74HC151; 74HCT151
8-input multiplexer
Rev. 10 — 19 October 2022
Product data sheet
1. General description
The 74HC151; 74HCT151 is an 8-bit multiplexer with eight binary inputs (I0 to I7), three select
inputs (S0 to S2) and an enable input (E). One of the eight binary inputs is selected by the select
inputs and routed to the complementary outputs (Y and Y). A HIGH on E forces the output Y
LOW and output Y HIGH. Inputs also include clamp diodes that enable the use of current limiting
resistors to interface inputs to voltages in excess of VCC.
2. Features and benefits
Wide supply voltage range from 2.0 V to 6.0 V
CMOS low power dissipation
High noise immunity
Latch-up performance exceeds 100 mA per JESD 78 Class II Level B
Input levels:
• For 74HC151: CMOS level
• For 74HCT151: TTL level
Non-inverting data path
Complies with JEDEC standards
• JESD8C (2.7 V to 3.6 V)
• JESD7A (2.0 V to 6.0 V)
ESD protection:
• HBM JESD22-A114F exceeds 2 kV
• MM JESD22-A115-A exceeds 200 V
Specified from -40 °C to +85 °C and from -40 °C to +125 °C
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74HC151D
74HCT151D
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
74HC151PW
74HCT151PW
-40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package;
16 leads; body width 4.4 mm
SOT403-1
74HC151BQ
-40 °C to +125 °C
DHVQFN16 plastic dual in-line compatible thermal
enhanced very thin quad flat package; no leads;
16 terminals; body 2.5 × 3.5 × 0.85 mm
SOT763-1
74HC151; 74HCT151
Nexperia
8-input multiplexer
4. Functional diagram
7
Fig. 1.
4
3
2
1
15
14
13
12
I0
I1
I2
I3
I4
I5
I6
I7
E
S0
S1
S2
11
10
9
Y
5
Y
6
aaa-004582
Logic symbol
I7
I6
I5
4
3
I0
11
10
9
7
2
I1
1
I2
15
I3
14
I4
13
I5
12
I6
I4
I7
S0
S1
I3
Y
I2
Y
I1
MULTIPLEXER
S2
I0
E
Y
Y
aaa-004586
5
Fig. 2.
Functional diagram
74HC_HCT151
Product data sheet
S2
6
Fig. 3.
S1
S0
E
aaa-004587
Logic diagram
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2022. All rights reserved
2 / 16
74HC151; 74HCT151
Nexperia
8-input multiplexer
5. Pinning information
5.1. Pinning
I1
3
14 I5
I0
4
13 I6
Y
5
12 I7
Y
6
11 S0
E
7
10 S1
GND
8
9
S2
I3
1
I2
2
15 I4
16 VCC
I1
3
14 I5
4
13 I6
I2
2
15 I4
I0
I1
3
14 I5
Y
5
I0
4
13 I6
6
Y
5
12 I7
Y
Y
6
11 S0
E
7
E
7
10 S1
GND
8
9
S2
11
S0
10 S1
aaa-035629
Transparent top view
aaa-035628
aaa-035627
12 I7
GND(1)
9
15 I4
S2
2
I3
I2
terminal 1
index area
PW package
SOT403-1 (TSSOP16)
1
16 VCC
8
1
GND
I3
16 VCC
BQ package
SOT763-1 (DHVQFN16)
D package
SOT109-1 (SO16)
(1) This is not a ground pin. There is no electrical or mechanical requirement to solder
the pad. In case soldered, the solder land should remain floating or connected to GND.
