74HC595-Q100; 74HCT595-Q100
8-bit serial-in, serial or parallel-out shift register with output
latches; 3-state
Rev. 4 — 11 March 2020
Product data sheet
1. General description
The 74HC595-Q100; 74HCT595-Q100 is an 8-bit serial-in/serial or parallel-out shift register with
a storage register and 3-state outputs. Both the shift and storage register have separate clocks.
The device features a serial input (DS) and a serial output (Q7S) to enable cascading and an
asynchronous reset MR input. A LOW on MR will reset the shift register. Data is shifted on the
LOW-to-HIGH transitions of the SHCP input. The data in the shift register is transferred to the
storage register on a LOW-to-HIGH transition of the STCP input. If both clocks are connected
together, the shift register will always be one clock pulse ahead of the storage register. Data in the
storage register appears at the output whenever the output enable input (OE) is LOW. A HIGH on
OE causes the outputs to assume a high-impedance OFF-state. Operation of the OE input does
not affect the state of the registers. Inputs include clamp diodes. This enables the use of current
limiting resistors to interface inputs to voltages in excess of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
8-bit serial input
8-bit serial or parallel output
Storage register with 3-state outputs
Shift register with direct clear
100 MHz (typical) shift out frequency
Complies with JEDEC standard no. 7A
Input levels:
• For 74HC595-Q100: CMOS level
• For 74HCT595-Q100: TTL level
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
Multiple package options
DHVQFN package with Side-Wettable Flanks enabling Automatic Optical Inspection (AOI) of
solder joints
3. Applications
Serial-to-parallel data conversion
Remote control holding register
Nexperia
8-bit serial-in, serial or parallel-out shift register with output latches; 3-state
4. Ordering information
Table 1. Ordering information
Type number
Package
74HC595D-Q100
Temperature range
Name
Description
Version
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
-40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package; 16 leads; SOT403-1
body width 4.4 mm
-40 °C to +125 °C
DHVQFN16 plastic dual in-line compatible thermal
enhanced very thin quad flat package; no leads;
16 terminals; body 2.5 × 3.5 × 0.85 mm
74HCT595D-Q100
74HC595PW-Q100
74HCT595PW-Q100
74HC595BQ-Q100
74HCT595BQ-Q100
SOT763-1
5. Functional diagram
14 DS
11 SHCP
10 MR
8-STAGE SHIFT REGISTER
Q7S
12 STCP
13 OE
9
8-BIT STORAGE REGISTER
3-STATE OUTPUTS
Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7
15 1
Fig. 1.
2
3
4
5
6
7
mna554
Functional diagram
13
11
12
SHCP STCP
Q7S
Q0
Q1
14
Q2
Q3
DS
Q4
Q5
Q6
Q7
MR
10
Fig. 2.
Logic symbol
74HC_HCT595_Q100
Product data sheet
EN3
12
10
11
9
15
14
1
C2
SRG8
R
C1/
1D
2D
3
2
1
2
3
3
4
4
5
5
6
6
7
7
OE
13
15
9
mna553
mna552
Fig. 3.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2020. All rights reserved
2 / 20
Nexperia
STAGE 0
DS
D
STAGES 1 TO 6
Q
STAGE 7
D
Q
D
CP
Q7S
Q
FF7
FF0
CP
R
R
SHCP
MR
D
Q
D
Q
LATCH
LATCH
CP
CP
STCP
OE
Q0
Fig. 4.
Q1 Q2 Q3 Q4 Q5 Q6
mna555
Q7
Logic diagram
6. Pinning information
6.1. Pinning
74HC595-Q100
74HCT595-Q100
Q1
1
16 VCC
Q2
2
15 Q0
Q3
3
14 DS
Q4
4
13 OE
Q5
5
12 STCP
Q6
6
11 SHCP
Q7
7
10 MR
GND
8
9
74HC595-Q100
74HCT595-Q100
Q7S
Q1
1
Q2
2
16 VCC
15 Q0
Q3
3
14 DS
Q4
4
13 OE
Q5
5
12 STCP
Q6
6
11 SHCP
Q7
7
10 MR
GND
8
Pin configuration for SOT109-1 (SO16)
74HC_HCT595_Q100
Product data sheet
Q7S
aaa-003477
aaa-003476
Fig. 5.
