14305R-ES
14305R-ES
    ECHELON
    VFQFN48_EP
    NEU 5000 PROC 48QFN 1=1 PIECE
14305R-ES 数据手册
Neuron® 5000 Processor The Next-generation Neuron Chip for LONWORKS® Control Networks ® Combined with inexpensive serial memory, the Neuron 5000 Processor provides a lower-cost, higher-performance LonWorks solution than those based on previous-generation Neuron 3120® and Neuron 3150® chips. The Neuron 5000 Processor incorporates communication and control functions on a single chip, in both hardware and firmware, to facilitate the design of a LONWORKS device. Its flexible 5-pin communications port can be configured to interface with a wide variety of media transceivers — including twistedpair, RF, IR, fiber-optics, and coaxial — at a wide range of data rates. Features • 3.3V operation. • Higher-performance Neuron® Core —internal system clock scales up to 80 MHz. • Enables lower-cost device designs. • Serial memory interface for inexpensive external EEPROM and flash non-volatile memories. • Supports up to 254 Network Variables (NVs) and 127 aliases. • User programmable interrupts provide faster response time to external events. • Includes hardware UART with 16-byte receive and transmit FIFOs. • 7mm x 7mm 48-pin QFN package. • 5-pin network communications port with 3.3V drive and 5V-tolerant pins. • 12 I/O pins with 35 programmable standard I/O models. • Supports up to 42KB of application code space. • 64KB RAM (44KB user accessible) and 16KB ROM on-chip memories. • Unique 48-bit Neuron ID in every device for network installation and management. • -40°C to +85°C operating temperature range. www.echelon.com ® Description The Neuron 5000 Processor includes 3 independent 8-bit logical processors to manage the physical MAC layer, the network, and the user application. These are called the Media-Access Control (MAC) processor, the network (NET) processor, and the application (APP) processor, respectively (see Figure 1). At higher system clock rates, there is also a fourth processor to handle interrupts. 12 / NVM (SPI or I2C) 2-6 / I/O Comm Port Serial Memory Interface IRQ CPU 5 / External Transformer APP CPU RAM (64K x 8) NET CPU ROM (16K x 8) MAC CPU SVC~ RST~ XOUT XIN Clock, Reset, and Service JTAG 5 Figure 1: Neuron 5000 Processor Backward Compatibility The pins for the Neuron 5000 Processor’s communications port drive a 3.3V signal and are 5V input-tolerant. Thus, the Neuron 5000 Processor is compatible with 3.3V transceivers and with 5V transceivers that have TTL-compatible input. The Neuron 5000 Processor is compatible with TP/XF-1250 and EIA-485 channels, and can be used with the LonWorks LPT-11 Link Power Transceiver. It also supports a variety of other channels used with previous-generation Neuron Chips, such as RF, IR, fiber-optic, and coaxial. It does not, however, support a TP/XF-78 channel. To support a TP/FT-10 channel, use an Echelon Free Topology Smart Transceiver (FT 5000 Smart Transceiver); to support a PL-20 power line channel, use an Echelon Power Line Smart Transceiver (PL 3120/3150/3170 Smart Transceiver). Echelon’s Smart Transceivers integrate the transceiver for the channel type and the Neuron Core into a single chip, which enables smaller designs and provides cost savings. The Neuron Core in the Neuron 5000 Processor uses the same instruction set and architecture as the previous-generation Neuron Core, with 2 new additional instructions for hardware multiplication and division. The Series 5000 Neuron Core is source code compatible with applications written for the Series 3100 Neuron Core. Applications written for the Series 3100 Neuron Core must be recompiled with the NodeBuilder ® FX Development Tool or the Mini FX Evaluation Kit before they can be used with the Neuron 5000 Processor. The Neuron 5000 Processor uses Neuron firmware version 19. Firmware versions prior to version 19 are not compatible with the Neuron 5000 Processor. The Neuron firmware