MR20H40 / MR25H40
MR20H40 - 50MHz/20ns tSCK (Industrial Temp Range) 4Mb SPI Interface MRAM
MR25H40 - 40MHz/25ns tSCK (Industrial, Extended and AEC-Q100 Grade 1 Temp Range) 4Mb SPI Interface MRAM
For more information on product options, see “Table 16 – Ordering Part Numbers” on page 25.
FEATURES
• No write delays
• Unlimited write endurance
• Data retention greater than 20 years
• Automatic data protection on power loss
8-DFN
• Fast, simple SPI interface, up to 50 MHz clock rate with MR20H40.
• 3.0 to 3.6 Volt power supply range
• Low-current sleep mode
• Industrial (-40 to 85°C), Extended (-40 to 105°C), and AEC-Q100
8-DFN Small Flag
Grade 1 (-40 to 125°C) temperature range options.
• Available in 8-pin DFN or 8-pin DFN Small Flag, RoHS-compliant
packages.
• Direct replacement for serial EEPROM, Flash, and FeRAM
RoHS
• MSL Level 3
DESCRIPTION
MR2xH40 is a family of 4,194,304-bit magnetoresistive random access memory (MRAM) devices
organized as 524,288 words of 8 bits. They are the ideal memory solution for applications that must
store and retrieve data and programs quickly using a small number of I/O pins. They have serial EEPROM and serial Flash compatible read/write timing with no write delays and unlimited read/write
endurance. Unlike other serial memories, with the MR2xH40 family both reads and writes can occur
randomly in memory with no delay between writes.
The MR2xH40 family provides highly reliable data storage over a wide range of temperatures. The
MR20H40 (50MHz) is offered with Industrial (-40° to +85 °C) range. The MR25H40 (40MHz) is offered
with Industrial (-40° to +85 °C), Extended (-40 to 105°C), and AEC-Q100 Grade 1 (-40°C to +125 °C)
operating temperature range options.
Both are available in a 5 x 6mm, 8-pin DFN package. The pinout is compatible with serial SRAM,
EEPROM, Flash, and FeRAM products.
Copyright © Everspin Technologies 2018
1
MR20H40 / MR25H40 Revision 12.4, 3/2018
MR20H40 / MR25H40
TABLE OF CONTENTS
OVERVIEW.............................................................................................................................................5
Figure 1 – Block Diagram............................................................................................................................................ 5
System Configuration......................................................................................................................5
Figure 2 – System Configuration.............................................................................................................................. 5
Pin Functions....................................................................................................................................6
Figure 3 – DFN Package Pin Diagram (Top View)............................................................................................... 6
Table 1 – Pin Functions................................................................................................................................................ 6
SPI COMMUNICATIONS PROTOCOL....................................................................................................7
Command Codes...............................................................................................................................7
Table 2 – Command Codes........................................................................................................................................ 7
Status Register, Memory Protection and Block Write Protection.................................................8
Table 3 – Status Register Bit Assignments............................................................................................................ 8
Memory Protection Modes..............................................................................................................8
Table 4 – Memory Protection Modes..................................................................................................................... 8
Block Protection Modes...................................................................................................................9
Table 5 – Block Memory Write Protection............................................................................................................. 9
Read Status Register (RDSR)......................................................................................................... 10
Figure 4 – Read Status Register (RDSR) Timing.................................................................................................10
Write Enable (WREN)..................................................................................................................... 10
Figure 5 – Write Enable (WREN) Timing...............................................................................................................10
Write Disable (WRDI)..................................................................................................................... 11
Figure 6 – Write Disable (WRDI) Timing...............................................................................................................11
Write Status Register (WRSR)....................................................................................................... 11
Figure 7 – Write Status Register (WRSR) Timing...............................................................................................11
Read Data Bytes (READ)................................................................................................................ 12
Figure 8 – Read Data Bytes (READ) Timing.........................................................................................................12
2
MR20H40 / MR25H40 Revision 12.4 3/2018
MR20H40 / MR25H40
Table of Contents (Cont’d)
Write Data Bytes (WRITE).............................................................................................................. 12
Figure 9 – Write Data Bytes (WRITE) Timing.......................................................................................................13
Enter Sleep Mode (SLEEP)............................................................................................................. 13
Figure 10 – Enter Sleep Mode (SLEEP) Timing...................................................................................................13
Exit Sleep Mode (WAKE)................................................................................................................ 14
