NUC120LE3AN
NUC120LE3AN
    NUVOTON(新唐)
    LQFP-48
    NUC120LE3AN
NUC120LE3AN 数据手册
NuMicro™ NUC120 Data Sheet ARM Cortex™-M0 32-BIT MICROCONTROLLER NuMicro™ Family NUC120 Data Sheet The information described in this document is the exclusive intellectual property of Nuvoton Technology Corporation and shall not be reproduced without permission from Nuvoton. Nuvoton is providing this document only for reference purposes of NuMicro microcontroller based system design. Nuvoton assumes no responsibility for errors or omissions. All data and specifications are subject to change without notice. For additional information or questions, please contact: Nuvoton Technology Corporation. -1- Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet Contents 1  2  GENERAL DESCRIPTION ......................................................................................................... 7  FEATURES ................................................................................................................................. 8  2.1  3  PARTS INFORMATION LIST AND PIN CONFIGURATION .................................................... 12  3.1  3.2  4  5  NuMicro™ NUC120 Features – USB Line ...................................................................... 8  NuMicro™ NUC120 Products Selection Guide ............................................................. 12  3.1.1  NuMicro™ NUC120 Medium Density USB Line Selection Guide....................................12  3.1.2  NuMicro™ NUC120 Low Density USB Line Selection Guide..........................................12  Pin Configuration .......................................................................................................... 14  3.2.1  NuMicro™ NUC120 Medium Density Pin Diagram .........................................................14  3.2.2  NuMicro™ NUC120 Low Density Pin Diagram ...............................................................17  BLOCK DIAGRAM .................................................................................................................... 19  4.1  NuMicro™ NUC120 Medium Density Block Diagram ................................................... 19  4.2  NuMicro™ NUC120 Low Density Block Diagram.......................................................... 20  FUNCTIONAL DESCRIPTION.................................................................................................. 21  5.1  ARM® Cortex™-M0 Core .............................................................................................. 21  5.2  System Manager........................................................................................................... 23  5.2.1  5.2.2  5.2.3  5.2.4  5.2.5  5.2.6  5.3  Clock Controller ............................................................................................................ 32  5.3.1  5.3.2  5.3.3  5.3.4  5.3.5  5.3.6  5.4  Overview ........................................................................................................................39  Features .........................................................................................................................39  I2C Serial Interface Controller (Master/Slave) (I2C) ...................................................... 40  5.6.1  5.6.2  5.7  Overview ........................................................................................................................38  Features .........................................................................................................................38  General Purpose I/O (GPIO) ........................................................................................ 39  5.5.1  5.5.2  5.6  Overview ........................................................................................................................32  Clock Generator .............................................................................................................34  System Clock and SysTick Clock ...................................................................................35  Peripherals Clock ...........................................................................................................36  Power Down Mode Clock ...............................................................................................36  Frequency Divider Output...............................................................................................37  USB Device Controller (USB) ....................................................................................... 38  5.4.1  5.4.2  5.5  Overview ........................................................................................................................23  System Reset .................................................................................................................23  System Power Distribution .............................................................................................24  System Memory Map......................................................................................................25  System Timer (SysTick) .................................................................................................27  Nested Vectored Interrupt Controller (NVIC) ..................................................................28  Overview ........................................................................................................................40  Features .........................................................................................................................41  PWM Generator and Capture Timer (PWM) ................................................................ 42  5.7.1  Overview ........................................................................................................................42  -2- Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.7.2  5.8  Real Time Clock (RTC)................................................................................................. 44  5.8.1  5.8.2  5.9  Overview ......................................................................................................................57  Features .......................................................................................................................57  FLASH MEMORY CONTROLLER (FMC) ................................................................................ 58  6.1  Overview ....................................................................................................................... 58  6.2  7  Overview ......................................................................................................................56  Features .......................................................................................................................56  External Bus Interface (EBI) ......................................................................................... 57  5.18.1  5.18.2  6  Overview ......................................................................................................................55  Features .......................................................................................................................55  PDMA Controller (PDMA) ............................................................................................. 56  5.17.1  5.17.2  5.18  Overview ......................................................................................................................54  Features .......................................................................................................................54  Analog Comparator (CMP) ........................................................................................... 55  5.16.1  5.16.2  5.17  Overview ......................................................................................................................53  Features .......................................................................................................................53  Analog-to-Digital Converter (ADC) ............................................................................... 54  5.15.1  5.15.2  5.16  Overview ......................................................................................................................52  Features .......................................................................................................................52  I2S Controller (I2S)......................................................................................................... 53  5.14.1  5.14.2  5.15  Overview ......................................................................................................................49  Features .......................................................................................................................51  PS/2 Device Controller (PS2D)..................................................................................... 52  5.13.1  5.13.2  5.14  Overview ......................................................................................................................47  Features .......................................................................................................................49  UART Interface Controller (UART) ............................................................................... 49  5.12.1  5.12.2  5.13  Overview ......................................................................................................................46  Features .......................................................................................................................46  Watchdog Timer (WDT)................................................................................................ 47  5.11.1  5.11.2  5.12  Overview ........................................................................................................................45  Features .........................................................................................................................45  Timer Controller (TMR)................................................................................................. 46  5.10.1  5.10.2  5.11  Overview ........................................................................................................................44  Features .........................................................................................................................44  Serial Peripheral Interface (SPI) ................................................................................... 45  5.9.1  5.9.2  5.10  Features .........................................................................................................................43  Features........................................................................................................................ 58  ELECTRICAL CHARACTERISTICS......................................................................................... 59  7.1  Absolute Maximum Ratings .......................................................................................... 59  7.2  DC Electrical Characteristics ........................................................................................ 60  7.2.1  NuMicro™ NUC100/NUC120 Medium Density DC Electrical Characteristics .................60  7.2.2  NuMicro™ NUC100/NUC120 Low Density DC Electrical Characteristics .......................65  -3- Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 7.2.3  7.2.4  7.2.5  7.3  AC Electrical Characteristics ........................................................................................ 75  7.3.1  7.3.2  7.3.3  7.3.4  7.4  9  External 4~24 MHz High Speed Crystal .........................................................................75  External 32.768 kHz Low Speed Crystal ........................................................................76  Internal 22.1184 MHz High Speed Oscillator..................................................................76  Internal 10 kHz Low Speed Oscillator.............................................................................76  Analog Characteristics.................................................................................................. 