MR2A08A
FEATURES
512K x 8 MRAM Memory
• Fast 35ns Read/Write Cycle
• SRAM Compatible Timing, Uses Existing SRAM Controllers Without
Redesign
• Unlimited Read & Write Endurance
• Data Always Non-volatile for >20 years at Temperature
• One Memory Replaces Flash, SRAM, EEPROM and BBSRAM in
System for Simpler, More Efficient Design
• Replace battery-backed SRAM solutions with MRAM to eliminate
battery assembly, improving reliability
• 3.3 Volt Power Supply
• Automatic Data Protection on Power Loss
• Commercial, Industrial, Automotive Temperatures
• RoHS-Compliant SRAM TSOP2 Package
• RoHS-Compliant SRAM BGA Package
• AEC-Q100 Grade 1 Qualified
RoHS
INTRODUCTION
The MR2A08A is a 4,194,304-bit magnetoresistive random access memory (MRAM) device organized as
524,288 words of 8 bits. The MR2A08A offers SRAM compatible 35ns read/write timing with unlimited
endurance. Data is always non-volatile for greater than 20 years. Data is automatically protected on power
loss by low-voltage inhibit circuitry to prevent writes with voltage out of specification.
The MR2A08A is the ideal memory solution for applications that must permanently store and retrieve critical data and programs quickly.
The MR2A08A is available in a small footprint 400-mil, 44-lead plastic small-outline TSOP type 2 package
or an 8 mm x 8 mm, 48-pin ball grid array (BGA) package with 0.75 mm ball centers. These packages are
compatible with similar low-power SRAM products and other non-volatile RAM products.
The MR2A08A provides highly reliable data storage over a wide range of temperatures. The product is offered with commercial temperature range (0 to +70 °C), industrial temperature range (-40 to +85 °C), and
AEC-Q100 Grade 1 temperature range (-40 to +125 °C) options.
CONTENTS
1. DEVICE PIN ASSIGNMENT......................................................................... 2
2. ELECTRICAL SPECIFICATIONS................................................................. 4
3. TIMING SPECIFICATIONS.......................................................................... 7
4. ORDERING INFORMATION....................................................................... 11
5. MECHANICAL DRAWING.......................................................................... 12
6. REVISION HISTORY...................................................................................... 14
How to Reach Us.......................................................................................... 14
Copyright © 2018 Everspin Technologies, Inc.
1
MR2A08A Rev. 6.3, 3/2018
MR2A08A
Figure 1.1 Block Diagram
G
A[18:0]
19
E
W
OUTPUT
ENABLE
BUFFER
ADDRESS
BUFFER
OUTPUT ENABLE
9
10
CHIP
ENABLE
BUFFER
ROW
DECODER
COLUMN
DECODER
8
SENSE
AMPS
512k x 8
BIT
MEMORY
ARRAY
WRITE
ENABLE
BUFFER
8
FINAL
WRITE
DRIVERS
8
OUTPUT
BUFFER
8
8
WRITE
DRIVER
8
DQ[7:0]
WRITE ENABLE
Table 1.1 Pin Functions
Signal Name
Function
A
Address Input
E
Chip Enable
W
Write Enable
G
Output Enable
DQ
Data I/O
VDD
Power Supply
VSS
Ground
DC
Do Not Connect
NC
No Connection - Pin 2, 43 (TSOPII); Ball H6, G2 (BGA) Reserved For Future Expansion
2
MR2A08A
Figure 1.2 Pin Diagrams for Available Packages (Top View)
DC
NC
A0
A1
A2
A3
A4
E
DQ0
DQ1
VDD
VSS
DQ2
DQ3
W
A5
A6
A7
A8
A9
DC
DC
44
43
42
41
40
39
38
37
36
35
34
33
32
31
30
29
28
27
26
25
24
23
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
DC
NC
DC
A18
A17
A16
A15
G
DQ7
DQ6
VSS
VDD
DQ5
DQ4
DC
1
2
3
4
5
6
DC
G
A0
A1
A2
DC
A
NC
DC
A3
A4
E
DC
B
DQ0
NC
A5
A6
NC
DQ4
C
VSS
DQ1
A17
A7
DQ5
VDD
D
VDD
DQ2
DC
A16
DQ6
VSS
E
A14
A13
A12
DQ3
NC
A14
A15
NC
DQ7
F
NC
NC
A12
A13
W
NC
G
A11
A10
A18
A8
A9
A10
A11
NC
H
DC
DC
44 Pin TSOP2
48 Pin FBGA
Table 1.2 Operating Modes
E1
G1
W1
Mode
VDD Current
DQ[7:0]2
H
X
X
Not selected
ISB1, ISB2
Hi-Z
L
H
H
Output disabled
IDDR
Hi-Z
L
L
H
Byte Read
IDDR
DOut
L
X
L
Byte Write
IDDW
Din
1
H = high, L = low, X = don’t care
2
Hi-Z = high impedance
3
MR2A08A
Absolute Maximum Ratings
This device contains circuitry to protect the inputs against damage caused by high static voltages or electric fields; however, it is advised that
normal precautions be taken to avoid application of any voltage greater than maximum rated voltages to these high-impedance (Hi-Z) circuits.
