MR0A08BMA35R
MR0A08BMA35R
    EVERSPINTECHNOLOGIESINC.
    LFBGA48
MR0A08BMA35R 数据手册
MR0A08B FEATURES • • • • • • • • • 128K x 8 MRAM 3.3 Volt power supply Fast 35 ns read/write cycle SRAM compatible timing Native non-volatility Unlimited read & write endurance Data always non-volatile for >20 years at temperature Commercial and industrial temperatures All products meet MSL-3 moisture sensitivity level RoHS-Compliant TSOP2 and BGA packages BENEFITS • One memory replaces FLASH, SRAM, EEPROM and MRAM in system for simpler, more efficient design • Improves reliability by replacing battery-backed SRAM 48-ball FBGA 44-pin TSOP2 INTRODUCTION The MR0A08B is a 1,048,576-bit magnetoresistive random access memory (MRAM) device organized as 131,072 words of 8 bits. The MR0A08B offers SRAM compatible 35 ns read/write timing with unlimited endurance. Data is always non-volatile for greater than 20-years. Data is automatically protected on power loss by low-voltage inhibit circuitry to prevent writes with voltage out of specification. The MR0A08B is the ideal memory solution for applications that must permanently store and retrieve critical data and programs quickly. The MR0A08B is available in small footprint 400-mil, 44-lead plastic small-outline TSOP type-2 package, 8 mm x 8 mm, or a 48-pin ball grid array (BGA) package with 0.75 mm ball centers. (The 32-SOIC package options is obsolete and no longer available for new orders.) These packages are compatible with similar low-power SRAM products and other non-volatile RAM products. The MR0A08B provides highly reliable data storage over a wide range of temperatures. The product is offered with commercial temperature range (0 to +70 °C) and industrial temperature range (-40 to +85 °C). RoHS Copyright © 2018 Everspin Technologies 1 MR0A08B Rev. 8.6, 3/2018 MR0A08B TABLE OF CONTENTS FEATURES..............................................................................................................................................1 BENEFITS................................................................................................................................................1 INTRODUCTION....................................................................................................................................1 BLOCK DIAGRAM AND PIN ASSIGNMENTS........................................................................................4 Figure 1 – MR0A08B Block Diagram....................................................................................................................... 4 Table 1 – Pin Functions................................................................................................................................................ 4 Figure 2 – Pin Diagrams for Available Packages (Top View) 1....................................................................... 5 OPERATING MODES..............................................................................................................................5 Table 2 – Operating Modes........................................................................................................................................ 5 ELECTRICAL SPECIFICATIONS.............................................................................................................6 Table 3 – Absolute Maximum Ratings.................................................................................................................... 6 OPERATING CONDITIONS....................................................................................................................7 Table 4 – Operating Conditions................................................................................................................................ 7 Power Up and Power Down Sequencing........................................................................................8 Figure 3 – Power Up and Power Down Diagram................................................................................................ 