77  7.4.1  7.4.2  7.4.3  7.4.4  7.4.5  7.4.6  7.4.7  7.4.8  8  Operating Current Curve (Test condition: run NOP).......................................................70  Idle Current Curve ..........................................................................................................72  Power Down Current Curve............................................................................................74  Specification of 12-bit SARADC .....................................................................................77  Specification of LDO and Power management...............................................................78  Specification of Low Voltage Reset ................................................................................79  Specification of Brown-Out Detector...............................................................................79  Specification of Power-On Reset (5 V) ...........................................................................79  Specification of Temperature Sensor .............................................................................80  Specification of Comparator ...........................................................................................80  Specification of USB PHY ..............................................................................................81  7.5  Flash DC Electrical Characteristics .............................................................................. 82  7.6  SPI Dynamic Characteristics ........................................................................................ 83  PACKAGE DIMENSIONS ......................................................................................................... 85  8.1  100L LQFP (14x14x1.4 mm footprint 2.0mm) .............................................................. 85  8.2  64L LQFP (10x10x1.4mm footprint 2.0 mm) ................................................................ 86  8.3  48L LQFP (7x7x1.4mm footprint 2.0mm) ..................................................................... 87  REVISION HISTORY ................................................................................................................ 88  -4- Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet Figures Figure 3-1 NuMicro™ NUC100 Series selection code ................................................................... 13  Figure 3-2 NuMicro™ NUC120 Medium Density LQFP 100-pin Pin Diagram ............................... 14  Figure 3-3 NuMicro™ NUC120 Medium Density LQFP 64-pin Pin Diagram ................................. 15  Figure 3-4 NuMicro™ NUC120 Medium Density LQFP 48-pin Pin Diagram ................................. 16  Figure 3-5 NuMicro™ NUC120 Low Density LQFP 64-pin Pin Diagram........................................ 17  Figure 3-6 NuMicro™ NUC120 Low Density LQFP 48-pin Pin Diagram........................................ 18  Figure 4-1 NuMicro™ NUC120 Medium Density Block Diagram ................................................... 19  Figure 4-2 NuMicro™ NUC120 Low Density Block Diagram ......................................................... 20  Figure 5-1 Functional Controller Diagram...................................................................................... 21  Figure 5-2 NuMicro™ NUC120 Power Distribution Diagram.......................................................... 24  Figure 5-4 Clock generator global view diagram ........................................................................... 33  Figure 5-5 Clock generator block diagram..................................................................................... 34  Figure 5-6 System Clock Block Diagram ....................................................................................... 35  Figure 5-7 SysTick Clock Control Block Diagram .......................................................................... 35  Figure 5-8 Clock Source of Frequency Divider .............................................................................. 37  Figure 5-9 Block Diagram of Frequency Divider ............................................................................ 37  Figure 5-10 I2C Bus Timing ............................................................................................................ 40  Figure 5-11 Timing of Interrupt and Reset Signal .......................................................................... 48  Figure 7-1 Typical Crystal Application Circuit ................................................................................ 76  Figure 7-2 SPI Master dynamic characteristics timing................................................................... 84  Figure 7-3 SPI Slave dynamic characteristics timing..................................................................... 84  -5- Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet Tables Table 1-1 Connectivity Supported Table.......................................................................................... 7  Table 5-1 Address Space Assignments for On-Chip Controllers................................................... 26  Table 5-2 Exception Model ............................................................................................................ 29  Table 5-3 System Interrupt Map..................................................................................................... 30  Table 5-4 Vector Table Format ...................................................................................................... 31  Table 5-5 Watchdog Timeout Interval Selection ............................................................................ 47  Table 5-6 UART Baud Rate Equation ............................................................................................ 49  Table 5-7 UART Baud Rate Setting Table ..................................................................................... 50  -6- Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 1 GENERAL DESCRIPTION The NuMicro™ NUC100 Series is 32-bit microcontrollers with embedded ARM® Cortex™-M0 core for industrial control and applications which need rich communication interfaces. The Cortex™-M0 is the newest ARM® embedded processor with 32-bit performance and at a cost equivalent to traditional 8-bit microcontroller. NuMicro™ NUC100 Series includes NUC100, NUC120, NUC130 and NUC140 product line. The NuMicro™ NUC120 USB Line with USB 2.0 full-speed function embeds Cortex™-M0 core running up to 50 MHz with 32K/64K/128K-byte embedded flash, 4K/8K/16K-byte embedded SRAM, and 4K-byte loader ROM for the ISP. It also equips with plenty of peripheral devices, such as Timers, Watchdog Timer, RTC, PDMA, UART, SPI, I2C, I2S, PWM Timer, GPIO, PS/2, USB 2.0 FS Device, 12-bit ADC, Analog Comparator, Low Voltage Reset Controller and Brown-Out Detector. Product Line UART SPI I2 C NUC100 ● ● ● NUC120 ● ● ● NUC130 ● ● ● NUC140 ● ● ● USB LIN CAN ● ● PS/2 I2 S ● ● ● ● ● ● ● ● ● ● ● ● Table 1-1 Connectivity Supported Table -7- Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 2 FEATURES The equipped features are dependent on the product line and their sub products. 2.1 NuMicro™ NUC120 Features – USB Line • Core – ARM® Cortex™-M0 core runs up to 50 MHz – One 24-bit system timer – Supports low power sleep mode – Single-cycle 32-bit hardware multiplier – NVIC for the 32 interrupt inputs, each with 4-levels of priority – Serial Wire Debug supports with 2 watchpoints/4 breakpoints • Build-in LDO for wide operating voltage ranges from 2.5 V to 5.5 V • Flash Memory 32K/64K/128K bytes Flash for program code (128KB only support in NuMicro™ NUC100/NUC120 Medium Density) – 4KB flash for ISP loader – Support In-system program (ISP) application code update – 512 byte page erase for flash – Configurable data flash address and size for 128KB system, fixed 4KB data flash for the 32KB and 64KB system – Support 2 wire ICP update through SWD/ICE interface – Support fast parallel programming mode by external programmer • SRAM Memory – 4K/8K/16K bytes embedded SRAM (16KB only support in NuMicro™ NUC100/NUC120 Medium Density) – Support PDMA mode • PDMA (Peripheral DMA) – Support 9 channels PDMA for automatic data transfer between SRAM and peripherals (Only support 1 channel in NuMicro™ NUC100/NUC120 Low Density) • Clock Control – – – – – – – Flexible selection for different applications Built-in 22.1184 MHz high speed OSC for system operation 1 % at +25 ℃ and VDD = 5 V ‹ Trimmed to 3 % at -40 ℃ ~ +85 ℃ and VDD = 2.5 V ~ 5.5 V ‹ Trimmed to Built-in 10 KHz low speed OSC for Watchdog Timer and Wake-up operation Support one PLL, up to 50 MHz, for high performance system operation External 4~24 MHz high speed crystal input for USB and precise timing operation External 32.768 kHz low speed crystal input for RTC function and low power system operation • GPIO – Four I/O modes: ‹ Quasi bi-direction ‹ Push-Pull output ‹ Open-Drain output ‹ Input only with high impendence -8- Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet – TTL/Schmitt trigger input selectable – I/O pin can be configured as interrupt source with edge/level setting – High driver and high sink IO mode support • Timer – – – – Support 4 sets of 32-bit timers with 24-bit up-timer and one 8-bit pre-scale counter Independent clock source for each timer Provides one-shot, periodic, toggle and continuous counting operation modes (NuMicro™ NUC100/NUC120 Medium Density only support one-shot and periodic mode) Support event counting function (NuMicro™ NUC100/NUC120 Low Density only) • Watchdog Timer – – – – • RTC Multiple clock sources 8 selectable time out period from 1.6ms ~ 26.0sec (depends on clock source) WDT can wake-up from power down or idle mode Interrupt or reset selectable on watchdog time-out Support software compensation by setting frequency compensate register (FCR) Support RTC counter (second, minute, hour) and calendar counter (day, month, year) Support Alarm registers (second, minute, hour, day, month, year) Selectable 12-hour or 24-hour mode Automatic leap year recognition Support periodic time tick interrupt with 8 period options 1/128, 1/64, 1/32, 1/16, 1/8, 1/4, 1/2 and 1 second – Support wake-up function • PWM/Capture – – – – – – – – – – • UART – – – – – – – – • SPI – – – Built-in up to four 16-bit PWM generators provide eight PWM outputs or four complementary paired PWM outputs Each PWM generator equipped with one clock source selector, one clock divider, one 8-bit prescaler and one Dead-Zone generator for complementary paired PWM Up to eight 16-bit digital Capture timers (shared with PWM timers) provide eight rising/falling capture inputs Support Capture interrupt Up to three UART controllers (NuMicro™ NUC100/NUC120 Low Density only support 2 UART controllers) UART ports with flow control (TXD, RXD, CTS and RTS) UART0 with 63-byte FIFO is for high speed UART1/2(optional) with 15-byte FIFO for standard device Support IrDA (SIR) function Support RS-485 9-bit mode and direction control. (NuMicro™ NUC100/NUC120 Low Density Only) Programmable baud-rate generator up to 1/16 system clock Support PDMA mode Up to four sets of SPI controller (NuMicro™ NUC100/NUC120 Low Density only support 2 SPI controllers) Master up to 16 MHz, and Slave up to 10 MHz (chip working @ 5V) Support SPI master/slave mode -9- Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet – – – – – – – • I2C – – – – – – – – – 2 •I S Full duplex synchronous serial data transfer Variable length of transfer data from 1 to 32 bits MSB or LSB first data transfer Rx and Tx on both rising or falling edge of serial clock independently 2 slave/device select lines when it is as the master, and 1 slave/device select line when it is as the slave