Figure 11 – Exit Sleep Mode (WAKE) Timing......................................................................................................14
ELECTRICAL SPECIFICATIONS.......................................................................................................... 15
Absolute Maximum Ratings......................................................................................................... 15
Table 6 – Absolute Maximum Ratings ...............................................................................................................15
Table 7 – Operating Conditions..............................................................................................................................16
Table 8 – DC Characteristics.....................................................................................................................................16
Table 9 – Power Supply Characteristics...............................................................................................................17
TIMING SPECIFICATIONS.................................................................................................................. 18
Capacitance.................................................................................................................................... 18
Table 10 – Capacitance..............................................................................................................................................18
AC Measurement Conditions........................................................................................................ 18
Table 11 – AC Measurement Conditions.............................................................................................................18
Figure 12 – Output Load for Impedance Parameter Measurements........................................................18
Figure 13 – Output Load for all Other Parameter Measurements..............................................................18
Power Up Timing........................................................................................................................... 19
Table 12 – Power-Up Timing....................................................................................................................................19
Figure 14 – Power-Up Timing.................................................................................................................................19
AC Timing Parameters................................................................................................................... 20
Table 13 – MR20H40 (fSCK = 50MHz) AC Timing Parameters......................................................................20
Table 14 – MR25H40 (fSCK = 40MHz) AC Timing Parameters......................................................................21
3
MR20H40 / MR25H40
Figure 15 – Synchronous Data Timing.................................................................................................................23
Figure 16 – HOLD Timing.........................................................................................................................................23
PART NUMBERS AND ORDERING..................................................................................................... 24
Table 15 – Part Numbering System.......................................................................................................................24
Table 16 – Ordering Part Numbers........................................................................................................................25
PACKAGE OUTLINE DRAWINGS........................................................................................................ 26
Figure 17 – DFN Package Outline.........................................................................................................................26
Figure 18 – DFN Small Flag Package.....................................................................................................................27
REVISION HISTORY............................................................................................................................ 28
HOW TO REACH US............................................................................................................................ 29
4
MR20H40 / MR25H40
OVERVIEW
The MR2xH40 family is an SPI interface MRAM family with a memory array logically organized as 512Kx8
using the four pin interface of chip select (CS), serial input (SI), serial output (SO) and serial clock (SCK) of the
serial peripheral interface (SPI) bus. The MRAM implements a subset of commands common to SPI EEPROM
and SPI Flash components. This allows the SPI MRAM to replace these components in the same socket
and interoperate on a shared SPI bus. The SPI MRAM offers superior write speed, unlimited endurance, low
standby & operating power, and simple, reliable data retention compared to other serial memory alternatives.
Instruction Decode
Clock Generator
Control Logic
Write Protect
WP
CS
HOLD
SCK
512Kb x 8
MRAM ARRAY
Instruction Register
19
Address Register
Counter
8
Data I/O Register
SI
SO
4
Nonvolatile Status
Register
Single or multiple devices can be connected to the bus as shown in Figure 2. Pins SCK, SO and SI are common among devices. Each device requires CS and HOLD pins to be driven separately.
SCK
MOSI
MISO
SO
SPI
Micro Controller
SI
SCK
EVERSPIN SPI MRAM 1
CS
HOLD
SO
SI
SCK
EVERSPIN SPI MRAM 2
CS
HOLD
CS1
HOLD 1
CS2
HOLD 2
MOSI = Master Out Slave In
MISO = Master In Slave Out
5
MR20H40 / MR25H40
Pin Functions
CS
1
8
VDD
SO
2
7
HOLD
WP
3
6
SCK
VSS
4
5
SI
Signal
Name
Pin
I/O
Function
Description
CS
1
Input
Chip Select
An active low chip select for the serial MRAM. When chip select is high, the
memory is powered down to minimize standby power, inputs are ignored
and the serial output pin is Hi-Z. Multiple serial memories can share a common set of data pins by using a unique chip select for each memory.
SO
2
Output
Serial Output
The data output pin is driven during a read operation and remains Hi-Z at
all other times. SO is Hi-Z when HOLD is low. Data transitions on the data
output occur on the falling edge of SCK.
WP
3
Input
Write Protect
A low on the write protect input prevents write operations to the Status
Register.
VSS
4
Reference
Ground
SI
5
Input
Serial Input
All data is input to the device through this pin. This pin is sampled on the
rising edge of SCK and ignored at other times. SI can be tied to SO to create
a single bidirectional data bus if desired.
