X2C026000B71H-HZ
X2C026000B71H-HZ
    HELE(加高电子)
    SMD2016_4P
    无源晶振 -10℃~+60℃
X2C026000B71H-HZ 数据手册
CRYSTAL RESONATOR Seam Sealed Ceramic Package HSX211S Series Features: ƒ Ultra miniature SMD type crystal device. ƒ High precision and reliability with excellent heat resistance. ƒOptimal solution for smartphone applications with limited design space, miniaturized wireless module devices, RFID application, and other consumer based products. Dimension (mm): 5 0 . 2 Internal Connections ±0.1 ±0.1 3 4 H40YM 2 1 5 6 . 1 Frequency Recommended Land Pattern (mm) Standard Specification: TYPE ITEM Frequency Range Mode Frequency Tolerance Frequency Stability over Operating Temperature Operating Temperature Load Capacitance Drive Level Equivalent Series Resistance Storage Temp. Range *Packing Unit:3,000pcs/Reel. HSX211S 16~30MHz 30~66MHz Fundamental ±7ppm ~ ±50ppm (at. 25℃) , or Specify ±10ppm, or Specify -10 ~ +60 ℃, or Specify Series, 8pF, 10pF, 12pF, or Specify 10μW (100μW Max.) 100ΩMax. 80ΩMax. -40 ~ +125℃
X2C026000B71H-HZ 价格&库存
很抱歉,暂时无法提供与“X2C026000B71H-HZ”相匹配的价格&库存,您可以联系我们找货
X2C026000B71H-HZ
    • 1+1.71936
    • 10+1.38521
    • 30+1.24200
    • 100+1.06326
    • 500+0.98367
    • 1000+0.93593
    X2C026000B71H-HZ
    • 1+0.81662
    • 30+0.78592
    • 100+0.72452
    • 500+0.66312
    • 1000+0.63242
