TSM9120ESA+T
TSM9120ESA+T
    TOUCHSTONESEMICONDUCTOR
    SOIC-8
    IC COMPARATOR SINGLE 8SOIC
TSM9120ESA+T 数据手册
TSM9117-TSM9120 1.6V Nanopower Comparators with/without Internal References FEATURES DESCRIPTION ♦ Second-source for MAX9117-MAX9120 ♦ Guaranteed to Operate Down to +1.6V ♦ Ultra-Low Supply Current 350nA - TSM9119/TSM9120 600nA - TSM9117/TSM9118 ♦ Internal 1.252V ±1.75% Reference ♦ Input Voltage Range Extends 200mV Outside-the-Rails ♦ No Phase Reversal for Overdriven Inputs ♦ Push-pull and Open-Drain Output Versions Available ♦ Crowbar-Current-Free Switching ♦ Internal Hysteresis for Clean Switching ♦ 5-pin SC70 and 8-pin SOIC Packaging The TSM9117–TSM9120 family of nanopower comparators is electrically and form-factor identical to the MAX9117-MAX9120 family of analog comparators. Ideally suited for all 2-cell batterymanagement/monitoring applications, these 5-pin SC70 analog comparators guarantee +1.6V operation, draw very little supply current, and have robust input stages that can tolerate input voltages beyond the power supply. The TSM9117 and the TSM9118 draw 600nA of supply current and include an on-board 1.252V ±1.75% reference. The comparator-only TSM9119 and the TSM9120 draw a supply current of 350nA. APPLICATIONS 2-Cell Battery Monitoring/Management Medical Instruments Threshold Detectors/Discriminators Sensing at Ground or Supply Line Ultra-Low-Power Systems Mobile Communications Telemetry and Remote Systems The TSM9117 and TSM9119’s push-pull output drivers were designed to drive 5mA loads from one supply rail to the other supply rail. The TSM9118 and the TSM9120’s open-drain output stages make it easy to incorporate these comparators into systems that operate on different supply voltages. TYPICAL APPLICATION CIRCUIT PART TSM9117 TSM9118 TSM9119 TSM9120 INTERNAL REFERENCE Yes Yes No No OUTPUT TYPE Push-Pull Open-Drain Push-Pull Open-Drain SUPPLY CURRENT (nA) 600 600 350 350 Page 1 © 2014 Silicon Laboratories, Inc. All rights reserved. TSM9117-TSM9120 ABSOLUTE MAXIMUM RATINGS Supply Voltage (VCC to VEE) ............................................ +6V Voltage Inputs (IN+, IN-, REF) .... (VEE - 0.3V) to (VCC + 0.3V) Output Voltage TSM9117/9119 ........................ (VEE - 0.3V) to (VCC + 0.3V) TSM9118/9120 ...................................... (VEE - 0.3V) to +6V Current Into Input Pins ................................................ ±20mA Output Current ............................................................ ±50mA Output Short-Circuit Duration ............................................ 10s Continuous Power Dissipation (TA = +70°C) 5-Pin SC70 (Derate 2.5mW/°C above +70°C) ........ 200mW 8-Pin SOIC (Derate 5.88mW/°C above +70°C) ...... 471mW Operating Temperature Range ...................... -40°C to +85°C Junction Temperature ................................................ +150°C Storage Temperature Range ....................... -65°C to +150°C Lead Temperature (soldering, 10s) ............................... +300° Electrical and thermal stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to any absolute maximum rating conditions for extended periods may affect device reliability and lifetime. PACKAGE/ORDERING INFORMATION ORDER NUMBER PART MARKING CARRIER QUANTITY Tape & Reel ----- TSM9117EXK+T Tape & Reel 3000 TSM9118EXK+ Tape & Reel ----- TSM9117EXK+ TAA ORDER NUMBER PART MARKING CARRIER QUANTITY Tube 97 TSM9117ESA+T Tape & Reel 2500 TSM9120ESA+ Tube 97 Tape & Reel 2500 TSM9117ESA+ TS9117E TAB TSM9118EXK+T Tape & Reel 3000 TSM9119EXK+ Tape & Reel ----- TSM9119EXK+T Tape & Reel 3000 TSM9120EXK+ Tape & Reel ----- TAC TS9120E TAD TSM9120EXK+T TSM9120ESA+T Tape & Reel 3000 Lead-free Program: Silicon Labs supplies only lead-free packaging. Consult Silicon Labs for products specified with