Serial Clock
Synchronizes the operation of the MRAM. The clock can operate up to 50
MHz to shift commands, address, and data into the memory. Inputs are
captured on the rising edge of clock. Data outputs from the MRAM occur
on the falling edge of clock. The serial MRAM supports both SPI Mode 0
(CPOL=0, CPHA=0) and Mode 3 (CPOL=1, CPHA=1). In Mode 0, the clock is
normally low. In Mode 3, the clock is normally high. Memory operation is
static so the clock can be stopped at any time.
A low on the Hold pin interrupts a memory operation for another task.
When HOLD is low, the current operation is suspended. The device will
ignore transitions on the CS and SCK when HOLD is low. All transitions of
HOLD must occur while CS is low.
SCK
6
Input
HOLD
7
Input
Hold
VDD
8
Supply
Power Supply
Power supply ground pin.
Power supply voltage from +3.0 to +3.6 volts.
6
MR20H40 / MR25H40
The MR2xH40 can be operated in either SPI Mode 0 (CPOL=0, CPHA =0) or SPI Mode 3 (CPOL=1, CPHA=1).
For both modes, inputs are captured on the rising edge of the clock and data outputs occur on the falling
edge of the clock. When not conveying data, SCK remains low for Mode 0; while in Mode 3, SCK is high.
The memory determines the mode of operation (Mode 0 or Mode 3) based upon the state of the SCK when
CS falls.
All memory transactions start when CS is brought low to the memory. The first byte is a command code.
Depending upon the command, subsequent bytes of address are input. Data is either input or output.
There is only one command performed per CS active period. CS must go inactive before another command
can be accepted. To ensure proper part operation according to specifications, it is necessary to terminate
each access by raising CS at the end of a byte (a multiple of 8 clock cycles from CS dropping) to avoid partial
or aborted accesses.
Command Codes
Instruction
Description
Binary Code
Hex Code
Address Bytes
Data Bytes
WREN
Write Enable
0000 0110
06h
WRDI
Write Disable
0000 0100
04h
RDSR 1
0000 0101
05h
WRSR
0000 0001
01h
READ
Read Data Bytes
0000 0011
03h
3
1 to ∞
WRITE
Write Data Bytes
0000 0010
02h
3
1 to ∞
SLEEP
Enter Sleep Mode
1011 1001
B9h
WAKE
Exit Sleep Mode
1010 1011
ABh
Note:
1. An RDSR command cannot immediately follow a READ command. If an RDSR command immediately follows a READ command, the output data will not be correct. Any other sequence of commands is allowed. If an RDSR command is required
immediately following a READ command, it is necessary that another command be inserted before the RDSR is executed.
Alternatively, two successive RDSR commands can be issued following the READ command. The second RDSR will output the
proper state of the Status Register.
7
MR20H40 / MR25H40
The status register consists of the 8 bits listed in Table 3. As seen in Table 4, the Status Register Write Disable
bit (SRWD) is used in conjunction with bit 1 (WEL) and the Write Protection pin (WP) to provide hardware
memory block protection. Bits BP0 and BP1 define the memory block arrays that are protected as described
in Table 5. The fast writing speed of the MR2xH40 does not require write status bits. The state of bits 6,5,4,
and 0 can be user modified and do not affect memory operation. All bits in the status register are pre-set
from the factory in the “0” state.
Bit 7
SRWD
Bit 6
Don’t Care
Bit 5
Don’t Care
Bit 4
Don’t Care
Bit 3
BP1
Bit 2
BP0
Bit 1
WEL
Bit 0
Don’t Care
When WEL is reset to 0, writes to all blocks and the status register are protected. When WEL is set to 1, BP0
and BP1 determine which memory blocks are protected. While SRWD is reset to 0 and WEL is set to 1,
status register bits BP0 and BP1 can be modified. Once SRWD is set to 1, WP must be high to modify SRWD,
BP0 and BP1.
SRWD
WP
Protected Blocks
Unprotected Blocks
Status
Register
X
X
Protected
Protected
Protected
1
X
Protected
Writable
Writable
1
1
Low
Protected
Writable
Protected
1
1
High
Protected
Writable
Writable
WEL
8
MR20H40 / MR25H40
The memory enters hardware block protection when the WP input is low and the Status Register Write Disable (SRWD) bit is set to 0. The memory leaves hardware block protection only when the WP pin goes high.
While WP is low, the write protection blocks for the memory are determined by the status register bits BP0
and BP1 and cannot be modified without taking the WP signal high again.
If the WP signal is high (independent of the status of SRWD bit), the memory is in software protection mode.
This means that block write protection is controlled solely by the status register BP0 and BP1 block write protect bits and this information can be modified using the WRSR command.
