74AHC594-Q100;
74AHCT594-Q100
8-bit shift register with output register
Rev. 4 — 7 July 2021
Product data sheet
1. General description
The 74AHC594-Q100; 74AHCT594-Q100 is a high-speed Si-gate CMOS device and is pin
compatible with Low-Power Schottky TTL (LSTTL). It is specified in compliance with JEDEC
standard No. 7-A.
The 74AHC594-Q100; 74AHCT594-Q100 is an 8-bit, non-inverting, serial-in, parallel-out shift
register that feeds an 8-bit D-type storage register. Separate clocks (SHCP and STCP) and direct
overriding clears (SHR and STR) are provided on both the shift and storage registers. A serial
output (Q7S) is provided for cascading purposes.
Both the shift and storage register clocks are positive-edge triggered. If the user wishes to connect
both clocks together, the shift register will always be one count pulse ahead of the storage register.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Wide supply voltage range from 2.0 V to 5.5 V
Balanced propagation delays
All inputs have Schmitt-trigger action
Overvoltage tolerant inputs to 5.5 V
High noise immunity
CMOS low power dissipation
8-bit serial-in, parallel-out shift register with storage
Independent direct overriding clears on shift and storage registers
Independent clocks for shift and storage registers
Latch-up performance exceeds 100 mA per JESD 78 Class II Level A
Input levels:
• For 74AHC594-Q100: CMOS level
• For 74AHCT594-Q100: TTL level
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pf, R = 0 Ω)
Multiple package options
DHVQFN package with Side-Wettable Flanks enabling Automatic Optical Inspection (AOI) of
solder joints
3. Applications
Serial-to parallel data conversion
Remote control holding register
Nexperia
4. Ordering information
Table 1. Ordering information
Type number
Package
74AHC594D-Q100
Temperature
range
Name
Description
Version
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
-40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package; 16 leads; SOT403-1
body width 4.4 mm
-40 °C to +125 °C
DHVQFN16 plastic dual in-line compatible thermal
enhanced very thin quad flat package; no leads;
16 terminals; body 2.5 × 3.5 × 0.85 mm
74AHCT594D-Q100
74AHC594PW-Q100
74AHCT594PW-Q100
74AHC594BQ-Q100
74AHCT594BQ-Q100
SOT763-1
5. Functional diagram
14
DS
11
SHCP
10
SHR
8-STAGE SHIFT REGISTER
9
12
STCP
13
STR
8-BIT STORAGE REGISTER
15 1
2
3
4
5
6
7
Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7
Fig. 1.
mbc320
Functional diagram
SHCP STCP
11
STR
12
9
DS
Fig. 2.
Q7S
74AHC_AHCT594_Q100
Product data sheet
Q7S
SHR
R2
12
10
11
C2
R1 SRG8
15
Q0
1
Q1
2
Q2
3
Q3
2
4
Q4
3
5
Q5
4
6
Q6
7
Q7
14
Logic symbol
STCP
13
10
13
SHR
STR
SHCP
DS
14
C1/
1D
15
2D
1
5
6
7
9
mbc319
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
Q7S
mbc322
Fig. 3.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 20
Nexperia
STAGE 0
DS
D
STAGES 1 TO 6
Q
D
STAGE 7
Q
D
FFSH0
CP
Q7S
Q
FFSH7
CP
R
R
SHCP
SHR
D
D
Q
FFST0
CP
Q
FFST7
CP
R
R
STCP
STR
Q0
Fig. 4.
Q1 Q2 Q3 Q4 Q5 Q6
Q7
mbc321
Logic diagram
6. Pinning information
6.1. Pinning
74AHC594
74AHCT594
Q1
1
16 VCC
Q2
2
15 Q0
Q3
3
14 DS
Q4
4
13 STR
Q5
5
12 STCP
Q6
6
11 SHCP
Q7
7
10 SHR
GND
8
9
Q7S
001aae343
Fig. 5.