8 DC CHARACTERISTICS..........................................................................................................................9 Table 5 – DC Characteristics....................................................................................................................................... 9 Table 6 – Power Supply Characteristics................................................................................................................. 9 TIMING SPECIFICATIONS.................................................................................................................. 10 Table 7 – Capacitance................................................................................................................................................10 Table 8 – AC Measurement Conditions...............................................................................................................10 Figure 4 – Output Load Test Low and High........................................................................................................10 Figure 5 – Output Load Test All Others................................................................................................................10 Copyright © 2018 Everspin Technologies 2 MR0A08B Rev. 8.6, 3/2018 MR0A08B TABLE OF CONTENTS (CONT’D) Read Mode..................................................................................................................................... 11 Table 9 – Read Cycle Timing....................................................................................................................................11 Figure 6 – Read Cycle 1..............................................................................................................................................12 Figure 7 – Read Cycle 2..............................................................................................................................................12 Write Mode..................................................................................................................................... 13 Table 10 – Write Cycle Timing 1 ( W Controlled )..............................................................................................13 Figure 8 – Write Cycle Timing 1 (W Controlled)................................................................................................14 Table 11 – Write Cycle Timing 2 (E Controlled).................................................................................................15 Figure 9 – Write Cycle Timing 2 (E Controlled).................................................................................................16 Table 12 – Write Cycle Timing 3 (Shortened tWHAX, W and E Controlled)..............................................17 Figure 10 – Write Cycle Timing 3 (Shortened tWHAX, W and E Controlled)............................................17 ORDERING INFORMATION................................................................................................................ 18 Table 13 – Ordering Part Number System for Parallel I/O MRAM..............................................................18 Table 14 – MR0A08B Ordering Part Numbers 1................................................................................................18 PACKAGE OUTLINE DRAWINGS........................................................................................................ 19 Figure 11 – 44-TSOP2 Package Outline...............................................................................................................19 Figure 12 – 48-BGA Package Outline....................................................................................................................20 Figure 13 – 32-SOIC Package Outline 1...............................................................................................................21 REVISION HISTORY............................................................................................................................ 