The device also contains protection against external magnetic fields. Precautions should be taken to avoid application of any magnetic field
more intense than the maximum field intensity specified in the maximum ratings.
Table 2.1 Absolute Maximum Ratings1
Symbol
Parameter
Temp Range
Package
Value
Unit
VDD
Supply voltage 2
-0.5 to 4.0
V
VIN
Voltage on any pin 2
-0.5 to VDD + 0.5
V
IOUT
Output current per pin
±20
mA
PD
Package power dissipation 3
Note 3
0.600
W
TBIAS
Temperature under bias
Commercial
-10 to 85
Industrial
-45 to 95
AEC-Q100 Grade 1
-45 to 130
°C
Tstg
Storage Temperature
-55 to 150
°C
TLead
Lead temperature during solder
(3 minute max)
260
°C
Commercial
TSOP2, BGA
2,000
BGA
2,000
TSOP2
10,000
TSOP2
2,000
TSOP2, BGA
8,000
BGA
8,000
TSOP2
10,000
TSOP2
8,000
Hmax_write
Maximum magnetic field during
write
Industrial
AEC-Q100 Grade 1
Commercial
Hmax_read
read or standby
Industrial
AEC-Q100 Grade 1
A/m
A/m
Notes:
1.
Permanent device damage may occur if absolute maximum ratings are exceeded. Functional operation should be restricted
to recommended operating conditions. Exposure to excessive voltages or magnetic fields could affect device reliability.
2.
All voltages are referenced to VSS.
3.
Power dissipation capability depends on package characteristics and use environment.
4
MR2A08A
Electrical Specifications
Table 2.2 Operating Conditions
Parameter
Symbol
Min
Typical
Max
Unit
Power supply voltage 1
VDD
3.0
3.3
3.6
V
Write inhibit voltage
VWI
2.5
2.7
3.0 1
V
Input high voltage
VIH
2.2
VDD + 0.3 2
V
Input low voltage
VIL
-0.5 3
0.8
V
MR2A08A (Commercial)
MR2A08AC (Industrial)
TA
MR2A08AM (AEC-Q100 Grade 1)4
-40
85
-40
125
°C
There is a 2 ms startup time once VDD exceeds VDD,(min). See Power Up and Power Down Sequencing below.
VIH(max) = VDD + 0.3 VDC ; VIH(max) = VDD + 2.0 VAC (pulse width ≤ 10 ns) for I ≤ 20.0 mA.
3
VIL(min) = -0.5 VDC ; VIL(min) = -2.0 VAC (pulse width ≤ 10 ns) for I ≤ 20.0 mA.
4
AEC-Q100 Grade 1 temperature profile assumes 10% duty cycle at maximum temperature (2-years out of 20-year life)
1
2
The MRAM is protected from write operations whenever VDD is less than VWI. As soon as VDD exceeds VDD(min), there is a
startup time of 2 ms before read or write operations can start. This time allows memory power supplies to stabilize.
The E and W control signals should track VDD on power up to VDD- 0.2 V or VIH (whichever is lower) and remain high
for the startup time. In most systems, this means that these signals should be pulled up with a resistor so that signal
remains high if the driving signal is Hi-Z during power up. Any logic that drives E and W should hold the signals high
with a power-on reset signal for longer than the startup time.
During power loss or brownout where VDD goes below VWI, writes are protected and a startup time must be observed
when power returns above VDD(min).