wider operating temperature ranges. Page 2 TSM9117/20 Rev. 1.0 TSM9117-TSM9120 ELECTRICAL CHARACTERISTICS: TSM9117 & TSM9118 VCC = +5V, VEE = 0V, VIN+ = VREF, TA = -40°C to +85°C, unless otherwise noted. Typical values are at TA = +25°C. See Note 1. PARAMETER SYMBOL Supply Voltage Range VCC Supply Current ICC IN+ Voltage Range VIN+ Input Offset Voltage VOS Input-Referred Hysteresis VHB Input Bias Current Power-Supply Rejection Ratio Output-Voltage Swing High Output-Voltage Swing Low Output Leakage Current IB PSRR VCC - VOH VOL ILEAK Output Short-Circuit Current ISC High-to-Low Propagation Delay (Note 4) tPD- Low-to-High Propagation Delay (Note 4) tPD+ Rise Time Fall Time tRISE tFALL Power-Up Time tON Reference Voltage VREF CONDITIONS Inferred from the PSRR test VCC = 1.6V TA = +25°C TA = TMIN to TMAX TA = +25°C TA = +25°C VCC = 5V TA = TMIN to TMAX Inferred from the output swing test TA = +25°C (Note 2) TA = TMIN to TMAX (Note 3) TA = +25°C TA = TMIN to TMAX VCC = 1.6V to 5.5V, TA = +25°C VCC = 1.8V to 5.5V, TA = TMIN to TMAX TA = +25°C TSM9117, VCC = 5V, ISOURCE = 5mA TA = TMIN to TMAX VCC = 1.6V, TA = +25°C TSM9117, ISOURCE = 1mA VCC = 1.8V, TA = TMIN to TMAX TA = +25°C VCC = 5V, ISINK = 5mA TA = TMIN to TMAX VCC = 1.6V, TA = +25°C ISINK = 1mA VCC = 1.8V, TA = TMIN to TMAX TSM9118 only, VO = 5.5V VCC = 5V Sourcing, VO = VEE VCC = 1.6V VCC = 5V Sinking, VO = VCC VCC = 1.6V VCC = 1.6V VCC = 5V VCC = 1.6V TSM9117 only VCC = 5V VCC = 1.6V, RPULLUP = 100kΩ TSM9118 only VCC = 5V, RPULLUP = 100kΩ TSM9117 only, CL = 15pF CL = 15pF ∆VREF/ ∆VCC Reference Load Regulation ∆VREF/ ∆IOUT ∆IOUT = 10nA TSM9117/20 Rev. 1.0 TYP 0.6 0.68 VEE - 0.2 1 4 0.15 0.1 190 100 MAX 5.5 5.5 1 1.30 1.60 VCC + 0.2 5 10 BW = 10Hz to 100kHz BW = 10Hz to 100kHz, CREF = 1nF VCC = 1.6V to 5.5V V μA V mV mV mV/V mV/V 200 mV nA 300 190 400 500 100 200 mV 300 0.002 35 3 35 3 16 14 15 40 1 μA mA µs µs 16 45 1.6 0.2 1.230 1.196 1.252 100 TCVREF UNITS 1 2 1 1 400 500 µs µs 1.2 TA = +25°C TA = TMIN to TMAX Reference Voltage Temperature Coefficient Reference Output Voltage Noise Reference Line Regulation en MIN 1.6 1.8 1.1 0.2 0.25 ±1 ms 1.274 1.308 V ppm/°C mVRMS mV/V mV/nA Page 3 TSM9117-TSM9120 ELECTRICAL CHARACTERISTICS: TSM9119 & TSM9120 VCC = +5V, VEE = 0V, VCM = 0V, TA = -40°C to +85°C, unless otherwise noted. Typical values are at TA = +25°C. See Note 1. PARAMETER SYMBOL Supply Voltage Range VCC Supply Current ICC Input Common-Mode Voltage Range VCM Input Offset Voltage VOS Input-Referred Hysteresis VHB Input Bias Current IB Input Offset Current IOS Power-Supply Rejection Ratio PSRR Common-Mode Rejection Ratio CMRR Output-Voltage Swing High VCC - VOH Output-Voltage Swing Low VOL Output Leakage Current ILEAK Output Short-Circuit Current ISC High-to-Low Propagation Delay (Note 4) tPD- Low-to-High Propagation Delay (Note 4) tPD+ Rise Time Fall Time tRISE tFALL Power-Up Time tON CONDITIONS Inferred from the PSRR test VCC = 1.6V VCC = 5V TA = +25°C TA = TMIN to TMAX TA = +25°C TA = +25°C TA = TMIN to TMAX Inferred from the CMRR test TA = +25°C -0.2V ≤ VCM ≤ (VCC+0.2V) (Note 2) TA = TMIN to TMAX -0.2V ≤ VCM ≤ (VCC+0.2V) (Note 3) TA = +25°C TA = TMIN to TMAX VCC = 1.6V to 5.5V, TA = +25°C VCC = 1.8V to 5.5V, TA = TMIN to TMAX (VEE - 0.2V) ≤ VCM ≤ (VCC + 0.2V) TA = +25°C TSM9119 only, VCC = 5V, ISOURCE = 5mA TA = TMIN to TMAX VCC = 1.6V, TA = +25°C TSM9119 only, ISOURCE = 1mA VCC = 1.8V, TA = TMIN to TMAX TA = +25°C VCC = 5V, ISINK = 5mA TA = TMIN to TMAX VCC = 1.6V, TA = +25°C ISINK = 1mA VCC = 1.8V, TA = TMIN to TMAX TSM9120 only, VO = 5.5V VCC = 5V Sourcing, VO = VEE VCC = 1.6V VCC = 5V Sinking, VO = VCC VCC = 1.6V VCC = 1.6V VCC = 5V VCC = 1.6V TSM9119 only VCC = 5V VCC = 1.6V, RPULLUP = 100kΩ TSM9120 only VCC = 5V, RPULLUP = 100kΩ TSM9119 only, CL = 15pF CL = 