74HCT157DB,118
74HCT157DB,118
    NEXPERIA(安世)
    SSOP16_208MIL
    IC MULTIPLEXER QUAD 2-IN 16SSOP
74HCT157DB,118 数据手册
74HC157; 74HCT157 Quad 2-input multiplexer Rev. 9 — 24 July 2020 Product data sheet 1. General description The 74HC157; 74HCT157 is a quad 2-input multiplexer. The device features select (S) and enable E inputs. A HIGH on S selects data source 1, a LOW data source 0. A HIGH on E forces all the outputs (1Y to 4Y) LOW. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits • • • • • • • • • • • Wide supply voltage range from 2.0 V to 6.0 V CMOS low power dissipation High noise immunity Latch-up performance exceeds 100 mA per JESD 78 Class II Level B Complies with JEDEC standards: • JESD8C (2.7 V to 3.6 V) • JESD7A (2.0 V to 6.0 V) Input levels: • For 74HC157: CMOS level • For 74HCT157: TTL level Non-inverting data path ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Multiple package options Specified from -40 °C to +85 °C and from -40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package 74HC157D Temperature range Name Description Version -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 -40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 -40 °C to +125 °C DHVQFN16 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5 × 3.5 × 0.85 mm SOT763-1 74HCT157D 74HC157PW 74HCT157PW 74HC157BQ 74HCT157BQ 74HC157; 74HCT157 Nexperia Quad 2-input multiplexer 4. Functional diagram S E 1I1 1Y 1I0 2I1 2Y 2I0 2 3I1 3Y 1 S 15 E 4Y 4I0 mna484 Fig. 1. Logic diagram 2 1I0 3 1I1 5 2I0 6 2I1 11 3I0 10 3I1 14 4I0 13 4I1 10 3Y 4Y 4 7 9 12 4 15 2Y 7 2 3 5 9 G1 EN 1 MUX Fig. 3. 1 15 Logic symbol 74HC_HCT157 Product data sheet 4 1 7 6 11 9 10 14 E 13 logic symbol 4Y 12 S 14 2Y 1Y 3Y 11 1Y 1 SELECTOR 6 mna481 Fig. 2. MULTIPLEXER OUTPUTS 5 1I0 1I1 2I0 2I1 3I0 3I1 4I0 4I1 3I0 4I1 3 12 13 mna483 mna482 Fig. 4. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 9 — 24 July 2020 © Nexperia B.V. 2020. All rights reserved 2 / 15 74HC157; 74HCT157 Nexperia Quad 2-input multiplexer 5. Pinning information 5.1. Pinning 1 S terminal 1 index area 1I0 2 15 E 1I1 3 14 4I0 1Y 4 13 4I1 2I0 5 12 4Y 2I1 6 11 3I0 2Y 7 10 3I1 GND 8 9 3 14 4I0 1Y 4 13 4I1 2I0 5 12 4Y 2I1 6 2Y 7 GND(1) 11 3I0 10 3I1 001aan354 Transparent top view (1) This is not a ground pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to GND. 3Y 001aan353 Fig. 5. 1I1 9 16 VCC 15 E 3Y 1 2 8 S 1I0 GND 74HC157 74HCT157 16 VCC 74HC157 74HCT157 Pin configuration SOT109-1 (SO16) and SOT403-1 (TSSOP16) Fig. 6. Pin configuration SOT763-1 (DHVQFN16) 5.2. Pin description Table 2. Pin description Symbol Pin Description S 1 common data select input 1I0 to 4I0 2, 5, 11, 14 data inputs from source 0 1I1 to 4I1 3, 6, 10, 13 data inputs from source 1 1Y to 4Y 4, 7, 9, 12 multiplexer outputs GND 8 ground (0 V) E 15 enable input (active LOW) VCC 16 supply voltage 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care. Output Input E S nI0 nI1 nY H X X X L L L L X L L L H X H L H X L L L H X H H 74HC_HCT157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 24 July 2020 © Nexperia B.V. 2020. All rights reserved 3 / 15 74HC157; 74HCT157 Nexperia Quad 2-input multiplexer 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current IOK IO ICC Min Max -0.5 +7 V VI < -0.5 V or VI > VCC + 0.5 V - ±20 mA output clamping current VO < -0.5 V or VO > VCC + 0.5 V - ±20 mA output current VO = -0.5 V to VCC + 0.5 V - ±25 mA supply current - +50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] Conditions Tamb = -40 °C to +125 °C [1] Unit For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C. For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C. For SOT763-1 (DHVQFN16) package: Ptot derates linearly with 11.2 mW/K above 106 °C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC157 74HCT157 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 74HC_HCT157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 24 July 2020 © Nexperia B.V. 2020. All rights reserved 4 / 15 74HC157; 74HCT157 Nexperia Quad 2-input multiplexer 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Tamb = 25 °C Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V VI = VIH or VIL HIGH-level output voltage IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V 74HC157 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V VI = VIH or VIL LOW-level output voltage IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V - - ±0.1 - ±1.0 - ±1.0 μA II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 μA CI input capacitance - 3.5 - - - - - pF 74HC_HCT157 Product data sheet VI = VCC or GND; VCC = 6.0 V All information provided in this document is subject to legal disclaimers. Rev. 9 — 24 July 2020 © Nexperia B.V. 2020. All rights reserved 5 / 15 74HC157; 74HCT157 Nexperia Quad 2-input multiplexer Symbol Parameter Conditions Tamb = 25 °C Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Min Typ Max Min Max Min Max Unit 74HCT157 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH VI = VIH or VIL; VCC = 4.5 V HIGH-level output voltage IO = -20 μA 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V IO = -4 mA VOL VI = VIH or VIL; VCC = 4.5 V LOW-level output voltage IO = 20 μA - 0 0.1 - 0.1 - 0.1 V - 0.15 0.26 - 0.33 - 0.4 V - - ±0.1 - ±1.0 - ±1.0 μA - - 8.0 - 80 - 160 μA per input pin; nI0, nI1 inputs - 100 360 - 450 - 490 μA per input pin; E input - 60 216 - 270 - 294 μA per input pin; S input - 100 360 - 450 - 490 μA - 3.5 - - - - - pF IO = 4.0 mA II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V ΔICC VI = VCC - 2.1 V; IO = 0 A; additional supply current other inputs at VCC or GND; VCC = 4.5 V to 5.5 V CI input capacitance 74HC_HCT157 Product data sheet VI = VCC or GND; VCC = 5.5 V All information provided in this document is subject to legal disclaimers. Rev. 9 — 24 July 2020 © Nexperia B.V. 2020. All rights reserved 6 / 15 74HC157; 74HCT157 Nexperia Quad 2-input multiplexer 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Fig. 9. Symbol Parameter Conditions Tamb = 25 °C Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 36 125 - 155 - 190 ns VCC = 4.5 V - 13 25 - 31 - 38 ns VCC = 5 V; CL = 15 pF - 11 - - - - - ns - 10 21 - 26 - 32 ns VCC = 2.0 V - 41 125 - 155 - 190 ns VCC = 4.5 V - 15 25 - 31 - 38 ns VCC = 5 V; CL = 15 pF - 12 - - - - - ns - 12 21 - 26 - 32 ns VCC = 2.0 V - 39 115 - 145 - 175 ns VCC = 4.5 V - 14 23 - 29 - 35 ns VCC = 5 V; CL = 15 pF - 11 - - - - - ns - 11 20 - 25 - 30 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns - 70 - - - - - pF 74HC157 tpd propagation delay nI0, nI1 to nY; see Fig. 7 [1] VCC = 6.0 V S to nY; see Fig. 7 [1] VCC = 6.0 V E to nY; see Fig. 8 [1] VCC = 6.0 V tt CPD transition time nY; see Fig. 7 [2] power CL = 50 pF; f = 1 MHz; dissipation VI = GND to VCC capacitance 74HC_HCT157 Product data sheet [3] All information provided in this document is subject to legal disclaimers. Rev. 9 — 24 July 2020 © Nexperia B.V. 2020. All rights reserved 7 / 15 74HC157; 74HCT157 Nexperia Quad 2-input multiplexer Symbol Parameter Conditions Tamb = 25 °C Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 4.5 V - 16 27 - 34 - 41 ns VCC = 5 V; CL = 15 pF - 13 - - - - - ns VCC = 4.5 V - 22 37 - 46 - 56 ns VCC = 5 V; CL = 15 pF - 19 - - - - - ns VCC = 4.5 V - 15 26 - 33 - 39 ns VCC = 5 V; CL = 15 pF - 12 - - - - - ns - 7 15 - 19 - 22 ns - 70 - - - - - pF 74HCT157 tpd propagation delay nI0, nI1 to nY; see Fig. 7 S to nY; see Fig. 7 [1] E to nY; see Fig. 8 tt transition time CPD [1] [2] [3] [1] [1] nY; see Fig. 7 [2] VCC = 4.5 V power CL = 50 pF; f = 1 MHz; dissipation VI = GND to VCC - 1.5 V capacitance [3] tpd is the same as tPLH and tPHL. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL x VCC x fo) = sum of outputs. 