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
I0, I1, I2, I3, I4, I5, I6, I7
4, 3, 2, 1, 15, 14, 13, 12
data inputs
Y
5
multiplexer output
Y
6
complementary multiplexer output
E
7
enable input (active LOW)
GND
8
ground (0 V)
S0, S1, S2
11, 10, 9
common data select inputs
VCC
16
supply voltage
74HC_HCT151
Product data sheet
3 / 16
74HC151; 74HCT151
Nexperia
8-input multiplexer
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
Input
Output
E
S2
S1
S0
I0
I1
I2
I3
I4
I5
I6
I7
Y
Y
H
X
X
X
X
X
X
X
X
X
X
X
H
L
L
L
L
L
L
X
X
X
X
X
X
X
H
L
L
L
L
L
H
X
X
X
X
X
X
X
L
H
L
L
L
H
X
L
X
X
X
X
X
X
H
L
L
L
L
H
X
H
X
X
X
X
X
X
L
H
L
L
H
L
X
X
L
X
X
X
X
X
H
L
L
L
H
L
X
X
H
X
X
X
X
X
L
H
L
L
H
H
X
X
X
L
X
X
X
X
H
L
L
L
H
H
X
X
X
H
X
X
X
X
L
H
L
H
L
L
X
X
X
X
L
X
X
X
H
L
L
H
L
L
X
X
X
X
H
X
X
X
L
H
L
H
L
H
X
X
X
X
X
L
X
X
H
L
L
H
L
H
X
X
X
X
X
H
X
X
L
H
L
H
H
L
X
X
X
X
X
X
L
X
H
L
L
H
H
L
X
X
X
X
X
X
H
X
L
H
L
H
H
H
X
X
X
X
X
X
X
L
H
L
L
H
H
H
X
X
X
X
X
X
X
H
L
H
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
IOK
output clamping current
IO
output current
ICC
Min
Max
-0.5
+7
V
VI < -0.5 V or VI > VCC + 0.5 V
±20
mA
VO < -0.5 V or VO > VCC + 0.5 V
±20
mA
VO = -0.5 V to (VCC + 0.5 V)
±25
mA
supply current
+50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
Conditions
Tamb = -40 °C to +125 °C
[1]
Unit
For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C.
For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C.
For SOT763-1 (DHVQFN16) package: Ptot derates linearly with 11.2 mW/K above 106 °C.
74HC_HCT151
Product data sheet
4 / 16
74HC151; 74HCT151
Nexperia
8-input multiplexer
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
74HC151
74HCT151
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
Δt/ΔV
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C -40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
74HC151
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
VI = VIH or VIL
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = -5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
VI = VIH or VIL
II
input leakage
current
VI = VCC or GND; VCC = 6.0 V
±0.1
±1.0
±1.0
μA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
80
160
μA
CI
input
capacitance
3.5
pF
74HC_HCT151
Product data sheet
5 / 16
74HC151; 74HCT151
Nexperia
8-input multiplexer
Symbol Parameter
Conditions
25 °C
Min
Typ
Max
Min
Max
Min
Max
74HCT151
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
IO = -20 μA
4.4
4.5
4.4
4.4
V
IO = -4 mA
3.98
4.32
3.84
3.7
V
IO = 20 μA
0.1
0.1
V
IO = 4.0 mA
LOW-level
output voltage
0.15
0.26
0.33
0.4
V
II
input leakage
current
VI = VCC or GND; VCC = 5.5 V
±0.1
±1.0
±1.0
μA
ICC
supply current
VCC = 5.5 V
8.0
80
160
μA
ΔICC
additional
supply current
VI = VCC - 2.1 V;
other inputs at VCC or GND;
VCC = 4.5 V to 5.5 V; IO = 0 A
per input pin; In inputs
45
162
203
221
μA
per input pin; E input
30
108
135
147
μA
per input pin; Sn input
150
540
675
735
μA
3.5
pF
VOL
CI
input
capacitance
74HC_HCT151
Product data sheet
6 / 16
74HC151; 74HCT151
Nexperia
8-input multiplexer
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Fig. 6.
