NAU8214YG
NAU8214YG
    NUVOTON(新唐)
    WFQFN20_EP
NAU8214YG 数据手册
NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier Table of Contents 1.1 1.2 Description .................................................................................................................................................. 2 Pin Descriptions .......................................................................................................................................... 3 Operating Characteristics ............................................................................................................................ 5 1.3 1.4 Absolute Maximum Ratings ......................................................................................................................... 6 1.5 Recommended Operating Conditions ......................................................................................................... 6 1.6 Special Feature Description ........................................................................................................................ 7 1.7 Device Protection .......................................................................................................................................16 1.7.1 Thermal Overload Protection ..............................................................................................................16 1.7.2 Short Circuit Protection .......................................................................................................................16 1.7.3 Supply under Voltage Protection .........................................................................................................16 1.8 Max Power Limiting feature ........................................................................................................................16 1.8.1 Power limiting VDD independent configuration ...................................................................................17 1.8.2 Power limiting VDD dependent configuration ......................................................................................17 1.8.3 ATTACK TIME, HOLD TIME, AND RELEASE TIME...........................................................................17 1.8.4 Attach time Plot ...................................................................................................................................18 1.8.5 Hold & Release plots ...........................................................................................................................18 1.9 Power up and Power down Control ............................................................................................................18 1.10 Application diagram ....................................................................................................................................19 1.10.1 Single ended input configuration .........................................................................................................19 1.10.2 Differential input configuration .............................................................................................................19 1.11 Component selection ..................................................................................................................................19 1.11.1 Coupling Capacitors ............................................................................................................................19 1.11.2 Bypass Capacitors ..............................................................................................................................20 1.12 Layout considerations ................................................................................................................................20 1.13 Class D without filter ...................................................................................................................................20 1.14 Class D with filter ........................................................................................................................................20 