is pre-programmed into the onchip ROM. The Neuron 5000 Processor can also be configured to read newer firmware from external memories, allowing the firmware to be upgraded over time. Enhanced Performance Faster system clock. The internal system clock for the Neuron 5000 Processor can be user-configured to run from 5MHz to 80MHz. The required external crystal provides a 10MHz clock frequency, and an internal PLL boosts the frequency to a maximum of 80MHz as the internal system clock speed. The previous-generation Neuron 3120/3150 Core divided the external oscillator frequency by two to create the internal system clock. Hence, a Neuron 3120/3150 Core running with a 10MHz external crystal had a 5MHz internal system clock. A Neuron 5000 Processor running with an 80MHz internal clock is thus 16 times faster than a 10MHz Neuron 3120/3150 Core running with a 5MHz internal system clock. The 5MHz system clock mode in the Neuron 5000 Processor provides backward compatibility to support time-critical applications designed for the 10MHz Neuron 3150 or Neuron 3120 processor. The Neuron Core inside the Neuron 5000 Processor includes a built-in hardware multiplier and divider to increase the performance of arithmetic operations. Support for more network variables. Because it uses Neuron system firmware Version 19, the Neuron 5000 Processor supports applications with up to 254 network variables and 127 aliases for Neuron hosted devices (devices without a host microprocessor). A Series 3100 Neuron Chip or Smart Transceiver with Neuron firmware Version 15 or earlier supports up to 62 network variables and 62 aliases for Neuron hosted devices. Series 3100 chips with Neuron firmware version 16 or later support up to 254 network variables. You must use the NodeBuilder FX Development Tool to take advantage of 254 network variables. Interrupts. The Neuron 5000 Processor lets developers define application interrupts to handle asynchronous events triggered by selected state changes on any of the 12 I/O pins, by on-chip hardware timer-counter units, or by an on-chip high- performance hardware system timer. An application uses the Neuron C interrupt() clause to define the interrupt condition and the interrupt task that handles the condition. The Neuron C program runs the interrupt task whenever the interrupt condition is met. See the Neuron C Programmer’s Guide for more information about writing interrupt tasks and handling interrupts. JTAG. The Neuron 5000 Processor provides an interface for the Institute of Electrical and Electronics Engineers (IEEE) Standard Test Access Port and BoundaryScan Architecture (IEEE 1149.1-1990) of the Joint Test Action Group (JTAG) to allow a Series 5000 chip to be included in the boundary-scan chain for device production tests. A Boundary Scan Description Language (BSDL) file for the Neuron 5000 Processor can be downloaded from Echelon’s Web site. Communications Port The Neuron 5000 Processor includes a versatile 5-pin communications port that can be configured in two ways: 3.3 V Single-Ended Mode and 3.3 V SpecialPurpose Mode. In Single-Ended Mode, pin CP0 is used for receiving serial data, pin CP1 for transmitting serial data, and pin CP2 for enabling an external transmitter. Data is communicated using Differential Manchester encoding. In Special-Purpose Mode, pin CP0 is used for receiving serial data, pin CP1 for transmitting serial data, pin CP2 transmits a bit clock, and pin CP4 transmits a frame clock for use by an external intelligent transceiver. In this mode, the external transceiver is responsible for encoding and decoding the data stream. Unlike the Neuron 3120/3150 Chips, the Neuron 5000 Processor does not support the Differential Mode configuration for the communications port. Thus, devices that require Differential Mode transceiver types must be redesigned for a Neuron 5000 Processor to use Single-Ended Mode with external circuitry to