74HCT253DB,118
74HCT253DB,118
    NEXPERIA(安世)
    SSOP-16
    IC MULTIPLEXER 2 X 4:1 16SSOP
74HCT253DB,118 数据手册
74HC253; 74HCT253 Dual 4-input multiplexer; 3-state Rev. 9 — 20 October 2022 Product data sheet 1. General description The 74HC253; 74HCT253 is a dual 4-bit multiplexer, each with four binary inputs (nI0 to nI3), an output enable input (nOE) and shared select inputs (S0 and S1). One of the four binary inputs is selected by the select inputs and routed to the output nY. A HIGH on nOE causes the outputs to assume a high-impedance OFF-state. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits • • • • • • • • • • • • • Non-inverting data path 3-state outputs interface directly with system bus Common select inputs Separate output enable inputs Wide supply voltage range from 2.0 V to 6.0 V Input levels: • For 74HC253: CMOS level • For 74HCT253: TTL level CMOS low power dissipation High noise immunity Latch-up performance exceeds 100 mA per JESD 78 Class II Level B Complies with JEDEC standards • JESD8C (2.7 V to 3.6 V) • JESD7A (2.0 V to 6.0 V) ESD protection: • HBM JESD22-A114F exceeds 2 kV • MM JESD22-A115-A exceeds 200 V Multiple package options Specified from -40 °C to +85 °C and from -40 °C to +125 °C 3. Applications • • Data selectors Data multiplexers 74HC253; 74HCT253 Nexperia Dual 4-input multiplexer; 3-state 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74HC253PW -40 °C to +125 °C 74HCT253PW TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74HC253BQ DHVQFN16 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5 × 3.5 × 0.85 mm SOT763-1 74HC253D 74HCT253D -40 °C to +125 °C 5. Functional diagram 1 1I1 5 13 14 1I0 1I1 1I2 1I3 2I0 2I1 2I2 2I3 S0 10 2 S1 11 1 1OE 12 15 2OE 14 Fig. 1. 4 3 10 11 12 2Y 7 9 S1 2 2I0 2I1 9 2I3 15 001aal850 Fig. 2. 1I3 2Y MUX 2I2 2OE Logic symbol 1OE 1I2 1I1 1I0 S0 S1 001aal851 Functional diagram 2I3 1Y Fig. 3. S0 13 1Y 7 1I3 3 5 1Y MUX 1I2 4 6 1OE 1I0 6 2I2 2I1 2Y 2I0 2OE 001aal852 Logic diagram 74HC_HCT253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 20 October 2022 © Nexperia B.V. 2022. All rights reserved 2 / 16 74HC253; 74HCT253 Nexperia Dual 4-input multiplexer; 3-state 6. Pinning information 6.1. Pinning D package SOT109-1 (SO16) 1I3 3 14 S0 1I2 4 13 2I3 1I1 5 12 2I2 1I0 6 11 2I1 1Y 7 10 2I0 GND 8 9 2Y 1OE 1 1OE 15 2OE 1 2 S1 2 15 2OE 16 VCC 1I3 3 14 S0 4 13 2I3 S1 2 15 2OE 1I2 1I3 3 14 S0 1I1 5 1I2 4 13 2I3 1I1 5 12 2I2 1I0 6 1I0 6 11 2I1 1Y 7 1Y 7 10 2I0 GND 8 9 2Y aaa-035487 aaa-035486 12 2I2 VCC(1) 11 2I1 10 2I0 9 S1 terminal 1 index area PW package SOT403-1 (TSSOP16) 8 16 VCC 2Y 1 GND 1OE 16 VCC BQ package SOT763-1 (DHVQFN16) aaa-034032 Transparent top view (1) This is not a supply pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to VCC. 6.2. Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE 1, 15 output enable inputs (active LOW) S0, S1 14, 2 data select inputs 1I0, 1I1, 1I2, 1I3 6, 5, 4, 3 data inputs source 1 1Y 7 multiplexer output source 1 GND 8 ground (0 V) 2Y 9 multiplexer output source 2 2I0, 2I1, 2I2, 2I3 10, 11, 12, 13 data inputs source 2 VCC 16 supply voltage 74HC_HCT253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 20 October 2022 © Nexperia B.V. 2022. All rights reserved 3 / 16 74HC253; 74HCT253 Nexperia Dual 4-input multiplexer; 3-state 7. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. select Inputs data inputs output enable output S0 S1 nI0 nI1 nI2 nI3 nOE nY X X X X X X H Z L L L X X X L L L L H X X X L H H L X L X X L L H L X H X X L H L H X X L X L L L H X X H X L H H H X X X L L L H H X X X H L H 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +7.0 V [1] - ±20 mA [1] - ±50 mA - ±35 mA supply current - 70 mA ground current -70 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V IO output current -0.5 V < VO < VCC + 0.5 V ICC IGND [1] [2] Tamb = -40 °C to +125 °C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C. For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C. For SOT763-1 (DHVQFN16) package: Ptot derates linearly with 11.2 mW/K above 106 °C. 74HC_HCT253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 20 October 2022 © Nexperia B.V. 2022. All rights reserved 4 / 16 74HC253; 74HCT253 Nexperia Dual 4-input multiplexer; 3-state 9. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74HC253 74HCT253 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 - +125 -40 - +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 10. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V 74HC253 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -6.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -7.8 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 6.