22 HOW TO CONTACT US........................................................................................................................ 23 Copyright © 2018 Everspin Technologies 3 MR0A08B Rev. 8.6, 3/2018 MR0A08B BLOCK DIAGRAM AND PIN ASSIGNMENTS Figure 1 – MR0A08B Block Diagram G A[16:0] 17 E W OUTPUT ENABLE BUFFER OUTPUT ENABLE ADDRESS BUFFER 7 10 ROW DECODER CHIP ENABLE BUFFER COLUMN DECODER 8 SENSE AMPS 128k x 8 BIT MEMORY ARRAY WRITE ENABLE BUFFER 8 FINAL WRITE DRIVERS 8 OUTPUT BUFFER 8 WRITE DRIVER 8 8 DQ[7:0] WRITE ENABLE Table 1 – Pin Functions Signal Name Function A Address Input E Chip Enable W Write Enable G Output Enable DQ Data I/O VDD Power Supply VSS Ground DC Do Not Connect NC No Connection - Pin 2, 40, 41,43 (TSOP2); Ball C2, C5, D3, F2, F5, G1, G2, G6, H1, H6 (BGA); Pin 30 (SOIC) Reserved For Future Expansion Copyright © 2018 Everspin Technologies 4 MR0A08B Rev. 8.6, 3/2018 MR0A08B Figure 2 – Pin Diagrams for Available Packages (Top View) 1 DC NC A0 A1 A2 A3 A4 E DQ0 DQ1 VDD VSS DQ2 DQ3 W A5 A6 A7 A8 A9 DC DC 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 DC DC 1 32 VDD NC DC NC NC A16 A15 G DQ7 A16 2 31 A15 A14 3 30 NC A12 4 29 W A7 5 28 A13 A6 6 27 A8 A5 7 26 A9 DQ6 VSS A4 8 25 A11 VDD DQ5 DQ4 DC A3 9 24 G A2 10 23 A10 A1 11 22 E A14 A13 A12 A0 12 21 DQ7 DQ0 13 20 DQ6 DQ1 14 19 DQ5 DQ2 15 18 DQ4 VSS 16 17 DQ3 A11 A10 DC DC 1 2 3 4 5 6 DC G A0 A1 A2 DC A NC DC A3 A4 E DC B DQ0 NC A5 A6 NC DQ4 C VSS DQ1 NC A7 DQ5 VDD D VDD DQ2 DC A16 DQ6 VSS E DQ3 NC A14 A15 NC DQ7 F NC NC A12 A13 W NC G NC A8 A9 A10 A11 NC H 32 Pin SOIC 1 44 Pin TSOP2 48 Pin FBGA Note: 1. The 32-SOIC package is obsolete and shown for legacy reference only. This package option is no longer available for new orders. OPERATING MODES Table 2 – Operating Modes E1 G1 W1 Mode VDD Current DQ[7:0] 2 H X X Not selected ISB1, ISB2 Hi-Z L H H Output disabled IDDR Hi-Z L L H Byte Read IDDR DOut L X L Byte Write IDDW Din Notes: 1. H = high, L = low, X = don’t care 2. Hi-Z = high impedance Copyright © 2018 Everspin Technologies 5 MR0A08B Rev. 8.6, 3/2018 MR0A08B ELECTRICAL SPECIFICATIONS Absolute Maximum Ratings This device contains circuitry to protect the inputs against damage caused by high static voltages or electric fields; however, it is advised that normal precautions be taken to avoid application of any voltage greater than maximum rated voltages to these high-impedance (Hi-Z) circuits. The device also contains protection against external magnetic fields. Precautions should be taken o avoid application of any magnetic field more intense than the maximum field intensity specified in the maximum ratings. 1 Table 3 – Absolute Maximum Ratings Parameter Symbol Value Unit Supply voltage 2,3 VDD -0.5 to 4.0 V Voltage on any pin 2,3 VIN -0.5 to VDD + 0.5 V Output current per pin IOUT ±20 mA PD 0.600 W Package power dissipation 3 Temperature under bias MR0A08B (Commercial) MR0A08BC (Industrial) Storage Temperature TBIAS -10 to 85 -45 to 95 °C Tstg -55 to 150 °C TLead 260 °C Maximum magnetic field during write MR0A08B (All Temperatures) Hmax_write 2000 A/m Maximum magnetic field during read or standby Hmax_read 8000 A/m Lead temperature during solder (3 minute max) Notes: 1. Permanent device damage may occur if absolute maximum ratings are exceeded. Functional operation should be restricted to recommended operating conditions. Exposure to excessive voltages or magnetic fields could affect device reliability. 2. All voltages are referenced to VSS. 3. Power dissipation capability depends on package characteristics and use environment. Copyright © 2018 Everspin Technologies 6 MR0A08B Rev. 8.6, 3/2018 MR0A08B OPERATING CONDITIONS Table 4 – Operating Conditions Parameter Min 3.0 1 Typical Max Unit Power supply voltage Symbol VDD 3.3 3.6 V Write inhibit voltage VWI 2.5 2.7 3.0 1 V Input high voltage VIH 2.2 - VDD + 0.3 2 V Input low voltage VIL -0.5 3 - 0.8 V TA 0 70 °C -40 85 Temperature under bias MR0A08B (Commercial) MR0A08BC (Industrial) Notes: 1. There is a 2 ms startup time once VDD exceeds VDD,(max). See “Figure 3 – Power Up and Power Down Diagram” . 