Pin configuration SOT109-1 (SO16)
74AHC_AHCT594_Q100
Product data sheet
3 / 20
Nexperia
1
Q1
terminal 1
index area
2
Q3
3
14 DS
Q4
4
13 STR
Q5
5
12 STCP
Q6
6
11 SHCP
Q7
7
10 SHR
GND
8
9
3
14 DS
Q4
4
13 STR
Q5
5
12 STCP
Q6
6
Q7
7
GND(1)
11 SHCP
10 SHR
001aae345
Transparent top view
(1) This is not a ground pin. There is no electrical or
mechanical requirement to solder the pad. In case
soldered, the solder land should remain floating or
connected to GND
Q7S
001aae344
Fig. 6.
Q3
9
Q2
16 VCC
15 Q0
15 Q0
Q7S
1
2
8
Q1
Q2
GND
74AHC594
74AHCT594
16 VCC
74AHC594
74AHCT594
Pin configuration SOT403-1 (TSSOP16)
Fig. 7.
Pin configuration SOT763-1 (DHVQFN16)
6.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7
15, 1, 2, 3, 4, 5, 6, 7
parallel data output
GND
8
ground (0 V)
Q7S
9
serial data output
SHR
10
shift register reset input (active LOW)
SHCP
11
shift register clock input
STCP
12
storage register clock input
STR
13
storage register reset input (active LOW)
DS
14
serial data input
VCC
16
supply voltage
74AHC_AHCT594_Q100
Product data sheet
4 / 20
Nexperia
7. Functional description
Table 3. Function table
H = HIGH voltage state; L = LOW voltage state; ↑ = LOW to HIGH transition; X = don’t care; NC = no change.
Input
Output
Function
SHCP STCP SHR
STR
DS
Q7S
Qn
X
X
L
X
X
L
NC
a LOW-state on SHR only affects the shift register
X
X
X
L
X
NC
L
a LOW-state on STR only affects the storage register
X
L
H
X
L
L
empty shift register loaded into storage register
X
H
X
H
Q6S
NC
logic HIGH level shifted into shift register stage 0. Contents of all
shift register stages shifted through, e.g. previous state of stage 6
(internal Q6S) appears on the serial output (Q7S).
X
H
H
X
NC
QnS
contents of shift register stages (internal QnS) are transferred to
the storage register and parallel output stages
H
H
X
Q6S
QnS
contents of shift register shifted through; previous contents of the
shift register is transferred to the storage register and the parallel
output stages
SHCP
DS
STCP
SHR
STR
Q0
Q1
Q6
Q7
Q7S
mbc323
Fig. 8.
Timing diagram
74AHC_AHCT594_Q100
Product data sheet
5 / 20
Nexperia
8. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
Min
Max
Unit
supply voltage
-0.5
+7.0
V
VI
input voltage
-0.5
+7.0
V
IIK
input clamping current
VI < -0.5 V
[1]
-20
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
[1]
-20
+20
mA
IO
output current
VO = -0.5 V to (VCC + 0.5 V)
-25
+25
mA
ICC
supply current
+75
mA
IGND
ground current
-75
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
[2]
Conditions
Tamb = -40 °C to +125 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C.
For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C.
For SOT763-1 (DHVQFN16) package: Ptot derates linearly with 11.2 mW/K above 106 °C.
9. Recommended operating conditions
Table 5. Operating conditions
Symbol Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Δt/ΔV
Conditions
74AHC594-Q100
74AHCT594-Q100
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
5.5
4.5
5.0
5.5
V
V
VCC
V
VCC
+25
+125
-40
+25
input transition rise and fall rate VCC = 3.0 V to 3.6 V
100
ns/V
VCC = 4.5 V to 5.5 V
ns/V
74AHC_AHCT594_Q100
Product data sheet
+125 °C
6 / 20
Nexperia
10. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C
-40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
74AHC594-Q100
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
VCC = 5.5 V
1.65
1.65
1.65
V
VI = VIH or VIL
HIGH-level
output voltage
IO = -50 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -50 μA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = -50 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -4.0 mA; VCC = 3.0 V 2.58
2.48
2.40
V
IO = -8.0 mA; VCC = 4.5 V 3.94
3.80
3.70
V
VI = VIH or VIL
LOW-level
output voltage
IO = 50 μA; VCC = 2.0 V
0.1
0.1
V
IO = 50 μA; VCC = 3.0 V
0.1
0.1
V
IO = 50 μA; VCC = 4.5 V
0.1
0.1
V
IO = 4 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8 mA; VCC = 4.5 V
0.36
0.44
0.55
V
0.1
1.0
2.0
μA
II
input leakage
current
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
4.0
40
80
μA
CI
input
capacitance
3
10
10
10
pF
74AHC_AHCT594_Q100
Product data sheet
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
VI = VCC or GND
7 / 20
Nexperia
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C
Min
Typ
Max
Min
Max
Min
Max
74AHCT594-Q100
VIH
HIGH-level
input voltage
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
VI = VIH or VIL
HIGH-level
output voltage
4.4
4.5
4.4
4.4
V
3.80
3.70
V
VOL
VI = VIH or VIL
LOW-level
output voltage
0.1
0.1
V
0.36
0.44
0.55
V
0.1
1.0
2.0
μA
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
ICC
VCC = 5.5 V
4.0
40
80
μA
ΔICC
additional
per input pin;
supply current VI = VCC - 2.1 V; other pins
at VCC or GND; IO = 0 A;
1.35
1.5
1.5
mA
CI
input
capacitance
3
10
10
10
pF
VI = VCC or GND
11. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 15.
