WMS7201050P
WMS7201050P
    NUVOTON(新唐)
    DIP8
    IC DGTL POT 50KOHM 256TAP 8DIP
WMS7201050P 数据手册
PRELIMINARY WMS7201 256-TAP NON-VOLATILE DIGITAL POTENTIOMETER -1- Publication Release Date: April 22, 2005 Revision 1.2 WMS7201 1. GENERAL DESCRIPTION The WMS7201 is a 256-tap, single-channel non-volatile digital potentiometer available in 10KΩ, 50KΩ and 100KΩ end-to-end resistances. These devices can be used as a three-terminal potentiometer or as a two terminal variable resistor in a wide variety of applications. The output of the potentiometer is determined by the wiper position, which varies linearly between VA and VB terminal according to the content stored in the volatile Tap Register (TR). The settings of the TR can be provided either directly by the user through the industry standard SPI interface, or by the non-volatile memory (NVMEM0~3) where the previous settings are stored. When changes are made to the TR to establish a new wiper position, the value of the setting can be saved into any non-volatile memory location (NVMEM0~3) by executing a NVMEM save operation. Upon powerup the content of the NVMEM0 is automatically loaded to the Tap Register. The WMS7201 contains a single potentiometer in 8-pin PDIP, SOIC, MSOP or 10 pin TSSOP packages and can operate over a wide operating voltage range from 2.7V to 5.5V. A selectable output buffer is built-in for those applications where an output buffer is required. 2. FEATURES • 256 taps for the potentiometer • End-to-end resistance available in 10KΩ, 50KΩ and 100KΩ • Selectable output buffer for each channel • SPI Serial Interface for data transfer and potentiometer control • Daisy-chain operation for multiple devices (10-pin TSSOP package only) • Nonvolatile storage of four wiper positions per channel with power-on recall from NVMEM0 • Low standby current (1μA Max. with output buffer inactive) • Endurance 100K typical stores per bit • Register Data Retention 100 years • Industrial temperature range: -40 ~ 85°C • Wide operating voltage range: 2.7V ~ 5.5V • Package option: ƒ 8-pin MSOP, 8-pin SOIC, 8-pin PDIP, 10-pin TSSOP -2- WMS7201 CS Interface SDI MUX Serial VA1 Decoder CLK Tap Register 3. BLOCK DIAGRAM VW1 VB1 1 SDO NV Memory 1 WP VDD NV Memory Control Power on/Preset Mem Tap 9th bit 3 Addressable Preset Tap values 9th bit VSS FIGURE 1 – WMS7201 BLOCK DIAGRAM Note 1: Available in 10-pin TSSOP packages only. -3- Publication Release Date: April 22, 2005 Revision 1.2 WMS7201 4. TABLE OF CONTENTS 1. GENERAL DESCRIPTION.................................................................................................................. 2 2. FEATURES ......................................................................................................................................... 2 3. BLOCK DIAGRAM .............................................................................................................................. 3 4. TABLE OF CONTENTS ...................................................................................................................... 4 5. PIN CONFIGURATION ....................................................................................................................... 5 6. PIN DESCRIPTION ............................................................................................................................. 5 7. FUNCTIONAL DESCRIPTION............................................................................................................ 7 7.1. Potentiometer and Rheostat Modes ............................................................................................. 7 7.1.1. Rheostat Configuration .......................................................................................................... 7 7.1.2. Potentiometer Configuration .................................................................................................. 7 7.2. Programming Modes .................................................................................................................... 7 7.3. Non-Volatile Memory (NVMEM) ................................................................................................... 8 7.3.1 Write Protect of NVMEM ......................................................................................................... 