AMMA00060630R47MV1
AMMA00060630R47MV1
    CHILISIN(奇力新)
    SMD,6.86x6.47mm
    功率电感 470nH ±20% IND_6.86X6.47MM_SM 3.00mm 6.86 x 6.47mm 4.2mΩ 17.5A
AMMA00060630R47MV1 数据手册
Automotive Power Inductor AMMA Series AEC-Q200 RoHS Compliant Halogen Free REACH Compliant ■ Part Numbering A Grade MMA Series Name 00 Control Code 040420 1R0 Dimensions Code (mm) 040420 4.45x4.06x2 050530 5.49x5.18x3 060630 6.86x6.47x3 101040 10.5x10x4 131364 13.2x12.9x6.4 Inductance (uH) R22 0.22 1R0 1.0 3R3 3.3 M V1 Tolerance Internal Code M ±20% Automotive Power Inductor AMMA Series AEC-Q200 AMMA00040420 Type ■ Dimensions ■ Recommended Land Pattern unit:mm unit:mm ■ Electrical Characteristics Part No. AMMA00040420R10MV1 AMMA00040420R22MV1 AMMA00040420R33MV1 AMMA00040420R47MV1 AMMA000404201R0MV1 AMMA000404201R2MV1 AMMA000404202R2MV1 Inductance (uH) Test Freq. RDC(mΩ) Max(Typ) Isat (A)Typ. Irms (A)Typ. Tolerance (±%) Marking 0.10 0.22 0.33 0.47 1.0 1.2 2.2 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 5(4.5) 8(7.3) 13(9.6) 18(16) 37(33) 48(41) 90(80) 35 24 18 11.5 8.5 7 6 11 13 9 5.6 3.75 3.1 2.85 20 20 20 20 20 20 20 R10 R22 R33 R47 1R0 1R2 2R2 Note: When ordering, please specify tolerance code. Tolerance: M=±20% 1. Operating temperature range 55 125 2. Isat for Inductance drop 20% from its value without current 3. Irms for a 40℃ temprature rise from 25℃ ambient with current 4. Withstand voltage : 25VDC 5. Measure Equipment: L: Keysight 4285A or equivalent. RDC: ADEX AX1152D or equivalent. Isat: Keysight 4285A or equivalent. Irms: CHROMA 62050P-100-100 Automotive Power Inductor AMMA Series AEC-Q200 AMMA00040420 Type ■ Characteristics Graph Inductance vs. DC Current 2.5 2 2R2 L(uH) 1.5 1R2 1 1R0 0.5 R47 R33 R22 R10 0 0 5 10 15 20 25 30 35 40 DC Current (A) Temperature Change vs. DC Current 120 1R2 100 2R2 R47 R10 R22 80 R33 △ T(℃ ℃) 1R0 60 40 20 0 0 5 10 15 DC Current (A) 20 25 Automotive Power Inductor AMMA Series AEC-Q200 AMMA00050530 Type ■ Dimensions ■ Recommended Land Pattern unit:mm unit:mm ■ Electrical Characteristics Part No. AMMA00050530R33MV1 AMMA00050530R47MV1 AMMA00050530R68MV1 AMMA000505301R0MV1 AMMA000505301R5MV1 AMMA000505302R2MV1 AMMA000505303R3MV1 AMMA000505304R7MV1 AMMA00050530100MV1 AMMA00050530150MV1 Inductance (uH) Test Freq. RDC(mΩ) Max(Typ) Isat (A)Typ. Irms (A)Typ. Tolerance (±%) Marking 0.33 0.47 0.68 1.0 1.5 2.2 3.3 4.7 10 15 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 5.56(5.3) 7.04(6.7) 8.96(8.53) 13.7(13.1) 20.7(19.7) 29.2(27.8) 54.7(52.1) 77.5(73.8) 