9
Fig. 6.
Pin configuration for SOT403-1 (TSSOP16)
3 / 20
Nexperia
1
Q1
terminal 1
index area
16 VCC
74HC595-Q100
74HCT595-Q100
Q2
2
15 Q0
Q3
3
14 DS
Q4
4
13 OE
Q5
5
12 STCP
Q6
6
Q7
7
GND(1)
11 SHCP
8
9
GND
Q7S
10 MR
aaa-003478
Transparent top view
(1) This is not a ground pin. There is no electrical or mechanical requirement to solder the pad. In case soldered,
the solder land should remain floating or connected to GND.
Fig. 7.
Pin configuration for SOT763-1 (DHVQFN16)
6.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7
15, 1, 2, 3, 4, 5, 6, 7
parallel data output
GND
8
ground (0 V)
Q7S
9
serial data output
MR
10
master reset (active LOW)
SHCP
11
shift register clock input
STCP
12
storage register clock input
OE
13
output enable input (active LOW)
DS
14
serial data input
Q0
15
parallel data output 0
VCC
16
supply voltage
74HC_HCT595_Q100
Product data sheet
4 / 20
Nexperia
7. Functional description
Table 3. Function table
H = HIGH voltage state; L = LOW voltage state; ↑ = LOW-to-HIGH transition;
X = don’t care; NC = no change; Z = high-impedance OFF-state.
Input Output
Control
Function
SHCP
STCP
OE
MR
DS
Q7S
Qn
X
X
L
L
X
L
NC
a LOW-level on MR only affects the shift registers
X
L
L
X
L
L
empty shift register loaded into storage register
X
X
H
L
X
L
Z
shift register clear; parallel outputs in high-impedance OFF-state
X
L
H
H
Q6S
NC
logic HIGH-level shifted into shift register stage 0. Contents of all
shift register stages shifted through, e.g. previous state of stage 6
(internal Q6S) appears on the serial output (Q7S).
X
L
H
X
NC
QnS
contents of shift register stages (internal QnS) are transferred to the
storage register and parallel output stages
L
H
X
Q6S
QnS
contents of shift register shifted through; previous contents of the
shift register is transferred to the storage register and the parallel
output stages
SHCP
DS
STCP
MR
OE
Z-state
Q0
Z-state
Q1
Z-state
Q6
Z-state
Q7
Q7S
mna556
Fig. 8.
Timing diagram
74HC_HCT595_Q100
Product data sheet
5 / 20
Nexperia
8. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Max
VCC
supply voltage
IIK
input clamping current
IOK
IO
Unit
-0.5
+7
V
VI < -0.5 V or VI > VCC + 0.5 V
±20
mA
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
±20
mA
output current
VO = -0.5 V to (VCC + 0.5 V)
pin Q7S
±25
mA
pins Qn
±35
mA
70
mA
ICC
supply current
IGND
ground current
-70
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
[1]
For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C.
For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C.
For SOT763-1 (DHVQFN16) package: Ptot derates linearly with 11.2 mW/K above 106 °C.
9. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
74HC595-Q100
74HCT595-Q100
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Δt/ΔV
input transition rise and fall
rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
-40
+25
+125
-40
+25
+125
VCC
supply voltage
VI
Tamb
ambient temperature
°C
10. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Typ
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
V
74HC595-Q100
VIH
VIL
HIGH-level
input voltage
LOW-level
input voltage
74HC_HCT595_Q100
Product data sheet
6 / 20
Nexperia
Symbol Parameter
VOH
HIGH-level
output voltage
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Typ
Max
Min
Max
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
V
IO = -4 mA; VCC = 4.5 V
3.84
4.32
3.7
V
IO = -5.2 mA; VCC = 6.0 V
5.34
5.81
5.2
V
IO = -6 mA; VCC = 4.5 V
3.84
4.32
3.7
V
IO = -7.8 mA; VCC = 6.0 V
5.34
5.81
5.2
V
IO = 20 μA; VCC = 2.0 V
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
V
IO = 4 mA; VCC = 4.5 V
0.15
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.33
0.4
V
IO = 6 mA; VCC = 4.5 V
0.15
0.33
0.4
V
IO = 7.8 mA; VCC = 6.0 V
VI = VIH or VIL
all outputs
Q7S output
Qn bus driver outputs
VOL
LOW-level
output voltage
VI = VIH or VIL
all outputs
Q7S output
0.16
0.33
0.4
V
II
input leakage
current
VI = VCC or GND; VCC = 6.0 V
±1.0
±1.0
μA
IOZ
OFF-state
output current
VI = VIH or VIL; VCC = 6.0 V;
VO = VCC or GND
±5.0
±10
μA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
80
160
μA
CI
input
capacitance
3.5
pF
74HCT595-Q100
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
4.4
4.5
4.4
V
3.84
4.32
3.7
V
3.7
4.32
3.7
V
all outputs
IO = -20 μA
Q7S output
IO = -4 mA
IO = -6 mA
74HC_HCT595_Q100
Product data sheet
7 / 20
Nexperia
Symbol Parameter
VOL
LOW-level
output voltage
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Typ
Max
Min
Max
0.1
V
0.15
0.33
0.4
V
all outputs
IO = 20 μA
Q7S output
IO = 4.0 mA
0.16
0.33
0.4
V
II
input leakage
current
VI = VCC or GND; VCC = 5.5 V
IO = 6.0 mA
±1.0
±1.0
μA
IOZ
OFF-state
output current
VI = VIH or VIL; VCC = 5.5 V;
VO = VCC or GND
±5.0
±10
μA
ICC
supply current
VCC = 5.5 V
80
160
μA
ΔICC
additional
supply current
per input pin;
other inputs at VCC or GND;
IO = 0 A; VI = VCC - 2.1 V;
pins MR, SHCP, STCP, OE
150
675
735
μA
pin DS
25
113
123
μA
3.5
pF
CI
input
capacitance
11. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 14.
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
Min Typ[1] Max
-40 °C to
+125 °C
Min
Max
Min
Max
Unit
74HC595-Q100
tpd
propagation
delay
SHCP to Q7S; see Fig. 9
52
160
200
240
ns
VCC = 4.5 V
19
32
40
48
ns
VCC = 6 V
15
27
34
41
ns
VCC = 2 V
55
175
220
265
ns
VCC = 4.5 V
44
53
ns
VCC = 6 V
16
30
37
45
ns
VCC = 2 V
47
175
220
265
ns