1.14.1 Ferrite Bead filter .................................................................................................................................21 1.14.2 LC filter ................................................................................................................................................21 1.15 NAU8214 EMI performance .......................................................................................................................22 Package Dimensions ...............................................................................................................................................23 1.16 20 Pin QFN Package ..................................................................................................................................23 1.17 8 pin SOP package ...................................................................................................................................24 Ordering Information ...............................................................................................................................................25 1.18 Nuvoton Part Number Description ..............................................................................................................25 NAU8214 Data Sheet Rev1.6 Page 1 of 25 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier 1.1 Description The NAU8214 is a mono high efficiency filter-free Class-D audio amplifier with variable gain amplifier, which is capable of driving a 4Ω load with up to 2.9W output power. This device provides chip enable pin with extremely low standby current and fast start-up time of 4ms.The NAU8214 is ideal for the portable applications of battery drive, low quiescent current (i.e. 1.7mA at 3.6V), Max power limiting function for a given load and superior EMI performance. It has the ability to configure the inputs in either single-ended or differential mode. NAU8214 is available in SOP-8 package. Key Features  Low Quiescent Current:  1.4mA at 3.6V  2.7mA at 5V  Powerful Mono Class-D Amplifier:           1.48 W (4Ω @ 3.6V, 10% THD+N)  1.2 W (4Ω @ 3.6V, 1% THD+N)  0.87 W (8Ω @ 3.6V, 10% THD+N)  0.71 W (8Ω @ 3.6V, 1% THD+N) 2.9W (4Ω @ 5V, 10% THD+N) 2.3W (4Ω @ 5V, 1% THD+N) 1.7W (8Ω @ 5V, 10% THD+N) 1.38W (8Ω @ 5V, 1% THD+N) Low Output Noise: 56 µVRMS (A –Weighted @3.6V) 82dB PSRR @217Hz Low Current Shutdown Mode Click-and Pop Suppression Max Power limiting feature Applications     Smartphones Tablet PCs Personal Navigation Devices Rugged hand held computer and two-way radios VIN Class D Modulator ALC VIP R PLMT NAU8214 Click / Pop Suppression Output Driver Current / Thermal Protection VDD VSS EN NAU8214 Block Diagram NAU8214 Data Sheet Rev1.6 Page 2 of 25 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier Pin Descriptions EN 1 8 VOUTN PLMT 2 7 GND VIP 3 6 VDD VIN 4 5 VOUTP NAU8214SG Package Package Material NAU8214SG 4mm x 5mm SOP-8 Green Part Number Dimension Package Package Material NAU8214YG 4mm x 4mm QFN-20 Green 1 NC 2 16 17 18 19 20 NAU8214 Data Sheet Rev1.6 VOUTP NC Dimension VSS(output stage GND VDD(output stage PWR Part Number NC NAU8214 MQFN 20-Pin 15 OUTLN 14 NC 13 GND 5 11 IPL Page 3 of 25 INL PLM 10 NC 9 NC 8 12 7 4 VIP NC 6 3 NC EN NC 1.2 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier Pin # Name Type Functionality 1 2 3 4 5 6 7 8 EN PLMT VIP VIN VOUTP VDD VSS VOUTN Digital Input Power Limiting Analog Input Analog Input Analog Output Supply Supply Analog Output Chip Enable (High = Power Up; Low = Power Down) Power Limiting Threshold Positive Differential Input Negative Differential Input Positive BTL Output Power Supply High Current Ground Negative BTL Output Table 1 NAU8214 Pin description NAU8214 Data Sheet Rev1.6 Page 4 of 25 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier 1.3 Operating Characteristics Conditions: EN = VDD = 5V, VSS = 0V, Av = 18dB, ZL = ∞, Bandwidth = 20Hz to 22kHz, T A = 25 °C Parameter Symbol Comments/Conditions Min Typ Max Units Power Delivered Output Power Pout Parameter Chip Enable (EN) Voltage Enable