TMPC1206HP-R47MG-D
TMPC1206HP-R47MG-D
    TAI-TECH(台庆)
    SMD,13.5x12.5mm
    功率电感 470nH ±20% IND_13.5X12.5MM_SM 6.00mm 13.50 x 12.50mm 1.3mΩ 38A
TMPC1206HP-R47MG-D 数据手册
TAI-TECH P1 SMD Power Choke Coil TMPC1206HP-Series(G)-D 1. Features 1. Carbonyl Powder inductor. 2. Compact design. Halogen 3. High current,low DCR,high efficiency. 4. Very low acoustic noise and very low leakage flux noise. Halogen-free 5. High reliability. 6. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 7. Operating temperature -40~+125℃(Including self - temperature rise) 8. 2. Applications Note PC power system,incl. IMVP-6 DC/DC converter. 3. Dimensions C A D E B   100 2019 leadframe D C A Recommend PC Board Pattern L 1R0 2019 E H B non-leadframe G Series A(mm) B(mm) C(mm) D(mm) E(mm) TMPC1206HP 13.5±0.5 12.5±0.3 5.7±0.3 2.3±0.3 4.7±0.3 4. Part Numbering TMPC 1206 HP A B C A: Series B: Dimension C: Type D: Inductance E: Inductance Tolerance F: Code ) - 100 D MG E L(mm) G(mm) H(mm) 14.2 8.0 5.0 Note: 1. The above PCB layout reference only. 2. Recommend solder paste thickness at 0.15mm and above. D F BxC H: Carbonyl Powder;P: PAD broaden 100=10.0uH K=±10%,L=±15%,M=±20%,N=±25%,Y=±30%. Marking: Black.100 and 2019(20 YY,19 WW,follow production date). TAI-TECH P2 5. Specification Part Number Inductance L0 (uH)±20% I rms ( A ) DCR (mΩ)Typ. @25℃ DCR (mΩ)Max. @25℃ Type TMPC1206HP-R22YG-D 0.22±30% 55 100 120 0.48 0.65 non-leadframe TMPC1206HP-R36MG-D 0.36 42 65 80 0.72 0.90 non-leadframe TMPC1206HP-R47MG-D 0.47 38 60 64 0.92 1.3 non-leadframe TMPC1206HP-R56MG-D 0.56 35 56 60 1.15 1.5 non-leadframe TMPC1206HP-R68MG-D 0.68 33 53 57 1.33 1.7 non-leadframe TMPC1206HP-R82MG-D 0.82 31 47 55 1.5 1.9 non-leadframe TMPC1206HP-1R0MG-D 1.00 29 45 53 1.8 2.4 non-leadframe TMPC1206HP-1R5MG-D 1.50 26 43 50 2.7 3.2 non-leadframe TMPC1206HP-2R2MG-D 2.20 21 34 43 4.0 4.7 leadframe TMPC1206HP-3R3MG-D 3.30 17 28 35 5.8 7.1 leadframe TMPC1206HP-4R7MG-D 4.70 16 25 30 9.5 11.5 leadframe TMPC1206HP-5R6MG-D 5.60 15.5 22 28 10.8 12.6 leadframe TMPC1206HP-6R8MG-D 6.80 15 19 25 12 13.8 leadframe TMPC1206HP-8R2MG-D 8.20 11 17 23 13.6 16 leadframe TMPC1206HP-100MG-D 10.0 11 15.5 21 18 20.7 leadframe TMPC1206HP-150MG-D 15.0 9.0 13 16 25 29 leadframe TMPC1206HP-180MG-D 18.0 8.5 12 15 30 35 leadframe TMPC1206HP-220MG-D 22.0 8.0 11 14 34 39.5 leadframe TMPC1206HP-330MG-D 33.0 6.0 8.0 12.0 65 75 leadframe TMPC1206HP-470MG-D 47.0 5.5 7.0 11.0 80 90 leadframe TMPC1206HP-680MG-D 68.0 5.0 6.0 9.0 120 140 leadframe Note: 1. 2. 3. 4. 5. I sat 1 ( A ) I sat 2 ( A ) Test frequency : Ls : 100KHz /1.0V. All test data referenced to 25℃ ambient. Testing Instrument(or equ) : L: HP4284A,CH11025,CH3302,CH1320,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER. Heat Rated Current (Irms) will cause the coil temperature rise approximately ΔT of 40℃ Saturation Current (Isat1) will cause L0 to drop approximately 20%. Saturation Current (Isat2) will cause L0 to drop approximately 30%. 6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 7. Special inquiries besides the above common used types can be met on your requirement. TAI-TECH 6. Typical Performance Curves P3 TAI-TECH P4
TMPC1206HP-R47MG-D 价格&库存
很抱歉,暂时无法提供与“TMPC1206HP-R47MG-D”相匹配的价格&库存,您可以联系我们找货