15pF MIN 1.6 1.8 TYP 0.35 0.45 VEE - 0.2 1 4 0.15 75 0.1 0.5 190 100 MAX 5.5 5.5 0.80 0.80 1.20 UNITS VCC + 0.2 V 5 10 mV V μA mV 1 2 1 1 3 400 500 200 nA pA mV/V mV/V mV/V mV 300 190 400 500 100 200 mV 300 0.001 35 3 35 3 16 14 15 40 16 1 μA mA µs µs 45 1.6 0.2 µs µs 1.2 ms Note 1: All specifications are 100% tested at TA = +25°C. Specification limits over temperature (TA = TMIN to TMAX) are guaranteed by design, not production tested. Note 2: VOS is defined as the center of the hysteresis band at the input. Note 3: The hysteresis-related trip points are defined by the edges of the hysteresis band, measured with respect to the center of the hysteresis band (i.e., VOS) (See Figure 2). Note 4: Specified with an input overdrive (VOVERDRIVE) of 100mV, and load capacitance of CL = 15pF. VOVERDRIVE is defined above and beyond the offset voltage and hysteresis of the comparator input. For the TSM9117/TSM9118, reference voltage error should also be added. Page 4 TSM9117/20 Rev. 1.0 TSM9117-TSM9120 TYPICAL PERFORMANCE CHARACTERISTICS VCC = +5V; VEE = 0V; CL = 15pF; VOVERDRIVE = 100mV; TA = +25°C, unless otherwise noted. TSM9117/9118 Supply Current vs TSM9119/9120 Supply Current Supply Voltage and Temperature vs Supply Voltage and Temperature 1 1.25 0.9 TA = +85°C SUPPLY CURENT - µA SUPPLY CURENT - µA 1.15 1.05 0.95 0.85 0.75 TA = +25°C 0.65 0.55 TA = +85°C 0.8 0.7 0.6 0.5 TA = +25°C 0.4 TA = -40°C TA = -40°C 0.3 0.45 0.2 1.5 2.5 3.5 4.5 5.5 1.5 4.5 5.5 SUPPLY VOLTAGE - Volt TSM9117/9118 Supply Current vs Temperature 1.1 TSM9119/9120 Supply Current vs Temperature 1 0.9 SUPPLY CURENT - µA SUPPLY CURENT - µA 3.5 SUPPLY VOLTAGE - Volt 1 VCC =+5V 0.9 0.8 VCC =+3V 0.7 0.6 VCC =+1.8V 0.5 0.8 VCC =+5V 0.7 0.6 VCC =+3V 0.5 0.4 VCC =+1.8V 0.3 0.4 0.2 -40 -15 35 10 60 -40 85 -15 10 35 60 TEMPERATURE - °C TEMPERATURE - °C TSM9117/9118 Supply Current vs Output Transition Frequency TSM9119/9120 Supply Current vs Output Transition Frequency 35 35 30 30 SUPPLY CURRENT - µA SUPPLY CURRENT - µA 2.5 25 VCC =+5V 20 15 VCC =+3V 10 VCC =+1.8V 5 85 25 VCC =+5V 20 15 VCC =+3V 10 VCC =+1.8V 5 0 0 1 10 100 1k 10k OUTPUT TRANSITION FREQUENCY - Hz TSM9117/20 Rev. 1.0 1 10 100 1k 10k OUTPUT TRANSITION FREQUENCY- Hz Page 5 TSM9117-TSM9120 TYPICAL PERFORMANCE CHARACTERISTICS VCC = +5V; VEE = 0V; CL = 15pF; VOVERDRIVE = 100mV; TA = +25°C, unless otherwise noted. Output Voltage Low vs. Sink Current and Temperature Output Voltage Low vs. Sink Current 600 700 TA = +25°C 600 500 VCC =+3V 400 400 VOL - mV VOL - mV 500 VCC =+1.8V 300 300 TA = +85°C 200 VCC =+5V 200 TA = +25°C TA = -40°C 100 100 0 0 2 0 4 6 8 10 0 SINK CURRENT- mA 8 10 0.6 0.6 0.5 VCC =+1.8V VCC =+3V TA = +25°C VCC – VOH - V 0.5 VCC – VOH - V 6 TSM9117/9119 Output Voltage High vs Source Current and Temperature 0.7 0.4 0.3 VCC =+5V 0.2 0.4 0.3 TA = +85°C 0.2 TA = -40°C 0.1 0.1 0 0 0 2 4 6 8 0 10 2 4 6 8 10 SOURCE CURRENT- mA SOURCE CURRENT- mA Short-Circuit Sink Current vs Temperature TSM9117/9119 Short-Circuit Source Current vs Temperature 50 40 45 35 SOURCE CURRENT- mA VCC =+5V SINK CURRENT- mA 4 SINK CURRENT- mA TSM9117/9119 Output Voltage High vs Source Current 30 25 20 VCC =+3V 15 10 VCC =+1.8V 5 VCC =+5V 40 35 30 25 VCC =+3V 20 15 10 VCC =+1.8V 5 0 0 -40 -15 10 35 TEMPERATURE - °C Page 6 2 60 85 -40 -15 10 35 60 85 TEMPERATURE - °C TSM9117/20 Rev. 1.0 TSM9117-TSM9120 TYPICAL PERFORMANCE CHARACTERISTICS VCC = +5V; VEE = 0V; CL = 15pF; VOVERDRIVE = 100mV; TA = +25°C, unless otherwise noted. Offset Voltage vs Temperature Hysteresis Voltage vs Temperature 2.8 6 VCC =+1.8V 5.5 2.6 VHB - mV VOS - mV 5 VCC =+3V 2.4 4.5 4 VCC =+5V 2.2 3.5 2 3 -40 -15 10 35 60 85 -40 -15 35 10 60 TEMPERATURE - °C TEMPERATURE - °C TSM9117/9118 Reference Voltage vs Temperature TSM9117/9118 Reference Voltage vs Supply Voltage 