Product Data Sheet
Product Data Sheet
3M™ EM Aware TNG ESD Event Monitor
The EM Aware TNG Event Monitor is designed to:
• Provide a real time detection of most ESD events, change of static voltage and
verification of critical environment ionizers (< + 5V offset)
• Continuously monitor the environment for ESD
• Provide a comprehensive diagnostic tool
The EM Aware TNG ESD Event Monitor measures parameters through a single remote
antenna, rejects most non-ESD events, and provides output of data.
Properties
Typical Value
ESD Event Monitor
Measurement
Magnitude of HF Electromagnetic Field by ESD Event
ESD Event Threshold Range
60 – 140 dBμV typical (default setting: 80dBμV)
Raw Input Signal
60 dBμV - 134 dBμV typical
Filtering Function
ESD
Static Voltage Monitor
Measurement
Change of static voltage
Static Voltage Setting Range (+/-)
12.5V, 100V, 250V, 500V, 1000V
Analog Output
Vout = 1 V (4 mA for 250Ω) typical for high negative static voltage value
range
Vout = 5 V (20 mA for 250Ω) typical for high positive static voltage value
range
Verification of Ionizer*
( Model 3M034-031-TNG only)
Compatible Ionizer
Monitoring Balance Range
Steady State DC Blower Ionizer
± 5V* *typical
Connectivity
Selection Guide
Model
3M034-031-TNG
3M034-030-TNG
Input
SMA Connector for Remote antenna
Outputs
RJ45 connector, 4-20mA analog output or RS485 as digital output
ESD
Events
Event
Magnitude
Event
Counter
Change
on Static
Voltage
Ionizer
Verification*
General
Alarm
Buzzer
Display
LCD
Power
Universal 100 - 240VAC 0.5A, ~ 50 - 60Hz
Output: 12VDC 1.5A
Dimension (approx.)
3.17" W x 2.23" H x 1.50" D (antenna not included)
(81 mm W x 57 mm H x 38 mm D)
Weight (approx.)
146g
*Only for ionizers having less than ± 5V offset
*Only for ionizers having less than + 5V offset
** The readings of ionization voltage and decay under identical conditions may not always be correlated with CPM. 3M™ EM Aware TNG ESD Event Monitor is not a
replacement for regular test of ionizer by CPM.
Product Data Sheet
Product Data Sheet
3M is a trademark of 3M Company.
Important Notice
All statements, technical information, and recommendations related to 3M’s products are based
on information believed to be reliable, but the accuracy or completeness is not guaranteed.
Before using this product, you must evaluate it and determine if it is suitable for your intended
application. You assume all risks and liability associated with such use. Any statements related
to the product which are not contained in 3M’s current publications, or any contrary statements
contained on your purchase order shall have no force or effect unless expressly agreed upon, in
writing, by an authorized officer of 3M.
3
Electronics Materials Solutions Division
Static Control Products
926 JR Industrial Drive
Sanford, NC 27332-9733
Toll-Free: 866-722-3736
International: 919-718-0000
Email: 3mstaticinfo@mmm.com
www.3Mstatic.com
Please recycle. Printed in USA.
© 3M 2014. All rights reserved.
78-9102-1947-2 JHA
Warranty; Limited Remedy; Limited Liability.
This product will be free from defects in material and manufacture for one year from the time of
purchase. 3M MAKES NO OTHER WARRANTIES INCLUDING, BUT NOT LIMITED
TO, ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A
PARTICULAR PURPOSE. If this product is defective within the warranty period stated above,
your exclusive remedy shall be, at 3M’s option, to replace or repair the 3M product or refund
the purchase price of the 3M product. Except where prohibited by law, 3M will not be liable
for any indirect, special, incidental or consequential loss or damage arising from this 3M
product, regardless of the legal theory asserted.
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
SCS:
3M3A1-C-TNG 3M2A3-C-TNG 3M2AM3-C-TNG 3M034-031-TNG 3M034-030-TNG 3M3A3-C-TNG 3M1A4-C-TNG
3M2AM2-C-TNG 3M2A2-C-TNG 3M2A4-C-TNG 3M2A6-C-TNG 3M2A1-C-TNG 3M3A5-C-TNG 3M3A4-C-TNG
很抱歉,暂时无法提供与“3M034-030-TNG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+13171.630821+1702.19751