provide Single-Ended to Differential Mode conversions. See the Series 5000 Chip Data Book and the Connecting a Neuron 5000 Processor to an External Transceiver Engineering Bulletin for more information. Any 3.3V transceiver or a 5V transceiver with TTL-compatible inputs can be used with the Neuron 5000 Processor because the communications port has pins that are 5V tolerant and drive a 3.3V signal. Common transceiver types that can be used with a Neuron 5000 Processor include twisted-pair, RF, IR, fiber-optic, and coaxial. www.echelon.com ® I/O Pins and Counters The Neuron 5000 Processor provides 12 bidirectional I/O pins that are 5V tolerant and can be configured to operate in one or more of 35 predefined standard input/ output models. The chip also has two 16-bit timer/counters that reduce the need for external logic and software development. Configuration 2 EEPROM I2C Flash SPI ☑ SPI ☑ Memory Architecture The Neuron 5000 Processor uses inexpensive external serial EEPROM and flash memories for non-volatile application and data storage, and optionally for future Neuron firmware upgrades. It has 16KB of ROM and 64KB (44 KB user-accessible) of RAM on the chip. It has no on-chip non-volatile memory (EEPROM or flash) for application use. Each chip, however, contains its unique Neuron identifier (Neuron ID) in an on-chip, non-volatile, read-only memory. The application code and configuration data are stored in the external non-volatile memory (NVM) and copied into the internal RAM during device reset; the instructions then execute from internal RAM. Writes to NVM are shadowed in the internal RAM and pushed out to external NVM by the Neuron firmware (see Figure 1). The application does manage NVM directly. External memories supported. The Neuron 5000 Processor supports two serial interfaces for accessing off-chip non-volatile memories: serial Inter-Integrated Circuit (I2C) and serial peripheral interface (SPI). EEPROM and flash memory devices can use either the I2C interface or the SPI interface; flash memory devices must use the SPI interface. External serial EEPROMs and flash devices, which are inexpensive and come in very small form factors, are available from many vendors. The Neuron 5000 Processor requires at least 2KB of off-chip memory available in an EEPROM device to store the configuration data. The application code can be stored either in the EEPROM (by using a larger-capacity EEPROM device) or in a flash memory device used in addition to the 2KB (minimum) EEPROM. Thus, the external memory for a Neuron 5000 Processor has one of the configurations listed in Table 1: Configuration 1 EEPROM I2C ☑ SPI Flash SPI Comments A single I2C EEPROM memory device, from 2KB to 64KB in size. 3 4 Comments One I2C EEPROM (at least 2KB in size, up to 64KB in size, but the system uses only the first 2KB of the EEPROM memory). One SPI flash memory device. ☑ A single SPI EEPROM memory device, from 2KB to 64KB in size. ☑ ☑ One SPI EEPROM (at least 2KB in size, up to 64KB in size, but the system uses only the first 2KB of the EEPROM memory). One SPI flash memory device. Table 1: Allowed External Memory Device Configurations As Table 1 shows, the Neuron 5000 Processor supports using a single EEPROM memory device, or a single EEPROM memory device plus a single flash memory device. If the Neuron 5000 Processor detects an external flash memory device, the flash memory represents the entire user nonvolatile memory for the device. That is, any additional EEPROM memory beyond the mandatory 2KB is not used. Using the I2C interface. When using the I2C interface for external EEPROM, the Neuron 5000 Processor is always the master I2C device (see Figure 2). The clock speed supported for the I2C serial memory interface is 400kHz (fast I2C mode). The I2C memory device must specify I2C address 0. Both 1-byte and 2-byte address modes are supported, but 3-byte addressing mode is not. 3.3 V SCL Series 