MR2A16AYS35R
MR2A16AYS35R
    EVERSPINTECHNOLOGIESINC.
    TSOP-44
MR2A16AYS35R 数据手册
MR2A16A FEATURES 256K x 16 MRAM Memory • Fast 35 ns Read/Write cycle • SRAM compatible timing, uses existing SRAM controllers without redesign • Unlimited Read & Write endurance • Data non-volatile for >20 years at temperature • One memory replaces Flash, SRAM, EEPROM and BBSRAM in a system for simpler, more efficient design • Replaces battery-backed SRAM solutions with MRAM to improve reliability • 3.3 volt power supply • Automatic data protection on power loss • Commercial, Industrial, Extended temperatures • AEC-Q100 Grade 1 option • All products meet MSL-3 moisture sensitivity level • RoHS-compliant SRAM TSOP2 and BGA Packages 44-pin TSOP2 48-ball BGA RoHS INTRODUCTION The MR2A16A is a 4,194,304-bit magnetoresistive random access memory (MRAM) device organized as 262,144 words of 16 bits. The MR2A16A offers SRAM compatible 35 ns read/write timing with unlimited endurance. Data is always non-volatile for greater than 20 years. Data is automatically protected on power loss by low-voltage inhibit circuitry to prevent writes with voltage out of specification. The MR2A16A is the ideal memory solution for applications that must permanently store and retrieve critical data and programs quickly. The M2A16A is available in a small footprint 48-pin ball grid array (BGA) package and a 44-pin thin small outline package (TSOP Type 2). These packages are compatible with similar low-power SRAM products and other nonvolatile RAM products. The MR2A16A provides highly reliable data storage over a wide range of temperatures. The product is offered with Commercial (0 to +70 °C), Industrial (-40 to +85 °C), Extended (-40 to +105 °C), and AEC-Q100 Grade 1 (-40 to +125 °C) operating temperature range options. Copyright © Everspin Technologies 2018 1 MR2A16A Rev. 11.3 3/2018 MR2A16A TABLE OF CONTENTS FEATURES..............................................................................................................................................1 INTRODUCTION....................................................................................................................................1 BLOCK DIAGRAM AND PIN ASSIGNMENTS........................................................................................4 Figure 1 – Block Diagram............................................................................................................................................ 4 Table 1 – Pin Functions................................................................................................................................................ 4 Figure 2 – Pin Diagrams for Available Packages (Top View)........................................................................... 5 Table 2 – Operating Modes........................................................................................................................................ 5 ABSOLUTE MAXIMUM RATINGS..........................................................................................................6 Table 3 – Absolute Maximum Ratings.................................................................................................................... 6 OPERATING CONDITIONS....................................................................................................................7 Power Up and Power Down Sequencing........................................................................................8 Figure 3 – Power Up and Power Down Diagram................................................................................................ 8 DC CHARACTERISTICS..........................................................................................................................9 Table 4 – DC Characteristics....................................................................................................................................... 