37646
37646
    DESCO
    FOAM BLACK COND LEAD INS GRADE
37646 数据手册
Description: This foam is suitable for protection of static sensitive devices and assemblies, shunting of IC leads, and cushion packaging. It is non-sloughing, non-contaminating, and non-corrosive. The material will thermoform into simple shapes. Features: • Ideal for lead insertion packaging, providing ESD and physical protection to component leads • Shuntable, brings leads to equipotential, minimizing exposure to discharge • Conductive crosslink polyethylene foam, RTT < 104 ohms • Non-contaminating, corrosion resistant, will not affect solderability • Cross linked foam will not particulate; the choice for critical environments • 3.1 lb/ft density • Available in small, ready-to-use pieces Specifications: Item No. Thickness Size (in.) 37640 1/4 2-7/16 x 1 37641 1/4 3-3/16 x 1 Property Test Method Results 37643 1/4 3-3/16 x 1-7/8 Density ASTM D3575-84 3.1 lb/ft3 37644 1/4 3-1/2 x 3-1/2 Volume Resistivity ASTM D991-86
37646 价格&库存
很抱歉,暂时无法提供与“37646”相匹配的价格&库存,您可以联系我们找货