VCC = 4.5 V
17
35
44
53
ns
VCC = 6 V
14
30
37
45
ns
STCP to Qn; see Fig. 10
tPHL
HIGH to LOW
propagation
delay
74HC_HCT595_Q100
Product data sheet
[2]
VCC = 2 V
[2]
MR to Q7S; see Fig. 12
8 / 20
Nexperia
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
Min Typ[1] Max
ten
tdis
tW
enable time
disable time
pulse width
OE to Qn; see Fig. 13
-40 °C to
+125 °C
Min
Max
Min
Max
Unit
[3]
VCC = 2 V
47
150
190
225
ns
VCC = 4.5 V
17
30
38
45
ns
VCC = 6 V
14
26
33
38
ns
VCC = 2 V
41
150
190
225
ns
VCC = 4.5 V
15
30
38
45
ns
VCC = 6 V
12
27
33
38
ns
VCC = 2 V
75
17
95
110
ns
VCC = 4.5 V
15
6
19
22
ns
VCC = 6 V
13
5
16
19
ns
VCC = 2 V
75
11
95
110
ns
VCC = 4.5 V
15
4
19
22
ns
VCC = 6 V
13
3
16
19
ns
VCC = 2 V
75
17
95
110
ns
VCC = 4.5 V
15
6
19
22
ns
VCC = 6 V
13
5
16
19
ns
VCC = 2 V
50
11
65
75
ns
VCC = 4.5 V
10
4
13
15
ns
VCC = 6 V
9
3
11
13
ns
VCC = 2 V
75
22
95
110
ns
VCC = 4.5 V
15
8
19
22
ns
VCC = 6 V
13
7
16
19
ns
VCC = 2 V
3
-6
3
3
ns
VCC = 4.5 V
3
-2
3
3
ns
VCC = 6 V
3
-2
3
3
ns
VCC = 2 V
50
-19
65
75
ns
VCC = 4.5 V
10
-7
13
15
ns
VCC = 6 V
9
-6
11
13
ns
[4]
SHCP HIGH or LOW; see Fig. 9
STCP HIGH or LOW;
see Fig. 10
MR LOW; see Fig. 12
tsu
set-up time
DS to SHCP; see Fig. 11
SHCP to STCP; see Fig. 11
th
trec
hold time
recovery time
74HC_HCT595_Q100
Product data sheet
MR to SHCP; see Fig. 12
9 / 20
Nexperia
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
Min Typ[1] Max
fmax
maximum
frequency
power
dissipation
capacitance
Min
Max
Min
Max
Unit
SHCP or STCP;
see Fig. 9 and Fig. 10
VCC = 2 V
9
30
4.8
4
MHz
VCC = 4.5 V
30
91
24
MHz
VCC = 6 V
CPD
-40 °C to
+125 °C
fi = 1 MHz; VI = GND to VCC
35
108
28
24
MHz
[5]
[6]
115
pF
74HCT595-Q100; VCC = 4.5 V to 5.5 V
propagation
delay
[2]
25
42
53
63
ns
[2]
24
40
50
60
ns
tPHL
HIGH to LOW
propagation
delay
23
40
50
60
ns
ten
enable time
[3]
21
35
44
53
ns
tdis
disable time
[4]
18
30
38
45
ns
tW
pulse width
16
6
ns
STCP HIGH or LOW;
see Fig. 10
16
5
ns
MR LOW; see Fig. 12
25
30
ns
16
5
ns
16
8
ns
tpd
tsu
set-up time
th
hold time
3
-2
3
3
ns
trec
recovery time
10
-7
13
15
ns
fmax
maximum
frequency
SHCP and STCP;
30
52
24
MHz
CPD
power
dissipation
capacitance
fi = 1 MHz;
VI = GND to VCC - 1.5 V
130
pF
[1]
[2]
[3]
[4]
[5]
[6]
[5]
[6]
Typical values are measured at nominal supply voltage.
tpd is the same as tPHL and tPLH.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
2
Σ(CL × VCC × fo) = sum of outputs;
CL = output load capacitance in pF;
VCC = supply voltage in V.
All 9 outputs switching.
74HC_HCT595_Q100
Product data sheet
10 / 20
Nexperia
11.1. Waveforms and test circuit
1/fmax
VI
SHCP input
VM
GND
tW
t PHL
t PLH
VOH
VM
Q7S output
VOL
mna557
Measurement points are given in Table 8.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 9.