9 Table 5 – Power Supply Characteristics................................................................................................................. 9 TIMING SPECIFICATIONS.................................................................................................................. 10 Table 6 – Capacitance................................................................................................................................................10 Table 7 – AC Measurement Conditions...............................................................................................................10 Figure 4 – Output Load Test Low and High........................................................................................................10 Figure 5 – Output Load Test All Others................................................................................................................10 Read Mode..................................................................................................................................... 11 Table 8 – Read Cycle Timing....................................................................................................................................11 Figure 6 – Read Cycle 1..............................................................................................................................................11 Figure 7 – Read Cycle 2..............................................................................................................................................11 Write Mode..................................................................................................................................... 12 Table 9 – Write Cycle Timing 1 (W Controlled)..................................................................................................12 Copyright © Everspin Technologies 2018 2 MR2A16A Rev. 11.3 3/2018 MR2A16A TABLE OF CONTENTS (CONT’D) Figure 8 – Write Cycle Timing 1 (W Controlled)................................................................................................12 Table 10 – Write Cycle Timing 2 (E Controlled).................................................................................................13 Figure 9 – Write Cycle Timing 2 (E Controlled)..................................................................................................13 Table 11 – Write Cycle Timing 3 (LB / UB Controlled).....................................................................................14 Figure 10 – Write Cycle Timing 3 (LB / UB Controlled)...................................................................................14 ORDERING INFORMATION................................................................................................................ 15 Table 12 – Ordering Part Number System for Parallel I/O MRAM..............................................................15 Table 13 – MR2A16A Ordering Part Numbers...................................................................................................16 PACKAGE OUTLINE DRAWINGS........................................................................................................ 17 Figure 11 – 44-TSOP2 Package Outline...............................................................................................................17 Figure 12 – 48-FBGA Packge Outline....................................................................................................................18 REVISION HISTORY............................................................................................................................ 