2. VIH(max) = VDD + 0.3 VDC ; VIH(max) = VDD + 2.0 VAC (pulse width ≤ 10 ns) for I ≤ 20.0 mA. 3. VIL(min) = -0.5 VDC ; VIL(min) = -2.0 VAC (pulse width ≤ 10 ns) for I ≤ 20.0 mA. Copyright © 2018 Everspin Technologies 7 MR0A08B Rev. 8.6, 3/2018 MR0A08B Power Up and Power Down Sequencing The MRAM is protected from write operations whenever VDD is less than VWI. As soon as VDD exceeds VDD(min), there is a startup time of 2 ms before read or write operations can start. This time allows memory power supplies to stabilize. The E and W control signals should track VDD on power up to VDD- 0.2 V or VIH (whichever is lower) and remain high for the startup time. In most systems, this means that these signals should be pulled up with a resistor so that signal remains high if the driving signal is Hi-Z during power up. Any logic that drives E and W should hold the signals high with a power-on reset signal for longer than the startup time. During power loss or brownout where VDD goes below VWI, writes are protected and a startup time must be observed when power returns above VDD(min). Figure 3 – Power Up and Power Down Diagram VWI VDD BROWNOUT or POWER LOSS 2 ms STARTUP READ/WRITE INHIBITED 2 ms RECOVER NORMAL OPERATION READ/WRITE INHIBITED NORMAL OPERATION VIH VIH E W Copyright © 2018 Everspin Technologies 8 MR0A08B Rev. 8.6, 3/2018 MR0A08B DC CHARACTERISTICS Table 5 – DC Characteristics Parameter Symbol Min Typical Max Unit Input leakage current Ilkg(I) - - ±1 μA Output leakage current Ilkg(O) - - ±1 μA VOL - - 0.4 V VOH 2.4 - Output low voltage (IOL = +4 mA) (IOL = +100 μA) VSS + 0.2 Output high voltage (IOL = -4 mA) (IOL = -100 μA) - V VDD - 0.2 Table 6 – Power Supply Characteristics Parameter AC active supply current - read modes 1 (IOUT= 0 mA, VDD= max) Symbol Typical Max Unit IDDR 25 30 mA 55 65 55 70 ISB1 6 7 mA ISB2 5 6 mA AC active supply current - write modes 1 (VDD= max) MR0A08B (Commercial) MR0A08BC (Industrial) IDDW mA AC standby current (VDD= max, E = VIH) no other restrictions on other inputs CMOS standby current ( E ≥ VDD - 0.2 V and VIn ≤ VSS + 0.2 V or ≥ VDD - 0.2 V ) ( VDD = max, f = 0 MHz ) Notes: 1. All active current measurements are measured with one address transition per cycle and at minimum cycle time. Copyright © 2018 Everspin Technologies 9 MR0A08B Rev. 8.6, 3/2018 MR0A08B TIMING SPECIFICATIONS Table 7 – Capacitance Parameter 1 Symbol Typical Max Unit Address input capacitance CIn - 6 pF Control input capacitance CIn - 6 pF Input/Output capacitance CI/O - 8 pF Notes: 1. f = 1.0 MHz, dV = 3.0 V, TA = 25 °C, periodically sampled rather than 100% tested. Table 8 – AC Measurement Conditions Parameter Value Unit Logic input timing measurement reference level 1.5 V Logic output timing measurement reference level 1.5 V 0 or 3.0 V 2 ns Logic input pulse levels Input rise/fall time Output load for low and high impedance parameters See Figure 4 Output load for all other timing parameters See Figure 5 Figure 4 – Output Load Test Low and High ZD= 50 Ω Output RL = 50 Ω VL = 1.5 V Figure 5 – Output Load Test All Others 3.3 V 590 Ω Output 5 pF 435 Ω Copyright © 2018 Everspin Technologies 10 MR0A08B Rev. 8.6, 3/2018 MR0A08B Read Mode Table 9 – Read Cycle Timing Parameter 1 Symbol Min Max Unit Read cycle time tAVAV 35 - ns Address access time tAVQV - 35 ns Enable access time 2 tELQV - 35 ns Output enable access time tGLQV - 15 ns Output hold from address change tAXQX 3 - ns Enable low to output active 3 tELQX 3 - ns Output enable low to output active 3 tGLQX 0 - ns Enable high to output Hi-Z 3 tEHQZ 0 15 ns Output enable high to output Hi-Z 3 tGHQZ 0 10 ns Notes: 1. W is high for read cycle. Power supplies must be properly grounded and decoupled, and bus contention conditions must be minimized or eliminated during read or write cycles. 