8 7.4 Flow Control................................................................................................................................... 8 7.5. Daisy Chain .................................................................................................................................. 9 7.6. Serial Data Iterface ..................................................................................................................... 10 7.7. Instruction Set ............................................................................................................................. 12 7.8. Basic Operation .......................................................................................................................... 12 7.8.1 Sending a Command ............................................................................................................ 12 7.8.2 Wake Up/Sleep/Power Commands ...................................................................................... 13 7.8.3 Write to Tap Register (TR) .................................................................................................... 13 7.8.4 Programming Non-Volatile Memory (NVMEM)..................................................................... 14 7.8.5 Reading Tap Register and NVMEM Location (10-pin TSSOP package only)...................... 15 8. TIMING DIAGRAMS.......................................................................................................................... 16 9. ABSOLUTE MAXIMUM RATINGS.................................................................................................... 18 10. ELECTRICAL CHARACTERISTICS ............................................................................................... 19 10.1 Test Circuits ............................................................................................................................... 21 11. TYPICAL APPLICATION CIRCUIT................................................................................................. 22 11.1. Layout Considerations .............................................................................................................. 24 12. PACKAGE DRAWINGS AND DEMINSIONS.................................................................................. 25 13. ORDERING INFORMATION........................................................................................................... 28 14. VERSION HISTORY ....................................................................................................................... 29 -4- WMS7201 5. PIN CONFIGURATION FIGURE 2 – PACKAGE TYPES -5- Publication Release Date: April 22, 2005 Revision 1.2 WMS7201 6. PIN DESCRIPTION TABLE 1 – PIN DESCRIPTION PIN NAME PIN NO 2 I/O DESCRIPTION I Serial Clock pin. Data Shifts in one bit at a time on positive clock (CLK) edges I Chip Select pin. When CS is HIGH, WMS7201 is deselected and the SDO pin is at high impedance, and (unless an internal write cycle is underway) the device will be in the standby state. CS LOW enables WMS7201, placing it in the active power mode. It should be noted that after a power-up, a HIGH to LOW transition on CS is required prior to the start of any operation. I Serial Data Input pin. All opcodes, byte addresses and data to be written to the registers are input on this pin. Data is latched by the rising edge of the serial clock. O Serial Data Output pin with open-drain output. During a read cycle, data is shifted out on this pin. Data is clocked out by the falling edge of the serial clock except for the 1st bit, which is clocked out by the falling edge of CS. Also can be used to daisy-chain several parts. (Only 10-pin TSSOP package) NC I Hardware Write Protect pin. When active LOW WP prevents any changes to the present contents except retrieving NVMEM contents. (Only 10-pin TSSOP package) VDD 8 - Power Supply VSS 4 - Ground pin, logic ground reference - A terminal of potentiometer ‘1’, equivalent to the HI terminal connection on a mechanical potentiometer - B terminal of potentiometer ‘1’, equivalent to the LO terminal connection on a mechanical potentiometer O Wiper terminal of potentiometer ‘1’, equivalent to the wiper terminal of a mechanical potentiometer CLK CS 1 3 SDI SDO WP VA1 VB1 VW1 1 1 NC 7 5 6 -6- WMS7201 7. FUNCTIONAL DESCRIPTION The WMS7201 series, a family of 256-tap, nonvolatile digitally programmable potentiometers is designed to operate as both a potentiometer or a variable resistor depending upon the output configuration selected. The chip can store four 9-bit words in nonvolatile memory (NVMEM0 ~ NVMEM3) and the word stored in the NVMEM0 will be used to set the tap register values when the device is powered up. The WMS7201 is controlled by a serial SPI interface that allows setting tap register value as well as storing data in the nonvolatile memory. 