High Voltage Enable Low Input Leakage Current Thermal and Current Protection Thermal Shutdown Temperature ZL = 4Ω + 33µH THD + N = 10% ZL = 4Ω + 33µH THD + N = 1% ZL = 8Ω + 68µH THD + N = 10% ZL = 8Ω + 68µH THD + N = 1% Symbol VEN_H VEN_L VDD = 5.0V VDD = 3.6V VDD = 5.0V VDD = 3.6V VDD = 5.0V VDD = 3.6V VDD = 5.0V VDD = 3.6V Comments/Conditions VDD = 2.5V to 5.5V VDD = 2.5V to 5.5V 2.9 1.48 2.3 1.2 1.7 0.87 1.38 0.71 Min 0.1 Parameter ILIMIT RIN REN Symbol AV = 18dB Comments/Conditions Max 1.3 Thermal Shutdown Hysteresis Limiting Current Single Ended Input Resistance Resistance (EN pin to GND) Typ W Min 0.35 2.0 Units V V µA 150 °C 20 °C 2.0 10 300 A kΩ kΩ Typ Max Units Normal Operation Quiescent Current Consumption IQUI Shut Down Current Oscillator Frequency Efficiency Start Up Time Output Offset Voltage Common Mode Rejection Ratio IOFF fOSC η Tstart VOS CMRR Power Supply Rejection Ratio PSRR Noise Performance NAU8214 Data Sheet Rev1.6 VDD = 3.6V VDD = 5V EN = 0 1.4 2.7 0.5 300 91 4 ±1 60 92 82 mA mA µA kHz % ms mV dB dB dB VRIPPLE = 0.2Vpp@1kHz 80 dB VRIPPLE = 0.2Vpp@10kHz 60 dB VDD = 3.6V (A-weighted) 56 µVRMS SOP-8 (ZL=8Ω) fIN = 1KHz DC PSRR AC PSRR VRIPPLE = 0.2Vpp @217Hz Page 5 of 25 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier Parameter 1.4 Symbol Comments/Conditions Min Typ Max Units Absolute Maximum Ratings Parameter Symbol Condition Min Max Units DC Power Supply VDD VDD-VSS -0.30 +6.00 V Analog Input Voltage AVIN VIN-VSS -0.3 VDD+0.3 V Digital Input Voltage DVIN DVIN-VSS -0.3 VDD+0.3 V 3.2 Ω Minimum Load Resistance RL Continuous Power Dissipation PO WCSP, T=25°C 530 mW Continuous Power Dissipation PO WCSP, T=85°C 275 mW Storage temperature range Tst +150 °C -55 CAUTION: Do not operate at or near the maximum ratings listed for extended periods of time. Exposure to such conditions may adversely influence product reliability and result in failures not covered by warranty. 1.5 Recommended Operating Conditions Parameter DC Power Supply High-level input voltage(EN pin) Low-level input voltage(EN pin) Operating Temperature NAU8214 Data Sheet Rev1.6 Symbol Condition Min Typical Max Units VDD VDD-VSS 2.50 5.00 5.50 V VIH 1.30 V VIL TA -40 Page 6 of 25 +25 0.35 V +85 °C April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier Audio Precision NAU8214 THD+N vs.Output Power into 8 Ω + 66 μ 04/07/14 14:05:49 H, Gain = 18 dB TYPICAL PERFORMANCE CHARACTERISTICS 10 5 T H D + N ( % ) 2 1 0.5 0.2 0.1 0.05 0.02 0.01 100u 200u 500u 1m 2m 5m 10m 20m 50m 100m 200m 500m 1 2 5 10 OUTPUT POWER (W) Sweep Trace Color Line Style Thick Data Axis 1 2 3 1 1 1 Blue Green Red Solid Solid Solid 3 3 3 Anlr.THD+N Ratio Anlr.THD+N Ratio Anlr.THD+N Ratio Left Left Left Comment Audio Precision NAU8214 THD+N vs.Output Power into 4 Ω + 33 μ 04/07/14 13:54:18 A-A THD+N % vs Output Levl_8ohm.at27 H, Gain = 18 dB THD + N vs. Output Power into 8 Ω + 66 μH, Gain = 18 dB 10 5 T H D + N ( % ) 2 1 0.5 0.2 0.1 0.05 0.02 0.01 100u 200u 500u 1m 2m 5m 10m 20m 50m 100m 200m 500m 1 2 5 10 OUTPUT POWER (W) Sweep Trace Color Line Style Thick Data Axis Comment 1 2 3 1 1 1 Blue Green Red Solid Solid Solid 3 3 3 S2C.Anlr.THD+N Ratio S2C.Anlr.THD+N Ratio S2C.Anlr.THD+N Ratio Left Left Left VDD 2.5V VDD 3.6V VDD 5V A-A THD+N % vs Output Levl.at27 THD + N vs. Output Power into 4 Ω + 33 μH, Gain = 18 dB NAU8214 Data Sheet Rev1.6 Page 7 of 25 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier Audio Precision THD + N vs. Frequency, VDD = 5V, Rl=8ohm+66uH, Gain = 18dB 04/07/14 14:16:47 100 50 20 10 5 T H D + N ( % ) 2 1 0.5 0.2 0.1 0.05 0.02 0.01 0.005 0.002 0.001 10 20 50 100 200 500 1k 2k 5k 10k 20k 50k 100k Frequency (Hz) Sweep Trace Color Line Style Thick Data Axis Comment 1 2 3 1 1 1 Blue Green Red Solid Solid Solid 3 3 3 Anlr.THD+N Ratio Anlr.THD+N Ratio Anlr.THD+N Ratio Left Left Left OUTPUT POWER 0.25W OUTPUT POWER 0.5W OUTPUT POWER 1W Audio Precision THD + N vs. Frequency, VDD = 5V, 04/07/14 14:24:04 A-A THD+N % vs Frequency_8ohm.at27 Rl=4ohm+33uH, Gain = 18dB THD + N vs. Frequency, VDD = 5 V, RL = 8 Ω + 66 μH, Gain = 18 dB 100 50 20 10 5 T H D + N ( % ) 2 1 0.5 0.2 0.1 0.05 0.02 0.01 0.005 0.002 0.001 10 20 50 100 200 500 1k 2k 5k 10k 20k 50k 100k Frequency (Hz) Sweep Trace Color Line Style Thick Data Axis Comment 1 2 3 1 1 1 Blue Green Red Solid Solid Solid 3 3 3 Anlr.THD+N Ratio Anlr.THD+N Ratio Anlr.THD+N Ratio Left Left Left OUTPUT POWER 0.5W OUTPUT POWER 1W OUTPUT POWER 2W A-A THD+N % vs Frequency_4ohm.at27 THD + N vs. Frequency, VDD = 5 V, RL = 4 Ω + 33 μH, Gain = 18 dB NAU8214 Data Sheet Rev1.6 Page 8 of 25 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier Audio Precision THD + N vs. Frequency, VDD = 3.6V, Rl=8ohm+66uH, Gain = 18dB 04/07/14 14:43:34 100 50 20 10 5 T H D + N ( % ) 2 1 0.5 0.2 0.1 0.05 0.02 0.01 0.005 0.002 0.001 10 20 50 100 200 500 1k 2k 5k 10k 20k 50k 100k Frequency (Hz) Sweep Trace Color Line Style Thick Data Axis Comment 1 2 3 1 1 1 Blue Green Red Solid Solid Solid 3 3 3 Anlr.THD+N Ratio Anlr.THD+N Ratio Anlr.THD+N Ratio Left Left Left OUTPUT POWER 0.125W OUTPUT POWER 0.25W OUTPUT POWER 0.5W Audio Precision THD + N vs. Frequency, VDD = 3.6V, 04/07/14 14:29:03 A-A THD+N % vs Frequency_8ohm.at27 Rl=4ohm+33uH, Gain = 18dB THD + N vs. Frequency, VDD = 3.6 V, RL = 8 Ω + 66 μH, Gain = 18 dB 100 50 20 10 5 T H D + N ( % ) 2 1 0.5 0.2 0.1 0.05 0.02 0.01 0.005 0.002 0.001 10 20 50 100 200 500 1k 2k 5k 10k 20k 50k 100k Frequency (Hz) Sweep Trace Color Line Style Thick Data Axis Comment 1 2 3 1 1 1 Blue Green Red Solid Solid Solid 3 3 3 Anlr.THD+N Ratio Anlr.THD+N Ratio Anlr.THD+N Ratio Left Left Left OUTPUT POWER 0.25W OUTPUT POWER 0.5W OUTPUT POWER 1W A-A THD+N % vs Frequency_4ohm.at27 THD + N vs. Frequency, VDD = 3.6 V, RL = 4 Ω + 33 μH, Gain = 18 dB NAU8214 Data Sheet Rev1.6 Page 9 of 25 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier Audio Precision THD + N vs. Frequency, VDD = 2.5V, Rl=8ohm+66uH, Gain = 18dB 04/07/14 14:39:21 100 50 20 10 5 T H D + N ( % ) 2 1 0.5 0.2 0.1 0.05 0.02 0.01 0.005 0.002 0.001 10 20 50 100 200 500 1k 2k 5k 10k 20k 50k 100k Frequency (Hz) Sweep Trace Color Line Style Thick Data Axis Comment 1 2 3 1 1 1 Blue Green Red Solid Solid Solid 3 3 3 Anlr.THD+N Ratio Anlr.THD+N Ratio Anlr.THD+N Ratio Left Left Left OUTPUT POWER 0.0625W OUTPUT POWER 0.125W OUTPUT POWER 0.25W Audio Precision THD + N vs. Frequency, VDD = 2.5V, 04/07/14 14:33:12 A-A THD+N % vs Frequency_8ohm.at27 Rl=4ohm+33uH, Gain = 18dB THD + N vs. Frequency, VDD = 2.5 V, RL = 8 Ω + 66 μH, Gain = 18 dB 100 50 20 10 5 T H D + N ( % ) 2 1 0.5 0.2 0.1 0.05 0.02 0.01 0.005 0.002 0.001 10 20 50 100 200 500 1k 2k 5k 10k 20k 50k 100k Frequency (Hz) Sweep Trace Color Line Style Thick Data Axis Comment 1 2 3 1 1 1 Blue Green Red Solid Solid Solid 3 3 3 Anlr.THD+N Ratio Anlr.THD+N Ratio Anlr.THD+N Ratio Left Left Left OUTPUT POWER 0.125W OUTPUT POWER 0.25W OUTPUT POWER 0.5W A-A THD+N % vs Frequency_4ohm.at27 THD + N vs. Frequency, VDD = 2.5 V, RL = 4 Ω + 33 μH, Gain = 18 dB NAU8214 Data Sheet Rev1.6 Page 10 of 25 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier Supply Current vs. Supply Voltage 4 SUPPLY CURRENT (mA) 3.5 3 2.5 NO LOAD 2 RL = 4ohm+33uH 1.5 RL = 8ohm+66uH 1 0.5 SUPPLY VOLTAGE( V ) 0 2.5 3 3.5 4 4.5 5 5.5 Maximum Output Power vs Supply Voltage , RL=8Ω+33uH, Gain = 18dB 2 1.8 OUTPUT POWER (W) 1.6 1.4 1.2 1% 1 10% 0.8 0.6 0.4 0.2 SUPPLY VOLTAGE (V) 0 2.5 NAU8214 Data Sheet Rev1.6 3 3.5 Page 11 of 25 4 4.5 5 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier Maximum Output Power vs Supply Voltage , RL=4Ω+33uH, Gain = 18dB 3.5 OUTPUT POWER (W) 3 2.5 2 1% 1.5 10% 1 0.5 SUPPLY VOLTAGE (V) 0 2.5 3 3.5 4 4.5 5 Maximum Output Power vs Supply Voltage , RL=3Ω+33uH, Gain = 18dB 4 OUTPUT POWER (W) 3.5 3 2.5 1% 2 10% 1.5 1 0.5 SUPPLY VOLTAGE (V) 0 2.5 NAU8214 Data Sheet Rev1.6 3 3.5 Page 12 of 25 4 4.5 5 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier Efficiency vs. Output Power into 8ohm + 66uH 100.00 90.00 80.00 EFFICIENCY (%) 70.00 60.00 VDD 2.5V 50.00 VDD 3.6V 40.00 VDD 5V 30.00 20.00 10.00 OUTPUT POWER (W) 0.00 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 Efficiency vs. Output Power into 4ohm + 33uH 100.00 90.00 