74HC139DB-Q100J
74HC139DB-Q100J
    NEXPERIA(安世)
    SSOP16_208MIL
    IC DECODER/DEMUX DUAL 16SSOP
74HC139DB-Q100J 数据手册
74HC139-Q100; 74HCT139-Q100 Dual 2-to-4 line decoder/demultiplexer Rev. 1 — 19 June 2014 Product data sheet 1. General description The 74HC139-Q100; 74HCT139-Q100 decodes two binary weighted address inputs (nA0, nA1) to four mutually exclusive outputs (nY0 to nY3). Each decoder features an enable input (nE). When nE is HIGH all outputs are forced HIGH. The enable input can be used as the data input for a 1-to-4 demultiplexer application. Inputs include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Input levels:  For 74HC139-Q100: CMOS level  For 74HCT139-Q100: TTL level  Demultiplexing capability  2 independent 2-to-4 decoders  Multifunction capability  Suitable for memory decoding, data routing or code conversion  Complies with JEDEC standard no. 7A  Active LOW mutually exclusive outputs  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 74HC139-Q100; 74HCT139-Q100 Nexperia Dual 2-to-4 line decoder/demultiplexer 3. Ordering information Table 1. Ordering information Type number Package 74HC139D-Q100 Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74 HCT139D-Q100 74HC139DB-Q100 74HCT139DB-Q100 74HC139PW-Q100 74HCT139PW-Q100 4. Functional diagram
74HC139DB-Q100J
1. 物料型号:74HC139-Q100 和 74HCT139-Q100 是双2至4线解码器/解复用器。
2. 器件简介:这些芯片能将两个二进制加权地址输入(nA0, nA1)解码为四个互斥的输出(nY0 至 nY3)。每个解码器具有使能输入(nE),当 nE 为高电平时,所有输出被强制为高电平。使能输入可以用作1至4解复用器应用的数据输入。输入包含钳位二极管,允许使用限流电阻将输入接口至超过 VCC 的电压。
3. 引脚分配:芯片有16个引脚,包括使能输入(1E, 2E)、地址输入(1A0, 1A1, 2A0, 2A1)、输出(1Y0 至 1Y3, 2Y0 至 2Y3)、地(GND)和正电源电压(VCC)。
4. 参数特性:包括工作电压范围(-40°C 至 +125°C)、输入电平(74HC139-Q100 为 CMOS 电平,74HCT139-Q100 为 TTL 电平)、解复用能力、多功能能力、符合 JEDEC 标准等。
5. 功能详解:芯片符合汽车电子委员会(AEC)标准 Q100(1级),适用于汽车应用。具有 ESD 保护,包括 MIL-STD-883 方法 3015 超过 2000V、HBM JESD22-A114F 超过 2000V 和 MM JESD22-A115-A 超过 200V。
6. 应用信息:适用于内存解码、数据路由或代码转换。
7. 封装信息:提供多种封装选项,包括 SO16、SSOP16 和 TSSOP16。
74HC139DB-Q100J 价格&库存
很抱歉,暂时无法提供与“74HC139DB-Q100J”相匹配的价格&库存,您可以联系我们找货