19 HOW TO CONTACT US........................................................................................................................ 20 Copyright © Everspin Technologies 2018 3 MR2A16A Rev. 11.3 3/2018 MR2A16A BLOCK DIAGRAM AND PIN ASSIGNMENTS Figure 1 – Block Diagram Table 1 – Pin Functions Signal Name Function A Address Input E Chip Enable W Write Enable G Output Enable UB Upper Byte Enable LB Lower Byte Enable DQ Data I/O VDD Power Supply VSS Ground DC Do Not Connect NC No Connection Copyright © Everspin Technologies 2018 4 MR2A16A Rev. 11.3 3/2018 MR2A16A Figure 2 – Pin Diagrams for Available Packages (Top View) A0 A1 A2 A3 A4 E DQL0 DQL1 DQL2 DQL3 VDD VSS DQL4 DQL5 DQL6 DQL7 W A5 A6 A7 A8 A9 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 A17 A16 A15 G UB LB DQU15 DQU14 DQU13 DQU12 VSS VDD DQU11 DQU10 DQU9 DQU8 DC A14 A13 A12 A11 A10 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 1 2 3 4 5 6 LB G A0 A1 A2 NC A DQU8 UB A3 A4 E DQL0 B DQU9 DQU10 A5 A6 DQL1 DQL2 C VSS DQU11 A17 A7 DQL3 VDD D VDD DQU12 NC A16 DQL4 VSS E DQU14 DQU13 A14 A15 DQL5 DQL6 F DQU15 NC A12 A13 W DQL7 G NC A8 A9 A10 A11 DC H 44-Pin TSOP Type2 48-Pin BGA Table 2 – Operating Modes E1 G1 W 1 LB 1 UB1 VDD Current DQL[7:0]2 DQU[15:8]2 H X X X X Not selected ISB1, ISB2 Hi-Z Hi-Z L H H X X Output disabled IDDR Hi-Z Hi-Z L X X H H Output disabled IDDR Hi-Z Hi-Z L L H L H Lower Byte Read IDDR DOut Hi-Z L L H H L Upper Byte Read IDDR Hi-Z DOut L L H L L Word Read IDDR DOut DOut L X L L H Lower Byte Write IDDW Din Hi-Z L X L H L Upper Byte Write IDDW Hi-Z Din L X L L L Word Write IDDW Din Din Mode Notes: 1. H = high, L = low, X = don’t care 2. Hi-Z = high impedance Copyright © Everspin Technologies 2018 5 MR2A16A Rev. 11.3 3/2018 MR2A16A ABSOLUTE MAXIMUM RATINGS Table 3 – Absolute Maximum Ratings This device contains circuitry to protect the inputs against damage caused by high static voltages or electric fields; however, it is advised that normal precautions be taken to avoid application of any voltage greater than maximum rated voltages to these high-impedance (Hi-Z) circuits. The device also contains protection against external magnetic fields. Precautions should be taken to avoid application of any magnetic field more intense than the maximum field intensity specified in the maximum ratings. 1 Symbol Parameter Temp Range Package Value Unit VDD Supply voltage 2 - - -0.5 to 4.0 V VIN Voltage on any pin 2 - - -0.5 to VDD + 0.5 V IOUT Output current per pin - - ±20 mA PD Package power dissipation 3 - Note 3 0.600 W TBIAS Temperature under bias Commercial - -10 to 85 Industrial - -45 to 95 Extended - -45 to 110 AEC-Q100 Grade 1 - -45 to 130 °C Tstg Storage Temperature - - -55 to 150 °C TLead Lead temperature during solder (3 minute max) - - 260 °C Commercial TSOP2, BGA 2,000 BGA 2,000 TSOP2 10,000 TSOP2 2,000 TSOP2, BGA 8,000 BGA 8,000 TSOP2 10,000 TSOP2 8,000 Hmax_write Maximum magnetic field during write Industrial, Extended AEC-Q100 Grade 1 Commercial Hmax_read Maximum magnetic field during read or standby Industrial, Extended AEC-Q100 Grade 1 A/m A/m Notes: 1. Permanent device damage may occur if absolute maximum ratings are exceeded. Functional operation should be restricted to recommended operating conditions. Exposure to excessive voltages or magnetic fields could affect device reliability. 2. All voltages are referenced to VSS. 3. Power dissipation capability depends on package characteristics and use environment. Copyright © Everspin Technologies 2018 6 MR2A16A Rev. 11.3 3/2018 MR2A16A OPERATING CONDITIONS Parameter Symbol VDD Min Typical Max Unit 3.0 3.3 3.6 V Write inhibit voltage VWI 2.5 2.7 3.0 1 V Input high voltage VIH 2.2 - VDD + 0.3 2 V Input low voltage VIL -0.5 3 - 0.8 V Temperature under bias MR2A16A (Commercial) MR2A16AC (Industrial) MR2A16AV (Extended) MR2A16AM (AEC-Q100 Grade 1) 4 TA 0 -40 -40 -40 Power supply voltage 1 70 85 105 125 °C Notes: 1. 2. 3. 