7.1. POTENTIOMETER AND RHEOSTAT MODES The WMS7201 can operate as either a rheostat or as a potentiometer (voltage divider). When in the potentiometer configuration there are two possible modes. One is without the output buffer and the other mode is with the output buffer. Selecting the mode is done by controlling bit D8 of the data register. D8 = 0 sets the output buffer off and D8 = 1 sets it on. Note that this bit can only be set by loading the value to the NVMEM with instructions #5 and then loading the TAP register with instruction #6 from NVMEM. This bit cannot be controlled by directly writing the value to the chip when the tap register is set. 7.1.1. Rheostat Configuration The WMS7201 acts as a two terminal resistive element in the rheostat configuration where one terminal is either one of the end point pins of the resistor (VA and VB) and the other terminal is the wiper (VW) pin. This configuration controls the resistance between the two terminals and the resistance can be adjusted by sending the corresponding tap register setting commands to the WMS7201 or loading a pre-set tap register value from nonvolatile memory NVMEM0 ~ MVMEM3. 7.1.2. Potentiometer Configuration In potentiometer configuration an input voltage is connected to one of the end point pins (VA or VB). The voltage on the wiper pin will be proportional to the voltage difference between VA and VB and the wiper setting. The resistance cannot be directly measured in this configuration. 7.2. PROGRAMMING MODES Two program modes are available for the WMS7201: • Direct program mode. The tap register setting can be changed either by loading a predetermined value from an external microcontroller or by using the UP/DOWN command. The UP and DOWN commands change the tap register setting incrementally i.e., 1 LSB at a time. The UP and DOWN commands will not wrap around at the ends of the scale. • NVMEM restore mode. One of the previously stored settings can be loaded into the TR register from the non-volatile memory. Four 9-bit non-volatile memories, are available for to store the tap register settings. The first register, NVMEM0, stores the favorite or default tap register setting that will be loaded into the tap register at system power up or software power on reset operation. -7- Publication Release Date: April 22, 2005 Revision 1.2 WMS7201 7.3. NON-VOLATILE MEMORY (NVMEM) The WMS7201 has four NVMEM positions available for storing the output buffer operating mode and the potentiometer setting. These NVMEM positions can be directly written through the SPI using a write command (#5) with address and data bytes. Another command (#7) is available that stores the current output buffer operating mode and potentiometer settings into the selected NVMEM position. Bit A3 and A2 in the instruction byte decide which NVMEM position is used. (See Table 5) The potentiometer is loaded with the value stored in the NVMEM position 0 on power up. 7.3.1 Write Protect of NVMEM Write-Protect ( WP ) disables any changes of current content in the NVMEM regardless of the commands, except that NVMEM setting can be retrieved using commands 4, 6 of Table 5. Therefore, Write-Protect ( WP ) pin provides hardware NVMEM protection feature with WP tied to Vss. WP , which is active at logic LOW, should be tied directly to VDD if it is not being used. This function is only available on the 10-pin package. 