1.260 85 1.254 1.256 REFERENCE VOLTAGE - V REFERENCE VOLTAGE - V 1.258 VCC =+1.8V 1.254 1.252 1.250 VCC =+3V 1.248 VCC =+5V 1.246 1.244 1.242 1.253 1.252 1.251 1.250 1.249 1.240 -40 -15 10 35 60 85 1.5 4.5 5.5 TSM9117/9118 Reference Voltage vs Reference Sink Current 1.260 1.260 1.258 1.258 REFERENCE VOLTAGE - V REFERENCE VOLTAGE - V TSM9117/9118 Reference Voltage vs Reference Source Current 1.256 VCC =+1.8V 1.252 1.250 1.248 VCC =+3V, 5V 1.246 3.5 SUPPLY VOLTAGE - Volt TEMPERATURE - °C 1.254 2.5 1.244 1.242 VCC =+1.8V 1.256 1.254 VCC =+3V, 5V 1.252 1.250 1.248 1.246 1.244 1.242 1.240 1.240 0 2 4 6 8 SOURCE CURRENT- nA TSM9117/20 Rev. 1.0 10 0 2 4 6 8 10 SINK CURRENT- nA Page 7 TSM9117-TSM9120 TYPICAL PERFORMANCE CHARACTERISTICS VCC = +5V; VEE = 0V; CL = 15pF; VOVERDRIVE = 100mV; TA = +25°C, unless otherwise noted. Propagation Delay (tPD-) vs Temperature 28 TSM9117/9119 Propagation Delay (tPD+) vs Temperature 60 26 VCC =+5V 50 24 22 tPD+ - µs tPD- - µs 18 VCC =+3V 16 VCC =+3V 40 VCC =+5V 20 14 30 VCC =+1.8V 20 12 10 VCC =+1.8V 10 8 6 0 -40 -15 10 35 60 -40 85 TEMPERATURE - °C 140 140 120 120 tPD+ - µs tPD- - µs 160 160 VCC =+5V VCC =+3V 60 85 VCC =+3V VCC =+5V 80 60 VCC =+1.8V 40 20 20 0 0 0.01 0.1 1 10 100 1000 0.01 0.1 1 10 100 1000 CAPACITIVE LOAD - nF CAPACITIVE LOAD - nF TSM9117/9119 Propagation Delay (tPD+) vs Input Overdrive Propagation Delay (tPD-) vs Input Overdrive 80 70 70 60 60 VCC =+5V 50 VCC =+3V tPD+ - µs VCC =+5V 50 tPD- - µs 60 VCC =+1.8V 100 40 40 VCC =+3V 30 40 30 VCC =+1.8V 20 20 10 VCC =+1.8V 10 0 0 0 10 20 30 40 INPUT OVERDRIVE - mV Page 8 35 TSM9117/9119 Propagation Delay (tPD+) vs Capacitive Load 180 180 80 10 TEMPERATURE - °C Propagation Delay (tPD-) vs Capacitive Load 200 100 -15 50 0 10 20 30 40 50 INPUT OVERDRIVE - mV TSM9117/20 Rev. 1.0 TSM9117-TSM9120 TYPICAL PERFORMANCE CHARACTERISTICS VCC = +5V; VEE = 0V; CL = 15pF; VOVERDRIVE = 100mV; TA = +25°C, unless otherwise noted. TSM9118/9120 Propagation Delay (tPD-) vs Pullup Resistance TSM9118/9120 Propagation Delay (tPD+) vs Pullup Resistance 15 200 14 180 160 VCC =+5V 13 140 tPD+ - µs tPD- - µs 12 11 10 VCC =+3V 9 VCC =+5V 120 100 VCC =+3V 80 60 8 VCC =+1.8V 40 7 20 VCC =+1.8V 0 6 10 100 1k 10k 10 100 1k 100k RPULLUP - kΩ Propagation Delay (tPD-) at VCC = +5V TSM9117/9119 Propagation Delay (tPD+) at VCC = +5V OUTPUT OUTPUT INPUT INPUT RPULLUP - kΩ Propagation Delay (tPD-) at VCC = +3V TSM9117/9119 Propagation Delay (tPD+) at VCC = +3V OUTPUT OUTPUT INPUT 20µs/DIV INPUT 20µs/DIV 20µs/DIV TSM9117/20 Rev. 1.0 20µs/DIV Page 9 TSM9117-TSM9120 TYPICAL PERFORMANCE CHARACTERISTICS VCC = +5V; VEE = 0V; CL = 15pF; VOVERDRIVE = 100mV; TA = +25°C, unless otherwise noted. TSM9117/9119 Propagation Delay (tPD+) at VCC = +1.8V OUTPUT OUTPUT INPUT INPUT Propagation Delay (tPD-) at VCC = +1.8V TSM9117/9119 10kHz Transient Response at VCC = +1.8V TSM9117/9119 1kHz Transient Response at VCC = +5V OUTPUT OUTPUT INPUT 20µs/DIV INPUT 20µs/DIV 20µs/DIV 200µs/DIV OUTPUT INPUT Power-Up/Power-Down Transient Response 0.2s/DIV Page 10 TSM9117/20 Rev. 1.0 TSM9117-TSM9120 PIN FUNCTIONS TSM9117/TSM9118 SC70 SO 1 6 2 4 3 3 TSM9119/TSM9120 SC70 SO 1 6 2 4 3 3 NAME OUT VEE IN+ 4 2 — — REF 5 — — 7 — 1, 5, 8 5 4 — 7 2 1, 5, 8 VCC INNC FUNCTION Comparator Output Negative Supply Voltage Comparator Noninverting Input 1.252V Reference Output and Comparator Inverting Input Positive Supply Voltage Comparator Inverting Input No Connection. Not internally connected. BLOCK DIAGRAMS DESCRIPTION OF OPERATION Guaranteed to operate from +1.6V supplies, the TSM9117 and the TSM9118 comparators only draw 600nA supply current, feature a robust input stage that can tolerate input voltages 200mV beyond the power supply rails, and include an on-board +1.252V ±1.75% voltage reference. The comparator-only