20-101-0698
20-101-0698
    DIGIINTERNATIONAL
    MODULE RABBITCORE RCM3310
20-101-0698 数据手册
Selection Guide RCM2000/3000 RabbitCore™ Shared Features of the RCM2000/3000 RabbitCore Series Feature RCM2XXX RCM3XXX EMI Reduction Spectrum spreader for reduced EMI (radiated emissions) Serial Rate Max. asynchronous burst rate = CLK/32 Max. asynchronous burst rate = CLK/8 Backup Battery Connection for user-supplied battery (to support RTC and SRAM) Slave Interface Permits use as master or intelligent peripheral with Rabbit-based or other master controller Real-Time Clock Yes, battery backable Timers Five 8-bit timers (four cascadable from the first) and one 10-bit timer with 2 match registers Ten 8-bit timers (six cascadable from the first, three reserved for internal peripherals) and one 10-bit timer with 2 match registers Watchdog Yes Humidity 5–95%, noncondensing Pulse-Width Modulation N/A Input Capture N/A 2-channel input capture can be used to time input signals from various port pins Quadrature Decoder N/A 2-channel quadrature decoder accepts inputs from external incremental encoder modules continued next page 8-bit free running counter and four 10-bit pulse-width registers 8 © 2004 Z•World, Inc. All rights reserved. © 2004 Rabbit Semiconductor. All rights reserved. 1 Distinguishing Features of the RCM2000 RabbitCore Series Feature RCM2000 CPU Speed RCM2010 Ethernet RCM2100 RCM2110 RCM2120 RCM2130 18.4 MHz None Flash Memory SRAM RCM2020 25.8 MHz 128K None 10Base-T RJ-45, 2 LEDs 10Base-T raw signals 10Base-T RJ-45, 2 LEDs None 256K 512K 256K 512K 256K 128K 512K 128K 512K 128K Analog Inputs None 34 parallel I/O • 20 configurable I/O • 8 fixed inputs • 6 fixed outputs Add’l Inputs 40 parallel I/O • 26 configurable I/O • 8 fixed inputs • 6 fixed outputs 26 parallel I/O • 16 configurable I/O • 7 fixed inputs • 3 fixed outputs 29 parallel I/O • 17 config. I/O • 8 fixed inputs • 4 fixed outputs 2 Startup Mode, Reset Add’l Outputs External I/O Watchdog, Reset Status, Clock, Watchdog, Reset Status, Reset 13 address, 8 data, I/O Read-Write, Buffer Enable 13 buffered address lines, 8 buffered data lines, I/O Read-Write, Buffer Enable 4 address, 8 data, I/O Read-Write Serial Ports Power RCM2300 512K None 40 parallel I/O • 26 configurable I/O • 8 fixed inputs • 6 fixed outputs RCM2250 512K Serial Flash General Purpose I/O* RCM2210 22.1 MHz 10Base-T RJ-45, 2 LEDs 256K 512K RCM2200 Four 5 V CMOS-compatible • 4 configurable as asynchronous • 2 configurable as clocked serial (SPI) 4.75–5.25 V DC • 130 mA 4.75–5.25 V DC • 98 mA Four 5 V CMOS-compatible • 4 configurable as asynchronous • 2 configurable as clocked serial (SPI)** 4.75–5.25 V DC • 140 mA 4.75–5.25 V DC • 134 mA 4.75–5.25 V DC • 108 mA Operating Temp. –40°C to +85°C –40°C to +70°C –40°C to +80°C –40°C to +70°C –40°C to +85°C Board Size 2.3” x 1.9” x 0.5” (58 x 48 x 13 mm) 3.5” x 2.0” x 0.86” (89 x 51 x 22 mm) 3.5” x 2.0” x 0.5” (89 x 51 x 13 mm) 2.3” x 1.6” x 0.86” (59 x 41 x 22 mm) 1.60” x 1.15” x 0.47” (41 x 29 x 12 mm) Connectors Part Number 2 x 20, 2 mm IDC headers 101-0404 101-0405 Development Kit Part Number U.S.101-0398 Int’l 101-0399 101-0383 101-0434 2 x 13, 2 mm IDC headers 101-0435 101-0436 U.S. 101-0451 Int’l 101-0452 101-0446 101-0454 101-0488 U.S. 101-0475 Int’l 101-0478 101-0494 101-0453 U.S. 101-0480 Int’l 101-0481 * Grouped in 8-bit ports and shared with serial ports **1 clocked line available only on programming header 2 Distinguishing Features of the RCM3000 RabbitCore Series Feature RCM3000 RCM3010 RCM3100 CPU Speed Ethernet Flash Memory SRAM RCM3110 10Base-T, RJ-45, 2 LEDs None 10/100Base-T, RJ-45, 3 LEDs 512K (2 x 256K) 256K 512K (2 x 256K) 256K 