CBTD16210DGG,518
CBTD16210DGG,518
    NEXPERIA(安世)
    TFSOP48
    IC BUS SWITCH 10 X 1:1 48TSSOP
CBTD16210DGG,518 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia INTEGRATED CIRCUITS CBTD16210 20-bit level shifting bus switch with 10-bit output enables Product specification Supersedes data of 2000 Sep 25    2000 Oct 12 Philips Semiconductors Product specification 20-bit level shifting bus switch with 10-bit output enables CBTD16210 FEATURES DESCRIPTION • 5Ω switch connection between two ports • TTL compatible control input levels • Designed to be used in 5.5 V to 3.3 V level shifting applications • Package options include shrink small outline (SSOP) and thin The CBTD16210 provides 20 bits of high-speed TTL-compatible bus switching. The low on-state resistance of the switch allows connections to be made with minimal propagation delay. A diode to VCC is integrated in the circuit to allow for level shifting between 5 V inputs and 3.3 V outputs. The device is organized as a dual 10-bit bus switch with separate output-enable (OE) inputs. It can be used as two 10-bit bus switches or as one 20-bit bus switch. When OE is low, the associated 10-bit bus switch is on, and port A is connected to port B. When OE is high, the switch is open, and a high-impedance state exists between the ports. shrink small outline (TSSOP) The CBTD16210 is characterized for operation from –40°C to +85°C. QUICK REFERENCE DATA SYMBOL CONDITIONS Tamb = 25°C; GND = 0V PARAMETER TYPICAL UNIT tPLH tPHL Propagation delay An to Yn CL = 50pF; VCC = 5V 0.25 ns CIN Input capacitance VI = 0V or VCC 4.3 pF COUT Output capacitance Outputs disabled; VO = 0V or VCC 6.9 pF ICCZ Total supply current Outputs disabled; VCC = 5.5V 4.0 µA ORDERING INFORMATION PACKAGES TEMPERATURE RANGE ORDER CODE DWG NUMBER 48-Pin Plastic SSOP Type III –40°C to +85°C CBTD16210 DL SOT370-1 48-Pin Plastic TSSOP Type II –40°C to +85°C CBTD16210 DGG SOT362-1 LOGIC SYMBOL 2 FUNCTION TABLE INPUTS 46 1A1 1B1 12 1OE 2OE 1A, 1B 2A, 2B L L 1A = 1B 2A = 2B L H 1A = 1B Z H L Z 2A = 2B H H Z Z 36 1A10 1B10 H = High voltage level L = Low voltage level Z = High impedance “off ” state 88 1OE 13 OUTPUTS 35 2A1 2B1 24 2A10 25 2B10 47 2OE SA00545 2000 Oct 12 2 853-2221 24787 Philips Semiconductors Product specification 20-bit level shifting bus switch with 10-bit output enables CBTD16210 PIN CONFIGURATION PIN DESCRIPTION SYMBOL 1 NC NAME AND FUNCTION No internal connection NC 1 48 1OE 1A1 2 47 2OE 48, 47 1OE, 2OE Output enables 1A2 3 46 1B1 Inputs 4 45 1B2 2, 3, 4, 5, 6, 7, 9, 10, 11, 12 1A1-1A10 1A3 1A4 5 44 1B3 46, 45, 44, 43, 42, 40, 39, 38, 37, 36 1B1-1B10 Outputs 1A5 6 43 1B4 1A6 7 42 1B5 13, 14, 16, 18, 19, 20, 21, 22, 23, 24 2A1-2A10 Inputs GND 8 41 GND 1A7 40 1B6 35, 34, 33, 31, 30, 29, 28, 27, 26, 25 2B1-2B10 Outputs 9 1A8 10 39 1B7 8, 17, 32, 41 GND Ground (0V) 1A9 11 38 1B8 15 VCC Positive supply voltage 1A10 12 37 1B9 2A1 13 36 1B10 2A2 14 35 2B1 VCC 15 34 2B2 2A3 16 33 2B3 GND 17 32 GND 2A4 18 31 2B4 2A5 19 30 2B5 2A6 20 29 2B6 2A7 21 28 2B7 2A8 22 27 2B8 2A9 23 26 2B9 2A10 24 25 2B10 SA00546 2000 Oct 12 PIN NUMBER 3 Philips Semiconductors Product specification 20-bit level shifting bus switch with 10-bit output enables CBTD16210 ABSOLUTE MAXIMUM RATINGS1, 2 PARAMETER SYMBOL VCC CONDITIONS RATING DC supply voltage IIK DC input diode current VI DC input voltage3 VI < 0 voltage3 VOUT DC output IOUT DC output current Tstg Storage temperature range UNIT –0.5 to +7.0 V –50 mA –0.5 to +7.0 V output in Off or High state –0.5 to +5.5 V output in Low state 128 mA –65 to +150 °C NOTES: 1. Stresses beyond those listed may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. 