2. Addresses valid before or at the same time E goes low. 3. This parameter is sampled and not 100% tested. Transition is measured ±200 mV from the steady-state voltage. Copyright © 2018 Everspin Technologies 11 MR0A08B Rev. 8.6, 3/2018 MR0A08B Figure 6 – Read Cycle 1 t AVAV A (ADDRESS) t AXQX Q (DATA OUT) Previous Data Valid Data Valid t AVQV Note: Device is continuously selected (E≤VIL, G≤VIL). Figure 7 – Read Cycle 2 t AVAV A (ADDRESS) t AVQV E (CHIP ENABLE) t ELQV t EHQZ t ELQX G (OUTPUT ENABLE) Q (DATA OUT) Copyright © 2018 Everspin Technologies t GHQZ t GLQV t GLQX Data Valid 12 MR0A08B Rev. 8.6, 3/2018 MR0A08B Write Mode Table 10 – Write Cycle Timing 1 ( W Controlled ) Parameter 1 Symbol Min Max Unit Write cycle time 2 tAVAV 35 - ns Address set-up time tAVWL 0 - ns Address valid to end of write (G high) tAVWH 18 - ns Address valid to end of write (G low) tAVWH 20 - ns Write pulse width (G high) tWLWH tWLEH 15 - ns Write pulse width (G low) tWLWH tWLEH 15 - ns Data valid to end of write tDVWH 10 - ns Data hold time tWHDX 0 - ns Write low to data Hi-Z 3 tWLQZ 0 12 ns Write high to output active 3 tWHQX 3 - ns Write recovery time tWHAX 12 - ns Notes: 1. All write occurs during the overlap of E low and W low. Power supplies must be properly grounded and decoupled and bus contention conditions must be minimized or eliminated during read and write cycles. If G goes low at the same time or after W goes low, the output will remain in a high impedance state. After W or E has been brought high, the signal must remain in steady-state high for a minimum of 2 ns. The minimum time between E being asserted low in one cycle to E being asserted low in a subsequent cycle is the same as the minimum cycle time allowed for the device. 2. All write cycle timings are referenced from the last valid address to the first transition address. 3. This parameter is sampled and not 100% tested. Transition is measured ±200 mV from the steady-state voltage. At any given voltage or temperate, tWLQZ(max) < tWHQX(min) Copyright © 2018 Everspin Technologies 13 MR0A08B Rev. 8.6, 3/2018 MR0A08B Figure 8 – Write Cycle Timing 1 (W Controlled) t AVAV A (ADDRESS) t AVWH t WHAX E (CHIP ENABLE) t WLEH t WLWH W (WRITE ENABLE) t AVWL t DVWH D (DATA IN) t WHDX DATA VALID t WLQZ Q (DATA OUT) Hi -Z Hi -Z t WHQX Copyright © 2018 Everspin Technologies 14 MR0A08B Rev. 8.6, 3/2018 MR0A08B Table 11 – Write Cycle Timing 2 (E Controlled) Parameter 1 Symbol Min Max Unit Write cycle time 2 tAVAV 35 - ns Address set-up time tAVEL 0 - ns Address valid to end of write (G high) tAVEH 18 - ns Address valid to end of write (G low) tAVEH 20 - ns Enable to end of write (G high) tELEH tELWH 15 - ns Enable to end of write (G low) 3 tELEH tELWH 15 - ns Data valid to end of write tDVEH 10 - ns Data hold time tEHDX 0 - ns Write recovery time tEHAX 12 - ns Notes: 1. All write occurs during the overlap of E low and W low. Power supplies must be properly grounded and decoupled and bus contention conditions must be minimized or eliminated during read and write cycles. If G goes low at the same time or after W goes low, the output will remain in a high impedance state. After W or E has been brought high, the signal must remain in steady-state high for a minimum of 2 ns. The minimum time between E being asserted low in one cycle to E being asserted low in a subsequent cycle is the same as the minimum cycle time allowed for the device. 2. All write cycle timings are referenced from the last valid address to the first transition address. 3. If E goes low at the same time or after W goes low, the output will remain in a high-impedance state. If E goes high at the same time or before W goes high, the output will remain in a high-impedance state. Copyright © 2018 Everspin Technologies 15 MR0A08B Rev. 8.6, 3/2018 MR0A08B Figure 9 – Write Cycle Timing 2 (E Controlled) t AVAV A (ADDRESS) t EHAX t AVEH t ELEH E (CHIP ENABLE) t AVEL t ELWH W (WRITE ENABLE) t DVEH D (DATA IN) Data Valid Hi-Z Q (DATA OUT) Copyright © 2018 Everspin Technologies t EHDX 16 MR0A08B Rev. 8.6, 3/2018 MR0A08B Table 12 – Write Cycle Timing 3 (Shortened tWHAX, W and E Controlled) Parameter 1 Min Max Unit Write cycle time 2 Symbol tAVAV 35 - ns Address set-up time tAVWL 0 - ns Address valid to end of write (G high) tAVWH tAVWH 