5000 Chip SDA_CS1~ MISO I2C Slave (EEPROM) Figure 2: Using the I C Interface for External NVM EEPROM Memory 2 support up to two SPI slave devices from the serial memory interface: one EEPROM device at CS0~ and one flash device at CS1~ (see Figure 3). The Neuron 5000 Processor supports 2-byte addressing mode for SPI EEPROM devices, but does not support 3-byte addressing. The Neuron 5000 Processor runs the SPI protocol from the serial memory interface at 2.5MHz and supports SPI Mode 0. In Mode 0, the base value of the clock is zero; the data is read on the clock’s rising edge and changed on the clock’s falling edge. Most external NVMs support SPI Modes 0 and 3. SDA_CS1~ CS0~ Series 5000 Chip SCK MOSI MISO SPI Slave (EEPROM) SPI Slave (Flash) Figure 3: Using the SPI Interface for External NVM Memories Using both I2C and SPI interfaces. Figure 4 shows a Neuron 5000 Processor that includes both an I2C memory device (a 2KB EEPROM device) and a SPI memory device (a flash memory device). Although both EEPROM and flash memory share the SDA_CS1~ pin, there is no conflict because only one of them can be active at a time. SDA is an active high signal and CS1~ is an active low signal. While small applications could use EEPROM both for application code and configuration data, larger applications might find it economical to use a small EEPROM for configuration data and a flash device for application code. The choice between EEPROM and flash can be affected by multiple factors, including: • Use of a single external memory versus two memories. • Cost comparison between a large EEPROM device and a combination of a small EEPROM and large flash devices. • Use of non-volatile variables by the application, which can require a large number of writes to the device. Using the SPI interface. The Neuron 5000 Processor is always the master SPI device; any external NVM devices are always slave devices. The Neuron 5000 Processor can www.echelon.com ® 3.3 V SCL SDA_CS1~ Series 5000 Chip requires a hardware redesign of the boards. • On-chip RAM for stack segments and RAMNEAR data. • Mandatory external EEPROM that holds configuration data and nonvolatile application variables. CS0~ SCK MOSI MISO • Reserved space for system use. I2C Slave (EEPROM) SPI Slave (Flash) Figure 4: Using both I C and SPI Interfaces for External NVM Memories 2 Memory devices supported. The Neuron 5000 Processor supports any EEPROM device that uses the SPI or I2C protocol, and meets the clock speed and addressing requirements described above. If a 64KB external serial EEPROM or flash device is used, the maximum allowed size of application code is 42KB as defined by extended NVM area in the memory map. An additional 16KB of the remaining space can hold an external system firmware image, in case a future firmware upgrade is required. 0xF800 to 0xFFFF 0xF000 to 0xF7FF 0xE800 to 0xEFFF While all EEPROM devices have a uniform write procedure, flash devices from various manufacturers differ slightly in their write procedure. Thus, a small library routine is stored in the external EEPROM device that helps the system write successfully to the external flash device. Echelon has qualified the following SPI flash memory devices for use with the Neuron 5000 Processor: Reserved Mandatory EEPROM On-Chip RAM 2 KB 2 KB 2 KB • Silicon Storage Technology SST25VF512A 512 Kbit SPI Serial Flash. • Additional devices may be qualified in the future. Memory map. A Neuron 5000 Processor has a memory map of 64KB. A Neuron C application program uses this memory map to organize its memory and data access. The memory map is a logical view of device memory, rather than a physical view, because the chip’s processors only directly access RAM. The memory map divides the Neuron 5000 Processor’s physical 64KB RAM into the following types of logical memory, as shown in Figure 5: Current Transceiver Type Used FTT-10A Transceiver EIA-485 Transceiver