Symbol Parameter
Conditions
-40 °C to +85 °C -40 °C to +125 °C Unit
25 °C
Min Typ[1] Max
Min
Max
Min
Max
74AHC594-Q100
tPLH
LOW to HIGH SHCP to Q7S; see Fig. 9
propagation V = 3.0 V to 3.6 V
CC
delay
CL = 15 pF
5.2
8.5
2.2
9.7
2.2
10.6
ns
7.4
11.5
3.0
13.2
3.0
14.3
ns
CL = 15 pF
3.8
6.3
1.7
7.2
1.7
7.8
ns
CL = 50 pF
4.8
8.0
2.4
9.1
2.4
10.0
ns
CL = 15 pF
5.1
8.3
2.3
9.5
2.3
10.6
ns
CL = 50 pF
7.3
11.9
3.3
13.6
3.3
14.7
ns
CL = 15 pF
3.5
5.7
1.8
6.5
1.8
7.1
ns
CL = 50 pF
4.8
7.8
2.6
9.0
2.6
9.8
ns
CL = 50 pF
STCP to Qn; see Fig. 10
74AHC_AHCT594_Q100
Product data sheet
8 / 20
Nexperia
Symbol Parameter
Conditions
25 °C
Min Typ[1] Max
tPHL
HIGH to LOW SHCP to Q7S; see Fig. 9
CC
delay
CL = 15 pF
Min
Max
Min
Max
5.5
8.9
2.3
10.2
2.3
11.0
ns
7.4
12.1
3.0
13.9
3.0
15.1
ns
CL = 15 pF
4.1
6.7
1.9
7.6
1.9
8.2
ns
CL = 50 pF
5.4
8.8
2.5
10.1
2.5
11.0
ns
CL = 15 pF
5.5
9.1
2.4
10.4
2.4
11.3
ns
CL = 50 pF
7.3
12.0
3.2
13.8
3.2
15.0
ns
CL = 15 pF
3.7
6.0
1.9
6.9
1.9
7.5
ns
CL = 50 pF
5.2
8.5
2.6
9.7
2.6
10.5
ns
CL = 15 pF
5.7
9.5
2.3
10.8
2.3
11.7
ns
CL = 50 pF
7.5
12.2
3.6
14.0
3.6
15.2
ns
CL = 15 pF
4.1
6.7
2.0
7.6
2.0
8.2
ns
CL = 50 pF
5.4
8.8
2.8
10.1
2.8
11.0
ns
CL = 15 pF
5.8
9.6
2.8
11.0
2.8
12.0
ns
CL = 50 pF
7.7
12.5
3.8
14.4
3.8
15.6
ns
CL = 15 pF
4.1
7.2
2.2
8.2
2.2
8.9
ns
CL = 50 pF
5.4
9.4
3.0
10.7
3.0
11.6
ns
80
125
70
65
MHz
90
170
80
70
MHz
6.0
6.5
7.0
ns
5.5
6.0
6.5
ns
5.0
5.0
5.5
ns
5.0
5.2
5.7
ns
CL = 50 pF
SHR to Q7S; see Fig. 13
STR to Qn; see Fig. 12
fmax
tW
maximum
frequency
pulse width
SHCP or STCP;
see Fig. 9 and Fig. 10
SHCP and STCP HIGH or
LOW; see Fig. 9 and Fig. 10
SHR and STR HIGH or
LOW; see Fig. 13 and Fig. 12
74AHC_AHCT594_Q100
Product data sheet
9 / 20
Nexperia
Symbol Parameter