Status Register
BP1
BP0
Memory Contents
Protected Area
Unprotected Area
None
All Memory
Upper Quarter
Lower Three-Quarters
1
Upper Half
Lower Half
1
1
All
None
9
MR20H40 / MR25H40
The Read Status Register (RDSR) command allows the Status Register to be read. The Status Register can be
read to check the status of write enable latch bit, status register write protect bit, and block write protect
bits. For MR2xH40, the write in progress bit (bit 0) is not written by the memory because there is no write
delay. The RDSR command is entered by driving CS low, sending the command code, and then driving CS
high. An RDSR command cannot immediately follow a READ command. If an RDSR command immediately
If an RDSR command is required immediately following a READ command, it is necessary that another command be inserted before the RDSR is executed. Alternatively, two successive RDSR commands can be issued
following the READ command. The second RDSR will output the proper state of the Status Register.
CS
2
3
4
5
6
7
2
3
4
5
6
7
SCK
SI
Mode 3
Mode 0
MSB
Status Register Out
SO
High Impedance
7
6
5
4
3
2
1
High Z
MSB
Write Enable (WREN)
CS
Mode 3
SCK
2
3
4
5
6
7
Mode 3
Mode 0
Mode 0
Instruction (06h)
SI
SO
1
High Impedance
The Write Enable (WREN) command sets the Write Enable Latch (WEL) bit in the status register (bit 1). The
Write Enable Latch must be set prior to writing either bit in the status register or the memory. The WREN
command is entered by driving CS low, sending the command code, and then driving CS high.
10
MR20H40 / MR25H40
The Write Disable (WRDI) command resets the Write Enable Latch (WEL) bit in the status register (bit 1) to 0.
This prevents writes to status register or memory. The WRDI command is entered by driving CS low, sending
The Write Enable Latch (WEL) is reset to 0 on power-up or when the WRDI command is completed.
CS
Mode 3
SCK
2
3
4
5
6
Mode 3
7
Mode 0
Mode 0
Instruction (04h)
SI
High Impedance
SO
The Write Status Register (WRSR) command allows new values to be written to the Status Register. The
WRSR command is not executed unless the Write Enable Latch (WEL) has been set to 1 by executing a WREN
command while pin WP and the Status Register SRWD (Bit 7) correspond to values that make the status register writable as seen in Table 4 on page 8. Status Register bits are non-volatile with the exception of the
WEL which is reset to 0 upon power cycling.
The WRSR command is entered by driving CS low, sending the command code and status register write data
byte, and then driving CS high.
CS
2
3
4
5
6
7
8
9
10
11
12
13
14
15 Mode 3
SCK
Mode 0
Instruction (01h)
SI
Status Register In
7
6
5
4
3
2
1
MSB
SO
High Impedance
11
MR20H40 / MR25H40
The Read Data Bytes (READ) command allows data bytes to be read starting at an address specified by the
24-bit address. Only address bits 0-18 are decoded by the memory. The data bytes are read out sequentially
from memory until the read operation is terminated by bringing CS high. The entire memory can be read in
a single command. The address counter will roll over to 0000H when the address reaches the top of memory.
The READ command is entered by driving CS low and sending the command code. The memory drives the
read data bytes on the SO pin. Reads continue as long as the memory is clocked. The command is terminated by bringing CS high.
CS
2
3
4
5
6
7
8
9
10
28
29
30
31
32
33
34
35
36
37
38
39
SCK
Instruction (03h)
SI
24-Bit Address
1
1
23
22
21
3
2
1
MSB
SO
Data Out 1
High Impedance
7
6
5
4
3
Data Out 2
2
1
MSB
The Write Data Bytes (WRITE) command allows data bytes to be written starting at an address specified by
the 24-bit address. Only address bits 0-18 are decoded by the memory. The data bytes are written sequentially in memory until the write operation is terminated by bringing CS high. The entire memory can be
written in a single command. The address counter will roll over to 0000H when the address reaches the top
of memory.
Unlike EEPROM or Flash Memory, MRAM can write data bytes continuously at its maximum rated clock speed
without write delays or data polling. Back to back WRITE commands to any random location in memory can
be executed without write delay. MRAM is a random access memory rather than a page, sector, or block
organized memory so it is ideal for both program and data storage.
The WRITE command is entered by driving CS low, sending the command code, and then sequential write
data bytes. Writes continue as long as the memory is clocked. The command is terminated by bringing CS
high.