158(152) 265(252) 19 16 13.5 12 11 10 8.5 8.2 4 2.5 13.7 12.2 10.2 9.2 7.2 5.8 5 3.5 2.5 1.9 20 20 20 20 20 20 20 20 20 20 R33 R47 R68 1R0 1R5 2R2 3R3 4R7 100 150 Note: When ordering, please specify tolerance code. Tolerance: M=±20% 1. Operating temperature range 55 125 2. Isat for Inductance drop 20% from its value without current 3. Irms for a 40℃ temprature rise from 25℃ ambient with current 4. Withstand voltage : 25VDC 5. Measure Equipment: L: Keysight 4285A or equivalent. RDC: ADEX AX1152D or equivalent. Isat: Keysight 4285A or equivalent. Irms: CHROMA 62050P-100-100 Automotive Power Inductor AMMA Series AEC-Q200 AMMA00050530 Type ■ Characteristics Graph Inductance vs. DC Current 10 100 8 L(uH) 6 4 4R7 3R3 2 2R2 1R5 1R0 R68 R47 R33 0 0 2 4 6 8 10 12 14 16 18 20 22 24 DC Current (A) Temperature Change vs. DC Current 140 R33 120 1R0 150 100 R47 100 △ T(℃ ℃) 3R3 2R2 80 4R7 R68 1R5 60 40 20 0 0 2 4 6 8 10 12 14 DC Current (A) 16 18 20 22 24 Automotive Power Inductor AMMA Series AEC-Q200 AMMA00060630 Type ■ Dimensions ■ Recommended Land Pattern unit:mm unit:mm ■ Electrical Characteristics Part No. AMMA00060630R10MV1 AMMA00060630R15MV1 AMMA00060630R20MV1 AMMA00060630R22MV1 AMMA00060630R33MV1 AMMA00060630R47MV1 AMMA00060630R68MV1 AMMA00060630R82MV1 AMMA000606301R0MV1 AMMA000606301R5MV1 AMMA000606302R2MV1 AMMA000606303R3MV1 AMMA000606304R7MV1 AMMA000606306R8MV1 AMMA000606308R2MV1 AMMA00060630100MV1 Inductance (uH) Test Freq. RDC(mΩ) Max(Typ) Isat (A)Typ. Irms (A)Typ. Tolerance (±%) Marking 0.10 0.15 0.20 0.22 0.33 0.47 0.68 0.82 1.0 1.5 2.2 3.3 4.7 6.8 8.2 10 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 1.7(1.5) 2.5(1.9) 3(2.4) 2.8(2.5) 3.9(3.5) 4.2(4) 5.5(5) 8(6.7) 10(9) 15(14) 20(18) 30(28) 40(37) 60(54) 68(64) 105(102) 60 52 41 40 30 26 25 24 22 18 14 13.5 10 8 7.5 7 32.5 26 24 23 20 17.5 15.5 13 11 9 8 6 5.5 4.5 4 3 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 R10 R15 R20 R22 R33 R47 R68 R82 1R0 1R5 2R2 3R3 4R7 6R8 8R2 100 Note: When ordering, please specify tolerance code. Tolerance: M=±20% 1. Operating temperature range 55 125 2. Isat for Inductance drop 20% from its value without current 3. Irms for a 40℃ temprature rise from 25℃ ambient with current 4. Withstand voltage : 25VDC 5. Measure Equipment: L: Keysight 4285A or equivalent. RDC: ADEX AX1152D or equivalent. Isat: Keysight 4285A or equivalent. Irms: CHROMA 62050P-100-100 Automotive Power Inductor AMMA Series AEC-Q200 AMMA00060630 Type ■ Characteristics Graph Inductance vs. DC Current 