MR0DL08B
FEATURES
Dual Supply 128K x 8 MRAM
• 3.3 Volt VDD power supply with a range of 2.7V to 3.6V
• I/O Voltage range supports wide +1.65 to +3.6 Volt interfaces
• Fast 45 ns read/write cycle
• SRAM compatible timing
• Unlimited read & write endurance
• Data always non-volatile for >20-years at temperature
• All products meet MSL-3 moisture sensitivity level
• RoHS-compliant small footprint BGA package
BENEFITS
• One memory replaces FLASH, SRAM, EEPROM and BBSRAM in systems
for simpler, more efficient designs
RoHS
• Improves reliability by replacing battery-backed SRAM
INTRODUCTION
The MR0DL08B is a dual power supply 1,048,576-bit magnetoresistive random access memory (MRAM)
device organized as 131,072 words of 8 bits. It supports I/O voltages from +1.65 to +3.6 volts. The
MR0DL08B offers SRAM compatible 45ns read/write timing with unlimited endurance. Data is always
non-volatile for greater than 20-years. Data is automatically protected on power loss by low-voltage inhibit
circuitry to prevent writes with voltage out of specification. The MR0DL08B is the ideal memory solution
for applications that must permanently store and retrieve critical data and programs quickly.
The MR0DL08B is available in small footprint 8 mm x 8 mm, 48-pin ball grid array (BGA) package with 0.75
mm ball centers.
The MR0DL08B provides highly reliable data storage over a wide range of temperatures. The product is
offered with commercial temperature (0 to +70 °C).
CONTENTS
1. DEVICE PIN ASSIGNMENT......................................................................... 2
2. ELECTRICAL SPECIFICATIONS................................................................. 4
3. TIMING SPECIFICATIONS.......................................................................... 8
4. ORDERING INFORMATION....................................................................... 13
5. MECHANICAL DRAWING.......................................................................... 14
6. REVISION HISTORY...................................................................................... 15
How to Reach Us.......................................................................................... 15
Copyright © Everspin Technologies 2018
1
MR0DL08B Rev. 1.3, 3/2018
MR0DL08B
Figure 1.1 Block Diagram
OUTPUT
ENABLE
BUFFER
G
A[16:0]
17
ADDRESS
BUFFER
OUTPUT ENABLE
7
10
ROW
DECODER
COLUMN
DECODER
CHIP
ENABLE
BUFFER
E
8
8
OUTPUT
BUFFER
8
128Kx 8 BIT
MEMORY
ARRAY
WRITE
ENABLE
BUFFER
W
SENSE
AMPS
8
FINAL
WRITE
DRIVERS
8
WRITE
DRIVER
8
DQ[7:0]
WRITE ENABLE
Table 1.1 Pin Functions
Signal Name
Function
A
Address Input
E
Chip Enable
W
Write Enable
G
Output Enable
DQ
Data I/O
VDD
Power Supply
VDDQ
I/O Power Supply
VSS
Ground
DC
Do Not Connect
NC
No Connection, Ball D3, H1, H6, G2 Reserved for Future Expansion
2
MR0DL08B Rev. 1.2, 3/2018
MR0DL08B
Figure 1.2 Pin Diagrams for Available Packages (Top View)
1
2
3
4
5
6
DC
G
A
A
A
VDD
A
NC
DC
A
A
E
DC
B
DQ
VDD
A
A
NC
DQ
C
VSS
DQ
NC
A
DQ
VDDQ
D
VDDQ
DQ
DC
DQ
VSS
E
DQ3
NC
NC
DQ
F
NC
NC
A
A
W
NC
G
NC
A
A
A
A
NC
H
48 Pin FBGA
Table 1.2 Operating Modes
E1
G1
W1
Mode
VDD Current
DQ[7:0]2
H
X
X
Not selected
ISB1, ISB2
Hi-Z
L
H
H
Output disabled
IDDR
Hi-Z
L
L
H
Byte Read
IDDR
DOut
L
X
L
Byte Write
IDDW
Din
1
H = high, L = low, X = don’t care
2
Hi-Z = high impedance
3
MR0DL08B
Absolute Maximum Ratings
This device contains circuitry to protect the inputs against damage caused by high static voltages or
electric fields; however, it is advised that normal precautions be taken to avoid application of any
voltage greater than maximum rated voltages to these high-impedance (Hi-Z) circuits.
The device also contains protection against external magnetic fields. Precautions should be taken
to avoid application of any magnetic field more intense than the maximum field intensity specified
in the maximum ratings.
Table 2.1 Absolute Maximum Ratings1
Parameter
Core Supply voltage2
I/O Power Supply voltage2
Symbol
VDD
Value
Unit
-0.5 to 4.0
V
VDDQ
-0.5 to 4.0
V
VIN
-0.5 to +4.0 or
Voltage on any pin2
VDDQ + 0.5
V
whichever is less
Output current per pin
IOUT
±20
mA
Package power dissipation 3
PD
0.600
W
Temperature under bias
TBIAS
-10 to 85
°C
Storage Temperature
Tstg
-55 to 150
°C
Lead temperature during solder (3 minute max)
TLead
260
°C
Maximum magnetic field during write
Hmax_write
2000
A/m
Maximum magnetic field during read or standby
Hmax_read
8000
A/m
1
Permanent device damage may occur if absolute maximum ratings are exceeded. Functional operation should be restricted to recommended operating conditions. Exposure to excessive voltages or
magnetic fields could affect device reliability.