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C
Min
Typ
Max
Min
Max
Min
Max
52
170
215
255
ns
VCC = 4.5 V
19
34
43
51
ns
VCC = 5 V; CL = 15 pF
17
ns
VCC = 6.0 V
15
29
37
43
ns
VCC = 2.0 V
58
185
230
280
ns
VCC = 4.5 V
21
37
46
56
ns
17
ns
VCC = 6.0 V
17
31
39
48
ns
VCC = 2.0 V
61
185
230
280
ns
VCC = 4.5 V
22
37
46
56
ns
19
ns
VCC = 6.0 V
18
31
39
48
ns
VCC = 2.0 V
61
205
255
310
ns
VCC = 4.5 V
22
41
51
62
ns
19
ns
VCC = 6.0 V
18
35
43
53
ns
VCC = 2.0 V
41
125
155
190
ns
VCC = 4.5 V
15
25
31
38
ns
12
ns
VCC = 6.0 V
12
21
26
32
ns
VCC = 2.0 V
47
145
180
220
ns
VCC = 4.5 V
17
29
36
44
ns
14
ns
VCC = 6.0 V
14
25
31
38
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
40
pF
74HC151
tpd
propagation In to Y; see Fig. 4
delay
VCC = 2.0 V
[1]
In to Y; see Fig. 4
[1]
Sn to Y; see Fig. 5
[1]
Sn to Y; see Fig. 5
[1]
E to Y; see Fig. 5
E to Y; see Fig. 5
tt
CPD
transition
time
Y, Y; see Fig. 4
[2]
power
CL = 50 pF; f = 1 MHz;
dissipation VI = GND to VCC
capacitance
74HC_HCT151
Product data sheet
[3]
7 / 16
74HC151; 74HCT151
Nexperia
8-input multiplexer
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C
Min
Typ
Max
Min
Max
Min
Max
22
38
48
57
ns
19
ns
22
38
48
57
ns
19
ns
VCC = 4.5 V
23
41
51
62
ns
ns
VCC = 4.5 V
25
43
54
65
ns
ns
VCC = 4.5 V
16
29
36
44
ns
13
ns
VCC = 4.5 V
21
36
45
54
ns
18
ns
7
15
19
22
ns
40
pF
74HCT151
delay
VCC = 4.5 V
tpd
[1]
In to Y; see Fig. 4
[1]
VCC = 4.5 V
Sn to Y; see Fig. 5
[1]
Sn to Y; see Fig. 5
[1]
E to Y; see Fig. 5
[1]
E to Y; see Fig. 5
tt
transition
time
CPD
[1]
[2]
[3]
[1]
Y, Y; see Fig. 4
[2]
VCC = 4.5 V
power
dissipation VI = GND to VCC - 1.5 V
capacitance
[3]
tpd is the same as tPLH and tPHL.
tt is the same as tTHL and tTLH.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL × VCC × fo) = sum of outputs.
74HC_HCT151
Product data sheet
8 / 16
74HC151; 74HCT151
Nexperia
8-input multiplexer
10.1. Waveforms and test circuit
VI
In input
VM
VM
GND
tPHL
VOH
tPLH
90 %
90 %
VM
Y output
VM
10 %
VOL
10 %
tTLH
tTHL
tPLH
VOH
Y output
VOL
90 %
VM
tPHL
90 %
VM
10 %
10 %
tTLH
tTHL
aaa-004588
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 4.
Propagation delay input (In) to output (Y, Y) and the output (Y, Y) transition time
VI
VM
Sn, E input
VM
GND
tPHL
VOH
tPLH
90 %
90 %
VM
Y output
VM
10 %
VOL
10 %
tTLH
tTHL
tPLH
VOH
90 %
VM
Y output
tPHL
90 %
VOL
VM
10 %
10 %
tTLH
tTHL
aaa-004589
Fig. 5.
Propagation delay input (Sn, E) to output (Y, Y) and output (Y, Y) transitions time
Table 8. Measurement points
Type
Input
Output
VM
VM
74HC151
0.5 × VCC
0.5 × VCC
74HCT151
1.3 V
1.3 V
74HC_HCT151
Product data sheet
9 / 16
74HC151; 74HCT151
Nexperia
8-input multiplexer
VI
negative
pulse
VM
VI
GND
VM
10 %
GND
positive
pulse
tW
90 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VO
RT
CL
001aah768
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator;
CL = Load capacitance including jig and probe capacitance;
RL = Load resistance;
S1 = Test selection switch.