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 7.8 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±0.1 - ±1.0 - ±1.0 μA IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - ±0.5 - ±5.0 - ±10.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 μA 74HC_HCT253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 20 October 2022 © Nexperia B.V. 2022. All rights reserved 5 / 16 74HC253; 74HCT253 Nexperia Dual 4-input multiplexer; 3-state Symbol Parameter CI Conditions 25 °C input capacitance -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max - 3.5 - - - - - pF 74HCT253 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = -20 μA 4.4 4.5 - 4.4 - 4.4 - V IO = -6 mA 3.98 4.32 - 3.84 - 3.7 - V IO = 20 μA - 0 0.1 - 0.1 - 0.1 V IO = 6.0 mA - 0.15 0.26 - 0.33 - 0.4 V VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±0.1 - ±1.0 - ±1.0 μA IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - - ±0.5 - ±5.0 - ±10 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 - 80 - 160 μA ΔICC additional supply current VI = VCC - 2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A per input pin; 1In, 2In inputs - 40 144 - 180 - 196 μA per input pin; nOE input - 110 396 - 495 - 539 μA per input pin; Sn input - 110 396 - 495 - 539 μA - 3.5 - - - - - pF CI input capacitance 74HC_HCT253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 20 October 2022 © Nexperia B.V. 2022. All rights reserved 6 / 16 74HC253; 74HCT253 Nexperia Dual 4-input multiplexer; 3-state 11. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); For test circuit see Fig. 6. Symbol Parameter Conditions -40 °C to +85 °C 25 °C -40 °C to +125 °C Unit Typ Max Max Max 55 175 220 265 ns VCC = 4.5 V 20 35 44 53 ns VCC = 5.0 V; CL = 15 pF 17 - - - ns VCC = 6.0 V 16 30 37 45 ns VCC = 2.0 V 58 175 220 265 ns VCC = 4.5 V 21 35 44 53 ns VCC = 5.0 V; CL = 15 pF 18 - - - ns VCC = 6.0 V 17 30 37 45 ns VCC = 2.0 V 30 100 125 150 ns VCC = 4.5 V 11 20 25 30 ns VCC = 6.0 V 9 17 21 26 ns VCC = 2.0 V 41 150 190 225 ns VCC = 4.5 V 15 30 38 45 ns VCC = 6.0 V 12 26 33 38 ns VCC = 2.0 V 14 60 75 90 ns VCC = 4.5 V 5 12 15 18 ns VCC = 6.0 V 4 10 13 15 ns 55 - - - pF 74HC253 tpd propagation 1ln to 1Y or 2ln to 2Y; see Fig. 4 [1] delay VCC = 2.0 V Sn to nY; see Fig. 4 ten tdis tt CPD enable time nOE to nY; see Fig. 5 disable time nOE to nY; see Fig. 5 transition time see Fig. 4 power per multiplexer; dissipation VI = GND to VCC capacitance 74HC_HCT253 Product data sheet [2] [3] [4] [5] All information provided in this document is subject to legal disclaimers. Rev. 9 — 20 October 2022 © Nexperia B.V. 2022. All rights reserved 7 / 16 74HC253; 74HCT253 Nexperia Dual 4-input multiplexer; 3-state Symbol Parameter Conditions -40 °C to +85 °C 25 °C -40 °C to +125 °C Unit Typ Max Max Max 20 38 48 57 ns 17 - - - ns 22 40 50 60 ns 74HCT253 propagation 1ln to 1Y or 2ln to 2Y; see Fig. 4 [1] delay VCC = 4.5 V tpd VCC = 5.0 V; CL = 15 pF Sn to nY; see Fig. 4 VCC = 4.5 V 19 - - - ns ten enable time nOE to nY; VCC = 4.5 V; see Fig. 5 VCC = 5.0 V; CL = 15 pF [2] 14 30 38 45 ns tdis disable time nOE to nY; VCC = 4.5 V; see Fig. 5 [3] 13 30 38 45 ns tt transition time 5 12 15 18 ns CPD power per multiplexer; dissipation VI = GND to VCC - 1.5 V capacitance 55 - - - pF [1] [2] [3] [4] [5] VCC = 4.5 V; see Fig. 4 [5] tpd is the same as tPHL, tPLH. ten is the same as tPZH, tPZL. tdis is the same as tPHZ, tPLZ. tt is the same as tTHL, tTLH. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + ∑(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 ∑(CL × VCC × fo) = sum of outputs. 74HC_HCT253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 20 October 2022 © Nexperia B.V. 2022. All rights reserved 8 / 16 74HC253; 74HCT253 Nexperia Dual 4-input multiplexer; 3-state 11.1. Waveforms and test circuit VI VM Sn, 1In, 2ln input VM GND tPHL tPLH VOH 90 % VM nY output VM 10 % VOL tTHL tTLH 001aal855 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 4. Propagation delays input (Sn, 1In, 2In) to output (nY) and output (nY) transition times tr VI tf 90 % nOE input VM GND 10 % tPLZ output LOW-to-OFF OFF-to-LOW tPZL VCC VM 10 % VOL tPHZ output HIGH-to-OFF OFF-to-HIGH VOH tPZH 90 % VM GND outputs enabled outputs disabled outputs enabled 001aal856 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 5. 