HCS Series
Stackpole Electronics, Inc.
High Current Metal Element Shunt Resistor
Resistive Product Solutions
Features:
Metal element shunt resistor
Available in up to 10W power rating
Resistance value from 0.1 to 5mΩ
Current handling up to 316A in 5930 size
Excellent long-term stability
AEC-Q200 qualified
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Applications:
Power modules
Frequency converters
Current sensor for power hybrid sources
High current handling for automotive engine controls and power management
Electrical Specifications
Type / Code
Power Rating (W)
@ 100°C
Power Rating (W)
@ 70°C
HCS1206
2
±300
±200
±150
±150
±115
±115
±100
±50
±50
±50
±50
±200
±150
±70
±50
±50
±50
±50
±50
±300
±100
±100
±75
±50
±50
±50
6
3
5
HCS2512
4
3
2.5
2
4
3
2.5
12
10
9
7
6
5
4
3
10
15
7
10
8
9
7
2
1.5
5
HCS3920
HCS5930
6
4
3
Rev Date: 5/12/2022
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
TCR (ppm/ºC)
1
Ohmic Range (Ω) and Tolerance
1% and 5%
0.0003
0.0005
0.001
0.0003
0.0005
0.00075
0.001
0.002
0.003
0.004
0.005
0.0002
0.0003
0.0005
0.001
0.002
0.003
0.004
0.005
0.0001
0.0002
0.0003
0.0005
0.001
0.002
0.003
www.seielect.com
marketing@seielect.com
HCS Series
Mechanical Specifications
L
Type / Code
HCS1206…L300
HCS1206…L500
HCS1206…1L00
HCS2512…L300
HCS2512…L500
HCS2512…L750
HCS2512…1L00
HCS2512…2L00
HCS2512…3L00
HCS2512…4L00
HCS2512…5L00
HCS3920…L200
HCS3920…L300
HCS3920…L500
HCS3920…1L00
HCS3920…2L00
HCS3920…3L00
HCS3920…4L00
HCS3920…5L00
0.126
3.20
0.126
3.20
0.126
3.20
0.256
6.50
0.256
6.50
0.256
6.50
0.256
6.50
0.256
6.50
0.256
6.50
0.256
6.50
0.256
6.50
0.402
10.20
0.402
10.20
0.402
10.20
0.402
10.20
0.402
10.20
0.402
10.20
0.402
10.20
0.402
10.20
W
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.065
1.65
0.065
1.65
0.065
1.65
0.128
3.25
0.128
3.25
0.128
3.25
0.128
3.25
0.128
3.25
0.128
3.25
0.128
3.25
0.128
3.25
0.205
5.20
0.205
5.20
0.205
5.20
0.205
5.20
0.205
5.20
0.205
5.20
0.205
5.20
0.205
5.20
H
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
T
NA
NA
NA
0.046
1.17
0.042
1.07
0.037
0.95
0.029
0.73
0.038
0.96
0.030
0.76
0.026
0.66
0.026
0.66
0.078
1.98
0.076
1.92
0.054
1.36
0.036
0.92
0.047
1.19
0.037
0.94
0.033
0.85
0.033
0.85
Rev Date: 5/12/2022
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.047
1.20
0.035
0.90
0.035
0.90
0.032
0.82
0.028
0.72
0.024
0.60
0.015
0.38
0.024
0.61
0.016
0.41
0.012
0.31
0.012
0.31
0.058
1.48
0.056
1.42
0.034
0.86
0.017
0.42
0.027
0.69
0.017
0.44
0.014
0.35
0.014
0.35
2
A
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.006
0.15
0.031
0.80
0.031
0.80
0.031
0.80
0.035
0.90
0.035
0.90
0.035
0.90
0.035
0.90
0.035
0.90
0.035
0.90
0.035
0.90
0.035
0.90
0.071
1.80
0.071
1.80
0.071
1.80
0.071
1.80
0.071
1.80
0.071
1.80
0.071
1.80
0.071
1.80
P
C (max.)
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
NA
NA
NA
NA
NA
NA
0.016
0.40
0.016
0.40
0.016
0.40
0.016
0.40
0.016
0.40
0.016
0.40
0.016
0.40
0.016
0.40
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.014
0.35
0.014
0.35
0.014
0.35
0.014
0.35
0.014
0.35
0.014
0.35
0.014
0.35
0.014
0.35
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
Unit
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
HCS Series
Mechanical Specifications (cont.)
L
Type / Code
W
H
T
A
P
C (max.)