12
MR20H40 / MR25H40
CS
2
3
4
5
6
7
8
9
10
28
29
30
31
32
33
34
35
36
37
38
39
SCK
Instruction (02h)
SI
24-Bit Address
22
21
3
2
1
MSB
7
6
5
4
3
2
1
MSB
High Impedance
SO
CS
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
Mode 3
55
SCK
Mode 0
Data Byte 2
SI
7
6
5
4
3
Data Byte 3
2
1
6
4
5
3
Data Byte N
2
1
MSB
6
5
4
3
2
1
MSB
High Impedance
SO
The Enter Sleep Mode (SLEEP) command turns off all MRAM power regulators in order to reduce the overall
chip standby power to 15 μA typical. The SLEEP command is entered by driving CS low, sending the command code, and then driving CS high. The standby current is achieved after time, tDP. If power is removed
when the part is in sleep mode, upon power restoration, the part enters normal standby. The only valid
command following SLEEP mode entry is a WAKE command.
CS
t DP
2
3
4
5
6
Mode 3
7
SCK
Mode 0
Instruction (B9h)
SI
1
1
1
Active Current
Standby Current
Sleep Mode Current
SO
13
MR20H40 / MR25H40
The Exit Sleep Mode (WAKE) command turns on internal MRAM power regulators to allow normal operation.
The WAKE command is entered by driving CS low, sending the command code, and then driving CS high.
The memory returns to standby mode after tRDP. The CS pin must remain high until the tRDP period is over.
WAKE must be executed after sleep mode entry and prior to any other command.
CS
t RDP
2
3
4
5
6
7
SCK
Mode 3
Mode 0
Instruction (ABh)
SI
1
1
Sleep Mode Current
Standby Current
SO
14
MR20H40 / MR25H40
This device contains circuitry to protect the inputs against damage caused by high static voltages or electric
fields. However, it is advised that normal precautions be taken to avoid application of any voltage greater
than maximum rated voltages to these high-impedance (Hi-Z) circuits.
The device also contains protection against external magnetic fields. Precautions should be taken to avoid
application of any magnetic field more intense than the maximum field intensity specified in the maximum
ratings.
Permanent device damage may occur if absolute maximum ratings are exceeded. Functional operation should be restricted to
recommended operating conditions. Exposure to excessive voltages or magnetic fields could affect device reliability.
Symbol
Parameter
VDD
Supply voltage 2
VIN
Voltage on any pin 2
IOUT
Output current per pin
PD
TBIAS
Tstg
TLead
Conditions
Value
Unit
-0.5 to 4.0
V
-0.5 to VDD + 0.5
V
±20
mA
0.600
W
Commercial
-45 to 95
°C
Industrial
-45 to 95
°C
Extended
-45 to 115
°C
AEC-Q100 Grade 1
-45 to 135
°C
-55 to 150
°C
260
°C
Package power dissipation 3
Temperature under bias
Storage Temperature
Lead temperature during solder (3 minute max)
Hmax_write
Maximum magnetic field during write
Write
12,000
A/m
Hmax_read
Maximum magnetic field during read or
standby
Read or Standby
12,000
A/m
Notes:
1. All voltages are referenced to VSS. The DC value of VIN must not exceed actual applied VDD by more than 0.5V. The AC value of
VIN must not exceed applied VDD by more than 2V for 10ns with IIN limited to less than 20mA.
2. Power dissipation capability depends on package characteristics and use environment.
15
MR20H40 / MR25H40
Symbol
Parameter
Temp Grade
Min
Max
Unit
VDD
3.0
3.6
V
VIH
Input high voltage
2.2
VDD + 0.3
V
VIL
Input low voltage
-0.5
0.8
V
°C
Industrial
-40
85
°C
Extended
-40
105
°C
AEC-Q100 Grade 1 1
-40
125
°C
Commercial
TA
Ambient temperature under bias
Notes:
1. AEC-Q100 Grade 1 temperature profile assumes 10 percent duty cycle at maximum temperature (2 years out of 20-year life.)