3-state output enable and disable times Table 8. Measurement points Type Input Output VM VM 74HC253 0.5 × VCC 0.5 × VCC 74HCT253 1.3 V 1.3 V 74HC_HCT253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 20 October 2022 © Nexperia B.V. 2022. All rights reserved 9 / 16 74HC253; 74HCT253 Nexperia Dual 4-input multiplexer; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VCC VO RT RL S1 open CL 001aad983 Measurement points are given in Table 8 and test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator; CL = Load capacitance including jig and probe capacitance; RL = Load resistor. Fig. 6. Test circuit for measuring switching times Table 9. Test data Type Input Load Switch position VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74HC253 VCC 6 ns 50 pF 1 kΩ open GND VCC 74HCT253 3V 6 ns 50 pF 1 kΩ open GND VCC 74HC_HCT253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 20 October 2022 © Nexperia B.V. 2022. All rights reserved 10 / 16 74HC253; 74HCT253 Nexperia Dual 4-input multiplexer; 3-state 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 7. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT109-1 (SO16) 74HC_HCT253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 20 October 2022 © Nexperia B.V. 2022. All rights reserved 11 / 16 74HC253; 74HCT253 Nexperia Dual 4-input multiplexer; 3-state TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 Fig. 8. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Package outline SOT403-1 (TSSOP16) 74HC_HCT253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 20 October 2022 © Nexperia B.V. 2022. All rights reserved 12 / 16 74HC253; 74HCT253 Nexperia Dual 4-input multiplexer; 3-state DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm B D A A E A1 c detail X terminal 1 index area terminal 1 index area C e1 e b 2 7 y y1 C v M C A B w M C L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 0.5 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Fig. 9. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Package outline SOT763-1 (DHVQFN16) 74HC_HCT253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 20 October 2022 © Nexperia B.V. 2022. All rights reserved 13 / 16 74HC253; 74HCT253 Nexperia Dual 4-input multiplexer; 3-state 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT253 v.9 20221020 Product data sheet - Modifications: • 74HC_HCT253 v.8 20211018 Modifications: • 74HC_HCT253 v.7 20210816 Modifications: • • • • • • Type number 74HC253BQ (SOT763-1/DHVQFN16) added. - 74HC_HCT253 v.7 Product data sheet - 74HC_HCT253 v.6 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type numbers 74HC253DB and 74HCT253DB (SOT338-1/SSOP16) removed. Type number 74HC253PW (SOT403-1/TSSOP16) added. Section 2 updated. Section 8: Derating values for Ptot total power dissipation updated. 20160201 Modifications: • 74HC_HCT253 v.5 20150121 Modifications: • 74HC_HCT253 v.4 20111212 Modifications: • 74HC_HCT253 v.3 20100422 74HC_HCT253_CNV v.2 970828 Product data sheet Product data sheet Type number 74HCT253PW (SOT403-1/TSSOP16) added. 74HC_HCT253 v.6 74HC_HCT253 74HC_HCT253 v.8 Product data sheet - 74HC_HCT253 v.5 Type numbers 74HC253N and 74HCT253N (SOT38-4) removed. Product data sheet - 74HC_HCT253 v.4 Table 7: Power dissipation capacitance condition for 74HCT253 is corrected. Product data sheet - 74HC_HCT253 v.3 Product data sheet - 74HC_HCT253_CNV v.2 Product specification - - Legal pages updated. All information provided in this document is subject to legal disclaimers. Rev. 9 — 20 October 2022 © Nexperia B.V. 2022. All rights reserved 14 / 16 74HC253; 74HCT253 Nexperia Dual 4-input multiplexer; 3-state 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC_HCT253 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 9 — 20 October 2022 © Nexperia B.V. 2022. All rights reserved 15 / 16 74HC253; 74HCT253 Nexperia Dual 4-input multiplexer; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................2 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 3 7. Functional description................................................. 4 8. Limiting values............................................................. 4 9. Recommended operating conditions..........................5 10. Static characteristics..................................................5 11. Dynamic characteristics.............................................7 11.1. Waveforms and test circuit........................................ 9 12. Package outline........................................................ 11 13. Abbreviations............................................................ 14 14. Revision history........................................................14 15. Legal information......................................................15 © Nexperia B.V. 2022. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 20 October 2022 74HC_HCT253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 20 October 2022 © Nexperia B.V. 2022. All rights reserved 16 / 16
74HCT253DB,118 价格&库存
很抱歉,暂时无法提供与“74HCT253DB,118”相匹配的价格&库存,您可以联系我们找货
74HCT253DB,118
    • 1+4.11480
    • 10+3.32640
    • 30+2.93760
    • 100+2.54880
    • 500+2.31120
    • 1000+2.19240
