AT45DB041E-SSHNHT-B
AT45DB041E-SSHNHT-B
    DIALOGSEMICONDUCTOR(戴乐格)
    SOIC8_150MIL
    ICFLASH4MBIT85MHZ8SOIC
AT45DB041E-SSHNHT-B 数据手册
AT45DB041E 4-Mbit, 1.65V Minimum SPI DataFlash® Memory DATASHEET (ADDENDUM) High Temperature Operation (125°C)  This data sheet addendum is to be used in conjunction with the existing AT45DB041E datasheet specifications. The Adesto AT45DB041E 4Mbit DataFlash devices will operate @ 125°C with the following datasheet caveats. All other parameters will meet the existing datasheet specifications. The ordering code suffix (CAN# Code) 'HT' must be used to ensure correct operation at this extended temperature range. Adesto will not modify and republish the current datasheet to reflect the CAN# 'HT' ordering code or the above caveats.The standard AT45DB041E datasheet is available at http://www.adestotech.com. 1. Electrical Specifications 1.1 DC and AC Operating Range AT45DB041E-xxxHT Operating Temperature -40C to +125C Endurance (Maximum) 10,000 Cycles 1.2 DC Characteristics 1.65V to 3.6V Symbol Parameter Condition IDPD Deep Power-Down Current ISB ICC3 Min 2.3V to 3.6V Typ Max CS, RESET, WP = VIH All inputs at CMOS levels 4.5 Standby Current CS, RESET, WP = VIH All inputs at CMOS levels Active Current,  Program Operation CS=VCC Min Typ Max Units 20 5 20 µA 25 45 25 45 µA 14 20 14 20 mA AT45DB041E (Addendum)–024C–8/2017 1.3 AC Characteristics 1.65V to 3.6V Symbol Parameter fCAR1 SCK Frequency for Continuous Read (0x0B) fCAR2 SCK Frequency for Continuous Read (0x03) (Low Frequency) tCS Minimum CS High Time tV Output Valid 1.4 Min Max Units 70 70 MHz 33 33 MHz 24 Min 24 ns 8 6 ns Program and Erase Characteristics 1.65V to 3.6V 2.3V to 3.6V Symbol Parameter Typ Max Typ Max Units tBE Block Erase Time 30 50 30 50 ms tSE Sector Erase Time .7 1.3 .7 1.3 s Notes: 1. 2. Values are based on device characterization, not 100% tested in production. Not 100% tested (value guaranteed by design and characterization). 2. Ordering Code 2.1 Ordering Code Detail Ordering Code (1) AT45DB041E-SHNHT-T AT45DB041E-SHNHT-B AT45DB041E-SSHNHT-T AT45DB041E-SSHNHT-B 1. Max 2.3V to 3.6V Package Operating Voltage Max. Freq. (MHz) 1.65V to 3.6V 85MHz Operation Range 8S2 Extended (-40°C to +125°C) 8S1 The shipping carrier option code is not marked on the devices. Package Type 8S1 8-lead, 0.150" Wide, Plastic Gull Wing Small Outline Package (JEDEC SOIC) 8S2 8-lead, 0.208" Wide, Plastic Gull Wing Small Outline Package (EIAJ SOIC) AT45DB041E (Addendum) DS-45DB041E–024C–8/2017 2 1. Revision History Revision Level – Release Date History A – January 2015 Initial release. B – October 2015 Corrected package type in Ordering Code Detail table. C – August 2017 Updated corporate address information. Corporate Office California | USA Adesto Headquarters 3600 Peterson Way Santa Clara, CA 95054 Phone: (+1) 408.400.0578 Email: contact@adestotech.com © 2017 Adesto Technologies. All rights reserved. / Rev.: DS-45DB041E–024C–8/2017 Disclaimer: Adesto Technologies Corporation makes no warranty for the use of its products, other than those expressly contained in the Company's standard warranty which is detailed in Adesto's Terms and Conditions located on the Company's web site. The Company assumes no responsibility for any errors which may appear in this document, reserves the right to change devices or specifications detailed herein at any time without notice, and does not make any commitment to update the information contained herein. No licenses to patents or other intellectual property of Adesto are granted by the Company in connection with the sale of Adesto products, expressly or by implication. Adesto's products are not authorized for use as critical components in life support devices or systems.
AT45DB041E-SSHNHT-B 价格&库存
很抱歉,暂时无法提供与“AT45DB041E-SSHNHT-B”相匹配的价格&库存,您可以联系我们找货