Support byte suspend mode in 32-bit transmission Support PDMA mode Up to two sets of I2C device Master/Slave mode Bidirectional data transfer between masters and slaves Multi-master bus (no central master) Arbitration between simultaneously transmitting masters without corruption of serial data on the bus Serial clock synchronization allows devices with different bit rates to communicate via one serial bus Serial clock synchronization can be used as a handshake mechanism to suspend and resume serial transfer Programmable clocks allow versatile rate control Support multiple address recognition (four slave address with mask option) – Interface with external audio CODEC – Operate as either master or slave mode – Capable of handling 8-, 16-, 24- and 32-bit word sizes – Mono and stereo audio data supported – I2S and MSB justified data format supported – Two 8 word FIFO data buffers are provided, one for transmit and one for receive – Generates interrupt requests when buffer levels cross a programmable boundary – Support two DMA requests, one for transmit and one for receive • PS/2 Device Controller – Host communication inhibit and request to send detection – Reception frame error detection – Programmable 1 to 16 bytes transmit buffer to reduce CPU intervention – Double buffer for data reception – S/W override bus • USB 2.0 Full-Speed Device – One set of USB 2.0 FS Device 12Mbps – On-chip USB Transceiver – Provide 1 interrupt source with 4 interrupt events – Support Control, Bulk In/Out, Interrupt and Isochronous transfers – Auto suspend function when no bus signaling for 3 ms – Provide 6 programmable endpoints – Include 512 Bytes internal SRAM as USB buffer – Provide remote wake-up capability • EBI (External bus interface) support (NuMicro™ NUC100/NUC120 Low Density 64-pin Package Only) – – – Accessible space: 64KB in 8-bit mode or 128KB in 16-bit mode Support 8-/16-bit data width Support byte write in 16-bit data width mode Publication Release Date: Jan. 2, 2012 - 10 Revision V2.03 NuMicro™ NUC120 Data Sheet • ADC – 12-bit SAR ADC with 600K SPS – Up to 8-ch single-end input or 4-ch differential input – Single scan/single cycle scan/continuous scan – Each channel with individual result register – Scan on enabled channels – Threshold voltage detection – Conversion start by software programming or external input – Support PDMA mode • Analog Comparator – Up to two analog comparators – External input or internal bandgap voltage selectable at negative node – Interrupt when compare result change – Power down wake-up • One built-in temperature sensor with 1℃ resolution • Brown-Out detector – With 4 levels: 4.5 V/3.8 V/2.7 V/2.2 V – Support Brown-Out Interrupt and Reset option • Low Voltage Reset – Threshold voltage levels: 2.0 V • Operating Temperature: -40℃~85℃ • Packages: – – All Green package (RoHS) LQFP 100-pin / 64-pin / 48-pin (100-pin for NuMicro™ NUC100/NUC120 Medium Density Only) - 11 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 3 PARTS INFORMATION LIST AND PIN CONFIGURATION 3.1 3.1.1 NuMicro™ NUC120 Products Selection Guide NuMicro™ NUC120 Medium Density USB Line Selection Guide Part number NUC120LD3AN APROM RAM 64 KB Connectivity I/O I2S Comp. PWM Timer I2C UART SPI ADC RTC EBI ISP Package ICP USB LIN CAN up to 31 4x32-bit 2 1 2 1 - - 1 1 4 8x12-bit v - v LQFP48 NUC120LE3AN 128 KB 16 KB Definable 4 KB up to 31 4x32-bit 2 1 2 1 - - 1 1 4 8x12-bit v - v LQFP48 NUC120RD3AN 4 KB up to 45 4x32-bit 2 2 2 1 - - 1 2 6 8x12-bit v - v LQFP64 NUC120RE3AN 128 KB 16 KB Definable 4 KB up to 45 4x32-bit 2 2 2 1 - - 1 2 6 8x12-bit v - v LQFP64 NUC120VD2AN 64 KB 8 KB 4 KB 4 KB up to 76 4x32-bit 3 4 2 1 - - 1 2 8 8x12-bit v - v LQFP100 NUC120VD3AN 64 KB 16 KB 4 KB 4 KB up to 76 4x32-bit 3 4 2 1 - - 1 2 8 8x12-bit v - v LQFP100 4 KB up to 76 4x32-bit 3 4 2 1 - - 1 2 8 8x12-bit v - v LQFP100 16 KB 4 KB ISP Loader ROM 4 KB 64 KB 16 KB Data Flash 4 KB NUC120VE3AN 128 KB 16 KB Definable 3.1.2 NuMicro™ NUC120 Low Density USB Line Selection Guide Part number APROM RAM Data Flash ISP Loader ROM Connectivity I/O I2S Comp. PWM Timer UART SPI 2 IC ADC RTC EBI ISP Package ICP USB LIN CAN NUC120LC1BN 32 KB 4 KB 4 KB 4 KB up to 31 4x32-bit 2 1 2 1 - - 1 1 4 8x12-bit v - v LQFP48 NUC120LD1BN 64 KB 4 KB 4 KB 4 KB up to 31 4x32-bit 2 1 2 1 - - 1 1 4 8x12-bit v - v LQFP48 NUC120LD2BN 64 KB 8 KB 4 KB 4 KB up to 31 4x32-bit 2 1 2 1 - - 1 1 4 8x12-bit v - v LQFP48 NUC120RC1BN 32 KB 4 KB 4 KB 4 KB up to 45 4x32-bit 2 2 2 1 - - 1 2 4 8x12-bit v v v LQFP64 NUC120RD1BN 64 KB 4 KB 4 KB 4 KB up to 45 4x32-bit 2 2 2 1 - - 1 2 4 8x12-bit v v v LQFP64 NUC120RD2BN 64 KB 8 KB 4 KB 4 KB up to 45 4x32-bit 2 2 2 1 - - 1 2 4 8x12-bit v v v LQFP64 - 12 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet NUC 1 0 0 - X X X X X ARM-Based 32-bit Microcontroller Temperature CPU core N: -40 E: -40 C: -40 ~ +85 ~ +105 ~ +125 1: Cortex-M0 5/7: ARM7 9: ARM9 Reserve Function RAM Size 1: 4K 2: 8K 3: 16K 0: Advance Line 2: USB Line 3: Automotive Line 4: Connectivity Line APROM Size A: 8K B: 16K C: 32K D: 64K E: 128K Package Type Y: QFN 36 L: LQFP 48 R: LQFP 64 V: LQFP 100 Figure 3-1 NuMicro™ NUC100 Series selection code - 13 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 3.2 Pin Configuration PE.0/PWM6 PE.1/PWM7 PE.2 PE.3 PE.4 53 52 51 PC.10/MISO10 54 PC.9/SPICLK1 59 PC.13/MOSI11 PC.8/SPISS10 60 55 PA.15/PWM3/I2SMCLK 61 56 PA.14/PWM2 62 PC.11/MOSI10 PA.13/PWM1 63 PC.12/MISO11 PA.12/PWM0 64 57 ICE_DAT 65 58 ICE_CK 66 AVSS 70 67 PA.0/ADC0 71 VSS PA.1/ADC1 72 VDD PA.2/ADC2 73 68 PA.3/ADC3 74 69 PA.4/ADC4 75 3.2.1 NuMicro™ NUC120 Medium Density Pin Diagram 3.2.1.1 NuMicro™ NUC120 Medium Density LQFP 100 pin ADC5/PA.5 76 50 PB.9/SPISS11 ADC6/PA.6 77 49 PB.10/SPISS01 ADC7/SPISS21/PA.7 78 48 PB.11/PWM4 VREF 79 47 PE.5/PWM5 AVDD 80 46 PE.6 SPISS20/PD.0 81 45 PC.0/SPISS00/I2SLRCLK SPICLK2/PD.1 82 44 PC.1/SPICLK0/I2SBCLK MISO20/PD.2 83 43 PC.2/MISO00/I2SDI MOSI20/PD.3 84 42 PC.3/MOSI00/I2SDO MISO21/PD.4 85 41 PC.4/MISO01 MOSI21/PD.5 86 40 PC.5/MOSI01 CPN0/PC.7 87 39 PD.15/TXD2 38 PD.14/RXD2 37 PD.7 36 PD.6 NUC120VxxAN Medium Density LQFP 100-pin 18 19 20 21 22 23 24 25 MOSI31/PD.13 RXD1/PB.4 TXD1/PB.5 RTS1/PB.6 CTS1/PB.7 LDO VDD VSS PE.8 17 26 MISO31/PD.12 PE.7 100 STADC/PB.8 16 27 MOSI30/PD.11 99 15 VBUS PVSS MISO30/PD.10 28 14 98 SPICLK3/PD.9 VDD33 PS2CLK 13 29 SPISS30/PD.8 97 12 D- PS2DAT I2C0SDA/PA.8 30 11 96 I2C0SCL/PA.9 D+ VDD 10 31 9 95 I2C1SCL/PA.11 PB.0/RXD0 VSS I2C1SDA/PA.10 32 8 94 X32I PB.1/TXD0 /RESET 7 33 X32O 93 6 PB.2/RTS0 XT1_IN CLKO/CPO0/PB.12 34 5 92 CPO1/PB.13 PB.3/CTS0 XT1_OUT 4 35 SPISS31/INT0/PB.14 91 3 INT1/PB.15 PE.13 90 2 CPP1/PC.14 1 89 PE.14 88 PE.15 CPP0/PC.6 CPN1/PC.15 Figure 3-2 NuMicro™ NUC120 Medium Density LQFP 100-pin Pin Diagram - 14 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet PA.4/ADC4 PA.3/ADC3 PA.2/ADC2 PA.1/ADC1 PA.0/ADC0 AVSS ICE_CK ICE_DAT PA.12/PWM0 PA.13/PWM1 PA.14/PWM2 PA.15/PWM3/I2SMCLK PC.8/SPISS10 PC.9/SPICLK1 PC.10/MISO10 PC.11/MOSI10 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 NuMicro™ NUC120 Medium Density LQFP 64 pin ADC5/PA.5 49 32 PB.9 ADC6/PA.6 50 31 PB.10 ADC7/PA.7 51 30 PB.11/PWM4 AVDD 52 29 PE.5/PWM5 CPN0/PC.7 53 28 PC.0/SPISS00/I2SLRCLK 27 PC.1/SPICLK0/I2SBCLK 26 PC.2/MISO00/I2SDI 25 PC.3/MOSI00/I2SDO 24 PB.3/CTS0 23 PB.2/RTS0 CPP0/PC.6 54 CPN1/PC.15 55 CPP1/PC.14 56 INT1/PB.15 57 XT1_OUT 58 NUC120RxxAN Medium Density LQFP 64-pin XT1_IN 59 22 PB.1/TXD0 /RESET 60 21 PB.0/RXD0 VSS 61 20 D+ 13 14 15 16 CTS1/PB.7 LDO VDD VSS 12 9 I2C0SDA/PA.8 RTS1/PB.6 8 I2C0SCL/PA.9 11 7 I2C1SDA/PA.10 10 6 I2C1SCL/PA.11 TXD1/PB.5 5 RXD1/PB.4 4 VBUS X32I 17 X32O 64 3 VDD33 STADC/PB.8 2 D- 18 CPO1/PB.13 19 63 CLKO/CPO0/PB.12 62 1 VDD PVSS INT0/PB.14 3.2.1.2 Figure 3-3 NuMicro™ NUC120 Medium Density LQFP 64-pin Pin Diagram - 15 - Publication Release Date: Jan. 2, 2012 Revision V2.03 - 16 - 29 28 8 9 RXD1/PB.4 TXD1/PB.5 12 30 7 I2C0SDA/PA.8 VSS 31 6 I2C0SCL/PA.9 11 32 5 VDD 33 4 I2C1SCL/PA.11 I2C1SDA/PA.10 25 26 27 34 3 X32I 10 35 2 X32O LDO 36 1 PA.15/PWM3/I2SMCLK PA.14/PWM2 PA.13/PWM1 PA.12/PWM0 ICE_DAT ICE_CK AVSS PA.0/ADC0 PA.1/ADC1 PA.2/ADC2 PA.3/ADC3 PA.4/ADC4 3.2.1.3 CLKO/CPO0/PB.12 NuMicro™ NUC120 Data Sheet NuMicro™ NUC120 Medium Density LQFP 48 pin Figure 3-4 NuMicro™ NUC120 Medium Density LQFP 48-pin Pin Diagram Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 3.2.2 NuMicro™ NUC120 Low Density Pin Diagram 3.2.2.1 NuMicro™ NUC120 Low Density LQFP 64 pin AD8/ADC5/PA.5 49 32 PB.9/TM1 AD7/ADC6/PA.6 50 31 PB.10/TM2 AD6/ADC7/PA.7 51 30 PB.11/TM3 AVDD 52 29 PE.5 AD5/CPN0/PC.7 53 28 PC.0/SPISS00/I2SLRCLK 27 PC.1/SPICLK0/I2SBCLK 26 PC.2/MISO00/I2SDI 25 PC.3/MOSI00/I2SDO 24 PB.3/CTS0/nWRH 23 PB.2/RTS0/nWRL AD4/CPP0/PC.6 54 AD3/CPN1/PC.15 55 AD2/CPP1/PC.14 56 INT1/PB.15 57 XT1_OUT 58 XT1_IN 59 22 PB.1/TXD0 /RESET 60 21 PB.0/RXD0 VSS 61 20 D+ VDD 62 19 D- PVSS 63 18 VDD33 STADC/TM0/PB.8 64 17 VBUS NUC120RxxBN Low Density LQFP 64-pin Figure 3-5 NuMicro™ NUC120 Low Density LQFP 64-pin Pin Diagram - 17 - Publication Release Date: Jan. 2, 2012 Revision V2.03 - 18 - 29 28 8 9 RXD1/PB.4 TXD1/PB.5 12 30 7 I2C0SDA/PA.8 VSS 31 6 I2C0SCL/PA.9 25 26 27 32 5 11 33 4 I2C1SCL/PA.11 I2C1SDA/PA.10 10 34 3 X32I VDD 35 2 X32O LDO 36 1 PA.15/PWM3/I2SMCLK PA.14/PWM2 PA.13/PWM1 PA.12/PWM0 ICE_DAT ICE_CK AVSS PA.0/ADC0 PA.1/ADC1 PA.2/ADC2 PA.3/ADC3 PA.4/ADC4 3.2.2.2 CLKO/CPO0/PB.12 NuMicro™ NUC120 Data Sheet NuMicro™ NUC120 Low Density LQFP 48 pin Figure 3-6 NuMicro™ NUC120 Low Density LQFP 48-pin Pin Diagram Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 4 4.1 BLOCK DIAGRAM NuMicro™ NUC120 Medium Density Block Diagram Cortex-M0 50MHz FLASH 128KB SRAM 16KB ISP 4KB GPIO A,B,C,D,E PDMA 10 kHz P L L 32.768 kHz 22.1184 MHz 4~24 MHz CLK_CTL LDO 2.5V~ 5.5V PS2 RTC SPI 2/3 WDT SPI 0/1 12-bit ADC I2C 1 Timer 0/1/ UART 0 -3M Analog Comparator UART 1 -115K Timer 2/3 UART 2 -115K PWM 4~7 PWM 0~3 LVR I2S I2C 0 USB-FS 512BRAM USBPHY POR Brown-out Peripherals with PDMA Figure 4-1 NuMicro™ NUC120 Medium Density Block Diagram - 19 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 4.2 NuMicro™ NUC120 Low Density Block Diagram Cortex-M0 50MHz FLASH 64KB ISP 4KB SRAM 8KB GPIO A,B,C,D,E PDMA 10 kHz P L L 32.768 kHz 22.1184 MHz 4~24 MHz CLK_CTL LDO RTC 2.5V~ 5.5V WDT SPI 0/1 12-bit ADC I2C 1 Timer 0/1/ UART 0 -3M Analog Comparator UART 1 -115K Timer 2/3 POR Brown-out I2S I2C 0 PWM 0~3 LVR USB-FS 512BRAM USBPHY Peripherals with PDMA Figure 4-2 NuMicro™ NUC120 Low Density Block Diagram - 20 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5 5.1 FUNCTIONAL DESCRIPTION ARM® Cortex™-M0 Core The Cortex™-M0 processor is a configurable, multistage, 32-bit RISC processor. It has an AMBA AHB-Lite interface and includes an NVIC component. It also has optional hardware debug functionality. The processor can execute Thumb code and is compatible with other Cortex-M profile processor. The profile supports two modes -Thread mode and Handler mode. Handler mode is entered as a result of an exception. An exception return can only be issued in Handler mode. Thread mode is entered on Reset, and can be entered as a result of an exception return. Figure 5-1 shows the functional controller of processor. Cortex-M0 components Cortex-M0 processor Nested Vectored Interrupt Controller (NVIC) Interrupts Debug Cortex-M0 Processor Core Wakeup Interrupt Controller (WIC) Bus Matrix Breakpoint and Watchpoint Unit Debug Access Port (DAP) Debugger interface AHB-Lite interface Serial Wire or JTAG debug port Figure 5-1 Functional Controller Diagram The implemented device provides: z A low gate count processor that features: ‹ The ARMv6-M Thumb® instruction set ‹ Thumb-2 technology ‹ ARMv6-M compliant 24-bit SysTick timer ‹ A 32-bit hardware multiplier ‹ The system interface supports little-endian data accesses ‹ The ability to have deterministic, fixed-latency, interrupt handling ‹ Load/store-multiples and multicycle-multiplies that can be abandoned and restarted to facilitate rapid interrupt handling ‹ C Application Binary Interface compliant exception