CBT3244ADB,118
CBT3244ADB,118
    NEXPERIA(安世)
    SSOP-20_7.2X5.3MM
    IC BUS SWITCH 4 X 1:1 20SSOP
CBT3244ADB,118 数据手册
CBT3244A Octal bus switch with quad output enables Rev. 3 — 8 September 2017 1 Product data sheet General description The CBT3244A provides eight bits of high-speed TTL-compatible bus switching in a standard '244 device pinout. The low ON-state resistance of the switch allows connections to be made with minimal propagation delay. The CBT3244A device is organized as two 4-bit low-impedance switches with separate output-enable (OE) inputs. When OE is LOW, the switch is on and data can flow from port A to port B, or vice versa. When OE is HIGH, the switch is open and high-impedance state exists between the two ports. The CBT3244A is characterized for operation from -40 °C to +85 °C. 2 Features and benefits • • • • • 3 Standard '244-type pinout 5 Ω switch connection between two ports TTL compatible control input levels Latch-up protection exceeds 500 mA per JESD78 ESD protection: – HBM JESD22-A114 exceeds 2000 V – MM JESD22-A115 exceeds 200 V – CDM JESD22-C101 exceeds 1000 V Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version CBT3244ABQ -40 °C to + 85 °C DHVQFN20 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 20 terminals; body 2.5 × 4.5 × 0.85 mm SOT764-1 CBT3244APW -40 °C to + 85 °C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 CBT3244ADB -40 °C to + 85 °C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 CBT3244AD -40 °C to + 85 °C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 CBT3244A Nexperia Octal bus switch with quad output enables 4 Marking Table 2. Marking codes Type number Marking code CBT3244ABQ CT3244A CBT3244APW CT3244A CBT3244ADB CT3244A CBT3244AD CBT3244AD 5 Functional diagram CBT3244A 1A1 1B1 1A4 1B4 1OE 2A1 2B1 2A4 2B4 2OE 002aab655 Figure 1. Logic diagram CBT3244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 September 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 16 CBT3244A Nexperia Octal bus switch with quad output enables 6 Pinning information 6.1 Pinning 1OE 1 20 VCC 1OE 1 20 VCC 1A1 2 19 2OE 1A1 2 19 2OE 2B4 3 18 1B1 2B4 3 18 1B1 1A2 4 17 2A4 1A2 4 17 2A4 2B3 5 16 1B2 2B3 5 1A3 6 15 2A3 1A3 6 2B2 7 14 1B3 2B2 7 14 1B3 1A4 8 13 2A2 1A4 8 13 2A2 2B1 9 12 1B4 2B1 9 12 1B4 GND 10 11 2A1 CBT3244APW 16 1B2 CBT3244AD 15 2A3 GND 10 11 2A1 002aab651 002aab654 Figure 2. Pin configuration for TSSOP20 Figure 3. Pin configuration for SO20 1OE 1 terminal 1 index area 1A1 2 20 VCC 19 2OE 2B4 3 18 1B1 1A2 4 17 2A4 2B3 5 1A3 6 2B2 7 14 1B3 1A4 8 13 2A2 2B1 9 12 1B4 GND 10 11 2A1 18 1B1 1A2 4 17 2A4 2B3 5 16 1B2 1A3 6 15 2A3 2B2 7 14 1B3 1A4 8 2B1 9 15 2A3 Figure 4. Pin configuration for SSOP20 Product data sheet 19 2OE 3 16 1B2 CBT3244ADB 002aab653 CBT3244A 2 2B4 GND(1) 13 2A2 12 1B4 2A1 11 1 1A1 GND 10 1OE 20 VCC CBT3244ABQ 002aab650 Transparent top view (1) This is not a supply pin, the substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad however if it is soldered the solder land should remain floating or be connected to GND. Figure 5. Pin configuration for DHVQFN20 All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 September 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 16 CBT3244A Nexperia Octal bus switch with quad output enables 6.2 Pin description Table 3. Pin description Symbol Pin Description 1OE, 2OE 1, 19 output enable (active LOW) 1A1, 1A2, 1A3, 1A4, 2A1, 2A2, 2A3, 2A4 2, 4, 6, 8, 11, 13, 15, 17 inputs 1B1, 1B2, 1B3, 1B4, 2B1, 2B2, 2B3, 2B4 18, 16, 14, 12, 9, 7, 5, 3 outputs GND 10 ground (0 V) VCC 20 positive supply voltage 7 Functional description Table 4. Function selection [1] Inputs Outputs 1OE 2OE 1An, 1Bn 2An, 2Bn L L 1An = 1Bn 2An = 2Bn L H 1An = 1Bn Z H L Z 2An = 2Bn H H Z Z [1] 8 H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF state Limiting values Table 5. Limiting values [1] In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Conditions supply voltage Min Max Unit -0.5 +7.0 V input voltage [2] -1.2 +7.0 V VO output voltage output in OFF or HIGH state [2] -0.5 +7.0 V IIK input clamping current VI < 0 V - -18 mA IOK output clamping current VO < 0 V - -50 mA IO output current output in LOW state - 128 mA Tstg storage temperature -65 +150 °C VI [1] [2] The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. The maximum junction temperature of this integrated circuit should not exceed 150 °C. The input and output voltage ratings may be exceeded if the input and output current ratings are observed. CBT3244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 September 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 16 CBT3244A Nexperia Octal bus switch with quad output enables 9 Recommended operating conditions Table 6. Operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Tamb ambient temperature Conditions Min Typ Max 4.5 - 5.5 V -40 - +85 °C operating in free-air Unit 10 Static characteristics Table 7. Static characteristics Tamb = -40 °C to +85 °C. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min VIK input clamping voltage VCC = 4.5 V; II = -18 mA VIH Typ [1] Max Unit - - -1.2 V HIGH-state input voltage 2.0 - - V VIL LOW-state input voltage - - 0.8 V II input leakage current VCC = 5.5 V; VI = VCC or GND - - ±1 μA ICC supply current - 1 3 μA - - 2.5 mA VCC = 5.5 V; IO = 0 mA; VI = VCC or GND [2] ΔICC additional supply current per input; VCC = 5.5 V; one input at 3.4 V; other inputs at VCC or GND Ci input capacitance control pins; VI = 3 V or 0 V; nOE = VCC - 3 - pF CI/O input/output capacitance nOE = VCC = 5.0 V - 3 - pF Ron ON-state resistance VCC = 4.5 V; VI = 0 V; II = 64 mA - 4 7 Ω VCC = 4.5 V; VI = 0 V; II = 30 mA - 4 7 Ω VCC = 4.5 V; VI = 2.4 V; II = 15 mA - 8 15 Ω [1] [2] [3] [3] All typical values are measured at VCC = 5 V; Tamb = 25 °C. This is the increase in supply current for each input that is at the specified TTL voltage level rather than VCC or GND. Measured by the voltage level between the A and the B terminals at the indicated current through the switch. ON-state resistance is determined by the lowest voltage of the two (A or B) terminals. CBT3244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 September 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 16 CBT3244A Nexperia Octal bus switch with quad output enables 11 Dynamic characteristics Table 8. Dynamic characteristics Tamb = -40 °C to +85 °C; Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 8. Symbol Parameter Conditions Min Typ Max Unit - - 0.25 ns tpd propagation delay nAn to nBn, or nBn to nAn; VCC = 5.0 V ± 0.5 V; see Figure 6 [1] [2] ten enable time nOE to nAn or nBn; VCC = 5.0 V ± 0.5 V; see Figure 7 [3] 1.0 - 5.6 ns tdis disable time nOE to nAn or nBn; VCC = 5.0 V ± 0.5 V; see Figure 7 [4] 1.0 - 6.0 ns [1] [2] [3] [4] This parameter is warranted but not production tested. The propagation delay is based on the RC time constant of the typical ON-state resistance of the switch and a load capacitance of 50 pF, when driven by an ideal voltage source (zero output impedance). tpd is the same as tPHL and tPLH. ten is the same as tPZH and tPZL. tdis is the same as tPHZ and tPLZ 11.1 Waveforms and test circuit VI nAn, nBn input VM VM GND tPHL tPLH VOH nBn, nAn output VM VOL VM 001aak881 Measurement points are given in Table 9. VOL and VOH are typical output voltage levels that occur with the output load. Figure 6. The data input (A) to output (nYn) propagation delay times CBT3244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 September 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 16 CBT3244A Nexperia Octal bus switch with quad output enables VI VM nOE input VM GND tPZL tPLZ output LOW to OFF OFF to LOW 3.5 V VM VX VOL tPZH tPHZ output HIGH to OFF OFF to HIGH VOH VY VM GND outputs enabled outputs disabled outputs enabled 001aak298 Measurement points are given in Table 9. VOL and VOH are typical output voltage levels that occur with the output load. Figure 7. Enable and disable times Table 9. Measurement points Input Output VI VM VM VX VY 3.0 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V CBT3244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 September 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 16 CBT3244A Nexperia Octal bus switch with quad output enables VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 10 All input pulses are supplied by generators having the following characteristics: PRR ≤ 10 MHz; Zo = 50 Ω The outputs are measured one at a time with one transition per measurement. RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Figure 8. Test circuit for measuring switching times Table 10. Test data Input Load VEXT VI tr, tf CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ VCC ≤ 2.5 ns 50 pF 500 Ω open open 7V CBT3244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 September 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 16 CBT3244A Nexperia Octal bus switch with quad output enables 12 Package outline DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 20 terminals; body 2.5 x 4.5 x 0.85 mm B D SOT764-1 A A A1 E c detail X terminal 1 index area terminal 1 index area e1 C e b 2 9 v w C A B C y1 C y L 1 10 Eh e 20 11 19 12 X Dh 0 2.5 5 mm scale Dimensions (mm are the original dimensions) Unit mm A(1) A1 b max 1.00 0.05 0.30 nom 0.90 0.02 0.25 min 0.80 0.00 0.18 c D(1) Dh E(1) Eh e e1 L v 0.2 4.6 4.5 4.4 3.15 3.00 2.85 2.6 2.5 2.4 