Extended Memory (Configurable as: Extended RAM or Non-volatile memory) 42 KB TPT Twisted Pair Transceiver Module (for a TP/XF-1250 channel type) 0x4000 to 0xE7FF On-Chip ROM 16 KB 0x0000 to 0x3FFF Figure 5: FT 5000 Smart Transceiver Memory Map Programming memory devices. Because the Neuron 5000 Processor does not have any on-chip user-accessible NVM, only the external serial EEPROM or flash devices need to be programmed with the application and configuration data. The memory devices can be programmed in any of the following ways: In-circuit programming on the board. Over the network. • System firmware image (stored in on-chip ROM or external NVM). Pre-programming before soldering on the board. • On-chip RAM or NVM. Memory ranges for each are configurable within the device hardware template. The non-volatile memory represents the area shadowed from external NVM into the RAM. Migration Considerations Equivalent Series 5000 Design FT 5000 Smart Transceiver plus FT-X3 Communications Transformer Neuron 5000 Processor plus EIA-485 Transceiver or (if possible) FT 5000 Smart Transceiver plus FT-X3 Communications Transformer • Atmel® AT25F512B 512-Kilobit 2.7-volt Minimum SPI Serial Flash Memory. • Numonyx™ M25P05-A 512-Kbit, serial flash memory, 50MHz SPI bus interface. The recommended migration path for devices based on a Neuron Chip depends on the transceiver type used with the Neuron Chip, as shown in Table 2. Most device designs that use the previousgeneration Neuron 3120 or Neuron 3150 Chip can transition to using the Neuron 5000 Processor. However, because the supply voltage and memory architecture of Neuron 3120/3150 Chips and Neuron 5000 Processors are different, the transition LonWorks LPT-11 Link Power Transceiver Other transceiver type Comments Use an FT 5000 Smart Transceiver for TP/FT-10 channels. If your design is flexible enough to allow either an EIA-485 channel or a TP/FT-10 channel, use the FT 5000 Smart Transceiver with the TP/FT-10 channel. The Neuron 5000 Processor must be configured to operate in 3.3V Neuron 5000 Single-Ended Processor plus Mode with the TPT/XF-1250 TPT Twisted Twisted Pair Transceiver Pair Transceiver Module (for a Module and TP/XF-1250 external circuitry channel type) must be added for Single-Ended to Differential Mode conversion. The Neuron 5000 Processor must Neuron 5000 be configured to Processor operate in 3.3V plus LPT-11 Single-Ended Link Power Mode with the Transceiver LPT-11 Link Power Transceiver. The Neuron 5000 Processor can connect to other Neuron 5000 transceiver types Processor plus other transceiver for the supported channel types, but type more hardware design work may be required. Table 2: Migration for Devices with Neuron Chips See the Series 5000 Chip Data Book and the Connecting a Neuron 5000 Processor to an External Transceiver Engineering Bulletin for more information about migrating device designs for Neuron 3120/3150 Chips to Neuron 5000 Processors. www.echelon.com ® End-to-End Solutions A typical Neuron 5000 Processor-based device requires a power source, crystal, external memory, and an I/O interface to the device being controlled (see Figure 6 for a typical Neuron 5000 Processor-based device). Echelon provides all of the building blocks required to successfully design and field cost-effective, robust products based on the Neuron 5000 Processor. Our end-toend solutions include a comprehensive set of development tools, network interfaces, routers, and network tools. Pre-production design review services, training, and worldwide technical support—including on-site support—are available through Echelon’s Support technical assistance program. Serial EEPROM (2KB or larger) Sense or Control Devices: Motors, Valves, Lights, Relays, Switches, Controllers I/O Serial SPI Flash (optional) External Transceiver Neuron 5000 Processor Crystal (10 MHz) Power Source LONWORKS or other Network Channel Figure 6: Typical