model. This is the ARMv6-M, C Application Binary Interface (C-ABI) compliant exception model that enables the use of pure C functions as interrupt handlers - 21 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet ‹ z z z Low power sleep mode entry using Wait For Interrupt (WFI), Wait For Event (WFE) instructions, or the return from interrupt sleep-on-exit feature NVIC that features: ‹ 32 external interrupt inputs, each with four levels of priority ‹ Dedicated Non-Maskable Interrupt (NMI) input. ‹ Support for both level-sensitive and pulse-sensitive interrupt lines ‹ Wake-up Interrupt Controller (WIC), providing ultra-low power sleep mode support. Debug support ‹ Four hardware breakpoints. ‹ Two watchpoints. ‹ Program Counter Sampling Register (PCSR) for non-intrusive code profiling. ‹ Single step and vector catch capabilities. Bus interfaces: ‹ Single 32-bit AMBA-3 AHB-Lite system interface that provides simple integration to all system peripherals and memory. ‹ Single 32-bit slave port that supports the DAP (Debug Access Port). - 22 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.2 System Manager 5.2.1 Overview System management includes these following sections: z System Resets z System Memory Map z System management registers for Part Number ID, chip reset and on-chip controllers reset , multi-functional pin control z System Timer (SysTick) z Nested Vectored Interrupt Controller (NVIC) z System Control registers 5.2.2 System Reset The system reset can be issued by one of the below listed events. For these reset event flags can be read by RSTSRC register. z The Power-On Reset z The low level on the /RESET pin z Watchdog Time Out Reset z Low Voltage Reset z Brown-Out Detector Reset z CPU Reset z System Reset System Reset and Power-On Reset all reset the whole chip including all peripherals. The difference between System Reset and Power-On Reset is external crystal circuit and ISPCON.BS bit. System Reset doesn’t reset external crystal circuit and ISPCON.BS bit, but Power-On Reset does. - 23 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.2.3 System Power Distribution In this chip, the power distribution is divided into three segments. z Analog power from AVDD and AVSS provides the power for analog components operation. z Digital power from VDD and VSS supplies the power to the internal regulator which provides a fixed 2.5 V power for digital operation and I/O pins. z USB transceiver power from VBUS offers the power for operating the USB transceiver. VSS VDD X32I X32O PVSS The outputs of internal voltage regulators, LDO and VDD33, require an external capacitor which should be located close to the corresponding pin. Analog power (AVDD) should be the same voltage level of the digital power (VDD). Figure 5-2 shows the power distribution of NuMicro™ NUC120. Figure 5-2 NuMicro™ NUC120 Power Distribution Diagram - 24 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.2.4 System Memory Map NuMicro™ NUC100 Series provides 4G-byte addressing space. The memory locations assigned to each on-chip controllers are shown in the following table. The detailed register definition, memory space, and programming detailed will be described in the following sections for each onchip peripherals. NuMicro™ NUC100 Series only supports little-endian data format. Address Space Token Controllers Flash and SRAM Memory Space 0x0000_0000 – 0x0001_FFFF FLASH_BA FLASH Memory Space (128KB) 0x2000_0000 – 0x2000_3FFF SRAM Memory Space (16KB) SRAM_BA 0x6000_0000 – 0x6001_FFFF EXTMEM_BA External Memory Space (128KB) (NuMicro™ NUC100/NUC120 Low Density 64-pin Only) AHB Controllers Space (0x5000_0000 – 0x501F_FFFF) 0x5000_0000 – 0x5000_01FF GCR_BA System Global Control Registers 0x5000_0200 – 0x5000_02FF CLK_BA Clock Control Registers 0x5000_0300 – 0x5000_03FF INT_BA Interrupt Multiplexer Control Registers 0x5000_4000 – 0x5000_7FFF GPIO_BA GPIO Control Registers 0x5000_8000 – 0x5000_BFFF PDMA_BA Peripheral DMA Control Registers 0x5000_C000 – 0x5000_FFFF FMC_BA Flash Memory Control Registers 0x5001_0000 – 0x5001_03FF EBI_BA External Bus Interface Control Registers (NuMicro™ NUC100/NUC120 Low Density 64-pin Only) APB1 Controllers Space (0x4000_0000 ~ 0x400F_FFFF) 0x4000_4000 – 0x4000_7FFF WDT_BA Watchdog Timer Control Registers 0x4000_8000 – 0x4000_BFFF RTC_BA Real Time Clock (RTC) Control Register 0x4001_0000 – 0x4001_3FFF TMR01_BA Timer0/Timer1 Control Registers 0x4002_0000 – 0x4002_3FFF I2C0_BA I C0 Interface Control Registers 0x4003_0000 – 0x4003_3FFF SPI0_BA SPI0 with master/slave function Control Registers 0x4003_4000 – 0x4003_7FFF SPI1_BA SPI1 with master/slave function Control Registers 0x4004_0000 – 0x4004_3FFF PWMA_BA PWM0/1/2/3 Control Registers 0x4005_0000 – 0x4005_3FFF UART0_BA UART0 Control Registers 0x4006_0000 – 0x4006_3FFF USBD_BA USB 2.0 FS device Controller Registers 0x400D_0000 – 0x400D_3FFF ACMP_BA 2 Analog Comparator Control Registers - 25 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet Address Space Token 0x400E_0000 – 0x400E_FFFF ADC_BA Controllers Analog-Digital-Converter (ADC) Control Registers APB2 Controllers Space (0x4010_0000 ~ 0x401F_FFFF) 0x4010_0000 – 0x4010_3FFF PS2_BA PS/2 Interface Control Registers 0x4011_0000 – 0x4011_3FFF TMR23_BA Timer2/Timer3 Control Registers 0x4012_0000 – 0x4012_3FFF I2C1_BA I C1 Interface Control Registers 0x4013_0000 – 0x4013_3FFF SPI2_BA 0x4013_4000 – 0x4013_7FFF SPI3_BA 0x4014_0000 – 0x4014_3FFF PWMB_BA 0x4015_0000 – 0x4015_3FFF UART1_BA 0x4015_4000 – 0x4015_7FFF UART2_BA 0x401A_0000 – 0x401A_3FFF I2S_BA 2 SPI2 with master/slave function Control Registers (NuMicro™ NUC100/NUC120 Medium Density Only) SPI3 with master/slave function Control Registers (NuMicro™ NUC100/NUC120 Medium Density Only) PWM4/5/6/7 Control Registers (NuMicro™ NUC100/NUC120 Medium Density Only) UART1 Control Registers UART2 Control Registers (NuMicro™ NUC100/NUC120 Medium Density Only) I2S Interface Control Registers System Controllers Space (0xE000_E000 ~ 0xE000_EFFF) 0xE000_E010 – 0xE000_E0FF SCS_BA System Timer Control Registers 0xE000_E100 – 0xE000_ECFF SCS_BA External Interrupt Controller Control Registers 0xE000_ED00 – 0xE000_ED8F SCS_BA System Control Registers Table 5-1 Address Space Assignments for On-Chip Controllers - 26 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.2.5 System Timer (SysTick) The Cortex-M0 includes an integrated system timer, SysTick. SysTick provides a simple, 24-bit clear-on-write, decrementing, wrap-on-zero counter with a flexible control mechanism. The counter can be used as a Real Time Operating System (RTOS) tick timer or as a simple counter. When system timer is enabled, it will count down from the value in the SysTick Current Value Register (SYST_CVR) to zero, and reload (wrap) to the value in the SysTick Reload Value Register (SYST_RVR) on the next clock cycle, then decrement on subsequent clocks. When the counter transitions to zero, the COUNTFLAG status bit is set. The COUNTFLAG bit clears on reads. The SYST_CVR value is UNKNOWN on reset. Software should write to the register to clear it to zero before enabling the feature. This ensures the timer will count from the SYST_RVR value rather than an arbitrary value when it is enabled. If the SYST_RVR is zero, the timer will be maintained with a current value of zero after it is reloaded with this value. This mechanism can be used to disable the feature independently from the timer enable bit. For more detailed information, please refer to the documents “ARM® Cortex™-M0 Technical Reference Manual” and “ARM® v6-M Architecture Reference Manual”. - 27 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.2.6 Nested Vectored Interrupt Controller (NVIC) Cortex-M0 provides an interrupt controller as an integral part of the exception mode, named as “Nested Vectored Interrupt Controller (NVIC)”. It is closely coupled to the processor kernel and provides following features: z Nested and Vectored interrupt support z Automatic processor state saving and restoration z Reduced and deterministic interrupt latency The NVIC prioritizes and handles all supported exceptions. All exceptions are handled in “Handler Mode”. This NVIC architecture supports 32 (IRQ[31:0]) discrete interrupts with 4 levels of priority. All of the interrupts and most of the system exceptions can be configured to different priority levels. When an interrupt occurs, the NVIC will compare the priority of the new interrupt to the current running one’s priority. If the priority of the new interrupt is higher than the current one, the new interrupt handler will override the current handler. When any interrupts is accepted, the starting address of the interrupt service routine (ISR) is fetched from a vector table in memory. There is no need to determine which interrupt is accepted and branch to the starting address of the correlated ISR by software. While the starting address is fetched, NVIC will also automatically save processor state including the registers “PC, PSR, LR, R0~R3, R12” to the stack. At the end of the ISR, the NVIC will restore the mentioned registers from stack and resume the normal execution. Thus it will take less and deterministic time to process the interrupt request. The NVIC supports “Tail Chaining” which handles back-to-back interrupts efficiently without the overhead of states saving and restoration and therefore reduces delay time in switching to pending ISR at the end of current ISR. The NVIC also supports “Late Arrival” which improves the efficiency of concurrent ISRs. When a higher priority interrupt request occurs before the current ISR starts to execute (at the stage of state saving and starting address fetching), the NVIC will give priority to the higher one without delay penalty. Thus it advances the real-time capability. For more detailed information, please refer to the documents “ARM® Cortex™-M0 Technical Reference Manual” and “ARM® v6-M Architecture Reference Manual”. - 28 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.2.6.1 Exception Model and System Interrupt Map Table 5-2 lists the exception model supported by NuMicro™ NUC100 Series. Software can set four levels of priority on some of these exceptions as well as on all interrupts. The highest userconfigurable priority is denoted as “0” and the lowest priority is denoted as “3”. The default priority of all the user-configurable interrupts is “0”. Note that priority “0” is treated as the fourth priority on the system, after three system exceptions “Reset”, “NMI” and “Hard Fault”. Exception Name Vector Number Priority Reset 1 -3 NMI 2 -2 Hard Fault 3 -1 Reserved 4 ~ 10 Reserved SVCall 11 Configurable Reserved 12 ~ 13 Reserved PendSV 14 Configurable SysTick 15 Configurable Interrupt (IRQ0 ~ IRQ31) 16 ~ 47 Configurable Table 5-2 Exception Model Vector Number Interrupt Number (Bit in Interrupt Registers) Interrupt Name Source IP Interrupt description 0 ~ 15 - - - System exceptions 16 0 BOD_OUT 17 1 WDT_INT WDT Watchdog Timer interrupt 18 2 EINT0 GPIO External signal interrupt from PB.14 pin 19 3 EINT1 GPIO External signal interrupt from PB.15 pin 20 4 GPAB_INT GPIO External signal interrupt from PA[15:0]/PB[13:0] 21 5 GPCDE_INT GPIO External interrupt from PC[15:0]/PD[15:0]/PE[15:0] 22 6 PWMA_INT PWM0~3 PWM0, PWM1, PWM2 and PWM3 interrupt 23 7 PWMB_INT PWM4~7 PWM4, PWM5, PWM6 and PWM7 interrupt 24 8 TMR0_INT TMR0 Timer 0 interrupt 25 9 TMR1_INT TMR1 Timer 1 interrupt Brown-Out Brown-Out low voltage detected interrupt - 29 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet Vector Number Interrupt Number (Bit in Interrupt Registers) Interrupt Name Source IP Interrupt description 26 10 TMR2_INT TMR2 Timer 2 interrupt 27 11 TMR3_INT TMR3 Timer 3 interrupt 28 12 UART02_INT UART0/2 29 13 UART1_INT UART1 30 14 SPI0_INT SPI0 SPI0 interrupt 31 15 SPI1_INT SPI1 SPI1 interrupt 32 16 SPI2_INT SPI2 SPI2 interrupt 33 17 SPI3_INT SPI3 SPI3 interrupt 34 18 I2C0_INT I2C0 I2C0 interrupt 35 19 I2C1_INT I2C1 I2C1 interrupt 36 20 Reserved Reserved Reserved 37 21 