Figure 2.1 Power Up and Power Down Diagram
VWI
VDD
BROWNOUT or POWER LOSS
2 ms
STARTUP
READ/WRITE
INHIBITED
2 ms
RECOVER
NORMAL
OPERATION
READ/WRITE
INHIBITED
NORMAL
OPERATION
VIH
VIH
E
W
5
MR2A08A
Table 2.3 DC Characteristics
Parameter
Symbol
Min
Max
Unit
Input leakage current
Ilkg(I)
±1
μA
Output leakage current
Ilkg(O)
±1
μA
VOL
0.4
V
Output low voltage
(IOL = +4 mA)
(IOL = +100 μA)
Output high voltage
VSS + 0.2
(IOL = -4 mA)
VOH
2.4
(IOL = -100 μA)
V
VDD - 0.2
Table 2.4 Power Supply Characteristics
Parameter
AC active supply current - read modes1
(IOUT= 0 mA, VDD= max)
Symbol
Typical
Max
Unit
IDDR
30
66
mA
90
135
90
135
90
135
ISB1
13
mA
ISB2
8
10
mA
AC active supply current - write modes1
(VDD= max)
Commercial Grade
Industrial Grade
IDDW
AEC-Q100 Grade
mA
AC standby current
(VDD= max, E = VIH)
no other restrictions on other inputs
CMOS standby current
(E ≥ VDD - 0.2 V and VIn ≤ VSS + 0.2 V or ≥ VDD - 0.2 V)
(VDD = max, f = 0 MHz)
1
All active current measurements are measured with one address transition per cycle and at minimum cycle time.
6
MR2A08A
Table 3.1 Capacitance1
Parameter
1
Symbol
Typical
Max
Unit
Address input capacitance
CIn
6
pF
Control input capacitance
CIn
6
pF
Input/Output capacitance
CI/O
8
pF
Value
Unit
Logic input timing measurement reference level
1.5
V
Logic output timing measurement reference level
1.5
V
0 or 3.0
V
2
ns
f = 1.0 MHz, dV = 3.0 V, TA = 25 °C, periodically sampled rather than 100% tested.
Table 3.2 AC Measurement Conditions
Parameter
Logic input pulse levels
Input rise/fall time
Output load for low and high impedance parameters
See Figure 3.1
Output load for all other timing parameters
See Figure 3.2
Figure 3.1 Output Load Test Low and High
ZD= 50 Ω
Output
RL = 50 Ω
VL = 1.5 V
Figure 3.2 Output Load Test All Others
3.3 V
590 Ω
Output
5 pF
435 Ω
7
MR2A08A
Timing Specifications
Read Mode
Table 3.3 Read Cycle Timing1
Parameter
Symbol
Min
Max
Unit
Read cycle time
tAVAV
35
ns
Address access time
tAVQV
35
ns
Enable access time2
tELQV
35
ns
Output enable access time
tGLQV
15
ns
Output hold from address change
tAXQX
3
ns
Enable low to output active3
tELQX
3
ns
Output enable low to output active3
tGLQX
ns
Enable high to output Hi-Z3
tEHQZ
ns
Output enable high to output Hi-Z3
tGHQZ
ns
W is high for read cycle. Power supplies must be properly grounded and decoupled, and bus contention conditions must be
minimized or eliminated during read or write cycles.
2
Addresses valid before or at the same time E goes low.
3
This parameter is sampled and not 100% tested. Transition is measured ±200 mV from the steady-state voltage.
1
Figure 3.3A Read Cycle 1
t AVAV
A (ADDRESS)
t AXQX
Q (DATA OUT)
Previous Data Valid
Data Valid
t AVQV
Note: Device is continuously selected (E ≤ VIL, G ≤ VIL).
Figure 3.3B Read Cycle 2
t AVAV
A (ADDRESS)
t AVQV
E (CHIP ENABLE)
t ELQV
t EHQZ
t ELQX
G (OUTPUT ENABLE)
Q (DATA OUT)
t GHQZ
t GLQV
t GLQX
Data Valid
8
MR2A08A
Table 3.4 Write Cycle Timing 1 (W Controlled)1
Parameter
Symbol
Min
Max
Unit
Write cycle time 2
tAVAV
35
ns
Address set-up time
tAVWL
ns
Address valid to end of write (G high)
tAVWH
18
ns
Address valid to end of write (G low)
tAVWH
ns
15
ns
15
ns
tWLWH
Write pulse width (G high)
tWLEH
tWLWH
Write pulse width (G low)
tWLEH
Data valid to end of write
tDVWH
10
ns
Data hold time
tWHDX
ns
Write low to data Hi-Z 3
tWLQZ
ns
Write high to output active 3
tWHQX
3
ns
Write recovery time
tWHAX
12
ns
All write occurs during the overlap of E low and W low. Power supplies must be properly grounded and decoupled and bus
contention conditions must be minimized or eliminated during read and write cycles. If G goes low at the same time or after
W goes low, the output will remain in a high impedance state. After W or E has been brought high, the signal must remain in
steady-state high for a minimum of 2 ns. The minimum time between E being asserted low in one cycle to E being asserted
low in a subsequent cycle is the same as the minimum cycle time allowed for the device.
