINARY 64-pin (LQFP, 7x7x1.4mm) -281 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY 25. REVISION HISTORY VERSION DATE PAGE DESCRIPTION 0.1 06/23/2011 N.A. Draft datasheet 0.2 07/20/2011 N.A. Modify pin configuration 0.5 07/26/2011 N.A. Add functional description and register information 0.6 09/28/2011 P.238, P.239 0.7 09/30/2011 P.239 Correct GPIO (GP24, GP55) multi-function description Correct GPIO (GP54) multi-function description -282 Publication Release Date: September 30, 2011 Version: 0.7 NCT5532D PRELIMINARY Important Notice Nuvoton products are not designed, intended, authorized or warranted for use as components in systems or equipment intended for surgical implantation, atomic energy control instruments, airplane or spaceship instruments, transportation instruments, traffic signal instruments, combustion control instruments, or for other applications intended to support or sustain life. Furthermore, Nuvoton products are not intended for applications wherein failure of Nuvoton products could result or lead to a situation wherein personal injury, death or severe property or environmental damage could occur. Nuvoton customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Nuvoton for any damages resulting from such improper use or sales. -283 Publication Release Date: September 30, 2011 Version: 0.7
NCT5532D 价格&库存
很抱歉,暂时无法提供与“NCT5532D”相匹配的价格&库存,您可以联系我们找货