Reserved Reserved Reserved 38 22 Reserved Reserved Reserved 39 23 USB_INT USBD 40 24 PS2_INT PS/2 41 25 ACMP_INT ACMP Analog Comparator-0 or Comaprator-1 interrupt 42 26 PDMA_INT PDMA PDMA interrupt 43 27 I2S_INT I2S 44 28 PWRWU_INT CLKC Clock controller interrupt for chip wake-up from power down state 45 29 ADC_INT ADC ADC interrupt 46 30 Reserved 47 31 RTC_INT UART0 and UART2 interrupt UART1 interrupt USB 2.0 FS Device interrupt PS/2 interrupt I2S interrupt Reserved Reserved RTC Real time clock interrupt Table 5-3 System Interrupt Map - 30 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.2.6.2 Vector Table When any interrupts is accepted, the processor will automatically fetch the starting address of the interrupt service routine (ISR) from a vector table in memory. For ARMv6-M, the vector table base address is fixed at 0x00000000. The vector table contains the initialization value for the stack pointer on reset, and the entry point addresses for all exception handlers. The vector number on previous page defines the order of entries in the vector table associated with exception handler entry as illustrated in previous section. Vector Table Word Offset Description 0 Vector Number SP_main – The Main stack pointer Exception Entry Pointer using that Vector Number Table 5-4 Vector Table Format 5.2.6.3 Operation Description NVIC interrupts can be enabled and disabled by writing to their corresponding Interrupt SetEnable or Interrupt Clear-Enable register bit-field. The registers use a write-1-to-enable and write1-to-clear policy, both registers reading back the current enabled state of the corresponding interrupts. When an interrupt is disabled, interrupt assertion will cause the interrupt to become Pending, however, the interrupt will not activate. If an interrupt is Active when it is disabled, it remains in its Active state until cleared by reset or an exception return. Clearing the enable bit prevents new activations of the associated interrupt. NVIC interrupts can be pended/un-pended using a complementary pair of registers to those used to enable/disable the interrupts, named the Set-Pending Register and Clear-Pending Register respectively. The registers use a write-1-to-enable and write-1-to-clear policy, both registers reading back the current pended state of the corresponding interrupts. The Clear-Pending Register has no effect on the execution status of an Active interrupt. NVIC interrupts are prioritized by updating an 8-bit field within a 32-bit register (each register supporting four interrupts). The general registers associated with the NVIC are all accessible from a block of memory in the System Control Space and will be described in next section. - 31 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.3 Clock Controller 5.3.1 Overview The clock controller generates the clocks for the whole chip, including system clocks and all peripheral clocks. The clock controller also implements the power control function with the individually clock ON/OFF control, clock source selection and a clock divider. The chip will not enter power down mode until CPU sets the power down enable bit (PWR_DOWN_EN) and Cortex-M0 core executes the WFI instruction. After that, chip enter power down mode and wait for wake-up interrupt source triggered to leave power down mode. In the power down mode, the clock controller turns off the external 4~24 MHz high speed crystal and internal 22.1184 MHz high speed oscillator to reduce the overall system power consumption. - 32 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 22.1184 MHz 22.1184 MHz 10 kHz 4~12 MHz PLLFOUT 32.768 kHz 32.768 kHz 4~24 MHz 10 kHz 111 010 HCLK 22.1184 MHz PCLK 111 1/2 011 1/2 010 000 000 CLKSEL1[22:20] CLKSEL1[18:16] CLKSEL1[14:12] CLKSEL1[10:8] PLLFOUT 4~24 MHz 22.1184 MHz 11 22.1184 MHz PLLFOUT 4~24 MHz CLKSEL1[3:2] CLKSEL1[25:24] SysTick FDIV PWM 6-7 PWM 4-5 PWM 2-3 PWM 0-1 10 01 00 32.768 kHz CLKSEL2[7:2] CLKSEL1[31:28] RTC I2S 01 10 kHz 00 BOD 11 HCLK CLKSEL2[1:0] PS2 FMC SYST_CSR[2] 4~24 MHz 10 1 0 HCLK 11 22.1184 MHz CPUCLK 32.768 kHz HCLK TMR 0 TMR 1 TMR 2 TMR 3 001 4~24 MHz CLKSEL0[5:3] 22.1184 MHz SPI 0-3 010 001 4~24 MHz I2C 0~1 111 HCLK 1/2 32.768 kHz PDMA ACMP 22.1184 MHz PLLFOUT 0 4~24 MHz 1/(HCLK_N+1) 000 PLLCON[19] HCLK EBI 32.768 kHz 1 4~24 MHz CPU 001 CLKSEL0[2:0] 22.1184 MHz CPUCLK 011 1/2048 10 WDT CLKSEL1[1:0] 11 01 00 PLLFOUT 1/(ADC_N+1) ADC 1/(UART_N+1) UART 0-2 1/(USB_N+1) USB Figure 5-3 Clock generator global view diagram - 33 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.3.2 Clock Generator The clock generator consists of 5 clock sources which are listed below: z One external 32.768 kHz low speed crystal z One external 4~24 MHz high speed crystal z One programmable PLL FOUT(PLL source consists of external 4~24 MHz high speed crystal and internal 22.1184 MHz high speed oscillator) z One internal 22.1184 MHz high speed oscillator z One internal 10 kHz low speed oscillator XTL32K_EN (PWRCON[1]) X32I External 32.768 kHz Crystal 32.768 kHz X32O XTL12M_EN (PWRCON[0]) 4~24 MHz XT_IN External 4~24 MHz Crystal PLL_SRC (PLLCON[19]) XT_OUT 0 OSC22M_EN (PWRCON[2]) 1 PLL PLL FOUT Internal 22.1184 MHz Oscillator 22.1184 MHz OSC10K_EN(PWRCON[3]) Internal 10 kHz Oscillator 10 kHz Figure 5-4 Clock generator block diagram - 34 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.3.3 System Clock and SysTick Clock The system clock has 5 clock sources which were generated from clock generator block. The clock source switch depends on the register HCLK_S (CLKSEL0[2:0]). The block diagram is showed in Figure 5-5. HCLK_S (CLKSEL0[2:0]) 22.1184 MHz 10 kHz PLLFOUT 32.768 kHz 4~24 MHz 111 011 CPUCLK 010 HCLK 1/(HCLK_N+1) 001 HCLK_N (CLKDIV[3:0]) PCLK CPU AHB APB 000 CPU in Power Down Mode Figure 5-5 System Clock Block Diagram The clock source of SysTick in Cortex-M0 core can use CPU clock or external clock (SYST_CSR[2]). If using external clock, the SysTick clock (STCLK) has 5 clock sources. The clock source switch depends on the setting of the register STCLK_S (CLKSEL0[5:3]). The block diagram is showed in Figure 5-6. Figure 5-6 SysTick Clock Control Block Diagram - 35 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.3.4 Peripherals Clock The peripherals clock had different clock source switch setting which depends on the different peripheral. Please refer the CLKSEL1 and CLKSEL2 register description in 5.3.7. 5.3.5 Power Down Mode Clock When chip enters into power down mode, system clocks, some clock sources, and some peripheral clocks will be disabled. Some clock sources and peripherals clock are still active in power down mode. For theses clocks which still keep active list below: z z Clock Generator ‹ Internal 10 kHz low speed oscillator clock ‹ External 32.768 kHz low speed crystal clock Peripherals Clock (When WDT adopt internal 10 kHz low speed oscillator as clock source and RTC adopt external 32.768 kHz low speed crystal as clock source) - 36 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.3.6 Frequency Divider Output This device is equipped a power-of-2 frequency divider which is composed by16 chained divideby-2 shift registers. One of the 16 shift register outputs selected by a sixteen to one multiplexer is reflected to CLKO function pin. Therefore there are 16 options of power-of-2 divided clocks with the frequency from Fin/21 to Fin/216 where Fin is input clock frequency to the clock divider. The output formula is Fout = Fin/2(N+1), where Fin is the input clock frequency, Fout is the clock divider output frequency and N is the 4-bit value in FSEL (FRQDIV[3:0]). When write 1 to DIVIDER_EN (FRQDIV[4]), the chained counter starts to count. When write 0 to DIVIDER_EN (FRQDIV[4]), the chained counter continuously runs till divided clock reaches low state and stay in low state. Figure 5-7 Clock Source of Frequency Divider Figure 5-8 Block Diagram of Frequency Divider - 37 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.4 USB Device Controller (USB) 5.4.1 Overview There is one set of USB 2.0 full-speed device controller and transceiver in this device. It is compliant with USB 2.0 full-speed device specification and support control/bulk/interrupt/ isochronous transfer types. In this device controller, there are two main interfaces: the APB bus and USB bus which comes from the USB PHY transceiver. For the APB bus, the CPU can program control registers through it. There are 512 bytes internal SRAM as data buffer in this controller. For IN or OUT transfer, it is necessary to write data to SRAM or read data from SRAM through the APB interface or SIE. Users need to set the effective starting address of SRAM for each endpoint buffer through “buffer segmentation register (USB_BUFSEGx)”. There are 6 endpoints in this controller. Each of the endpoint can be configured as IN or OUT endpoint. All the operations including Control, Bulk, Interrupt and Isochronous transfer are implemented in this block. The block of ENDPOINT CONTROL is also used to manage the data sequential synchronization, endpoint states, current start address, transaction status, and data buffer status for each endpoint. There are four different interrupt events in this controller. They are the wake-up function, device plug-in or plug-out event, USB events, like IN ACK, OUT ACK etc, and BUS events, like suspend and resume, etc. Any event will cause an interrupt, and users just need to check the related event flags in interrupt event status register (USB_INTSTS) to acknowledge what kind of interrupt occurring, and then check the related USB Endpoint Status Register (USB_EPSTS) to acknowledge what kind of event occurring in this endpoint. A software-disable function is also supported for this USB controller. It is used to simulate the disconnection of this device from the host. If user enables DRVSE0 bit (USB_DRVSE0), the USB controller will force the output of USB_DP and USB_DM to level low and its function is disabled. After disable the DRVSE0 bit, host will enumerate the USB device again. Reference: Universal Serial Bus Specification Revision 1.1 5.4.2 Features This Universal Serial Bus (USB) performs a serial interface with a single connector type for attaching all USB peripherals to the host system. Following is the feature listing of this USB. z Compliant with USB 2.0 Full-Speed specification z Provide 1 interrupt vector with 4 different interrupt events (WAKEUP, FLDET, USB and BUS) z Support Control/Bulk/Interrupt/Isochronous transfer type z Support suspend function when no bus activity existing for 3 ms z Provide 6 endpoints for configurable Control/Bulk/Interrupt/Isochronous transfer types and maximum 512 bytes buffer size z Provide remote wake-up capability - 38 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.5 General Purpose I/O (GPIO) 5.5.1 Overview NuMicro™ NUC100/NUC120 Medium Density has up to 80 General Purpose I/O pins can be shared with other function pins; it depends on the chip configuration. These 80 pins are arranged in 5 ports named with GPIOA, GPIOB, GPIOC, GPIOD and GPIOE. Each port equips maximum 16 pins. Each one of the 80 pins is independent and has the corresponding register bits to control the pin mode function and data. NuMicro™ NUC100/NUC120 Low Density has up to 65 General Purpose I/O pins can be shared with other function pins; it depends on the chip configuration and package. These 65 pins are arranged in 4 ports named with GPIOA, GPIOB, GPIOC and GPIOD with each port equips maximum 16 pins and another port named GPIOE with 1 pins PE.5. The I/O type of each of I/O pins can be configured by software individually as input, output, opendrain or quasi-bidirectional mode. After reset, the I/O type of all pins stay in quasi-bidirectional mode and port data register GPIOx_DOUT[15:0] resets to 0x0000_FFFF. Each I/O pin equips a very weakly individual pull-up resistor which is about 110KΩ~300KΩ for VDD is from 5.0 V to 2.5 V. 5.5.2 Features z Four I/O modes: ‹ Quasi bi-direction ‹ Push-Pull output ‹ Open-Drain