80.00 EFFICIENCY (%) 70.00 60.00 VDD 2.5V 50.00 VDD 3.6V 40.00 VDD 5V 30.00 20.00 10.00 OUTPUT POWER (W) 0.00 0 0.2 0.4 0.6 0.8 NAU8214 Data Sheet Rev1.6 1 1.2 1.4 1.6 1.8 Page 13 of 25 2 2.2 2.4 2.6 2.8 3 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier Supply Current vs. Output Power into 8ohm+66uH 450.0000 400.0000 SUPPLY CURRENT (mA) 350.0000 300.0000 250.0000 VDD 2.5V VDD 3.6V 200.0000 VDD 5V 150.0000 100.0000 50.0000 OUTPUT POWER (W) 0.0000 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 Supply Current vs. Output Power into 4ohm + 33uH 800.00 SUPPLY CURRENT (mA) 700.00 600.00 500.00 VDD 2.5V 400.00 VDD 3.6V 300.00 VDD 5V 200.00 100.00 OUTPUT POWER (W) 0.00 0 0.2 0.4 0.6 0.8 NAU8214 Data Sheet Rev1.6 1 1.2 1.4 1.6 1.8 Page 14 of 25 2 2.2 2.4 2.6 2.8 3 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier ALC release waveform , VDD 5V Input 0dBV / 3kHz sine Output LC Load 4ohm+30uH Start up time 4ms , VDD 5V Input 0dBV / 1kHz sine Output LC Load 4ohm+30uH NAU8214 Data Sheet Rev1.6 Page 15 of 25 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier 1.6 Special Feature Description The NAU8214 offers excellent quantity performance as high efficiency, high output power and low quiescent current. It also provides the following special features. 1.7 Device Protection The NAU8214 includes device protection for three operating scenarios. They are 1. 2. 3. Thermal Overload Short circuit Supply under voltage 1.7.1 Thermal Overload Protection When the device internal junction temperature reaches 150°C, the NAU8214 will disable the output drivers. When the device cools down and a safe operating temperature of 130°C has been reached for at least about 100ms, the output drivers will be enabled again. 1.7.2 Short Circuit Protection If a short circuit is detected on any of the pull-up or pull-down devices on the output drivers for at least 16.7µs, the output drivers will be disabled for 100ms. The output drivers will then are enabled again and check for the short circuit. If the short circuit is still present, the output drivers are disabled after 16.7µs. This cycle will continue until the short circuit is removed. The short circuit threshold is 2.0A at 3.6V. 1.7.3 Supply under Voltage Protection If the supply voltage drops under 2.1V, the output drivers will be disabled while the NAU8214 control circuitry still operates. This will avoid the battery supply to drag down too low before the host processor can safely shut down the devices on the system. If the supply drops further below 1.6 V the internal power on reset is activated and puts the entire device in power down state. 1.8 Max Power Limiting feature The NAU8214 has a unique feature that limits the Maximum output power delivered to the load. This Max power limit is set by using external resistor connected to the dedicated pin PLMT. Once the threshold is set, the NAU8214 will not allow the voltage output more than the set value irrespective of the power supply voltage variations. Because of this output voltage control, the NAU8214 is able to achieve Power limit function for any given load. There are two methods to set the maximum output amplitude threshold (Vout) during the limiting mode. The following equations show the Max output voltage limit in terms of external resistor (RLMT). In equation 1, RLMT is tied to GND, which sets (Vout) as VDD independent, unlike equations two where Vout is proportional to (VDD-1.2V). The maximum peak voltage (Vout) is VDD dependent with offset voltage 1.2V in equation 2. 