AT25XE021A-SSHN-T
AT25XE021A-SSHN-T
    DIALOGSEMICONDUCTOR(戴乐格)
    SOIC8_150MIL
    ICFLASH2MBIT85MHZ8SOIC
AT25XE021A-SSHN-T 数据手册
AT25XE021A 2-Mbit, 1.65V Minimum SPI Serial Flash Memory with Dual-I/O Support Features  Single 1.65V - 3.6V Supply  Serial Peripheral Interface (SPI) Compatible Supports SPI Modes 0 and 3 Supports Dual-I/O Operation  70MHz Maximum Operating Frequency  Clock-to-Output (tV) of 6 ns  Flexible, Optimized Erase Architecture for Code + Data Storage Applications  Small (256-Byte) Page Erase  Uniform 4-Kbyte Block Erase  Uniform 32-Kbyte Block Erase  Uniform 64-Kbyte Block Erase  Full Chip Erase  Hardware Controlled Locking of Protected Sectors via WP Pin    128-byte, One-Time Programmable (OTP) Security Register 64 bytes factory programmed with a unique identifier 64 bytes user programmable  Flexible Programming  Byte/Page Program (1 to 256 Bytes)  Dual-Input Byte/Page Program (1 to 256 Bytes)  Sequential Program Mode Capability  Fast Program and Erase Times  2ms Typical Page Program (256 Bytes) Time  45ms Typical 4-Kbyte Block Erase Time  360ms Typical 32-Kbyte Block Erase Time  720ms Typical 64-Kbyte Block Erase Time  Automatic Checking and Reporting of Erase/Program Failures    Software Controlled Reset  JEDEC Standard Manufacturer and Device ID Read Methodology  Low Power Dissipation 200nA Ultra Deep Power Down current (Typical) 4.5µA Deep Power-Down Current (Typical) 25uA Standby current (Typical) 3mA Active Read Current (Typical)  Endurance: 100,000 Program/Erase Cycles      Data Retention: 20 Years  Complies with Full Industrial Temperature Range  Industry Standard Green (Pb/Halide-free/RoHS Compliant) Package Options      8-lead SOIC (150-mil) 8-pad Ultra Thin DFN (2 x 3 x 0.6 mm) 8-pad Ultra Thin DFN (5 x 6 x 0.6 mm) 8-lead TSSOP Package 8-ball WLCSP(1) Note: 1. Contact factory for availability. DS-25XE021A–061I–9/2017 1. Description The Adesto® AT25XE021A is a serial interface Flash memory device designed for use in a wide variety of high-volume consumer based applications in which program code is shadowed from Flash memory into embedded or external RAM for execution. The flexible erase architecture of the AT25XE021A, with its page erase granularity it is ideal for data storage as well, eliminating the need for additional data storage devices. The erase block sizes of the AT25XE021A have been optimized to meet the needs of today's code and data storage applications. By optimizing the size of the erase blocks, the memory space can be used much more efficiently. Because certain code modules and data storage segments must reside by themselves in their own erase regions, the wasted and unused memory space that occurs with large sectored and large block erase Flash memory devices can be greatly reduced. This increased memory space efficiency allows additional code routines and data storage segments to be added while still maintaining the same overall device density. The device also contains a specialized OTP (One-Time Programmable) Security Register that can be used for purposes such as unique device serialization, system-level Electronic Serial Number (ESN) storage, locked key storage, etc. Specifically designed for use in many different systems, the AT25XE021A supports read, program, and erase operations with a wide supply voltage range of 1.65V to 3.6V. No separate voltage is required for programming and erasing. 2. Pin Descriptions and Pinouts Table 2-1. Symbol CS SCK Pin Descriptions Name and Function CHIP SELECT: Asserting the CS pin selects the device. When the CS pin is deasserted, the device will be deselected and normally be placed in standby mode (not Deep Power-Down mode), and the SO pin will be in a high-impedance state. When the device is deselected, data will not be accepted on the SI pin. A high-to-low transition on the CS pin is required to start an operation, and a low-to-high transition is required to end an operation. When ending an internally self-timed operation such as a program or erase cycle, the device will not enter the standby