Fig. 6.
Test circuit for measuring switching times
Table 9. Test data
Type
Load
Input
Test
VI
tr, tf
CL
74HC151
VCC
6.0 ns
15 pF, 50 pF
tPLH, tPHL
74HCT151
3.0 V
6.0 ns
15 pF, 50 pF
tPLH, tPHL
74HC_HCT151
Product data sheet
10 / 16
74HC151; 74HCT151
Nexperia
8-input multiplexer
11. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.05
0.039
0.016
0.028
0.020
0.01
0.01
0.004
0.028
0.012
0.244
0.041
0.228
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig. 7.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT109-1 (SO16)
74HC_HCT151
Product data sheet
11 / 16
74HC151; 74HCT151
Nexperia
8-input multiplexer
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
Fig. 8.
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Package outline SOT403-1 (TSSOP16)
74HC_HCT151
Product data sheet
12 / 16
74HC151; 74HCT151
Nexperia
8-input multiplexer
DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT763-1
16 terminals; body 2.5 x 3.5 x 0.85 mm
B
D
A
A
E
A1
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
b
2
7
y
y1 C
v M C A B
w M C
L
1
8
Eh
e
16
9
15
10
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
c
D (1)
Dh
E (1)
Eh
e
e1
L
v
w
y
y1
mm
1
0.05
0.00
0.30
0.18
0.2
3.6
3.4
2.15
1.85
2.6
2.4
1.15
0.85
0.5
2.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
Fig. 9.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT763-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Package outline SOT763-1 (DHVQFN16)
74HC_HCT151
Product data sheet
13 / 16
74HC151; 74HCT151
Nexperia
8-input multiplexer
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74HC_HCT151 v.10
20221019
Product data sheet
Modifications:
74HC_HCT151 v.9
20220706
Modifications:
74HC_HCT151 v.8
20210318
Modifications:
74HC_HCT151 v.7
20210114
Modifications:
Type number 74HC151BQ (SOT763-1/DHVQFN16) added.
74HC_HCT151 v.8
Product data sheet
74HC_HCT151 v.7
Type number 74HC151DB (SOT338-1/SSOP16) added.
Product data sheet
74HC_HCT151 v.6
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type numbers 74HC151DB and 74HCT151DB (SOT338-1/SSOP16) removed.
Section 7: Derating values for Ptot total power dissipation have been updated.
20151228
Modifications:
74HC_HCT151 v.5
20150126
Modifications:
74HC_HCT151 v.4
20130211
Modifications:
74HC_HCT151 v.3
20120919
74HC_HCT151_CNV v.2
19970827
Product data sheet
Product data sheet
Section 2 updated.
Type number 74HC151DB (SOT338-1/SSOP16) removed.
74HC_HCT151 v.6
74HC_HCT151
74HC_HCT151 v.9
Product data sheet
74HC_HCT151 v.5
Type numbers 74HC151N and 74HCT151N (SOT38-4) removed.
Product data sheet
74HC_HCT151 v.4
Table 7: Power dissipation capacitance condition for 74HCT151 is corrected.
Product data sheet
74HC_HCT151 v.3
Product data sheet
74HC_HCT151_CNV v.2
Product specification
New descriptive title (errata).
14 / 16
74HC151; 74HCT151
Nexperia
8-input multiplexer
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74HC_HCT151
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
15 / 16
74HC151; 74HCT151
Nexperia
8-input multiplexer
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 3
6. Functional description................................................. 4
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................5
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 7
10.1. Waveforms and test circuit........................................ 9
11. Package outline........................................................ 11
12. Abbreviations............................................................ 14
13. Revision history........................................................14
14. Legal information......................................................15
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 19 October 2022
74HC_HCT151
Product data sheet
16 / 16