tsu
set-up time
Conditions
25 °C
Min Typ[1] Max
Min
Max
Min
Max
3.5
3.5
4.0
ns
3.0
3.0
3.5
ns
8.0
9.0
9.5
ns
5.0
5.0
5.5
ns
8.0
8.5
9.0
ns
5.0
5.0
5.5
ns
1.5
1.5
2.0
ns
2.0
2.0
2.5
ns
4.2
4.8
5.3
ns
2.9
3.3
3.8
ns
4.6
5.3
5.8
ns
3.2
3.7
4.3
ns
55
pF
3.8
6.3
1.7
7.2
1.7
7.8
ns
4.8
8.0
2.2
9.1
2.2
9.9
ns
CL = 15 pF
3.5
5.7
1.8
6.5
1.8
7.1
ns
CL = 50 pF
4.6
7.7
2.6
8.8
2.6
9.6
ns
4.1
6.7
1.8
7.6
1.8
8.3
ns
5.4
8.8
2.4
10.1
2.4
11.0
ns
CL = 15 pF
3.7
6.1
1.9
6.9
1.9
7.2
ns
CL = 50 pF
5.2
8.5
2.6
9.7
2.6
10.5
ns
CL = 15 pF
4.3
7.0
2.4
8.0
2.4
8.7
ns
CL = 50 pF
5.4
8.8
2.7
10.1
2.7
11.0
ns
CL = 15 pF
4.5
7.4
2.3
8.4
2.3
9.2
ns
CL = 50 pF
5.7
9.4
3.1
10.7
3.1
11.7
ns
90
160
80
70
DS to SHCP; see Fig. 11
SHR to STCP; see Fig. 14
SHCP to STCP; see Fig. 10
th
trec
hold time
recovery time SHR to SHCP; see Fig. 13
STR to STCP; see Fig. 12
CPD
power
dissipation
capacitance
fi = 1 MHz; VI = GND to VCC
[2]
74AHCT594-Q100; VCC = 4.5 V to 5.5 V
tPLH
propagation
CL = 15 pF
delay
CL = 50 pF
tPHL
propagation
CL = 15 pF
delay
CL = 50 pF
fmax
maximum
frequency
74AHC_AHCT594_Q100
Product data sheet
SHCP or STCP;
MHz
10 / 20
Nexperia
Symbol Parameter
tW
pulse width
tsu
set-up time
Conditions
25 °C
Min Typ[1] Max
Min
Max
Min
Max
5.5
6.0
6.5
ns
SHR and STR HIGH or
5.2
5.5
6.0
ns
3.0
3.0
3.5
ns
5.0
5.0
5.5
ns
5.0
5.0
5.5
ns
2.0
2.0
2.5
ns
th
hold time
trec
2.9
3.3
3.8
ns
3.4
3.8
4.3
ns
55
pF
CPD
[1]
[2]
power
dissipation
capacitance
[2]
Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V).
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL x VCC x fo) = sum of the outputs.
11.1. Waveforms and test circuit
1/fmax
SHCP input
VM
tW
tPLH
Q7S output
tPHL
VM
tTLH
tTHL
001aae341
Measurement points are given in Table 8.
Fig. 9.