7.4 FLOW CONTROL Reading and writing to NVMEM requires an internal access cycle to complete before the next command can be sent. Read Tap Register (#2) Read NVMEM (#4) Program NVMEM (#5) Load Tap Register(#6) Program NVMEM with Tap Register (#7) -8- WMS7201 7.5. DAISY CHAIN Multiple devices can be controlled by the same bus without the need for extra CS lines from the microcontroller by daisy chaining the devices with the SDO of the first device connected to SDI of the next device as shown in figure 3 when using the 10-pin package. VDD CS CLK Micro controller SDO CS CLK CS CLK CS CLK SDI SDO SDI SDO SDI SDO Device Device Device FIGURE 3 – DAISY CHAIN CONFIGURATION [10-PIN TSSOP PACKAGE ONLY] A complete command is 24 bits including the instruction and the two data bytes. When shifting 24 bits in to the first device in the chain, the 24 bits of the previous command will be shifted out. So to set up two devices in a daisy chain, a total of 48 bits must be sent where the first 24 bits will be shifted out to the second device and the 24 bits shifted in last will remain in the first device. 1. Command and data for device 2 is shifted into device 1, this will propagate to Device 2 when the next 24 bits are shifted in. Device Command 1 Data 2 Data 2 Device xx xx xx 2. Command and data for device 1 is shifted into device 1. Now Device 1 and 2 are correctly set up. 10-pin TSSOP package only. Device Command 2 Data 1 Data Device Command 1 1 Data 2 Data 2 FIGURE 4 – DAISY CHAIN COMMAND EXAMPLE -9- Publication Release Date: April 22, 2005 Revision 1.2 WMS7201 7.6. SERIAL DATA ITERFACE The WMS7201 contains a four-wire SPI interface: • SDO (Serial Data Output) Used for reading out the internal register contents and for daisy chaining multiple devices on the 10-pin package. • SDI (Serial Data Input) Used for clocking in commands and potentiometer settings. • CS (Chip Select) This pin must be pulled LOW before starting to send a command and pulled HIGH to signal the end of the command; this pin can be used to control multiple devices on the bus. • CLK (Clock) The SDI bits are shifted in on the rising edge of the clock and SDO data is shifted out on the falling edge of the clock. The key features of this interface include: • Independently programmable Read & Write to all registers • Direct parallel refresh of Tap register from corresponding internal NVMEM registers • Increment and decrement instruction for Tap register • Nonvolatile storage of the present Tap register values into one of the four NVMEM registers available. • Configurable output buffer amplifier to allow both the functions of a potentiometer and a variable resistor • Four 9-bit non-volatile registers store four preset wiper positions and the first one will be recalled to set the wiper position during power up. The serial interface uses an SPI compatible uniform 24-bit word format as shown below. This format is used for all members of the WMS720x family. The data is sent MSB first. TABLE 2 – 24-BIT DATA WORD FORMAT MSB C3 LSB C2 C1 C0 A3 A2 A1 A0 X X X X X X X D8 D7 D6 D5 D4 D3 D2 D1 D0 C3-C0 are the command bits that control the operation of the digital potentiometer according to the command instructions shown in the Instruction Set in Table 5 in Section 7.7. A1 and A0 are the address bits that determine which channel is activated in the WMS720x family as shown in the table below. For the WMS7201 A0 and A1 are always set to 0. - 10 - WMS7201 TABLE 3 – A1 AND A0 ADDRESS BIT DECODE TABLE [A1 A0] [0 0] [0 1] [1 0] [1 1] Channel 0 1 2 3 A3 and A2 are the address bits that decide which NVMEM memory to be accessed, as shown in the table below. TABLE 4 – A3 AND A2 ADDRESS BIT DECODE TABLE [A3 A2] [0 0] [0 1] [1 0] [1 1] NVMEM 0 1 2 3 D7-D0 are the data values to be loaded into the Tap Register to set the wiper position, while D8 is used to set the output mode. D8 has to be loaded into the NVMEM0~3 first and then the “Load Tap Register” command (#6) has be executed to load D8 into the output-selection MUX to set the output mode. D8=0 sets the output to Buffer Off mode while D8=1 sets to Buffer On mode. CS is taken LOW before command starts CS 1 CLK 2 3 4 5 6 CS is taken HIGH after command is sent 7 8 9 1 0 C3 C2 C1 C0 A3 A2 A1 A0 x ` SDI x 1 1 1 1 2 3 x x 1 4 x x 1 1 1 5 6 7 1 1 8 9 2 0 2 2 1 2 2 2 3 4 x D8 D7 D6 D5 D4 D3 D2 D1 D0 Note: • A multiple of 24 bits must always be sent or the command will not be valid • Bits marked ‘x’ are don’t care bits. FIGURE 5 – SPI COMMAND WAVEFORMS - 11 - Publication Release Date: April 22, 2005 Revision 1.2 WMS7201 7.7. INSTRUCTION SET TABLE 5 – INSTRUCTION SET Inst No. Instruction Byte Data Byte 1 Data Byte 2 C3 C2 C1 C0 A3 A2 A1 A0 D15 D14 D13 D12 D11 