INTEGRATED CIRCUITS
DATA SHEET
74ALVC16244; 74ALVCH16244
2.5 V/3.3 V 16-bit buffer/line driver
(3-state)
Product specification
Supersedes data of 1998 Jun 29
2003 May 14
Philips Semiconductors
(3-state)
74ALVC16244;
74ALVCH16244
FEATURES
DESCRIPTION
• Wide supply voltage range from 1.2 to 3.6 V
The 74ALVC16244; 74ALVCH16244 is a 16-bit
non-inverting buffer/line driver with 3-state outputs. The
device can be used as four 4-bit buffers, two 8-bit buffers
or one 16-bit buffer. The 3-state outputs are controlled by
the output enable inputs 1OE, 2OE, 3OE and 4OE. A
HIGH on nOE causes the outputs to assume a
high-impedance OFF-state.
• CMOS low power consumption
• MultiByte flow-through standard pin-out architecture
• Low inductance multiple VCC and GND pins for minimum
noise and ground bounce
• Direct interface with TTL levels
• Bus hold on data inputs (74ALVCH16244 only)
The 74ALVCH16244 has active bus hold circuitry which is
provided to hold unused or floating data inputs at a valid
logic level. This feature eliminates the need for external
pull-up or pull-down resistors.
• Output drive capability 50 Ω transmission lines at 85 °C
• Current drive ±24 mA at 3.0 V
• Complies with JEDEC standard no. 8-1 A
The 74ALVC16244 has 5 V tolerant inputs.
• ESD protection:
HBM EIA/JESD22-A114-A exceeds 2000 V
MM EIA/JESD22-A115-A exceeds 200 V.
QUICK REFERENCE DATA
GND = 0 V; Tamb = 25 °C; tr = tf ≤ 2.5 ns
SYMBOL
tPHL/tPLH
PARAMETERS
propagation delay nAn to nYn
CI
input capacitance
CPD
power dissipation capacitance per buffer
CONDITIONS
UNIT
VCC = 2.5 V; CL = 30 pF
1.9
ns
VCC = 3.3 V; CL = 50 pF
1.9
ns
5.0
pF
outputs enabled
25
pF
outputs disabled
4
pF
notes 1 and 2
Notes
1. CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in Volts;
N = total load switching outputs;
Σ(CL × VCC2 × fo) = sum of the outputs.
2. The condition is VI = GND to VCC.
2003 May 14
TYPICAL
2
(3-state)
74ALVC16244;
74ALVCH16244
FUNCTION TABLE
See note 1
INPUT
OUTPUT
nOE
nAn
nYn
L
L
L
L
H
H
H
X
Z
Note
1. H = HIGH voltage level;
L = LOW voltage level;
X = don’t care;
Z = high-impedance OFF-state.
ORDERING INFORMATION
PACKAGE
TYPE NUMBER
TEMPERATURE RANGE
PINS
PACKAGE
MATERIAL
CODE
74ALVC16244DL
−40 °C to +85 °C
48
SSOP48
plastic
SOT370-1
74ALVCH16244DL
−40 °C to +85 °C
48
SSOP48
plastic
SOT370-1
74ALVC16244DGG
−40 °C to +85 °C
48
TSSOP48
plastic
SOT362-1
74ALVCH16244DGG
−40 °C to +85 °C
48
TSSOP48
plastic
SOT362-1
2003 May 14
3
(3-state)
74ALVC16244;
74ALVCH16244
PINNING
PIN
PIN
SYMBOL
SYMBOL
DESCRIPTION
DESCRIPTION
25
3OE
output enable input (active LOW)
1
1OE
26
4A3
