Opening
3-Hole Punch
Description:
#07450/16252 ESD Protective
Desco’s heavy weight (6 mil) sheet protector is made from a static dissipative coextruded
polyolefin material. The triboelectric charge generation of the material is negligible (tested per
EIA-541) to make them safe for use around ESD susceptible items. They are designed for top
loading a standard 8.5" x 11" sheet of paper and have a standard 3-hole punch for use with a
binder.
Electrical Properties:
Static Decay:
Surface Resistance:
< 1.0 sec.
1 x 10^4 < 1 x 10^11 ohms
per FTMS 101C, Method 4046
per ANSI/ESD STM11.11
Negligible
Negligible
.050 gm/10 min.
0.923 gm/cc
10%
90
56
230 gms
0.50
per
per
per
per
per
per
per
per
per
11.25"
Descoindustries.com
Specifications:
8.75"
9.25"
RoHS and REACH Compliance Statement
None of the RoHS restricted materials or REACH substances of very
high concern are intentionally added in manufacturing this product. Ref:
Directive 2002/95/EC Article 4.1. and Regulation (EC) No. 1907/2006.
See Desco Industries Inc. Limited Warranty at Desco.com.
Polycarbonate Haze:
Corrosivity:
Melt Index:
Density:
Haze:
60° gloss:
45° gloss:
Dart impact:
Coefficient of friction:
N-Octanoic Acid Free
Has No Measurable Outgassing
72 hour contact
FTMS 101C-3005
ASTM D-1238
ASTM D-1505
ASTM D-1003
ASTM D-2457
ASTM D-2457
ASTM D-1709
ASTM D-1894
Sheet protector has holes for standard US three ring binder.
Wording across ring hole area:
“DESCO IND. INC. #07470 STATIC SAFE”
Per ANSI/ESD S541 section 7.2.2 Resistance of Dissipative Materials “A static
dissipative material shall have a surface resistance of greater than or equal to
1.0 x 10^4 ohms but less than 1.0 x 10^11 ohms. Packaging materials that are in
intimate contact with devices should be dissipative.”
“It should be understood that any object, item, material or person could be a
source of static electricity in the work environment. Removal of unnecessary
nonconductors, replacing nonconductive materials with dissipative or conductive
materials and grounding all conductors are the principle methods of controlling
static electricity in the workplace, regardless of the activity.” [ESD Handbook ESD
TR20.20-2008 section 2.4 Sources of Static Electricity]
Inside Dimension Tolerances are -0/+1/4" unless specified
STATFREE® SHEET PROTECTOR, STATIC SAFE, 6 MIL
DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com
PHONE (909) 627-8178
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
PHONE (781) 821-8370
©2012 DESCO INDUSTRIES INC.
Employee Owned
Made in the
United States of America
Specifications and procedures subject to change without notice.
DRAWING NUMBER
07470
DATE:
April
2012
很抱歉,暂时无法提供与“07470”相匹配的价格&库存,您可以联系我们找货