D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0 Operation 1 0 0 0 0 x x x x x x x x x x x x x x x x x x x x No Operation (NOP). Do nothing 2 1 1 0 0 x x A1 A0 x x x x x x x x x x x x x x x x Read Tap Register and output selection MUX register 3 0 1 0 0 x x A1 A0 x x x x x x x x D7 D6 D5 D4 D3 D2 D1 D0 Write to Tap Register with D7-D0 4 1 0 1 0 A3 A2 A1 A0 x x x x x x x x x x x x x x x x Read NVMEM pointed to by A3-A0 5 0 0 1 0 A3 A2 A1 A0 x D8 x x x x x x 6 1 0 1 1 A3 A2 A1 A0 x x x x x x x x x x x x x x x x Load Tap Register and output selection MUX register with the contents of NVMEM pointed to by A3-A0 7 0 0 1 1 A3 A2 A1 A0 x x x x x x x x x x x x x x x x Program NVMEM pointed to by A3-A0 with the contents of Tap Register and output selection MUX register 8 0 1 1 1 x x A1 A0 x x x x x x x x x x x x x x x x Up: Increment setting of TR by one tap 9 1 1 1 1 x x A1 A0 x x x x x x x x x x x x x x x x Down: Decrement setting of TR by one tap 10 1 0 0 0 x x x x x x x x x x x x x x x x x x x x Sleep: Discontinue clock supply to the logic and memories 11 0 0 0 1 x x x x x x x x x x x x x x x x x x x x Wake Up: Clock supply to the logic and memories 12 1 1 0 1 A3 A2 A1 A0 x x x x x x x x x x x x x x x x Byte-erase NVMEM pointed to by A3-A0 13 1 0 0 1 x x x x x x x x x x x x x x x x Power On Reset: Software reset the part to the power up state x x x x D7 D6 D5 D4 D3 D2 D1 D0 Program NVMEM pointed to by A3-A0 with D8-D0 Note: C3-C0 are the command op-code; A3, A2 are the NVMEM address; A1, A0 are the channel address. 7.8. BASIC OPERATION This chapter describes the sequences of commands to send to the WMS7201 and how to use the different features. 7.8.1 Sending a Command 1. Take the chip out of SLEEP mode. 2. Check that the write protect is set correctly if writing to NVMEM (10-pin TSSOP package only). 3. Pull the CS pin LOW before sending data to the device. - 12 - WMS7201 4. 24 clock pulses are sent for each command. SDI must be valid on the rising edge of the clock, SDO is valid on the falling edge of the clock or CS . 5. Take CS HIGH after the command has completed 6. If command 2, 4, 5, 6 or 7 is sent, wait TSV time before sending the next command. 7.8.2 Wake Up/Sleep/Power Commands The chip is in SLEEP mode after: • VDD is applied • A Power on Reset command is sent • A SLEEP command is sent Before any operations can be performed the WAKE UP command must be sent. When a SLEEP command is sent, the chip retains its resistor settings as long as the chip is powered up but cannot accept any other commands than a WAKE UP command. TABLE 6 – POWER RELATED COMMANDS Inst. No. Command Name: Command Byte Data Byte 1 Data Byte 2 Comment 11 Wake Up 0001xxxx xxxxxxxx xxxxxxxx Wake Up entire chip 10 Sleep 1000xxxx xxxxxxxx xxxxxxxx Send chip into power save mode 13 Power on Reset 1001xxxx xxxxxxxx xxxxxxxx Reset Chip 1 NOP 0000xxxx xxxxxxxx xxxxxxxx Dummy instruction The commands above control the entire chip. 7.8.3 Write to Tap Register (TR) The microcontroller can write a value directly into the tap register or send an increment or decrement command to control the tap register. Alternatively, the contents of an NVMEM location can be written to the tap register. The only way to change the output buffer mode is to write the desired value of bit D8 into an NVMEM location and then load the corresponding NVMEM location into the tap register. - 13 - Publication Release Date: April 22, 2005 Revision 1.2 WMS7201 TABLE 7 – WRITING TO THE TAP REGISTERS Inst. No. Comman d Name: Command Byte Data Byte 1 Data Byte 2 Comment 3 Write to Tap Register 0100 x x00 xxxxxxxx D7 D6 D5 D4 D3 D2 D1 D0 Writes a value to the tap register. 8 Up 0111 x x00 xxxxxxxx xxxxxxxx Increment tap register value by one 9 Down 1111 x x00 xxxxxxxx xxxxxxxx Decrement tap register value by one 6 Load Tap Register 1 0 1 1 A3 A2 0 0 xxxxxxxx xxxxxxxx Load the selected NVMEM location into the tap register 7.8.4 Programming Non-Volatile Memory (NVMEM) The value stored in the NVMEM location is 9 bits, the 8 bits (D7-D0) of the tap register plus 1 bit (D8) of the output buffer mode. The NVMEM position must be erased before writing to it. There are two ways to program a value into NVMEM. Write a value directly from the microcontroller. Load the current potentiometer setting into NVMEM. TABLE 8 – PROGRAMMING NVMEM Inst. No Command Name Command Byte Data Byte 1 Data Byte 2 12 Erase NVMEM 1 1 0 1 A3 A2 0 0 xxxxxxxx x 5 Program NVMEM 0 0 1 0 A3 A2 0 0 x x x x x x x D8 D7 D6 D5 D4 D3 D2 D1 D0 Writes a value to the NVMEM register. 