data input
2
1Y0
data output
27
4A2
data input
3
1Y1
data output
28
GND
ground (0 V)
4
GND
ground (0 V)
29
4A1
data input
5
1Y2
data output
30
4A0
data input
6
1Y3
data output
31
VCC
supply voltage
7
VCC
supply voltage
32
3A3
data input
8
2Y0
data output
33
3A2
data input
9
2Y1
data output
34
GND
ground (0 V)
10
GND
ground (0 V)
35
3A1
data input
11
2Y2
data output
36
3A0
data input
12
2Y3
data output
37
2A3
data input
13
3Y0
data output
38
2A2
data input
14
3Y1
data output
39
GND
ground (0 V)
15
GND
ground (0 V)
40
2A1
data input
16
3Y2
data output
41
2A0
data input
17
3Y3
data output
42
VCC
supply voltage
18
VCC
supply voltage
43
1A3
data input
19
4Y0
data output
44
1A2
data input
4Y1
data output
45
GND
ground (0 V)
21
GND
ground (0 V)
46
1A1
data input
22
4Y2
data output
47
1A0
data input
23
4Y3
data output
48
2OE
24
4OE
2003 May 14
4
(3-state)
74ALVC16244;
74ALVCH16244
handbook, halfpage
1OE
1
48 2OE
1Y0
2
47 1A0
1Y1
3
46 1A1
handbook,47
halfpage
2
1A0
GND
4
45 GND
1Y2
5
44 1A2
1Y3
6
43 1A3
VCC
7
42 VCC
2Y0
8
41 2A0
2Y1
9
40 2A1
GND 10
39 GND
2Y2 11
38 2A2
2Y3 12
46
1A3
1OE
37 2A3
36 3A0
3Y1 14
35 3A1
GND 15
34 GND
3Y2 16
33 3A2
3Y3 17
32 3A3
VCC 18
31 VCC
4Y0 19
30 4A0
4Y1 20
29 4A1
GND 21
28 GND
4Y2 22
27 4A2
4Y3 23
26 4A3
4OE 24
25 3OE
43
40
2OE
1Y2
3A2
1Y3
3A3
3OE
8
38
37
48
4A0
2Y1
4A1
33
2Y2
4A2
2Y3
4A3
11
12
4OE
32
17
3Y3
25
19
4Y0
4Y1
27
22
4Y2
26
23
4Y3
24
MNA996
MNA995
Fig.1 Pin configuration.
2003 May 14
16
3Y2
29
9
14
3Y1
30
2Y0
13
3Y0
35
6
2A1
2A3
3A1
5
2A0
2A2
1Y1
1
41
16244
3Y0 13
44
3A0
3
1A1
1A2
36
1Y0
Fig.2 Logic symbol.
5
(3-state)
handbook, halfpage
1
48
74ALVC16244;
74ALVCH16244
1EN
2EN
25
3EN
24
4EN
47
1
1
2
46
3
44
5
43
6
41
1
2
9
38
11
37
12
1
3
14
33
16
32
17
1
4
To internal
circuit
Data input
13
35
30
VCC
8
40
36
handbook, halfpage
MNA998
19
29
22
26
23
MNA997
Fig.3 Logic symbol (IEEC/IEC).
Fig.4 Bus hold circuit.
RECOMMENDED OPERATING CONDITIONS
SYMBOL
VCC
VI
PARAMETER
supply voltage
input voltage
CONDITIONS
MIN.
MAX.
UNIT
maximum speed performance
2.3
2.7
V
3.0
3.6
V
low-voltage applications
1.2
3.6
V
for pins nAn with bus hold
VCC
V
for pins nAn without bus hold
V
for pins nOE
V
VO
output voltage
VCC
V
Tamb
operating temperature
in free air
−40
+85
°C
tr, tf
input rise and fall times
VCC = 2.3 to 3.0 V
ns/V
VCC = 3.0 to 3.6 V
ns/V
2003 May 14
6
(3-state)
74ALVC16244;
74ALVCH16244
LIMITING VALUES
In accordance with the Absolute Maximum Rating System (IEC 60134); voltages are referenced to GND (ground = 0 V).
SYMBOL
PARAMETER
VCC
supply voltage
IIK
input diode current
VI
input voltage
CONDITIONS
MIN.
MAX.