10.1. Waveforms VI input S, nI0, nI1 VM VM GND t PHL t PLH VOH output nY 90 % VM VM 10 % VOL t THL t TLH 001aad477 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 7. Propagation delay input (nI0, nI1, S) to output (nYn) 74HC_HCT157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 24 July 2020 © Nexperia B.V. 2020. All rights reserved 8 / 15 74HC157; 74HCT157 Nexperia Quad 2-input multiplexer VCC VM E input GND t PHL t PLH VOH VM nY output mna485 VOL Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 8. Propagation delay input (E) to output (nY) Table 8. Measurement points Type Input Output VM VM 74HC157 0.5VCC 0.5VCC 74HCT157 1.3 V 1.3 V VI negative pulse VM tf tr tr VI GND VM 10 % GND positive pulse tW 90 % tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL 001aah768 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig. 9. Test circuit for measuring switching times Table 9. Test data Type Load Input Test VI tr, tf CL 74HC157 VCC 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HCT157 3.0 V 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HC_HCT157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 24 July 2020 © Nexperia B.V. 2020. All rights reserved 9 / 15 74HC157; 74HCT157 Nexperia Quad 2-input multiplexer 11. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 10. Package outline SOT109-1 (SO16) 74HC_HCT157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 24 July 2020 © Nexperia B.V. 2020. All rights reserved 10 / 15 74HC157; 74HCT157 Nexperia Quad 2-input multiplexer TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 11. Package outline SOT403-1 (TSSOP16) 74HC_HCT157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 24 July 2020 © Nexperia B.V. 2020. All rights reserved 11 / 15 74HC157; 74HCT157 Nexperia Quad 2-input multiplexer DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm B D A A E A1 c detail X terminal 1 index area terminal 1 index area C e1 e b 2 7 y y1 C v M C A B w M C L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 0.5 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig. 12. Package outline SOT763-1 (DHVQFN16) 74HC_HCT157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 24 July 2020 © Nexperia B.V. 2020. All rights reserved 12 / 15 74HC157; 74HCT157 Nexperia Quad 2-input multiplexer 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT157 v.9 20200724 Product data sheet - 74HC_HCT157 v.8 Modifications: • • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type number 74HC157DB and 74HCT157DB (SOT338-1/SSOP16) removed. Section 1 and Section 2 updated. Table 4: Derating values for Ptot total power dissipation have been updated. 74HC_HCT157 v.8 20151228 Modifications: • 74HC_HCT157 v.7 20150121 Modifications: • 74HC_HCT157 v.6 20120827 Modifications: • 74HC_HCT157 v.5 20120425 Modifications: • 74HC_HCT157 v.4 20111219 74HC_HCT157 v.3 74HC_HCT157_CNV v.2 74HC_HCT157 Product data sheet Product data sheet - 74HC_HCT157 v.7 Type numbers 74HC157N and 74HCT157N (SOT38-4) removed. Product data sheet - 74HC_HCT157 v.6 Table 7: Power dissipation capacitance condition for 74HCT157 is corrected. Product data sheet - 74HC_HCT157 v.5 - 74HC_HCT157 v.4 Product data sheet - 74HC_HCT157 v.3 20101231 Product data sheet - 74HC_HCT157_CNV v.2 19970827 Product specification - - Package outline drawing DIP16 added. Product data sheet Fig. 7 updated with transition times. All information provided in this document is subject to legal disclaimers. Rev. 9 — 24 July 2020 © Nexperia B.V. 2020. All rights reserved 13 / 15 74HC157; 74HCT157 Nexperia Quad 2-input multiplexer 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC_HCT157 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 9 — 24 July 2020 © Nexperia B.V. 2020. All rights reserved 14 / 15 74HC157; 74HCT157 Nexperia Quad 2-input multiplexer Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 3 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................4 9. Static characteristics....................................................5 10. Dynamic characteristics............................................ 7 10.1. Waveforms.................................................................8 11. Package outline........................................................ 10 12. Abbreviations............................................................ 13 13. Revision history........................................................13 14. Legal information......................................................14 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 24 July 2020 74HC_HCT157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 24 July 2020 © Nexperia B.V. 2020. All rights reserved 15 / 15
74HCT157DB,118 价格&库存
很抱歉,暂时无法提供与“74HCT157DB,118”相匹配的价格&库存,您可以联系我们找货