Shift clock pulse, maximum frequency and input to output propagation delays
VI
SHCP input
VM
GND
1/fmax
t su
VI
STCP input
VM
GND
tW
t PHL
t PLH
VOH
VM
Qn output
VOL
mna558
Fig. 10. Storage clock to output propagation delays
74HC_HCT595_Q100
Product data sheet
11 / 20
Nexperia
VI
VM
SHCP input
GND
t su
t su
th
th
VI
VM
DS input
GND
VOH
VM
Q7S output
VOL
mna560
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig. 11. Data set-up and hold times
VI
VM
MR input
GND
tW
t rec
VI
SHCP input
VM
GND
t PHL
VOH
VM
Q7S output
VOL
mna561
Fig. 12. Master reset to output propagation delays
74HC_HCT595_Q100
Product data sheet
12 / 20
Nexperia
tr
tf
90 %
VM
OE input
10 %
tPLZ
tPZL
Qn output
VM
LOW-to-OFF
OFF-to-LOW
10 %
tPHZ
tPZH
90 %
Qn output
VM
HIGH-to-OFF
OFF-to-HIGH
outputs
enabled
outputs
enabled
outputs
disabled
msa697
Fig. 13. Enable and disable times
Table 8. Measurement points
Type
Input
Output
VM
VM
74HC595-Q100
0.5VCC
0.5VCC
74HCT595-Q100
1.3 V
1.3 V
74HC_HCT595_Q100
Product data sheet
13 / 20
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VCC
VO
RT
RL
S1
open
CL
001aad983
Test data is given in Table 9.
Definitions for test circuit:
CL = load capacitance including jig and probe capacitance.
RL = load resistance.
RT = termination resistance should be equal to the output impedance Zo of the pulse generator.
S1 = test selection switch.
Fig. 14. Test circuit for measuring switching times
Table 9. Test data
Type
Input
Load
S1 position
VI
tr, tf
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
74HC595-Q100
VCC
6 ns
50 pF
1 kΩ
open
GND
VCC
74HCT595-Q100
3V
6 ns
50 pF
1 kΩ
open
GND
VCC
74HC_HCT595_Q100
Product data sheet
14 / 20
Nexperia
12. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.05
0.039
0.016
0.028
0.020
0.01
0.01
0.004
0.028
0.012
0.244
0.041
0.228
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 15. Package outline SOT109-1 (SO16)
74HC_HCT595_Q100
Product data sheet
15 / 20
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 16. Package outline SOT403-1 (TSSOP16)
74HC_HCT595_Q100
Product data sheet
16 / 20
Nexperia
DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT763-1
16 terminals; body 2.5 x 3.5 x 0.85 mm
B
D
A
A
E
A1
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
b
2
7
y
y1 C
v M C A B
w M C
L
1
8
Eh
e
16
9
15
10
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
c
D (1)
Dh
E (1)
Eh
e
e1
L
v
w
y
y1
mm
1
0.05
0.00
0.30
0.18
0.2
3.6
3.4
2.15
1.85
2.6
2.4
1.15
0.85
0.5
2.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT763-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig. 17. Package outline SOT763-1 (DHVQFN16)
74HC_HCT595_Q100
Product data sheet
17 / 20
Nexperia
13. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT595_Q100 v.4 20200311
Product data sheet
74HC_HCT595_Q100 v.3
Modifications:
Type numbers 74HC595DB-Q100 and 74HCT595DB-Q100 (SOT338-1) removed.
Section 2 updated.
Table 4: Derating values for Ptot total power dissipation updated.
74HC_HCT595_Q100 v.3 20170228
Modifications:
Product data sheet
74HC_HCT595_Q100 v.2
Product data sheet
74HC_HCT595_Q100 v.1
Type numbers 74HC595DB-Q100 and 74HCT595DB-Q100 added.
74HC_HCT595_Q100 v.1 20120802
74HC_HCT595_Q100
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
74HC_HCT595_Q100 v.2 20130410
Modifications:
Product data sheet
Product data sheet
18 / 20
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74HC_HCT595_Q100
Product data sheet
19 / 20
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Ordering information....................................................2
5. Functional diagram.......................................................2
6. Pinning information......................................................3
6.1. Pinning.........................................................................3
6.2. Pin description............................................................. 4
7. Functional description................................................. 5
8. Limiting values............................................................. 6
9. Recommended operating conditions..........................6
10. Static characteristics..................................................6
11. Dynamic characteristics.............................................8
11.1. Waveforms and test circuit.......................................11
12. Package outline........................................................ 15
13. Abbreviations............................................................ 18
14. Revision history........................................................18
15. Legal information......................................................19
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 11 March 2020
74HC_HCT595_Q100
Product data sheet
20 / 20