2
All write cycle timings are referenced from the last valid address to the first transition address.
3
This parameter is sampled and not 100% tested. Transition is measured ±200 mV from the steady-state voltage. At any given
voltage or temperature, tWLQZ(max) < tWHQX(min)
1
Figure 3.4 Write Cycle Timing 1 (W Controlled)
t AVAV
A (ADDRESS)
t AVWH
t WHAX
E (CHIP ENABLE)
t WLEH
t WLWH
W (WRITE ENABLE)
t AVWL
t DVWH
D (DATA IN)
t WHDX
DATA VALID
t WLQZ
Q (DATA OUT)
Hi -Z
Hi -Z
t WHQX
9
MR2A08A
Table 3.5 Write Cycle Timing 2 (E Controlled) 1
Parameter
Symbol
Min
Max
Unit
Write cycle time 2
tAVAV
35
ns
Address set-up time
tAVEL
ns
tAVEH
18
ns
tAVEH
ns
15
ns
15
ns
tELEH
Enable to end of write (G high)
tELWH
tELEH
Enable to end of write (G low) 3
tELWH
tDVEH
10
ns
Data hold time
tEHDX
ns
Write recovery time
tEHAX
12
ns
2
3
If E goes low at the same time or after W goes low, the output will remain in a high-impedance state. If E goes high at the
same time or before W goes high, the output will remain in a high-impedance state.
1
Figure 3.5 Write Cycle Timing 2 (E Controlled)
t AVAV
A (ADDRESS)
t AVEH
t EHAX
t ELEH
E (CHIP ENABLE)
t AVEL
t ELWH
W (WRITE ENABLE)
t DVEH
D (DATA IN)
Data Valid
Hi-Z
Q (DATA OUT)
t EHDX
10
MR2A08A
Figure 4.1 Part Numbering System
MR
2
A
08
A
C
YS
35
R
Carrier
(Blank = Tray, R = Tape & Reel)
Speed
(35 ns)
Package (YS = TSOP2, MA = FBGA)
Temperature Range
(Blank= Commercial (0 to +70 °C, C=
Industrial (-40 to +85 °C, M= AECQ100 Grade 1 (-40 to +125 °C)
Revision
Data Width (08 = 8-Bit, 16 = 16-bit)
Type
(A = Asynchronous, S = Synchronous)
Density (256 = 256 Kb, 0 = 1Mb, 1 =2Mb,
2 =4Mb, 4 =16Mb)
Magnetoresistive RAM
(MR)
Table 4.1 Available Parts
Part Number
Description
MR2A08AYS35
MR2A08ACYS35
MR2A08AMYS35
3.3 V 512Kx8 MRAM Commercial
44-TSOP2
3.3 V 512Kx8 MRAM Industrial
44-TSOP2
3.3 V 512Kx8 MRAM AEC-Q100 Grade 1 44-TSOP2
Tray
Tray
Tray
MR2A08AYS35R
44-TSOP2
Tape & Reel
0 to +70 °C
MR2A08ACYS35R
MR2A08AMYS35R
MR2A08AMA35
MR2A08ACMA35
MR2A08AMA35R
MR2A08ACMA35R
3.3 V 512Kx8 MRAM T&R Commercial
3.3 V 512Kx8 MRAM T&R Industrial
44-TSOP2
44-TSOP2
48-BGA
48-BGA
48-BGA
48-BGA
Tape & Reel
Tape & Reel
Tray
Tray
Tape & Reel
Tape & Reel
-40 to +85 °C
-40 to +125 °C
0 to +70 °C
-40 to +85 °C
0 to +70 °C
-40 to +85 °C
Package
11
Ship Pack
Temp Range
0 to +70 °C
-40 to +85 °C
-40 to +125 °C
MR2A08A
Figure 5.1 TSOP2
Print Version Not To Scale
1. Dimensions and tolerances per ASME Y14.5M - 1994.
2. Dimensions in Millimeters.
3. Dimensions do not include mold protrusion.
4. Dimension does not include DAM bar protrusions.
DAM Bar protrusion shall not cause the lead width to exceed 0.58.
