19245
19245
    DESCO
    TESTER LOW RESISTANCE
19245 数据手册
  TECHNICAL BULLETIN TB-3055  Low Resistance Tester Operation and Maintenance Made in the United States of America ANSI/ESD S6.1 – Grounding “6.4.1 The resistance of the conductor from the groundable point ground of any ESD technical element (e.g. worksurface, floor, chair, wrist strap, etc.) to the common point ground or common connection point shall not be greater than 1 ohm. Where a resistor is used in the grounding conductor, the total resistance shall include the value of the resistor. 6.4.2 The resistance of the conductor from the common point ground to the AC equipment ground shall not be greater than 1 ohm.” Packaging 1 1 1 1 1 1 Figure 1. Desco 19245 Low Resistance Tester Low Resistance Tester Threaded Banana Plug Threaded Needle Point Alligator Clip Banana Jack Outlet Adapter Certificate of Calibration Features and Components A B Description C D E F G Desco’s Low Resistance Tester is designed to measures resistance of grounding paths of banana jacks and other equipment. Selectable Test Ranges:
19245 价格&库存
很抱歉,暂时无法提供与“19245”相匹配的价格&库存,您可以联系我们找货