Unit
HCS5930…L100
0.591 ± 0.008 0.305 ± 0.008 0.098 ± 0.006 0.079 ± 0.006 0.165 ± 0.008
15.00 ± 0.20
7.75 ± 0.20
2.50 ± 0.15
2.00 ± 0.15
4.20 ± 0.20
0.039
1.00
0.020 ± 0.004 inches
0.50 ± 0.10
mm
HCS5930…L200
0.591 ± 0.008 0.305 ± 0.008 0.076 ± 0.006 0.056 ± 0.006 0.165 ± 0.008
15.00 ± 0.20
7.75 ± 0.20
1.92 ± 0.15
1.42 ± 0.15
4.20 ± 0.20
0.039
1.00
0.50 ± 0.10
mm
HCS5930…L300
0.591 ± 0.008 0.305 ± 0.008 0.057 ± 0.006 0.037 ± 0.006 0.165 ± 0.008
15.00 ± 0.20
7.75 ± 0.20
1.44 ± 0.15
0.94 ± 0.15
4.20 ± 0.20
0.039
1.00
0.50 ± 0.10
mm
HCS5930…L500
0.591 ± 0.008 0.305 ± 0.008 0.043 ± 0.006 0.023 ± 0.006 0.165 ± 0.008
15.00 ± 0.20
7.75 ± 0.20
1.08 ± 0.15
0.58 ± 0.15
4.20 ± 0.20
0.039
1.00
0.50 ± 0.10
mm
HCS5930…1L00
0.591 ± 0.008 0.305 ± 0.008 0.054 ± 0.006 0.034 ± 0.006 0.165 ± 0.008
15.00 ± 0.20
7.75 ± 0.20
1.37 ± 0.15
0.87 ± 0.15
4.20 ± 0.20
0.039
1.00
0.50 ± 0.10
mm
HCS5930…2L00
0.591 ± 0.008 0.305 ± 0.008 0.037 ± 0.006 0.018 ± 0.006 0.165 ± 0.008
15.00 ± 0.20
7.75 ± 0.20
0.95 ± 0.15
0.45 ± 0.15
4.20 ± 0.20
0.039
1.00
0.50 ± 0.10
mm
HCS5930…3L00
0.591 ± 0.008 0.305 ± 0.008 0.035 ± 0.006 0.016 ± 0.006 0.165 ± 0.008
15.00 ± 0.20
7.75 ± 0.20
0.90 ± 0.15
0.40 ± 0.15
4.20 ± 0.20
0.039
1.00
0.50 ± 0.10
mm
Power Derating Curve:
Environmental Performance Characteristics
Test
Test Specification
Test Condition
Short Time Overload
ΔR: ± (1% + 0.0005Ω)
5 times rated power for 5 seconds
Temperature Coefficient of
Resistance (TCR)
Refer to
Moisture Resistance
The specimens shall be placed in a chamber and subjected to a relative
humidity of 90 ~ 98% and a temperature of 25ºC / 65ºC, 10 cycles.
(MIL-STD-202, Method 106)
High Temperature Exposure
The chip (mounted on board) is exposed in the heat chamber,
125ºC for 1000 hours (JIS-C5202-7.2)
Load Life
Apply rated power for 1000 hours with 1.5 hours ON and 0.5 hour OFF.
(JIS-C5202-7.10)
+25ºC / +125ºC (JIS-C5202-5.2)
Rev Date: 5/12/2022
3
www.seielect.com
HCS Series
Environmental Performance Characteristics (cont.)
Test
Test Specification
Test Condition
The chip (mounted on board) is exposed, - 55 ± 3ºC (30 min) / +125 ± 2ºC
(30 minutes) for 5 cycles. The following conditions as the figure below.
(JIS_C5202-7.4)
Rapid Change of Temperature
Operating temperature range is -55°C to +170°C
Storage condition is 22°C to 28°C, humidity is of 40% to 75%.
Function Performance Characteristics
Test
Test Specification
Test Condition
Mount the chip to test 90 mm (L)*40 mm (W) FR4 printed circuit board
substrate. Apply pressure in direction of arrow unit band width reaches
2 mm (+0.2 / -0 mm) illustrated in the picture below and hold for 10 ± 1
seconds (JIS-C5202-6.1)
Bending Strength
The part shall be immersed into the flux specified in the solder bath
235ºC ± 5ºC for 2 seconds ± 0.5 seconds. It shall be immersed to a point
10 mm from its root.
(Sn96.5/Ag3.0/Cu0.5) (JIS-C5 202 6.11)
Solderability
Solder shall cover 95% or more
of the electrode area
Note: The terminal temperature of component should be below 100ºC.