output ‹ Input only with high impendence z TTL/Schmitt trigger input selectable z I/O pin can be configured as interrupt source with edge/level setting z High driver and high sink IO mode support - 39 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.6 I2C Serial Interface Controller (Master/Slave) (I2C) 5.6.1 Overview I2C is a two-wire, bi-directional serial bus that provides a simple and efficient method of data exchange between devices. The I2C standard is a true multi-master bus including collision detection and arbitration that prevents data corruption if two or more masters attempt to control the bus simultaneously. Data is transferred between a Master and a Slave synchronously to SCL on the SDA line on a byte-by-byte basis. Each data byte is 8-bit long. There is one SCL clock pulse for each data bit with the MSB being transmitted first. An acknowledge bit follows each transferred byte. Each bit is sampled during the high period of SCL; therefore, the SDA line may be changed only during the low period of SCL and must be held stable during the high period of SCL. A transition on the SDA line while SCL is high is interpreted as a command (START or STOP). Please refer to the Figure 5-9 for more detail I2C BUS Timing. Figure 5-9 I2C Bus Timing The device’s on-chip I2C logic provides the serial interface that meets the I2C bus standard mode specification. The I2C port handles byte transfers autonomously. To enable this port, the bit ENS1 in I2CON should be set to '1'. The I2C H/W interfaces to the I2C bus via two pins: SDA and SCL. Pull up resistor is needed for I2C operation as these are open drain pins. When the I/O pins are used as I2C port, user must set the pins function to I2C in advance. - 40 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.6.2 Features The I2C bus uses two wires (SDA and SCL) to transfer information between devices connected to the bus. The main features of the bus are: z Master/Slave mode z Bidirectional data transfer between masters and slaves z Multi-master bus (no central master) z Arbitration between simultaneously transmitting masters without corruption of serial data on the bus z Serial clock synchronization allows devices with different bit rates to communicate via one serial bus z Serial clock synchronization can be used as a handshake mechanism to suspend and resume serial transfer z Built-in a 14-bit time-out counter will request the I2C interrupt if the I2C bus hangs up and timer-out counter overflows. z External pull-up are needed for high output z Programmable clocks allow versatile rate control z Supports 7-bit addressing mode z I2C-bus controllers support multiple address recognition ( Four slave address with mask option) - 41 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.7 PWM Generator and Capture Timer (PWM) 5.7.1 Overview NuMicro™ NUC100/NUC120 Medium Density has 2 sets of PWM group supports total 4 sets of PWM Generators which can be configured as 8 independent PWM outputs, PWM0~PWM7, or as 4 complementary PWM pairs, (PWM0, PWM1), (PWM2, PWM3), (PWM4, PWM5) and (PWM6, PWM7) with 4 programmable dead-zone generators. NuMicro™ NUC100/NUC120 Low Density only support 1 set of PWM group supports total 2 sets of PWM Generators which can be configured as 4 independent PWM outputs, PWM0~PWM3, or as 2 complementary PWM pairs, (PWM0, PWM1) and (PWM2, PWM3) with 2 programmable dead-zone generators. Each PWM Generator has one 8-bit prescaler, one clock divider with 5 divided frequencies (1, 1/2, 1/4, 1/8, 1/16), two PWM Timers including two clock selectors, two 16-bit PWM downcounters for PWM period control, two 16-bit comparators for PWM duty control and one deadzone generator. The 4 sets of PWM Generators provide eight independent PWM interrupt flags which are set by hardware when the corresponding PWM period down counter reaches zero. Each PWM interrupt source with its corresponding enable bit can cause CPU to request PWM interrupt. The PWM generators can be configured as one-shot mode to produce only one PWM cycle signal or auto-reload mode to output PWM waveform continuously. When PCR.DZEN01 is set, PWM0 and PWM1 perform complementary PWM paired function; the paired PWM period, duty and dead-time are determined by PWM0 timer and Dead-zone generator 0. Similarly, the complementary PWM pairs of (PWM2, PWM3), (PWM4, PWM5) and (PWM6, PWM7) are controlled by PWM2, PWM4 and PWM6 timers and Dead-zone generator 2, 4 and 6, respectively. To prevent PWM driving output pin with unsteady waveform, the 16-bit period down counter and 16-bit comparator are implemented with double buffer. When user writes data to counter/comparator buffer registers the updated value will be load into the 16-bit down counter/ comparator at the time down counter reaching zero. The double buffering feature avoids glitch at PWM outputs. When the 16-bit period down counter reaches zero, the interrupt request is generated. If PWMtimer is set as auto-reload mode, when the down counter reaches zero, it is reloaded with PWM Counter Register (CNRx) automatically then start decreasing, repeatedly. If the PWM-timer is set as one-shot mode, the down counter will stop and generate one interrupt request when it reaches zero. The value of PWM counter comparator is used for pulse high width modulation. The counter control logic changes the output to high level when down-counter value matches the value of compare register. The alternate feature of the PWM-timer is digital input Capture function. If Capture function is enabled the PWM output pin is switched as capture input mode. The Capture0 and PWM0 share one timer which is included in PWM0 and the Capture1 and PWM1 share PWM1 timer, and etc. Therefore user must setup the PWM-timer before enable Capture feature. After capture feature is enabled, the capture always latched PWM-counter to Capture Rising Latch Register (CRLR) when input channel has a rising transition and latched PWM-counter to Capture Falling Latch Register (CFLR) when input channel has a falling transition. Capture channel 0 interrupt is programmable by setting CCR0.CRL_IE0[1] (Rising latch Interrupt enable) and CCR0.CFL_IE0[2]] (Falling latch Interrupt enable) to decide the condition of interrupt occur. Capture channel 1 has the same feature by setting CCR0.CRL_IE1[17] and CCR0.CFL_IE1[18]. And capture channel 2 to channel 3 on each group have the same feature by setting the corresponding control bits in CCR2. For each group, whenever Capture issues Interrupt 0/1/2/3, - 42 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet the PWM counter 0/1/2/3 will be reload at this moment. The maximum captured frequency that PWM can capture is confined by the capture interrupt latency. When capture interrupt occurred, software will do at least three steps, they are: Read PIIR to get interrupt source and Read CRLRx/CFLRx(x=0~3) to get capture value and finally write 1 to clear PIIR to zero. If interrupt latency will take time T0 to finish, the capture signal mustn’t transition during this interval (T0). In this case, the maximum capture frequency will be 1/T0. For example: HCLK = 50 MHz, PWM_CLK = 25 MHz, Interrupt latency is 900 ns So the maximum capture frequency will is 1/900ns ≈ 1000 kHz 5.7.2 Features 5.7.2.1 PWM function features: 5.7.2.2 z PWM group has two PWM generators. Each PWM generator supports one 8-bit prescaler, one clock divider, two PWM-timers (down counter), one dead-zone generator and two PWM outputs. z Up to 16-bit resolution z PWM Interrupt request synchronized with PWM period z One-shot or Auto-reload mode PWM z Up to 2 PWM group (PWMA/PWMB) to support 8 PWM channels or 4 PWM paired channels (only 1 PWM group support for NuMicro™ NUC100/NUC120 Low Density) Capture Function Features: z Timing control logic shared with PWM Generators z Support 8 Capture input channels shared with 8 PWM output channels (NuMicro™ NUC100/NUC120 Low Density only support 4 Capture input channels shared with 4 PWM output channels) z Each channel supports one rising latch register (CRLR), one falling latch register (CFLR) and Capture interrupt flag (CAPIFx) - 43 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.8 Real Time Clock (RTC) 5.8.1 Overview Real Time Clock (RTC) controller provides user the real time and calendar message. The clock source of RTC is from an external 32.768 kHz low speed crystal connected at pins X32I and X32O (reference to pin descriptions) or from an external 32.768 kHz low speed oscillator output fed at pin X32I. The RTC controller provides the time message (second, minute, hour) in Time Loading Register (TLR) as well as calendar message (day, month, year) in Calendar Loading Register (CLR). The data message is expressed in BCD format. It also offers alarm function that user can preset the alarm time in Time Alarm Register (TAR) and alarm calendar in Calendar Alarm Register (CAR). The RTC controller supports periodic Time Tick and Alarm Match interrupts. The periodic interrupt has 8 period options 1/128, 1/64, 1/32, 1/16, 1/8, 1/4, 1/2 and 1 second which are selected by TTR (TTR[2:0]). When RTC counter in TLR and CLR is equal to alarm setting time registers TAR and CAR, the alarm interrupt flag (RIIR.AIF) is set and the alarm interrupt is requested if the alarm interrupt is enabled (RIER.AIER=1). Both RTC Time Tick and Alarm Match can cause chip wakeup from power down mode if wake-up function is enabled (TWKE (TTR[3])=1). 5.8.2 z Features There is a time counter (second, minute, hour) and calendar counter (day, month, year) for user to check the time z Alarm register (second, minute, hour, day, month, year) z 12-hour or 24-hour mode is selectable z Leap year compensation automatically z Day of week counter z Frequency compensate register (FCR) z All time and calendar message is expressed in BCD code z Support periodic time tick interrupt with 8 period options 1/128, 1/64, 1/32, 1/16, 1/8, 1/4, 1/2 and 1 second z Support RTC Time Tick and Alarm Match interrupt z Support wake-up chip from power down mode - 44 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.9 Serial Peripheral Interface (SPI) 5.9.1 Overview The Serial Peripheral Interface (SPI) is a synchronous serial data communication protocol which operates in full duplex mode. Devices communicate in master/slave mode with 4-wire bi-direction interface. The NuMicro™ NUC100/NUC120 Medium Density contains up to four sets of SPI controller performing a serial-to-parallel conversion on data received from a peripheral device, and a parallel-to-serial conversion on data transmitted to a peripheral device. Each set of SPI controller can be set as a master that can drive up to 2 external peripheral slave devices; it also can be configured as a slave device controlled by an off-chip master device. NuMicro™ NUC100/NUC120 Low Density contains two sets of SPI controller only. This controller supports a variable serial clock for special application and it also supports 2-bit transfer mode to connect 2 off-chip slave devices at the same time. The SPI controller also supports PDMA function to access the data buffer. 5.9.2 z Features Up to four sets of SPI controller for NuMicro™ NUC100/NUC120 Medium Density z Up to two sets of SPI controller for NuMicro™ NUC100/NUC120 Low Density z Support master or slave mode operation z Support 1-bit or 2-bit transfer mode z Configurable bit length up to 32-bit of a transfer word and configurable word numbers up to 2 of a transaction, so the maximum bit length is 64-bit for each data transfer z Provide burst mode operation, transmit/receive can be transferred up to two times word transaction in one transfer z Support MSB or LSB first transfer z 2 device/slave select lines in master mode, but 1 device/slave select line in slave mode z Support byte reorder function z Support byte or word suspend mode z Variable output serial clock frequency in master mode z Support two programmable serial clock frequencies in master mode z Support two channel PDMA request, one for transmitter and another for receiver - 45 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.10 Timer Controller (TMR) 5.10.1 Overview The timer controller includes four 32-bit timers, TIMER0~TIMER3, which allows user to easily implement a timer control for applications. The timer can perform functions like frequency measurement, event counting, interval measurement, clock generation, delay timing, and so on. The timer can generates an interrupt signal upon timeout, or provide the current value during operation. Note: toggle mode, continuous counting mode and event counting function only support in NuMicro™ NUC100/NUC120 Low Density. 