Symbol
Parameter
Conditions
Min
Max
Unit
ILI
Input leakage current
±1
μA
ILO
Output leakage current
±1
μA
IOL = +4 mA
0.4
V
IOL = +100 μA
VSS + 0.2v
V
2.4
V
VDD - 0.2
V
VOL
Output low voltage
VOH
Output high voltage
IOH = -4 mA
IOH = -100 μA
16
MR20H40 / MR25H40
Symbol
IDDR
IDDW
Parameter
Active Read Current
Active Write Current
Conditions
Typical
Max
Unit
@ 1 MHz
5.0
11
mA
@ 40 MHz
12
17
mA
@ 50MHz
13.8
18.5
mA
@ 1 MHz
9.0
25
mA
@ 40 MHz
28
42
mA
@ 50 MHz
33
46.5
mA
@ 40 MHz
250
400
μA
@ 50 MHz
650
750
μA
ISB1
AC Standby Current (CS High)
ISB2
CMOS Standby Current (CS High)
90
180
μA
IZZ
Standby Sleep Mode Current (CS High)
15
40
μA
17
MR20H40 / MR25H40
Capacitance
Symbol
Parameter
Typical
Max
Unit
CIn
Control input capacitance 1
6
pF
CI/O
Input/Output capacitance 1
8
pF
Notes:
1. ƒ = 1.0 MHz, dV = 3.0 V, TA = 25 °C, periodically sampled rather than 100% tested.
Parameter
Value
Unit
Logic input timing measurement reference level
1.5
V
Logic output timing measurement reference level
1.5
V
0 or 3.0
V
2
ns
Logic input pulse levels
Input rise/fall time
Output load for low and high impedance parameters
See Figure 12
Output load for all other timing parameters
See Figure 13
ZD= 50 Ω
Output
RL = 50 Ω
VL = 1.5 V
3.3 V
590 Ω
Output
30 pF
435 Ω
18
MR20H40 / MR25H40
Power Up Timing
The MR2xH40 is not accessible for a start-up time, tPU= 400 μs after power up. Users must wait this time
from the time when VDD (min) is reached until the first CS low to allow internal voltage references to become
stable. The CS signal should be pulled up to VDD so that the signal tracks the power supply during power-up
sequence.
Symbol
Parameter
Min
Typical
Max
Unit
VWI
Write Inhibit Voltage
2.2
V
tPU
Startup Time
400
μs
VDD
VDD(max)
Chip Selection not allowed
VDD(min)
Reset state
of the
device
t PU
Normal Operation
VWI
Time
19
MR20H40 / MR25H40
Industrial Temperature Range, VDD=3.0 to 3.6 V, CL= 30 pF for all values.
Symbol
fSCK
Parameter
Temp Range
Min
Typical
Max
Unit
SCK Clock Frequency
Industrial
MHz
tRI
Input Rise Time
Industrial
50
ns
tRF
Input Fall Time
Industrial
50
ns
tWH
SCK High Time
Industrial
7
ns
tWL
SCK Low Time
Industrial
7
ns
Synchronous Data Timing see Figure 15
tCS
CS High Time
Industrial
40
ns
tCSS
CS Setup Time
Industrial
5
ns
tCSH
CS Hold Time
Industrial
5
ns
tSU
Data In Setup Time
Industrial
2
ns
tH
Data In Hold Time
Industrial
5
ns
tV
Output Valid
Industrial
ns
Output Hold Time
Industrial
ns
tHO
HOLD Timing see Figure 16
tHD
HOLD Setup Time
Industrial
5
ns
tCD
HOLD Hold Time
Industrial
5
ns
tLZ
HOLD to Output Low Impedance
Industrial
ns
tHZ
HOLD to Output High Impedance
Industrial
ns
Other Timing Specifications
tWPS
WP Setup To CS Low
Industrial
5
ns
tWPH
WP Hold From CS High
Industrial
5
ns
tDP
Sleep Mode Entry Time
Industrial
3
μs
tRDP
Sleep Mode Exit Time
Industrial
400
μs
tDIS
Output Disable Time
Industrial
12
ns
MR20H40 / MR25H40
Industrial, Extended and AEC-Q100 Grade 1 Temperature Ranges, VDD=3.0 to 3.6 V, CL= 30 pF for all values.
Symbol
Parameter
Temp Grade
Min
Typical
Max
Unit
SCK Clock Frequency
All
MHz
tRI
Input Rise Time
All
50
ns
tRF
Input Fall Time
All
50
ns
tWH
SCK High Time
All
11
ns
tWL
SCK Low Time
All
11
ns
fSCK
tCS
CS High Time
All
40
ns
tCSS
CS Setup Time
All
10
ns
tCSH
CS Hold Time
All
10
ns
tSU
Data In Setup Time
All
5
ns
tH
Data In Hold Time
All
5
ns
tV
Output Valid
Industrial/Extended
ns
AEC-Q100 Grade 1
ns
ns
tHO
Output Hold Time
All
Table continues next page.