TSM9119 and the TSM9120 have the same attributes and only draw a supply current of 350nA. To insure clean output switching behavior, all four analog comparators feature 4mV internal hysteresis. The TSM9117 and the TSM9119’s push-pull output drivers were designed to minimize supply-current surges while driving ±5mA loads with rail-to-rail output swings. The open-drain output stage TSM9118 and TSM9120 can be connected to supply voltages above VCC to an absolute maximum of 6V above VEE. Where wired-OR logic connections are TSM9117/20 Rev. 1.0 needed, their open-drain output stages make it easy to use these analog comparators. Input Stage Circuitry The robust design of the analog comparators’ input stage can accommodate any differential input voltage from VEE - 0.2V to VCC + 0.2V. Input bias currents are typically ±0.15nA so long as the applied input voltage remains between the supply rails. ESD protection diodes - connected internally to the supply rails protect comparator inputs against overvoltage conditions. However, if the applied input voltage exceeds either or both supply rails, an increase in input current can occur when these ESD protection diodes start to conduct. Page 11 TSM9117-TSM9120 Output Stage Circuitry Many conventional analog comparators can draw orders of magnitude higher supply current when switching. Because of this behavior, additional power supply bypass capacitance may be required to provide additional charge storage during switching. The design of the TSM9117–TSM9120’s rail-to-rail output stage implements a technique that virtually eliminates supply-current surges when output transitions occur. As shown on Page 5 of the Typical Operating Characteristics, the supply-current change as a function of output transition frequency exhibited by this analog comparator family is very small. Material benefits of this attribute to batterypower applications is the increase in operating time and in reducing the size of power-supply filter capacitors. TSM9117/9118’s Internal +1.252V VREF The TSM9117 and the TSM9118’s internal +1.252V voltage reference exhibits a typical temperature coefficient of 100ppm/°C over the full -40°C to +85°C temperature range. An equivalent circuit for the reference section is illustrated in Figure 1. Since the output impedance of the voltage reference is Figure 1: TSM9117 & TSM9118 Internal VREF Output Equivalent Circuit 200kΩ, its output can be bypassed with a lowleakage capacitor and is stable with any capacitive load. An external buffer – such as the TS1001 – can be used to buffer the voltage reference output for higher output current drive or to reduce reference output impedance. APPLICATIONS INFORMATION Low-Voltage, Low-Power Operation Designed specifically for low-power applications, the TSM9117–TSM9120 comparators are an excellent choice. Under nominal conditions, approximate operating times for this analog comparator family is illustrated in Table 1 for a number of battery types and their charge capacities. Internal Hysteresis As a result of circuit noise or unintended parasitic feedback, many analog comparators often break into oscillation within their linear region of operation especially when the applied differential input voltage approaches 0V (zero volt). Externally-introduced hysteresis is a well-established technique to stabilizing analog comparator behavior and requires external components. As shown in Figure 2, adding comparator hysteresis creates two trip points: VTHR (for the rising input voltage) and VTHF (for the falling input voltage). The hysteresis band (VHB) is defined as the voltage difference between the two trip points. When a comparator’s input voltages are equal, hysteresis effectively forces one comparator input to move quickly past the other input, moving