1.15 1.00 0.85 0.5 3.5 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. References Outline version IEC JEDEC JEITA SOT764-1 --- MO-241 --- sot764-1_po European projection Issue date 03-01-27 14-12-12 Figure 9. Package outline SOT764-1 (DHVQFN20) CBT3244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 September 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 16 CBT3244A Nexperia Octal bus switch with quad output enables TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm D SOT360-1 E A X c HE y v M A Z 11 20 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 10 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Figure 10. Package outline SOT360-1 (TSSOP20) CBT3244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 September 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 16 CBT3244A Nexperia Octal bus switch with quad output enables SSOP20: plastic shrink small outline package; 20 leads; body width 5.3 mm D SOT339-1 E A X c HE y v M A Z 20 11 Q A2 pin 1 index A (A 3) A1 θ Lp L 1 10 bp e detail X w M 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 7.4 7.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 0.9 0.5 8o 0o Note 1. Plastic or metal protrusions of 0.2 mm maximum per side are not included. OUTLINE VERSION SOT339-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Figure 11. Package outline SOT339-1 (SSOP20) CBT3244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 September 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 16 CBT3244A Nexperia Octal bus switch with quad output enables SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c y HE v M A Z 20 11 Q A2 A (A 3 ) A1 pin 1 index θ Lp L 1 10 e bp detail X w M 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.9 0.4 inches 0.1 0.012 0.096 0.004 0.089 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 0.043 0.039 0.01 0.01 0.004 0.035 0.016 Z (1) θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 12. Package outline SOT163-1 (SO20) CBT3244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 September 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 16 CBT3244A Nexperia Octal bus switch with quad output enables 13 Abbreviations Table 11. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model PRR Pulse Rate Repetition TTL Transistor-Transistor Logic 14 Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes CBT3244A v.3 20170908 Product data sheet CBT3244A v.2 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. • Type number CBT3244ADS removed. CBT3244A v.2 20050915 Modifications: • The format of this data sheet has been redesigned to comply with the new presentation and information standard of Philips Semiconductors. • added DHVQFN20 package option. • Section 2, 5th bullet: changed from ‘exceeds 1000 V HBM ...’ to ‘exceeds 2000 V HBM ...’ • added Section 13 Abbreviations CBT3244A v.1 20040526 CBT3244A Product data sheet Product data sheet Product data sheet - - - All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 September 2017 CBT3244A v.1 - © Nexperia B.V. 2017. All rights reserved. 13 / 16 CBT3244A Nexperia Octal bus switch with quad output enables 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical CBT3244A Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 September 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 16 CBT3244A Nexperia Octal bus switch with quad output enables Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer CBT3244A Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 September 2017 © Nexperia B.V. 2017. All rights reserved. 15 / 16 CBT3244A Nexperia Octal bus switch with quad output enables Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 11.1 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Marking .................................................................2 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 4 Functional description ........................................4 Limiting values .................................................... 4 Recommended operating conditions ................ 5 Static characteristics .......................................... 5 Dynamic characteristics .....................................6 Waveforms and test circuit ................................ 6 Package outline ...................................................9 Abbreviations .................................................... 13 Revision history ................................................ 13 Legal information .............................................. 14 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 8 September 2017 Document identifier: CBT3244A
CBT3244ADB,118 价格&库存
很抱歉,暂时无法提供与“CBT3244ADB,118”相匹配的价格&库存,您可以联系我们找货