1. Vout = 2. Vout = V with RLMT tied to ground V with RLMT tied to supply voltage The maximum output power is calculated from the following eq. Pout = ( √ ) Where R is the Load resistance (Speaker Resistance) If the supply voltage is lower than the pre-set Max Vout voltage, then the output signal will clip to the supply voltage rather than being limited by the power limiter. NAU8214 Data Sheet Rev1.6 Page 16 of 25 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier 1.8.1 Power limiting VDD independent configuration VIN 0.1uF Output Driver Class D Modulator ALC VIP 0.1uF VDD NAU8214 Click / Pop Suppression RLMT PLMT 10uF 0.1uF VSS VDD 1.8.2 Current / Thermal Protection EN Power limiting VDD dependent configuration VIN 0.1uF Class D Modulator ALC VIP Output Driver 0.1uF VDD VDD NAU8214 Click / Pop Suppression PLMT 10uF 0.1uF VSS RLMT VDD 1.8.3 Current / Thermal Protection EN ATTACK TIME, HOLD TIME, AND RELEASE TIME When the input to the NAU8214 exceeds a preset threshold, MPL reduces amplifier gain rapidly until its output settles to a target level. This gain level is maintained for a certain period. If the input does not exceed the threshold again, MPL increases the gain gradually. The attack time is the time taken to reduce the gain from maximum to minimum. The hold time is the time to sustain the reduced gain. The release time is the time taken to increase the gain from minimum to maximum. See below plots for these times. NAU8214 Data Sheet Rev1.6 Page 17 of 25 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier 1.8.4 Attach time Plot 1.8.5 Hold & Release plots 1.9 Power up and Power down Control When the supply voltage ramps up, the internal power on reset, circuit is triggered. At this time, all internal circuits will be set to power down state. The device can be enabled by setting the EN pin high. Upon setting the EN pin high, the device will go through an internal power up sequence in order to minimize ‘pops’ on the speaker output. The complete power up sequence will take about 4ms. The device will power down in about 30µs, when the EN pin is set low. It is important to keep the input signal at zero amplitude or enable the mute condition in order to minimize the ‘pops’ when the EN pin is toggled. NAU8214 Data Sheet Rev1.6 Page 18 of 25 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier 1.10 Application diagram 1.10.1 Single ended input configuration VIN 0.1uF Class D Modulator ALC VIP Output Driver 0.1uF R PLMT Click / Pop Suppression NAU8214 Current / Thermal Protection VDD 10uF 0.1uF VSS VDD EN 1.10.2 Differential input configuration VIN 0.1uF Class D Modulator ALC VIP Output Driver 0.1uF R PLMT Click / Pop Suppression NAU8214 Current / Thermal Protection VDD 10uF 0.1uF VSS VDD EN 1.11 Component selection 1.11.1 Coupling Capacitors An ac coupling capacitor (Cin) is used to block the dc content from the input source. The input resistance of the amplifier (Rin) together with the Cin will act as a high pass filter. So depending on the required cut off frequency the Cin can be calculated by using the following formula NAU8214 Data Sheet Rev1.6 Page 19 of 25 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier Where is the desired cut off frequency of the High pass filter. Input Cin Amplifier Output Rin(Input Resistance) 1.11.2 Bypass Capacitors Bypass capacitors are required to remove the ac ripple on the VDD pins. The value of these capacitors depends on the length of the VDD trace. In most cases, 10µF and 0.1µF are enough to get the good performance. 1.12 Layout considerations Good PCB layout and grounding techniques are essential to get the good audio performance. It is better to use low resistance traces as these devices are driving low impedance loads. The resistance of the traces has a significant effect on the output power delivered to the load. In order to dissipate more heat, use wide traces for the power and ground lines. 1.13 Class D without filter The NAU8214 is designed for use without any filter on the output line. That means the outputs can be directly connected to the speaker in the simplest configuration. This type of filter less design is suitable for portable applications where the speaker is very close to the amplifier. In other words, this is preferable in applications where the length of the traces between the speaker and amplifier is short. The following diagram shows this simple configuration. VOUTP VOUTN NAU8214 outputs connected to speaker without filter circuit 1.14 Class D with filter NAU8214 Data Sheet Rev1.6 Page 20 of 25 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier In some applications, short trace lengths are not possible because of speaker size limitations and other layout reasons. In these applications, the long traces will cause EMI issues. There are two types of filter circuits available to reduce the EMI effects. These are ferrite bead and LC filters. 