2. The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. The maximum junction temperature of this integrated circuit should not exceed 150°C. 3. The input and output voltage ratings may be exceeded if the input and output current ratings are observed. RECOMMENDED OPERATING CONDITIONS LIMITS SYMBOL PARAMETER Min Max 5.5 VCC DC supply voltage 4.5 VIH High-level input voltage 2.0 VIL Low-level Input voltage Tamb Operating free-air temperature range UNIT V V –40 0.8 V +85 °C DC ELECTRICAL CHARACTERISTICS LIMITS SYMBOL PARAMETER TEST CONDITIONS Tamb = –40°C to +85°C Min VIK Input clamp voltage VCC = 4.5 V; II = –18 mA VOH Output high pass voltage See Figure 1, page 6 II ICC ∆ICC CI CIO(OFF) ron3 Typ1 Max –1.2 V V VCC = 0 V; VI = 5.5 V 10 VCC = 5.5 V; VI = GND or 5.5 V ±1 Quiescent supply current2 VCC = 5.5 V; IO = 0, VI = VCC or GND; 1OE=2OE=GND 1.5 mA Additional supply current per input pin2 VCC = 5.5 V, one input at 3.4 V, other inputs at VCC or GND 2.5 mA Control pins VI= 3 V or 0 4.5 pF Power-off leakage current VO = 3 V or 0, OE = VCC 8 pF VCC = 4.5 V; V1 = 0 V; II = 64 mA 5 7 VCC = 4.5 V; V1 = 0 V; II = 30 mA 5 7 VCC = 4.5 V; V1 = 2.4 V; II = –15 mA 16 50 Input leakage current NOTES: 1. All typical values are at VCC = 5 V, Tamb = 25°C 2. This is the increase in supply current for each input that is at the specified TTL voltage level rather than VCC or GND 3. Measured by the voltage drop between the A and the B terminals at the indicated current through the switch. On-state resistance is determined by the lowest voltage of the two (A or B) terminals. 2000 Oct 12 UNIT 4 µA Ω Philips Semiconductors Product specification 20-bit level shifting bus switch with 10-bit output enables CBTD16210 AC CHARACTERISTICS GND = 0 V; tR; CL = 50 pF LIMITS –40°C to +85°C VCC = 5 V ± 0.5 V PARAMETER DESCRIPTION SYMBOL Min Mean Propagation delay1 tpd UNITS Max 250 ps tPZH Output enable time to HIGH level 1.5 5.0 7.5 ns tPHZ Output disable time from HIGH level 1.0 2.5 4.5 ns tPZL Output enable time to LOW level 1.5 6.0 9.0 ns tPLZ Output disable time from LOW level 1.5 3.5 6.0 ns NOTES: 1. This parameter is warranted but not production tested. The propagation delay is based on the RC time constant of the typical on-state resistance of the switch and a load capacitance of 50 pF, when driven by an ideal voltage source (zero output impedance). AC WAVEFORMS TEST CIRCUIT AND WAVEFORMS VM = 1.5 V, VIN = GND to 3.0 V 7V 3V 1.5V 500 Ω From Output Under Test 1.5V S1 Open GND INPUT 500 Ω CL = 50 pF 0V tPLH tPHL Load Circuit VOH 1.5V 1.5V OUTPUT VOL SA00028 Waveform 1. Input (An) to Output (Yn) Propagation Delays TEST S1 tpd open tPLZ/tPZL 7V tPHZ/tPZH open DEFINITIONS Load capacitance includes jig and probe capacitance; CL = see AC CHARACTERISTICS for value. 3V Output Control (Low-level enabling 1.5 V SA00012 1.5 V 0V tPLZ tPZL 3.5V Output Waveform 1 S1 at 7 V (see Note) 1.5 V Output Waveform 2 S1 at Open (see Note) VOL + 0.3V VOL tPHZ tPZH VOH VOH – 0.3V 1.5 V 0V Note: Waveform 1 is for an output with internal conditions such that the output is low except when disabled by the output control. Waveform 2 is for an output with internal conditions such that the output is high except when disabled by the output control. SA00029 Waveform 2. 