512K 128K 512K 128K 512K program + 512K data 4MB None 52 digital I/O • 44 configurable I/O • 4 fixed inputs • 4 fixed outputs 52 digital I/O • 44 configurable I/O • 4 fixed inputs • 4 fixed outputs 49 parallel digital I/O • 43 configurable I/O • 3 fixed inputs • 3 fixed outputs 2 Startup Mode, Reset Status, Reset External I/O 6 address (shared with I/O), 8 data, plus I/O Rd, I/O Wr Serial Ports 5 address (shared with I/O), 8 data, plus I/O Rd, I/O Wr Six 3.3 V CMOS-compatible: • 6 configurable as asynchronous (with IrDA) • 4 configurable as clocked serial (SPI) • 2 configurable as SDLC/HDLC 3.15–3.45 V DC • 150 mA 3.15–3.45 V DC • 75 mA –40°C to +70°C –40°C to +85°C 2.73” × 1.85” × 0.86” (69 x 47 x 22 mm) 1.85” × 1.65” × 0.55” (47 x 42 x 14 mm) Connectors Part Number 10/100Base-T, RJ-45, 3 LEDs 8 MB Add’t Outputs Development Kit RCM3310 512K Add’t Inputs Part Number None None General Purpose I/O* Board Size RCM3300 512K program + 256K data Analog Inputs Operating Temp. RCM3220 44.2 MHz Serial Flash Power RCM3200 29.4 MHz Five 3.3 V CMOS-compatible: • 5 configurable as asynchronous (with IrDA), • 3 configurable as clocked serial (SPI) • 2 configurable as SDLC/HDLC • 1 asynchronous serial port (programming) 3.15–3.45 V DC • 255 mA 3.15–3.45 V DC • 350 mA @ 3.3 V –40°C to +70°C 2.73” × 1.85” × 0.86” (69 x 47 x 22 mm) 2.73” × 1.85” × 0.86” (69 x 47 x 22 mm) Two 2 x 17, 2 mm IDC headers 101-0507 101-0508 U.S. 101-0523 Int’l 101-0524 101-0517 U.S. 101-0533 Int’l 101-0534 101-0518 101-0520 101-0522 U.S. 101-0552 Int’l 101-0553 101-0691 101-0698 U.S. 101-0704 Int’l 101-0705 * Grouped in 8-bit ports and shared with serial ports 3 Feature RCM3400 CPU Speed Ethernet RCM3410 RCM3600 RCM3610 29.4 MHz RCM3700 RCM3710 22.1 MHz Reference Design for 10/100Base-T Mac ID installed None 10Base-T, RJ-45 Flash Memory 512K 256K 512K 256K 512K 256K SRAM 512K 256K 512K 128K 512K 128K Serial Flash Analog Inputs None None 47 digital I/O • 41 configurable I/O • 3 fixed inputs • 3 fixed outputs 33 parallel digital I/O lines • 31 configurable I/O • 2 fixed outputs General Purpose I/O* Add’t Inputs 2 Startup Mode, Reset In, CONVERT Add’t Outputs External I/O Serial Ports Power Status, Reset Out, BVREF None 5 address (shared with I/O), 8 data, plus I/O Rd, I/O Wr Five 3.3 V CMOS-compatible: • 4 configurable as asynchronous (with IrDA) • 3 as clocked serial (SPI), 2 as SDLC/HDLC (with IrDA) • 1 asynchronous serial port (programming) • Support for MIR/SIR IrDA transceiver 4.75-12.6 VDC • 60 mA @ 22.1 MHz; 38 mA @ 11.06 MHz 4.75-5.25 VDC • 100 mA @ 22.1 MHz; 78 mA @ 11.06 MHz 2.10” × 1.20 “ × 0.62” (53 x 30 x 16 mm) 2.95” × 1.20 “ × 0.88” (75 x 30 x 22 mm) –40°C to +85°C 1.38” × 1.16 “ × 0.31” (35 x 29 x 7.4 mm) Connectors Two 2 x 17, 1.27 mm IDC Headers Part Number Four 3.3 V CMOS-compatible: • 4 configurable as asynchronous (with IrDA) • 3 as clocked serial (SPI) and 1 as SDLC/HDLC (with IrDA), or 1 SPI and 2 SDLC/HDLC • 1 asynchronous serial port (programming) 3.0–3.45 V DC • 97 mA @ 29.4 MHz; 2.8–3.45 V DC • 57 mA @ 14.7 MHz Board Size Development Kit Reset 6 address (shared with I/O ), 8 data, plus I/O Rd, I/O Wr Operating Temp. Part Number 1MB 8 channels single-ended (11-bit) or 4 channels differ. (12-bit), Prog. gain 1, 2, 4, 5, 8, 10, 16, and 20 V/V. –40°C to +70°C Single 2 x 20, 0.1” IDC header 101-0561 101-0562 101-0672 101-0673 101-0674 101-0675 U.S. 101-0587 Int’l 101-0588 U.S. 101-0587 Int’l 101-0588 U.S. 101-0678 Int’l 101-0679 U.S. 101-0678 Int’l 101-0679 U.S. 101-0680 Int’l 101-0681 U.S. 101-0680 Int’l 101-0681 * Grouped in 8-bit ports and shared with serial ports 4
20-101-0698 价格&库存
很抱歉,暂时无法提供与“20-101-0698”相匹配的价格&库存,您可以联系我们找货