5.10.2 Features z 4 sets of 32-bit timers with 24-bit up-timer and one 8-bit pre-scale counter z Independent clock source for each timer z Provides one-shot, periodic, toggle and continuous counting operation modes (NuMicro™ NUC100/NUC120 Medium Density only support one-shot and periodic mode) z Time out period = (Period of timer clock input) * (8-bit pre-scale counter + 1) * (24-bit TCMP) z Maximum counting cycle time = (1 / T MHz) * (28) * (224), T is the period of timer clock z 24-bit timer value is readable through TDR (Timer Data Register) z Support event counting function to count the event from external pin (NuMicro™ NUC100/NUC120 Low Density only) - 46 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.11 Watchdog Timer (WDT) 5.11.1 Overview The purpose of Watchdog Timer is to perform a system reset when system runs into an unknown state. This prevents system from hanging for an infinite period of time. Besides, this Watchdog Timer supports another function to wake-up chip from power down mode. The watchdog timer includes an 18-bit free running counter with programmable time-out intervals. Table 5-5 show the watchdog timeout interval selection and Figure 5-64 shows the timing of watchdog interrupt signal and reset signal. Setting WTE (WDTCR [7]) enables the watchdog timer and the WDT counter starts counting up. When the counter reaches the selected time-out interval, Watchdog timer interrupt flag WTIF will be set immediately to request a WDT interrupt if the watchdog timer interrupt enable bit WTIE is set, in the meanwhile, a specified delay time (1024 * TWDT) follows the time-out event. User must set WTR (WDTCR [0]) (Watchdog timer reset) high to reset the 18-bit WDT counter to avoid chip from Watchdog timer reset before the delay time expires. WTR bit is cleared automatically by hardware after WDT counter is reset. There are eight time-out intervals with specific delay time which are selected by Watchdog timer interval select bits WTIS (WDTCR [10:8]). If the WDT counter has not been cleared after the specific delay time expires, the watchdog timer will set Watchdog Timer Reset Flag (WTRF) high and reset chip. This reset will last 63 WDT clocks (TRST) then chip restarts executing program from reset vector (0x0000_0000). WTRF will not be cleared by Watchdog reset. User may poll WTRF by software to recognize the reset source. WDT also provides wake-up function. When chip is powered down and the Watchdog Timer Wake-up Function Enable bit (WDTR[4]) is set, if the WDT counter reaches the specific time interval defined by WTIS (WDTCR [10:8]) , the chip is waken up from power down state. First example, if WTIS is set as 000, the specific time interval for chip to wake up from power down state is 24 * TWDT. When power down command is set by software, then, chip enters power down state. After 24 * TWDT time is elapsed, chip is waken up from power down state. Second example, if WTIS (WDTCR [10:8]) is set as 111, the specific time interval for chip to wake up from power down state is 218 * TWDT. If power down command is set by software, then, chip enters power down state. After 218 * TWDT time is elapsed, chip is waken up from power down state. Notice if WTRE (WDTCR [1]) is set to 1, after chip is waken up, software should clear the Watchdog Timer counter by setting WTR(WDTCR [0]) to 1 as soon as possible. Otherwise, if the Watchdog Timer counter is not cleared by setting WTR (WDTCR [0]) to 1 before time starting from waking up to software clearing Watchdog Timer counter is over 1024 * TWDT , the chip is reset by Watchdog Timer. WTIS Timeout Interval Selection TTIS 000 2 * TWDT 001 010 011 100 101 110 111 Interrupt Period TINT WTR Timeout Interval (WDT_CLK=10 kHz) Min. TWTR ~ Max. TWTR 4 1024 * TWDT 1.6 ms ~ 104 ms 6 1024 * TWDT 6.4 ms ~ 108.8 ms 8 1024 * TWDT 25.6 ms ~ 128 ms 2 * TWDT 2 * TWDT 10 * TWDT 1024 * TWDT 102.4 ms ~ 204.8 ms 12 * TWDT 1024 * TWDT 409.6 ms ~ 512 ms 14 * TWDT 1024 * TWDT 1.6384 s ~ 1.7408 s 16 * TWDT 1024 * TWDT 6.5536 s ~ 6.656 s 18 * TWDT 1024 * TWDT 26.2144 s ~ 26.3168 s 2 2 2 2 2 Table 5-5 Watchdog Timeout Interval Selection - 47 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet TWDT INT RST TTIS TINT 1024 * TWDT TRST Minimum TWTR 63 * TWDT Maximum TWTR TWDT : Watchdog Engine Clock Time Period TTIS : Watchdog Timeout Interval Selection Period TINT : Watchdog Interrupt Period TRST : Watchdog Reset Period TWTR : Watchdog Timeout Interval Period Figure 5-10 Timing of Interrupt and Reset Signal - 48 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.11.2 Features z 18-bit free running counter to avoid chip from Watchdog timer reset before the delay time expires. z Selectable time-out interval (24 ~ 218) and the time out interval is 104 ms ~ 26.3168 s (if WDT_CLK = 10 kHz). z Reset period = (1 / 10 kHz) * 63, if WDT_CLK = 10 kHz. 5.12 UART Interface Controller (UART) NuMicro™ NUC100/NUC120 Medium Density provides up to three channels of Universal Asynchronous Receiver/Transmitters (UART). UART0 supports High Speed UART and UART1~2 perform Normal Speed UART, besides, only UART0 and UART1 support flow control function. NuMicro™ NUC100/NUC120 Low Density only supports UART0 and UART1. 5.12.1 Overview The Universal Asynchronous Receiver/Transmitter (UART) performs a serial-to-parallel conversion on data received from the peripheral, and a parallel-to-serial conversion on data transmitted from the CPU. The UART controller also supports IrDA SIR Function and RS-485 mode functions. Each UART channel supports seven types of interrupts including transmitter FIFO empty interrupt (INT_THRE), receiver threshold level reaching interrupt (INT_RDA), line status interrupt (parity error or framing error or break interrupt) (INT_RLS), receiver buffer time out interrupt (INT_TOUT), MODEM/Wake-up status interrupt (INT_MODEM) and Buffer error interrupt (INT_BUF_ERR). Interrupts of UART0 and UART2 share the interrupt number 12 (vector number is 28); Interrupt number 13 (vector number is 29) only supports UART1 interrupt. Refer to Nested Vectored Interrupt Controller chapter for System Interrupt Map. The UART0 is built-in with a 64-byte transmitter FIFO (TX_FIFO) and a 64-byte receiver FIFO (RX_FIFO) that reduces the number of interrupts presented to the CPU and the UART1~2 are equipped 16-byte transmitter FIFO (TX_FIFO) and 16-byte receiver FIFO (RX_FIFO). The CPU can read the status of the UART at any time during the operation. The reported status information includes the type and condition of the transfer operations being performed by the UART, as well as 4 error conditions (parity error, framing error, break interrupt and buffer error) probably occur while receiving data. The UART includes a programmable baud rate generator that is capable of dividing clock input by divisors to produce the serial clock that transmitter and receiver need. The baud rate equation is Baud Rate = UART_CLK / M * [BRD + 2], where M and BRD are defined in Baud Rate Divider Register (UA_BAUD). Table 5-6 lists the equations in the various conditions and Table 5-7 list the UART baud rate setting table. Mode DIV_X_EN DIV_X_ONE Divider X BRD Baud rate equation 0 0 0 B A UART_CLK / [16 * (A+2)] 1 1 0 B A UART_CLK / [(B+1) * (A+2)] , B must >= 8 2 1 1 Don’t care A UART_CLK / (A+2), A must >=3 Table 5-6 UART Baud Rate Equation - 49 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet System clock = Internal 22.1184 MHz high speed oscillator Mode0 Baud rate Mode1 Mode2 Parameter Register Parameter Register Parameter Register 921600 x x A=0,B=11 0x2B00_0000 A=22 0x3000_0016 460800 A=1 0x0000_0001 A=1,B=15 A=2,B=11 0x2F00_0001 0x2B00_0002 A=46 0x3000_002E 230400 A=4 0x0000_0004 A=4,B=15 A=6,B=11 0x2F00_0004 0x2B00_0006 A=94 0x3000_005E 115200 A=10 0x0000_000A A=10,B=15 A=14,B=11 0x2F00_000A 0x2B00_000E A=190 0x3000_00BE 57600 A=22 0x0000_0016 A=22,B=15 A=30,B=11 0x2F00_0016 0x2B00_001E A=382 0x3000_017E 38400 A=34 0x0000_0022 A=62,B=8 A=46,B=11 A=34,B=15 0x2800_003E 0x2B00_002E 0x2F00_0022 A=574 0x3000_023E 19200 A=70 0x0000_0046 A=126,B=8 A=94,B=11 A=70,B=15 0x2800_007E 0x2B00_005E 0x2F00_0046 A=1150 0x3000_047E 9600 A=142 A=254,B=8 0x0000_008E A=190,B=11 A=142,B=15 0x2800_00FE 0x2B00_00BE 0x2F00_008E A=2302 0x3000_08FE 4800 A=286 A=510,B=8 0x0000_011E A=382,B=11 A=286,B=15 0x2800_01FE 0x2B00_017E 0x2F00_011E A=4606 0x3000_11FE Table 5-7 UART Baud Rate Setting Table The UART0 and UART1 controllers support auto-flow control function that uses two low-level signals, /CTS (clear-to-send) and /RTS (request-to-send), to control the flow of data transfer between the UART and external devices (ex: Modem). When auto-flow is enabled, the UART is not allowed to receive data until the UART asserts /RTS to external device. When the number of bytes in the RX FIFO equals the value of RTS_TRI_LEV (UA_FCR [19:16]), the /RTS is deasserted. The UART sends data out when UART controller detects /CTS is asserted from external device. If a valid asserted /CTS is not detected the UART controller will not send data out. The UART controllers also provides Serial IrDA (SIR, Serial Infrared) function (User must set IrDA_EN (UA_FUN_SEL [1]) to enable IrDA function). The SIR specification defines a short-range infrared asynchronous serial transmission mode with one start bit, 8 data bits, and 1 stop bit. The maximum data rate is 115.2 Kbps (half duplex). The IrDA SIR block contains an IrDA SIR Protocol encoder/decoder. The IrDA SIR protocol is half-duplex only. So it cannot transmit and receive data at the same time. The IrDA SIR physical layer specifies a minimum 10ms transfer delay between transmission and reception. This delay feature must be implemented by software. For NuMicro™ NUC100/NUC120 Low Density, another alternate function of UART controllers is RS-485 9-bit mode function, and direction control provided by RTS pin or can program GPIO (PB.2 for RTS0 and PB.6 for RTS1) to implement the function by software. The RS-485 mode is selected by setting the UA_FUN_SEL register to select RS-485 function. The RS-485 driver control is implemented using the RTS control signal from an asynchronous serial port to enable the RS-485 driver. In RS-485 mode, many characteristics of the RX and TX are same as UART. - 50 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.12.2 Features z Full duplex, asynchronous communications z Separate receive / transmit 64/16/16 bytes (UART0/UART1/UART2) entry FIFO for data payloads z Support hardware auto flow control/flow control function (CTS, RTS) and programmable RTS flow control trigger level (UART0 and UART1 support) z Programmable receiver buffer trigger level z Support programmable baud-rate generator for each channel individually z Support CTS wake-up function (UART0 and UART1 support) z Support 7-bit receiver buffer time out detection function z UART0/UART1 can be served by the DMA controller z Programmable transmitting data delay time between the last stop and the next start bit by setting UA_TOR [DLY] register z Support break error, frame error, parity error and receive / transmit buffer overflow detect function z Fully programmable serial-interface characteristics z „ Programmable number of data bit, 5-, 6-, 7-, 8-bit character „ Programmable parity bit, even, odd, no parity or stick parity bit generation and detection „ Programmable stop bit, 1, 1.5, or 2 stop bit generation Support IrDA SIR function mode „ z Support for 3-/16-bit duration for normal mode Support RS-485 function mode. (NuMicro™ NUC100/NUC120 Low Density only) „ Support RS-485 9-bit mode „ Support hardware or software direct enable control provided by RTS pin - 51 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.13 PS/2 Device Controller (PS2D) 5.13.1 Overview PS/2 device controller provides basic timing control for PS/2 communication. All communication between the device and the host is managed through the CLK and DATA pins. Unlike PS/2 keyboard or mouse device controller, the received/transmit code needs to be translated as meaningful code by firmware. The device controller generates the CLK signal after receiving a request to send, but host has ultimate control over communication. DATA sent from the host to the device is read on the rising edge and DATA sent from device to the host is change after rising edge. A 16 bytes FIFO is used to reduce CPU intervention. S/W can select 1 to 16 bytes for a continuous transmission. 