7 Program NVMEM with Tap Register 0 0 1 1 A3 A2 0 0 xxxxxxxx x Takes the current potentiometer settings and saves in the selected NVMEM location. x x x x x x Comment x x For programming NVMEM, the following sequence must be followed: 1. Erase word at NVMEM location 2. Program word at NVMEM location - 14 - x x x x x x Erases the 9 bit word pointed to by A3, A2, A1 and A0. WMS7201 7.8.5 Reading Tap Register and NVMEM Location (10-pin TSSOP package only) The contents of the tap register or any NVMEM location can be read back through the SDO pin. When a command is sent, the data is clocked out on the falling edge of the clock. Since daisy-chain operation requires data from one command to be clocked out when the next command arrives, any read command must be followed by another command to get the correct data on the SDO pin. TABLE 9 – READING THE TAP REGISTER Inst. No. Command Name: Command Byte Data Byte 1 Data Byte 2 Comment 4 Read NVMEM 1 0 1 0 A3 A2 0 0 xxxxxxxx x x x x x x x x Read the value of the selected NVMEM location 2 Read Tap Register 1100 x x00 xxxxxxxx x x x x x x x x Read the value of the selected tap register 1 NOP to Read Register 0000 x xxx x x x x x x x D8 D7 D6 D5 D4 D3 D2 D1 D0 Output data to SDO pin To read the contents of either the tap register or a NVMEM location, the following sequence must be followed. 1. Send the desired read command (#2 or #4) 2. Send another command such as NOP and read the SDO pin on the falling edge of the clock. The other command could be any command, but to make sure that the chip does not change anything, send either another Read command or a NOP command (#1). - 15 - Publication Release Date: April 22, 2005 Revision 1.2 WMS7201 8. TIMING DIAGRAMS CLK tCYC tWL tWH tLEAD tLAG CS tDSU tDH MSB SDI LSB tPD tLAC tLRL MSB SDO LSB tRSU R/B tST tSV 1 tWPSU WP tCS tWPH 2 FIGURE 6 – WMS7201 TIMING DIAGRAM Notes: (1) Internal signal only. (2) Only on 10-pin TSSOP package. - 16 - WMS7201 TABLE 10 – TIMING PARAMETERS PARAMETER SYMBOL MIN. SPI Clock Cycle Time tCYC 100 ns SPI Clock HIGH Time tWH 50 ns SPI Clock LOW Time tWL 50 ns Lead Time tLEAD 100 ns Lag Time tLAG 100 ns SDI Setup Time tDSU 20 ns SDI Hold Time tDH 20 ns CS to SDO – SPI Line Acquire 1 tLAC 5 ns CS to SDO – SPI Line Release 1 tLRL 5 ns 1 tPD 1 ns CLK to SDO Propagation Delay MAX. 2 UNIT Store to NVMEM Save Time tSV ms CS Deselect Time tCS 600 ns Startup Time tST 0.1 ms WP Setup Time 1 tWPSU 10 ns WP Hold Time 1 tWPH 10 ns Note: The interface timing characteristics apply to all parts but are guaranteed by design and not subject to production test. Note 1: 10-pin package only. - 17 - Publication Release Date: April 22, 2005 Revision 1.2 WMS7201 9. ABSOLUTE MAXIMUM RATINGS TABLE 11 – ABSOLUTE MAXIMUM RATINGS Condition Value Junction temperature 150ºC Storage temperature -65º to +150ºC Voltage applied to any pad (Vss – 0.3V) to (VDD + 0.3V) VDD – VSS -0.3 to 7.0V Note: Exposure to conditions beyond those listed under: Absolute Maximum Ratings, may adversely affect the life and reliability of the device. - 18 - WMS7201 10. ELECTRICAL CHARACTERISTICS TABLE 12 – ELECTRICAL CHARACTERISTICS All Parameters apply across specified operating ranges unless noted (VDD: 2.7V~5.5V; Temp: –40°C~85°C) Typical values: VDD=5V and T=25°C PARAMETER Rheostat Mode Nominal Resistance Different Non Linearity Integral Non Linearity R DNL INL Rheostat Tempco1 ΔRAB/ΔT Wiper Resistance2 RW Potentiometer Mode Resolution1 Different Non Linearity2 Integral Non Linearity2 Potentiometer Tempco1 Full Scale Error Zero Scale Error Resistor Terminal Voltage Range1 Terminal Capacitance1 Wiper Capacitance1 Dynamic Characteristics1 SYMBOL MIN. -20 -1 -1 MAX. UNITS 0.3 0.5 +20 +1 +1 % LSB LSB 500 N DNL INL ΔVw/ΔT 8 -1 -1 VFSE VZSE -1 0 VA,VB,VW CA, CB TYP 50 100 Ω 80 120 Ω +1 +1 +20 0 1 VSS VDD Bits LSB LSB ppm/° C LSB LSB V pF pF BW10K 1.5 MHz BW50K BW100K TS 300 200 80 KHz KHz uS B T=25ºC, VW open ppm/° C 30 30 B CONDITIONS VDD=5V, I=VDD/RTotal VDD=2.7V, I=VDD/RTotal Code = 80h Code = Full Scale Code = Zero Scale VDD=5V, VB=VSS B Code = Full Scale Bandwidth –3dB Settling Time to 1 LSB 100 Code = 80h CL=30pf