711
711
    SCS
    HOUSING PLSTC BLK 2.38"LX1.75"W
711 数据手册
Product Data Sheet Product Data Sheet 3M™ Charge Analyzer 711 The Charge Analyzer 711 is designed to test the performance of products used for the purpose of static control and elimination. The Charge Analyzer 711 can be used as a laboratory analytical tool, evaluating the performance of ionizing equipment, staticprotective packaging, work surfaces and personnel grounding systems. It is effective for use as a demonstration tool in employee static awareness training sessions. The Charge Analyzer 711 is powered by built-in rechargeable NiMH batteries or an AC wall plug-in adapter. All interfacing connections are made at the rear of the unit. Property Typical Value Dimensions Base unit: 152 L x 152 H x152 W mm (6 L x 6 H x 6 W inches) Weight 1.8 kg (4 lbs.) High Voltage Power Supply (internal) > 1100V positive or negative Low Voltage Power Supplies Built-in NiMH-rechargeable batteries, 1400 mAh AC/DC Adapter: secondary side, 12VDC/500 mA Operating Time (rechargeable batteries) 4 hours (approximately) with full charge Accuracy ± 10% Operating Functions CPM (positive/negative/automatic), voltmeter and fieldmeter Interfaces Analog output ± 2 V (± 1V, in 500V range for voltmeter), serial PC-COM, and external field sensor type 711 RS Displays LCD Settings – CPM Operating Function Starting voltage: 600V – 1200V n 1V-steps Stop voltage: 1V – 500V in 1V-steps (in decimal mode) Static Decay Time 0.1 seconds – 99.9 seconds Offset-Voltage Time 1-10 seconds in 1 second steps and 10-60 seconds in 10 seconds steps Voltmeter Operating Function Ranges: 25V, 100V, 500V, 1.0kV, 5.0kV and auto range Fieldmeter Operating Function Ranges: Manual 1.25kV/m, 5kV/m, 25kV/m, 50kV/m, 250kV/m and automatic Plate Electrode Stainless 152 x 152 mm (6 x 6 in.), removable, capacitance (20 ± 2) pF Cup Electrode Gold-plated electrode with 4 mm banana socket, for voltage measurements Selection of Operating Function Pre-setting is “FIELDMETER,” additional automatic settings by applying the plate or cup electrode Declaration of Conformity CE Product Data Sheet Product Data Sheet 3M™ Charge Analyzer 711 3M is a trademark of 3M Company. Important Notice All statements, technical information, and recommendations related to 3M’s products are based on information believed to be reliable, but the accuracy or completeness is not guaranteed. Before using this product, you must evaluate it and determine if it is suitable for your intended application. You assume all risks and liability associated with such use. Any statements related to the product which are not contained in 3M’s current publications, or any contrary statements contained on your purchase order shall have no force or effect unless expressly agreed upon, in writing, by an authorized officer of 3M. 3 Electronics Materials Solutions Division Static Control Products 926 JR Industrial Drive Sanford, NC 27332-9733 Toll-Free: 866-722-3736 International: 919-718-0000 Email: 3mstaticinfo@mmm.com www.3Mstatic.com Printed in USA. © 3M 2014. All rights reserved. 78-9102-1910-0 JHA Warranty; Limited Remedy; Limited Liability. This product will be free from defects in material and manufacture for one year from the time of purchase. 3M MAKES NO OTHER WARRANTIES INCLUDING, BUT NOT LIMITED TO, ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. If this product is defective within the warranty period stated above, your exclusive remedy shall be, at 3M’s option, to replace or repair the 3M product or refund the purchase price of the 3M product. Except where prohibited by law, 3M will not be liable for any indirect, special, incidental or consequential loss or damage arising from this 3M product, regardless of the legal theory asserted. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: SCS: 711
很抱歉,暂时无法提供与“711”相匹配的价格&库存,您可以联系我们找货