LonWorks based Device MOSI SCK MISO SCL VDD1V8 SDA_CS1~ VDD3V3 VDD3V3 CS0~ CP4 CP3 CP2 48 47 46 45 44 43 42 41 40 39 38 37 Neuron 5000 Processor Pin Configuration GND PAD SVC~ 1 36 GND IO0 2 35 NC IO1 3 34 CP1 IO2 4 33 AGND IO3 5 32 GP0 VDD1V8 6 31 AVDD3V3 IO4 7 30 VDD3V3 VDD3V3 8 29 VIN3V3 28 RST~ Neuron 5000 Processor Pin Number Type Dashed line represents Pad (pin 49) Pad must be connected to GND Figure 7: Neuron 5000 Processor Pinout Neuron 5000 Processor Pin Descriptions All digital inputs are low-voltage transistortransistor logic (LVTTL) compatible, low leakage, 5V-tolerant. All digital outputs are slew-rate limited to reduce Electromagnetic Interference (EMI) concerns. Description SVC~ 1 Digital I/O Service (active low) IO0 2 Digital I/O IO0 for I/O Objects IO1 3 Digital I/O IO1 for I/O Objects IO2 4 Digital I/O IO2 for I/O Objects IO3 5 Digital I/O IO3 for I/O Objects VDD1V8 6 IO4 7 VDD3V3 8 IO5 9 IO6 Power 1.8 V Power Input (from internal voltage regulator) Pin Name Pin Number CP0 32 AGND 33 Type Ground Digital I/O IO5 for I/O Objects NC 35 N/A 10 Digital I/O IO6 for I/O Objects GND 36 Ground IO7 11 Digital I/O IO7 for I/O Objects IO8 12 Digital I/O IO8 for I/O Objects IO9 13 Digital I/O IO9 for I/O Objects IO10 14 IO11 15 VDD1V8 16 for I/O Digital I/O IO10 Objects for I/O Digital I/O IO11 Objects 1.8 V Power Input Power (from internal voltage regulator) TRST~ 17 VDD3V3 3.3 V Power Digital Input JTAG Test Reset (active low) 18 Power 3.3 V Power TCK 19 TMS 20 TDI 21 TDO 22 XIN 23 XOUT 24 Digital Input Digital Input Digital Input Digital Output Oscillator In Oscillator Out VDDPLL 25 Power GNDPLL 26 Power Ground Power 1.8 V Power Output (of internal voltage regulator) VOUT1V8 27 RST~ 28 JTAG Test Clock JTAG Test Mode Select JTAG Test Data In JTAG Test Data Out Crystal oscillator Input Crystal oscillator Output 1.8 V Power Input (from internal voltage regulator) Digital I/O Reset (active low) VIN3V3 29 Power 3.3 V input to internal voltage regulator VDD3V3 30 Power 3.3 V Power AVDD3V3 31 Power 3.3 V Power CP2 37 CP3 38 CP4 39 CS0~ 40 Ground Single-Ended Mode: Transmit Communi- serial data cations Special Purpose Mode: Transmit serial data 34 Power Description Single-Ended Mode: Receive Communi- serial data cations Special Purpose Mode: Receive serial data CP1 Digital I/O IO4 for I/O Objects 24 XOUT 23 XIN 22 TDO TDI TCK TMS VDD3V3 TRST~ VDD1V8 IO9 IO11 IO10 21 VDDPLL 20 25 19 12 18 GNDPLL IO8 17 VOUT1V8 26 16 27 11 15 10 IO7 14 9 IO6 13 IO5 Pin Name Do Not Connect Ground Single-Ended Mode: External Communi- transceiver enable cations Special Purpose Mode: Bit clock Communi- Do Not Connect cations Single-Ended Mode: Collision Communi- detect cations Special Purpose Mode: Frame clock SPI slave select 0 (CS0~, Digital I/O active low) (for external memory connection only) VDD3V3 41 Power 3.3 V Power VDD3V3 42 Power 3.3 V Power SDA_CS1~ 43 VDD1V8 44 SCL 45 MISO 46 SCK 47 I2C: serial data (SDA) SPI: slave Digital I/O select 1 (CS1~, active low) (for external memory connection only) 1.8 V Power Input Power (from internal voltage regulator) I2C: serial (SCL) (for Digital I/O clock external memory connection only) SPI master input, slave output Digital I/O (MISO) (for external memory connection only) SPI serial clock (SCK) Digital (for external I/O memory connection only) www.echelon.com ® Pin Name MOSI PAD Pin Number 48 49 Type Digital I/O Ground Pad Description SPI master output, slave input (MOSI) (for external memory connection only) Ground Table 3: Neuron 5000 Processor Pin Description Electrical Characteristics Neuron 5000 Processor Operating Conditions Parameter1 VDD3 VLVI TA fXIN IDD3 Description Minimum Typical Maximum Supply voltage 3.00 V 3.3 V Low-voltage indicator trip 2.70 V point Ambient -40° C temperature XIN clock 10,0000 frequency2 MHz Current consumption3 5MHz 9 mA 10MHz 9 mA 20MHz 15 mA 40MHz 23 mA 80MHz 38 mA 3.60 V Parameter1 Description Minimum