1.14.1 Ferrite Bead filter The ferrite bead filters are used to reduce the high frequency emissions. The typical circuit diagram is shown in the figure. Ferrite Bead VOUTP 1nF Ferrite Bead VOUTN 1 nF NAU8214 outputs connected to speaker with Ferrite Bead filter The characteristic of ferrite bead is such that it offers higher impedance at high frequencies. For better EMI performance select ferrite bead which offers highest impedance at high frequencies, so that it will attenuate the signals at higher frequencies. Usually the ferrite beads have low impedance in the audio range, so it will act as a pass through filter in the audio frequency range. 1.14.2 LC filter The LC filter is used to suppress the low frequency emissions. The following diagram shows the NAU8214 outputs connected to the speaker with LC filter circuit. R L is the resistance of the speaker coil. L OUTLP RL C OUTLN C L NAU8214 outputs connected to speaker with LC filter NAU8214 Data Sheet Rev1.6 Page 21 of 25 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier Ls Input Output R Cs Standard Low pass LCR filter The following are the equations for the critically damped (ζ = 0.707) standard low pass LCR filter √ is the cutoff frequency √ The L and C values for differential configuration can be calculated by duplicating the single ended configuration values and substituting RL = 2R. 1.15 NAU8214 EMI performance The NAU8214 includes a spread spectrum oscillator for reduced EMI. The PWM oscillator frequency typically sweeps in a range of 300 kHz +/- 15 kHz in order to spread the energy of the PWM pulses over a larger frequency band. In addition, slew rate control on the output drivers allows the application of ‘filter less’ loads, while suppressing EMI at high frequencies. NAU8214 Data Sheet Rev1.6 Page 22 of 25 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier Package Dimensions 1.16 20 Pin QFN Package TOP VIEW 15 BOTTOM VIEW 11 16 11 10 10 6 6 15 16 20 20 1 NAU8214 Data Sheet Rev1.6 5 5 Page 23 of 25 1 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier 1.17 8 pin SOP package 8 5 E 4 1 Control demensions are in milmeters . E  NAU8214 Data Sheet Rev1.6 Page 24 of 25 April 22, 2015 NAU8214 2.9W Mono Filter-Free Class-D Audio Amplifier Ordering Information 1.18 Nuvoton Part Number Description NAU8214XG Package Material: G = Green Package Package Type: S = 8-pin SOP Package Y = 20-pin QFN Package Version History VERSION DATE PAGE DESCRIPTION Rev1.0 May, 2013 NA Preliminary Revision Rev 1.1 May, 2013 5 Rev1.2 November 2013 6-7 Rev1.3 December 2013 2 and 12 Added new package information Rev 1.4 August 28,2014 13 Added QFN20 Package info Rev1.5 October 27, 2014 7-15 Added Performance graphs. Rev 1.6 April 22, 2015 13-25 Corrected the ordering number for SOP 8 package. Populated the Power limiting table with resistance and Vout values. Added attack time, hold time, and release time plots PLM Table 2 Version History Important Notice Nuvoton products are not designed, intended, authorized or warranted for use as components in systems or equipment intended for surgical implantation, atomic energy control instruments, airplane or spaceship instruments, transportation instruments, traffic signal instruments, combustion control instruments, or for other applications intended to support or sustain life. Furthermore, Nuvoton products are not intended for applications wherein failure of Nuvoton products could result or lead to a situation wherein personal injury, death or severe property or environmental damage could occur. Nuvoton customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Nuvoton for any damages resulting from such improper use or sales. NAU8214 Data Sheet Rev1.6 Page 25 of 25 April 22, 2015
NAU8214YG 价格&库存
很抱歉,暂时无法提供与“NAU8214YG”相匹配的价格&库存,您可以联系我们找货
NAU8214YG
  • 980+6.03031980+0.78018