4. There is a 2 ms startup time once VDD exceeds VDD,(max). See “Power Up and Power Down Sequencing” on page 8. VIH(max) = VDD + 0.3 VDC ; VIH(max) = VDD + 2.0 VAC (pulse width ≤ 10 ns) for I ≤ 20.0 mA. VIL(min) = -0.5 VDC ; VIL(min) = -2.0 VAC (pulse width ≤ 10 ns) for I ≤ 20.0 mA. AEC-Q100 Grade 1 temperature profile assumes 10% duty cycle at maximum temperature (2 years out of 20 years life.) Copyright © Everspin Technologies 2018 7 MR2A16A Rev. 11.3 3/2018 MR2A16A Power Up and Power Down Sequencing The MRAM is protected from write operations whenever VDD is less than VWI. As soon as VDD exceeds VDD(min), there is a startup time of 2 ms before read or write operations can start. This time allows memory power supplies to stabilize. The E and W control signals should track VDD on power up to VDD- 0.2 V or VIH (whichever is lower) and remain high for the startup time. In most systems, this means that these signals should be pulled up with a resistor so that signal remains high if the driving signal is Hi-Z during power up. Any logic that drives E and W should hold the signals high with a power-on reset signal for longer than the startup time. During power loss or brownout where VDD goes below VWI, writes are protected and a startup time must be observed when power returns above VDD(min). Figure 3 – Power Up and Power Down Sequencing Timing Diagram VWI VDD BROWNOUT or POWER LOSS 2 ms STARTUP READ/WRITE INHIBITED 2 ms RECOVER NORMAL OPERATION READ/WRITE INHIBITED NORMAL OPERATION VIH VIH E W Copyright © Everspin Technologies 2018 8 MR2A16A Rev. 11.3 3/2018 MR2A16A DC CHARACTERISTICS Table 4 – DC Characteristics Parameter Symbol Min Typical Max Unit Input leakage current Ilkg(I) - - ±1 μA Output leakage current Ilkg(O) - - ±1 μA Output low voltage (IOL = +4 mA) (IOL = +100 μA) VOL - - 0.4 VSS + 0.2 V Output high voltage (IOH = -4 mA) (IOH = -100 μA) VOH 2.4 VDD - 0.2 - - V Table 5 – Power Supply Characteristics Parameter Symbol Typical Max Unit IDDR 55 80 mA IDDW 105 105 105 105 155 165 165 165 mA AC standby current (VDD= max, E = VIH) no other restrictions on other inputs ISB1 18 28 mA CMOS standby current (E ≥ VDD - 0.2 V and VIn ≤ VSS + 0.2 V or ≥ VDD - 0.2 V) (VDD = max, f = 0 MHz) ISB2 9 12 mA AC active supply current - read modes1 (IOUT= 0 mA, VDD= max) AC active supply current - write modes1 (VDD= max) Commercial Grade Industrial Grade Extended Grade AEC-Q100 Grade Notes: 1. All active current measurements are measured with one address transition per cycle and at minimum cycle time. Copyright © Everspin Technologies 2018 9 MR2A16A Rev. 11.3 3/2018 MR2A16A TIMING SPECIFICATIONS Table 6 – Capacitance Parameter 1 Symbol Typical Max Unit Address input capacitance CIn - 6 pF Control input capacitance CIn - 6 pF Input/Output capacitance CI/O - 8 pF Value Unit Logic input timing measurement reference level 1.5 V Logic output timing measurement reference level 1.5 V 0 or 3.0 V Input rise/fall time 2 ns Output load for low and high impedance parameters See Figure 4 Output load for all other timing parameters See Figure 5 Notes: 1. f = 1.0 MHz, dV = 3.0 V, TA = 25 °C, periodically sampled rather than 100% tested. Table 7 – AC Measurement Conditions Parameter Logic input pulse levels Figure 4 – Output Load Test Low and High ZD= 50 Ω Output RL = 50 Ω VL = 1.5 V Figure 5 – Output Load Test All Others 3.3 V 590 Ω Output 5 pF 435 Ω Copyright © Everspin Technologies 2018 10 MR2A16A Rev. 11.3 3/2018 MR2A16A Read Mode Table 8 – Read Cycle Timing Parameter 1 Symbol Min Max Unit Read cycle time tAVAV 35 - ns Address access time tAVQV - 35 ns Enable access time2 tELQV - 35 ns Output enable access time tGLQV - 15 ns Byte enable access time tBLQV - 15 ns Output hold from address change tAXQX 3 - ns Enable low to output active3 tELQX 3 - ns Output enable low to output active3 tGLQX 0 - ns Byte enable low to output active3 tBLQX 0 - ns Enable high to output Hi-Z3 tEHQZ 0 15 ns Output enable high to output Hi-Z3 tGHQZ 0 10 ns Byte high to output Hi-Z3 tBHQZ 0 10 ns Notes: 1. W is high for read cycle. Power supplies must be properly grounded and decoupled, and bus contention conditions must be minimized or eliminated during read or write cycles. 