the input Table 1: Battery Applications using the TSM9117- TSM9120 2000 TSM9117/TSM9118 OPERATING TIME (hrs) 2.5 x 106 TSM9119/TSM9120 OPERATING TIME (hrs) 5 x 106 1.8 750 937,500 1.875 x 106 3.5 2.7 1000 1.25 x 106 2.5 x 106 2.4 1.8 1000 1.25 x 106 2.5 x 106 BATTERY TYPE RECHARGEABLE VFRESH (V) VEND-OF-LIFE (V) CAPACITY, AA SIZE (mA-h) Alkaline (2 Cells) Nickel-Cadmium (2 Cells) Lithium-Ion (1 Cell) Nickel-MetalHydride (2 Cells) No 3.0 1.8 Yes 2.4 Yes Yes Page 12 TSM9117/20 Rev. 1.0 TSM9117-TSM9120 out of the region where oscillation occurs. Figure 2 illustrates the case in which an IN- input is a fixed voltage and an IN+ is varied. If the input signals were reversed, the figure would be the same with an inverted output. To save cost and external pcb area, an internal 4mV hysteresis circuit was added to the TSM9117–TSM9120. From the results of the two formulae, the smaller of the two resulting resistor values is chosen. For example, when using the TSM9117 (VREF = 1.252V) at a VCC = 3.3V and if IR2 = 0.2μA is chosen, then the formulae above produce two resistor values: 6.26MΩ and 10.24MΩ - the 6.2MΩ standard value for R2 is selected. Adding Hysteresis to the TSM9117/TSM9119 2) Next, the desired hysteresis band (VHYSB) is set. In this example, VHYSB is set to 100mV. 3) Resistor R1 is calculated according to the following equation: R1 = R2 x (VHYSB/VCC) and substituting the values selected in 1) and 2) above yields: R1 = 6.2MΩ x (100mV/3.3V) = 187.88kΩ. The 187kΩ standard value for R1 is chosen. Figure 2: TSM9117-TSM9120 Threshold Hysteresis Band ` Figure 3: Using Three Resistors Introduces Additional Hysteresis in the TSM9117 & TSM9119. The TSM9117/TSM9119 exhibit an internal hysteresis band (VHYSB) of 4mV. Additional hysteresis can be generated with three external resistors using positive feedback as shown in Figure 3. Unfortunately, this method also reduces the hysteresis response time. Use the following procedure to calculate resistor values. 1) Setting R2. As the leakage current at the IN pin is less than 2nA, the current through R2 should be at least 0.2μA to minimize offset voltage errors caused by the input leakage current. The current through R2 at the trip point is (VREF - VOUT)/R2. In solving for R2, there are two formulas – one each for the two possible output states: R2 = VREF/IR2 or R2 = (VCC - VREF)/IR2 TSM9117/20 Rev. 1.0 4) The trip point for VIN rising (VTHR) is chosen such that VTHR > VREF x (R1 + R2)/R2 (VTHF is the trip point for VIN falling). This is the threshold voltage at which the comparator switches its output from low to high as VIN rises above the trip point. In this example, VTHR is set to 3V. 5) With the VTHR from Step 4 above, resistor R3 is then computed as follows: R3 = 1/[VTHR/(VREF x R1) - (1/R1) - (1/R2)] R3 = 1/[3V/(1.252V x 187kΩ) - (1/187kΩ) - (1/6.2MΩ)] = 136.9kΩ In this example, a 137kΩ, 1% standard value resistor is selected for R3. 6) The last step is to verify the trip voltages and hysteresis band using the standard resistance values: For VIN rising: VTHR = VREF x R1 [(1/R1) + (1/R2) + (1/R3)] = 3V and, for VIN falling: VTHF = VTHR - (R1 x VCC/R2) = 2.9V Page 13 TSM9117-TSM9120 and Hysteresis Band = VTHR – VTHF = 100mV Adding Hysteresis to the TSM9118/TSM9120 The TSM9118/TSM9120 have a 4mV internal hysteresis band. Both products have open-drain outputs and require an external pullup resistor to VCC as shown in Figure 4. Additional hysteresis can be where the smaller of the two resulting resistor values is the best starting value. 2) As before, the desired hysteresis band (VHYSB) is set to 100mV. 3) Next, resistor R1 is then computed according to the following equation: R1 = (R2 + R4) x (VHYSB/VCC) 4) The trip point for VIN rising (VTHR) is chosen (again, remember that VTHF is the trip point for VIN falling). This is the threshold voltage at which the comparator switches its output from low to high as VIN rises above the trip point. 