UNIT
−0.5
+4.6
V
VI < 0
−50
mA
for data inputs with bus hold; note 1
−0.5
VCC + 0.5 V
for data inputs without bus hold; note 1 −0.5
+5.5
V
for control pins; note 1
−0.5
+5.5
V
±50
mA
IOK
output diode current
VO > VCC or VO < 0
VO
output voltage
note 1
−0.5
VCC + 0.5 V
IO
output source or sink current VO = 0 to VCC
±50
mA
ICC, IGND
VCC or GND current
±100
mA
Tstg
storage temperature
−65
+150
°C
Ptot
power dissipation
SSOP48 package
850
mW
TSSOP48 package
600
mW
Tamb = −40 to +85 °C; note 2
Notes
1. The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
2. For SSOP48 packages: above 55 °C the value of Ptot derates linearly with 11.3 mW/K.
For TSSOP48 packages: above 55 °C the value of Ptot derates linearly with 8 mW/K.
2003 May 14
7
(3-state)
74ALVC16244;
74ALVCH16244
DC CHARACTERISTICS
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
TEST CONDITIONS
SYMBOL
PARAMETER
TYP.(1)
MIN.
OTHER
MAX.
UNIT
VCC (V)
VIH
VIL
VOH
VOL
ILI
IIHZ, IILZ
IOZ
ICC
HIGH-level input
voltage
LOW-level input
voltage
HIGH-level output VI = VIH or VIL
voltage
IO = −100 µA
1.2
VCC
V
1.8
0.7 × VCC
0.9
V
2.3 to 2.7
1.7
1.2
V
2.7 to 3.6
2.0
1.5
V
1.2
GND
V
1.8
0.9
0.2 × VCC
V
2.3 to 2.7
1.2
0.7
V
2.7 to 3.6
1.5
0.8
V
1.8 to 3.6
VCC − 0.2
VCC
V
IO = −6 mA
1.8
VCC − 0.4
VCC − 0.10 −
V
IO = −6 mA
2.3
VCC − 0.3
VCC − 0.08 −
V
IO = −12 mA
2.3
VCC − 0.5
VCC − 0.17 −
V
IO = −18 mA
2.3
VCC − 0.6
VCC − 0.26 −
V
IO = −12 mA
2.7
VCC − 0.5
VCC − 0.14 −
V
IO = −24 mA
3.0
VCC − 1.0
VCC − 0.28 −
V
IO = 100 µA
1.8 to 3.6
GND
0.20
V
IO = 6 mA
1.8
0.09
0.30
V
IO = 6 mA
2.3
0.07
0.20
V
IO = 12 mA
2.3
0.15
0.40
V
IO = 18 mA
2.3
0.23
0.60
V
IO = 12 mA
2.7
0.14
0.40
V
IO = 24 mA
3.0
0.27
0.55
V
data pin with bus hold;
VI = VCC or GND
1.8 to 3.6
0.1
5
µA
data pin without bus hold;
VI = 5.5 V or GND
1.8 to 3.6
0.1
5
µA
control pin;
VI = 5.5 V or GND
1.8 to 3.6
0.1
5
µA
VI = VCC or GND
1.8 to 2.7
0.1
10
µA
3.6
0.1
15
µA
3-state output
VI = VCC or GND;
OFF-state current VI = VIH or VIL
1.8 to 2.7
0.1
5
µA
3.6
0.1
10
µA
quiescent supply
current
1.8 to 2.7
0.1
µA
2.3 to 3.6
0.2
40
µA
LOW-level output
voltage
input leakage
current
3-state input
current for
common I/O pins
2003 May 14
VI = VIH or VIL
VI = VCC or GND; IO = 0
8
(3-state)
74ALVC16244;
74ALVCH16244
TEST CONDITIONS
SYMBOL
PARAMETER
∆ICC
additional
quiescent supply
current per pin
TYP.(1)
MIN.
OTHER
MAX.