21
MR20H40 / MR25H40
Table 14 (Cont’d) - MR25H40 (fSCK = 40MHz) AC Timing Parameters
Symbol Parameter
Temp Grade
Min
Typical
Max
Unit
tHD
HOLD Setup Time
All
10
ns
tCD
HOLD Hold Time
All
10
ns
tLZ
All
ns
tHZ
All
ns
tWPS
WP Setup To CS Low
All
5
ns
tWPH
All
5
ns
tDP
All
3
μs
tRDP
All
400
μs
tDIS
Output Disable Time
All
12
ns
22
MR20H40 / MR25H40
CS
tCD
tCD
SCK
tHD
tHD
HOLD
tHZ
tLZ
SO
23
MR20H40 / MR25H40
Product Family Number
MRAM
MR
50 MHz Serial Family
20H
40 MHz Serial Family
25H
256 Kb
256
512 Kb
512
1 Mb
10
4 Mb
40
No Revision
Blank
Revision A
A
Revision B
B
Commercial
0 to 70°C
Blank
Industrial
-40 to 85°C
C
Extended
-40 to 105°C
V
AEC Q-100 Grade 1 -40 to 125°C
M
8-pin DFN in Tray
DC
8-pin DFN Tape and Reel
DCR
DF
8-pin DFN (small flag) in Tray
8-pin DFN (small flag) Tape and Reel
DFR
Engineering Samples
ES
Customer Samples
Blank
Mass Production
Blank
MR
Memory
MR
25H
Interface
25H
40
Density
40
Revision
Temp
C
Package
DC
Grade
ES
Product Family Number and Ordering Part Number given are for illustration only.
24
MR20H40 / MR25H40
Speed
Grade
Temp Grade
Temperature
Package
50MHz
Industrial
-40 to +85 C
8-DFN Small Trays
Flag
Tape and Reel
8-DFN 1
Industrial
-40 to +85 C
Shipping ConOrder Part Number
tainer
MR20H40CDF
MR20H40CDFR
Trays
MR25H40CDC 1
Tape and Reel
MR25H40CDCR 1
8-DFN Small Trays
Flag
Tape and Reel
MR25H40CDF
-40 to +105 C
8-DFN Small Trays
Flag
Tape and Reel
MR25H40VDF
AEC-Q100 Grade 1 -40 to +125 C
8-DFN Small Trays
Flag
Tape and Reel
MR25H40MDF
40 MHz
Extended
MR25H40CDFR
MR25H40VDFR
MR25H40MDFR
Note:
1. The DC pckage option (8-DFN) is not recommended for new designs. Please select the DF (8-DFN small
flag) option for new designs.
25
MR20H40 / MR25H40
Exposed metal Pad. Do not
connect anything except VSS
A
8
5
DAP Size
4.4 x 4.4
J
B
I
L
G
H
M
C
Pin 1 Index
Detail A
D
1
4
F
K
N
E
Detail A
A
B
C
D
E
F
G
H
I
J
Max.
5.10
6.10
1.00
1.27
0.45
0.05
0.70
4.20
4.20
0.261
Min.
4.90
5.90
0.90
BSC
0.35
0.00
0.35
Ref.
0.50
4.00
4.00
0.195
Dimension
K
L
C0.35
M
R0.20
N
0.05
0.00
Notes:
1. Reference JEDEC MO-229.
2. All dimensions are in mm. Angles in degrees.
3. Coplanarity applies to the exposed pad as well as the terminals. Coplanarity shall be within 0.08 mm.
4. Warpage shall not exceed 0.10 mm.
26
MR20H40 / MR25H40
A
2X
0.10 C
8
5
2X
J
B
I
G
L
H
M
C
Pin 1 Index
Detail A
D
1
4
F
K
E
N
Detail A
A
B
C
D
E
F
G
H
I
J
K
Max.
5.10
6.10
0.90
0.45
0.05
1.60
0.70
2.10
2.10
.210
Min.
4.90
5.90
0.80
1.27
BSC
0.35
0.00
1.20
0.50
1.90
1.90
.196
Dimension
0.10 C
L
M
C0.45 R0.20
N
0.05
0.00
Notes:
27
MR20H40 / MR25H40
REVISION HISTORY
Revision
Date
Description of Change
Product Concept Release
0 .1
Feb. 23, 2010
Fixed typos in text.
1
May 5, 2010
Removed commercial specifications. All parts meet industrial specifications.
2
Jan 11, 2011
Preliminary Product Release. Updated description of status register non-volatility, WAKE
command, Table 3.4.
3
Apr 25, 2011
Removed DIP package part to seperate datasheet. Added inset detail for mechanical package drawings.