5) With the VTHR from Step 4 above, resistor R3 is computed as follows: R3 = 1/[VTHR/(VREF x R1) - (1/R1) - (1/R2)] Figure 4: Using Four Resistors Introduces Additional Hysteresis in the TSM9118 & TSM9120. generated using positive feedback; however, formulae differ slightly from those of TSM9117/TSM9119. The procedure to calculate resistor values for the TSM9118/TSM9120 is follows: 1) As in the previous section, resistor R2 is chosen according to the formulae: R2 = VREF/0.2µA or R2 = (VCC - VREF)/0.2μA - R4 Page 14 the the the as 6) As before, the last step is to verify the trip voltages and hysteresis band with the standard resistor values used in the circuit: For VIN rising: VTHR = VREF x R1 x (1/R1+1/R2+1/R3) and, for VIN falling: VTHF = VREF x R1 x [1/R1+1/R3+1/(R2+R4)] -[R1/(R2+R4)] x VCC and Hysteresis Band is given by VTHR - VTHF PC Board Layout and Power-Supply Bypassing While power-supply bypass capacitors are not typically required, it is good engineering practice to use 0.1µF bypass capacitors close to the device’s power supply pins when the power supply impedance is high, the power supply leads are long, or there is excessive noise on the power supply traces. To reduce stray capacitance, it is also good engineering practice to make signal trace lengths as short as possible. Also recommended are a ground plane and surface mount resistors and capacitors. TSM9117/20 Rev. 1.0 TSM9117-TSM9120 A Zero-Crossing Detector To configure a zero-crossing detector using a TSM9119 is illustrated in Figure 5. In this example, the TSM9119’s inverting input is connected to ground and its noninverting input is connected to a 100mVP-P signal source. The TSM9119’s output changes state as the signal at the noninverting input crosses 0V. A Logic-Level Translator Logic-level translation between two different voltage systems is easy using the TSM9120 as shown in Figure 6. This application circuit converts 5V logic to Figure 6: A 5V-to-3V Logic Level Translator Figure 5: A Simple Zero-Crossing Detector TSM9117/20 Rev. 1.0 3V logic levels. In this case, the TSM9120 is powered by a +5V system and the external pullup resistor for the TSM9120’s open-drain output is connected to a +3V system. This configuration allows the full 5V logic swing without creating overvoltage on the 3V logic inputs. For 3V to 5V logic-level translations, simply interchange the +3V supply voltage connection on the comparator’s VCC and the +5V supply voltage to the external pullup resistor. Page 15 TSM9117-TSM9120 PACKAGE OUTLINE DRAWING 5-Pin SC70 Package Outline Drawing (N.B., Drawings are not to scale) Page 16 TSM9117/20 Rev. 1.0 TSM9117-TSM9120 PACKAGE OUTLINE DRAWING 8-Pin SOIC Package Outline Drawing (N.B., Drawings are not to scale) Patent Notice Silicon Labs invests in research and development to help our customers differentiate in the market with innovative low-power, small size, analog-intensive mixed-signal solutions. Silicon Labs' extensive patent portfolio is a testament to our unique approach and world-class engineering team. The information in this document is believed to be accurate in all respects at the time of publication but is subject to change without notice. Silicon Laboratories assumes no responsibility for errors and omissions, and disclaims responsibility for any consequences resulting from the use of information included herein. Additionally, Silicon Laboratories assumes no responsibility for the functioning of undescribed features or parameters. Silicon Laboratories reserves the right to make changes without further notice. Silicon Laboratories makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Silicon