18 - ns 20 - ns Address valid to end of write (G low) Write pulse width tWLWH tWLEH 15 - ns Data valid to end of write tDVWH 10 - ns Data hold time tWHDX 0 - ns Enable recovery time tEHAX -2 - ns Write recovery time 3 tWHAX 6 - ns Write to enable recovery time 3 tWHEL 12 - ns Notes: 1. All write occurs during the overlap of E low and W low. Power supplies must be properly grounded and decoupled and bus contention conditions must be minimized or eliminated during read and write cycles. If G goes low at the same time or after W goes low, the output will remain in a high impedance state. After W, or E has been brought high, the signal must remain in steady-state high for a minimum of 2 ns. The minimum time between E being asserted low in one cycle to E being asserted low in a subsequent cycle is the same as the minimum cycle time allowed for the device. 2. All write cycle timings are referenced from the last valid address to the first transition address. 3. If E goes low at the same time or after W goes low the output will remain in a high impedance state. If E goes high at the same time or before W goes high the output will remain in a high impedance state. E must be brought high each cycle. Figure 10 – Write Cycle Timing 3 (Shortened tWHAX, W and E Controlled) t AVAV A (ADDRESS) t WHAX t AVWH E (CHIP ENABLE) t EHAX t WLEH W (WRITE ENABLE) t WHEL t WLWH t AVWL t DVWH t WHDX D (DATA IN) Copyright © 2018 Everspin Technologies 17 MR0A08B Rev. 8.6, 3/2018 MR0A08B ORDERING INFORMATION Table 13 – Ordering Part Number System for Parallel I/O MRAM MRAM 256 Kb 1 Mb 4 Mb 16 Mb Example Ordering Part Number MR 256 0 2 4 Memory Density MR 0 Type A I/O Width 08 Rev. B Temp Package Speed C MA 35 Packing R Grade A Async 3.3v Async 3.3v Vdd and 1.8v Vddq D Async 3.3v Vdd and 1.8v Vddq with 2.7v min. Vdd DL 8-bit 16-bit Rev A Rev B Commercial 0 to 70°C Industrial -40 to 85°C Extended -40 to 105°C AEC Q-100 Grade 1 -40 to 125°C 44-TSOP-2 48-FBGA 16-SOIC 32-SOIC 35 ns 45 ns Tray Tape and Reel Engineering Samples Customer Samples Mass Production 08 16 A B Blank C V M YS MA SC SO 35 45 Blank R ES Blank Blank Table 14 – MR0A08B Ordering Part Numbers 1 Temp Grade Temp Package Shipping Tray 44-TSOP2 Commercial 0 to +70 °C Tape and Reel Tray 48-BGA Tape and Reel Tray 32-SOIC 1 Tape and Reel Tray 44-TSOP2 Industrial -40 to +85 °C Tape and Reel Tray 48-BGA Tape and Reel Tray 32-SOIC 1 Tape and Reel Ordering Part Number MR0A08BYS35 MR0A08BYS35R MR0A08BMA35 MR0A08BMA35R MR0A08BSO35 Obsolete MR0A08BSO35R Obsolete MR0A08BCYS35 MR0A08BCYS35R MR0A08BCMA35 MR0A08BCMA35R MR0A08BCSO35 Obsolete MR0A08BCSO35R Obsolete 1 The 32-SOIC package option is obsolete and no longer available. See PCN02895 here. Copyright © 2018 Everspin Technologies 18 MR0A08B Rev. 8.6, 3/2018 MR0A08B PACKAGE OUTLINE DRAWINGS Figure 11 – 44-TSOP2 Package Outline Not To Scale 1. Dimensions and tolerances per ASME Y14.5M - 1994. 2. Dimensions in Millimeters. 3. Dimensions do not include mold protrusion. 4. Dimension does not include DAM bar protrusions. 5. DAM Bar protrusion shall not cause the lead width to exceed 0.58. 44 Copyright © 2018 Everspin Technologies 19 MR0A08B Rev. 8.6, 3/2018 MR0A08B Figure 12 – 48-BGA Package Outline TOP VIEW 0.41 0.31 BOTTOM VIEW 0.32 0.22 SIDE VIEW Not To Scale 1. Dimensions in Millimeters. 2. Dimensions and tolerances per ASME Y14.5M - 1994. 3. Maximum solder ball diameter measured parallel to DATUM A 4. DATUM A, the seating plane is determined by the spherical crowns of the solder balls. 5. surface of package. Copyright © 2018 Everspin Technologies 20 MR0A08B Rev. 8.6, 3/2018 MR0A08B Figure 13 – 32-SOIC Package Outline 1 PIN 1 ID 32 17 J Reference JEDEC MO-119 K 1 16 A I G D B Unit mm - Min - Max inch - Min - Max E C A 20.574 20.878 0.810 0.822 B 1.00 1.50 0.04 0.06 C 0.355 0.508 0.14 0.02 D 0.66 0.81 0.026 0.032 E 0.101 0.254 0.004 0.010 H F F 2.286 2.540 0.09 0.10 G Radius 0.101 Radius 0.0040 H 0.533 1.041 0.021 0.041 I 0.152 0.304 0.006 0.012 J 7.416 7.594 0.292 0.299 K 10.287 10.642 0.405 0.419 Note: 1. The 32-SOIC package is obsolete and shown for legacy reference only. This package option is no longer available for new orders. Copyright © 2018 Everspin Technologies 21 MR0A08B Rev. 8.6, 3/2018 MR0A08B REVISION HISTORY Revision 0 Date Description of Change Sep 12, 2008 Initial Advance Information Release Revised format; Add Table 3.6 Write Timing Cycle 3; Add Figure 3.6 Write Timing Cycle 3; Add TSOPII Lead Width Info; Changed to Preliminary from Product Concept. Changed from datasheet from Preliminary to Production except where noted. 