5.13.2 Features z Host communication inhibit and request to send detection z Reception frame error detection z Programmable 1 to 16 bytes transmit buffer to reduce CPU intervention z Double buffer for data reception z S/W override bus - 52 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.14 I2S Controller (I2S) 5.14.1 Overview The I2S controller consists of IIS protocol to interface with external audio CODEC. Two 8 word deep FIFO for read path and write path respectively and is capable of handling 8 ~ 32 bit word sizes. DMA controller handles the data movement between FIFO and memory. 5.14.2 Features z I2S can operate as either master or slave z Capable of handling 8-, 16-, 24- and 32-bit word sizes z Mono and stereo audio data supported z I2S and MSB justified data format supported z Two 8 word FIFO data buffers are provided, one for transmit and one for receive z Generates interrupt requests when buffer levels cross a programmable boundary z Two DMA requests, one for transmit and one for receive - 53 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.15 Analog-to-Digital Converter (ADC) 5.15.1 Overview NuMicro™ NUC100 Series contains one 12-bit successive approximation analog-to-digital converters (SAR A/D converter) with 8 input channels. The A/D converter supports three operation modes: single, single-cycle scan and continuous scan mode. The A/D converters can be started by software and external STADC pin. 5.15.2 Features z Analog input voltage range: 0~VREF z 12-bit resolution and 10-bit accuracy is guaranteed z Up to 8 single-end analog input channels or 4 differential analog input channels z Maximum ADC clock frequency is 16 MHz z Up to 600K SPS conversion rate z Three operating modes „ Single mode: A/D conversion is performed one time on a specified channel „ Single-cycle scan mode: A/D conversion is performed one cycle on all specified channels with the sequence from the lowest numbered channel to the highest numbered channel „ Continuous scan mode: A/D converter continuously performs Single-cycle scan mode until software stops A/D conversion z An A/D conversion can be started by „ Software write 1 to ADST bit „ External pin STADC z Conversion results are held in data registers for each channel with valid and overrun indicators z Conversion result can be compared with specify value and user can select whether to generate an interrupt when conversion result is equal to the compare register setting z Channel 7 supports 3 input sources: external analog voltage, internal bandgap voltage, and internal temperature sensor output z Support Self-calibration to minimize conversion error - 54 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.16 Analog Comparator (CMP) 5.16.1 Overview NuMicro™ NUC100 Series contains two comparators. The comparators can be used in a number of different configurations. The comparator output is a logical one when positive input greater than negative input, otherwise the output is a zero. Each comparator can be configured to cause an interrupt when the comparator output value changes. The block diagram is shown in Error! Reference source not found.. 5.16.2 Features z Analog input voltage range: 0~5.0 V z Hysteresis function supported z Two analog comparators with optional internal reference voltage input at negative end z One interrupt vector for both comparators - 55 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.17 PDMA Controller (PDMA) 5.17.1 Overview NuMicro™ NUC100/NUC120 Medium Density contains a peripheral direct memory access (PDMA) controller that transfers data to and from memory or transfer data to and from APB devices. The PDMA has nine channels of DMA (Peripheral-to-Memory or Memory-to-Peripheral or Memory-to-Memory). For each PDMA channel (PDMA CH0~CH8), there is one word buffer as transfer buffer between the Peripherals APB devices and Memory. Software can stop the PDMA operation by disable PDMA [PDMACEN]. The CPU can recognize the completion of a PDMA operation by software polling or when it receives an internal PDMA interrupt. The PDMA controller can increase source or destination address or fixed them as well. Notice: NuMicro™ NUC100/NUC120 Low Density only has 1 PDMA channel (channel 0). 5.17.2 Features z Up to nine DMA channels. Each channel can support a unidirectional transfer (NuMicro™ NUC100/NUC120 Low Density only has 1 PDMA channel) z AMBA AHB master/slave interface compatible, for data transfer and register read/write z Support source and destination address increased mode or fixed mode z Hardware channel priority. DMA channel 0 has the highest priority and channel 8 has the lowest priority - 56 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 5.18 External Bus Interface (EBI) 5.18.1 Overview The NuMicro™ NUC100/NUC120 Low Density LQFP-64 package equips an external bus interface (EBI) for external device used. To save the connections between external device and this chip, EBI support address bus and data bus multiplex mode. And, address latch enable (ALE) signal supported differentiate the address and data cycle. 5.18.2 Features External Bus Interface has the following functions: z External devices with max. 64K-byte size (8-bit data width)/128K-byte (16-bit data width) supported z Variable external bus base clock (MCLK) supported z 8-bit or 16-bit data width supported z Variable data access time (tACC), address latch enable time (tALE) and address hold time (tAHD) supported z Address bus and data bus multiplex mode supported to save the address pins z Configurable idle cycle supported for different access condition: Write command finish (W2X), Read-to-Read (R2R) - 57 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 6 6.1 FLASH MEMORY CONTROLLER (FMC) Overview NuMicro™ NUC100 Series equips with 128/64/32K bytes on chip embedded Flash for application program memory (APROM) that can be updated through ISP procedure. In System Programming (ISP) function enables user to update program memory when chip is soldered on PCB. After chip power on, Cortex-M0 CPU fetches code from APROM or LDROM decided by boot select (CBS) in Config0. By the way, NuMicro™ NUC100 Series also provides additional DATA Flash for user, to store some application dependent data before chip power off. For 128K bytes APROM device, the data flash is shared with original 128K program memory and its start address is configurable and defined by user application request in Config1. For 64K/32K bytes APROM device, the data flash is fixed at 4K. 6.2 Features z Run up to 50 MHz with zero wait state for continuous address read access z 128/64/32KB application program memory (APROM) (NuMicro™ NUC100/NUC120 Low Density only support up to 64KB size) z 4KB in system programming (ISP) loader program memory (LDROM) z Configurable or fixed 4KB data flash with 512 bytes page erase unit z Programmable data flash start address for 128K APROM device z In System Program (ISP) to update on chip Flash - 58 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 7 7.1 ELECTRICAL CHARACTERISTICS Absolute Maximum Ratings SYMBOL PARAMETER MIN MAX UNIT VDD−VSS -0.3 +7.0 V VIN VSS-0.3 VDD+0.3 V 1/tCLCL 4 24 MHz TA -40 +85 °C TST -55 +150 °C - 120 mA Maximum Current out of VSS 120 mA Maximum Current sunk by a I/O pin 35 mA Maximum Current sourced by a I/O pin 35 mA Maximum Current sunk by total I/O pins 100 mA Maximum Current sourced by total I/O pins 100 mA DC Power Supply Input Voltage Oscillator Frequency Operating Temperature Storage Temperature Maximum Current into VDD Note: Exposure to conditions beyond those listed under absolute maximum ratings may adversely affects the lift and reliability of the device. - 59 - Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet 7.2 DC Electrical Characteristics 7.2.1 NuMicro™ NUC100/NUC120 Medium Density DC Electrical Characteristics (VDD-VSS=3.3 V, TA = 25°C, FOSC = 50 MHz unless otherwise specified.) SPECIFICATION PARAMETER SYM. TEST CONDITIONS MIN. Operation voltage Power Ground VDD VSS AVSS 2.5 MAX. UNIT 5.5 V -0.3 LDO Output Voltage VLDO -10% Analog Operating Voltage AVDD Analog Reference Voltage Vref IDD1 TYP. VDD =2.5 V ~ 5.5 V up to 50 MHz V 2.5 +10% V 0 VDD V 0 AVDD V 54 VDD > 2.7 V VDD = 5.5 V@50 MHz, mA enable all IP and PLL, XTAL=12 MHz VDD = 5.5 V@ 50 MHz, Operating Current IDD2 31 IDD3 51 Normal Run Mode @ 50 MHz mA disable all IP and enable PLL, XTAL=12 MHz VDD = 3 V@50 MHz, mA enable all IP and PLL, XTAL=12 MHz VDD = 3 V@50 MHz, IDD4 28 IDD5 22 Operating Current Normal Run Mode @ 12 MHz mA disable all IP and enable PLL, XTAL=12 MHz VDD = 5.5 V@12 MHz, mA enable all IP and disable PLL, XTAL=12 MHz VDD = 5.5 V@12 MHz, IDD6 14 IDD7 20 - 60 - mA disable all IP and disable PLL, XTAL=12 MHz VDD = 3 V@12MHz, mA enable all IP and disable PLL, XTAL=12 MHz Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet SPECIFICATION PARAMETER SYM. TEST CONDITIONS MIN. IDD8 TYP. 12 MAX. UNIT VDD = 3 V@12 MHz, mA disable all IP and disable PLL, XTAL=12 MHz VDD = 5 V@4 MHz, Operating Current IDD9 15 IDD10 11 Normal Run Mode @ 4 MHz Operating Current IDD11 13 IDD12 9 VDD = 3 V@4 MHz, mA disable all IP and disable PLL, XTAL=4 MHz IIDLE1 38 VDD= 5.5 V@50 MHz, mA enable all IP and PLL, XTAL=12 MHz IIDLE2 15 VDD=5.5 V@50 MHz, mA disable all IP and enable PLL, XTAL=12 MHz IIDLE3 35 VDD = 3 V@50 MHz, mA enable all IP and PLL, XTAL=12 MHz IIDLE4 13 VDD = 3 V@50 MHz, mA disable all IP and enable PLL, XTAL=12 MHz IIDLE5 13 VDD = 5.5 V@12 MHz, mA enable all IP and disable PLL, XTAL=12 MHz IIDLE6 5.5 VDD = 5.5 V@12 MHz, mA disable all IP and disable PLL, XTAL=12 MHz IIDLE7 12 VDD = 3 V@12 MHz, mA enable all IP and disable PLL, XTAL=12 MHz Operating Current Idle Mode VDD = 5 V@4 MHz, mA disable all IP and disable PLL, XTAL=4 MHz VDD = 3 V@4 MHz, Idle Mode @ 50 MHz mA enable all IP and disable PLL, XTAL=4 MHz @ 12 MHz - 61 - mA enable all IP and disable PLL, XTAL=4 MHz Publication Release Date: Jan. 2, 2012 Revision V2.03 NuMicro™ NUC120 Data Sheet SPECIFICATION PARAMETER SYM. TEST CONDITIONS MIN. IIDLE8 TYP. MAX. UNIT VDD = 3 V@12 MHz, mA disable all IP and disable PLL, XTAL=12 MHz 4 VDD = 5 V@4 MHz, Operating Current IIDLE9 8.5 IIDLE10 3.5 mA enable all IP and disable PLL, XTAL=4 MHz VDD = 5 V@4 MHz, mA disable all IP and disable PLL, XTAL=4 MHz Idle Mode @ 4 MHz VDD = 3 V@4 MHz, IIDLE11 7 IIDLE12 2.5 VDD = 3 V@4 MHz, mA disable all IP and disable PLL, XTAL=4 MHz IPWD1 23 μA VDD = 5.5 V, RTC OFF, No load @ Disable BOV function IPWD2 18 μA VDD = 3.3 V, RTC OFF, No load @ Disable BOV function IPWD3 28 μA VDD = 5.5 V, RTC run , No load @ Disable BOV function IPWD4 22 μA VDD = 3.3 V, RTC run , No load @ Disable BOV function Input Current PA, PB, PC, PD, PE (Quasi-bidirectional mode) IIN1 -50 -60 μA VDD = 5.5 V, VIN = 0 V or VIN=VDD Input Current at /RESET[1] IIN2 -55 -45 -30 μA VDD = 3.3 V, VIN = 0.45 V Input Leakage Current PA, PB, PC, PD, PE ILK -2 - +2 μA VDD = 5.5 V, 0
NUC120LE3AN 价格&库存
很抱歉,暂时无法提供与“NUC120LE3AN”相匹配的价格&库存,您可以联系我们找货