2. Addresses valid before or at the same time E goes low. 3. This parameter is sampled and not 100% tested. Transition is measured ±200 mV from the steady-state voltage. Figure 6 – Read Cycle 1 t AVAV A (ADDRESS) t AXQX Previous Data Valid Q (DATA OUT) Data Valid t AVQV Note: Device is continuously selected (E ≤ VIL, G ≤ VIL). Figure 7 – Read Cycle 2 t AVAV A (ADDRESS) t AVQV E (CHIP ENABLE) t ELQV t EHQZ t ELQX G (OUTPUT ENABLE) t GLQX t GHQZ t GLQV LB, UB (BYTE ENABLE) Q (DATA OUT) Copyright © Everspin Technologies 2018 t BLQX t BHQZ t BLQV Data Valid 11 MR2A16A Rev. 11.3 3/2018 MR2A16A Write Mode Table 9 – Write Cycle Timing 1 (W Controlled) Parameter 1 Symbol Min Max Unit tAVAV 35 - ns Address set-up time tAVWL 0 - ns Address valid to end of write (G high) tAVWH 18 - ns Address valid to end of write (G low) tAVWH 20 - ns 15 - ns 15 - ns Write cycle time 2 tWLWH Write pulse width (G high) tWLEH tWLWH Write pulse width (G low) tWLEH Data valid to end of write tDVWH 10 - ns Data hold time tWHDX 0 - ns Write low to data Hi-Z 3 tWLQZ 0 12 ns Write high to output active 3 tWHQX 3 - ns Write recovery time tWHAX 12 - ns Notes: 1. All write occurs during the overlap of E low and W low. Power supplies must be properly grounded and decoupled and bus contention conditions must be minimized or eliminated during read and write cycles. If G goes low at the same time or after W goes low, the output will remain in a high impedance state. After W, E or UB/LB has been brought high, the signal must remain in steady-state high for a minimum of 2 ns. The minimum time between E being asserted low in one cycle to E being asserted low in a subsequent cycle is the same as the minimum cycle time allowed for the device. 2. All write cycle timings are referenced from the last valid address to the first transition address. 3. This parameter is sampled and not 100% tested. Transition is measured ±200 mV from the steady-state voltage. At any given voltage or temperate, tWLQZ(max) < tWHQX(min) Figure 8 – Write Cycle Timing 1 (W Controlled) t AVAV A (ADDRESS) t AVWH t WHAX E (CHIP ENABLE) t WLEH t WLWH W (WRITE ENABLE) t AVWL t DVWH D (DATA IN) t WHDX DATA VALID t WLQZ Q (DATA OUT) Hi -Z Hi -Z t WHQX Copyright © Everspin Technologies 2018 12 MR2A16A Rev. 11.3 3/2018 MR2A16A Table 10 – Write Cycle Timing 2 (E Controlled) Parameter 1 Symbol Min Max Unit Write cycle time 2 tAVAV 35 - ns Address set-up time tAVEL 0 - ns Address valid to end of write (G high) tAVEH 18 - ns Address valid to end of write (G low) tAVEH 20 - ns 15 - ns 15 - ns tELEH Enable to end of write (G high) tELWH tELEH Enable to end of write (G low) 3 tELWH Data valid to end of write tDVEH 10 - ns Data hold time tEHDX 0 - ns Write recovery time tEHAX 12 - ns Notes: 1. All write occurs during the overlap of E low and W low. Power supplies must be properly grounded and decoupled and bus contention conditions must be minimized or eliminated during read and write cycles. If G goes low at the same time or after W goes low, the output will remain in a high impedance state. After W, E or UB/LB has been brought high, the signal must remain in steady-state high for a minimum of 2 ns. The minimum time between E being asserted low in one cycle to E being asserted low in a subsequent cycle is the same as the minimum cycle time allowed for the device. 2. All write cycle timings are referenced from the last valid address to the first transition address. 3. If E goes low at the same time or after W goes low, the output will remain in a high-impedance state. If E goes high at the same time or before W goes high, the output will remain in a high-impedance state. Figure 9 – Write Cycle Timing 2 (E Controlled) t AVAV A (ADDRESS) t EHAX t AVEH t ELEH E (CHIP ENABLE) t AVEL t ELWH W (WRITE ENABLE) UB, LB (BYTE ENABLE) t DVEH D (DATA IN) Q (DATA OUT) Copyright © Everspin Technologies 2018 t EHDX Data Valid Hi-Z 13 MR2A16A Rev. 11.3 3/2018 MR2A16A Table 11 – Write Cycle Timing 3 (LB / UB Controlled) Parameter 1 Symbol Min Max Unit Write cycle time 2 tAVAV 35 - ns Address set-up time tAVBL 0 - ns Address valid to end of write (G high) tAVBH 18 - ns Address valid to end of write (G low) tAVBH 20 - ns 