VOH Output drive high at IOH = 8 mA 2.4 V VDD3 VOL Output drive low at IOL = 8 mA GND 0.4 V VIH Input high level 2.0 V 5.5 V - Neuron 5000 Processor IC Mechanical Specification 0.8 V VIL Input low level GND VHYS Input hysteresis for RST~ pin IIN Input leakage current - 10 µA RPU Pullup resistance2 13 kΩ 23 kΩ IPU Pullup current when pin at 0 V2 130 µA 275 µA 2.96 V +85° C Maximum Typical 300 mV Table 5: Neuron 5000 Processor Digital Pin Characteristics Notes 15 mA 15 mA 23 mA 33 mA 52 mA Table 4: Neuron 5000 Processor Operating Conditions Notes 1. All parameters assume nominal supply voltage (VDD3 = 3.3 V ± 0.3 V) and operating temperature (TA between -40ºC and +85ºC), unless otherwise noted. 2. Applies to RST~ and SVC~ pins only. Recommended Neuron 5000 Processor Pad Layout 1. All parameters assume nominal supply voltage (VDD3 = 3.3 V ± 0.3 V) and operating temperature (TA between -40ºC and +85ºC), unless otherwise noted. 2. See Clock Requirements in the Series 5000 Chip Data Book for more detailed information about the XIN clock frequency. Figure 9: Neuron 5000 Processor IC Mechanical Specifications 3. Assumes no load on digital I/O pins, and that the I/O lines are not switching. Notes Digital Pin Characteristics The digital I/O pins (IO0–IO11) have LVTTLlevel inputs. Pins IO0–IO7 also have lowlevel-detect latches. The RST~ and SVC~ pins have internal pull-ups, and the RST~ pin has hysteresis. Table 5 below lists the characteristics of the digital I/O pins, which include IO0–IO11, CP0CP4 and the other digital pins listed in Table 3. 1. All dimensions are in millimeters. Figure 8: Neuron 5000 Processor Pad Layout 2. Dimensions and tolerances conform to ASME Y14.5M.-1994. 3. Package warpage max. 0.08 mm. 4. Package corners unless otherwise specified are R0.175±0.025 mm. www.echelon.com ® Neuron 5000 Tape and Reel Figure 12: Neuron 5000 10” Reel and Hub Drawing Devices are uniformly loaded in the carrier tape such that the device pin one is oriented in quadrant 1 toward the side of the tape having round sprocket holes. Figure 10 illustrates the pin-one location. User Direction of Feed Figure 10: Neuron 5000 Pin One Orientation Figure 11 shows the outline dimensions of the carrier tape. Figure 11: Carrier Tape Outline Drawing Ao = Bo = 7.25 Ko = 1.10 Notes 1. All dimensions are in millimeters. 2. Tolerances unless noted: 1PL + 0.2. 2PL + 0.1 3. 10 Sprocket hole pitch cumulative tolerance +0.2 4. Camber in compliance with EIA 481. 5. P  ocket position relative to sprocket hole measured as true position of pocket, not pocket hole. For more information, refer to EIA-481-B, Taping of Surface Mount Components for Automatic Placement. Figure 12 shows the Neuron 5000 Series 13” Reel Drawing and Specification. www.echelon.com ® Figure 13 shows the 5000 Series 7” Reel Drawing and Specification. Specifications RoHS-Compliant The Neuron 5000 Processor is compliant with the European Directive 2002/95/EC on the restriction of the use of certain hazardous substances (RoHS) in electrical and electronic equipment. EMC Specifications depend on the network transceiver used with the Neuron 5000 Processor. Transmission Speed Depends on network transceiver: 78 kbit/s for TP/FT-10 channel; 1250 kbit/s for TP/XF-1250 channel. (See EIA-485 channel specification for transmission speed characteristics.) Operating Temperature -40 to 85°C Reflow Soldering Temperature Profile Refer to Joint Industry Standard document IPC/JEDEC J-STD-020D.1 (March 2008). Peak Reflow Soldering Temperature Ordering Information Neuron 5000 Processor 14305R-2000 14305R-500 Figure 13: Neuron 5000 7” Reel and Hub Drawing © 2014 Echelon, LonWorks, and the Echelon logo are trademarks of Echelon Corporation registered in the United States and other countries.IzoT is a trademark of Echelon Corporation. Content subject to change without notice. www.echelon.com
14305R-ES 价格&库存
很抱歉,暂时无法提供与“14305R-ES”相匹配的价格&库存,您可以联系我们找货