Shift register clock pulse width, maximum frequency and input to output propagation delays
74AHC_AHCT594_Q100
Product data sheet
11 / 20
Nexperia
SHCP input
VM
tsu
1/fmax
VM
STCP input
tW
tPHL
tPLH
Qn outputs
VM
mla512
Fig. 10. Shift register clock to storage register clock set-up time and storage clock pulse width, maximum
VM
SHCP input
t su
t su
th
th
VM
DS input
VM
Q7 output
001aae342
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig. 11. Shift register clock to data input set-up and hold times
STR input
VM
tW
trec
VM
STCP input
tPHL
Qn outputs
VM
mbc325
Fig. 12. Storage register reset pulse width, input to output propagation delay and recovery time
74AHC_AHCT594_Q100
Product data sheet
12 / 20
Nexperia
SHR input
VM
tW
trec
VM
SHCP input
tPHL
VM
Q7S output
mbc324
Fig. 13. Shift register reset pulse width, input to output propagation delay and recovery time
SHR input
VM
tsu
STCP input
Qn outputs
VM
VM
mbc326
Fig. 14. Shift register reset to storage register clock set-up time
Table 8. Measurement points
Type
Input
Output
VM
VM
74AHC594-Q100
0.5 x VCC
0.5 x VCC
74AHCT594-Q100
1.5 V
0.5 x VCC
74AHC_AHCT594_Q100
Product data sheet
13 / 20
Nexperia
VI
negative
pulse
VM
VI
GND
VM
10 %
GND
positive
pulse
tW
90 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VO
RT
CL
001aah768
For test data see Table 9.
Definitions for test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
Fig. 15. Test circuit for measuring switching times
Table 9. Test data
Type
Load
Input
Test
VI
tr, tf
CL
74AHC594-Q100
VCC
≤ 3.0 ns
15 pF, 50 pF
tPLH, tPHL
74AHCT594-Q100
3.0 V
≤ 3.0 ns
15 pF, 50 pF
tPLH, tPHL
74AHC_AHCT594_Q100
Product data sheet
14 / 20
Nexperia
12. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.05
0.039
0.016
0.028
0.020
0.01
0.01
0.004
0.028
0.012
0.244
0.041
0.228
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 16. Package outline SOT109-1 (SO16)
74AHC_AHCT594_Q100
Product data sheet
15 / 20
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 17. Package outline SOT403-1 (TSSOP16)
74AHC_AHCT594_Q100
Product data sheet
16 / 20
Nexperia
DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT763-1
16 terminals; body 2.5 x 3.5 x 0.85 mm
B
D
A
A
E
A1
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
b
2
7
y
y1 C
v M C A B
w M C
L
1
8
Eh
e
16
9
15
10
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
c
D (1)
Dh
E (1)
Eh
e
e1
L
v
w
y
y1
mm
1
0.05
0.00
0.30
0.18
0.2
3.6
3.4
2.15
1.85
2.6
2.4
1.15
0.85
0.5
2.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT763-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig. 18. Package outline SOT763-1 (DHVQFN16)
74AHC_AHCT594_Q100
Product data sheet
17 / 20
Nexperia
13. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
LSTTL
Low-power Schottky Transistor-Transistor Logic
MIL
Military
MM
Machine Model
TTL
14. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74AHC_AHCT594_Q100 v.4
20210707
Product data sheet
Modifications:
74AHC_AHCT594_Q100 v.3
20200625
Modifications:
Type number 74AHCT594DB-Q100 (SOT338-1/SSOP16) removed.
20130704
Modifications:
74AHC_AHCT594_Q100 v.1
20120712
Product data sheet
Product data sheet
74AHC_AHCT594_Q100 v.2
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type number 74AHC594DB-Q100 (SOT338-1/SSOP16) removed.
Section 2 updated.
Table 4: Derating values for Ptot total power dissipation updated.
74AHC_AHCT594_Q100
Product data sheet
74AHC594DB-Q100 and 74AHCT594DB-Q100 added.
Product data sheet
18 / 20
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74AHC_AHCT594_Q100
Product data sheet
19 / 20
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Ordering information....................................................2
5. Functional diagram.......................................................2
6. Pinning information......................................................3
6.1. Pinning.........................................................................3
6.2. Pin description............................................................. 4
7. Functional description................................................. 5
8. Limiting values............................................................. 6
9. Recommended operating conditions..........................6
10. Static characteristics..................................................7
11. Dynamic characteristics.............................................8
11.1. Waveforms and test circuit.......................................11
12. Package outline........................................................ 15
13. Abbreviations............................................................ 18
14. Revision history........................................................18
15. Legal information......................................................19
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 7 July 2021
74AHC_AHCT594_Q100
Product data sheet
20 / 20
