35014
35014
    DESCO
    ESD CARD HOLDER PROXIMITY VERT
35014 数据手册
OPENING 2 11/16" SPECIFICATIONS • • • • • • 4 3/8" • • • • nI edaM aciremA ADNEM Front MENDA Back Made In America Dissipative Vinyl Proximity Card Holder ◦ Material Thickness: 0.012" front, & 0.024" back ◦ Material Tolerance (thickness): ±10% ◦ Material Color: matte front & back Highly visible yellow header with ESD protective symbol Includes a 1/8" x 9/16" punch through slot located 3/8" from the top 2 11/16" x 4 3/8" (Outer Dimension) Opening along top Embossed with: Menda & Made In America along the bottom of card holder RTT: 10E6 to 10E10 ohms per ANSI/ESD S11.11 Tribocharging: < 100 volts Genuine Made in America - accept no substitutes We can do Customs just let us know your insert size "It should be understood that any object, item, material or person could be a source of static electricity in the work enviroment. Removal of unnecessary nonconductors, replacing nonconductive materials with dissipative or conductive materials and grounding all conductors are the principle methods of controlling static electricity in the workplace, regardless of the activity." [ESD Handbook ESD TR20.20-2008 section 2.4 Sources of Static Electricity] MADE IN AMERICA ± 1/16" tolerances on dimensions unless specified VERTICAL PROXIMITY ESD CARD HOLDER, 2 1/8" x 4" INSERT SIZE, W/ YELLOW HEADER 3651 WALNUT AVENUE, CHINO, CA 91710 PHONE: (909) 627-2453 FAX: (951) 755-8848 WEBSITE: Menda-ID.com © 2009 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 35014 DATE May 2010
35014
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款高性能的微处理器。
2. 器件简介:该器件是一款32位的ARM Cortex-M4处理器,适用于需要高性能计算和低功耗的应用场景。
3. 引脚分配:共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
4. 参数特性:工作电压为1.8V至3.6V,工作频率高达200MHz。
5. 功能详解:具备高级的中断管理功能,支持多种通信接口,如I2C、SPI、UART等。
6. 应用信息:广泛应用于工业控制、消费电子和物联网设备。
7. 封装信息:采用QFP封装,共有48个引脚,适用于表面贴装技术。
35014 价格&库存
很抱歉,暂时无法提供与“35014”相匹配的价格&库存,您可以联系我们找货