Rev Date: 5/12/2022
4
www.seielect.com
HCS Series
Taping Specifications – Embossed Plastic Tape
Type / Code
HCS1206
HCS2512
(all Ω ranges)
HCS3920
(all Ω ranges)
HCS5930
(all Ω ranges)
A
0.074
1.88
0.140
3.55
0.217
5.50
0.327
8.30
Type / Code
HCS1206
HCS2512
(0.0003Ω, 0.0005Ω, 0.00075Ω, 0.002Ω)
HCS2512
(0.001Ω, 0.003Ω)
HCS2512
(0.004Ω, 0.005Ω)
HCS3920
(0.0002Ω, 0.0003Ω, 0.0005Ω, 0.002Ω)
HCS3920
(0.001Ω, 0.003Ω, 0.004Ω, 0.005Ω)
HCS5930
(0.0001Ω, 0.0002Ω, 0.0003Ω, 0.001Ω)
HCS5930
(0.0005Ω, 0.002Ω, 0.003Ω)
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
B
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.140
3.56
0.266
6.75
0.425
10.80
0.606
15.40
P0
± 0.004
± 0.10
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.004
± 0.10
± 0.004
± 0.10
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.315
8.00
0.315
8.00
0.472
12.00
0.472
12.00
E
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
P1
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
F
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.138
3.50
0.217
5.50
0.295
7.50
0.453
11.50
P2
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.004
± 0.10
± 0.004
± 0.10
0.061
1.55
0.059
1.50
0.059
1.50
0.059
1.50
0.059
1.50
0.059
1.50
0.059
1.50
0.059
1.50
W
Unit
0.002
0.05
0.002
0.05
0.002
0.05
0.004
0.10
0.315
8.00
0.472
12.00
0.630
16.00
0.945
24.00
0.004
0.10
0.008
0.20
0.008
0.20
0.012
0.30
inches
mm
inches
mm
inches
mm
inches
mm
D0
± 0.002
± 0.05
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
0.055
1.40
0.055
1.40
0.043
1.10
0.031
0.80
0.078
1.97
0.049
1.25
0.094
2.40
0.055
1.40
T
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Recommended Pad Layouts
Type / Code
a
b
c
Unit
1206
0.055
1.40
0.067
1.70
0.071
1.80
inches
mm
2512
0.150
3.80
0.071
1.80
0.134
3.40
3920
0.220
5.60
0.106
2.70
0.244
6.20
5930
0.220
5.60
0.205
5.20
0.344
8.75
inches
mm
inches
mm
inches
mm
Rev Date: 5/12/2022
5
www.seielect.com
HCS Series
Soldering Recommendations:
Peak reflow temperatures and durations
✓ IR Reflow Peak = 260ºC max for 10 seconds
✓ Not suitable for wave soldering
Compatible with lead and lead-free solder reflow processes
Recommended IR reflow profile:
Pulsed Power Characteristics – HCS1206
Rev Date: 5/12/2022
6
www.seielect.com
HCS Series
Pulsed Power Characteristics – HCS2512
Pulsed Power Characteristics – HCS3920
Rev Date: 5/12/2022
7
www.seielect.com
HCS Series
Pulsed Power Characteristics – HCS5930
Rated Power vs. Surface Temperature – HCS1206
Rev Date: 5/12/2022
8
www.seielect.com
HCS Series
Rated Power vs. Surface Temperature – HCS2512
Rated Power vs. Surface Temperature – HCS3920
Rev Date: 5/12/2022
9
www.seielect.com
HCS Series
Rated Power vs. Surface Temperature – HCS5930
Temperature rise test boards use aluminum substrate (MCPCB).
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
Package /
Termination
Type
HCS
High Current Shunt Resistor
SMD
Standard
Series
RoHS
Compliant
YES
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
100% Copper
Always
Lead-Free
Effective Date
Code
(YY/WW)
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Rev Date: 5/12/2022
10
www.seielect.com
HCS Series
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
H
C
S
3
9
2
F
T
L
3
Product Series
HCS
Size
1206
2512
3920
5930
Tolerance
Code
Tol
F
1%
J
5%
Code
T
Packaging
Description
7" Reel - Plastic Tape
10" Reel - Plastic Tape
13" Reel - Plastic Tape
Resistance Value
Size
1206
2512
3920
5930
Quantity
2000
4000
3000
2000
Four characters with
"L" used as multiplier
of 10-3 for any value
under 0.1 ohm
0.0003 ohm = L300
0.0005 ohm = L500
0.00075 ohm = L750
0.001 ohm = 1L00
Rev Date: 5/12/2022
11
www.seielect.com
很抱歉,暂时无法提供与“HCS3920FTL500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+4.466893000+0.58023
- 6000+4.188336000+0.54405
- 9000+4.045259000+0.52546
- 15000+3.8834715000+0.50445
- 21000+3.7870521000+0.49192
- 国内价格 香港价格
- 1+13.935531+1.81016
- 10+9.1428610+1.18761
- 25+7.8508125+1.01978
- 50+7.0430450+0.91486
- 100+6.35544100+0.82554
- 250+5.60172250+0.72764
- 500+5.13018500+0.66639
- 1000+4.729341000+0.61432