12
MR2A08A
Mechanical Drawings
Figure 5.2 FBGA
TOP VIEW
SIDE VIEW
BOTTOM VIEW
1. Dimensions in Millimeters.
2. Dimensions and tolerances per ASME Y14.5M - 1994.
3. Maximum solder ball diameter measured parallel to DATUM A
4. DATUM A, the seating plane is determined by the spherical crowns
of the solder balls.
5. Parallelism measurement shall exclude any effect of mark on top
surface of package.
13
MR2A08A
6. REVISION HISTORY
Revision
Date
1
Oct 29, 2007
2
Sep 12, 2008
3
Apr 10, 2009
Add typical and worst case current specifications
4
July 6, 2009
Changed datasheet from Preliminary to Production except where noted. Updated
format.
5
Dec 16, 2011
Added AEC-Q100 Grade 1 temp performance specifications to Table 2.1, Table
2.2, addition of AEC-Q100 Grade 1 and revision of IDDW Typical values in Table 2.4.
AEC-Q100 Grade 1 ordering options added to Figure 4.1 and Table 4.1. Changed
TSOP-II to TSOP2 everywhere. New logo design. Cosmetic revision to Table 2.1.
6
August 2, 2012
Improved magnetic immunity for Industrial and Extended Grades. Revised Power
Up/Power Down Diagram.
6.1
May 19, 2015
Revised contact information.
6.2
June 11, 2015
Corrected Japan Sales Office telephone number.
6.3
Description of Change
Designate pin 23, 24, 42 of TSOPII as DC "Don't Connect" pins since these pins
should remain floating at all times. Functional operation of E2 pin defined.
Reformat Datasheet for Everspin, Delete E2 pin Function, Add BGA Package Information Add Tape & Reel Part Numbers, Add Power Sequencing Info, Correct IOH
Spec For VOH to -100 uA, Correct ac Test Conditions
March 23, 2018 Update the Contact Us table
14
HOW TO CONTACT US
How to Reach Us:
Home Page:
www.everspin.com
World Wide Information Request
WW Headquarters - Chandler, AZ
5670 W. Chandler Blvd., Suite 100
Chandler, Arizona 85226
Tel: +1-877-480-MRAM (6726)
Local Tel: +1-480-347-1111
Fax: +1-480-347-1175
support@everspin.com
orders@everspin.com
sales@everspin.com
Europe, Middle East and Africa
Everspin Europe Support
support.europe@everspin.com
Japan
Everspin Japan Support
support.japan@everspin.com
Asia Pacific
Everspin Asia Support
support.asia@everspin.com
Filename:
Information in this document is provided solely to enable system and
software implementers to use Everspin Technologies products. There are
no express or implied licenses granted hereunder to design or fabricate
any integrated circuit or circuits based on the information in this document. Everspin Technologies reserves the right to make changes without
further notice to any products herein. Everspin makes no warranty, representation or guarantee regarding the suitability of its products for any
particular purpose, nor does Everspin Technologies assume any liability
arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation consequential or incidental damages. “Typical” parameters, which may be provided
in Everspin Technologies data sheets and/or specifications can and do
vary in different applications and actual performance may vary over time.
All operating parameters including “Typicals” must be validated for each
customer application by customer’s technical experts. Everspin Technologies does not convey any license under its patent rights nor the rights of
others. Everspin Technologies products are not designed, intended, or
authorized for use as components in systems intended for surgical implant
into the body, or other applications intended to support or sustain life, or
for any other application in which the failure of the Everspin Technologies
product could create a situation where personal injury or death may occur.
Should Buyer purchase or use Everspin Technologies products for any such
unintended or unauthorized application, Buyer shall indemnify and hold
Everspin Technologies and its officers, employees, subsidiaries, affiliates,
and distributors harmless against all claims, costs, damages, and expenses,
and reasonable attorney fees arising out of, directly or indirectly, any claim
of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that Everspin Technologies was negligent regarding the design or manufacture of the part. Everspin™ and the
Everspin logo are trademarks of Everspin Technologies, Inc.
All other product or service names are the property of their respective owners.
Copyright © Everspin Technologies, Inc. 2018
EST00170_MR2A08A_Datasheet_Rev6.3 032318
15