UNIT
VCC (V)
VI =VCC − 0.6 V; IO = 0
2.7 to 3.6
150
750
µA
data pin without bus hold 2.7 to 3.6
5
500
µA
control pin
2.7 to 3.6
5
500
µA
bus hold LOW
VI = 0.7 V; note 2
sustaining current VI = 0.8 V; note 2
2.3
45
µA
3.0
75
150
µA
bus hold HIGH
VI = 1.7 V; note 2
sustaining current VI = 2.0 V; note 2
2.3
−45
µA
3.0
−75
−175
µA
IBHLO
bus hold LOW
overdrive current
note 2
2.7
300
µA
3.6
450
µA
IBHHO
bus hold HIGH
overdrive current
note 2
2.7
−300
µA
3.6
−450
µA
IBHL
IBHH
Notes
1. All typical values are measured at Tamb = 25 °C.
2. Valid for data inputs of bus hold parts.
2003 May 14
9
(3-state)
74ALVC16244;
74ALVCH16244
AC CHARACTERISTICS
GND = 0 V; tr = tf ≤ 2.0 ns and CL = 30 pF for VCC < 2.7 V; tr = tf ≤ 2.5 ns and CL = 50 pF for VCC ≥ 2.7 V.
TEST CONDITIONS
SYMBOL
PARAMETER
MIN.
WAVEFORMS
TYP.
MAX.
UNIT
VCC (V)
Tamb = −40 to +85 °C; note 1
tPHL/tPLH
tPZH/tPZL
tPHZ/tPLZ
propagation
delay nAn to nYn
3-state output
enable time
nOE to nYn
3-state output
disable time
nOE to nYn
see Figs 5 and 7
see Figs 6 and 7
see Figs 6 and 7
1.2
5.8
ns
1.8
1.5
2.8
5.1
ns
2.3 to 2.7
1.0
1.9
3.7
ns
2.7
1.0
2.1
3.6
ns
3.0 to 3.6
1.0
1.9
3.0
ns
1.2
8.4
ns
1.8
1.5
3.8
7.1
ns
2.3 to 2.7
1.0
2.5
4.9
ns
2.7
1.0
2.9
4.9
ns
3.0 to 3.6
1.0
2.3
4.0
ns
1.2
5.9
ns
1.8
1.5
3.1
5.4
ns
2.3 to 2.7
1.0
2.1
4.1
ns
2.7
1.0
3.0
4.5
ns
3.0 to 3.6
1.0
2.7
4.1
ns
Note
Typical values for VCC = 2.3 to 2.7 V are measured at VCC = 2.5 V.
Typical values for VCC = 3.3 to 3.6 V are measured at VCC = 3.3 V.
AC WAVEFORMS
handbook, halfpage
VI
VM
nAn input
GND
tPHL
tPLH
VOH
VM
nYn output
VOL
MNB013
VM = 0.5VCC at VCC < 2.7 V and VM = 1.5 V at VCC ≥ 2.7 V.
VOL and VOH are the typical output voltage drop that occur with the output load.
Fig.5 Input (nAn) to output (nYn) propagation delays.
2003 May 14
10
(3-state)
74ALVC16244;
74ALVCH16244
VI
handbook, full pagewidth
nOE input
VM
GND
t PLZ
t PZL
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
t PZH
t PHZ
VOH
VY
output
HIGH-to-OFF
OFF-to-HIGH
VM
GND
outputs
enabled
outputs
enabled
outputs
disabled
MNA999
VX = VOL + 0.15 V at VCC < 2.7 V and VX = VOL + 0.3 V at VCC ≥ 2.7 V.
VY = VOH − 0.15 V at VCC < 2.7 V and VY = VOH − 0.3 V at VCC ≥ 2.7 V.
Fig.6 3-state enable and disable times.
S1
VCC
PULSE
GENERATOR
VI
RL
500 Ω
VO
2 × VCC
open
GND
D.U.T.
CL
RT
RL
500 Ω
MNA755
TEST
S1
VCC
VI
tPLH/tPHL
open
很抱歉,暂时无法提供与“74ALVC16244DGG,512”相匹配的价格&库存,您可以联系我们找货