4
September 22,
2011
Added AEC-Q100 Grade 1 ordering option. Revised Table 3.1, Table 3.2, Table 3.4, Table 4.4
revised and Note 2 deleted, revised Figure 5.1 and Table 5.1.
Nov 18, 2011
Corrected VOL in Table 3.3 to read VOL Max = VSS + 0.2v. Corrected SI waveform in Figure 2.8.
New Small Flag DFN package option added to Page 1 Features and available parts Table 5.1.
DFN Small Flag drawing and dimensions table added as Figure 6.2. Figure 6.1, DFN Package, cleaned up with better quality drawing and dimension table. No specifications were
changed in Figure 6.1.
6
August 23, 2012
CDF and CDFR options changed to Preliminary. Added Small Flag DFN illustrations. Reformatted all parametric tables. Revised 8-DFN package drawing to show correct proportion
for flag and package. Added MR20H40 as 50MHz speed option. Deleted large flag DFN
ordering option for AEC-Q100 products. Corrected errors in DFN package outline drawings.
7
January 17,
2013
Removed Preliminary status from MR25H40CDF, CDFR.
8
May 24, 2013
Removed Preliminary status from MR20H40CDF(R), and from MR20H40DF(R).
9
March 28, 2014
Removed Preliminary status from 25H40MDF(R). VWI max to unspecified from TBD. Added
MSL-3 status to the Features list.
10
July 11, 2014
MR20H40DF and MR20H40DFR withdrawn from sales status.
11
August 13, 2014
Added Extended temperature grade offering.
11.1
May 19, 2015
Revised Everspin contact information.
11.2
June 11, 2015
Corrected Japan Sales Office telephone number.
12.0
December 9,
2015
Clarification of RDSR command operation.
12.1
December 18,
2015
Minor edits to the revised RDSR command operation. Corrected wrong bit number for the
WEL in the WRDI command description. Clarification of SRWD bit location in the Status Register within the WRSR command description. Condensed Note 1 in Table 2, referring to RDSR
operation after a READ command.
5
28
MR20H40 / MR25H40
REVISION HISTORY - Cont’d
Revision
Date
12.2
December 13,
2016
Change all large flag DFN options to “The DC pckage option (8-DFN) is not recommended
for new designs. Please select the DF (8-DFN small flag) option for new designs.”
12.3
February 2, 2017 Added tHO and tV relationship to Synchronous Data Timing
12.4
March 23, 2018
Updated the Contact Us table
29
MR20H40 / MR25H40
HOW TO REACH US
Everspin Technologies, Inc.
How to Reach Us:
Home Page:
www.everspin.com
World Wide Information Request
WW Headquarters - Chandler, AZ
5670 W. Chandler Blvd., Suite 100
Chandler, Arizona 85226
Tel: +1-877-480-MRAM (6726)
Local Tel: +1-480-347-1111
Fax: +1-480-347-1175
support@everspin.com
orders@everspin.com
sales@everspin.com
Europe, Middle East and Africa
Everspin Europe Support
support.europe@everspin.com
Japan
Everspin Japan Support
support.japan@everspin.com
Asia Pacific
Everspin Asia Support
support.asia@everspin.com
Information in this document is provided solely to enable system and software implementers to use Everspin Technologies products. There are no
express or implied licenses granted hereunder to design or fabricate any
integrated circuit or circuits based on the information in this document.
Everspin Technologies reserves the right to make changes without further
notice to any products herein. Everspin makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Everspin Technologies assume any liability arising
out of the application or use of any product or circuit, and specifically
disclaims any and all liability, including without limitation consequential
or incidental damages. “Typical” parameters, which may be provided in
Everspin Technologies data sheets and/or specifications can and do vary
in different applications and actual performance may vary over time. All
operating parameters including “Typicals” must be validated for each customer application by customer’s technical experts. Everspin Technologies
does not convey any license under its patent rights nor the rights of others. Everspin Technologies products are not designed, intended, or authorized for use as components in systems intended for surgical implant
into the body, or other applications intended to support or sustain life, or
for any other application in which the failure of the Everspin Technologies
product could create a situation where personal injury or death may occur. Should Buyer purchase or use Everspin Technologies products for any
such unintended or unauthorized application, Buyer shall indemnify and
hold Everspin Technologies and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly,
any claim of personal injury or death associated with such unintended or
unauthorized use, even if such claim alleges that Everspin Technologies
was negligent regarding the design or manufacture of the part. Everspin™
and the Everspin logo are trademarks of Everspin Technologies, Inc. All
other product or service names are the property of their respective owners.
Copyright © Everspin Technologies, Inc. 2018
30