1 May 8, 2009 2 June 18, 2009 3 Apr 12, 2011 Added SOIC package option. 4 August 15, 2011 Corrected SOIC Pin 1 to read DC. Updated contact information. Revised copyright year. 5 Dec 16, 2011 Changed TSOP-II to TSOP2. Changed logo to new EST Logo. Added Industrial Temp Grade option in SOIC package, Table 4.1. Deleted Tape & Reel pack option for all SOIC packaged parts. Figure 2.1 cosmetic update. Figure 5.2 BGA package outline drawing revised for ball size. 6 July 9, 2013 MR0A08BCSO35 preliminary status removed. Now MP. 7 September 4, 2013 Added table of dimenstions to the SOIC package outline diagram. 8 October 11, 2013 Added Tape and Reel shipping option for SOIC packged versions. Reformatted to current standards. 8.1 May 18, 2015 Revised How to Contact Us information. 8.2 June 11, 2015 Correction to Japan Sales Office telephone number. 8.3 July 20, 2015 32-SOIC package options Not Recommended for New Designs. 8.4 October 17, 2015 32-SOIC package options are obsolete and no longer available. 8.5 December 9, 2015 Corrections to incorrect package pinouts and replaced missing 48-BGA package outline drawing. 8.6 March 22, 2018 Updated Contact Us table Copyright © 2018 Everspin Technologies 22 MR0A08B Rev. 8.6, 3/2018 MR0A08B HOW TO CONTACT US Home Page: Everspin Technologies, Inc. www.everspin.com Information in this document is provided solely to enable system and software implementers to use Everspin Technologies products. There are no express or implied licenses granted hereunder to design or fabricate any integrated circuit or circuits based on the information in this document. Everspin Technologies reserves the right to make changes without further notice to any products herein. Everspin makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Everspin Technologies assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation consequential or incidental damages. “Typical” parameters, which may be provided in Everspin Technologies data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters including “Typicals” must be validated for each customer application by customer’s technical experts. Everspin Technologies does not convey any license under its patent rights nor the rights of others. Everspin Technologies products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the Everspin Technologies product could create a situation where personal injury or death may occur. Should Buyer purchase or use Everspin Technologies products for any such unintended or unauthorized application, Buyer shall indemnify and hold Everspin Technologies and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that Everspin Technologies was negligent regarding the design or manufacture of the part. Everspin™ and the Everspin logo are trademarks of Everspin Technologies, Inc. All other product or service World Wide Information Request WW Headquarters - Chandler, AZ 5670 W. Chandler Blvd., Suite 100 Chandler, Arizona 85224 Tel: +1-877-480-MRAM (6726) Local Tel: +1-480-347-1111 Fax: +1-480-347-1175 support@everspin.com Europe, Middle East and Africa Everspin Europe Support support.europe@everspin.com Japan Everspin Japan Support support.japan@everspin.com Asia Pacific Everspin Asia Support support.asia@everspin.com Filename: names are the property of their respective owners. EST00183_MR0A08B_Datasheet_Rev8.6 032218 Copyright © Everspin Technologies, Inc. 2018 Copyright © 2018 Everspin Technologies 23 MR0A08B Rev. 8.6, 3/2018
MR0A08BMA35R 价格&库存
很抱歉,暂时无法提供与“MR0A08BMA35R”相匹配的价格&库存,您可以联系我们找货