2
All voltages are referenced to VSS.
Power dissipation capability depends on package characteristics and use environment.
3
4
MR0DL08B
Electrical Specifications
Table 2.2 Operating Conditions
Parameter
Core Power supply voltage
Symbol
VDD
Min
Typical
Max
2.7 1
3.3
3.6
Unit
V
I/O Power supply voltage
VDDQ
1.65 1
3.6
V
Write inhibit voltage VDD
VWIDD
2.3
2.5
2.7 1
V
Write inhibit voltage VDDQ
VWIDDQ
1.2
1.4
1.65 1
V
Input high voltage (VDDQ=1.65-2.2V)
VIH
1.4
VDDQ + 0.2 2
V
Input high voltage (VDDQ=2.2-2.7V)
VIH
1.8
VDDQ + 0.2 2
V
Input high voltage (VDDQ=2.7-3.6V)
VIH
2.2
VDDQ + 0.2 2
V
Input low voltage (VDDQ=1.65-2.2V)
VIL
-0.2 3
0.4
V
Input low voltage (VDDQ=2.2-2.7V)
VIL
-0.2 3
0.6
V
Input low voltage (VDDQ=2.7-3.6V)
VIL
-0.2 3
0.8
V
Access Time
TA
°C
Notes:
1. VDDQ≤VDD. Write inhibit occurs when either VDD or VDDQ drops below its write inhibit voltage. There is a 2 ms startup time once
VDD exceeds VDD(min). See Power Up and Power Down Sequencing.
2. VIH(max) = VDDQ + 0.2 V DC ; VIH(max) = VDDQ + 0.5 V AC (pulse width ≤ 20 ns) for I ≤ 20.0 mA.
3. VIL(min) = -0.2 V DC ; VIL(min) = -2.0 V AC (pulse width ≤ 20 ns) for I ≤ 20.0 mA.
5
MR0DL08B
Initial Power Up
The MRAM is protected from write operations whenever VDD is less than VWIDD. Upon power up VDD must go
above 3.0V, and a 2 ms startup time must be observed before read or write operations can start. This time
allows memory power supplies to stabilize.
Power Loss or Brownout
During power loss or brownout where VDD goes below VWIDD writes are inhibited. To return to normal operation and exit Write Inhibit, VDD must go above 3.0V, and a 2 ms startup time must be observed. Once powered up, VDD minimum can go as low as 2.7V.
Chip Enable and Write Enable
The E and W control signals should track VDD on power up to VDD - 0.2 V or VIH (whichever is lower) and remain
high for the startup time. In most systems, this means that these signals should be pulled up with a resistor so that signal remains high if the driving signal is Hi-Z during power up. Any logic that drives E and W
should hold the signals high with a power-on reset signal for longer than the startup time.
Figure 2.1 Power Up and Power Down Sequencing
VWIDD
VWIDDQ
VDD / VDDQ
STARTUP
2 ms
READ/WRITE
INHIBITED
BROWNOUT or POWER LOSS
NORMAL
OPERATION
READ/WRITE
INHIBITED
2 ms
RECOVER
NORMAL
OPERATION
VIH
VIH
E
W
6
MRD08B
Table 2.3 DC Characteristics
Parameter
Symbol
Ilkg(I)
Input leakage current
Min
Typical Max
Unit
±1
μA
Output leakage current
Ilkg(O)
±1
μA
Output low voltage (VDDQ=1.65-2.2V@ 0.1mA)
VOL
0.2
V
Output low voltage (VDDQ=2.2-2.7V@ 0.1mA)
VOL
0.4
V
Output low voltage (VDDQ=2.7-3.6V@ 2.1 mA)
VOL
0.4
V
Output high voltage (VDDQ=1.65-2.2V@ - 0.1 mA)
VOH
1.4
V
Output high voltage (VDDQ=2.2-2.7V@ -0.1 mA)
VOH
2
V
Output high voltage (VDDQ=2.7-3.6V@ -1.0 mA)
VOH
2.4
V
Table 2.4 Power Supply Characteristics
Parameter
AC active supply current - read modes1
(IOUT= 0 mA, VDD= max)
AC active supply current - write modes1
(VDD= max)
Symbol
Typical
Max
Unit
IDDR
25
30
mA
IDDW
55
65
mA
IDDQ
0.50
2
mA
ISB1
6
8
mA
ISB2
5
7
mA
AC active operating current
(VDDQ = VIH= 3.6V, VIL= 0V)
input transitions
很抱歉,暂时无法提供与“MR0DL08BMA45”相匹配的价格&库存,您可以联系我们找货