10 9 100 8 7 8R2 L(uH) 6 6R8 5 4 4R7 3 3R3 2R2 1R5 2 1 1R0 R82 R68 R47R33 R22 R10 0 0 5 10 15 20 25 30 35 40 45 50 55 60 65 DC Current (A) Temperature Change vs. DC Current 120 2R2 100 R10 R20 R47 80 1R5 △ T(℃ ℃) R68 4R7 6R8 3R3 8R2 R33 R22 1R0 R82 R15 100 60 40 20 0 0 5 10 15 20 25 30 DC Current (A) 35 40 45 50 Automotive Power Inductor AMMA Series AEC-Q200 AMMA00101040 Type ■ Dimensions ■ Recommended Land Pattern unit:mm unit:mm ■ Electrical Characteristics Part No. AMMA00101040R19MV1 AMMA00101040R36MV1 AMMA00101040R56MV1 AMMA001010401R0MV1 AMMA001010401R5MV1 AMMA001010402R2MV1 AMMA001010403R3MV1 AMMA001010404R7MV1 AMMA001010405R6MV1 AMMA001010406R8MV1 AMMA00101040100MV1 Inductance (uH) Test Freq. RDC(mΩ) Max(Typ) Isat (A)Typ. Irms (A)Typ. Tolerance (±%) Marking 0.19 0.36 0.56 1.0 1.5 2.2 3.3 4.7 5.6 6.8 10 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 0.95(0.87) 1.4(1.3) 1.8(1.7) 4.1(3.7) 5.8(5.3) 9(8.2) 11.8(10.8) 16.5(15) 19.3(17.6) 23.3(21.2) 36.5(33.2) 90 60 49 36 27.5 25.6 18.6 17 16 13.5 12 40 31.5 27.5 17.5 15 12 10 9.5 8.5 8 6.8 20 20 20 20 20 20 20 20 20 20 20 R19 R36 R56 1R0 1R5 2R2 3R3 4R7 5R6 6R8 100 Note: When ordering, please specify tolerance code. Tolerance: M=±20% 1. Operating temperature range 55 125 2. Isat for Inductance drop 20% from its value without current 3. Irms for a 40℃ temprature rise from 25℃ ambient with current 4. Withstand voltage : 25VDC 5. Measure Equipment: L: Keysight 4285A or equivalent. RDC: ADEX AX1152D or equivalent. Isat: Keysight 4285A or equivalent. Irms: CHROMA 62050P-100-100 Automotive Power Inductor AMMA Series AEC-Q200 AMMA00101040 Type ■ Characteristics Graph Inductance vs. DC Current 10 9 100 8 7 L(uH) 6 6R8 5 5R6 4 4R7 3 3R3 2 2R2 1R5 1 1R0 R56 R36 R19 0 0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 90 95 100 DC Current (A) Temperature Change vs. DC Current 120 6R8 100 100 80 △ T(℃ ℃) 5R6 R56 4R7 2R2 3R3 1R5 1R0 R19 R36 60 40 20 0 0 5 10 15 20 25 30 35 DC Current (A) 40 45 50 55 60 Automotive Power Inductor AMMA Series AEC-Q200 AMMA00131364 Type ■ Dimensions ■ Recommended Land Pattern unit:mm unit:mm ■ Electrical Characteristics Part No. AMMA00131364R15MV1 AMMA00131364R22MV1 AMMA00131364R33MV1 AMMA00131364R47MV1 AMMA00131364R56MV1 AMMA00131364R68MV1 AMMA00131364R82MV1 AMMA001313641R0MV1 AMMA001313641R5MV1 AMMA001313641R8MV1 AMMA001313642R2MV1 AMMA001313643R3MV1 AMMA001313644R7MV1 AMMA001313646R8MV1 AMMA001313648R2MV1 AMMA00131364100MV1 Inductance (uH) Test Freq. RDC(mΩ) Max(Typ) Isat (A)Typ. Irms (A)Typ. Tolerance (±%) Marking 0.15 0.22 0.33 0.47 0.56 0.68 0.82 1.0 1.5 1.8 2.2 3.3 4.7 6.8 8.2 10 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 100kHz/0.25V 0.6(0.53) 0.7(0.63) 0.9(0.83) 1.2(1.0) 1.4(1.2) 1.6(1.4) 1.9(1.6) 2.0(1.7) 3.0(2.5) 3.2(2.8) 4.2(3.5) 6.8(5.7) 11.2(9.3) 14(13.1) 15.5(14.5) 17.2(16.4) 118 112 65 63 62 60 50 49 45 41 40 35 30 16.5 16 15.5 55 53 46 41 37 35 33 32 27 24 22 18 13.5 11.5 10.5 10 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 R15 R22 R33 R47 R56 R68 R82 1R0 1R5 1R8 2R2 3R3 4R7 6R8 8R2 100 Note: When ordering, please specify tolerance code. Tolerance: M=±20% 1. Operating temperature range 55 125 2. Isat for Inductance drop 20% from its value without current 3. Irms for a 40℃ temprature rise from 25℃ ambient with current 4. Withstand voltage : 25VDC 5. Measure Equipment: L: Keysight 4285A or equivalent. RDC: ADEX AX1152D or equivalent. Isat: Keysight 4285A or equivalent. Irms: CHROMA 62050P-100-100 Automotive Power Inductor AMMA Series AEC-Q200 AMMA00131364 Type ■ Characteristics Graph Inductance vs. DC Current 10 9 100 8 7 8R2 L(uH) 6 6R8 5 4 4R7 3 3R3 2R2 1R8 1R5 1R0 R82 R68 R56 R47 R33 2 1 R22 R15 0 0 10 20 30 40 50 60 70 80 90 100 110 120 130 140 DC Current (A) Temperature Change vs. DC Current 120 100 100 8R2 6R8 2R2 1R8 1R5 80 R33 R47 R22 4R7 3R3 △ T(℃ ℃) R15 R56 1R0 R82 R68 60 40 20 0 0 10 20 30 40 50 DC Current (A) 60 70 80 90 Automotive Power Inductor AMMA Series AEC-Q200 ■ Packaging Tape Dimensions Reel Dimensions Dimensions in mm Tape Dimensions Reel Dimensions Quantity TYPE A B K T D E W P P0 P2 A B C D E F PCS / REEL AMMA00040420 4.4 4.9 2.4 0.35 1.5 1.75 12 8 4 2 330 100 21.5 13 12.4 17.4 2000 AMMA00050530 5.4 5.9 3.3 0.35 1.5 1.75 12 8 4 2 330 100 21.5 13 12.4 17.4 1000 AMMA00060630 6.9 7.6 3.4 0.35 1.5 1.75 12 8 4 2 330 100 21.5 13 16.4 21.4 1000 AMMA00101040 10.4 11.5 4.5 0.35 1.5 1.75 24 16 4 2 330 100 21.5 13 24.2 29.2 500 AMMA00131364 13.4 14.1 6.8 0.4 1.5 1.75 24 16 4 2 330 100 21.5 13 24.2 29.2 250
AMMA00060630R47MV1
物料型号:AMMA Series,由HILISIN Electronics Corp.(YAGEO公司的一部分)生产的功率电感器。
器件简介:这些功率电感器符合汽车AEC-Q200标准,无卤素,符合RoHS和REACH标准,具有高电流容量和超高频特性。
引脚分配:文档中没有提供具体的引脚分配信息,但提到了推荐的焊盘图案尺寸。
参数特性:包括不同型号的电感值(如0.10uH、0.22uH、1.0uH等),直流电阻(RDC),饱和电流(Isat),额定电流(Irms),以及电感公差(通常为±20%)。
功能详解:文档提供了电感值与直流电流的关系图,以及直流电流引起的温度变化图,说明了电感器在不同电流下的电气特性。
应用信息:虽然文档没有明确指出具体的应用场景,但提到了产品可能不适用于医疗或高风险应用,除非得到Chilisin的批准。
封装信息:提供了不同型号的封装尺寸,包括推荐的胶带和卷轴尺寸。
AMMA00060630R47MV1 价格&库存
很抱歉,暂时无法提供与“AMMA00060630R47MV1”相匹配的价格&库存,您可以联系我们找货