15 - ns 15 - ns tBLEH Write pulse width (G high) tBLWH tBLEH Write pulse width (G low) tBLWH Data valid to end of write tDVBH 10 - ns Data hold time tBHDX 0 - ns Write recovery time tBHAX 12 - ns Notes: 1. All write occurs during the overlap of E low and W low. Power supplies must be properly grounded and decoupled and bus contention conditions must be minimized or eliminated during read and write cycles. If G goes low at the same time or after W goes low, the output will remain in a high impedance state. After W, E or LB/UB has been brought high, the signal must remain in steady-state high for a minimum of 2 ns. If both byte control signals are asserted, the two signals must have no more than 2 ns skew between them. The minimum time between E being asserted low in one cycle to E being asserted low in a subsequent cycle is the same as the minimum cycle time allowed for the device. 2. All write cycle timings are referenced from the last valid address to the first transition address. Figure 10 – Write Cycle Timing 3 (LB / UB Controlled) t AVAV A (ADDRESS) t AVEH t BHAX E (CHIP ENABLE) W (WRITE ENABLE) t AVBL t BLEH t BLWH UB, LB (BYTE ENABLED) t DVBH D (DATA IN) Q (DATA OUT) t BHDX Data Valid Hi -Z Copyright © Everspin Technologies 2018 Hi -Z 14 MR2A16A Rev. 11.3 3/2018 MR2A16A ORDERING INFORMATION Table 12 – Ordering Part Number System for Parallel I/O MRAM MRAM 256 Kb 1 Mb 4 Mb 16 Mb Example Ordering Part Number MR 256 0 2 4 Async 3.3v Type A I/O Width 16 Rev. A Temp Package Speed C MA 35 Packing R Grade A Async 3.3v Vdd and 1.8v Vddq D Async 3.3v Vdd and 1.8v Vddq with 2.7v min. Vdd DL 8-bit 16-bit Rev A Rev B Commercial 0 to 70°C Industrial -40 to 85°C Extended -40 to 105°C AEC Q-100 Grade 1 -40 to 125°C 44-TSOP-2 48-FBGA 16-SOIC 32-SOIC 35 ns 45 ns Tray Tape and Reel Engineering Samples Customer Samples Mass Production Memory Density MR 2 8 16 A B Blank C V M YS MA SC SO 35 45 Blank R ES Blank Blank Copyright © Everspin Technologies 2018 15 MR2A16A Rev. 11.3 3/2018 MR2A16A Table 13 – MR2A16A Ordering Part Numbers Temp Grade Temp Package Shipping 44-TSOP2 Commercial 0 to +70 °C 48-BGA 44-TSOP2 Industrial -40 to +85 °C 48-BGA 44-TSOP2 Extended -40 to +105 °C 48-BGA Automotive AECQ100 Grade 1 -40 to +125 °C Copyright © Everspin Technologies 2018 44-TSOP2 16 Ordering Part Number Tray MR2A16AYS35 Tape and Reel MR2A16AYS35R Tray MR2A16AMA35 Tape and Reel MR2A16AMA35R Tray MR2A16ACYS35 Tape and Reel MR2A16ACYS35R Tray MR2A16ACMA35 Tape and Reel MR2A16ACMA35R Tray MR2A16AVYS35 Tape and Reel MR2A16AVYS35R Tray MR2A16AVMA35 Tape and Reel MR2A16AVMA35R Tray MR2A16AMYS35 Tape and Reel MR2A16AMYS35R MR2A16A Rev. 11.3 3/2018 MR2A16A PACKAGE OUTLINE DRAWINGS Figure 11 – 44-TSOP2 Package Outline 44 PLACES 1. 2. 3. 4. Print Version Not To Scale Dimensions and tolerances per ASME Y14.5M - 1994. Dimensions in Millimeters. Dimensions do not include mold protrusion. Dimension does not include DAM bar protrusions. DAM Bar protrusion shall not cause the lead width to exceed 0.58. 44 PLACES Copyright © Everspin Technologies 2018 17 MR2A16A Rev. 11.3 3/2018 MR2A16A Figure 12 – 48-FBGA Packge Outline Notes: 1. Dimensions in Millimeters. 2. Dimensions and tolerances per ASME Y14.5M - 1994. 3. Maximum solder ball diameter measured parallel to DATUM A 4. DATUM A, the seating plane is determined by the spherical crowns of the solder balls. 5. Parallelism measurement shall exclude any effect of mark on top surface of package. Copyright © Everspin Technologies 2018 18 MR2A16A Rev. 11.3 3/2018 MR2A16A REVISION HISTORY Revision Date Description of Change 5 Sept 21, 2007 Changed MR2A16ATS35C product description to Legacy Commercial. Added the New Commerical temperature product (MR2A16AYS35) information. Table 3: MR2A16AYS35 Hmaxwrite=25 Oe. Table 4: MR2A16AYS35 has a 2 ms power up waiting period. Table 6: Applied values to TBD’s in IDD specifications. 