VDD=5.5V=VA, VB=VSS B Analog Output (Buffer enabled) Amp Output Current2 IOUT Amp Output Resistance2 Rout Total Harmonic Distortion1 THD Digital Inputs/Outputs Input High Voltage Input Low Voltage Output Low Voltage Input Leakage Current VIH VIL VOL ILI 3 1 10 mA Ω 0.08 % 0.3VDD 0.4 +1 V V V uA 0.7VDD -1 - 19 - VO=1/2 scale VA=2.5V, VDD=5V, f=1kHz, VIN=1VRMS IOL=2mA CS =VDD,Vin=Vss Publication Release Date: April 22, 2005 Revision 1.2 WMS7201 Output Leakage Current ILo -1 +1 uA Input Capacitance1 CIN 25 pF Output Capacitance1 COUT 25 pF ~ VDD CS =VDD,Vin=VSS ~ VDD VDD=5V, fc = 1Mhz Code = 80h VDD=5V, fc = 1Mhz Code = 80h Power Requirements Operating Voltage1 VDD Operating Current IDDR Operating Current IDDW ISA Standby Current Power Supply Rejection Ratio 2.7 5.5 V 1 1.8 mA 1 2 mA 1 mA 1 uA 1 LSB/V 0.5 ISB2 0.1 PSRR All ops except NVMEM program During Nonvolatile memory program Buffer is active, , no load Buffer is inactive, Power Down, No load VDD=5V±10%, Code=80h Note: 1. Not subject to production test; 2. Only on Final Test; 3. VDD = +2.7V to 5.5V, VSS = 0V, T = 25ºC, unless otherwise noted. - 20 - WMS7201 10.1 TEST CIRCUITS VA VW V+ V+ = VDD 1LSB= V+/255 VA VW V+ VB WMS7201 VMS* B VB WMS7201 VMS* B *Assume infinite input impedance *Assume infinite input impedance Potentiometer divider nonlinearity error test circuit (INL, DNL) Power supply sensitivity test circuit (PSS, PSRR) No Connection VA WMS7201 IW VA V+ = VDD ±10% PSRR(dB) = 20LOG( ΔVMS ) ΔVDD VMS PSS(%/%) = Δ ΔVDD WMS7201 VW B VW W VB +5V VOUT VB VMS * B ~ VIN 2.5V DC Offset *Assume infinite input impedance Resistor position nonlinearity error test circuit (Rheostat Operation: R-INL, R-DNL) Capacitance test circuit VMS* VA VW WMS7201 +5V VA IW = VDD /RTotal IW VIN VW ~ VOUT VB B VB B WMS7201 RW = VMS /IW OFFSET GND 2.5V DC *Assume infinite input impedance Gain vs. frequency test circuit Wiper resistance test circuit FIGURE 7 – TEST CIRCUITS - 21 - Publication Release Date: April 22, 2005 Revision 1.2 WMS7201 11. TYPICAL APPLICATION CIRCUIT RA RB Vin WMS7201 _ OP AMP VOUT + VOUT = - VIN RA = RB RA RAB(256 − D) , 256 RB = B R AB D 256 RAB = Total resistance of potentiometer D = Wiper setting for WMS7201 FIGURE 8 – PROGRAMMABLE INVERTING GAIN AMPLIFIER USING THE WMS7201 VIN RA + OP _ AMP VOUT RB B WMS7201 VOUT = VIN (1+ RA = RB ) RA RAB(256 − D) R AB D , RB = 256 256 B RAB = Total resistance of potentiometer D = Wiper setting for WMS7201 FIGURE 9 – PROGRAMMABLE NON-INVERTING GAIN AMPLIFIER USING THE WMS7201 - 22 - WMS7201 V+ I = 32mA VREFH VREF = 5.0v WMS7201 GND FIGURE 10 – WMS7201 TRIMMING VOLTAGE REFERENCE VDD L1 CHOKE CS\ SDI CLK 1 2 3 4 CS CLK SDI VSS VDD VA1 VW1 VB1 C1 0.1uF 8 7 6 5 RF OUT Q1 FILTER RF POWER AMP WMS7201 WINPOT C2 RF Input FIGURE 11 – WMS7201 RF AMP CONTROL - 23 - Publication Release Date: April 22, 2005 Revision 1.2 WMS7201 11.1. LAYOUT CONSIDERATIONS A 0.1μF bypass capacitor as close as possible to the VDD pin is recommended for best performance. Often this can be done by placing the surface mount capacitor on the bottom side of the PC board, directly between the VDD and VSS pins. Care should be taken to separate the analog and digital traces. Sensitive traces should not run under the device or close to the bypass capacitors. A dedicated plane for analog ground helps in reducing ground noise for sensitive analog signals. FIGURE 12 – WMS7201 LAYOUT - 24 - WMS7201 12. PACKAGE DRAWINGS AND DEMINSIONS 8 5 c E HE L 4 1 0.25 D O A Y e SEATING PLANE GAUGE PLANE A1 b Control demensions are in milmeters . SYMBOL A A1 b c E D e HE Y L θ DIMENSION IN MM MAX. MIN. 1.35 1.75 0.10 0.25 0.51 0.33 0.19 0.25 3.80 4.00 4.80 5.00 1.27 BSC 6.20 5.80 0.10 0.40 1.27 0 10 DIMENSION IN INCH MIN. MAX. 0.053 0.069 0.010 0.004 0.013 0.020 0.008 0.010 0.150 0.157 0.188 0.196 0.050 BSC 0.228 0.016 0 0.244 0.004 0.050 10 FIGURE 13 – 8L SOIC – 150MIL - 25 - Publication Release Date: April 22, 2005 Revision 1.2 WMS7201 D 8 5 E1 4 1 B B 1 E S c A1 A A2 Base Plane Seating Plane L e1 α Symbol A A1 A2 B B1 c D E E1 e1 L α e S Dimension in inch Min Nom Min Nom 0.010 Max 4.45 0.175 0.25 0.125 0.130 0.135 3.18 3.30 3.43 0.016 0.018 0.022 0.41 0.46 0.56 0.058 0.060 0.064 1.47 1.52 1.63 0.008 0.010 0.014 0.20 0.25 0.36 0.360 0.380 9.14 9.65 0.300 0.310 7.37 7.62 7.87 0.245 0.250 0.255 6.22 6.35 6.48 0.090 0.100 