mode until the completion of the operation. SERIAL CLOCK: This pin is used to provide a clock to the device and is used to control the flow of data to and from the device. Command, address, and input data present on the SI pin is always latched in on the rising edge of SCK, while output data on the SO pin is always clocked out on the falling edge of SCK. Asserted State Type Low Input - Input - Input/ Output - Input/ Output SERIAL INPUT: The SI pin is used to shift data into the device. The SI pin is used for all data input including command and address sequences. Data on the SI pin is always latched in on the rising edge of SCK. SI (I/O0) With the Dual-Output Read commands, the SI Pin becomes an output pin (I/O0) in conjunction with other pins to allow two bits of data on (I/O1-0) to be clocked out on every falling edge of SCK. To maintain consistency with the SPI nomenclature, the SI (I/O0) pin will be referenced as the SI pin unless specifically addressing the Dual-I/O modes in which case it will be referenced as I/O0. Data present on the SI pin will be ignored whenever the device is deselected (CS is deasserted). SERIAL OUTPUT: The SO pin is used to shift data out from the device. Data on the SO pin is always clocked out on the falling edge of SCK. SO (I/O1) With the Dual-Output Read commands, the SO Pin remains an output pin (I/O1) in conjunction with other pins to allow two bits of data on (I/O1-0) to be clocked out on every falling edge of SCK. To maintain consistency with the SPI nomenclature, the SO (I/O1) pin will be referenced as the SO pin unless specifically addressing the Dual-I/O modes in which case it ise referenced as I/O1. The SO pin will be in a high-impedance state whenever the device is deselected (CS is deasserted). AT25XE021A DS-25XE021A–061I–9/2017 2 Table 2-1. Symbol Pin Descriptions (Continued) Name and Function WRITE PROTECT: The WP pin controls the hardware locking feature of the device. Please refer to “Protection Commands and Features” on page 17 for more details on protection features and the WP pin. WP The WP pin is internally pulled-high and may be left floating if hardware controlled protection will not be used. However, it is recommended that the WP pin also be externally connected to VCC whenever possible. Asserted State Type Low Input Low Input - Power - Power HOLD: The HOLD pin is used to temporarily pause serial communication without deselecting or resetting the device. While the HOLD pin is asserted, transitions on the SCK pin and data on the SI pin will be ignored, and the SO pin will be in a high-impedance state. The CS pin must be asserted, and the SCK pin must be in the low state in order for a Hold condition to start. A Hold condition pauses serial communication only and does not have an effect on internally self-timed operations such as a program or erase cycle. Please refer to “Hold” on page 35 for additional details on the Hold operation.The HOLD pin is internally pulled-high and may be left floating if the Hold function will not be used. However, it is recommended that the HOLD pin also be externally connected to VCC whenever possible. HOLD DEVICE POWER SUPPLY: The VCC pin is used to supply the source voltage to the device. VCC Operations at invalid VCC voltages may produce spurious results and should not be attempted. GROUND: The ground reference for the power supply. GND should be connected to the system ground. GND Table 2-2. Pinouts Figure 2-1. 8-SOIC Top View CS SO WP GND Figure 2-3. 8-UDFN Top View 1 2 3 4 8 7 6 5 CS SO WP GND VCC HOLD SCK SI 1 8 2 7 3 6 4 5 Figure 2-4. WLCSP Bottom View(1) Figure 2-2. 8-TSSOP Top View SCK CS SO WP GND 1 2 3 4 VCC HOLD SCK SI 8 7 6 5 VCC HOLD SCK SI WP SI SO HOLD GND Vcc CS A1 Note: 1. Contact info@adestotech.com for manufacturing flow and availability. AT25XE021A DS-25XE021A–061I–9/2017 3 3. Block Diagram Figure 3-1. Block Diagram &21752/$1' 3527(&7,21 /2*,& &6 6, ,2 62 :3 +2/' 65$0 '$7$  %8))(5 ,17(5)$&( &21752/ $1' /2*,&
AT25XE021A-SSHN-T 价格&库存
很抱歉,暂时无法提供与“AT25XE021A-SSHN-T”相匹配的价格&库存,您可以联系我们找货