6 Nov 12, 2007 Table 2: Changed IDDA to IDDR or IDDW. Table 13: Added noteindicating that TS and YS are both valid package codes. Current Part Numbering System: Added commercial (missing letter) temperature range. 7 Sep 12, 2008 Reformat Datasheet for EverSpin, Add BGA Packaging Information, Add Tape & Reel Part Numbers, Add Power Sequencing Info, Correct IOH spec of VOH to -100 uA, Correct ac Test Conditions. 8 July 22, 2009 Add TSOP2 Lead Cross-Section, Add Production Note. Converted to new document format. 9 Dec 16, 2011 Added AEC-Q100 Grade 1 product option for TSOP2 package to Table 4.1. Revised Tables 2.1, 2.2 and 4.1 to include AEC-Q100 Grade 1 specifications. New logo design. 10 August 29, 2012 Corrected error in Table 1.1. Corrected Figure 2.1. Improved magnetic immunity for Industrial and Extended Grades. Corrected minor errors in Table 4.1 Product Numbering. 10.1 July 30, 2013 Corrected G to read G for 44-TSOP Type2 in Figure 1.2. 11 October 14, 2013 MR2A16AMYS35/R is released from Preliminary to fully qualified. Reformatted to meet current standards. 11.1 May 19, 2015 Revised Everspin contact information. 11.2 June 11, 2015 Corrected Japan Sales Office telephone number. 11.3 March 23, 2018 Updated the Contact Us table Copyright © Everspin Technologies 2018 19 MR2A16A Rev. 11.3 3/2018 MR2A16A HOW TO CONTACT US How to Reach Us: Home Page: www.everspin.com Everspin Technologies, Inc. Information in this document is provided solely to enable system and software implementers to use Everspin Technologies products. There World Wide Information Request are no express or implied licenses granted hereunder to design or WW Headquarters - Chandler, AZ fabricate any integrated circuit or circuits based on the information 5670 W. Chandler Blvd., Suite 100 in this document. Everspin Technologies reserves the right to make Chandler, Arizona 85226 changes without further notice to any products herein. Everspin makes Tel: +1-877-480-MRAM (6726) no warranty, representation or guarantee regarding the suitability of its Local Tel: +1-480-347-1111 Fax: +1-480-347-1175 products for any particular purpose, nor does Everspin Technologies assupport@everspin.com sume any liability arising out of the application or use of any product or orders@everspin.com circuit, and specifically disclaims any and all liability, including without sales@everspin.com limitation consequential or incidental damages. “Typical” parameters, which may be provided in Everspin Technologies data sheets and/ Europe, Middle East and Africa or specifications can and do vary in different applications and actual Everspin Europe Support performance may vary over time. All operating parameters including support.europe@everspin.com “Typicals” must be validated for each customer application by customer’s technical experts. Everspin Technologies does not convey any Japan Everspin Japan Support license under its patent rights nor the rights of others. Everspin Techsupport.japan@everspin.com nologies products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or Asia Pacific other applications intended to support or sustain life, or for any other Everspin Asia Support application in which the failure of the Everspin Technologies product support.asia@everspin.com could create a situation where personal injury or death may occur. Should Buyer purchase or use Everspin Technologies products for any such unintended or unauthorized application, Buyer shall indemnify Filename: and hold Everspin Technologies and its officers, employees, subsidiarEST00193_MR2A16A_Datasheet_Rev11.3 032318 ies, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that Everspin Technologies was negligent regarding the design or manufacture of the part. Everspin™ and the Everspin logo are trademarks of Everspin Technologies, Inc. All other product or service names are the property of their respective owners. Copyright © Everspin Technologies, Inc. 2018 Copyright © Everspin Technologies 2018 20 MR2A16A Rev. 11.3 3/2018
MR2A16AYS35R 价格&库存
很抱歉,暂时无法提供与“MR2A16AYS35R”相匹配的价格&库存,您可以联系我们找货
