KRL2012E-M-R220-F-T5
    SUSUMU
    贴片电阻 0508 220mΩ ±1% 1W ±50ppm/℃
KRL2012E-M-R220-F-T5 数据手册
Metal foil low resistance chip resistors (long-side terminal) ■KRL series AEC-Q200 Compliant Features ・ High current sensing long side terminal low resistance chip resistor ・ Two types available: high temperature (operating temperature up to 175°C), low emf type (operating temperature up to 155°C) ・ High current handling capability and wide range of power ratings ・ Size: 1608 ~ 15075, power ratings: 0.5W ~ 10W, resistance value range: 1m ~ 500mΩ ・ Face down construction. Choice between bottom only or wrap around terminal. KRL series Current sensing surface mount resistors Applications ・ Automotive electronics ・ Power source devises, ACDC converters, DCDC converters ・ Motors, inverters, office automation equipment ◆Part numbering system KRL 2012E - C - R010 - F - T1 Series code Packaging quantity:T05(500pcs) T1(1,000pcs), T5(5,000pcs) Resistance tolerance Size: KRL1608, KRL2012, KRL3216, KRL5025 KRL6432, KRL7638, KRL9045, KRL11050 KRL15075 Nominal resistance value Temperature characteristics type: C (high operating temperature), M (low EMF) Terminal type: D (bottom terminal), E (wrap around terminal) ◆Electrical Specification Power ratings Type KRL1608 *2 0.5W KRL2012 1W KRL3216 1.5W KRL5025 2W KRL6432 3W KRL7638 4W KRL9045 5W KRL11050 6W KRL15075 10W Temperature coefficient of resistance (ppm/°C) ±1% (F) ±2% (G) ±5% (J) ±50 ±100 ー 5m≦R≦9m ー ー ー ー R=2m ー ー R=1m ー ー R=2m ー ー R=1m ー ー R=2m ー ー R=1m ー ー R=2m ー ー R=1m ー ー R=2m ー ー R=1m ー ー R=2m ー ー R=1m ー ー ±100 ±150 10m≦R≦100m ー 3m≦R≦9m (1m step) 10m≦R≦500m ー ー 3m≦R≦9m (1m step) 10m≦R≦500m ー ー 3m≦R≦9m (1m step) 10m≦R≦500m ー ー 3m≦R≦9m (1m step) 10m≦R≦500m ー ー 3m≦R≦9m (1m step) 10m≦R≦500m ー ー 3m≦R≦9m (1m step) 10m≦R≦500m ー ー 3m≦R≦9m (1m step) 10m≦R≦500m ー ー R=2m ー ー R=1m ±50 10m≦R≦500m ー ー ±100 3m≦R≦9m (1m step) ー R=2m R=1m ー ー ±50 ±100 ±150 ±50 ±100 ±150 ±50 ±100 ±150 ±50 ±100 ±150 ±50 ±100 ±150 ±50 ±100 ±150 ±50 ±150 *1 *2 *3 *1 Resistance range(Ω) Resistance tolerance We can meet your requirement of less than 1mΩ. Please contact our sales office. For KRL1608, please contact our sales office We can meet your requirement of resistance value outside of E-6 series. Please contact our sales office. 49 Resistance value series Operating temperature C Packaging quantity M T5 T1 T5 E-6 *3 -55℃ ~ 175℃ -55℃ ~ 155℃ T1 T05 T1 ◆Dimensions L t a a Size Type (inch) *1 W D Type L t a a W L W t a KRL1608 0603 0.80±0.20 1.60±0.20 0.50±0.20 0.25±0.20(5mΩ∼) KRL2012 0805 1.25±0.20 2.00±0.20 0.50±0.20 0.30±0.20(2mΩ∼)/0.55±0.20(1mΩ) KRL3216 1206 1.60±0.20 3.20±0.20 0.50±0.20 0.30±0.20(2mΩ∼)/0.55±0.20(1mΩ) KRL5025 2010 2.50±0.20 5.00±0.20 0.50±0.20 0.55±0.20(2mΩ∼)/0.90±0.20(1mΩ) KRL6432 2512 3.10±0.20 6.30±0.20 0.50±0.20 0.50±0.20(2mΩ∼)/1.20±0.20(1mΩ) KRL7638 3015 3.80±0.20 7.60±0.20 0.50±0.20 0.60±0.20(2mΩ∼)/1.35±0.20(1mΩ) KRL9045 3518 4.50±0.20 9.00±0.20 0.50±0.20 0.70±0.20(2mΩ∼)/1.60±0.20(1mΩ) KRL11050 4320 5.00±0.20 11.00±0.20 0.50±0.20 0.80±0.20(2mΩ∼)/1.60±0.20(1mΩ) KRL15075 5930 7.50±0.20 15.00±0.20 0.65±0.20 1.10±0.20(2mΩ∼)/2.75±0.20(1mΩ) *1 KRL1608 doesn't have E Type (unit:mm) Current sensing surface mount resistors E Type Ratio to rated power (%) KRL series ◆Derating Curve C(high operating temperature) M(low EMF) 100 50 0 -55     0     50  100 120 155 175 Ambient temperature (℃) 50
KRL2012E-M-R220-F-T5 价格&库存
很抱歉,暂时无法提供与“KRL2012E-M-R220-F-T5”相匹配的价格&库存,您可以联系我们找货
  • 5000+1.394735000+0.18027
  • 10000+1.3007010000+0.16812
  • 15000+1.2524015000+0.16188
  • 25000+1.1977825000+0.15482
  • 35000+1.1652335000+0.15061
  • 50000+1.1334450000+0.14650
库存:49277
  • 1+5.365361+0.69347
  • 10+3.4598110+0.44718
  • 25+2.9403025+0.38004
  • 50+2.6147650+0.33796
  • 100+2.33745100+0.30212
  • 250+2.03403250+0.26290
  • 500+1.84388500+0.23832
  • 1000+1.682431000+0.21746
库存:49277