0.110 2.29 2.54 2.79 0.120 0.130 0.140 3.05 3.30 3.56 15 0 9.02 9.53 0.290 0 A Dimension in mm Max 0.335 0.355 0.375 8.51 0.045 15 1.14 FIGURE 14 – 8L PDIP - 26 - eA WMS7201 FIGURE 15 – 8L MSOP - 27 - Publication Release Date: April 22, 2005 Revision 1.2 WMS7201 13. ORDERING INFORMATION Winbond’s WinPot Part Number Description: WMS72 XX XXX X Winbond WinPot Products Features: • 01: Single channel with SPI Interface • 02: Dual channels with SPI Interface • 04: Quad channels with SPI Interface End-to-end Resistance: • 010: 10KΩ • 050: 50KΩ • 100: 100KΩ Package Index: • T: TSSOP • S: SOIC • P: PDIP • M: MSOP (Available only for single channel devices) For the latest product information, access Winbond’s worldwide website at http://www.winbond-usa.com - 28 - WMS7201 14. VERSION HISTORY VERSION DATE DESCRIPTION 1.0 Jan. 2003 Initial issue 1.1 Jan. 2003 Correct typos 1.2 April. 2005 Revise disclaim section - 29 - Publication Release Date: April 22, 2005 Revision 1.2 WMS7201 Winbond products are not designed, intended, authorized or warranted for use as components in systems or equipment intended for surgical implantation, atomic energy control instruments, airplane or spaceship instruments, transportation instruments, traffic signal instruments, combustion control instruments, or for other applications intended to support or sustain life. Furthermore, Winbond products are not intended for applications wherein failure of Winbond products could result or lead to a situation wherein personal injury, death or severe property or environmental damage could occur. Winbond customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Winbond for any damages resulting from such improper use or sales. The contents of this document are provided only as a guide for the applications of Winbond products. Winbond makes no representation or warranties with respect to the accuracy or completeness of the contents of this publication and reserves the right to discontinue or make changes to specifications and product descriptions at any time without notice. No license, whether express or implied, to any intellectual property or other right of Winbond or others is granted by this publication. Except as set forth in Winbond's Standard Terms and Conditions of Sale, Winbond assumes no liability whatsoever and disclaims any express or implied warranty of merchantability, fitness for a particular purpose or infringement of any Intellectual property. The contents of this document are provided “AS IS”, and Winbond assumes no liability whatsoever and disclaims any express or implied warranty of merchantability, fitness for a particular purpose or infringement of any Intellectual property. In no event, shall Winbond be liable for any damages whatsoever (including, without limitation, damages for loss of profits, business interruption, loss of information) arising out of the use of or inability to use the contents of this documents, even if Winbond has been advised of the possibility of such damages. Application examples and alternative uses of any integrated circuit contained in this publication are for illustration only and Winbond makes no representation or warranty that such applications shall be suitable for the use specified. The 100-year retention and 100K record cycle projections are based upon accelerated reliability tests, as published in the Winbond Reliability Report, and are neither warranted nor guaranteed by Winbond. This product incorporates SuperFlash®. This datasheet and any future addendum to this datasheet is(are) the complete and controlling ISD® ChipCorder® product specifications. In the event any inconsistencies exist between the information in this and other product documentation, or in the event that other product documentation contains information in addition to the information in this, the information contained herein supersedes and governs such other information in its entirety. This datasheet is subject to change without notice. Copyright© 2005, Winbond Electronics Corporation. All rights reserved. ChipCorder® and ISD® are trademarks of Winbond Electronics Corporation. SuperFlash® is the trademark of Silicon Storage Technology, Inc. All other trademarks are properties of their respective owners. - 30 -
WMS7201050P 价格&库存
很抱歉,暂时无法提供与“WMS7201050P”相匹配的价格&库存,您可以联系我们找货