3-State Output Enable and Disable Times 2000 Oct 12 5 Philips Semiconductors Product specification 20-bit level shifting bus switch with 10-bit output enables CBTD16210 TYPICAL CHARACTERISTICS 4.2 4.2 Temp = +70°C Temp = +85°C 3.8 3.8 –6 mA –12 mA 3.0 –24 mA –100 UA 3.4 Pass Gate Volts Pass Gate Volts –100 UA 3.4 2.6 –6 mA –12 mA –24 mA 3.0 2.6 2.2 2.2 1.8 1.8 4.5 4.75 5.0 5.25 4.5 5.5 4.75 VCC – Supply Volts 5.0 5.25 5.5 VCC – Supply Volts 4.2 Temp = +25°C 3.8 Pass Gate Volts –100 UA 3.4 –6 mA –12 mA –24 mA 3.0 2.6 2.2 1.8 4.5 4.75 5.0 5.25 5.5 VCC – Supply Volts 4.2 4.2 Temp = 0°C Temp = –40°C 3.8 –100 UA 3.4 Pass Gate Volts Pass Gate Volts 3.8 –6 mA –12 mA –24 mA 3.0 2.6 2.2 3.4 –100 UA –6 mA –12 mA –24 mA 3.0 2.6 2.2 1.8 1.8 4.5 4.75 5.0 5.25 4.5 5.5 VCC – Supply Volts 4.75 5.0 5.25 5.5 VCC – Supply Volts SA00554 Figure 1. VOH values (Vin = VCC) 2000 Oct 12 6 Philips Semiconductors Product specification 20-bit level shifting bus switch with 10-bit output enables CBTD16210 SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm 2000 Oct 12 7 SOT370-1 Philips Semiconductors Product specification 20-bit level shifting bus switch with 10-bit output enables CBTD16210 TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm 2000 Oct 12 8 SOT362-1 Philips Semiconductors Product specification 20-bit level shifting bus switch with 10-bit output enables CBTD16210 NOTES 2000 Oct 12 9 Philips Semiconductors Product specification 20-bit level shifting bus switch with 10-bit output enables CBTD16210 Data sheet status Data sheet status Product status Definition [1] Objective specification Development This data sheet contains the design target or goal specifications for product development. Specification may change in any manner without notice. Preliminary specification Qualification This data sheet contains preliminary data, and supplementary data will be published at a later date. Philips Semiconductors reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. Product specification Production This data sheet contains final specifications. Philips Semiconductors reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. [1] Please consult the most recently issued datasheet before initiating or completing a design. Definitions Short-form specification — The data in a short-form specification is extracted from a full data sheet with the same type number and title. For detailed information see the relevant data sheet or data handbook. Limiting values definition — Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Application information — Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors make no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Disclaimers Life support — These products are not designed for use in life support appliances, devices or systems where malfunction of these products can reasonably be expected to result in personal injury. Philips Semiconductors customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips Semiconductors for any damages resulting from such application. Right to make changes — Philips Semiconductors reserves the right to make changes, without notice, in the products, including circuits, standard cells, and/or software, described or contained herein in order to improve design and/or performance. Philips Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no license or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless otherwise specified.  Copyright Philips Electronics North America Corporation 2000 All rights reserved. Printed in U.S.A. Philips Semiconductors 811 East Arques Avenue P.O. Box 3409 Sunnyvale, California 94088–3409 Telephone 800-234-7381 Date of release: 10-00 Document order number:    2000 Oct 12 10 9397 750 07692
CBTD16210DGG,518 价格&库存
很抱歉,暂时无法提供与“CBTD16210DGG,518”相匹配的价格&库存,您可以联系我们找货