Laboratories assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation consequential or incidental damages. Silicon Laboratories products are not designed, intended, or authorized for use in applications intended to support or sustain life, or for any other application in which the failure of the Silicon Laboratories product could create a situation where personal injury or death may occur. Should Buyer purchase or use Silicon Laboratories products for any such unintended or unauthorized application, Buyer shall indemnify and hold Silicon Laboratories harmless against all claims and damages. Silicon Laboratories and Silicon Labs are trademarks of Silicon Laboratories Inc. Other products or brandnames mentioned herein are trademarks or registered trademarks of their respective holders. Silicon Laboratories, Inc. 400 West Cesar Chavez, Austin, TX 78701 +1 (512) 416-8500 ▪ www.silabs.com Page 17 TSM9117/20 Rev. 1.0 Smart. Connected. Energy-Friendly Products Quality Support and Community www.silabs.com/products www.silabs.com/quality community.silabs.com Disclaimer Silicon Laboratories intends to provide customers with the latest, accurate, and in-depth documentation of all peripherals and modules available for system and software implementers using or intending to use the Silicon Laboratories products. Characterization data, available modules and peripherals, memory sizes and memory addresses refer to each specific device, and "Typical" parameters provided can and do vary in different applications. Application examples described herein are for illustrative purposes only. Silicon Laboratories reserves the right to make changes without further notice and limitation to product information, specifications, and descriptions herein, and does not give warranties as to the accuracy or completeness of the included information. Silicon Laboratories shall have no liability for the consequences of use of the information supplied herein. This document does not imply or express copyright licenses granted hereunder to design or fabricate any integrated circuits. The products must not be used within any Life Support System without the specific written consent of Silicon Laboratories. A "Life Support System" is any product or system intended to support or sustain life and/or health, which, if it fails, can be reasonably expected to result in significant personal injury or death. Silicon Laboratories products are generally not intended for military applications. Silicon Laboratories products shall under no circumstances be used in weapons of mass destruction including (but not limited to) nuclear, biological or chemical weapons, or missiles capable of delivering such weapons. Trademark Information Silicon Laboratories Inc., Silicon Laboratories, Silicon Labs, SiLabs and the Silicon Labs logo, CMEMS®, EFM, EFM32, EFR, Energy Micro, Energy Micro logo and combinations thereof, "the world’s most energy friendly microcontrollers", Ember®, EZLink®, EZMac®, EZRadio®, EZRadioPRO®, DSPLL®, ISOmodem ®, Precision32®, ProSLIC®, SiPHY®, USBXpress® and others are trademarks or registered trademarks of Silicon Laboratories Inc. ARM, CORTEX, Cortex-M3 and THUMB are trademarks or registered trademarks of ARM Holdings. Keil is a registered trademark of ARM Limited. All other products or brand names mentioned herein are trademarks of their respective holders. Silicon Laboratories Inc. 400 West Cesar Chavez Austin, TX 78701 USA http://www.silabs.com
TSM9120ESA+T 价格&库存
很抱歉,暂时无法提供与“TSM9120ESA+T”相匹配的价格&库存,您可以联系我们找货
TSM9120ESA+T
  • 1+5.279401+0.63891
  • 10+5.1424910+0.62234
  • 25+5.0441625+0.61044
  • 250+4.94509250+0.59845
  • 500+4.84612500+0.58648
  • 1000+4.747191000+0.57450
库存:5000
TSM9120ESA+T
  • 2500+4.747192500+0.57450
库存:5000
